[U-Boot] [PATCH V2 0/3] Fix hang when loading U-Boot from SPI or NAND
This series of patches fixes a hang seen when loading U-Boot from SPI or NAND on Seaboard and Harmony due to a missing PLLX init. It also corrects a UARTD bit error in clk_rst.h, and adds rudimentary GPIO support so that the UART on Seaboard can be used by U-Boot (UARTD & SPIFLASH are muxed, and the default POR setting is for SPI access, so GPIO_PI3 has to be driven low to enable serial console I/O over UARTD). Harmony has no SPIFLASH, so the issue doesn't exist there.
With these changes, I can write U-Boot to SPI on Seaboard and boot with it to the U-Boot cmd prompt. This should also apply to loading from NAND on Seaboard and Harmony - testing to follow.
Changes in V2: - Change 2nd patch's description to 'Add basic GPIO definitions' - Add more descriptive comment for CPCON use in init_pllx
Tom Warren (3): arm: Tegra2: Add missing PLLX init arm: Tegra2: GPIO: Add basic GPIO definitions arm: Tegra2: Move clk/mux init to board_early_init_f, add GPIO init
arch/arm/cpu/armv7/tegra2/ap20.c | 29 ++++++++++++++ arch/arm/include/asm/arch-tegra2/clk_rst.h | 6 ++- arch/arm/include/asm/arch-tegra2/gpio.h | 59 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-tegra2/tegra2.h | 1 + board/nvidia/common/board.c | 32 ++++++++++----- board/nvidia/common/board.h | 4 ++ board/nvidia/harmony/Makefile | 1 + board/nvidia/harmony/harmony.c | 34 ++++++++++++++++ board/nvidia/seaboard/Makefile | 1 + board/nvidia/seaboard/seaboard.c | 52 ++++++++++++++++++++++++ 10 files changed, 206 insertions(+), 13 deletions(-) create mode 100644 arch/arm/include/asm/arch-tegra2/gpio.h create mode 100644 board/nvidia/harmony/harmony.c create mode 100644 board/nvidia/seaboard/seaboard.c
Signed-off-by: Tom Warren twarren@nvidia.com --- arch/arm/cpu/armv7/tegra2/ap20.c | 29 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-tegra2/clk_rst.h | 6 +++- 2 files changed, 33 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/tegra2/ap20.c b/arch/arm/cpu/armv7/tegra2/ap20.c index d3e6797..60dd5df 100644 --- a/arch/arm/cpu/armv7/tegra2/ap20.c +++ b/arch/arm/cpu/armv7/tegra2/ap20.c @@ -32,6 +32,32 @@
u32 s_first_boot = 1;
+void init_pllx(void) +{ + struct clk_rst_ctlr *clkrst = (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + u32 reg; + + /* If PLLX is already enabled, just return */ + reg = readl(&clkrst->crc_pllx_base); + if (reg & PLL_ENABLE) + return; + + /* Set PLLX_MISC */ + reg = CPCON; /* CPCON[11:8] = 0001 */ + writel(reg, &clkrst->crc_pllx_misc); + + /* Use 12MHz clock here */ + reg = (PLL_BYPASS | PLL_DIVM); + reg |= (1000 << 8); /* DIVN = 0x3E8 */ + writel(reg, &clkrst->crc_pllx_base); + + reg |= PLL_ENABLE; + writel(reg, &clkrst->crc_pllx_base); + + reg &= ~PLL_BYPASS; + writel(reg, &clkrst->crc_pllx_base); +} + static void enable_cpu_clock(int enable) { struct clk_rst_ctlr *clkrst = (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; @@ -47,6 +73,9 @@ static void enable_cpu_clock(int enable) */
if (enable) { + /* Initialize PLLX */ + init_pllx(); + /* Wait until all clocks are stable */ udelay(PLL_STABILIZATION_DELAY);
diff --git a/arch/arm/include/asm/arch-tegra2/clk_rst.h b/arch/arm/include/asm/arch-tegra2/clk_rst.h index d67a5d7..bd8ad2c 100644 --- a/arch/arm/include/asm/arch-tegra2/clk_rst.h +++ b/arch/arm/include/asm/arch-tegra2/clk_rst.h @@ -160,8 +160,8 @@ struct clk_rst_ctlr { #define PLL_DIVP (1 << 20) /* post divider, b22:20 */ #define PLL_DIVM 0x0C /* input divider, b4:0 */
-#define SWR_UARTD_RST (1 << 2) -#define CLK_ENB_UARTD (1 << 2) +#define SWR_UARTD_RST (1 << 1) +#define CLK_ENB_UARTD (1 << 1) #define SWR_UARTA_RST (1 << 6) #define CLK_ENB_UARTA (1 << 6)
@@ -189,4 +189,6 @@ struct clk_rst_ctlr { #define CPU0_CLK_STP (1 << 8) #define CPU1_CLK_STP (1 << 9)
+#define CPCON (1 << 8) + #endif /* CLK_RST_H */
