[U-Boot] [PATCH v5 0/2] Generic firmware loader
This patchset contains generic firmware loader which is very close to Linux firmware loader but for U-Boot framework. Generic firmware loader can be used load whatever into target location, and then consumer driver would use it to program whatever, ie. the FPGA. This version mainly resolved comments from Lothar Waßmann, and Lukasz Majewski in [v4].
This series is working on top of u-boot.git - http://git.denx.de/u-boot.git .
[v4]: https://www.mail-archive.com/u-boot@lists.denx.de/msg272432.html
v4 -> v5 changes: ----------------- - Changed the env variable name to lower case. - Added memory freeing function in failure case. - Assign valid pointer to *firmware_p only when everything is OK. - Removed the casting on void pointer when assigning to any type pointer. - Fixed with the right return code.
Patchset history ---------------- [v1]: https://www.mail-archive.com/u-boot@lists.denx.de/msg271905.html [v2]: https://www.mail-archive.com/u-boot@lists.denx.de/msg271979.html [v3]: https://www.mail-archive.com/u-boot@lists.denx.de/msg272039.html
Tien Fong Chee (2): spl: Remove static declaration on spl_mmc_find_device function common: Generic firmware loader for file system
common/Makefile | 1 + common/fs_loader.c | 311 +++++++++++++++++++++++++++++++++++++++++++++ common/spl/spl_mmc.c | 2 +- doc/README.firmware_loader | 76 +++++++++++ include/fs_loader.h | 28 ++++ include/spl.h | 2 + 6 files changed, 419 insertions(+), 1 deletion(-) create mode 100644 common/fs_loader.c create mode 100644 doc/README.firmware_loader create mode 100644 include/fs_loader.h
v4 -> v5 changes: ----------------- - Changed the env variable name to lower case. - Added memory freeing function in failure case. - Assign valid pointer to *firmware_p only when everything is OK. - Removed the casting on void pointer when assigning to any type pointer. - Fixed withthe right return code.
This patch removes the static declation on spl_mmc_find_device_function so this function is accessible by the caller from other file. This patch is required for later patch.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- common/spl/spl_mmc.c | 2 +- include/spl.h | 2 ++ 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index b57e0b0..183d05a 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -114,7 +114,7 @@ static int spl_mmc_get_device_index(u32 boot_device) return -ENODEV; }
-static int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device) +int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device) { #if CONFIG_IS_ENABLED(DM_MMC) struct udevice *dev; diff --git a/include/spl.h b/include/spl.h index 308ce7b..912983a 100644 --- a/include/spl.h +++ b/include/spl.h @@ -10,6 +10,7 @@ /* Platform-specific defines */ #include <linux/compiler.h> #include <asm/spl.h> +#include <mmc.h>
/* Value in r0 indicates we booted from U-Boot */ #define UBOOT_NOT_LOADED_FROM_SPL 0x13578642 @@ -72,6 +73,7 @@ void preloader_console_init(void); u32 spl_boot_device(void); u32 spl_boot_mode(const u32 boot_device); void spl_set_bd(void); +int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device);
/** * spl_set_header_raw_uboot() - Set up a standard SPL image structure
This is file system generic loader which can be used to load the file image from the storage into target such as memory. The consumer driver would then use this loader to program whatever, ie. the FPGA device.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- common/Makefile | 1 + common/fs_loader.c | 311 +++++++++++++++++++++++++++++++++++++++++++++ doc/README.firmware_loader | 76 +++++++++++ include/fs_loader.h | 28 ++++ 4 files changed, 416 insertions(+) create mode 100644 common/fs_loader.c create mode 100644 doc/README.firmware_loader create mode 100644 include/fs_loader.h
diff --git a/common/Makefile b/common/Makefile index cec506f..2934221 100644 --- a/common/Makefile +++ b/common/Makefile @@ -130,3 +130,4 @@ obj-$(CONFIG_CMD_DFU) += dfu.o obj-y += command.o obj-y += s_record.o obj-y += xyzModem.o +obj-y += fs_loader.o diff --git a/common/fs_loader.c b/common/fs_loader.c new file mode 100644 index 0000000..ddfce58 --- /dev/null +++ b/common/fs_loader.c @@ -0,0 +1,311 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <errno.h> +#include <fs.h> +#include <fs_loader.h> +#include <nand.h> +#include <sata.h> +#include <spi.h> +#include <spi_flash.h> +#include <spl.h> +#include <linux/string.h> +#include <usb.h> + +struct firmware_priv { + const char *name; /* Filename */ + u32 offset; /* Offset of reading a file */ +}; + +static struct device_location default_locations[] = { + { + .name = "mmc", + .devpart = "0:1", + }, + { + .name = "usb", + .devpart = "0:1", + }, + { + .name = "sata", + .devpart = "0:1", + }, +}; + +/* USB build is not supported yet in SPL */ +#ifndef CONFIG_SPL_BUILD +#ifdef CONFIG_USB_STORAGE +static int init_usb(void) +{ + int err; + + err = usb_init(); + if (err) + return err; + +#ifndef CONFIG_DM_USB + err = usb_stor_scan(1) < 0 ? -ENODEV : 0; +#endif + + return err; +} +#else +static int init_usb(void) +{ + printf("Error: Cannot load flash image: no USB support\n"); + return -ENOSYS; +} +#endif +#endif + +#ifdef CONFIG_SATA +static int init_storage_sata(void) +{ + return sata_probe(0); +} +#else +static int init_storage_sata(void) +{ + printf("Error: Cannot load image: no SATA support\n"); + return -ENOSYS; +} +#endif + +#ifdef CONFIG_CMD_UBIFS +static int mount_ubifs(struct device_location *location) +{ + int ret; + char cmd[32]; + + sprintf(cmd, "ubi part %s", location->mtdpart); + + ret = run_command(cmd, 0); + if (ret) + return ret; + + sprintf(cmd, "ubifsmount %s", location->ubivol); + + ret = run_command(cmd, 0); + + return ret; +} + +static int umount_ubifs(void) +{ + return run_command("ubifsumount", 0); +} +#else +static int mount_ubifs(struct device_location *location) +{ + printf("Error: Cannot load image: no UBIFS support\n"); + return -ENOSYS; +} +#endif + +#if defined(CONFIG_SPL_MMC_SUPPORT) && defined(CONFIG_SPL_BUILD) +static int init_mmc(void) +{ + /* Just for the case MMC is not yet initialized */ + struct mmc *mmc = NULL; + int err; + + spl_mmc_find_device(&mmc, spl_boot_device()); + + err = mmc_init(mmc); + if (err) { + printf("spl: mmc init failed with error: %d\n", err); + return err; + } + + return err; +} +#else +static int init_mmc(void) +{ + /* Expect somewhere already initialize MMC */ + return 0; +} +#endif + +static int select_fs_dev(struct device_location *location) +{ + int ret; + + if (!strcmp("mmc", location->name)) { + ret = fs_set_blk_dev("mmc", location->devpart, FS_TYPE_ANY); + } else if (!strcmp("usb", location->name)) { + ret = fs_set_blk_dev("usb", location->devpart, FS_TYPE_ANY); + } else if (!strcmp("sata", location->name)) { + ret = fs_set_blk_dev("sata", location->devpart, FS_TYPE_ANY); + } else if (!strcmp("ubi", location->name)) { + if (location->ubivol != NULL) + ret = fs_set_blk_dev("ubi", NULL, FS_TYPE_UBIFS); + else + ret = -ENODEV; + } else { + printf("Error: unsupported location storage.\n"); + return -ENODEV; + } + + if (ret) + printf("Error: could not access storage.\n"); + + return ret; +} + +static int init_storage_device(struct device_location *location) +{ + int ret; + + if (!strcmp("mmc", location->name)) { + ret = init_mmc(); + } else if (!strcmp("sata", location->name)) { + ret = init_storage_sata(); + } else if (location->ubivol != NULL) { + ret = mount_ubifs(location); +#ifndef CONFIG_SPL_BUILD + /* USB build is not supported yet in SPL */ + } else if (!strcmp("usb", location->name)) { + ret = init_usb(); +#endif + } else { + printf("Error: no supported storage device is available.\n"); + ret = -ENODEV; + } + + return ret; +} + +static void set_storage_devpart(char *name, char *devpart) +{ + size_t i; + + for (i = 0; i < ARRAY_SIZE(default_locations); i++) { + if (!strcmp(default_locations[i].name, name)) + default_locations[i].devpart = devpart; + } +} + +/* + * Prepare firmware struct; + * return -ve if fail. + */ +static int _request_firmware_prepare(struct firmware **firmware_p, + const char *name, void *dbuf, + size_t size, u32 offset) +{ + struct firmware *firmware; + struct firmware_priv *fw_priv; + + *firmware_p = NULL; + + if (!name || name[0] == '\0') + return -EINVAL; + + firmware = calloc(1, sizeof(*firmware)); + if (!firmware) { + printf("%s: calloc(struct firmware) failed\n", __func__); + return -ENOMEM; + } + + fw_priv = calloc(1, sizeof(*fw_priv)); + if (!fw_priv) { + printf("%s: calloc(struct fw_priv) failed\n", __func__); + free(firmware); + return -ENOMEM; + } + + fw_priv->name = name; + fw_priv->offset = offset; + firmware->data = dbuf; + firmware->size = size; + firmware->priv = fw_priv; + *firmware_p = firmware; + + return 0; +} + +/* + * fw_get_filesystem_firmware - load firmware into an allocated buffer + * @location: An array of supported firmware location + * @firmware_p: pointer to firmware image + * + * @return: size of total read + * -ve when error + */ +static int fw_get_filesystem_firmware(struct device_location *location, + struct firmware *firmware_p) +{ + struct firmware_priv *fw_priv = NULL; + loff_t actread; + char *dev_part; + int ret; + + dev_part = env_get("fw_dev_part"); + if (dev_part) + set_storage_devpart(location->name, dev_part); + + ret = init_storage_device(location); + if (ret) + goto out; + + select_fs_dev(location); + if (ret) + goto out; + + fw_priv = firmware_p->priv; + + ret = fs_read(fw_priv->name, (ulong)firmware_p->data, fw_priv->offset, + firmware_p->size, &actread); + + if (ret) { + printf("Error: %d Failed to read %s from flash %lld != %d.