[PATCH v4 0/4] cmd: bootefi: refactor the code for bootmgr
This patch set is motivated by the discussion[1] regarding CONFIG_BOOTEFI_BOOTMGR option.
# This version (v4) contains only the remaining commits.
At the end, bootefi.c will be decomposed into two parts, one for providing the command itself and one for implementing helper functions. EFI_LOADER will now be available without CONFIG_CMDLINE or specifically CONFIG_CMD_BOOTEFI if invoked via bootmeth/bootstd.
Then, EFI_LOADER library side will be further split into two options for fine-grain control: CONFIG_EFI_BINARY_EXEC: execute UEFI binaries which are to be explicitly loaded by U-Boot's load commands/functions or other methods (like a jtag debugger?) It supports bootmeth_efi as well as "bootefi <addr>|hello"(/"bootm"?).
CONFIG_EFI_BOOTMGR: provide EFI boot manger functionality It supports bootmeth_efi_mgr as well as "bootefi bootmgr".
As such, We will no longer need CONFIG_EFI_BINARY_EXEC if we want to only make use of the UEFI boot manger for booting a next stage OS.
Prerequisite ============ This patch set is based on top of the latest "master" branch.
Tests ===== * ran and passed py/efi_selftest on sandbox locally (I saw an error in tcg2 though) * ran and passed py/test_efi_bootmgr on sandbox locally * passed CI check (github pull request)
Changes ======= v4 (Jan 10, 2024) * rebased onto the latest master branch * moved binary execution portion of code (EFI_BINARY_EXEC) to a new file, efi_bootbin.c, instead of efi_helper.c (patch#1)
v3 (Dec 18, 2023) * rebased onto Tom's latest next branch * remove already-merged commits
v2 (Nov 21, 2023) * rebased onto Tom's next branch * remove already merged commits * revise commit messages * add patch #5 which was split from ex-patch#5 RFC (Oct 26, 2023)
[1] https://lists.denx.de/pipermail/u-boot/2023-October/534598.html
AKASHI Takahiro (4): efi_loader: split unrelated code from efi_bootmgr.c efi_loader: rename BOOTEFI_BOOTMGR to EFI_BOOTMGR net: tftp: remove explicit efi configuration dependency fs: remove explicit efi configuration dependency
boot/Kconfig | 4 +- boot/Makefile | 2 +- cmd/Kconfig | 10 +- cmd/efidebug.c | 4 +- fs/fs.c | 7 +- include/efi_loader.h | 28 +- lib/efi_loader/Kconfig | 11 +- lib/efi_loader/Makefile | 3 +- lib/efi_loader/efi_bootbin.c | 211 +++++++++++++ lib/efi_loader/efi_bootmgr.c | 488 ------------------------------- lib/efi_loader/efi_device_path.c | 3 +- lib/efi_loader/efi_helper.c | 286 ++++++++++++++++++ net/tftp.c | 10 +- test/boot/bootflow.c | 2 +- 14 files changed, 546 insertions(+), 523 deletions(-) create mode 100644 lib/efi_loader/efi_bootbin.c
Some code moved from cmd/bootefi.c is actually necessary only for "bootefi <addr>" command (starting an image manually loaded by a user using U-Boot load commands or other methods (like JTAG debugger).
The code will never been opted out as unused code by a compiler which doesn't know how EFI boot manager is implemented. So introduce a new configuration, CONFIG_EFI_BINARY_EXEC, to enforce them opted out explicitly.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- v4 * moved binary execution portion of code (EFI_BINARY_EXEC) to a new file, efi_bootbin.c --- boot/Kconfig | 4 +- cmd/Kconfig | 6 +- include/efi_loader.h | 28 +- lib/efi_loader/Kconfig | 9 + lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_bootbin.c | 211 +++++++++++++ lib/efi_loader/efi_bootmgr.c | 488 ------------------------------- lib/efi_loader/efi_device_path.c | 3 +- lib/efi_loader/efi_helper.c | 286 ++++++++++++++++++ 9 files changed, 531 insertions(+), 505 deletions(-) create mode 100644 lib/efi_loader/efi_bootbin.c
diff --git a/boot/Kconfig b/boot/Kconfig index 9f5b8a0cb2c8..347f8cca7d0b 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -523,7 +523,7 @@ config BOOTMETH_EXTLINUX_PXE
config BOOTMETH_EFILOADER bool "Bootdev support for EFI boot" - depends on BOOTEFI_BOOTMGR + depends on EFI_BINARY_EXEC default y help Enables support for EFI boot using bootdevs. This makes the @@ -558,7 +558,7 @@ config BOOTMETH_DISTRO select BOOTMETH_SCRIPT if CMDLINE # E.g. Armbian uses scripts select BOOTMETH_EXTLINUX # E.g. Debian uses these select BOOTMETH_EXTLINUX_PXE if CMD_PXE && CMD_NET && DM_ETH - select BOOTMETH_EFILOADER if BOOTEFI_BOOTMGR # E.g. Ubuntu uses this + select BOOTMETH_EFILOADER if EFI_BINARY_EXEC # E.g. Ubuntu uses this
config SPL_BOOTMETH_VBE bool "Bootdev support for Verified Boot for Embedded (SPL)" diff --git a/cmd/Kconfig b/cmd/Kconfig index 26aeeeed03b6..150fa37a50a7 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -294,7 +294,7 @@ config CMD_BOOTMETH
config BOOTM_EFI bool "Support booting UEFI FIT images" - depends on BOOTEFI_BOOTMGR && CMD_BOOTM && FIT + depends on EFI_BINARY_EXEC && CMD_BOOTM && FIT default y help Support booting UEFI FIT images via the bootm command. @@ -386,7 +386,7 @@ config CMD_BOOTEFI if CMD_BOOTEFI config CMD_BOOTEFI_BINARY bool "Allow booting an EFI binary directly" - depends on BOOTEFI_BOOTMGR + depends on EFI_BINARY_EXEC default y help Select this option to enable direct execution of binary at 'bootefi'. @@ -416,7 +416,7 @@ config CMD_BOOTEFI_HELLO_COMPILE
config CMD_BOOTEFI_HELLO bool "Allow booting a standard EFI hello world for testing" - depends on CMD_BOOTEFI_HELLO_COMPILE + depends on CMD_BOOTEFI_BINARY && CMD_BOOTEFI_HELLO_COMPILE default y if CMD_BOOTEFI_SELFTEST help This adds a standard EFI hello world application to U-Boot so that diff --git a/include/efi_loader.h b/include/efi_loader.h index 34e7fbbf1840..484c9fad239f 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -90,11 +90,7 @@ efi_status_t efi_add_runtime_mmio(void *mmio_ptr, u64 len); * back to u-boot world */ void efi_restore_gd(void); -/* Call this to unset the current device name */ -void efi_clear_bootdev(void); -/* Call this to set the current device name */ -void efi_set_bootdev(const char *dev, const char *devnr, const char *path, - void *buffer, size_t buffer_size); + /* Called by networking code to memorize the dhcp ack package */ void efi_net_set_dhcp_ack(void *pkt, int len); /* Print information about all loaded images */ @@ -116,10 +112,6 @@ static inline efi_status_t efi_add_runtime_mmio(void *mmio_ptr, u64 len)
