[U-Boot] [PATCH v2] riscv: configs: Rename ax25-ae350 defconfig
Remove cpu name from the defconfig naming. Because other cpus maybe run on AE350 platform. So only use platfrom name in defconfig naming will be better.
Signed-off-by: Rick Chen rick@andestech.com Cc: Greentime Hu greentime@andestech.com --- Changes since v1: Use git format-patch �VM to show delta when rename. --- configs/{a25-ae350_32_defconfig => ae350_rv32_defconfig} | 0 configs/{ax25-ae350_64_defconfig => ae350_rv64_defconfig} | 0 2 files changed, 0 insertions(+), 0 deletions(-) rename configs/{a25-ae350_32_defconfig => ae350_rv32_defconfig} (100%) rename configs/{ax25-ae350_64_defconfig => ae350_rv64_defconfig} (100%)
diff --git a/configs/a25-ae350_32_defconfig b/configs/ae350_rv32_defconfig similarity index 100% rename from configs/a25-ae350_32_defconfig rename to configs/ae350_rv32_defconfig diff --git a/configs/ax25-ae350_64_defconfig b/configs/ae350_rv64_defconfig similarity index 100% rename from configs/ax25-ae350_64_defconfig rename to configs/ae350_rv64_defconfig
Changes since v1: Use git format-patch ¡VM to show delta when rename.
Andes
Bin Meng