\n", + ret, fw_priv->name, actread, firmware_p->size); + return ret; + } else { + ret = actread; + } + +out: +#ifdef CONFIG_CMD_UBIFS + if (location->ubivol != NULL) + umount_ubifs(); +#endif + + return ret; +} + +/* + * request_firmware_into_buf - load firmware into a previously allocated buffer + * @firmware_p: pointer to firmware image + * @name: name of firmware file + * @location: an array of supported firmware location + * @buf: address of buffer to load firmware into + * @size: size of buffer + * @offset: offset of a file for start reading into buffer + * + * The firmware is loaded directly into the buffer pointed to by @buf and + * the @firmware_p data member is pointed at @buf. + * + * @return: size of total read + * -ve when error + */ +int request_firmware_into_buf(struct firmware **firmware_p, + const char *name, + struct device_location *location, + void *buf, size_t size, u32 offset) +{ + int ret; + + ret = _request_firmware_prepare(firmware_p, name, buf, size, offset); + if (ret < 0) /* error */ + return ret; + + ret = fw_get_filesystem_firmware(location, *firmware_p); + + return ret; +} diff --git a/doc/README.firmware_loader b/doc/README.firmware_loader new file mode 100644 index 0000000..f6e4c6b --- /dev/null +++ b/doc/README.firmware_loader @@ -0,0 +1,76 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +Introduction +------------ +This is firmware loader for U-Boot framework, which has very close to some Linux +Firmware API. For the details of Linux Firmware API, you can refer to +https://01.org/linuxgraphics/gfx-docs/drm/driver-api/firmware/index.html. + +Firmware loader can be used to load whatever(firmware, image, and binary) from +the flash in file system format into target location such as memory, then +consumer driver such as FPGA driver can program FPGA image from the target +location into FPGA. + +Firmware Loader API core features +--------------------------------- +=> Firmware storage device partition search + ---------------------------------------- + => Default storage device partition search set for mmc, usb and sata + as shown in below: + static struct device_location default_locations[] = { + { + .name = "mmc", + .devpart = "0:1", + }, + { + .name = "usb", + .devpart = "0:1", + }, + { + .name = "sata", + .devpart = "0:1", + }, + }; + + However, the default storage device .devpart value can be overwritten + with value which is defined in the environment variable "FW_DEV_PART". + For example: env_set("fw_dev_part", "0:2"); + +Firmware Loader API +------------------- +=> int request_firmware_into_buf(struct firmware **firmware_p, + const char *name, + struct device_location *location, + void *buf, size_t size, u32 offset) + -------------------------------------------------------------- + => Load firmware into a previously allocated buffer + + Parameters: + struct firmware **firmware_p + pointer to firmware image + + const char *name + name of firmware file + + struct device_location *location + an array of supported firmware location + + void *buf + address of buffer to load firmware into + + size_t size + size of buffer + + u32 offset + offset of a file for start reading into buffer + + return: size of total read + -ve when error + + Description: + The firmware is loaded directly into the buffer pointed to by buf and + the @firmware_p data member is pointed at buf. diff --git a/include/fs_loader.h b/include/fs_loader.h new file mode 100644 index 0000000..83a8b80 --- /dev/null +++ b/include/fs_loader.h @@ -0,0 +1,28 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ +#ifndef _FS_LOADER_H_ +#define _FS_LOADER_H_ + +#include <linux/types.h> + +struct firmware { + size_t size; /* Size of a file */ + const u8 *data; /* Buffer for file */ + void *priv; /* Firmware loader private fields */ +}; + +struct device_location { + char *name; /* Such as mmc, usb,and sata. */ + char *devpart; /* Use the load command dev:part conventions */ + char *mtdpart; /* MTD partition for ubi part */ + char *ubivol; /* UBI volume-name for ubifsmount */ +}; + +int request_firmware_into_buf(struct firmware **firmware_p, + const char *name, + struct device_location *location, + void *buf, size_t size, u32 offset); +#endif
- Copyright (C) 2017 Intel Corporation <www.intel.com>
- SPDX-License-Identifier: GPL-2.0
- const char *name; /* Filename */
- u32 offset; /* Offset of reading a file */
.name = "mmc",
.devpart = "0:1",
.name = "usb",
.devpart = "0:1",
.name = "sata",
.devpart = "0:1",
- int err;
- err = usb_init();
- if (err)
return err;
- err = usb_stor_scan(1) < 0 ? -ENODEV : 0;
- return err;
- printf("Error: Cannot load flash image: no USB support\n");
- return -ENOSYS;
+} +#endif +#endif
- return sata_probe(0);
- printf("Error: Cannot load image: no SATA support\n");
- return -ENOSYS;
+} +#endif
- int ret;
- char cmd[32];
- sprintf(cmd, "ubi part %s", location->mtdpart);
- ret = run_command(cmd, 0);
- if (ret)
return ret;
- sprintf(cmd, "ubifsmount %s", location->ubivol);
- return ret;
- return run_command("ubifsumount", 0);
- printf("Error: Cannot load image: no UBIFS support\n");
- return -ENOSYS;
+} +#endif
- /* Just for the case MMC is not yet initialized */
- struct mmc *mmc = NULL;
- int err;
- spl_mmc_find_device(&mmc, spl_boot_device());
- err = mmc_init(mmc);
- if (err) {
return err;
- return err;
- /* Expect somewhere already initialize MMC */
+} +#endif
- int ret;
- if (!strcmp("mmc", location->name)) {
- } else if (!strcmp("usb", location->name)) {
- } else if (!strcmp("sata", location->name)) {
- } else if (!strcmp("ubi", location->name)) {
else
ret = -ENODEV;
- } else {
return -ENODEV;
- if (ret)
- return ret;
- int ret;
ret = init_mmc();
- } else if (location->ubivol != NULL) {
- /* USB build is not supported yet in SPL */
ret = init_usb();
- } else {
ret = -ENODEV;
- return ret;
- size_t i;
- for (i = 0; i < ARRAY_SIZE(default_locations); i++) {
- Prepare firmware struct;
- return -ve if fail.
- struct firmware *firmware;
- struct firmware_priv *fw_priv;
- *firmware_p = NULL;
- if (!name || name[0] == '\0')
return -EINVAL;
- firmware = calloc(1, sizeof(*firmware));
- if (!firmware) {
return -ENOMEM;
- fw_priv = calloc(1, sizeof(*fw_priv));
- if (!fw_priv) {
free(firmware);
return -ENOMEM;
- fw_priv->name = name;
- fw_priv->offset = offset;
- firmware->data = dbuf;
- firmware->size = size;
- firmware->priv = fw_priv;
- *firmware_p = firmware;
- fw_get_filesystem_firmware - load firmware into an allocated buffer
- @location: An array of supported firmware location
- @firmware_p: pointer to firmware image
- @return: size of total read
-ve when error
- struct firmware_priv *fw_priv = NULL;
- loff_t actread;
- char *dev_part;
- int ret;
- dev_part = env_get("fw_dev_part");
- if (dev_part)
- ret = init_storage_device(location);
- if (ret)
goto out;
- select_fs_dev(location);
'ret = ' is missing.
- if (ret)
goto out;
- fw_priv = firmware_p->priv;
- ret = fs_read(fw_priv->name, (ulong)firmware_p->data, fw_priv->offset,
- if (ret) {
return ret;
Y Shouldn't this be 'goto out', do do the umount_ubifs() as in all other error cases?
- } else {
ret = actread;
What if actread != firmware_p->size? You handled it as an error before, now you happily return the number of bytes read in case of a short read.
- if (location->ubivol != NULL)
umount_ubifs();
- return ret;
Lothar Waßmann
.name = "mmc",
.devpart = "0:1",
.name = "usb",
.devpart = "0:1",
.name = "sata",
.devpart = "0:1",
- int err;
- err = usb_init();
- if (err)
return err;
- return err;
support\n");
- return -ENOSYS;
+} +#endif +#endif
- return -ENOSYS;
+} +#endif
- int ret;
- char cmd[32];
- if (ret)
return ret;
- return ret;
- return -ENOSYS;
+} +#endif
- int err;
- if (err) {
err);
return err;
- return err;
+} +#endif
- int ret;
FS_TYPE_ANY);
FS_TYPE_ANY);
FS_TYPE_ANY);
FS_TYPE_UBIFS);
else
ret = -ENODEV;
- } else {
return -ENODEV;
- if (ret)
- return ret;
- int ret;
ret = init_mmc();
ret = init_usb();
- } else {
available.\n");
ret = -ENODEV;
- return ret;
- size_t i;
return -EINVAL;
- if (!firmware) {
__func__);
return -ENOMEM;
- if (!fw_priv) {
__func__);
free(firmware);
return -ENOMEM;
buffer
- -ve when error
- loff_t actread;
- char *dev_part;
- int ret;
- if (dev_part)
- if (ret)
goto out;
Okay.
- if (ret)
goto out;
fw_priv->offset,
- if (ret) {
%lld != %d.\n",
size);
return ret;
okay.
