[U-Boot] [PATCH 1/3] arm: rmobile: alt: Enable channel 1 of sh-i2c
Alt board was connected Power IC to channel 1 of sh-i2c. Source code that controls this is already included, but channel 1 of sh-i2c is not enabled. This enables channel 1 of sh-i2c, and can use.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- board/renesas/alt/alt.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/board/renesas/alt/alt.c b/board/renesas/alt/alt.c index cf6d64c..083e007 100644 --- a/board/renesas/alt/alt.c +++ b/board/renesas/alt/alt.c @@ -49,6 +49,10 @@ void s_init(void) #define SMSTPCR8 0xE6150990 #define ETHER_MSTP813 (1 << 13)
+#define MSTPSR3 0xE6150048 +#define SMSTPCR3 0xE615013C +#define IIC1_MSTP323 (1 << 23) + #define mstp_setbits(type, addr, saddr, set) \ out_##type((saddr), in_##type(addr) | (set)) #define mstp_clrbits(type, addr, saddr, clear) \ @@ -69,6 +73,9 @@ int board_early_init_f(void) /* ETHER */ mstp_clrbits_le32(MSTPSR8, SMSTPCR8, ETHER_MSTP813);
+ /* IIC1 / sh-i2c ch1 */ + mstp_clrbits_le32(MSTPSR3, SMSTPCR3, IIC1_MSTP323); + return 0; }
PowerIC connected to channel 1 of sh-i2c, not channel 2.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- board/renesas/alt/alt.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/renesas/alt/alt.c b/board/renesas/alt/alt.c index 083e007..68ae937 100644 --- a/board/renesas/alt/alt.c +++ b/board/renesas/alt/alt.c @@ -166,7 +166,7 @@ void reset_cpu(ulong addr) { u8 val;
- i2c_set_bus_num(1); /* PowerIC connected to ch3 */ + i2c_set_bus_num(1); /* PowerIC connected to ch1 */ i2c_init(400000, 0); i2c_read(CONFIG_SYS_I2C_POWERIC_ADDR, 0x13, 1, &val, 1); val |= 0x02;
The i2c_init function is no longer necessary.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- board/renesas/alt/alt.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/board/renesas/alt/alt.c b/board/renesas/alt/alt.c index 68ae937..039cb37 100644 --- a/board/renesas/alt/alt.c +++ b/board/renesas/alt/alt.c @@ -167,7 +167,6 @@ void reset_cpu(ulong addr) u8 val;
i2c_set_bus_num(1); /* PowerIC connected to ch1 */ - i2c_init(400000, 0); i2c_read(CONFIG_SYS_I2C_POWERIC_ADDR, 0x13, 1, &val, 1); val |= 0x02; i2c_write(CONFIG_SYS_I2C_POWERIC_ADDR, 0x13, 1, &val, 1);
Nobuhiro Iwamatsu
