[PATCH] freescale: imx8mm_evk: Use IS_ENABLED instead of #ifdef
Use IS_ENABLED(CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG) to make the code more readable and fix checkpatch.pl warning
Signed-off-by: Tommaso Merciai tomm.merciai@gmail.com --- board/freescale/imx8mm_evk/imx8mm_evk.c | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/board/freescale/imx8mm_evk/imx8mm_evk.c b/board/freescale/imx8mm_evk/imx8mm_evk.c index ab55135a97..e0975fcda7 100644 --- a/board/freescale/imx8mm_evk/imx8mm_evk.c +++ b/board/freescale/imx8mm_evk/imx8mm_evk.c @@ -60,9 +60,10 @@ int board_mmc_get_env_dev(int devno)
int board_late_init(void) { -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - env_set("board_name", "EVK"); - env_set("board_rev", "iMX8MM"); -#endif + if (IS_ENABLED(CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG)) { + env_set("board_name", "EVK"); + env_set("board_rev", "iMX8MM"); + } + return 0; }
Use IS_ENABLED(CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG) to make the code more readable and fix checkpatch.pl warning Signed-off-by: Tommaso Merciai tomm.merciai@gmail.com
Best regards, Stefano Babic
Hi Stefano, Thanks for the update.
Tommaso
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de =====================================================================
sbabic@denx.de
Tommaso Merciai
Tommaso Merciai
