[U-Boot] [PATCH V3 1/5] ARM: fix u-boot.lds for -ffunction-sections/-fdata-sections
When -ffunction-sections or -fdata-section are used, symbols are placed into sections such as .data.eserial1_device and .bss.serial_current. Update the linker script to explicitly include these. Without this change (at least with my gcc-4.5.3 built using crosstool-ng), I see that the sections do end up being included, but __bss_end__ gets set to the same value as __bss_start.
Signed-off-by: Stephen Warren swarren@nvidia.com Acked-by: Allen Martin amartin@nvidia.com --- v3: No change. v2: Removed changes from some entries where it wasn't needed. --- arch/arm/cpu/u-boot.lds | 8 ++++---- 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/u-boot.lds b/arch/arm/cpu/u-boot.lds index e49ca0c..9153c3d 100644 --- a/arch/arm/cpu/u-boot.lds +++ b/arch/arm/cpu/u-boot.lds @@ -34,8 +34,8 @@ SECTIONS .text : { __image_copy_start = .; - CPUDIR/start.o (.text) - *(.text) + CPUDIR/start.o (.text*) + *(.text*) }
. = ALIGN(4); @@ -43,7 +43,7 @@ SECTIONS
. = ALIGN(4); .data : { - *(.data) + *(.data*) }
. = ALIGN(4); @@ -81,7 +81,7 @@ SECTIONS
.bss __rel_dyn_start (OVERLAY) : { __bss_start = .; - *(.bss) + *(.bss*) . = ALIGN(4); __bss_end__ = .; }
Add an ASSERT() to u-boot.lds to detect an SPL that doesn't fit within SPL_TEXT_BASE..SPL_MAX_SIZE.
Different .lds files implement this check in two possible ways: 1) An ASSERT() like this 2) Defining a MEMORY region of size SPL_MAX_SIZE, and re-directing all linker output into that region. Since u-boot.lds is used for both SPL and main U-Boot, this would entail only sometimes defining a MEMORY region, and only sometimes performing that redirection, and hence option (1) was deemed much simpler, and hence implemented.
Note that this causes build failures at least for NVIDIA Tegra Seaboard and Ventana. However, these are legitimate; the SPL doesn't fit within the required space, and this does cause runtime issues.
Signed-off-by: Stephen Warren swarren@nvidia.com Acked-by: Simon Glass sjg@chromium.org Acked-by: Allen Martin amartin@nvidia.com --- v3: No change. v2: New patch; replaced checks in Makefile. --- arch/arm/cpu/u-boot.lds | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/u-boot.lds b/arch/arm/cpu/u-boot.lds index 9153c3d..ec2a273 100644 --- a/arch/arm/cpu/u-boot.lds +++ b/arch/arm/cpu/u-boot.lds @@ -92,3 +92,7 @@ SECTIONS /DISCARD/ : { *(.interp*) } /DISCARD/ : { *(.gnu*) } } + +#if defined(CONFIG_SPL_TEXT_BASE) && defined(CONFIG_SPL_MAX_SIZE) +ASSERT(__bss_end__ < (CONFIG_SPL_TEXT_BASE + CONFIG_SPL_MAX_SIZE), "SPL image too big"); +#endif
- An ASSERT() like this
- Defining a MEMORY region of size SPL_MAX_SIZE, and re-directing all linker output into that region. Since u-boot.lds is used for both SPL and main U-Boot, this would entail only sometimes defining a MEMORY region, and only sometimes performing that redirection, and hence option (1) was deemed much simpler, and hence implemented.
This isn't quite what I envisoned at first (see arch/arm/cpu/armv7/omap-common/u-boot-spl.lds) but I think for the generic linker script, this is the least instrusive method.
Acked-by: Tom Rini trini@ti.com
And since parts 1 and 2 are generic code, I've assigned them to Albert in patchwork. It's his call if he wants to take them or have them all come via the tegra tree.
I tested this series on seaboard.
Tested-by: Simon Glass sjg@chromium.org
-- Tom
For Tegra, the SPL and main U-Boot are concatenated together to form a single memory image. Hence, the maximum SPL size is the different in TEXT_BASE for SPL and main U-Boot. Instead of manually calculating SPL_MAX_SIZE based on those two TEXT_BASE, which can lead to errors if one TEXT_BASE is changed without updating SPL_MAX_SIZE, simply perform the calculation automatically.
Signed-off-by: Stephen Warren swarren@nvidia.com Acked-by: Simon Glass sjg@chromium.org Acked-by: Allen Martin amartin@nvidia.com --- v3: No change. v2: New patch. --- include/configs/tegra20-common.h | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/include/configs/tegra20-common.h b/include/configs/tegra20-common.h index 70c5cfb..c0c93e5 100644 --- a/include/configs/tegra20-common.h +++ b/include/configs/tegra20-common.h @@ -188,7 +188,8 @@ #define CONFIG_SPL #define CONFIG_SPL_NAND_SIMPLE #define CONFIG_SPL_TEXT_BASE 0x00108000 -#define CONFIG_SPL_MAX_SIZE 0x00004000 +#define CONFIG_SPL_MAX_SIZE (CONFIG_SYS_TEXT_BASE - \ + CONFIG_SPL_TEXT_BASE) #define CONFIG_SYS_SPL_MALLOC_START 0x00090000 #define CONFIG_SYS_SPL_MALLOC_SIZE 0x00010000 #define CONFIG_SPL_STACK 0x000ffffc
1.7.0.4
Seaboard and Ventana are very similar boards, and so share the seaboard.c board file. The one difference needed so far is detected at run-time by calling machine_is_ventana(). This bloats the Ventana build with code that is never used. Switch to detecting Ventana at compile time to remove bloat. This shaves ~5K off the SPL size on Ventana, and makes the SPL fit within the max size.