/* No loader configured, stub out EFI_ENTRY */ static inline void efi_restore_gd(void) { } -static inline void efi_clear_bootdev(void) { } -static inline void efi_set_bootdev(const char *dev, const char *devnr, - const char *path, void *buffer, - size_t buffer_size) { } static inline void efi_net_set_dhcp_ack(void *pkt, int len) { } static inline void efi_print_image_infos(void *pc) { } static inline efi_status_t efi_launch_capsules(void) @@ -129,6 +121,20 @@ static inline efi_status_t efi_launch_capsules(void)
#endif /* CONFIG_IS_ENABLED(EFI_LOADER) */
+#if CONFIG_IS_ENABLED(EFI_BINARY_EXEC) +/* Call this to unset the current device name */ +void efi_clear_bootdev(void); +/* Call this to set the current device name */ +void efi_set_bootdev(const char *dev, const char *devnr, const char *path, + void *buffer, size_t buffer_size); +#else +static inline void efi_clear_bootdev(void) { } + +static inline void efi_set_bootdev(const char *dev, const char *devnr, + const char *path, void *buffer, + size_t buffer_size) { } +#endif + /* Maximum number of configuration tables */ #define EFI_MAX_CONFIGURATION_TABLES 16
@@ -541,8 +547,8 @@ efi_status_t efi_env_set_load_options(efi_handle_t handle, const char *env_var, u16 **load_options); /* Install device tree */ efi_status_t efi_install_fdt(void *fdt); -/* Run loaded UEFI image */ -efi_status_t efi_run_image(void *source_buffer, efi_uintn_t source_size); +/* Execute loaded UEFI image */ +efi_status_t do_bootefi_exec(efi_handle_t handle, void *load_options); /* Run loaded UEFI image with given fdt */ efi_status_t efi_binary_run(void *image, size_t size, void *fdt); /* Initialize variable services */ diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index ea807342f02f..64f2f1cdd161 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -32,6 +32,15 @@ config EFI_LOADER
if EFI_LOADER
+config EFI_BINARY_EXEC + bool "Execute UEFI binary" + default y + help + Select this option if you want to execute the UEFI binary after + loading it with U-Boot load commands or other methods. + You may enable CMD_BOOTEFI_BINARY so that you can use bootefi + command to do that. + config BOOTEFI_BOOTMGR bool "UEFI Boot Manager" default y diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index 24d33d540999..f85d26d9724c 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -43,6 +43,7 @@ endif
obj-$(CONFIG_CMD_BOOTEFI_HELLO) += helloworld_efi.o obj-$(CONFIG_BOOTEFI_BOOTMGR) += efi_bootmgr.o +obj-$(CONFIG_EFI_BINARY_EXEC) += efi_bootbin.o obj-y += efi_boottime.o obj-y += efi_helper.o obj-$(CONFIG_EFI_HAVE_CAPSULE_SUPPORT) += efi_capsule.o diff --git a/lib/efi_loader/efi_bootbin.c b/lib/efi_loader/efi_bootbin.c new file mode 100644 index 000000000000..edc7542cda93 --- /dev/null +++ b/lib/efi_loader/efi_bootbin.c @@ -0,0 +1,211 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * For the code moved from cmd/bootefi.c + * Copyright (c) 2016 Alexander Graf + */ + +#define LOG_CATEGORY LOGC_EFI + +#include <charset.h> +#include <efi.h> +#include <efi_loader.h> +#include <env.h> +#include <image.h> +#include <log.h> +#include <malloc.h> + +static struct efi_device_path *bootefi_image_path; +static struct efi_device_path *bootefi_device_path; +static void *image_addr; +static size_t image_size; + +/** + * efi_get_image_parameters() - return image parameters + * + * @img_addr: address of loaded image in memory + * @img_size: size of loaded image + */ +void efi_get_image_parameters(void **img_addr, size_t *img_size) +{ + *img_addr = image_addr; + *img_size = image_size; +} + +/** + * efi_clear_bootdev() - clear boot device + */ +void efi_clear_bootdev(void) +{ + efi_free_pool(bootefi_device_path); + efi_free_pool(bootefi_image_path); + bootefi_device_path = NULL; + bootefi_image_path = NULL; + image_addr = NULL; + image_size = 0; +} + +/** + * efi_set_bootdev() - set boot device + * + * This function is called when a file is loaded, e.g. via the 'load' command. + * We use the path to this file to inform the UEFI binary about the boot device. + * + * @dev: device, e.g. "MMC" + * @devnr: number of the device, e.g. "1:2" + * @path: path to file loaded + * @buffer: buffer with file loaded + * @buffer_size: size of file loaded + */ +void efi_set_bootdev(const char *dev, const char *devnr, const char *path, + void *buffer, size_t buffer_size) +{ + struct efi_device_path *device, *image; + efi_status_t ret; + + log_debug("dev=%s, devnr=%s, path=%s, buffer=%p, size=%zx\n", dev, + devnr, path, buffer, buffer_size); + + /* Forget overwritten image */ + if (buffer + buffer_size >= image_addr && + image_addr + image_size >= buffer) + efi_clear_bootdev(); + + /* Remember only PE-COFF and FIT images */ + if (efi_check_pe(buffer, buffer_size, NULL) != EFI_SUCCESS) { + if (IS_ENABLED(CONFIG_FIT) && + !fit_check_format(buffer, IMAGE_SIZE_INVAL)) { + /* + * FIT images of type EFI_OS are started via command + * bootm. We should not use their boot device with the + * bootefi command. + */ + buffer = 0; + buffer_size = 0; + } else { + log_debug("- not remembering image\n"); + return; + } + } + + /* efi_set_bootdev() is typically called repeatedly, recover memory */ + efi_clear_bootdev(); + + image_addr = buffer; + image_size = buffer_size; + + ret = efi_dp_from_name(dev, devnr, path, &device, &image); + if (ret == EFI_SUCCESS) { + bootefi_device_path = device; + if (image) { + /* FIXME: image should not contain device */ + struct efi_device_path *image_tmp = image; + + efi_dp_split_file_path(image, &device, &image); + efi_free_pool(image_tmp); + } + bootefi_image_path = image; + log_debug("- boot device %pD\n", device); + if (image) + log_debug("- image %pD\n", image); + } else { + log_debug("- efi_dp_from_name() failed, err=%lx\n", ret); + efi_clear_bootdev(); + } +} + +/** + * efi_run_image() - run loaded UEFI image + * + * @source_buffer: memory address of the UEFI image + * @source_size: size of the UEFI image + * Return: status code + */ +efi_status_t efi_run_image(void *source_buffer, efi_uintn_t source_size) +{ + efi_handle_t mem_handle = NULL, handle; + struct efi_device_path *file_path = NULL; + struct efi_device_path *msg_path; + efi_status_t ret, ret2; + u16 *load_options; + + if (!bootefi_device_path || !bootefi_image_path) { + log_debug("Not loaded from disk\n"); + /* + * Special case for efi payload not loaded from disk, + * such as 'bootefi hello' or for example payload + * loaded directly into memory via JTAG, etc: + */ + file_path = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, + (uintptr_t)source_buffer, + source_size); + /* + * Make sure that device for device_path exist + * in load_image(). Otherwise, shell and grub will fail. + */ + ret = efi_install_multiple_protocol_interfaces(&mem_handle, + &efi_guid_device_path, + file_path, NULL); + if (ret != EFI_SUCCESS) + goto out; + msg_path = file_path; + } else { + file_path = efi_dp_append(bootefi_device_path, + bootefi_image_path); + msg_path = bootefi_image_path; + log_debug("Loaded from disk\n"); + } + + log_info("Booting %pD\n", msg_path); + + ret = EFI_CALL(efi_load_image(false, efi_root, file_path, source_buffer, + source_size, &handle)); + if (ret != EFI_SUCCESS) { + log_err("Loading image failed\n"); + goto out; + } + + /* Transfer environment variable as load options */ + ret = efi_env_set_load_options(handle, "bootargs", &load_options); + if (ret != EFI_SUCCESS) + goto out; + + ret = do_bootefi_exec(handle, load_options); + +out: + ret2 = efi_uninstall_multiple_protocol_interfaces(mem_handle, + &efi_guid_device_path, + file_path, NULL); + efi_free_pool(file_path); + return (ret != EFI_SUCCESS) ? ret : ret2; +} + +/** + * efi_binary_run() - run loaded UEFI image + * + * @image: memory address of the UEFI image + * @size: size of the UEFI image + * @fdt: device-tree + * + * Execute an EFI binary image loaded at @image. + * @size may be zero if the binary is loaded with U-Boot load command. + * + * Return: status code + */ +efi_status_t efi_binary_run(void *image, size_t size, void *fdt) +{ + efi_status_t ret; + + /* Initialize EFI drivers */ + ret = efi_init_obj_list(); + if (ret != EFI_SUCCESS) { + log_err("Error: Cannot initialize UEFI sub-system, r = %lu\n", + ret & ~EFI_ERROR_MASK); + return -1; + } + + ret = efi_install_fdt(fdt); + if (ret != EFI_SUCCESS) + return ret; + + return efi_run_image(image, size); +} diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index a032d3ae04e2..da9629146f54 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -3,8 +3,6 @@ * EFI boot manager * * Copyright (c) 2017 Rob Clark - * For the code moved from cmd/bootefi.c - * Copyright (c) 2016 Alexander Graf */
#define LOG_CATEGORY LOGC_EFI @@ -21,17 +19,6 @@ #include <efi_variable.h> #include <asm/unaligned.h>
-/* TODO: temporarily added here; clean up later */ -#include <bootm.h> -#include <efi_selftest.h> -#include <env.h> -#include <mapmem.h> -#include <asm/global_data.h> -#include <linux/libfdt.h> -#include <linux/libfdt_env.h> - -DECLARE_GLOBAL_DATA_PTR; - static const struct efi_boot_services *bs; static const struct efi_runtime_services *rs;
@@ -1128,384 +1115,6 @@ out: return ret; }
-static struct efi_device_path *bootefi_image_path; -static struct efi_device_path *bootefi_device_path; -static void *image_addr; -static size_t image_size; - -/** - * efi_get_image_parameters() - return image parameters - * - * @img_addr: address of loaded image in memory - * @img_size: size of loaded image - */ -void efi_get_image_parameters(void **img_addr, size_t *img_size) -{ - *img_addr = image_addr; - *img_size = image_size; -} - -/** - * efi_clear_bootdev() - clear boot device - */ -void efi_clear_bootdev(void) -{ - efi_free_pool(bootefi_device_path); - efi_free_pool(bootefi_image_path); - bootefi_device_path = NULL; - bootefi_image_path = NULL; - image_addr = NULL; - image_size = 0; -} - -/** - * efi_set_bootdev() - set boot device - * - * This function is called when a file is loaded, e.g. via the 'load' command. - * We use the path to this file to inform the UEFI binary about the boot device. - * - * @dev: device, e.g. "MMC" - * @devnr: number of the device, e.g. "1:2" - * @path: path to file loaded - * @buffer: buffer with file loaded - * @buffer_size: size of file loaded - */ -void efi_set_bootdev(const char *dev, const char *devnr, const char *path, - void *buffer, size_t buffer_size) -{ - struct efi_device_path *device, *image; - efi_status_t ret; - - log_debug("dev=%s, devnr=%s, path=%s, buffer=%p, size=%zx\n", dev, - devnr, path, buffer, buffer_size); - - /* Forget overwritten image */ - if (buffer + buffer_size >= image_addr && - image_addr + image_size >= buffer) - efi_clear_bootdev(); - - /* Remember only PE-COFF and FIT images */ - if (efi_check_pe(buffer, buffer_size, NULL) != EFI_SUCCESS) { - if (IS_ENABLED(CONFIG_FIT) && - !fit_check_format(buffer, IMAGE_SIZE_INVAL)) { - /* - * FIT