Signed-off-by: Tom Warren twarren@nvidia.com --- arch/arm/include/asm/arch-tegra2/gpio.h | 59 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-tegra2/tegra2.h | 1 + 2 files changed, 60 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-tegra2/gpio.h
diff --git a/arch/arm/include/asm/arch-tegra2/gpio.h b/arch/arm/include/asm/arch-tegra2/gpio.h new file mode 100644 index 0000000..0fb8f0d --- /dev/null +++ b/arch/arm/include/asm/arch-tegra2/gpio.h @@ -0,0 +1,59 @@ +/* + * Copyright (c) 2011, Google Inc. All rights reserved. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _TEGRA2_GPIO_H_ +#define _TEGRA2_GPIO_H_ + +/* + * The Tegra 2x GPIO controller has 222 GPIOs arranged in 8 banks of 4 ports, + * each with 8 GPIOs. + */ +#define TEGRA_GPIO_PORTS 4 /* The number of ports per bank */ +#define TEGRA_GPIO_BANKS 8 /* The number of banks */ + +/* GPIO Controller registers for a single bank */ +struct gpio_ctlr_bank { + uint gpio_config[TEGRA_GPIO_PORTS]; + uint gpio_dir_out[TEGRA_GPIO_PORTS]; + uint gpio_out[TEGRA_GPIO_PORTS]; + uint gpio_in[TEGRA_GPIO_PORTS]; + uint gpio_int_status[TEGRA_GPIO_PORTS]; + uint gpio_int_enable[TEGRA_GPIO_PORTS]; + uint gpio_int_level[TEGRA_GPIO_PORTS]; + uint gpio_int_clear[TEGRA_GPIO_PORTS]; +}; + +struct gpio_ctlr { + struct gpio_ctlr_bank gpio_bank[TEGRA_GPIO_BANKS]; +}; + +#define GPIO_BANK(x) ((x) >> 5) +#define GPIO_PORT(x) (((x) >> 3) & 0x3) +#define GPIO_BIT(x) ((x) & 0x7) + +/* + * GPIO_PI3 = Port I = 8, bit = 3. + * Seaboard: used for UART/SPI selection + * Harmony: not used + */ +#define GPIO_PI3 ((8 << 3) | 3) + +#endif /* TEGRA2_GPIO_H_ */ diff --git a/arch/arm/include/asm/arch-tegra2/tegra2.h b/arch/arm/include/asm/arch-tegra2/tegra2.h index 7b0f5cc..742a75a 100644 --- a/arch/arm/include/asm/arch-tegra2/tegra2.h +++ b/arch/arm/include/asm/arch-tegra2/tegra2.h @@ -30,6 +30,7 @@ #define NV_PA_TMRUS_BASE 0x60005010 #define NV_PA_CLK_RST_BASE 0x60006000 #define NV_PA_FLOW_BASE 0x60007000 +#define NV_PA_GPIO_BASE 0x6000D000 #define NV_PA_EVP_BASE 0x6000F000 #define NV_PA_APB_MISC_BASE 0x70000000 #define NV_PA_APB_UARTA_BASE (NV_PA_APB_MISC_BASE + 0x6000)
Signed-off-by: Tom Warren twarren@nvidia.com --- board/nvidia/common/board.c | 32 +++++++++++++++-------- board/nvidia/common/board.h | 4 +++ board/nvidia/harmony/Makefile | 1 + board/nvidia/harmony/harmony.c | 34 ++++++++++++++++++++++++ board/nvidia/seaboard/Makefile | 1 + board/nvidia/seaboard/seaboard.c | 52 ++++++++++++++++++++++++++++++++++++++ 6 files changed, 113 insertions(+), 11 deletions(-) create mode 100644 board/nvidia/harmony/harmony.c create mode 100644 board/nvidia/seaboard/seaboard.c
diff --git a/board/nvidia/common/board.c b/board/nvidia/common/board.c index 5edd70f..3d6c248 100644 --- a/board/nvidia/common/board.c +++ b/board/nvidia/common/board.c @@ -41,7 +41,16 @@ const struct tegra2_sysinfo sysinfo = { #ifdef CONFIG_BOARD_EARLY_INIT_F int board_early_init_f(void) { - debug("Board Early Init\n"); + /* Initialize periph clocks */ + clock_init(); + + /* Initialize periph pinmuxes */ + pinmux_init(); + + /* Initialize periph GPIOs */ + gpio_init(); + + /* Init UART, scratch regs, and start CPU */ tegra2_start(); return 0; } @@ -64,10 +73,10 @@ int timer_init(void) static void clock_init_uart(void) { struct clk_rst_ctlr *clkrst = (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; - static int pllp_init_done; u32 reg;
- if (!pllp_init_done) { + reg = readl(&clkrst->crc_pllp_base); + if (!(reg & PLL_BASE_OVRRIDE)) { /* Override pllp setup for 216MHz operation. */ reg = (PLL_BYPASS | PLL_BASE_OVRRIDE | PLL_DIVP); reg |= (((NVRM_PLLP_FIXED_FREQ_KHZ/500) << 8) | PLL_DIVM); @@ -78,8 +87,6 @@ static void clock_init_uart(void)
reg &= ~PLL_BYPASS; writel(reg, &clkrst->crc_pllp_base); - - pllp_init_done++; }
/* Now do the UART reset/clock enable */ @@ -182,6 +189,15 @@ void pinmux_init(void) }
