[PATCH] pylibfdt: Fix "invalid escape sequence '\w'" in setup.py
Once u-boot's build system invokes
python3 scripts/dtc/pylibfdt/setup.py --quiet build_ext --inplace
it may fail with
scripts/dtc/pylibfdt/setup.py:40: SyntaxWarning: invalid escape sequence '\w' RE_KEY_VALUE = re.compile('(?P<key>\w+) *(?P<plus>[+])?= *(?P<value>.*)$')
depending on the used Python version.
Explicitly mark the regex string as raw string to avoid the warning.
Signed-off-by: Florian Schmaus flo@geekplace.eu --- scripts/dtc/pylibfdt/setup.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/scripts/dtc/pylibfdt/setup.py b/scripts/dtc/pylibfdt/setup.py index 8baae08770ca..c6fe5a6a446f 100755 --- a/scripts/dtc/pylibfdt/setup.py +++ b/scripts/dtc/pylibfdt/setup.py @@ -37,7 +37,7 @@ long_description = fh.read()
# Decodes a Makefile assignment line into key and value (and plus for +=) -RE_KEY_VALUE = re.compile('(?P<key>\w+) *(?P<plus>[+])?= *(?P<value>.*)$') +RE_KEY_VALUE = re.compile(r'(?P<key>\w+) *(?P<plus>[+])?= *(?P<value>.*)$')
def get_top_builddir(): if '--top-builddir' in sys.argv:
it may fail with
Reviewed-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com
it may fail with
Signed-off-by: Florian Schmaus flo@geekplace.eu Reviewed-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com