- } else {
ret = actread;
May be i misunderstand on ur previosly comment. There is not much description on fd_read, i just knowing that -ve is error from function based on other example codes in U-Boot as they check the error with "ret < 0" or "ret != 0". "actread != firmware_p->size" is the additonal checking i added myself because when i digging to the code, i found that such condition only with error printf inside the function without any error code return. So, i am not sure when "actread != firmware_p-
size", the ret would be -ve too.
How about we write in this way?
if (ret || (actread != firmware_p->size)) { printf("Error: %d Failed to read %s from flash %lld != %d.\n", ret, fw_priv->name, actread, firmware_p->size); goto out; } else { ret = actread; }
out: #ifdef CONFIG_CMD_UBIFS if (location->ubivol != NULL) umount_ubifs(); #endif
return ret;
umount_ubifs();
- return ret;
Lothar Waßmann
.name = "mmc",
.devpart = "0:1",
.name = "usb",
.devpart = "0:1",
.name = "sata",
.devpart = "0:1",
- int err;
- err = usb_init();
- if (err)
return err;
- return err;
support\n");
- return -ENOSYS;
+} +#endif +#endif
- return -ENOSYS;
+} +#endif
- int ret;
- char cmd[32];
- if (ret)
return ret;
- return ret;
- return -ENOSYS;
+} +#endif
- int err;
- if (err) {
err);
return err;
- return err;
+} +#endif
- int ret;
FS_TYPE_ANY);
FS_TYPE_ANY);
FS_TYPE_ANY);
FS_TYPE_UBIFS);
else
ret = -ENODEV;
- } else {
storage.\n");
return -ENODEV;
- if (ret)
- return ret;
- int ret;
ret = init_mmc();
ret = init_usb();
- } else {
available.\n");
ret = -ENODEV;
- return ret;
- size_t i;
*dbuf,
return -EINVAL;
- if (!firmware) {
__func__);
return -ENOMEM;
- if (!fw_priv) {
__func__);
free(firmware);
return -ENOMEM;
buffer
- -ve when error
struct firmware
*firmware_p) +{
- loff_t actread;
- char *dev_part;
- int ret;
- if (dev_part)
- if (ret)
goto out;
Okay.
- if (ret)
goto out;
fw_priv->offset,
- if (ret) {
%lld != %d.\n",
size);
return ret;
okay.
- } else {
ret = actread;
I suggest put ret = -EIO;
goto out;
return ret;
umount_ubifs();
- return ret;
Lothar Waßmann
.name = "mmc",
.devpart = "0:1",
.name = "usb",
.devpart = "0:1",
.name = "sata",
.devpart = "0:1",
- int err;
- err = usb_init();
- if (err)
return err;
- return err;
support\n");
- return -ENOSYS;
+} +#endif +#endif
- return -ENOSYS;
+} +#endif
- int ret;
- char cmd[32];
- if (ret)
return ret;
- return ret;
- return -ENOSYS;
+} +#endif
- int err;
- if (err) {
err);
return err;
- return err;
+} +#endif
- int ret;
FS_TYPE_ANY);
FS_TYPE_ANY);
FS_TYPE_ANY);
FS_TYPE_UBIFS);
else
ret = -ENODEV;
- } else {
return -ENODEV;
- if (ret)
- return ret;
- int ret;
ret = init_mmc();
ret = init_usb();
- } else {
available.\n");
ret = -ENODEV;
- return ret;
- size_t i;
return -EINVAL;
- if (!firmware) {
__func__);
return -ENOMEM;
- if (!fw_priv) {
__func__);
free(firmware);
return -ENOMEM;
buffer
- -ve when error
- loff_t actread;
- char *dev_part;
- int ret;
- if (dev_part)
- if (ret)
goto out;
Okay.
- if (ret)
goto out;
fw_priv->offset,
- if (ret) {
%lld != %d.\n",
size);
return ret;
okay.
- } else {
ret = actread;
What if actread != firmware_p->size? You handled it as an error before, now you happily return the number of bytes read in case of a short read. Operation not permitted
My comment was about returning -EPERM in this case. First of all you discarded the possible error code returned from fs_read() and secondly -EIO would be more appropriate than EPERM in case of reading less data than expected.
If 'size' is the actual size of the caller provided buffer and not the exact size of the firmware to be loaded, the condition actread != size would not be an error at all. If 'size' designates the exact size of the firmware, that the caller may know by other means, it is obviously an error if actread != size. Since you treated actread != size as an error in your original patch I assumed the latter case.
AFAICT Linux uses the first semantics ('size' specifies the size of the caller provided buffer as an upper limit for the read() call and not the exact amount of data to be read). Unfortunately the fs_read() semantics is fundamentally broken as it interprets 'size == 0' as 'read as much data as you can get' which may easily lead to buffer overflows and prints a very unhelpful error message "<filename> shorter than offset + len" in case 'size' does not match the actual amount of data read.
You should also consider what happens, if the firmware file you read is larger than the buffer you provided, as in that case fs_read() will stop reading at the provided buffer size and you won't be able to notice, that the file was not completely loaded!
Lothar Waßmann
.name = "mmc",
.devpart = "0:1",
.name = "usb",
.devpart = "0:1",
.name = "sata",
.devpart = "0:1",
- int err;
- err = usb_init();
- if (err)
return err;
- return err;
support\n");
- return -ENOSYS;
+} +#endif +#endif
- return -ENOSYS;
+} +#endif
- int ret;
- char cmd[32];
- if (ret)
return ret;
- return ret;
support\n");
- return -ENOSYS;
+} +#endif
- int err;
- if (err) {
%d\n", err);
return err;
- return err;
+} +#endif
- int ret;
FS_TYPE_ANY);
FS_TYPE_ANY);
devpart,
FS_TYPE_ANY);
FS_TYPE_UBIFS);
else
ret = -ENODEV;
- } else {
storage.\n");
return -ENODEV;
- if (ret)
- return ret;
- int ret;
ret = init_mmc();
ret = init_usb();
- } else {
available.\n");
ret = -ENODEV;
- return ret;
- size_t i;
devpart;
*dbuf,
return -EINVAL;
- if (!firmware) {
__func__);
return -ENOMEM;
- if (!fw_priv) {
__func__);
free(firmware);
return -ENOMEM;
allocated buffer
- -ve when error
struct firmware
*firmware_p) +{
- loff_t actread;
- char *dev_part;
- int ret;
- if (dev_part)
- if (ret)
goto out;
Okay.
- if (ret)
goto out;
fw_priv->offset,
- if (ret) {
%lld != %d.\n",
size);
return ret;
okay.
- } else {
ret = actread;
One of the reason I prefer to use -EIO instead of return from fs_read, because i'm not sure when "actread != firmware_p->size", the return from the fs_read is still -ve or not.
The size here refer to the size of firmware or chunk of firmware to read when the buffer is smaller than firmware.
I prefer to let the caller handles this, because this function can be used to read the firmware chunk by chunk when the allocated buffer is smaller than firmware.
Lothar Waßmann
.name = "mmc",
.devpart = "0:1",
.name = "usb",
.devpart = "0:1",
.name = "sata",
.devpart = "0:1",
- int err;
- err = usb_init();
- if (err)
return err;
- return err;
support\n");
- return -ENOSYS;
+} +#endif +#endif
- return -ENOSYS;
+} +#endif
- int ret;
- char cmd[32];
- if (ret)
return ret;
- return ret;
support\n");
- return -ENOSYS;
+} +#endif
- int err;
- if (err) {
%d\n", err);
return err;
- return err;
+} +#endif
- int ret;
FS_TYPE_ANY);
FS_TYPE_ANY);
devpart,
FS_TYPE_ANY);
FS_TYPE_UBIFS);
else
ret = -ENODEV;
- } else {
storage.\n");
return -ENODEV;
- if (ret)
- return ret;
- int ret;
ret = init_mmc();
ret = init_usb();
- } else {
available.\n");
ret = -ENODEV;
- return ret;
- size_t i;
devpart;
*dbuf,
return -EINVAL;
- if (!firmware) {
__func__);
return -ENOMEM;
- if (!fw_priv) {
__func__);
free(firmware);
return -ENOMEM;
allocated buffer
- -ve when error
struct firmware
*firmware_p) +{
- loff_t actread;
- char *dev_part;
- int ret;
- if (dev_part)
- if (ret)
goto out;
Okay.
- if (ret)
goto out;
fw_priv->offset,
- if (ret) {
%lld != %d.\n",
size);
return ret;
okay.
- } else {
ret = actread;
The return code of fs_read() could be for example -ENOENT, if the file you try to load does not exist. Replacing it with -EIO will mislead users about the cause of the error. Thus, if fs_read()'s return code is < 0, you should return that! If it is zero and you decide to treat actread =! firmware_p->size as an error, you should return -EIO only in that case!
OK. In that case, you should not print a message when actread != firmware_p->size, since fs_read will have already printed a message due to this.
So, the caller should also check, whether the return value of the function matches the requested size and you should omit the special handling of actread != firmware_p->size in fw_get_filesystem_firmware() (as you did in the current version of your patch).
Lothar Waßmann
file */ +};
.name = "mmc",
.devpart = "0:1",
.name = "usb",
.devpart = "0:1",
.name = "sata",
.devpart = "0:1",
- int err;
- err = usb_init();
- if (err)
return err;
- return err;
support\n");
- return -ENOSYS;
+} +#endif +#endif
support\n");
- return -ENOSYS;
+} +#endif
- int ret;
- char cmd[32];
- if (ret)
return ret;
- return ret;
support\n");
- return -ENOSYS;
+} +#endif
- int err;
- if (err) {
%d\n", err);
return err;
- return err;
+} +#endif
- int ret;
FS_TYPE_UBIFS);
else
ret = -ENODEV;
- } else {
storage.\n");
return -ENODEV;
- if (ret)
storage.\n");
- return ret;
- int ret;
ret = init_mmc();
ret = init_usb();
- } else {
is available.\n");
ret = -ENODEV;
- return ret;
- size_t i;
i++) {
name))
devpart;
const char *name,
void *dbuf,
size_t size, u32
offset) +{
return -EINVAL;
- if (!firmware) {
return -ENOMEM;
- if (!fw_priv) {
free(firmware);
return -ENOMEM;
allocated buffer
- -ve when error
struct firmware
*firmware_p) +{
- loff_t actread;
- char *dev_part;
- int ret;
- if (dev_part)
dev_part);
- if (ret)
goto out;
Okay.
