[PATCH] Kconfig: update LOGLEVEL range
As LOGLEVEL ranges form 0 to 9 set the limit to 10.
Signed-off-by: Marek Bykowski marek.bykowski@gmail.com --- common/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/Kconfig b/common/Kconfig index 28d5e9a0cc..d1c9dd47cf 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -469,7 +469,7 @@ config IDENT_STRING config LOGLEVEL int "loglevel" default 4 - range 0 8 + range 0 10 help All Messages with a loglevel smaller than the console loglevel will be compiled in. The loglevels are defined as follows:
