[U-Boot] [RFC PATCH v2] arm: mx6: Clamp MMDC and DDR3 clocks for timing calculations
This is proposal for clamping the MMDC/DDR3 clocks to the maximum supported frequencies as per imx6 SOC models, and for dynamically calculating valid clock value based on mem_speed.
Currently the code uses impossible values for mem_speed (1333, 1600 MT/s) for calculating the DDR timings, and uses fixed clock (528 or 400 MHz) which doesn't take into account DDR3 memory limitations.
Signed-off-by: Nikolay Dimitrov picmaster@mail.bg Cc: Fabio Estevam festevam@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: Tim Harvey tharvey@gateworks.com Cc: Eric Nelson eric.nelson@boundarydevices.com --- Changes v1 -> v2: - fixed mistake of accessing a struct const member
arch/arm/cpu/armv7/mx6/ddr.c | 30 +++++++++++++++++++++++------- 1 file changed, 23 insertions(+), 7 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/ddr.c b/arch/arm/cpu/armv7/mx6/ddr.c index fef2231..a0a7082 100644 --- a/arch/arm/cpu/armv7/mx6/ddr.c +++ b/arch/arm/cpu/armv7/mx6/ddr.c @@ -265,24 +265,40 @@ void mx6_dram_cfg(const struct mx6_ddr_sysinfo *sysinfo, u16 tdllk = 0x1ff; /* DLL locking time: 512 cycles (JEDEC DDR3) */ u8 coladdr; int clkper; /* clock period in picoseconds */ - int clock; /* clock freq in mHz */ + int clock; /* clock freq in MHz */ int cs; + u16 mem_speed = ddr3_cfg->mem_speed;
mmdc0 = (struct mmdc_p_regs *)MMDC_P0_BASE_ADDR; #ifndef CONFIG_MX6SX mmdc1 = (struct mmdc_p_regs *)MMDC_P1_BASE_ADDR; #endif
- /* MX6D/MX6Q: 1066 MHz memory clock, clkper = 1.894ns = 1894ps */ + /* Limit mem_speed for MX6D/MX6Q */ if (is_cpu_type(MXC_CPU_MX6Q) || is_cpu_type(MXC_CPU_MX6D)) { - clock = 528; + if (mem_speed > 1066) + mem_speed = 1066; /* 1066 MT/s */ + tcwl = 4; } - /* MX6S/MX6DL: 800 MHz memory clock, clkper = 2.5ns = 2500ps */ + /* Limit mem_speed for MX6S/MX6DL */ else { - clock = 400; + if (mem_speed > 800) + mem_speed = 800; /* 800 MT/s */ + tcwl = 3; } + + clock = mem_speed / 2; + /* + * Data rate of 1066 MT/s requires 533 MHz DDR3 clock, but MX6D/Q supports + * up to 528 MHz, so reduce the clock to fit chip specs + */ + if (is_cpu_type(MXC_CPU_MX6Q) || is_cpu_type(MXC_CPU_MX6D)) { + if (clock > 528) + clock = 528; /* 528 MHz */ + } + clkper = (1000 * 1000) / clock; /* pico seconds */ todtlon = tcwl; taxpd = tcwl; @@ -313,7 +329,7 @@ void mx6_dram_cfg(const struct mx6_ddr_sysinfo *sysinfo, } txpr = txs;
- switch (ddr3_cfg->mem_speed) { + switch (mem_speed) { case 800: txp = DIV_ROUND_UP(max(3 * clkper, 7500), clkper) - 1; tcke = DIV_ROUND_UP(max(3 * clkper, 7500), clkper) - 1; @@ -382,7 +398,7 @@ void mx6_dram_cfg(const struct mx6_ddr_sysinfo *sysinfo, debug("density:%d Gb (%d Gb per chip)\n", sysinfo->cs_density, ddr3_cfg->density); debug("clock: %dMHz (%d ps)\n", clock, clkper); - debug("memspd:%d\n", ddr3_cfg->mem_speed); + debug("memspd:%d\n", mem_speed); debug("tcke=%d\n", tcke); debug("tcksrx=%d\n", tcksrx); debug("tcksre=%d\n", tcksre);
Best regards, Stefano Babic
Nikolay Dimitrov
Stefano Babic
