Zybo Z7 board - fix SPL uart init bitrate
Zybo Z7 board uses 100 MHz clock for UART bitrate generator, in defconfig is 50 MHz listed. This error manifests itself when boot starts, following is seen on console:
������b U-Boot SPL 2019.01 (Jul 17 2019 - 21:36:54 +0200) mmc boot Trying to boot from MMC1
First line is output with wrong bitrate. After changing definition to correct value, boot output starts correctly, now:
Debug uart enabled
U-Boot SPL 2019.10 (Jan 09 2020 - 08:18:37 +0100) mmc boot Trying to boot from MMC1
(Please ignore version change, I just used this occasion to fix some other issues as well.)
Patch to fix this small issue follows. As this is my first contribution to this project, please help me with what could be necessary to do for this fix to be accepted, in order to fit any custom used here...
Regards, Milan
--- configs/zynq_zybo_z7_defconfig.orig 2020-01-09 08:16:33.744969000 +0100 +++ configs/zynq_zybo_z7_defconfig 2020-01-09 07:49:33.181891000 +0100 @@ -5,7 +5,7 @@ CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xe0001000 -CONFIG_DEBUG_UART_CLOCK=50000000 +CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_CUSTOM_LDSCRIPT=y
+Luis
čt 9. 1. 2020 v 14:00 odesílatel Milan Obuch u-boot@dino.sk napsal:
Debug uart enabled
Regards, Milan
Luis: Can you please check?
Thanks, Michal
Hi Michal,
On Tue, Jan 14, 2020 at 5:48 AM Michal Simek monstr@monstr.eu wrote:
+Luis
Zybo Z7 board uses 100 MHz clock for UART bitrate generator, in defconfig is 50 MHz listed. This error manifests itself when boot starts, following is seen on console: [...] --- configs/zynq_zybo_z7_defconfig.orig 2020-01-09 08:16:33.744969000 +0100 +++ configs/zynq_zybo_z7_defconfig 2020-01-09 07:49:33.181891000 +0100 @@ -5,7 +5,7 @@ CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xe0001000 -CONFIG_DEBUG_UART_CLOCK=50000000 +CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_CUSTOM_LDSCRIPT=y
I successfully tested the patch on a Zybo Z7-20 board. As the description said, the text "Debug uart enabled" is now displayed.
Once the commit is in shape to be merged, feel free to add my Tested-by tag.
Tested-by: Luis Araneda luaraneda@gmail.com
Please ping me if the author does not want to send a proper git patch so I can send it instead. I don't want this work to be lost.
Regards, Luis Araneda.
Luis Araneda
Michal Simek
Milan Obuch
