[PATCH v2 1/4] mmc: pic32: Refresh PIC32 MMC driver
The existing driver is not compatible with the Driver Model.
This patch makes the necessary changes while also removing obsolescent calls/properties as follows:
- fdtdec_* calls replaced with dev_read_* equivalents; - 'clock-freq-min-max' property replaced by querying the frequency of the source clock 'base_clk'; - The card detect erratum workaround is applied during probe rather than overriding get_cd.
The card detect workaround (Microchip ref. DS80000736E, erratum #15) is not needed if the SDCD signal is properly connected on the board and so can be disabled using a vendor specific DT property.
Signed-off-by: John Robertson john.robertson@simiatec.com --- Changes in v2: - Split patch; - Fix compilation failure after 'make pic32mzdask_defconfig'.
drivers/mmc/pic32_sdhci.c | 77 ++++++++++++++++++++++++--------------- 1 file changed, 48 insertions(+), 29 deletions(-)
diff --git a/drivers/mmc/pic32_sdhci.c b/drivers/mmc/pic32_sdhci.c index 029e0fbc2b..93f0532ad6 100644 --- a/drivers/mmc/pic32_sdhci.c +++ b/drivers/mmc/pic32_sdhci.c @@ -9,62 +9,78 @@ #include <common.h> #include <dm.h> #include <sdhci.h> -#include <linux/errno.h> -#include <mach/pic32.h> +#include <clk.h>
DECLARE_GLOBAL_DATA_PTR;
-static int pic32_sdhci_get_cd(struct sdhci_host *host) -{ - /* PIC32 SDHCI CD errata: - * - set CD_TEST and clear CD_TEST_INS bit - */ - sdhci_writeb(host, SDHCI_CTRL_CD_TEST, SDHCI_HOST_CONTROL); - - return 0; -} - -static const struct sdhci_ops pic32_sdhci_ops = { - .get_cd = pic32_sdhci_get_cd, +struct pic32_sdhci_plat { + struct mmc_config cfg; + struct mmc mmc; };
static int pic32_sdhci_probe(struct udevice *dev) { + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct pic32_sdhci_plat *plat = dev_get_platdata(dev); struct sdhci_host *host = dev_get_priv(dev); - const void *fdt = gd->fdt_blob; - u32 f_min_max[2]; + fdt_addr_t addr; fdt_size_t size; + struct clk clk; + ulong clk_rate; int ret;
- addr = fdtdec_get_addr_size(fdt, dev_of_offset(dev), "reg", &size); + addr = dev_read_addr_size(dev, "reg", &size); if (addr == FDT_ADDR_T_NONE) return -EINVAL;
+ ret = clk_get_by_name(dev, "base_clk", &clk); + if (ret) + return ret; + + clk_rate = clk_get_rate(&clk); + clk_free(&clk); + + if (IS_ERR_VALUE(clk_rate)) + return clk_rate; + host->ioaddr = ioremap(addr, size); host->name = dev->name; host->quirks = SDHCI_QUIRK_NO_HISPD_BIT; - host->bus_width = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), - "bus-width", 4); - host->ops = &pic32_sdhci_ops; - - ret = fdtdec_get_int_array(gd->fdt_blob, dev_of_offset(dev), - "clock-freq-min-max", f_min_max, 2); - if (ret) { - printf("sdhci: clock-freq-min-max not found\n"); + host->bus_width = dev_read_u32_default(dev, "bus-width", 4); + host->max_clk = clk_rate; + + host->mmc = &plat->mmc; + host->mmc->dev = dev; + + ret = sdhci_setup_cfg(&plat->cfg, host, 0, 0); + if (ret) return ret; - }
- host->max_clk = f_min_max[1]; + host->mmc->priv = host; + upriv->mmc = host->mmc;
- ret = add_sdhci(host, 0, f_min_max[0]); + ret = sdhci_probe(dev); if (ret) return ret; - host->mmc->dev = dev; + + if (!dev_read_bool(dev, "microchip,use-sdcd")) { + // Use workaround 1 for erratum #15 by default + u8 ctrl = sdhci_readb(host, SDHCI_HOST_CONTROL); + ctrl = (ctrl & ~SDHCI_CTRL_CD_TEST_INS) | SDHCI_CTRL_CD_TEST; + sdhci_writeb(host, ctrl, SDHCI_HOST_CONTROL); + }
return 0; }
+static int pic32_sdhci_bind(struct udevice *dev) +{ + struct pic32_sdhci_plat *plat = dev_get_platdata(dev); + + return sdhci_bind(dev, &plat->mmc, &plat->cfg); +} + static const struct udevice_id pic32_sdhci_ids[] = { { .compatible = "microchip,pic32mzda-sdhci" }, { } @@ -74,6 +90,9 @@ U_BOOT_DRIVER(pic32_sdhci_drv) = { .name = "pic32_sdhci", .id = UCLASS_MMC, .of_match = pic32_sdhci_ids, + .ops = &sdhci_ops, + .bind = pic32_sdhci_bind, .probe = pic32_sdhci_probe, .priv_auto_alloc_size = sizeof(struct sdhci_host), + .platdata_auto_alloc_size = sizeof(struct pic32_sdhci_plat) };
Am Montag, den 31.08.2020, 18:04 +0000 schrieb John Robertson:
Changes in v2:
- Split patch;
also remove this and common.h as this is not needed with the dev_* API
- struct mmc_config cfg;
- struct mmc mmc;
- struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev);
- struct pic32_sdhci_plat *plat = dev_get_platdata(dev); struct sdhci_host *host = dev_get_priv(dev);
- u32 f_min_max[2];
- fdt_addr_t addr; fdt_size_t size;
- struct clk clk;
- ulong clk_rate; int ret;
if (ret)
return ret;
clk_free(&clk);
return clk_rate;
use dev_remap_addr() instead of dev_read_addr_size() + ioremap()
"bus-width", 4);
- if (ret) {
- host->bus_width = dev_read_u32_default(dev, "bus-width", 4);
- host->max_clk = clk_rate;
- host->mmc = &plat->mmc;
- ret = sdhci_setup_cfg(&plat->cfg, host, 0, 0);
- if (ret) return ret;
- host->mmc->priv = host;
- upriv->mmc = host->mmc;
- ret = sdhci_probe(dev); if (ret) return ret;
- return sdhci_bind(dev, &plat->mmc, &plat->cfg);
- .ops = &sdhci_ops,
- .bind = pic32_sdhci_bind, .probe = pic32_sdhci_probe, .priv_auto_alloc_size = sizeof(struct sdhci_host),
- .platdata_auto_alloc_size = sizeof(struct pic32_sdhci_plat)
Changes in v2:
- Split patch;
Fixed in v3.
- struct mmc mmc;
- u32 f_min_max[2];
- struct clk clk;
if (ret)
return ret;
clk_free(&clk);
return clk_rate;
Agreed. Done in v3.
dev_of_offset(dev),
"bus-width", 4);
- if (ret) {
4);
- if (!dev_read_bool(dev, "microchip,use-sdcd")) {
SDHCI_CTRL_CD_TEST;
+static int pic32_sdhci_bind(struct udevice *dev) {
- return sdhci_bind(dev, &plat->mmc, &plat->cfg); }
- Daniel
Daniel Schwierzeck
John Robertson
