[U-Boot] [PATCH] board: ti: README: Update OP-TEE binary name
The OP-TEE binary to use is renamed to v2 as the v1 binary has been deprecated and is no longer built by default.
Reported-by: Grygorii Strashko grygorii.strashko@ti.com Signed-off-by: Andrew F. Davis afd@ti.com --- board/ti/am65x/README | 2 +- board/ti/j721e/README | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/ti/am65x/README b/board/ti/am65x/README index 2e3fd9c4a8..a8aa94024b 100644 --- a/board/ti/am65x/README +++ b/board/ti/am65x/README @@ -138,7 +138,7 @@ $ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- O=/tmp/r5
4.2. A53: $ make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- am65x_evm_a53_defconfig O=/tmp/a53 -$ make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- ATF=<path to ATF dir>/build/k3/generic/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager.bin O=/tmp/a53 +$ make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- ATF=<path to ATF dir>/build/k3/generic/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin O=/tmp/a53
Target Images -------------- diff --git a/board/ti/j721e/README b/board/ti/j721e/README index 5be7d099db..27461bd2eb 100644 --- a/board/ti/j721e/README +++ b/board/ti/j721e/README @@ -154,7 +154,7 @@ $ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- O=/tmp/r5
4.2. A72: $ make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- j721e_evm_a72_defconfig O=/tmp/a72 -$ make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- ATF=<path to ATF dir>/build/k3/generic/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager.bin O=/tmp/a72 +$ make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- ATF=<path to ATF dir>/build/k3/generic/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin O=/tmp/a72
Applied to u-boot-ti next.
Thanks and regards, Lokesh
Andrew F. Davis
Lokesh Vutla
