[PATCH] pinctrl: nxp: scu: Check the pad partition before set pinmux
If a pad is not owned by current partition we should not set its pinmux.
Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/pinctrl/nxp/pinctrl-scu.c | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/drivers/pinctrl/nxp/pinctrl-scu.c b/drivers/pinctrl/nxp/pinctrl-scu.c index aa11075e0a..c032be782a 100644 --- a/drivers/pinctrl/nxp/pinctrl-scu.c +++ b/drivers/pinctrl/nxp/pinctrl-scu.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2018 NXP + * Copyright 2018-2019 NXP */
#include <common.h> @@ -29,6 +29,11 @@ static int imx_pinconf_scu_set(struct imx_pinctrl_soc_info *info, u32 pad, * to handle that in scfw, so config it in pad conf func */
+ if (!sc_rm_is_pad_owned(-1, pad)) { + debug("Pad[%u] is not owned by curr partition\n", pad); + return -EPERM; + } + val |= PADRING_IFMUX_EN_MASK; val |= PADRING_GP_EN_MASK; val |= (mux << PADRING_IFMUX_SHIFT) & PADRING_IFMUX_MASK; @@ -57,7 +62,7 @@ int imx_pinctrl_scu_conf_pins(struct imx_pinctrl_soc_info *info, u32 *pin_data, config_val = pin_data[j++];
ret = imx_pinconf_scu_set(info, pin_id, mux, config_val); - if (ret) + if (ret && ret != -EPERM) printf("Set pin %d, mux %d, val %d, error\n", pin_id, mux, config_val); }
From: Ye Li ye.li@nxp.com If a pad is not owned by current partition we should not set its pinmux. Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Peng Fan
sbabic@denx.de
