[PATCH] ARM: meson: fixup error on efuse commands return
All `sm efuseread/efusewrite` commands exit with an error, even if the fuse have actually been dealt with correctly.
This is because the smc call return the size it actually processed but this result is checked against 0.
Return failure in do_efuse_read/write if the return value of meson_sm_read/write_efuse() is not the requested size.
Fixes: 52195ba5f579 ("ARM: amlogic: add sm efuse write support and cmd for read/write efuse") Signed-off-by: Jerome Brunet jbrunet@baylibre.com --- arch/arm/mach-meson/sm.c | 9 +++------ 1 file changed, 3 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-meson/sm.c b/arch/arm/mach-meson/sm.c index 6c28c0f5e445..d6eb910689f4 100644 --- a/arch/arm/mach-meson/sm.c +++ b/arch/arm/mach-meson/sm.c @@ -82,10 +82,7 @@ ssize_t meson_sm_write_efuse(uintptr_t offset, void *buffer, size_t size)
smc_call(®s);
- if (regs.regs[0] == 0) - return -1; - - return 0; + return regs.regs[0]; }
#define SM_CHIP_ID_LENGTH 119 @@ -222,7 +219,7 @@ static int do_efuse_read(struct cmd_tbl *cmdtp, int flag, int argc, address = simple_strtoul(argv[3], NULL, 0);
ret = meson_sm_read_efuse(offset, (void *)address, size); - if (ret) + if (ret != size) return CMD_RET_FAILURE;
return CMD_RET_SUCCESS; @@ -243,7 +240,7 @@ static int do_efuse_write(struct cmd_tbl *cmdtp, int flag, int argc, address = simple_strtoul(argv[3], NULL, 0);
ret = meson_sm_write_efuse(offset, (void *)address, size); - if (ret) + if (ret != size) return CMD_RET_FAILURE;
smc_call(®s);
return -1;
- if (ret)
- if (ret)
Reviewed-by: Neil Armstrong narmstrong@baylibre.com
Thanks, Applied to https://source.denx.de/u-boot/custodians/u-boot-amlogic (u-boot-amlogic-test)
[1/1] ARM: meson: fixup error on efuse commands return https://source.denx.de/u-boot/custodians/u-boot-amlogic/-/commit/3145e0d0ff0...
Jerome Brunet
Neil Armstrong
