[U-Boot] Condition in bootcmd to run bootz else bootm
Hi, I'd like to set a condition in bootcmd to run uImage from flash if it can't find zImage on the filesystem.
Here is our zImage bootcmd... mmc dev 0; ext2load mmc 0:1 ${loadaddr} /opt/common/var/zImage; ext2load mmc 0:1 0x71000000 /opt/common/var/dtb; bootz ${loadaddr} - 0x71000000
Here is our uImage bootcmd... mmc read ${loadaddr} 0x800 0x1600; bootm
So I tried adding || like so, but it doesn't work... mmc dev 0; ext2load mmc 0:1 ${loadaddr} /opt/common/var/zImage; ext2load mmc 0:1 0x71000000 /opt/common/var/dtb; bootz ${loadaddr} - 0x71000000 || mmc read ${loadaddr} 0x800 0x1600; bootm
They work individually from command line, but when I add the || to boot uImage it just errors out like so...
** File not found /opt/common/var/zImage.tls4xx ** 30463 bytes read in 200 ms (148.4 KiB/s) Bad Linux ARM zImage magic! <--- this is correct since it can't find zImage Wrong Image Format for bootm command <---- it tried bootm here so maybe my || needs to be more strategically placed? ERROR: can't get kernel image! SYS42>
-- View this message in context: http://u-boot.10912.n7.nabble.com/Condition-in-bootcmd-to-run-bootz-else-boo... Sent from the U-Boot mailing list archive at Nabble.com.
Turns out what I have works once I turn on the hush parser...
#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */
DaveKucharczyk
