[U-Boot] [PATCH v2 2/7] da850evm : enable NAND even when not in NAND boot mode
There is currently no NAND pinmux enabled by the da850evm board setup code. This is fine when booting from NAND since the early boot code (UBL) will setup the pinmux; however, when the boot mode is any other setting NAND is unusable when enabled in the config.
This patch adds a pinmux list for NAND and enables it when NAND is enabled in the config. Tested by booting from SPI on the da850evm and verifying NAND was usable.
Signed-off-by: Ben Gardiner bengardiner@nanometrics.ca CC: Nick Thompson nick.thompson@ge.com To: Sudhakar Rajashekhara sudhakar.raj@ti.com
V2: * Rebased to b69b02b92f59330be9d662110e202cfd3503eafa of u-boot-ti/master
Note: there is precendent for NAND configuration by u-boot independent of the selected boot mode; see commit 26be2c53d671ecfd3e0483f0870649ac28322293 by Nick Thompson nick.thompson@ge.com "Davinci: NAND enable ECC even when not in NAND boot mode"
--- board/davinci/da8xxevm/da850evm.c | 22 ++++++++++++++++++++++ 1 files changed, 22 insertions(+), 0 deletions(-)
diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c index eeb456c..f84adb9 100644 --- a/board/davinci/da8xxevm/da850evm.c +++ b/board/davinci/da8xxevm/da850evm.c @@ -54,12 +54,34 @@ static const struct pinmux_config i2c_pins[] = { { pinmux(4), 2, 3 } };
+#ifdef CONFIG_NAND_DAVINCI +const struct pinmux_config nand_pins[] = { + { pinmux(7), 1, 1 }, + { pinmux(7), 1, 2 }, + { pinmux(7), 1, 4 }, + { pinmux(7), 1, 5 }, + { pinmux(9), 1, 0 }, + { pinmux(9), 1, 1 }, + { pinmux(9), 1, 2 }, + { pinmux(9), 1, 3 }, + { pinmux(9), 1, 4 }, + { pinmux(9), 1, 5 }, + { pinmux(9), 1, 6 }, + { pinmux(9), 1, 7 }, + { pinmux(12), 1, 5 }, + { pinmux(12), 1, 6 } +}; +#endif + static const struct pinmux_resource pinmuxes[] = { #ifdef CONFIG_SPI_FLASH PINMUX_ITEM(spi1_pins), #endif PINMUX_ITEM(uart_pins), PINMUX_ITEM(i2c_pins), +#ifdef CONFIG_NAND_DAVINCI + PINMUX_ITEM(nand_pins), +#endif };
static const struct lpsc_resource lpsc[] = {
Ben Gardiner