images of type EFI_OS are started via command - * bootm. We should not use their boot device with the - * bootefi command. - */ - buffer = 0; - buffer_size = 0; - } else { - log_debug("- not remembering image\n"); - return; - } - } - - /* efi_set_bootdev() is typically called repeatedly, recover memory */ - efi_clear_bootdev(); - - image_addr = buffer; - image_size = buffer_size; - - ret = efi_dp_from_name(dev, devnr, path, &device, &image); - if (ret == EFI_SUCCESS) { - bootefi_device_path = device; - if (image) { - /* FIXME: image should not contain device */ - struct efi_device_path *image_tmp = image; - - efi_dp_split_file_path(image, &device, &image); - efi_free_pool(image_tmp); - } - bootefi_image_path = image; - log_debug("- boot device %pD\n", device); - if (image) - log_debug("- image %pD\n", image); - } else { - log_debug("- efi_dp_from_name() failed, err=%lx\n", ret); - efi_clear_bootdev(); - } -} - -/** - * efi_env_set_load_options() - set load options from environment variable - * - * @handle: the image handle - * @env_var: name of the environment variable - * @load_options: pointer to load options (output) - * Return: status code - */ -efi_status_t efi_env_set_load_options(efi_handle_t handle, - const char *env_var, - u16 **load_options) -{ - const char *env = env_get(env_var); - size_t size; - u16 *pos; - efi_status_t ret; - - *load_options = NULL; - if (!env) - return EFI_SUCCESS; - size = sizeof(u16) * (utf8_utf16_strlen(env) + 1); - pos = calloc(size, 1); - if (!pos) - return EFI_OUT_OF_RESOURCES; - *load_options = pos; - utf8_utf16_strcpy(&pos, env); - ret = efi_set_load_options(handle, size, *load_options); - if (ret != EFI_SUCCESS) { - free(*load_options); - *load_options = NULL; - } - return ret; -} - -/** - * copy_fdt() - Copy the device tree to a new location available to EFI - * - * The FDT is copied to a suitable location within the EFI memory map. - * Additional 12 KiB are added to the space in case the device tree needs to be - * expanded later with fdt_open_into(). - * - * @fdtp: On entry a pointer to the flattened device tree. - * On exit a pointer to the copy of the flattened device tree. - * FDT start - * Return: status code - */ -static efi_status_t copy_fdt(void **fdtp) -{ - unsigned long fdt_ram_start = -1L, fdt_pages; - efi_status_t ret = 0; - void *fdt, *new_fdt; - u64 new_fdt_addr; - uint fdt_size; - int i; - - for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { - u64 ram_start = gd->bd->bi_dram[i].start; - u64 ram_size = gd->bd->bi_dram[i].size; - - if (!ram_size) - continue; - - if (ram_start < fdt_ram_start) - fdt_ram_start = ram_start; - } - - /* - * Give us at least 12 KiB of breathing room in case the device tree - * needs to be expanded later. - */ - fdt = *fdtp; - fdt_pages = efi_size_in_pages(fdt_totalsize(fdt) + 0x3000); - fdt_size = fdt_pages << EFI_PAGE_SHIFT; - - ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, - EFI_ACPI_RECLAIM_MEMORY, fdt_pages, - &new_fdt_addr); - if (ret != EFI_SUCCESS) { - log_err("ERROR: Failed to reserve space for FDT\n"); - goto done; - } - new_fdt = (void *)(uintptr_t)new_fdt_addr; - memcpy(new_fdt, fdt, fdt_totalsize(fdt)); - fdt_set_totalsize(new_fdt, fdt_size); - - *fdtp = (void *)(uintptr_t)new_fdt_addr; -done: - return ret; -} - -/** - * get_config_table() - get configuration table - * - * @guid: GUID of the configuration table - * Return: pointer to configuration table or NULL - */ -static void *get_config_table(const efi_guid_t *guid) -{ - size_t i; - - for (i = 0; i < systab.nr_tables; i++) { - if (!guidcmp(guid, &systab.tables[i].guid)) - return systab.tables[i].table; - } - return NULL; -} - -/** - * efi_install_fdt() - install device tree - * - * If fdt is not EFI_FDT_USE_INTERNAL, the device tree located at that memory - * address will be installed as configuration table, otherwise the device - * tree located at the address indicated by environment variable fdt_addr or as - * fallback fdtcontroladdr will be used. - * - * On architectures using ACPI tables device trees shall not be installed as - * configuration table. - * - * @fdt: address of device tree or EFI_FDT_USE_INTERNAL to use - * the hardware device tree as indicated by environment variable - * fdt_addr or as fallback the internal device tree as indicated by - * the environment variable fdtcontroladdr - * Return: status code - */ -efi_status_t efi_install_fdt(void *fdt) -{ - struct bootm_headers img = { 0 }; - efi_status_t ret; - - /* - * The EBBR spec requires that we have either an FDT or an ACPI table - * but not both. - */ - if (CONFIG_IS_ENABLED(GENERATE_ACPI_TABLE) && fdt) - log_warning("WARNING: Can't have ACPI table and device tree - ignoring DT.\n"); - - if (fdt == EFI_FDT_USE_INTERNAL) { - const char *fdt_opt; - uintptr_t fdt_addr; - - /* Look for device tree that is already installed */ - if (get_config_table(&efi_guid_fdt)) - return EFI_SUCCESS; - /* Check if there is a hardware device tree */ - fdt_opt = env_get("fdt_addr"); - /* Use our own device tree as fallback */ - if (!fdt_opt) { - fdt_opt = env_get("fdtcontroladdr"); - if (!fdt_opt) { - log_err("ERROR: need device tree\n"); - return EFI_NOT_FOUND; - } - } - fdt_addr = hextoul(fdt_opt, NULL); - if (!fdt_addr) { - log_err("ERROR: invalid $fdt_addr or $fdtcontroladdr\n"); - return EFI_LOAD_ERROR; - } - fdt = map_sysmem(fdt_addr, 0); - } - - /* Install device tree */ - if (fdt_check_header(fdt)) { - log_err("ERROR: invalid device tree\n"); - return EFI_LOAD_ERROR; - } - - /* Create memory reservations as indicated by the device tree */ - efi_carve_out_dt_rsv(fdt); - - if (CONFIG_IS_ENABLED(GENERATE_ACPI_TABLE)) - return EFI_SUCCESS; - - /* Prepare