[PATCH v8 0/2] arm64: Add a build target for Flat Image Tree
Flat Image Tree (FIT) is a widely used file format for packaging a kernel and associated devicetree files[1]. It is not specific to any one bootloader, as it is supported by U-Boot, coreboot, Linuxboot, Tianocore and Barebox.
This series adds support for building a FIT as part of the kernel build. This makes it easy to try out the kernel - just load the FIT onto your tftp server and it will run automatically on any supported arm64 board.
The script is written in Python, since it is easy to build a FIT using the Python libfdt bindings. For now, no attempt is made to compress files in parallel, so building the 900-odd files takes a while, about 6 seconds with my testing.
The series also includes a few minor clean-up patches.
[1] https://github.com/open-source-firmware/flat-image-tree
Changes in v8: - Drop compatible string in FDT node - Correct sorting of MAINTAINERS to before ARM64 PORT - Turn compress part of the make_fit.py comment in to a sentence - Add two blank lines before parse_args() and setup_fit() - Use 'image.fit: dtbs' instead of BUILD_DTBS var - Use '$(<D)/dts' instead of '$(dir $<)dts' - Add 'mkimage' details Documentation/process/changes.rst - Allow changing the compression used - Tweak cover letter since there is only one clean-up patch
Changes in v7: - Drop the kbuild tag - Add Image as a dependency of image.fit - Drop kbuild tag - Add dependency on dtbs - Drop unnecessary path separator for dtbs - Rebase to -next
Changes in v6: - Drop the unwanted .gz suffix
Changes in v5: - Drop patch previously applied - Correct compression rule which was broken in v4
Changes in v4: - Use single quotes for UIMAGE_NAME
Changes in v3: - Drop temporary file image.itk - Drop patch 'Use double quotes for image name' - Drop double quotes in use of UIMAGE_NAME - Drop unnecessary CONFIG_EFI_ZBOOT condition for help - Avoid hard-coding "arm64" for the DT architecture
Changes in v2: - Drop patch previously applied - Add .gitignore file - Move fit rule to Makefile.lib using an intermediate file - Drop dependency on CONFIG_EFI_ZBOOT - Pick up .dtb files separately from the kernel - Correct pylint too-many-args warning for write_kernel() - Include the kernel image in the file count - Add a pointer to the FIT spec and mention of its wide industry usage - Mention the kernel version in the FIT description
Simon Glass (2): arm64: Add BOOT_TARGETS variable arm64: boot: Support Flat Image Tree
Documentation/process/changes.rst | 9 + MAINTAINERS | 7 + arch/arm64/Makefile | 11 +- arch/arm64/boot/.gitignore | 1 + arch/arm64/boot/Makefile | 9 +- scripts/Makefile.lib | 13 ++ scripts/make_fit.py | 291 ++++++++++++++++++++++++++++++ 7 files changed, 338 insertions(+), 3 deletions(-) create mode 100755 scripts/make_fit.py
Add a new variable containing a list of possible targets. Mark them as phony. This matches the approach taken for arch/arm
(no changes since v7)
arch/arm64/Makefile | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/arm64/Makefile b/arch/arm64/Makefile index 9a2d3723cd0f..1bd4fae6e806 100644 --- a/arch/arm64/Makefile +++ b/arch/arm64/Makefile @@ -150,6 +150,10 @@ libs-$(CONFIG_EFI_STUB) += $(objtree)/drivers/firmware/efi/libstub/lib.a # Default target when executing plain make boot := arch/arm64/boot
+BOOT_TARGETS := Image vmlinuz.efi + +PHONY += $(BOOT_TARGETS) + ifeq ($(CONFIG_EFI_ZBOOT),) KBUILD_IMAGE := $(boot)/Image.gz else @@ -159,7 +163,7 @@ endif all: $(notdir $(KBUILD_IMAGE))
vmlinuz.efi: Image -Image vmlinuz.efi: vmlinux +$(BOOT_TARGETS): vmlinux $(Q)$(MAKE) $(build)=$(boot) $(boot)/$@
Image.%: Image
Add a script which produces a Flat Image Tree (FIT), a single file containing the built kernel and associated devicetree files. Compression defaults to gzip which gives a good balance of size and performance.
The files compress from about 86MB to 24MB using this approach.
The FIT can be used by bootloaders which support it, such as U-Boot and Linuxboot. It permits automatic selection of the correct devicetree, matching the compatible string of the running board with the closest compatible string in the FIT. There is no need for filenames or other workarounds.
Add a 'make image.fit' build target for arm64, as well.