- if (ret)
goto out;
- if (ret) {
firmware_p- > > > size);
return ret;
okay.
- } else {
ret = actread;
Okay.
The printed message with additional info such as ret, size and actread.
Just to confirm we are in same page, the caller i means is function which call the request_firmware_into_buf. firmware_p->size is the size gonna be read from firmware, could be part of firmware with different offset. Would you mind to explain more why the special handling should be omitted? This special handling would return error code if fail,or actread if pass to the request_firmware_into_buf. request_firmware_into_buf just need to know status of file reading is performed successfully or not.
Lothar Waßmann
On Thu, 21 Dec 2017 15:25:29 +0800 tien.fong.chee@intel.com wrote: > > > > From: Tien Fong Chee tien.fong.chee@intel.com > > This is file system generic loader which can be used to > load > the file image from the storage into target such as memory. > The consumer driver would then use this loader to program > whatever, > ie. the FPGA device. > > Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com > --- > common/Makefile | 1 + > common/fs_loader.c | 311 > +++++++++++++++++++++++++++++++++++++++++++++ > doc/README.firmware_loader | 76 +++++++++++ > include/fs_loader.h | 28 ++++ > 4 files changed, 416 insertions(+) > create mode 100644 common/fs_loader.c > create mode 100644 doc/README.firmware_loader > create mode 100644 include/fs_loader.h > > diff --git a/common/Makefile b/common/Makefile > index cec506f..2934221 100644 > --- a/common/Makefile > +++ b/common/Makefile > @@ -130,3 +130,4 @@ obj-$(CONFIG_CMD_DFU) += dfu.o > obj-y += command.o > obj-y += s_record.o > obj-y += xyzModem.o > +obj-y += fs_loader.o > diff --git a/common/fs_loader.c b/common/fs_loader.c > new file mode 100644 > index 0000000..ddfce58 > --- /dev/null > +++ b/common/fs_loader.c > @@ -0,0 +1,311 @@ > +/* > + * Copyright (C) 2017 Intel Corporation <www.intel.com> > + * > + * SPDX-License-Identifier: GPL-2.0 > + */ > + > +#include <common.h> > +#include <errno.h> > +#include <fs.h> > +#include <fs_loader.h> > +#include <nand.h> > +#include <sata.h> > +#include <spi.h> > +#include <spi_flash.h> > +#include <spl.h> > +#include <linux/string.h> > +#include <usb.h> > + > +struct firmware_priv { > + const char *name; /* Filename */ > + u32 offset; /* Offset of reading a > file > */ > +}; > + > +static struct device_location default_locations[] = { > + { > + .name = "mmc", > + .devpart = "0:1", > + }, > + { > + .name = "usb", > + .devpart = "0:1", > + }, > + { > + .name = "sata", > + .devpart = "0:1", > + }, > +}; > + > +/* USB build is not supported yet in SPL */ > +#ifndef CONFIG_SPL_BUILD > +#ifdef CONFIG_USB_STORAGE > +static int init_usb(void) > +{ > + int err; > + > + err = usb_init(); > + if (err) > + return err; > + > +#ifndef CONFIG_DM_USB > + err = usb_stor_scan(1) < 0 ? -ENODEV : 0; > +#endif > + > + return err; > +} > +#else > +static int init_usb(void) > +{ > + printf("Error: Cannot load flash image: no USB > support\n"); > + return -ENOSYS; > +} > +#endif > +#endif > + > +#ifdef CONFIG_SATA > +static int init_storage_sata(void) > +{ > + return sata_probe(0); > +} > +#else > +static int init_storage_sata(void) > +{ > + printf("Error: Cannot load image: no SATA > support\n"); > + return -ENOSYS; > +} > +#endif > + > +#ifdef CONFIG_CMD_UBIFS > +static int mount_ubifs(struct device_location *location) > +{ > + int ret; > + char cmd[32]; > + > + sprintf(cmd, "ubi part %s", location->mtdpart); > + > + ret = run_command(cmd, 0); > + if (ret) > + return ret; > + > + sprintf(cmd, "ubifsmount %s", location->ubivol); > + > + ret = run_command(cmd, 0); > + > + return ret; > +} > + > +static int umount_ubifs(void) > +{ > + return run_command("ubifsumount", 0); > +} > +#else > +static int mount_ubifs(struct device_location *location) > +{ > + printf("Error: Cannot load image: no UBIFS > support\n"); > + return -ENOSYS; > +} > +#endif > + > +#if defined(CONFIG_SPL_MMC_SUPPORT) && > defined(CONFIG_SPL_BUILD) > +static int init_mmc(void) > +{ > + /* Just for the case MMC is not yet initialized */ > + struct mmc *mmc = NULL; > + int err; > + > + spl_mmc_find_device(&mmc, spl_boot_device()); > + > + err = mmc_init(mmc); > + if (err) { > + printf("spl: mmc init failed with error: > %d\n", > err); > + return err; > + } > + > + return err; > +} > +#else > +static int init_mmc(void) > +{ > + /* Expect somewhere already initialize MMC */ > + return 0; > +} > +#endif > + > +static int select_fs_dev(struct device_location *location) > +{ > + int ret; > + > + if (!strcmp("mmc", location->name)) { > + ret = fs_set_blk_dev("mmc", location- > >devpart, > FS_TYPE_ANY); > + } else if (!strcmp("usb", location->name)) { > + ret = fs_set_blk_dev("usb", location- > >devpart, > FS_TYPE_ANY); > + } else if (!strcmp("sata", location->name)) { > + ret = fs_set_blk_dev("sata", location- > > > > devpart, > FS_TYPE_ANY); > + } else if (!strcmp("ubi", location->name)) { > + if (location->ubivol != NULL) > + ret = fs_set_blk_dev("ubi", NULL, > FS_TYPE_UBIFS); > + else > + ret = -ENODEV; > + } else { > + printf("Error: unsupported location > storage.\n"); > + return -ENODEV; > + } > + > + if (ret) > + printf("Error: could not access > storage.\n"); > + > + return ret; > +} > + > +static int init_storage_device(struct device_location > *location) > +{ > + int ret; > + > + if (!strcmp("mmc", location->name)) { > + ret = init_mmc(); > + } else if (!strcmp("sata", location->name)) { > + ret = init_storage_sata(); > + } else if (location->ubivol != NULL) { > + ret = mount_ubifs(location); > +#ifndef CONFIG_SPL_BUILD > + /* USB build is not supported yet in SPL */ > + } else if (!strcmp("usb", location->name)) { > + ret = init_usb(); > +#endif > + } else { > + printf("Error: no supported storage device > is > available.\n"); > + ret = -ENODEV; > + } > + > + return ret; > +} > + > +static void set_storage_devpart(char *name, char *devpart) > +{ > + size_t i; > + > + for (i = 0; i < ARRAY_SIZE(default_locations); > i++) { > + if (!strcmp(default_locations[i].name, > name)) > + default_locations[i].devpart = > devpart; > + } > +} > + > +/* > + * Prepare firmware struct; > + * return -ve if fail. > + */ > +static int _request_firmware_prepare(struct firmware > **firmware_p, > + const char *name, > void > *dbuf, > + size_t size, u32 > offset) > +{ > + struct firmware *firmware; > + struct firmware_priv *fw_priv; > + > + *firmware_p = NULL; > + > + if (!name || name[0] == '\0') > + return -EINVAL; > + > + firmware = calloc(1, sizeof(*firmware)); > + if (!firmware) { > + printf("%s: calloc(struct firmware) > failed\n", > __func__); > + return -ENOMEM; > + } > + > + fw_priv = calloc(1, sizeof(*fw_priv)); > + if (!fw_priv) { > + printf("%s: calloc(struct fw_priv) > failed\n", > __func__); > + free(firmware); > + return -ENOMEM; > + } > + > + fw_priv->name = name; > + fw_priv->offset = offset; > + firmware->data = dbuf; > + firmware->size = size; > + firmware->priv = fw_priv; > + *firmware_p = firmware; > + > + return 0; > +} > + > +/* > + * fw_get_filesystem_firmware - load firmware into an > allocated > buffer > + * @location: An array of supported firmware location > + * @firmware_p: pointer to firmware image > + * > + * @return: size of total read > + * -ve when error > + */ > +static int fw_get_filesystem_firmware(struct > device_location > *location, > + struct firmware > *firmware_p) > +{ > + struct firmware_priv *fw_priv = NULL; > + loff_t actread; > + char *dev_part; > + int ret; > + > + dev_part = env_get("fw_dev_part"); > + if (dev_part) > + set_storage_devpart(location->name, > dev_part); > + > + ret = init_storage_device(location); > + if (ret) > + goto out; > + > + select_fs_dev(location); > 'ret = ' is missing.
Okay.
> > > > + if (ret) > + goto out; > + > + fw_priv = firmware_p->priv; > + > + ret = fs_read(fw_priv->name, (ulong)firmware_p- > >data, > fw_priv->offset, > + firmware_p->size, &actread); > + > + if (ret) { > + printf("Error: %d Failed to read %s from > flash > %lld != %d.\n", > + ret, fw_priv->name, actread, > firmware_p- > > > > > > size); > + return ret; Y Shouldn't this be 'goto out', do do the umount_ubifs() as in all other error cases?
okay.