device tree for payload */ - ret = copy_fdt(&fdt); - if (ret) { - log_err("ERROR: out of memory\n"); - return EFI_OUT_OF_RESOURCES; - } - - if (image_setup_libfdt(&img, fdt, NULL)) { - log_err("ERROR: failed to process device tree\n"); - return EFI_LOAD_ERROR; - } - - efi_try_purge_kaslr_seed(fdt); - - if (CONFIG_IS_ENABLED(EFI_TCG2_PROTOCOL_MEASURE_DTB)) { - ret = efi_tcg2_measure_dtb(fdt); - if (ret == EFI_SECURITY_VIOLATION) { - log_err("ERROR: failed to measure DTB\n"); - return ret; - } - } - - /* Install device tree as UEFI table */ - ret = efi_install_configuration_table(&efi_guid_fdt, fdt); - if (ret != EFI_SUCCESS) { - log_err("ERROR: failed to install device tree\n"); - return ret; - } - - return EFI_SUCCESS; -} - -/** - * do_bootefi_exec() - execute EFI binary - * - * The image indicated by @handle is started. When it returns the allocated - * memory for the @load_options is freed. - * - * @handle: handle of loaded image - * @load_options: load options - * Return: status code - * - * Load the EFI binary into a newly assigned memory unwinding the relocation - * information, install the loaded image protocol, and call the binary. - */ -static efi_status_t do_bootefi_exec(efi_handle_t handle, void *load_options) -{ - efi_status_t ret; - efi_uintn_t exit_data_size = 0; - u16 *exit_data = NULL; - struct efi_event *evt; - - /* On ARM switch from EL3 or secure mode to EL2 or non-secure mode */ - switch_to_non_secure_mode(); - - /* - * The UEFI standard requires that the watchdog timer is set to five - * minutes when invoking an EFI boot option. - * - * Unified Extensible Firmware Interface (UEFI), version 2.7 Errata A - * 7.5. Miscellaneous Boot Services - EFI_BOOT_SERVICES.SetWatchdogTimer - */ - ret = efi_set_watchdog(300); - if (ret != EFI_SUCCESS) { - log_err("ERROR: Failed to set watchdog timer\n"); - goto out; - } - - /* Call our payload! */ - ret = EFI_CALL(efi_start_image(handle, &exit_data_size, &exit_data)); - if (ret != EFI_SUCCESS) { - log_err("## Application failed, r = %lu\n", - ret & ~EFI_ERROR_MASK); - if (exit_data) { - log_err("## %ls\n", exit_data); - efi_free_pool(exit_data); - } - } - - efi_restore_gd(); - -out: - free(load_options); - - if (IS_ENABLED(CONFIG_EFI_LOAD_FILE2_INITRD)) { - if (efi_initrd_deregister() != EFI_SUCCESS) - log_err("Failed to remove loadfile2 for initrd\n"); - } - - /* Notify EFI_EVENT_GROUP_RETURN_TO_EFIBOOTMGR event group. */ - list_for_each_entry(evt, &efi_events, link) { - if (evt->group && - !guidcmp(evt->group, - &efi_guid_event_group_return_to_efibootmgr)) { - efi_signal_event(evt); - EFI_CALL(systab.boottime->close_event(evt)); - break; - } - } - - /* Control is returned to U-Boot, disable EFI watchdog */ - efi_set_watchdog(0); - - return ret; -} - /** * efi_bootmgr_run() - execute EFI boot manager * @fdt: Flat device tree @@ -1542,100 +1151,3 @@ efi_status_t efi_bootmgr_run(void *fdt)
return do_bootefi_exec(handle, load_options); } - -/** - * efi_run_image() - run loaded UEFI image - * - * @source_buffer: memory address of the UEFI image - * @source_size: size of the UEFI image - * Return: status code - */ -efi_status_t efi_run_image(void *source_buffer, efi_uintn_t source_size) -{ - efi_handle_t mem_handle = NULL, handle; - struct efi_device_path *file_path = NULL; - struct efi_device_path *msg_path; - efi_status_t ret, ret2; - u16 *load_options; - - if (!bootefi_device_path || !bootefi_image_path) { - log_debug("Not loaded from disk\n"); - /* - * Special case for efi payload not loaded from disk, - * such as 'bootefi hello' or for example payload - * loaded directly into memory via JTAG, etc: - */ - file_path = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, - (uintptr_t)source_buffer, - source_size); - /* - * Make sure that device for device_path exist - * in load_image(). Otherwise, shell and grub will fail. - */ - ret = efi_install_multiple_protocol_interfaces(&mem_handle, - &efi_guid_device_path, - file_path, NULL); - if (ret != EFI_SUCCESS) - goto out; - msg_path = file_path; - } else { - file_path = efi_dp_append(bootefi_device_path, - bootefi_image_path); - msg_path = bootefi_image_path; - log_debug("Loaded from disk\n"); - } - - log_info("Booting %pD\n", msg_path); - - ret = EFI_CALL(efi_load_image(false, efi_root, file_path, source_buffer, - source_size, &handle)); - if (ret != EFI_SUCCESS) { - log_err("Loading image failed\n"); - goto out; - } - - /* Transfer environment variable as load options */ - ret = efi_env_set_load_options(handle, "bootargs", &load_options); - if (ret != EFI_SUCCESS) - goto out; - - ret = do_bootefi_exec(handle, load_options); - -out: - ret2 = efi_uninstall_multiple_protocol_interfaces(mem_handle, - &efi_guid_device_path, - file_path, NULL); - efi_free_pool(file_path); - return (ret != EFI_SUCCESS) ? ret : ret2; -} - -/** - * efi_binary_run() - run loaded UEFI image - * - * @image: memory address of the UEFI image - * @size: size of the UEFI image - * @fdt: device-tree - * - * Execute an EFI binary image loaded at @image. - * @size may be zero if the binary is loaded with U-Boot load command. - * - * Return: status code - */ -efi_status_t efi_binary_run(void *image, size_t size, void *fdt) -{ - efi_status_t ret; - - /* Initialize EFI drivers */ - ret = efi_init_obj_list(); - if (ret != EFI_SUCCESS) { - log_err("Error: Cannot initialize UEFI sub-system, r = %lu\n", - ret & ~EFI_ERROR_MASK); - return -1; - } - - ret = efi_install_fdt(fdt); - if (ret != EFI_SUCCESS) - return ret; - - return efi_run_image(image, size); -} diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index 8dbd8105ae26..ae3f6a6f5fd7 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -1089,7 +1089,8 @@ efi_status_t efi_dp_from_name(const char *dev, const char *devnr, if (path && !file) return EFI_INVALID_PARAMETER;