The FIT can be examined using 'dumpimage -l'.
This features requires pylibfdt (use 'pip install libfdt'). It also requires compression utilities for the algorithm being used. Supported compression options are the same as the Image.xxx files. For now there is no way to change the compression other than by editing the rule for $(obj)/image.fit
While FIT supports a ramdisk / initrd, no attempt is made to support this here, since it must be built separately from the Linux build.
Changes in v7: - Add Image as a dependency of image.fit - Drop kbuild tag - Add dependency on dtbs - Drop unnecessary path separator for dtbs - Rebase to -next
Documentation/process/changes.rst | 9 + MAINTAINERS | 7 + arch/arm64/Makefile | 7 +- arch/arm64/boot/.gitignore | 1 + arch/arm64/boot/Makefile | 9 +- scripts/Makefile.lib | 13 ++ scripts/make_fit.py | 291 ++++++++++++++++++++++++++++++ 7 files changed, 334 insertions(+), 3 deletions(-) create mode 100755 scripts/make_fit.py
diff --git a/Documentation/process/changes.rst b/Documentation/process/changes.rst index bb96ca0f774b..cad51bd5bd62 100644 --- a/Documentation/process/changes.rst +++ b/Documentation/process/changes.rst @@ -62,6 +62,7 @@ Sphinx\ [#f1]_ 1.7 sphinx-build --version cpio any cpio --version GNU tar 1.28 tar --version gtags (optional) 6.6.5 gtags --version +mkimage (optional) 2017.01 mkimage --version ====================== =============== ========================================
.. [#f1] Sphinx is needed only to build the Kernel documentation @@ -189,6 +190,14 @@ The kernel build requires GNU GLOBAL version 6.6.5 or later to generate tag files through ``make gtags``. This is due to its use of the gtags ``-C (--directory)`` flag.
+mkimage +------- + +This tool is used when building a Flat Image Tree (FIT), commonly used on ARM +platforms. The tool is available via the ``u-boot-tools`` package or can be +built from the U-Boot source code. See the instructions at +https://docs.u-boot.org/en/latest/build/tools.html#building-tools-for-linux + System utilities ****************
diff --git a/MAINTAINERS b/MAINTAINERS index 14587be87a33..9f3eb476ece4 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -3037,6 +3037,13 @@ F: drivers/mmc/host/sdhci-of-arasan.c N: zynq N: xilinx
+ARM64 FIT SUPPORT +M: Simon Glass sjg@chromium.org +L: linux-arm-kernel@lists.infradead.org (moderated for non-subscribers) +S: Maintained +F: arch/arm64/boot/Makefile +F: scripts/make_fit.py + ARM64 PORT (AARCH64 ARCHITECTURE) M: Catalin Marinas catalin.marinas@arm.com M: Will Deacon will@kernel.org diff --git a/arch/arm64/Makefile b/arch/arm64/Makefile index 1bd4fae6e806..6b893dc454b7 100644 --- a/arch/arm64/Makefile +++ b/arch/arm64/Makefile @@ -150,7 +150,7 @@ libs-$(CONFIG_EFI_STUB) += $(objtree)/drivers/firmware/efi/libstub/lib.a # Default target when executing plain make boot := arch/arm64/boot
-BOOT_TARGETS := Image vmlinuz.efi +BOOT_TARGETS := Image vmlinuz.efi image.fit
@@ -162,7 +162,9 @@ endif
-vmlinuz.efi: Image +image.fit: dtbs + +vmlinuz.efi image.fit: Image $(BOOT_TARGETS): vmlinux $(Q)$(MAKE) $(build)=$(boot) $(boot)/$@
@@ -215,6 +217,7 @@ virtconfig: define archhelp echo '* Image.gz - Compressed kernel image (arch/$(ARCH)/boot/Image.gz)' echo ' Image - Uncompressed kernel image (arch/$(ARCH)/boot/Image)' + echo ' image.fit - Flat Image Tree (arch/$(ARCH)/boot/image.fit)' echo ' install - Install uncompressed kernel' echo ' zinstall - Install compressed kernel' echo ' Install using (your) ~/bin/installkernel or' diff --git a/arch/arm64/boot/.gitignore b/arch/arm64/boot/.gitignore index af5dc61f8b43..abaae9de1bdd 100644 --- a/arch/arm64/boot/.gitignore +++ b/arch/arm64/boot/.gitignore @@ -2,3 +2,4 @@ Image Image.gz vmlinuz* +image.fit diff --git a/arch/arm64/boot/Makefile b/arch/arm64/boot/Makefile index 1761f5972443..62efb533a9bc 100644 --- a/arch/arm64/boot/Makefile +++ b/arch/arm64/boot/Makefile @@ -16,7 +16,8 @@