> > > > + } else { > + ret = actread; > + } > What if actread != firmware_p->size? You handled it as an error before, now you happily return the number of bytes read in case of a short read. Operation not permitted
Okay.
The point is whether to define a short read as failure and return an error code in this case or just let the caller know the actual amount of data read. If you always return the actual number of bytes read (or a negative error code), no matter whether it matches the requested size or not, the caller has all information to handle the situation correctly. It could just request a new chunk for the missing bytes in case of a short read, or handle a short read as an error condition at its own discretion. So there is no need to check the actual read size in your function.
But probably this discussion is completely vain, since if you want to load a piece of firmware, you would probably check for the existence of the file and its size beforehand, allocate a sufficiently large buffer and then call request_firmware_into_buf() with the correct size. Thus the situation actread != size should never occur anyway in practice.
Lothar Waßmann
On Kha, 2017-12-21 at 09:48 +0100, Lothar Waßmann wrote: > > > > Hi, > > On Thu, 21 Dec 2017 15:25:29 +0800 tien.fong.chee@intel.c > om > wrote: > > > > > > > > > > From: Tien Fong Chee tien.fong.chee@intel.com > > > > This is file system generic loader which can be used to > > load > > the file image from the storage into target such as > > memory. > > The consumer driver would then use this loader to > > program > > whatever, > > ie. the FPGA device. > > > > Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com > > > > > --- > > common/Makefile | 1 + > > common/fs_loader.c | 311 > > +++++++++++++++++++++++++++++++++++++++++++++ > > doc/README.firmware_loader | 76 +++++++++++ > > include/fs_loader.h | 28 ++++ > > 4 files changed, 416 insertions(+) > > create mode 100644 common/fs_loader.c > > create mode 100644 doc/README.firmware_loader > > create mode 100644 include/fs_loader.h > > > > diff --git a/common/Makefile b/common/Makefile > > index cec506f..2934221 100644 > > --- a/common/Makefile > > +++ b/common/Makefile > > @@ -130,3 +130,4 @@ obj-$(CONFIG_CMD_DFU) += dfu.o > > obj-y += command.o > > obj-y += s_record.o > > obj-y += xyzModem.o > > +obj-y += fs_loader.o > > diff --git a/common/fs_loader.c b/common/fs_loader.c > > new file mode 100644 > > index 0000000..ddfce58 > > --- /dev/null > > +++ b/common/fs_loader.c > > @@ -0,0 +1,311 @@ > > +/* > > + * Copyright (C) 2017 Intel Corporation <www.intel.com > > > > > + * > > + * SPDX-License-Identifier: GPL-2.0 > > + */ > > + > > +#include <common.h> > > +#include <errno.h> > > +#include <fs.h> > > +#include <fs_loader.h> > > +#include <nand.h> > > +#include <sata.h> > > +#include <spi.h> > > +#include <spi_flash.h> > > +#include <spl.h> > > +#include <linux/string.h> > > +#include <usb.h> > > + > > +struct firmware_priv { > > + const char *name; /* Filename */ > > + u32 offset; /* Offset of > > reading a > > file > > */ > > +}; > > + > > +static struct device_location default_locations[] = { > > + { > > + .name = "mmc", > > + .devpart = "0:1", > > + }, > > + { > > + .name = "usb", > > + .devpart = "0:1", > > + }, > > + { > > + .name = "sata", > > + .devpart = "0:1", > > + }, > > +}; > > + > > +/* USB build is not supported yet in SPL */ > > +#ifndef CONFIG_SPL_BUILD > > +#ifdef CONFIG_USB_STORAGE > > +static int init_usb(void) > > +{ > > + int err; > > + > > + err = usb_init(); > > + if (err) > > + return err; > > + > > +#ifndef CONFIG_DM_USB > > + err = usb_stor_scan(1) < 0 ? -ENODEV : 0; > > +#endif > > + > > + return err; > > +} > > +#else > > +static int init_usb(void) > > +{ > > + printf("Error: Cannot load flash image: no USB > > support\n"); > > + return -ENOSYS; > > +} > > +#endif > > +#endif > > + > > +#ifdef CONFIG_SATA > > +static int init_storage_sata(void) > > +{ > > + return sata_probe(0); > > +} > > +#else > > +static int init_storage_sata(void) > > +{ > > + printf("Error: Cannot load image: no SATA > > support\n"); > > + return -ENOSYS; > > +} > > +#endif > > + > > +#ifdef CONFIG_CMD_UBIFS > > +static int mount_ubifs(struct device_location > > *location) > > +{ > > + int ret; > > + char cmd[32]; > > + > > + sprintf(cmd, "ubi part %s", location- > > >mtdpart); > > + > > + ret = run_command(cmd, 0); > > + if (ret) > > + return ret; > > + > > + sprintf(cmd, "ubifsmount %s", location- > > >ubivol); > > + > > + ret = run_command(cmd, 0); > > + > > + return ret; > > +} > > + > > +static int umount_ubifs(void) > > +{ > > + return run_command("ubifsumount", 0); > > +} > > +#else > > +static int mount_ubifs(struct device_location > > *location) > > +{ > > + printf("Error: Cannot load image: no UBIFS > > support\n"); > > + return -ENOSYS; > > +} > > +#endif > > + > > +#if defined(CONFIG_SPL_MMC_SUPPORT) && > > defined(CONFIG_SPL_BUILD) > > +static int init_mmc(void) > > +{ > > + /* Just for the case MMC is not yet > > initialized */ > > + struct mmc *mmc = NULL; > > + int err; > > + > > + spl_mmc_find_device(&mmc, spl_boot_device()); > > + > > + err = mmc_init(mmc); > > + if (err) { > > + printf("spl: mmc init failed with > > error: > > %d\n", > > err); > > + return err; > > + } > > + > > + return err; > > +} > > +#else > > +static int init_mmc(void) > > +{ > > + /* Expect somewhere already initialize MMC */ > > + return 0; > > +} > > +#endif > > + > > +static int select_fs_dev(struct device_location > > *location) > > +{ > > + int ret; > > + > > + if (!strcmp("mmc", location->name)) { > > + ret = fs_set_blk_dev("mmc", location- > > > > > > devpart, > > FS_TYPE_ANY); > > + } else if (!strcmp("usb", location->name)) { > > + ret = fs_set_blk_dev("usb", location- > > > > > > devpart, > > FS_TYPE_ANY); > > + } else if (!strcmp("sata", location->name)) { > > + ret = fs_set_blk_dev("sata", location- > > > > > > > > > devpart, > > FS_TYPE_ANY); > > + } else if (!strcmp("ubi", location->name)) { > > + if (location->ubivol != NULL) > > + ret = fs_set_blk_dev("ubi", > > NULL, > > FS_TYPE_UBIFS); > > + else > > + ret = -ENODEV; > > + } else { > > + printf("Error: unsupported location > > storage.\n"); > > + return -ENODEV; > > + } > > + > > + if (ret) > > + printf("Error: could not access > > storage.\n"); > > + > > + return ret; > > +} > > + > > +static int init_storage_device(struct device_location > > *location) > > +{ > > + int ret; > > + > > + if (!strcmp("mmc", location->name)) { > > + ret = init_mmc(); > > + } else if (!strcmp("sata", location->name)) { > > + ret = init_storage_sata(); > > + } else if (location->ubivol != NULL) { > > + ret = mount_ubifs(location); > > +#ifndef CONFIG_SPL_BUILD > > + /* USB build is not supported yet in SPL */ > > + } else if (!strcmp("usb", location->name)) { > > + ret = init_usb(); > > +#endif > > + } else { > > + printf("Error: no supported storage > > device > > is > > available.\n"); > > + ret = -ENODEV; > > + } > > + > > + return ret; > > +} > > + > > +static void set_storage_devpart(char *name, char > > *devpart) > > +{ > > + size_t i; > > + > > + for (i = 0; i < ARRAY_SIZE(default_locations); > > i++) { > > + if (!strcmp(default_locations[i].name, > > name)) > > + default_locations[i].devpart = > > devpart; > > + } > > +} > > + > > +/* > > + * Prepare firmware struct; > > + * return -ve if fail. > > + */ > > +static int _request_firmware_prepare(struct firmware > > **firmware_p, > > + const char *name, > > void > > *dbuf, > > + size_t size, u32 > > offset) > > +{ > > + struct firmware *firmware; > > + struct firmware_priv *fw_priv; > > + > > + *firmware_p = NULL; > > + > > + if (!name || name[0] == '\0') > > + return -EINVAL; > > + > > + firmware = calloc(1, sizeof(*firmware)); > > + if (!firmware) { > > + printf("%s: calloc(struct firmware) > > failed\n", > > __func__); > > + return -ENOMEM; > > + } > > + > > + fw_priv = calloc(1, sizeof(*fw_priv)); > > + if (!fw_priv) { > > + printf("%s: calloc(struct fw_priv) > > failed\n", > > __func__); > > + free(firmware); > > + return -ENOMEM; > > + } > > + > > + fw_priv->name = name; > > + fw_priv->offset = offset; > > + firmware->data = dbuf; > > + firmware->size = size; > > + firmware->priv = fw_priv; > > + *firmware_p = firmware; > > + > > + return 0; > > +} > > + > > +/* > > + * fw_get_filesystem_firmware - load firmware into an > > allocated > > buffer > > + * @location: An array of supported firmware location > > + * @firmware_p: pointer to firmware image > > + * > > + * @return: size of total read > > + * -ve when error > > + */ > > +static int fw_get_filesystem_firmware(struct > > device_location > > *location, > > + struct firmware > > *firmware_p) > > +{ > > + struct firmware_priv *fw_priv = NULL; > > + loff_t actread; > > + char *dev_part; > > + int ret; > > + > > + dev_part = env_get("fw_dev_part"); > > + if (dev_part) > > + set_storage_devpart(location->name, > > dev_part); > > + > > + ret = init_storage_device(location); > > + if (ret) > > + goto out; > > + > > + select_fs_dev(location); > > > 'ret = ' is missing. > Okay. > > > > > > > > > > > > > + if (ret) > > + goto out; > > + > > + fw_priv = firmware_p->priv; > > + > > + ret = fs_read(fw_priv->name, > > (ulong)firmware_p- > > > > > > data, > > fw_priv->offset, > > + firmware_p->size, &actread); > > + > > + if (ret) { > > + printf("Error: %d Failed to read %s > > from > > flash > > %lld != %d.\n", > > + ret, fw_priv->name, actread, > > firmware_p- > > > > > > > > > > > > size); > > + return ret; > Y > Shouldn't this be 'goto out', do do the umount_ubifs() as > in > all > other > error cases? > okay. > > > > > > > > > > > > > + } else { > > + ret = actread; > > + } > > > What if actread != firmware_p->size? > You handled it as an error before, now you happily return > the > number > of > bytes read in case of a short read. > Operation not permitted May be i misunderstand on ur previosly comment. There is not much
Okay.
