[U-Boot] [PATCH] defconfigs: Add a config for AM43xx High Security EVM with QSPI Boot support
On AM43xx HS devices, QSPI boot is XIP and we use a single stage bootloader. Add a defconfig for this.
Signed-off-by: Andrew F. Davis afd@ti.com --- MAINTAINERS | 1 + configs/am43xx_hs_evm_qspi_defconfig | 65 ++++++++++++++++++++++++++++ 2 files changed, 66 insertions(+) create mode 100644 configs/am43xx_hs_evm_qspi_defconfig
diff --git a/MAINTAINERS b/MAINTAINERS index 438fb225ab..1a9226d9b5 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -838,6 +838,7 @@ F: arch/arm/mach-k3/config_secure.mk F: configs/am335x_hs_evm_defconfig F: configs/am335x_hs_evm_uart_defconfig F: configs/am43xx_hs_evm_defconfig +F: configs/am43xx_hs_evm_qspi_defconfig F: configs/am57xx_hs_evm_defconfig F: configs/am57xx_hs_evm_usb_defconfig F: configs/dra7xx_hs_evm_defconfig diff --git a/configs/am43xx_hs_evm_qspi_defconfig b/configs/am43xx_hs_evm_qspi_defconfig new file mode 100644 index 0000000000..5960950142 --- /dev/null +++ b/configs/am43xx_hs_evm_qspi_defconfig @@ -0,0 +1,65 @@ +CONFIG_ARM=y +CONFIG_ARCH_CPU_INIT=y +# CONFIG_SYS_THUMB_BUILD is not set +CONFIG_ARCH_OMAP2PLUS=y +CONFIG_TI_SECURE_DEVICE=y +CONFIG_ISW_ENTRY_ADDR=0x300018e0 +CONFIG_TI_COMMON_CMD_OPTIONS=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_DM_GPIO=y +CONFIG_AM43XX=y +CONFIG_TI_SECURE_EMIF_REGION_START=0xbdb00000 +CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 +CONFIG_TI_SECURE_EMIF_PROTECTED_REGION_SIZE=0x01c00000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT_IMAGE_POST_PROCESS=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1,SERIAL1,QSPI" +CONFIG_QSPI_BOOT=y +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_MISC_INIT_R is not set +CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_NAND=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MTDPARTS=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="am43x-epos-evm" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DM=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y +CONFIG_DM_MMC=y +CONFIG_MMC_OMAP_HS=y +CONFIG_SPI_FLASH=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_SF_DEFAULT_SPEED=48000000 +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_PHY_GIGE=y +CONFIG_MII=y +CONFIG_DRIVER_TI_CPSW=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_TI_QSPI=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_OMAP=y +CONFIG_USB_DWC3_PHY_OMAP=y +CONFIG_OMAP_USB_PHY=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0403 +CONFIG_USB_GADGET_PRODUCT_NUM=0xbd00 +CONFIG_USB_GADGET_DOWNLOAD=y
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
This gives the following build warning. Can you fix it and re post?
In file included from arch/arm/mach-omap2/am33xx/board.c:14: include/ns16550.h:31: warning: "CONFIG_SYS_NS16550_REG_SIZE" redefined #define CONFIG_SYS_NS16550_REG_SIZE (-1)
In file included from include/config.h:8, from include/common.h:22, from arch/arm/mach-omap2/am33xx/board.c:10: include/configs/am43xx_evm.h:19: note: this is the location of the previous definition #define CONFIG_SYS_NS16550_REG_SIZE (-4)
In file included from drivers/serial/ns16550.c:11: include/ns16550.h:31: warning: "CONFIG_SYS_NS16550_REG_SIZE" redefined #define CONFIG_SYS_NS16550_REG_SIZE (-1)
In file included from include/config.h:8, from include/common.h:22, from drivers/serial/ns16550.c:7: include/configs/am43xx_evm.h:19: note: this is the location of the previous definition #define CONFIG_SYS_NS16550_REG_SIZE (-4)
In file included from drivers/serial/serial_omap.c:12: include/ns16550.h:31: warning: "CONFIG_SYS_NS16550_REG_SIZE" redefined #define CONFIG_SYS_NS16550_REG_SIZE (-1)
In file included from include/config.h:8, from include/common.h:22, from drivers/serial/serial_omap.c:9: include/configs/am43xx_evm.h:19: note: this is the location of the previous definition #define CONFIG_SYS_NS16550_REG_SIZE (-4)
arch/arm/mach-omap2/config_secure.mk:97: recipe for target 'u-boot_HS_XIP_X-LOADER' failed make: *** [u-boot_HS_XIP_X-LOADER] Error 1 make: *** Deleting file 'u-boot_HS_XIP_X-LOADER'
Andrew F. Davis
Lokesh Vutla
