[PATCH v2 0/2] musb-new: fix omap peripheral support
DM_GADGET did not compile at all, probe was not called in non-gadget mode.
Tested on an omap4 board with ums and fastboot command.
Changes in V2: - split up former 2/2 patch into two. - do not break non-DM_USB_GADGET compile further
Andreas Kemnade (2): musb-new: omap2430: no host data access in gadget mode musb-new: omap2430: fix compiling in DM_USB_GADGET config
drivers/usb/musb-new/omap2430.c | 53 ++++++++++++++++++++++----------- 1 file changed, 35 insertions(+), 18 deletions(-)
Avoid accessing structures (usb_bus_priv) only present when musb is in host mode.
Signed-off-by: Andreas Kemnade andreas@kemnade.info --- drivers/usb/musb-new/omap2430.c | 34 ++++++++++++++++----------------- 1 file changed, 16 insertions(+), 18 deletions(-)
diff --git a/drivers/usb/musb-new/omap2430.c b/drivers/usb/musb-new/omap2430.c index 7d15b94a6c..0d1fb03727 100644 --- a/drivers/usb/musb-new/omap2430.c +++ b/drivers/usb/musb-new/omap2430.c @@ -214,37 +214,35 @@ static int omap2430_musb_of_to_plat(struct udevice *dev)
static int omap2430_musb_probe(struct udevice *dev) { -#ifdef CONFIG_USB_MUSB_HOST - struct musb_host_data *host = dev_get_priv(dev); -#else - struct musb *musbp; -#endif struct omap2430_musb_plat *plat = dev_get_plat(dev); - struct usb_bus_priv *priv = dev_get_uclass_priv(dev); struct omap_musb_board_data *otg_board_data; int ret = 0; void *base = dev_read_addr_ptr(dev); - - priv->desc_before_addr = true; + struct musb *musbp;
otg_board_data = &plat->otg_board_data;
-#ifdef CONFIG_USB_MUSB_HOST - host->host = musb_init_controller(&plat->plat, - (struct device *)otg_board_data, - plat->base); - if (!host->host) { - return -EIO; + if (CONFIG_IS_ENABLED(USB_MUSB_HOST)) { + struct musb_host_data *host = dev_get_priv(dev); + struct usb_bus_priv *priv = dev_get_uclass_priv(dev); + + priv->desc_before_addr = true; + + host->host = musb_init_controller(&plat->plat, + (struct device *)otg_board_data, + plat->base); + if (!host->host) + return -EIO; + + return musb_lowlevel_init(host); }
- ret = musb_lowlevel_init(host); -#else musbp = musb_register(&plat->plat, (struct device *)otg_board_data, plat->base); if (IS_ERR_OR_NULL(musbp)) return -EINVAL; -#endif - return ret; + + return 0; }
static int omap2430_musb_remove(struct udevice *dev)
Add the separate IRQ handling function and change the registration.
Signed-off-by: Andreas Kemnade andreas@kemnade.info --- drivers/usb/musb-new/omap2430.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/drivers/usb/musb-new/omap2430.c b/drivers/usb/musb-new/omap2430.c index 0d1fb03727..42e7abddbc 100644 --- a/drivers/usb/musb-new/omap2430.c +++ b/drivers/usb/musb-new/omap2430.c @@ -46,6 +46,15 @@ static inline void omap2430_low_level_init(struct musb *musb) musb_writel(musb->mregs, OTG_FORCESTDBY, l); }
+#ifdef CONFIG_DM_USB_GADGET +int dm_usb_gadget_handle_interrupts(struct udevice *dev) +{ + struct musb_host_data *host = dev_get_priv(dev); + + host->host->isr(0, host->host); + return 0; +} +#endif
static int omap2430_musb_init(struct musb *musb) { @@ -235,6 +244,16 @@ static int omap2430_musb_probe(struct udevice *dev) return -EIO;
return musb_lowlevel_init(host); + } else if (CONFIG_IS_ENABLED(DM_USB_GADGET)) { + struct musb_host_data *host = dev_get_priv(dev); + + host->host = musb_init_controller(&plat->plat, + (struct device *)otg_board_data, + plat->base); + if (!host->host) + return -EIO; + + return usb_add_gadget_udc((struct device *)otg_board_data, &host->host->g); }
Andreas Kemnade
