[U-Boot] [PATCH] zynq: Move ENV location selection from zynq-common.h to config files.
The ifdef's in zynq-common.h do a partial selection of the u-boot environment storage location. As u-boot added more, the ifdefs no longe cope with all possible cases. Rather than correct the logic there, move the selection options into the board specific config files.
Signed-off-by: Philip Balister philip@opensdr.com --- configs/zynq_microzed_defconfig | 1 + configs/zynq_picozed_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 2 +- configs/zynq_zc770_xm011_defconfig | 2 +- configs/zynq_zc770_xm012_defconfig | 2 +- configs/zynq_zc770_xm013_defconfig | 2 +- configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 2 ++ include/configs/zynq-common.h | 10 ---------- 11 files changed, 11 insertions(+), 14 deletions(-)
diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index 4093618..b95c7d3 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-microzed" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/zynq_picozed_defconfig b/configs/zynq_picozed_defconfig index 3c3a5b2..53e9a3e 100644 --- a/configs/zynq_picozed_defconfig +++ b/configs/zynq_picozed_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x4000000 CONFIG_DEFAULT_DEVICE_TREE="zynq-picozed" +CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_NOWHERE" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index c59d7f5..62a96fd 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zc702" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index c73bacb..348f9fd 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zc706" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index ececcb4..3a8caba 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -5,7 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm010" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM010" +CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM010,ENV_IS_IN_SPI_FLASH" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index 980382c..7a6d2af 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -5,7 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm011" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM011" +CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM011,ENV_IS_NOWHERE" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index 48caf31..8d23bd9 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -5,7 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm012" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM012" +CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM012,ENV_IS_IN_FLASH" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index 23bcb0e..3a0b9e6 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -5,7 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm013" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM013" +CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM013,ENV_IS_IN_SPI_FLASH" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index 26a5320..3f54495 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zed" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index af7fe65..ed85319 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zybo" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y @@ -56,3 +57,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Xilinx" CONFIG_G_DNL_VENDOR_NUM=0x03fd CONFIG_G_DNL_PRODUCT_NUM=0x0300 +CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 431d6c4..94e49fb 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -162,16 +162,6 @@
/* Environment */ #ifndef CONFIG_ENV_IS_NOWHERE -# ifdef CONFIG_MTD_NOR_FLASH -/* Environment in NOR flash */ -# define CONFIG_ENV_IS_IN_FLASH -# elif defined(CONFIG_ZYNQ_QSPI) -/* Environment in Serial Flash */ -# define CONFIG_ENV_IS_IN_SPI_FLASH -# elif !defined(CONFIG_MTD_NOR_FLASH) -# define CONFIG_ENV_IS_NOWHERE -# endif - # define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE # define CONFIG_ENV_OFFSET 0xE0000 #endif
These are here twice.
There is any problem with xm013 which shouldn't have any delta when this patch is applied.
02: zynq: Move ENV location selection from zynq-common.h to config files. arm: (for 12/12 boards) all +231.0 bss +0.3 data +7.3 rodata +21.0 text +202.3 zynq_zc770_xm013: all +2772 bss +4 data +88 rodata +252 text +2428 u-boot: add: 21/0, grow: 5/0 bytes: 2232/0 (2232) function old new delta spi_get_bus_and_cs - 356 +356 device_unbind - 328 +328 saveenv - 232 +232 env_import - 224 +224 env_relocate_spec 4 208 +204 env_export - 164 +164 spi_flash_probe_bus_cs - 140 +140 spi_find_chip_select - 84 +84 device_bind_driver_to_node - 72 +72 spi_flash_probe - 48 +48 do_env_save - 44 +44 device_find_next_child - 40 +40 device_bind - 40 +40 env_relocate 20 48 +28 env_help_text 563 591 +28 device_find_first_child - 28 +28 cmd_env_sub 252 280 +28 _u_boot_list_2_cmd_2_saveenv - 28 +28 spi_flash_write_dm - 24 +24 spi_flash_read_dm - 24 +24 spi_flash_erase_dm - 24 +24 device_bind_driver - 20 +20 spi_flash_free - 12 +12 env_name_spec - 4 +4 env_init 24 28 +4 env_flash - 4 +4
M
No, we don't want to add more to SYS_EXTRA_OPTIONS, we want to start moving these options to Kconfig itself, directly. I'm happy to run the big migration of the configs so long as the Kconfig part has been tested in at least a few cases to be right. Thanks!
ah right - it is even deprecated in Kconfig.
Thanks for reminder. Michal
Michal Simek
Philip Balister