/* + * Routine: gpio_init + * Description: Do individual peripheral GPIO configs + */ +void gpio_init(void) +{ + gpio_config_uart(); +} + +/* * Routine: board_init * Description: Early hardware init. */ @@ -192,11 +208,5 @@ int board_init(void) /* board id for Linux */ gd->bd->bi_arch_number = CONFIG_MACH_TYPE;
- /* Initialize peripheral clocks */ - clock_init(); - - /* Initialize periph pinmuxes */ - pinmux_init(); - return 0; } diff --git a/board/nvidia/common/board.h b/board/nvidia/common/board.h index 47c7885..350bc57 100644 --- a/board/nvidia/common/board.h +++ b/board/nvidia/common/board.h @@ -25,5 +25,9 @@ #define _BOARD_H_
void tegra2_start(void); +void clock_init(void); +void pinmux_init(void); +void gpio_init(void); +void gpio_config_uart(void);
#endif /* BOARD_H */ diff --git a/board/nvidia/harmony/Makefile b/board/nvidia/harmony/Makefile index 3a146cb..9fb6b57 100644 --- a/board/nvidia/harmony/Makefile +++ b/board/nvidia/harmony/Makefile @@ -26,6 +26,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
+COBJS := $(BOARD).o COBJS += ../common/board.o
SRCS := $(COBJS:.o=.c) diff --git a/board/nvidia/harmony/harmony.c b/board/nvidia/harmony/harmony.c new file mode 100644 index 0000000..f1ab050 --- /dev/null +++ b/board/nvidia/harmony/harmony.c @@ -0,0 +1,34 @@ +/* + * (C) Copyright 2010,2011 + * NVIDIA Corporation <www.nvidia.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/tegra2.h> + +/* + * Routine: gpio_config_uart + * Description: Does nothing on Harmony - no conflict w/SPI. + */ +void gpio_config_uart(void) +{ +} diff --git a/board/nvidia/seaboard/Makefile b/board/nvidia/seaboard/Makefile index 3a146cb..9fb6b57 100644 --- a/board/nvidia/seaboard/Makefile +++ b/board/nvidia/seaboard/Makefile @@ -26,6 +26,7 @@ include $(TOPDIR)/config.mk
SRCS := $(COBJS:.o=.c) diff --git a/board/nvidia/seaboard/seaboard.c b/board/nvidia/seaboard/seaboard.c new file mode 100644 index 0000000..4b9a8f3 --- /dev/null +++ b/board/nvidia/seaboard/seaboard.c @@ -0,0 +1,52 @@ +/* + * (C) Copyright 2010,2011 + * NVIDIA Corporation <www.nvidia.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/tegra2.h> +#include <asm/arch/gpio.h> + +/* + * Routine: gpio_config_uart + * Description: Force GPIO_PI3 low on Seaboard so UART4 works. + */ +void gpio_config_uart(void) +{ + int gp = GPIO_PI3; + struct gpio_ctlr *gpio = (struct gpio_ctlr *)NV_PA_GPIO_BASE; + struct gpio_ctlr_bank *bank = &gpio->gpio_bank[GPIO_BANK(gp)]; + u32 val; + + /* Enable UART via GPIO_PI3 (port 8, bit 3) so serial console works */ + val = readl(&bank->gpio_config[GPIO_PORT(gp)]); + val |= 1 << GPIO_BIT(gp); + writel(val, &bank->gpio_config[GPIO_PORT(gp)]); + + val = readl(&bank->gpio_out[GPIO_PORT(gp)]); + val &= ~(1 << GPIO_BIT(gp)); + writel(val, &bank->gpio_out[GPIO_PORT(gp)]); + + val = readl(&bank->gpio_dir_out[GPIO_PORT(gp)]); + val |= 1 << GPIO_BIT(gp); + writel(val, &bank->gpio_dir_out[GPIO_PORT(gp)]); +}
Hi Tom,
Le 15/04/2011 00:09, Tom Warren a écrit :
This series of patches fixes a hang seen when loading U-Boot from SPI or NAND on Seaboard and Harmony due to a missing PLLX init. It also corrects a UARTD bit error in clk_rst.h, and adds rudimentary GPIO support so that the UART on Seaboard can be used by U-Boot (UARTD& SPIFLASH are muxed, and the default POR setting is for SPI access, so GPIO_PI3 has to be driven low to enable serial console I/O over UARTD). Harmony has no SPIFLASH, so the issue doesn't exist there.
Changes in V2:
Next time you post an updated patchset, please put patch history/changelog in the patches themselves.
I'll pull these in tomorrow morning unless someone requests changes in the meantime.
Amicalement,
Hi Tom,
Changes in V2:
Applied to u-boot-arm, thanks.
Amicalement,
Hi Tom,
Changes in V2:
Applied in u-boot-arm/master, thanks.
Amicalement,
Albert ARIBAUD
Tom Warren