- if (!strcmp(dev, "Mem") || !strcmp(dev, "hostfs")) { + if (IS_ENABLED(CONFIG_EFI_BINARY_EXEC) && + (!strcmp(dev, "Mem") || !strcmp(dev, "hostfs"))) { /* loadm command and semihosting */ efi_get_image_parameters(&image_addr, &image_size);
diff --git a/lib/efi_loader/efi_helper.c b/lib/efi_loader/efi_helper.c index 17f27ca1a0b2..11066eb505dc 100644 --- a/lib/efi_loader/efi_helper.c +++ b/lib/efi_loader/efi_helper.c @@ -4,13 +4,20 @@ */
#define LOG_CATEGORY LOGC_EFI +#include <bootm.h> #include <env.h> +#include <image.h> +#include <log.h> #include <malloc.h> +#include <mapmem.h> #include <dm.h> #include <fs.h> +#include <efi_api.h> #include <efi_load_initrd.h> #include <efi_loader.h> #include <efi_variable.h> +#include <linux/libfdt.h> +#include <linux/list.h>
#if defined(CONFIG_CMD_EFIDEBUG) || defined(CONFIG_EFI_LOAD_FILE2_INITRD) /* GUID used by Linux to identify the LoadFile2 protocol with the initrd */ @@ -281,3 +288,282 @@ bool efi_search_bootorder(u16 *bootorder, efi_uintn_t num, u32 target, u32 *inde
return false; } + +/** + * efi_env_set_load_options() - set load options from environment variable + * + * @handle: the image handle + * @env_var: name of the environment variable + * @load_options: pointer to load options (output) + * Return: status code + */ +efi_status_t efi_env_set_load_options(efi_handle_t handle, + const char *env_var, + u16 **load_options) +{ + const char *env = env_get(env_var); + size_t size; + u16 *pos; + efi_status_t ret; + + *load_options = NULL; + if (!env) + return EFI_SUCCESS; + size = sizeof(u16) * (utf8_utf16_strlen(env) + 1); + pos = calloc(size, 1); + if (!pos) + return EFI_OUT_OF_RESOURCES; + *load_options = pos; + utf8_utf16_strcpy(&pos, env); + ret = efi_set_load_options(handle, size, *load_options); + if (ret != EFI_SUCCESS) { + free(*load_options); + *load_options = NULL; + } + return ret; +} + +/** + * copy_fdt() - Copy the device tree to a new location available to EFI + * + * The FDT is copied to a suitable location within the EFI memory map. + * Additional 12 KiB are added to the space in case the device tree needs to be + * expanded later with fdt_open_into(). + * + * @fdtp: On entry a pointer to the flattened device tree. + * On exit a pointer to the copy of the flattened device tree. + * FDT start + * Return: status code + */ +static efi_status_t copy_fdt(void **fdtp) +{ + unsigned long fdt_ram_start = -1L, fdt_pages; + efi_status_t ret = 0; + void *fdt, *new_fdt; + u64 new_fdt_addr; + uint fdt_size; + int i; + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + u64 ram_start = gd->bd->bi_dram[i].start; + u64 ram_size = gd->bd->bi_dram[i].size; + + if (!ram_size) + continue; + + if (ram_start < fdt_ram_start) + fdt_ram_start = ram_start; + } + + /* + * Give us at least 12 KiB of breathing room in case the device tree + * needs to be expanded later. + */ + fdt = *fdtp; + fdt_pages = efi_size_in_pages(fdt_totalsize(fdt) + 0x3000); + fdt_size = fdt_pages << EFI_PAGE_SHIFT; + + ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, + EFI_ACPI_RECLAIM_MEMORY, fdt_pages, + &new_fdt_addr); + if (ret != EFI_SUCCESS) { + log_err("ERROR: Failed to reserve space for FDT\n"); + goto done; + } + new_fdt = (void *)(uintptr_t)new_fdt_addr; + memcpy(new_fdt, fdt, fdt_totalsize(fdt)); + fdt_set_totalsize(new_fdt, fdt_size); + + *fdtp = (void *)(uintptr_t)new_fdt_addr; +done: + return ret; +} + +/** + * get_config_table() - get configuration table + * + * @guid: GUID of the configuration table + * Return: pointer to configuration table or NULL + */ +static void *get_config_table(const efi_guid_t *guid) +{ + size_t i; + + for (i = 0; i < systab.nr_tables; i++) { + if (!guidcmp(guid, &systab.tables[i].guid)) + return systab.tables[i].table; + } + return NULL; +} + +/** + * efi_install_fdt() - install device tree + * + * If fdt is not EFI_FDT_USE_INTERNAL, the device tree located at that memory + * address will be installed as configuration table, otherwise the device + * tree located at the address indicated by environment variable fdt_addr or as + * fallback fdtcontroladdr will be used. + * + * On architectures using ACPI tables device trees shall not be installed as + * configuration table. + * + * @fdt: address of device tree or EFI_FDT_USE_INTERNAL to use + * the hardware device tree as indicated by environment variable + * fdt_addr or as fallback the internal device tree as indicated by + * the environment variable fdtcontroladdr + * Return: status code + */ +efi_status_t efi_install_fdt(void *fdt) +{ + struct bootm_headers img = { 0 }; + efi_status_t ret; + + /* + * The EBBR spec requires that we have either an FDT or an ACPI table + * but not both. + */ + if (CONFIG_IS_ENABLED(GENERATE_ACPI_TABLE) && fdt) + log_warning("WARNING: Can't have ACPI table and device tree - ignoring DT.