[PATCH] imx8mq: soc: Set the BYPASS ID SWAP bit (GPR10 bit 1)
Set the BYPASS ID SWAP bit (GPR10 bit 1). The ID SWAP function randomly make TZASC grant non-secure access to secure memory. TZASC ID SWAP should be bypassed by setting the bit TZASC_ID_SWAP_BYPASS(bit 1) in IOMUX_GPR10 register.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/soc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 7397b99a1eee..404322cb69f1 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -72,7 +72,7 @@ void enable_tzc380(void) * According to TRM, TZASC_ID_SWAP_BYPASS should be set in * order to avoid AXI Bus errors when GPU is in use */ - if (is_imx8mm() || is_imx8mn() || is_imx8mp()) + if (is_imx8mq() || is_imx8mm() || is_imx8mn() || is_imx8mp()) setbits_le32(&gpr->gpr[10], GPR_TZASC_ID_SWAP_BYPASS);
From: Peng Fan peng.fan@nxp.com Set the BYPASS ID SWAP bit (GPR10 bit 1). The ID SWAP function randomly make TZASC grant non-secure access to secure memory. TZASC ID SWAP should be bypassed by setting the bit TZASC_ID_SWAP_BYPASS(bit 1) in IOMUX_GPR10 register. Signed-off-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Peng Fan (OSS)
sbabic@denx.de
