[U-Boot] [PATCH 1/5] arm: dts: exynos4x12: fix the minor things
Fixed the minor things. 1. Removed '`' thing in comments 2. Fix the wrong interrupts value from 77 to 131
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- arch/arm/dts/exynos4x12.dtsi | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/exynos4x12.dtsi b/arch/arm/dts/exynos4x12.dtsi index 5d58c6e..b83a0d3 100644 --- a/arch/arm/dts/exynos4x12.dtsi +++ b/arch/arm/dts/exynos4x12.dtsi @@ -14,7 +14,7 @@ * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as -` * published by the Free Software Foundation. + * published by the Free Software Foundation. */
#include "exynos4.dtsi" @@ -104,7 +104,7 @@ mshc_0: mmc@12550000 { compatible = "samsung,exynos4412-dw-mshc"; reg = <0x12550000 0x1000>; - interrupts = <0 77 0>; + interrupts = <0 131 0>; #address-cells = <1>; #size-cells = <0>; fifo-depth = <0x80>;
mshc_0 node should be overwriten the defined node in exynos4.dtsi. It's meaningless. So removed this node. Instead, use the node in exynos4.dtsi.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- arch/arm/dts/exynos4x12.dtsi | 13 ------------- 1 file changed, 13 deletions(-)
diff --git a/arch/arm/dts/exynos4x12.dtsi b/arch/arm/dts/exynos4x12.dtsi index b83a0d3..e5ac15a 100644 --- a/arch/arm/dts/exynos4x12.dtsi +++ b/arch/arm/dts/exynos4x12.dtsi @@ -27,7 +27,6 @@ pinctrl1 = &pinctrl_1; pinctrl2 = &pinctrl_2; pinctrl3 = &pinctrl_3; - mshc0 = &mshc_0; };
pd_isp: isp-power-domain@10023CA0 { @@ -100,16 +99,4 @@ clock-names = "sclk_fimg2d", "fimg2d"; status = "disabled"; }; - - mshc_0: mmc@12550000 { - compatible = "samsung,exynos4412-dw-mshc"; - reg = <0x12550000 0x1000>; - interrupts = <0 131 0>; - #address-cells = <1>; - #size-cells = <0>; - fifo-depth = <0x80>; - clocks = <&clock 301>, <&clock 149>; - clock-names = "biu", "ciu"; - status = "disabled"; - }; };
I think you mean 'The mshc_0 node overwrites the defined node...'
'So remove this node'
Will fix
Changed the compatible from generic thing to meaning compatible. "samsung,exynos-mmc" should be removed.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- arch/arm/dts/exynos4.dtsi | 25 +++++++++++++++---------- 1 file changed, 15 insertions(+), 10 deletions(-)
diff --git a/arch/arm/dts/exynos4.dtsi b/arch/arm/dts/exynos4.dtsi index 7de227c..312133c 100644 --- a/arch/arm/dts/exynos4.dtsi +++ b/arch/arm/dts/exynos4.dtsi @@ -111,44 +111,49 @@ interrupts = <7 63 0>; };
- sdhci@12510000 { + sdhci0: sdhci@12510000 { #address-cells = <1>; #size-cells = <0>; - compatible = "samsung,exynos-mmc"; + compatible = "samsung,exynos4412-sdhci"; reg = <0x12510000 0x1000>; interrupts = <0 75 0>; + status = "disabled"; };
- sdhci@12520000 { + sdhci1: sdhci@12520000 { #address-cells = <1>; #size-cells = <0>; - compatible = "samsung,exynos-mmc"; + compatible = "samsung,exynos4412-sdhci"; reg = <0x12520000 0x1000>; interrupts = <0 76 0>; + status = "disabled"; };
- sdhci@12530000 { + sdhci2: sdhci@12530000 { #address-cells = <1>; #size-cells = <0>; - compatible = "samsung,exynos-mmc"; + compatible = "samsung,exynos4412-sdhci"; reg = <0x12530000 0x1000>; interrupts = <0 77 0>; + status = "disabled"; };
- sdhci@12540000 { + sdhci3: sdhci@12540000 { #address-cells = <1>; #size-cells = <0>; - compatible = "samsung,exynos-mmc"; + compatible = "samsung,exynos4412-sdhci"; reg = <0x12540000 0x1000>; interrupts = <0 78 0>; + status = "disabled"; };
- dwmmc@12550000 { + mshc_0: dwmmc@12550000 { #address-cells = <1>; #size-cells = <0>; - compatible = "samsung,exynos-dwmmc"; + compatible = "samsung,exynos4412-dw-mshc"; reg = <0x12550000 0x1000>; interrupts = <0 131 0>; + status = "disabled"; };
Does the drivers need to change?
Already prepared to use these. On MMC of exynos, drivers can use both with legacy and DM.
When it changes to DM, i will remove everything relevant to legacy for exynos.
