[U-Boot-Users] Any spport for Dallas 1-wire DS2502-E48
Has anyone tried to implement a 1-wire driver for Dallas/Maxim 1-Wire devices, in particular for a DS2502-E48 chip?
We are using a custom board based on the FreeScale Lite5200. We have added a DS2502-E48 chip to give us a unique MAC address on each board, instead of having to buy/manage a block of MAC addresses from IEEE.
I'm considering writing a standalone bit-banging application that u-boot can run to read and display the MAC address. The user could then use the display for the "setenv ethaddr" command. Would there be any way for the standalone program to modify the ethaddr environment variable directly?
Thanks,
Ed Jubenville
Hi Ed,
Please take a look at the file:
board/esd/cpci405/cpci405.c:
Here you will find an simple implementation to access to an 1-wire device. Search for ONE_WIRE_CLEAR...
Why not automatically set "ethaddr" to the value from the 1-wire device upon startup? This is done in other implementations already (not from 1-wire device though). For example:
board/tqm8xx/load_sernum_ethaddr.c
Best regards, Stefan
None that I know of.
Why not a regiular driver that fits into the existing environment.
You could export the setenv() function for SA programs, but why making all this so complicated? Implement a regular driver, and perform the setting of ethaddr automatically as part of your board init code.
Edward Jubenville
Stefan Roese