Signed-off-by: Stephen Warren swarren@nvidia.com --- v3: Combined back-to-back #ifdefs. v2: New patch to replace modification of CONFIG_SYS_TEXT_BASE. --- board/nvidia/seaboard/seaboard.c | 4 +--- 1 files changed, 1 insertions(+), 3 deletions(-)
diff --git a/board/nvidia/seaboard/seaboard.c b/board/nvidia/seaboard/seaboard.c index 4e8a183..ea431e9 100644 --- a/board/nvidia/seaboard/seaboard.c +++ b/board/nvidia/seaboard/seaboard.c @@ -34,7 +34,7 @@ #endif
/* TODO: Remove this code when the SPI switch is working */ -#ifndef CONFIG_SPI_UART_SWITCH +#if !defined(CONFIG_SPI_UART_SWITCH) && (CONFIG_MACH_TYPE != MACH_TYPE_VENTANA) /* * Routine: gpio_config_uart_seaboard * Description: Force GPIO_PI3 low on Seaboard so UART4 works. @@ -48,8 +48,6 @@ static void gpio_config_uart_seaboard(void)
void gpio_early_init_uart(void) { - if (machine_is_ventana()) - return; gpio_config_uart_seaboard(); } #endif
Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org
Seaboard has a GPIO that switches an external mux between Tegra's debug UART and SPI flash. This is initialized from the SPL so that SPL debug output can be seen. Simplify the code that does this, and don't actually request the GPIO in the SPL; just program it. This saves ~4.5K from the size of the SPL, mostly BSS due to the large gpio_names[] table that is no longer required. This makes Seaboard's SPL fit within the current max size.
Signed-off-by: Stephen Warren swarren@nvidia.com Acked-by: Simon Glass sjg@chromium.org Acked-by: Allen Martin amartin@nvidia.com --- v3: No change. v2: New patch to replace modification of CONFIG_SYS_TEXT_BASE. --- board/nvidia/seaboard/seaboard.c | 14 ++++---------- 1 files changed, 4 insertions(+), 10 deletions(-)
diff --git a/board/nvidia/seaboard/seaboard.c b/board/nvidia/seaboard/seaboard.c index ea431e9..c412c07 100644 --- a/board/nvidia/seaboard/seaboard.c +++ b/board/nvidia/seaboard/seaboard.c @@ -26,6 +26,7 @@ #include <asm/arch/tegra.h> #include <asm/arch/clock.h> #include <asm/arch/funcmux.h> +#include <asm/arch/gpio.h> #include <asm/arch/pinmux.h> #include <asm/arch-tegra/mmc.h> #include <asm/gpio.h> @@ -35,21 +36,14 @@
/* TODO: Remove this code when the SPI switch is working */ #if !defined(CONFIG_SPI_UART_SWITCH) && (CONFIG_MACH_TYPE != MACH_TYPE_VENTANA) -/* - * Routine: gpio_config_uart_seaboard - * Description: Force GPIO_PI3 low on Seaboard so UART4 works. - */ -static void gpio_config_uart_seaboard(void) +void gpio_early_init_uart(void) { /* Enable UART via GPIO_PI3 (port 8, bit 3) so serial console works */ +#ifndef CONFIG_SPL_BUILD gpio_request(GPIO_PI3, NULL); +#endif gpio_direction_output(GPIO_PI3, 0); } - -void gpio_early_init_uart(void) -{ - gpio_config_uart_seaboard(); -} #endif
#ifdef CONFIG_TEGRA_MMC
Hi Stephen,
On Mon, 22 Oct 2012 10:19:36 -0600, Stephen Warren swarren@wwwdotorg.org wrote:
Is it possible to reorder the patch series so that Seaboard (and Ventana?) builds do not break temporarily between patch 2 and this patch?
Amicalement,
On 10/27/2012 03:15 AM, Albert ARIBAUD wrote:
Hi Stephen,
It would be possibel, although I'd personally rather call out the issue explicitly with a build break; if the build succeeds, you end up using code that silently causes memory corruption. Of course, this issue has been around for a while, so perhaps hiding it for another couple extra commits wouldn't be a big deal. Plus, the build break proves the assert in the .lds file works:-) But it's not big deal either way; feel free to re-order the commits if you want.
Hi Stephen,
On Sat, 27 Oct 2012 20:09:20 -0600, Stephen Warren swarren@wwwdotorg.org wrote:
Hi Stephen,
No need: your points are valid.
Amicalement,
Hi Simon,
Applied (this patch only in the series) to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Stephen Warren