description on fd_read, i just knowing that -ve is error from function based on other example codes in U-Boot as they check the error with "ret < 0" or "ret != 0". "actread != firmware_p->size" is the additonal checking i added myself because when i digging to the code, i found that such condition only with error printf inside the function without any error code return. So, i am not sure when "actread != firmware_p- > > > > size", the ret would be -ve too.
Okay, so you means that regardless fs_read is success or fail, just return the actread to the caller, and let caller to decide the next handling action, right?
Lothar Waßmann
On Thu, 21 Dec 2017 09:36:41 +0000 Chee, Tien Fong wrote: > > > > On Kha, 2017-12-21 at 09:48 +0100, Lothar Waßmann wrote: > > > > > > > > Hi, > > > > On Thu, 21 Dec 2017 15:25:29 +0800 tien.fong.chee@intel.c > > om > > wrote: > > > > > > > > > > > > > > > From: Tien Fong Chee tien.fong.chee@intel.com > > > > > > This is file system generic loader which can be used to > > > load > > > the file image from the storage into target such as > > > memory. > > > The consumer driver would then use this loader to > > > program > > > whatever, > > > ie. the FPGA device. > > > > > > Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com > > > > > > > --- > > > common/Makefile | 1 + > > > common/fs_loader.c | 311 > > > +++++++++++++++++++++++++++++++++++++++++++++ > > > doc/README.firmware_loader | 76 +++++++++++ > > > include/fs_loader.h | 28 ++++ > > > 4 files changed, 416 insertions(+) > > > create mode 100644 common/fs_loader.c > > > create mode 100644 doc/README.firmware_loader > > > create mode 100644 include/fs_loader.h > > > > > > diff --git a/common/Makefile b/common/Makefile > > > index cec506f..2934221 100644 > > > --- a/common/Makefile > > > +++ b/common/Makefile > > > @@ -130,3 +130,4 @@ obj-$(CONFIG_CMD_DFU) += dfu.o > > > obj-y += command.o > > > obj-y += s_record.o > > > obj-y += xyzModem.o > > > +obj-y += fs_loader.o > > > diff --git a/common/fs_loader.c b/common/fs_loader.c > > > new file mode 100644 > > > index 0000000..ddfce58 > > > --- /dev/null > > > +++ b/common/fs_loader.c > > > @@ -0,0 +1,311 @@ > > > +/* > > > + * Copyright (C) 2017 Intel Corporation <www.intel.com > > > > > > > + * > > > + * SPDX-License-Identifier: GPL-2.0 > > > + */ > > > + > > > +#include <common.h> > > > +#include <errno.h> > > > +#include <fs.h> > > > +#include <fs_loader.h> > > > +#include <nand.h> > > > +#include <sata.h> > > > +#include <spi.h> > > > +#include <spi_flash.h> > > > +#include <spl.h> > > > +#include <linux/string.h> > > > +#include <usb.h> > > > + > > > +struct firmware_priv { > > > + const char *name; /* Filename */ > > > + u32 offset; /* Offset of > > > reading a > > > file > > > */ > > > +}; > > > + > > > +static struct device_location default_locations[] = { > > > + { > > > + .name = "mmc", > > > + .devpart = "0:1", > > > + }, > > > + { > > > + .name = "usb", > > > + .devpart = "0:1", > > > + }, > > > + { > > > + .name = "sata", > > > + .devpart = "0:1", > > > + }, > > > +}; > > > + > > > +/* USB build is not supported yet in SPL */ > > > +#ifndef CONFIG_SPL_BUILD > > > +#ifdef CONFIG_USB_STORAGE > > > +static int init_usb(void) > > > +{ > > > + int err; > > > + > > > + err = usb_init(); > > > + if (err) > > > + return err; > > > + > > > +#ifndef CONFIG_DM_USB > > > + err = usb_stor_scan(1) < 0 ? -ENODEV : 0; > > > +#endif > > > + > > > + return err; > > > +} > > > +#else > > > +static int init_usb(void) > > > +{ > > > + printf("Error: Cannot load flash image: no USB > > > support\n"); > > > + return -ENOSYS; > > > +} > > > +#endif > > > +#endif > > > + > > > +#ifdef CONFIG_SATA > > > +static int init_storage_sata(void) > > > +{ > > > + return sata_probe(0); > > > +} > > > +#else > > > +static int init_storage_sata(void) > > > +{ > > > + printf("Error: Cannot load image: no SATA > > > support\n"); > > > + return -ENOSYS; > > > +} > > > +#endif > > > + > > > +#ifdef CONFIG_CMD_UBIFS > > > +static int mount_ubifs(struct device_location > > > *location) > > > +{ > > > + int ret; > > > + char cmd[32]; > > > + > > > + sprintf(cmd, "ubi part %s", location- > > > >mtdpart); > > > + > > > + ret = run_command(cmd, 0); > > > + if (ret) > > > + return ret; > > > + > > > + sprintf(cmd, "ubifsmount %s", location- > > > >ubivol); > > > + > > > + ret = run_command(cmd, 0); > > > + > > > + return ret; > > > +} > > > + > > > +static int umount_ubifs(void) > > > +{ > > > + return run_command("ubifsumount", 0); > > > +} > > > +#else > > > +static int mount_ubifs(struct device_location > > > *location) > > > +{ > > > + printf("Error: Cannot load image: no UBIFS > > > support\n"); > > > + return -ENOSYS; > > > +} > > > +#endif > > > + > > > +#if defined(CONFIG_SPL_MMC_SUPPORT) && > > > defined(CONFIG_SPL_BUILD) > > > +static int init_mmc(void) > > > +{ > > > + /* Just for the case MMC is not yet > > > initialized */ > > > + struct mmc *mmc = NULL; > > > + int err; > > > + > > > + spl_mmc_find_device(&mmc, spl_boot_device()); > > > + > > > + err = mmc_init(mmc); > > > + if (err) { > > > + printf("spl: mmc init failed with > > > error: > > > %d\n", > > > err); > > > + return err; > > > + } > > > + > > > + return err; > > > +} > > > +#else > > > +static int init_mmc(void) > > > +{ > > > + /* Expect somewhere already initialize MMC */ > > > + return 0; > > > +} > > > +#endif > > > + > > > +static int select_fs_dev(struct device_location > > > *location) > > > +{ > > > + int ret; > > > + > > > + if (!strcmp("mmc", location->name)) { > > > + ret = fs_set_blk_dev("mmc", location- > > > > > > > > devpart, > > > FS_TYPE_ANY); > > > + } else if (!strcmp("usb", location->name)) { > > > + ret = fs_set_blk_dev("usb", location- > > > > > > > > devpart, > > > FS_TYPE_ANY); > > > + } else if (!strcmp("sata", location->name)) { > > > + ret = fs_set_blk_dev("sata", location- > > > > > > > > > > > > devpart, > > > FS_TYPE_ANY); > > > + } else if (!strcmp("ubi", location->name)) { > > > + if (location->ubivol != NULL) > > > + ret = fs_set_blk_dev("ubi", > > > NULL, > > > FS_TYPE_UBIFS); > > > + else > > > + ret = -ENODEV; > > > + } else { > > > + printf("Error: unsupported location > > > storage.\n"); > > > + return -ENODEV; > > > + } > > > + > > > + if (ret) > > > + printf("Error: could not access > > > storage.\n"); > > > + > > > + return ret; > > > +} > > > + > > > +static int init_storage_device(struct device_location > > > *location) > > > +{ > > > + int ret; > > > + > > > + if (!strcmp("mmc", location->name)) { > > > + ret = init_mmc(); > > > + } else if (!strcmp("sata", location->name)) { > > > + ret = init_storage_sata(); > > > + } else if (location->ubivol != NULL) { > > > + ret = mount_ubifs(location); > > > +#ifndef CONFIG_SPL_BUILD > > > + /* USB build is not supported yet in SPL */ > > > + } else if (!strcmp("usb", location->name)) { > > > + ret = init_usb(); > > > +#endif > > > + } else { > > > + printf("Error: no supported storage > > > device > > > is > > > available.\n"); > > > + ret = -ENODEV; > > > + } > > > + > > > + return ret; > > > +} > > > + > > > +static void set_storage_devpart(char *name, char > > > *devpart) > > > +{ > > > + size_t i; > > > + > > > + for (i = 0; i < ARRAY_SIZE(default_locations); > > > i++) { > > > + if (!strcmp(default_locations[i].name, > > > name)) > > > + default_locations[i].devpart = > > > devpart; > > > + } > > > +} > > > + > > > +/* > > > + * Prepare firmware struct; > > > + * return -ve if fail. > > > + */ > > > +static int _request_firmware_prepare(struct firmware > > > **firmware_p, > > > + const char *name, > > > void > > > *dbuf, > > > + size_t size, u32 > > > offset) > > > +{ > > > + struct firmware *firmware; > > > + struct firmware_priv *fw_priv; > > > + > > > + *firmware_p = NULL; > > > + > > > + if (!name || name[0] == '\0') > > > + return -EINVAL; > > > + > > > + firmware = calloc(1, sizeof(*firmware)); > > > + if (!firmware) { > > > + printf("%s: calloc(struct firmware) > > > failed\n", > > > __func__); > > > + return -ENOMEM; > > > + } > > > + > > > + fw_priv = calloc(1, sizeof(*fw_priv)); > > > + if (!fw_priv) { > > > + printf("%s: calloc(struct fw_priv) > > > failed\n", > > > __func__); > > > + free(firmware); > > > + return -ENOMEM; > > > + } > > > + > > > + fw_priv->name = name; > > > + fw_priv->offset = offset; > > > + firmware->data = dbuf; > > > + firmware->size = size; > > > + firmware->priv = fw_priv; > > > + *firmware_p = firmware; > > > + > > > + return 0; > > > +} > > > + > > > +/* > > > + * fw_get_filesystem_firmware - load firmware into an > > > allocated > > > buffer > > > + * @location: An array of supported firmware location > > > + * @firmware_p: pointer to firmware image > > > + * > > > + * @return: size of total read > > > + * -ve when error > > > + */ > > > +static int fw_get_filesystem_firmware(struct > > > device_location > > > *location, > > > + struct firmware > > > *firmware_p) > > > +{ > > > + struct firmware_priv *fw_priv = NULL; > > > + loff_t actread; > > > + char *dev_part; > > > + int ret; > > > + > > > + dev_part = env_get("fw_dev_part"); > > > + if (dev_part) > > > + set_storage_devpart(location->name, > > > dev_part); > > > + > > > + ret = init_storage_device(location); > > > + if (ret) > > > + goto out; > > > + > > > + select_fs_dev(location); > > > > > 'ret = ' is missing. > > > Okay. > > > > > > > > > > > > > > > > > > > > > + if (ret) > > > + goto out; > > > + > > > + fw_priv = firmware_p->priv; > > > + > > > + ret = fs_read(fw_priv->name, > > > (ulong)firmware_p- > > > > > > > > data, > > > fw_priv->offset, > > > + firmware_p->size, &actread); > > > + > > > + if (ret) { > > > + printf("Error: %d Failed to read %s > > > from > > > flash > > > %lld != %d.