\n"); + + if (fdt == EFI_FDT_USE_INTERNAL) { + const char *fdt_opt; + uintptr_t fdt_addr; + + /* Look for device tree that is already installed */ + if (get_config_table(&efi_guid_fdt)) + return EFI_SUCCESS; + /* Check if there is a hardware device tree */ + fdt_opt = env_get("fdt_addr"); + /* Use our own device tree as fallback */ + if (!fdt_opt) { + fdt_opt = env_get("fdtcontroladdr"); + if (!fdt_opt) { + log_err("ERROR: need device tree\n"); + return EFI_NOT_FOUND; + } + } + fdt_addr = hextoul(fdt_opt, NULL); + if (!fdt_addr) { + log_err("ERROR: invalid $fdt_addr or $fdtcontroladdr\n"); + return EFI_LOAD_ERROR; + } + fdt = map_sysmem(fdt_addr, 0); + } + + /* Install device tree */ + if (fdt_check_header(fdt)) { + log_err("ERROR: invalid device tree\n"); + return EFI_LOAD_ERROR; + } + + /* Create memory reservations as indicated by the device tree */ + efi_carve_out_dt_rsv(fdt); + + if (CONFIG_IS_ENABLED(GENERATE_ACPI_TABLE)) + return EFI_SUCCESS; + + /* Prepare device tree for payload */ + ret = copy_fdt(&fdt); + if (ret) { + log_err("ERROR: out of memory\n"); + return EFI_OUT_OF_RESOURCES; + } + + if (image_setup_libfdt(&img, fdt, NULL)) { + log_err("ERROR: failed to process device tree\n"); + return EFI_LOAD_ERROR; + } + + efi_try_purge_kaslr_seed(fdt); + + if (CONFIG_IS_ENABLED(EFI_TCG2_PROTOCOL_MEASURE_DTB)) { + ret = efi_tcg2_measure_dtb(fdt); + if (ret == EFI_SECURITY_VIOLATION) { + log_err("ERROR: failed to measure DTB\n"); + return ret; + } + } + + /* Install device tree as UEFI table */ + ret = efi_install_configuration_table(&efi_guid_fdt, fdt); + if (ret != EFI_SUCCESS) { + log_err("ERROR: failed to install device tree\n"); + return ret; + } + + return EFI_SUCCESS; +} + +/** + * do_bootefi_exec() - execute EFI binary + * + * The image indicated by @handle is started. When it returns the allocated + * memory for the @load_options is freed. + * + * @handle: handle of loaded image + * @load_options: load options + * Return: status code + * + * Load the EFI binary into a newly assigned memory unwinding the relocation + * information, install the loaded image protocol, and call the binary. + */ +efi_status_t do_bootefi_exec(efi_handle_t handle, void *load_options) +{ + efi_status_t ret; + efi_uintn_t exit_data_size = 0; + u16 *exit_data = NULL; + struct efi_event *evt; + + /* On ARM switch from EL3 or secure mode to EL2 or non-secure mode */ + switch_to_non_secure_mode(); + + /* + * The UEFI standard requires that the watchdog timer is set to five + * minutes when invoking an EFI boot option. + * + * Unified Extensible Firmware Interface (UEFI), version 2.7 Errata A + * 7.5. Miscellaneous Boot Services - EFI_BOOT_SERVICES.SetWatchdogTimer + */ + ret = efi_set_watchdog(300); + if (ret != EFI_SUCCESS) { + log_err("ERROR: Failed to set watchdog timer\n"); + goto out; + } + + /* Call our payload! */ + ret = EFI_CALL(efi_start_image(handle, &exit_data_size, &exit_data)); + if (ret != EFI_SUCCESS) { + log_err("## Application failed, r = %lu\n", + ret & ~EFI_ERROR_MASK); + if (exit_data) { + log_err("## %ls\n", exit_data); + efi_free_pool(exit_data); + } + } + + efi_restore_gd(); + +out: + free(load_options); + + if (IS_ENABLED(CONFIG_EFI_LOAD_FILE2_INITRD)) { + if (efi_initrd_deregister() != EFI_SUCCESS) + log_err("Failed to remove loadfile2 for initrd\n"); + } + + /* Notify EFI_EVENT_GROUP_RETURN_TO_EFIBOOTMGR event group. */ + list_for_each_entry(evt, &efi_events, link) { + if (evt->group && + !guidcmp(evt->group, + &efi_guid_event_group_return_to_efibootmgr)) { + efi_signal_event(evt); + EFI_CALL(systab.boottime->close_event(evt)); + break; + } + } + + /* Control is returned to U-Boot, disable EFI watchdog */ + efi_set_watchdog(0); + + return ret; +}
At this point, EFI boot manager interfaces is fully independent from bootefi command. So just rename the configuration parameter.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- boot/Makefile | 2 +- cmd/Kconfig | 4 ++-- cmd/efidebug.c | 4 ++-- lib/efi_loader/Kconfig | 2 +- lib/efi_loader/Makefile | 2 +- test/boot/bootflow.c | 2 +- 6 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/boot/Makefile b/boot/Makefile index a90ebea5a867..bcd01cfc890c 100644 --- a/boot/Makefile +++ b/boot/Makefile @@ -34,7 +34,7 @@ obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_CROS) += bootm.o bootm_os.o bootmeth_cros.o obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_SANDBOX) += bootmeth_sandbox.o obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_SCRIPT) += bootmeth_script.o ifdef CONFIG_$(SPL_TPL_)BOOTSTD_FULL -obj-$(CONFIG_BOOTEFI_BOOTMGR) += bootmeth_efi_mgr.o +obj-$(CONFIG_EFI_BOOTMGR) += bootmeth_efi_mgr.o obj-$(CONFIG_$(SPL_TPL_)EXPO) += bootflow_menu.o obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += bootflow_menu.o obj-$(CONFIG_$(SPL_TPL_)CEDIT) += cedit.o diff --git a/cmd/Kconfig b/cmd/Kconfig index 150fa37a50a7..62d2ae3d3f1b 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -395,7 +395,7 @@ config CMD_BOOTEFI_BINARY
config CMD_BOOTEFI_BOOTMGR bool "UEFI Boot Manager command" - depends on BOOTEFI_BOOTMGR + depends on EFI_BOOTMGR default y help Select this option to enable the 'bootmgr' subcommand of 'bootefi'. @@ -2153,7 +2153,7 @@ config CMD_EFIDEBUG config CMD_EFICONFIG bool "eficonfig - provide menu-driven uefi variables maintenance interface" default y if !HAS_BOARD_SIZE_LIMIT - depends on BOOTEFI_BOOTMGR + depends on EFI_BOOTMGR select MENU help Enable the 'eficonfig' command which provides the menu-driven UEFI diff --git a/cmd/efidebug.c b/cmd/efidebug.c index e10fbf891a42..b4954258eeba 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -1410,7 +1410,7 @@ static __maybe_unused int do_efi_test_bootmgr(struct cmd_tbl *cmdtp, int flag, }
static struct cmd_tbl cmd_efidebug_test_sub[] = { -#ifdef CONFIG_BOOTEFI_BOOTMGR +#ifdef CONFIG_EFI_BOOTMGR U_BOOT_CMD_MKENT(bootmgr, CONFIG_SYS_MAXARGS, 1, do_efi_test_bootmgr, "", ""), #endif @@ -1604,7 +1604,7 @@ U_BOOT_LONGHELP(efidebug, " - show UEFI memory map\n" "efidebug tables\n" " - show UEFI configuration tables\n" -#ifdef CONFIG_BOOTEFI_BOOTMGR +#ifdef CONFIG_EFI_BOOTMGR "efidebug test bootmgr\n" " - run simple bootmgr for test\n" #endif diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 64f2f1cdd161..db5571de1d95 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -41,7 +41,7 @@ config EFI_BINARY_EXEC You may enable CMD_BOOTEFI_BINARY so that you can use bootefi command to do that.