OBJCOPYFLAGS_Image :=-O binary -R .note -R .note.gnu.build-id -R .comment -S
-targets := Image Image.bz2 Image.gz Image.lz4 Image.lzma Image.lzo Image.zst +targets := Image Image.bz2 Image.gz Image.lz4 Image.lzma Image.lzo \ + Image.zst image.fit
$(obj)/Image: vmlinux FORCE $(call if_changed,objcopy) @@ -39,6 +40,12 @@ $(obj)/Image.lzo: $(obj)/Image FORCE $(obj)/Image.zst: $(obj)/Image FORCE $(call if_changed,zstd)
+# Use this to override the compression algorithm +FIT_COMPRESS ?= gzip + +$(obj)/image.fit: $(obj)/Image FORCE + $(call cmd,fit,$(FIT_COMPRESS)) + EFI_ZBOOT_PAYLOAD := Image EFI_ZBOOT_BFD_TARGET := elf64-littleaarch64 EFI_ZBOOT_MACH_TYPE := ARM64 diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 1a965fe68e01..41b360b11552 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -496,6 +496,19 @@ quiet_cmd_uimage = UIMAGE $@ -a $(UIMAGE_LOADADDR) -e $(UIMAGE_ENTRYADDR) \ -n '$(UIMAGE_NAME)' -d $< $@
+# Flat Image Tree (FIT) +# This allows for packaging of a kernel and all devicetrees files, using +# compression. +# --------------------------------------------------------------------------- + +MAKE_FIT := $(srctree)/scripts/make_fit.py + +quiet_cmd_fit = FIT $@ + cmd_fit = $(MAKE_FIT) -f $@ --arch $(UIMAGE_ARCH) --os linux \ + --name '$(UIMAGE_NAME)' \ + --compress $(UIMAGE_COMPRESSION) -k $< \ + $(<D)/dts + # XZ # --------------------------------------------------------------------------- # Use xzkern to compress the kernel image and xzmisc to compress other things. diff --git a/scripts/make_fit.py b/scripts/make_fit.py new file mode 100755 index 000000000000..e616b0d7a84a --- /dev/null +++ b/scripts/make_fit.py @@ -0,0 +1,291 @@ +#!/usr/bin/env python3 +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright 2023 Google LLC +# Written by Simon Glass sjg@chromium.org +# + +"""Build a FIT containing a lot of devicetree files + +Usage: + make_fit.py -A arm64 -n 'Linux-6.6' -O linux + -f arch/arm64/boot/image.fit -k /tmp/kern/arch/arm64/boot/image.itk + /tmp/kern/arch/arm64/boot/dts/ -E -c gzip + +Creates a FIT containing the supplied kernel and a directory containing the +devicetree files. + +Use -E to generate an external FIT (where the data is placed after the +FIT data structure). This allows parsing of the data without loading +the entire FIT. + +Use -c to compress the data, using bzip2, gzip, lz4, lzma, lzo and +zstd algorithms. + +The resulting FIT can be booted by bootloaders which support FIT, such +as U-Boot, Linuxboot, Tianocore, etc. + +Note that this tool does not yet support adding a ramdisk / initrd. +""" + +import argparse +import collections +import os +import subprocess +import sys +import tempfile +import time + +import libfdt + + +# Tool extension and the name of the command-line tools +CompTool = collections.namedtuple('CompTool', 'ext,tools') + +COMP_TOOLS = { + 'bzip2': CompTool('.bz2', 'bzip2'), + 'gzip': CompTool('.gz', 'pigz,gzip'), + 'lz4': CompTool('.lz4', 'lz4'), + 'lzma': CompTool('.lzma', 'lzma'), + 'lzo': CompTool('.lzo', 'lzop'), + 'zstd': CompTool('.zstd', 'zstd'), +} + + +def parse_args(): + """Parse the program ArgumentParser + + Returns: + Namespace object containing the arguments + """ + epilog = 'Build a FIT from a directory tree containing .dtb files' + parser = argparse.ArgumentParser(epilog=epilog) + parser.add_argument('-A', '--arch', type=str, required=True, + help='Specifies the architecture') + parser.add_argument('-c', '--compress', type=str, default='none', + help='Specifies the compression') + parser.add_argument('-E', '--external', action='store_true', + help='Convert the FIT to use external data') + parser.add_argument('-n', '--name', type=str, required=True, + help='Specifies the name') + parser.add_argument('-O', '--os', type=str, required=True, + help='Specifies the operating system') + parser.add_argument('-f', '--fit', type=str, required=True, + help='Specifies the output file (.fit)') + parser.add_argument('-k', '--kernel', type=str, required=True, + help='Specifies the (uncompressed) kernel input file (.itk)') + parser.add_argument('srcdir', type=str, nargs='*', + help='Specifies the directory tree that contains .dtb files') + + return parser.parse_args() + + +def setup_fit(fsw, name): + """Make a start on writing the FIT + + Outputs the root properties and the 'images' node + + Args: + fsw (libfdt.FdtSw): Object to use for writing + name (str): Name of kernel image + """ + fsw.INC_SIZE = 65536 + fsw.finish_reservemap() + fsw.begin_node('') + fsw.property_string('description', f'{name} with devicetree set') + fsw.property_u32('#address-cells', 1) + + fsw.property_u32('timestamp', int(time.time())) + fsw.begin_node('images') + + +def write_kernel(fsw, data, args): + """Write out the kernel image + + Writes a kernel node along with the required properties + + Args: + fsw (libfdt.FdtSw): Object to use for writing + data (bytes): Data to write (possibly compressed) + args (Namespace): Contains necessary strings: + arch: FIT architecture, e.g. 'arm64' + fit_os: Operating Systems, e.g. 'linux' + name: Name of OS, e.g. 'Linux-6.6.0-rc7' + compress: Compression algorithm to use, e.g. 'gzip' + """ + with fsw.add_node('kernel'): + fsw.property_string('description', args.name) + fsw.property_string('type', 'kernel_noload') + fsw.property_string('arch', args.arch) + fsw.property_string('os', args.os) + fsw.property_string('compression', args.compress) + fsw.property('data', data) + fsw.property_u32('load', 0) + fsw.property_u32('entry', 0) + + +def finish_fit(fsw, entries): + """Finish the FIT ready for use + + Writes the /configurations node and subnodes + + Args: + fsw (libfdt.FdtSw): Object to use for writing + entries (list of tuple): List of configurations: + str: Description of model + str: Compatible stringlist + """ + fsw.end_node() + seq = 0 + with fsw.add_node('configurations'): + for model, compat in entries: + seq += 1 + with fsw.add_node(f'conf-{seq}'): + fsw.property('compatible', bytes(compat)) + fsw.property_string('description', model) + fsw.property_string('fdt', f'fdt-{seq}') + fsw.property_string('kernel', 'kernel') + fsw.end_node() + + +def compress_data(inf, compress): + """Compress data using a selected algorithm + + Args: + inf (IOBase): Filename containing the data to compress + compress (str): Compression algorithm, e.g. 'gzip' + + Return: + bytes: Compressed data + """ + if compress == 'none': + return inf.read() + + comp = COMP_TOOLS.get(compress) + if not comp: + raise ValueError(f"Unknown compression algorithm '{compress}'") + + with tempfile.NamedTemporaryFile() as comp_fname: + with open(comp_fname.name, 'wb') as outf: + done = False + for tool in comp.tools.split(','): + try: + subprocess.call([tool, '-c'], stdin=inf, stdout=outf) + done = True + break + except FileNotFoundError: + pass + if not done: + raise ValueError(f'Missing tool(s): {comp.tools}\n') + with open(comp_fname.name, 'rb') as compf: + comp_data = compf.read() + return comp_data + + +def output_dtb(fsw, seq, fname, arch, compress): + """Write out a single devicetree to the FIT + + Args: + fsw (libfdt.FdtSw): Object to use for writing + seq (int): Sequence number (1 for first) + fmame (str): Filename containing the DTB + arch: FIT architecture, e.g. 'arm64' + compress (str): Compressed algorithm, e.g. 