\n", > > > + ret, fw_priv->name, actread, > > > firmware_p- > > > > > > > > > > > > > > > > size); > > > + return ret; > > Y > > Shouldn't this be 'goto out', do do the umount_ubifs() as > > in > > all > > other > > error cases? > > > okay. > > > > > > > > > > > > > > > > > > > > > + } else { > > > + ret = actread; > > > + } > > > > > What if actread != firmware_p->size? > > You handled it as an error before, now you happily return > > the > > number > > of > > bytes read in case of a short read. > > Operation not permitted > May be i misunderstand on ur previosly comment. There is > not > much > My comment was about returning -EPERM in this case. First of all you discarded the possible error code returned from fs_read() and secondly -EIO would be more appropriate than EPERM in case of reading less data than expected.
Okay.
> > > > description on fd_read, i just knowing that -ve is error > from > function > based on other example codes in U-Boot as they check the > error > with > "ret < 0" or "ret != 0". "actread != firmware_p->size" is > the > additonal > checking i added myself because when i digging to the code, > i > found > that such condition only with error printf inside the > function > without > any error code return. So, i am not sure when "actread != > firmware_p- > > > > > > > > size", the ret would be -ve too. If 'size' is the actual size of the caller provided buffer and not the exact size of the firmware to be loaded, the condition actread != size would not be an error at all. If 'size' designates the exact size of the firmware, that the caller may know by other means, it is obviously an error if actread != size. Since you treated actread != size as an error in your original patch I assumed the latter case.
NOOOOO! If fs_read() returns an error code, you should return that of course!
If the return code from fs_read() is zero, you should just return actread without spewing any message and let the caller handle the situation appropriately.
Lothar Waßmann
On Kha, 2017-12-21 at 12:53 +0100, Lothar Waßmann wrote: > > > > Hi, > > On Thu, 21 Dec 2017 09:36:41 +0000 Chee, Tien Fong wrote: > > > > > > > > > > On Kha, 2017-12-21 at 09:48 +0100, Lothar Waßmann > > wrote: > > > > > > > > > > > > > > > Hi, > > > > > > On Thu, 21 Dec 2017 15:25:29 +0800 tien.fong.chee@int > > > el.c > > > om > > > wrote: > > > > > > > > > > > > > > > > > > > > > > > > From: Tien Fong Chee tien.fong.chee@intel.com > > > > > > > > This is file system generic loader which can be > > > > used to > > > > load > > > > the file image from the storage into target such as > > > > memory. > > > > The consumer driver would then use this loader to > > > > program > > > > whatever, > > > > ie. the FPGA device. > > > > > > > > Signed-off-by: Tien Fong Chee <tien.fong.chee@intel > > > > .com > > > > > > > > > > > > > > --- > > > > common/Makefile | 1 + > > > > common/fs_loader.c | 311 > > > > +++++++++++++++++++++++++++++++++++++++++++++ > > > > doc/README.firmware_loader | 76 +++++++++++ > > > > include/fs_loader.h | 28 ++++ > > > > 4 files changed, 416 insertions(+) > > > > create mode 100644 common/fs_loader.c > > > > create mode 100644 doc/README.firmware_loader > > > > create mode 100644 include/fs_loader.h > > > > > > > > diff --git a/common/Makefile b/common/Makefile > > > > index cec506f..2934221 100644 > > > > --- a/common/Makefile > > > > +++ b/common/Makefile > > > > @@ -130,3 +130,4 @@ obj-$(CONFIG_CMD_DFU) += dfu.o > > > > obj-y += command.o > > > > obj-y += s_record.o > > > > obj-y += xyzModem.o > > > > +obj-y += fs_loader.o > > > > diff --git a/common/fs_loader.c > > > > b/common/fs_loader.c > > > > new file mode 100644 > > > > index 0000000..ddfce58 > > > > --- /dev/null > > > > +++ b/common/fs_loader.c > > > > @@ -0,0 +1,311 @@ > > > > +/* > > > > + * Copyright (C) 2017 Intel Corporation <www.intel > > > > .com > > > > > > > > > > > > > > + * > > > > + * SPDX-License-Identifier: GPL-2.0 > > > > + */ > > > > + > > > > +#include <common.h> > > > > +#include <errno.h> > > > > +#include <fs.h> > > > > +#include <fs_loader.h> > > > > +#include <nand.h> > > > > +#include <sata.h> > > > > +#include <spi.h> > > > > +#include <spi_flash.h> > > > > +#include <spl.h> > > > > +#include <linux/string.h> > > > > +#include <usb.h> > > > > + > > > > +struct firmware_priv { > > > > + const char *name; /* Filename */ > > > > + u32 offset; /* Offset of > > > > reading a > > > > file > > > > */ > > > > +}; > > > > + > > > > +static struct device_location default_locations[] > > > > = { > > > > + { > > > > + .name = "mmc", > > > > + .devpart = "0:1", > > > > + }, > > > > + { > > > > + .name = "usb", > > > > + .devpart = "0:1", > > > > + }, > > > > + { > > > > + .name = "sata", > > > > + .devpart = "0:1", > > > > + }, > > > > +}; > > > > + > > > > +/* USB build is not supported yet in SPL */ > > > > +#ifndef CONFIG_SPL_BUILD > > > > +#ifdef CONFIG_USB_STORAGE > > > > +static int init_usb(void) > > > > +{ > > > > + int err; > > > > + > > > > + err = usb_init(); > > > > + if (err) > > > > + return err; > > > > + > > > > +#ifndef CONFIG_DM_USB > > > > + err = usb_stor_scan(1) < 0 ? -ENODEV : 0; > > > > +#endif > > > > + > > > > + return err; > > > > +} > > > > +#else > > > > +static int init_usb(void) > > > > +{ > > > > + printf("Error: Cannot load flash image: no > > > > USB > > > > support\n"); > > > > + return -ENOSYS; > > > > +} > > > > +#endif > > > > +#endif > > > > + > > > > +#ifdef CONFIG_SATA > > > > +static int init_storage_sata(void) > > > > +{ > > > > + return sata_probe(0); > > > > +} > > > > +#else > > > > +static int init_storage_sata(void) > > > > +{ > > > > + printf("Error: Cannot load image: no SATA > > > > support\n"); > > > > + return -ENOSYS; > > > > +} > > > > +#endif > > > > + > > > > +#ifdef CONFIG_CMD_UBIFS > > > > +static int mount_ubifs(struct device_location > > > > *location) > > > > +{ > > > > + int ret; > > > > + char cmd[32]; > > > > + > > > > + sprintf(cmd, "ubi part %s", location- > > > > > > > > > > mtdpart); > > > > + > > > > + ret = run_command(cmd, 0); > > > > + if (ret) > > > > + return ret; > > > > + > > > > + sprintf(cmd, "ubifsmount %s", location- > > > > > > > > > > ubivol); > > > > + > > > > + ret = run_command(cmd, 0); > > > > + > > > > + return ret; > > > > +} > > > > + > > > > +static int umount_ubifs(void) > > > > +{ > > > > + return run_command("ubifsumount", 0); > > > > +} > > > > +#else > > > > +static int mount_ubifs(struct device_location > > > > *location) > > > > +{ > > > > + printf("Error: Cannot load image: no UBIFS > > > > support\n"); > > > > + return -ENOSYS; > > > > +} > > > > +#endif > > > > + > > > > +#if defined(CONFIG_SPL_MMC_SUPPORT) && > > > > defined(CONFIG_SPL_BUILD) > > > > +static int init_mmc(void) > > > > +{ > > > > + /* Just for the case MMC is not yet > > > > initialized */ > > > > + struct mmc *mmc = NULL; > > > > + int err; > > > > + > > > > + spl_mmc_find_device(&mmc, > > > > spl_boot_device()); > > > > + > > > > + err = mmc_init(mmc); > > > > + if (err) { > > > > + printf("spl: mmc init failed with > > > > error: > > > > %d\n", > > > > err); > > > > + return err; > > > > + } > > > > + > > > > + return err; > > > > +} > > > > +#else > > > > +static int init_mmc(void) > > > > +{ > > > > + /* Expect somewhere already initialize MMC > > > > */ > > > > + return 0; > > > > +} > > > > +#endif > > > > + > > > > +static int select_fs_dev(struct device_location > > > > *location) > > > > +{ > > > > + int ret; > > > > + > > > > + if (!strcmp("mmc", location->name)) { > > > > + ret = fs_set_blk_dev("mmc", > > > > location- > > > > > > > > > > > > > > > devpart, > > > > FS_TYPE_ANY); > > > > + } else if (!strcmp("usb", location->name)) > > > > { > > > > + ret = fs_set_blk_dev("usb", > > > > location- > > > > > > > > > > > > > > > devpart, > > > > FS_TYPE_ANY); > > > > + } else if (!strcmp("sata", location- > > > > >name)) { > > > > + ret = fs_set_blk_dev("sata", > > > > location- > > > > > > > > > > > > > > > > > > > > devpart, > > > > FS_TYPE_ANY); > > > > + } else if (!strcmp("ubi", location->name)) > > > > { > > > > + if (location->ubivol != NULL) > > > > + ret = > > > > fs_set_blk_dev("ubi", > > > > NULL, > > > > FS_TYPE_UBIFS); > > > > + else > > > > + ret = -ENODEV; > > > > + } else { > > > > + printf("Error: unsupported > > > > location > > > > storage.