-config BOOTEFI_BOOTMGR +config EFI_BOOTMGR bool "UEFI Boot Manager" default y select BOOTMETH_GLOBAL if BOOTSTD diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index f85d26d9724c..56e5ce220a3e 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -42,7 +42,7 @@ targets += initrddump.o endif
obj-$(CONFIG_CMD_BOOTEFI_HELLO) += helloworld_efi.o -obj-$(CONFIG_BOOTEFI_BOOTMGR) += efi_bootmgr.o +obj-$(CONFIG_EFI_BOOTMGR) += efi_bootmgr.o obj-$(CONFIG_EFI_BINARY_EXEC) += efi_bootbin.o obj-y += efi_boottime.o obj-y += efi_helper.o diff --git a/test/boot/bootflow.c b/test/boot/bootflow.c index 104f49deef2a..fa54dde661c8 100644 --- a/test/boot/bootflow.c +++ b/test/boot/bootflow.c @@ -374,7 +374,7 @@ static int bootflow_system(struct unit_test_state *uts) { struct udevice *bootstd, *dev;
- if (!IS_ENABLED(CONFIG_BOOTEFI_BOOTMGR)) + if (!IS_ENABLED(CONFIG_EFI_BOOTMGR)) return -EAGAIN; ut_assertok(uclass_first_device_err(UCLASS_BOOTSTD, &bootstd)); ut_assertok(device_bind(bootstd, DM_DRIVER_GET(bootmeth_efi_mgr),
This patch breaks the 'bootefi hello' command in qemu-riscv64_smode_defconfig and other QEMU defconfigs.
Best regards
Heinrich
What happened? Please elaborate details so that I can trace your issue.
On my side, I didn't see any problem with "bootefi hello" on qemu-arm64 and moreover CI check (github pull request) didn't complain anything.
-Takahiro Akashi
Best regards
Heinrich
The failures are logged in https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/19302
I have pushed the tag failed_20240114 to https://source.denx.de/u-boot/custodians/u-boot-efi.git for analysis.
Best regards
Heinrich
In the logs for qemu-arm64, qemu-risc64 and maybe others as well, I see the same error: --- --- ______________________________ test_efi_grub_net _______________________________ test/py/tests/test_efi_loader.py:188: in test_efi_grub_net addr = fetch_tftp_file(u_boot_console, 'env__efi_loader_grub_file') test/py/tests/test_efi_loader.py:136: in fetch_tftp_file assert expected_text in output E assert 'Bytes transferred = 520192' in "*** ERROR: `serverip' not set" --- ---
This seems to be the root cause and my commit will have nothing to do with the problem. Please check the test environment.
-Takahiro Akashi
Best regards
Heinrich
You are looking at test_efi_grub_net. I referred to 'bootefi hello', i.e. test_efi_helloworld_builtin:
----------------------------- Captured stdout call ----------------------------- => bootefi hello
The command does not provide any output.
Best regards
Heinrich
-Takahiro Akashi
Best regards
Heinrich
=> bootefi hello
Ah, yeah, but
Best regards
Heinrich
-Takahiro Akashi
While I compiled this code and tried to run "bootefi hello", I could not reproduce this issue, always seeing the right output either on qemu-arm64 or sandbox64. (I also invoked test_efi_loader/efi_helloworld_builtin locally, but the test passed.) So no clue.
-Takahiro Akashi
Best regards
Heinrich
On 1/10/24 02:16, AKASHI Takahiro wrote: > At this point, EFI boot manager interfaces is fully independent from > bootefi command. So just rename the configuration parameter. > > Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org > Reviewed-by: Simon Glass sjg@chromium.org
=> bootefi hello
Ah, yeah, but
-Takahiro Akashi
Please, rebase your patch set upon origin/master and retry the tests.
Best regards
Heinrich
On Sun, Jan 14, 2024 at 01:46:45PM +0100, Heinrich Schuchardt wrote: > On 1/10/24 02:16, AKASHI Takahiro wrote: > > At this point, EFI boot manager interfaces is fully independent from > > bootefi command. So just rename the configuration parameter. > > > > Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org > > Reviewed-by: Simon Glass sjg@chromium.org > > This patch breaks the 'bootefi hello' command in > qemu-riscv64_smode_defconfig and other QEMU defconfigs.
=> bootefi hello
Ah, yeah, but
-Takahiro Akashi
After rebasing my commits to the latest master (please note that my v4 has already been rebased on the master at my submission time), I tried the test again but anyhow the test passed as before on my side. I'm not able to reproduce your issue.
The only conflicting commit was f19171c919e0 ("efi_loader: Clean up efi_dp_append and efi_dp_concat"). I don't think that it would make any difference.
-Takahiro Akashi
Best regards
Heinrich
Now it is clear that the feature actually depends on efi interfaces, not "bootefi" command. efi_set_bootdev() will automatically be nullified if necessary efi component is disabled.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Reviewed-by: Ramon Fried rfried.dev@gmail.com Reviewed-by: Tom Rini trini@konsulko.com --- net/tftp.c | 10 ++++------ 1 file changed, 4 insertions(+), 6 deletions(-)
diff --git a/net/tftp.c b/net/tftp.c index 88e71e67de35..2e335413492b 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -302,12 +302,10 @@ static void tftp_complete(void) time_start * 1000, "/s"); } puts("\ndone\n"); - if (IS_ENABLED(CONFIG_CMD_BOOTEFI)) { - if (!tftp_put_active) - efi_set_bootdev("Net", "", tftp_filename, - map_sysmem(tftp_load_addr, 0), - net_boot_file_size); - } + if (!tftp_put_active) + efi_set_bootdev("Net", "", tftp_filename, + map_sysmem(tftp_load_addr, 0), + net_boot_file_size); net_set_state(NETLOOP_SUCCESS); }
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- fs/fs.c | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/fs/fs.c b/fs/fs.c index f1a0b70d1d57..acf465bdd807 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -791,10 +791,9 @@ int do_load(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[], return 1; }
- if (IS_ENABLED(CONFIG_CMD_BOOTEFI)) - efi_set_bootdev(argv[1], (argc > 2) ? argv[2] : "", - (argc > 4) ? argv[4] : "", map_sysmem(addr, 0), - len_read); + efi_set_bootdev(argv[1], (argc > 2) ? argv[2] : "", + (argc > 4) ? argv[4] : "", map_sysmem(addr, 0), + len_read);
printf("%llu bytes read in %lu ms", len_read, time); if (time > 0) {
AKASHI Takahiro