'gzip' + + Returns: + tuple: + str: Model name + bytes: Compatible stringlist + """ + with fsw.add_node(f'fdt-{seq}'): + # Get the compatible / model information + with open(fname, 'rb') as inf: + data = inf.read() + fdt = libfdt.FdtRo(data) + model = fdt.getprop(0, 'model').as_str() + compat = fdt.getprop(0, 'compatible') + + fsw.property_string('description', model) + fsw.property_string('type', 'flat_dt') + fsw.property_string('arch', arch) + fsw.property_string('compression', compress) + fsw.property('compatible', bytes(compat)) + + with open(fname, 'rb') as inf: + compressed = compress_data(inf, compress) + fsw.property('data', compressed) + return model, compat + + +def build_fit(args): + """Build the FIT from the provided files and arguments + + Args: + args (Namespace): Program arguments + + Returns: + tuple: + bytes: FIT data + int: Number of configurations generated + size: Total uncompressed size of data + """ + fsw = libfdt.FdtSw() + setup_fit(fsw, args.name) + seq = 0 + size = 0 + entries = [] + + # Handle the kernel + with open(args.kernel, 'rb') as inf: + comp_data = compress_data(inf, args.compress) + size += os.path.getsize(args.kernel) + write_kernel(fsw, comp_data, args) + + for path in args.srcdir: + # Handle devicetree files + if os.path.isdir(path): + for dirpath, _, fnames in os.walk(path): + for fname in fnames: + if os.path.splitext(fname)[1] != '.dtb': + continue + pathname = os.path.join(dirpath, fname) + seq += 1 + size += os.path.getsize(pathname) + model, compat = output_dtb(fsw, seq, pathname, + args.arch, args.compress) + entries.append([model, compat]) + + finish_fit(fsw, entries) + + # Include the kernel itself in the returned file count + return fsw.as_fdt().as_bytearray(), seq + 1, size + + +def run_make_fit(): + """Run the tool's main logic""" + args = parse_args() + + out_data, count, size = build_fit(args) + with open(args.fit, 'wb') as outf: + outf.write(out_data) + + ext_fit_size = None + if args.external: + mkimage = os.environ.get('MKIMAGE', 'mkimage') + subprocess.check_call([mkimage, '-E', '-F', args.fit], + stdout=subprocess.DEVNULL) + + with open(args.fit, 'rb') as inf: + data = inf.read() + ext_fit = libfdt.FdtRo(data) + ext_fit_size = ext_fit.totalsize() + + comp_size = len(out_data) + print(f'FIT size {comp_size:#x}/{comp_size / 1024 / 1024:.1f} MB', end='') + if ext_fit_size: + print(f', header {ext_fit_size:#x}/{ext_fit_size / 1024:.1f} KB', end='') + print(f', {count} files, uncompressed {size / 1024 / 1024:.1f} MB') + + +if __name__ == "__main__": + sys.exit(run_make_fit())
Changes in v8:
Changes in v7:
- Drop kbuild tag
- Rebase to -next
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+mkimage +-------
System utilities
- echo ' image.fit - Flat Image Tree (arch/$(ARCH)/boot/image.fit)' echo ' install - Install uncompressed kernel' echo ' zinstall - Install compressed kernel' echo ' Install using (your) ~/bin/installkernel or'
Image.zst image.fit
Again, $(FIT_COMPRESS) is not used anywhere.
Please fix it to
$(call cmd,fit)
See your code.
cmd_fit = $(MAKE_FIT) -f $@ --arch $(UIMAGE_ARCH) --os linux \ --name '$(UIMAGE_NAME)' \ --compress $(UIMAGE_COMPRESSION) -k $< \ $(<D)/dts
cmd_fit does not take any argument.
The compression is determined by $(UIMAGE_COMPRESSION).
Hi Masahiro,
Changes in v8:
Changes in v7:
- Drop kbuild tag
- Rebase to -next
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+mkimage +-------
System utilities
Image.zst image.fit
Please fix it to
$(call cmd,fit)
See your code.
This references argument 2, which is how it works. I have tested this, for example:
ARCH=arm64 CROSS_COMPILE=... make FIT_COMPRESS=lzma image.fit
I do want to support different algorithms, if possible. Is there a better way to do this?
On Sat, Dec 2, 2023 at 3:09 AM Simon Glass sjg@chromium.org wrote:
Hi Masahiro,
Changes in v8:
Changes in v7:
- Drop kbuild tag
- Rebase to -next
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
+mkimage +-------
System utilities
Image.zst image.fit
Please fix it to
$(call cmd,fit)
See your code.
Hah, I missed it, sorry.
You want to use gzip instead of none as the default compression for the fit image, right?
If so, maybe, you can directly add FIT_COMPRESSION in scripts/Makefile.lib Users are still allowed to override it from an environment variable.
FIT_COMPRESSION ?= gzip
cmd_fit = $(MAKE_FIT) -f $@ --arch $(UIMAGE_ARCH) --os linux \ --name '$(UIMAGE_NAME)' \ --compress $(FIT_COMPRESSION) -k $< \ $(<D)/dts
for example:
Masahiro Yamada