\n"); > > > > + return -ENODEV; > > > > + } > > > > + > > > > + if (ret) > > > > + printf("Error: could not access > > > > storage.\n"); > > > > + > > > > + return ret; > > > > +} > > > > + > > > > +static int init_storage_device(struct > > > > device_location > > > > *location) > > > > +{ > > > > + int ret; > > > > + > > > > + if (!strcmp("mmc", location->name)) { > > > > + ret = init_mmc(); > > > > + } else if (!strcmp("sata", location- > > > > >name)) { > > > > + ret = init_storage_sata(); > > > > + } else if (location->ubivol != NULL) { > > > > + ret = mount_ubifs(location); > > > > +#ifndef CONFIG_SPL_BUILD > > > > + /* USB build is not supported yet in SPL > > > > */ > > > > + } else if (!strcmp("usb", location->name)) > > > > { > > > > + ret = init_usb(); > > > > +#endif > > > > + } else { > > > > + printf("Error: no supported > > > > storage > > > > device > > > > is > > > > available.\n"); > > > > + ret = -ENODEV; > > > > + } > > > > + > > > > + return ret; > > > > +} > > > > + > > > > +static void set_storage_devpart(char *name, char > > > > *devpart) > > > > +{ > > > > + size_t i; > > > > + > > > > + for (i = 0; i < > > > > ARRAY_SIZE(default_locations); > > > > i++) { > > > > + if > > > > (!strcmp(default_locations[i].name, > > > > name)) > > > > + default_locations[i].devpa > > > > rt = > > > > devpart; > > > > + } > > > > +} > > > > + > > > > +/* > > > > + * Prepare firmware struct; > > > > + * return -ve if fail. > > > > + */ > > > > +static int _request_firmware_prepare(struct > > > > firmware > > > > **firmware_p, > > > > + const char > > > > *name, > > > > void > > > > *dbuf, > > > > + size_t size, > > > > u32 > > > > offset) > > > > +{ > > > > + struct firmware *firmware; > > > > + struct firmware_priv *fw_priv; > > > > + > > > > + *firmware_p = NULL; > > > > + > > > > + if (!name || name[0] == '\0') > > > > + return -EINVAL; > > > > + > > > > + firmware = calloc(1, sizeof(*firmware)); > > > > + if (!firmware) { > > > > + printf("%s: calloc(struct > > > > firmware) > > > > failed\n", > > > > __func__); > > > > + return -ENOMEM; > > > > + } > > > > + > > > > + fw_priv = calloc(1, sizeof(*fw_priv)); > > > > + if (!fw_priv) { > > > > + printf("%s: calloc(struct fw_priv) > > > > failed\n", > > > > __func__); > > > > + free(firmware); > > > > + return -ENOMEM; > > > > + } > > > > + > > > > + fw_priv->name = name; > > > > + fw_priv->offset = offset; > > > > + firmware->data = dbuf; > > > > + firmware->size = size; > > > > + firmware->priv = fw_priv; > > > > + *firmware_p = firmware; > > > > + > > > > + return 0; > > > > +} > > > > + > > > > +/* > > > > + * fw_get_filesystem_firmware - load firmware into > > > > an > > > > allocated > > > > buffer > > > > + * @location: An array of supported firmware > > > > location > > > > + * @firmware_p: pointer to firmware image > > > > + * > > > > + * @return: size of total read > > > > + * -ve when error > > > > + */ > > > > +static int fw_get_filesystem_firmware(struct > > > > device_location > > > > *location, > > > > + struct > > > > firmware > > > > *firmware_p) > > > > +{ > > > > + struct firmware_priv *fw_priv = NULL; > > > > + loff_t actread; > > > > + char *dev_part; > > > > + int ret; > > > > + > > > > + dev_part = env_get("fw_dev_part"); > > > > + if (dev_part) > > > > + set_storage_devpart(location- > > > > >name, > > > > dev_part); > > > > + > > > > + ret = init_storage_device(location); > > > > + if (ret) > > > > + goto out; > > > > + > > > > + select_fs_dev(location); > > > > > > > 'ret = ' is missing. > > > > > Okay. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > + if (ret) > > > > + goto out; > > > > + > > > > + fw_priv = firmware_p->priv; > > > > + > > > > + ret = fs_read(fw_priv->name, > > > > (ulong)firmware_p- > > > > > > > > > > > > > > > data, > > > > fw_priv->offset, > > > > + firmware_p->size, &actread); > > > > + > > > > + if (ret) { > > > > + printf("Error: %d Failed to read > > > > %s > > > > from > > > > flash > > > > %lld != %d.\n", > > > > + ret, fw_priv->name, actread, > > > > firmware_p- > > > > > > > > > > > > > > > > > > > > > > > > > size); > > > > + return ret; > > > Y > > > Shouldn't this be 'goto out', do do the > > > umount_ubifs() as > > > in > > > all > > > other > > > error cases? > > > > > okay. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > + } else { > > > > + ret = actread; > > > > + } > > > > > > > What if actread != firmware_p->size? > > > You handled it as an error before, now you happily > > > return > > > the > > > number > > > of > > > bytes read in case of a short read. > > > Operation not permitted > > May be i misunderstand on ur previosly comment. There > > is > > not > > much > > > My comment was about returning -EPERM in this case. > First of all you discarded the possible error code > returned > from > fs_read() and secondly -EIO would be more appropriate > than > EPERM > in > case of reading less data than expected. > One of the reason I prefer to use -EIO instead of return from fs_read, because i'm not sure when "actread != firmware_p->size", the return from the fs_read is still -ve or not.
size
Okay.
> > > > > > > > > > > > > description on fd_read, i just knowing that -ve is > > error > > from > > function > > based on other example codes in U-Boot as they check > > the > > error > > with > > "ret < 0" or "ret != 0". "actread != firmware_p->size" > > is > > the > > additonal > > checking i added myself because when i digging to the > > code, > > i > > found > > that such condition only with error printf inside the > > function > > without > > any error code return. So, i am not sure when "actread > > != > > firmware_p- > > > > > > > > > > > > > > > size", the ret would be -ve too. > If 'size' is the actual size of the caller provided > buffer > and > not > the > exact size of the firmware to be loaded, the condition > actread != > size > would not be an error at all. > If 'size' designates the exact size of the firmware, that > the > caller > may know by other means, it is obviously an error if > actread > != > size. > Since you treated actread != size as an error in your > original > patch > I > assumed the latter case. > The size here refer to the size of firmware or chunk of firmware to read when the buffer is smaller than firmware.
> > > > AFAICT Linux uses the first semantics ('size' specifies > the > size > of > the > caller provided buffer as an upper limit for the read() > call > and > not > the exact amount of data to be read). > Unfortunately the fs_read() semantics is fundamentally > broken > as > it > interprets 'size == 0' as 'read as much data as you can > get' > which > may > easily lead to buffer overflows and prints a very > unhelpful > error > message "<filename> shorter than offset + len" in case > 'size' > does > not > match the actual amount of data read. > > You should also consider what happens, if the firmware > file > you > read > is > larger than the buffer you provided, as in that case > fs_read() > will > stop reading at the provided buffer size and you won't be > able to > notice, that the file was not completely loaded! > I prefer to let the caller handles this, because this function can be used to read the firmware chunk by chunk when the allocated buffer is smaller than firmware.
Okay, i have no problem with that.
Lothar Waßmann
Chee, Tien Fong
Lothar Waßmann