Best Regards, Jaehoon Chung
Didn't overwrite the node. Just reuse the parent node. And add the Exynos Series specific properties.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- arch/arm/dts/exynos4210-origen.dts | 24 ++++--------- arch/arm/dts/exynos4210-trats.dts | 37 +++++++------------- arch/arm/dts/exynos4210-universal_c210.dts | 36 ++++++++------------ arch/arm/dts/exynos4412-odroid.dts | 46 ++++++++++--------------- arch/arm/dts/exynos4412-trats2.dts | 54 +++++++++++++----------------- 5 files changed, 73 insertions(+), 124 deletions(-)
diff --git a/arch/arm/dts/exynos4210-origen.dts b/arch/arm/dts/exynos4210-origen.dts index 26c4d7f..a13d033 100644 --- a/arch/arm/dts/exynos4210-origen.dts +++ b/arch/arm/dts/exynos4210-origen.dts @@ -22,24 +22,12 @@ aliases { serial0 = "/serial@13800000"; console = "/serial@13820000"; - mmc2 = "/sdhci@12530000"; - }; - - sdhci@12510000 { - status = "disabled"; - }; - - sdhci@12520000 { - status = "disabled"; - }; - - sdhci@12530000 { - samsung,bus-width = <4>; - samsung,timing = <1 2 3>; - cd-gpios = <&gpk2 2 0>; }; +};
- sdhci@12540000 { - status = "disabled"; - }; +&sdhci2 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpk2 2 0>; + status = "okay"; }; diff --git a/arch/arm/dts/exynos4210-trats.dts b/arch/arm/dts/exynos4210-trats.dts index 2ed38f3..8154ca8 100644 --- a/arch/arm/dts/exynos4210-trats.dts +++ b/arch/arm/dts/exynos4210-trats.dts @@ -29,8 +29,6 @@ i2c7 = "/i2c@138d0000"; serial0 = "/serial@13800000"; console = "/serial@13820000"; - mmc0 = "/sdhci@12510000"; - mmc2 = "/sdhci@12530000"; };
fimd@11c00000 { @@ -97,28 +95,17 @@
samsung,dsim-device-reverse-panel = <1>; }; +};
- sdhci@12510000 { - samsung,bus-width = <8>; - samsung,timing = <1 3 3>; - pwr-gpios = <&gpk0 2 0>; - }; - - sdhci@12520000 { - status = "disabled"; - }; - - sdhci@12530000 { - samsung,bus-width = <4>; - samsung,timing = <1 2 3>; - cd-gpios = <&gpx3 4 0>; - }; - - sdhci@12540000 { - status = "disabled"; - }; - - dwmmc@12550000 { - status = "disabled"; - }; +&sdhci0 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpk0 2 0>; + status = "okay"; +}; +&sdhci2 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpx3 4 0>; + status = "okay"; }; diff --git a/arch/arm/dts/exynos4210-universal_c210.dts b/arch/arm/dts/exynos4210-universal_c210.dts index 8cac7dd..c6dda42 100644 --- a/arch/arm/dts/exynos4210-universal_c210.dts +++ b/arch/arm/dts/exynos4210-universal_c210.dts @@ -17,28 +17,6 @@ aliases { serial0 = "/serial@13800000"; console = "/serial@13820000"; - mmc0 = "/sdhci@12510000"; - mmc2 = "/sdhci@12530000"; - }; - - sdhci@12510000 { - samsung,bus-width = <8>; - samsung,timing = <1 3 3>; - pwr-gpios = <&gpk0 2 0>; - }; - - sdhci@12520000 { - status = "disabled"; - }; - - sdhci@12530000 { - samsung,bus-width = <4>; - samsung,timing = <1 2 3>; - cd-gpios = <&gpx3 4 0>; - }; - - sdhci@12540000 { - status = "disabled"; };
soft-spi { @@ -94,3 +72,17 @@ samsung,rgb-mode = <0>; }; }; + +&sdhci0 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpk0 2 0>; + status = "okay"; +}; + +&sdhci2 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpx3 4 0>; + status = "okay"; +}; diff --git a/arch/arm/dts/exynos4412-odroid.dts b/arch/arm/dts/exynos4412-odroid.dts index 188cb93..4a2cfa9 100644 --- a/arch/arm/dts/exynos4412-odroid.dts +++ b/arch/arm/dts/exynos4412-odroid.dts @@ -224,34 +224,6 @@ status = "okay"; };
- sdhci@12510000 { - status = "disabled"; - }; - - sdhci@12520000 { - status = "disabled"; - }; - - sdhci@12530000 { - samsung,bus-width = <4>; - samsung,timing = <1 2 3>; - cd-gpios = <&gpk2 2 0>; - }; - - sdhci@12540000 { - status = "disabled"; - }; - - dwmmc@12550000 { - samsung,bus-width = <8>; - samsung,timing = <2 1 0>; - samsung,removable = <0>; - fifoth_val = <0x203f0040>; - bus_hz = <400000000>; - div = <0x3>; - index = <4>; - }; - ehci@12580000 { compatible = "samsung,exynos-ehci"; reg = <0x12580000 0x100>; @@ -268,3 +240,21 @@ reset-gpio = <&gpk1 2 0>; }; }; + +&sdhci2 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpk2 2 0>; + status = "okay"; +}; + +&mshc_0 { + samsung,bus-width = <8>; + samsung,timing = <2 1 0>; + samsung,removable = <0>; + fifoth_val = <0x203f0040>; + bus_hz = <400000000>; + div = <0x3>; + index = <4>; + status = "okay"; +}; diff --git a/arch/arm/dts/exynos4412-trats2.dts b/arch/arm/dts/exynos4412-trats2.dts index 1fbcf89..541f5da 100644 --- a/arch/arm/dts/exynos4412-trats2.dts +++ b/arch/arm/dts/exynos4412-trats2.dts @@ -29,9 +29,6 @@ i2c7 = "/i2c@138d0000"; serial0 = "/serial@13800000"; console = "/serial@13820000"; - mmc0 = "/sdhci@12510000"; - mmc2 = "/sdhci@12530000"; - mshc0 = "/dwmmc@12550000"; };
i2c@138d0000 { @@ -412,35 +409,30 @@
- sdhci@12510000 { - samsung,bus-width = <8>; - samsung,timing = <1 3 3>; - pwr-gpios = <&gpk0 4 0>; - status = "disabled"; - }; - - sdhci@12520000 { - status = "disabled"; - }; - - sdhci@12530000 { - samsung,bus-width = <4>; - samsung,timing = <1 2 3>; - cd-gpios = <&gpk2 2 0>; - }; +&sdhci0 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + pwr-gpios = <&gpk0 4 0>; + status = "disabled"; +};
- sdhci@12540000 { - status = "disabled"; - }; +&sdhci2 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + cd-gpios = <&gpk2 2 0>; + status = "okay"; +};
- dwmmc@12550000 { - samsung,bus-width = <8>; - samsung,timing = <2 1 0>; - pwr-gpios = <&gpk0 4 0>; - fifoth_val = <0x203f0040>; - bus_hz = <400000000>; - div = <0x3>; - index = <4>; - }; +&mshc_0 { + samsung,bus-width = <8>; + samsung,timing = <2 1 0>; + samsung,removable = <0>; + fifoth_val = <0x203f0040>; + bus_hz = <400000000>; + div = <0x3>; + index = <4>; + fifo-depth = <0x80>; + status = "okay"; };
Presumably (as Tom asks) these are syncing up with the kernel?
- Simon
Will resend. Thanks!
- Simon
To use the CONFIG_BLK/CONFIG_DM_MMC/CONFIG_DM_MMC_OPS, add the configurations for exynos4 series.(by default)
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- configs/odroid_defconfig | 3 +++ configs/origen_defconfig | 3 +++ configs/smdkv310_defconfig | 3 +++ configs/trats2_defconfig | 3 +++ configs/trats_defconfig | 3 +++ 5 files changed, 15 insertions(+)
diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index 76d0968..969d777 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -49,3 +49,6 @@ CONFIG_G_DNL_MANUFACTURER="Samsung" CONFIG_G_DNL_VENDOR_NUM=0x04e8 CONFIG_G_DNL_PRODUCT_NUM=0x6601 CONFIG_ERRNO_STR=y +CONFIG_BLK=y +CONFIG_DM_MMC=y +CONFIG_DM_MMC_OPS=y diff --git a/configs/origen_defconfig b/configs/origen_defconfig index d667b0f..5b582ff 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -35,3 +35,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Samsung" CONFIG_G_DNL_VENDOR_NUM=0x04e8 CONFIG_G_DNL_PRODUCT_NUM=0x6601 +CONFIG_BLK=y +CONFIG_DM_MMC=y +CONFIG_DM_MMC_OPS=y diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index c8c182b..52c3cc7 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -24,3 +24,6 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_BLK=y +CONFIG_DM_MMC=y +CONFIG_DM_MMC_OPS=y diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index 59b73ca..b6f6bf8 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -38,3 +38,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Samsung" CONFIG_G_DNL_VENDOR_NUM=0x04e8 CONFIG_G_DNL_PRODUCT_NUM=0x6601 +CONFIG_BLK=y +CONFIG_DM_MMC=y +CONFIG_DM_MMC_OPS=y diff --git a/configs/trats_defconfig b/configs/trats_defconfig index 2773654..26adb1f 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -37,3 +37,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Samsung" CONFIG_G_DNL_VENDOR_NUM=0x04e8 CONFIG_G_DNL_PRODUCT_NUM=0x6601 +CONFIG_BLK=y +CONFIG_DM_MMC=y +CONFIG_DM_MMC_OPS=y
But please use savedefconfig to get the ordering correct. A recent change should make DM_MMC and DM_MMC_OPS the default if BLK is enabled.
- Simon
Got it. Thanks!
- Simon
- Removed '`' thing in comments
- Fix the wrong interrupts value from 77 to 131
For this and the rest of the series, are these problems present in the Linux Kernel or are you backporting fixes? If backporting you should note that, thanks.
Thanks. I will recheck about your comments. But something might be my wrong. Now i'm checking the entire exynos4 series TRM.
And will resend the patch-set after adding the commit message in more details.
Jaehoon Chung
