[PATCH 1/2 v4] board: starfive: support Pine64 Star64 board
Similar to the Milk-V Mars, The Star64 board contains few differences to the VisionFive 2 boards, so can be part of the same U-boot build.
Signed-off-by: Henry Bell dmoo_dv@protonmail.com Cc: ycliang@andestech.com Cc: heinrich.schuchardt@canonical.com ---
Changes since v1
- Fix typos on naming - Create pine64_star64 struct to be populated with PHY values once confirmed
Changes since v2
- Set delays to 0 - Add missing 10/100/1000 clocks across the two devices - Set all uA values to 2910
Changes since v3
- Rebase against d678a59d2d --- board/starfive/visionfive2/spl.c | 91 +++++++++++++++++++ .../visionfive2/starfive_visionfive2.c | 4 + 2 files changed, 95 insertions(+)
diff --git a/board/starfive/visionfive2/spl.c b/board/starfive/visionfive2/spl.c index b555189556..becc178c38 100644 --- a/board/starfive/visionfive2/spl.c +++ b/board/starfive/visionfive2/spl.c @@ -86,6 +86,45 @@ static const struct starfive_vf2_pro starfive_verb[] = { "tx-internal-delay-ps", "0"}, };
+static const struct starfive_vf2_pro star64_pine64[] = { + {"/soc/ethernet@16030000", "starfive,tx-use-rgmii-clk", NULL}, + {"/soc/ethernet@16040000", "starfive,tx-use-rgmii-clk", NULL}, + + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,tx-clk-adj-enabled", NULL}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,tx-clk-10-inverted", NULL}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,tx-clk-100-inverted", NULL}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,tx-clk-1000-inverted", NULL}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,rx-clk-drv-microamp", "2910"}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "motorcomm,rx-data-drv-microamp", "2910"}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "rx-internal-delay-ps", "0"}, + {"/soc/ethernet@16030000/mdio/ethernet-phy@0", + "tx-internal-delay-ps", "0"}, + + {"/soc/ethernet@16040000/mdio/ethernet-phy@1", + "motorcomm,tx-clk-adj-enabled", NULL}, + {"/soc/ethernet@16040000/mdio/ethernet-phy@1", + "motorcomm,tx-clk-10-inverted", NULL}, + {"/soc/ethernet@16040000/mdio/ethernet-phy@1", + "motorcomm,tx-clk-100-inverted", NULL}, + {"/soc/ethernet@16040000/mdio/ethernet-phy@0", + "motorcomm,tx-clk-1000-inverted", NULL}, + {"/soc/ethernet@16040000/mdio/ethernet-phy@1", + "motorcomm,rx-clk-drv-microamp", "2910"}, + {"/soc/ethernet@16040000/mdio/ethernet-phy@1", + "motorcomm,rx-data-drv-microamp", "2910"}, + {"/soc/ethernet@16040000/mdio/ethernet-phy@1", + "rx-internal-delay-ps", "0"}, + {"/soc/ethernet@16040000/mdio/ethernet-phy@1", + "tx-internal-delay-ps", "0"}, +}; + void spl_fdt_fixup_mars(void *fdt) { static const char compat[] = "milkv,mars\0starfive,jh7110"; @@ -250,6 +289,56 @@ void spl_fdt_fixup_version_b(void *fdt) } }
+void spl_fdt_fixup_star64(void *fdt) +{ + static const char compat[] = "pine64,star64\0starfive,jh7110"; + u32 phandle; + u8 i; + int offset; + int ret; + + fdt_setprop(fdt, fdt_path_offset(fdt, "/"), "compatible", compat, sizeof(compat)); + fdt_setprop_string(fdt, fdt_path_offset(fdt, "/"), "model", + "Pine64 Star64"); + + /* gmac0 */ + offset = fdt_path_offset(fdt, "/soc/clock-controller@17000000"); + phandle = fdt_get_phandle(fdt, offset); + offset = fdt_path_offset(fdt, "/soc/ethernet@16030000"); + + fdt_setprop_u32(fdt, offset, "assigned-clocks", phandle); + fdt_appendprop_u32(fdt, offset, "assigned-clocks", JH7110_AONCLK_GMAC0_TX); + fdt_setprop_u32(fdt, offset, "assigned-clock-parents", phandle); + fdt_appendprop_u32(fdt, offset, "assigned-clock-parents", + JH7110_AONCLK_GMAC0_RMII_RTX); + + /* gmac1 */ + offset = fdt_path_offset(fdt, "/soc/clock-controller@13020000"); + phandle = fdt_get_phandle(fdt, offset); + offset = fdt_path_offset(fdt, "/soc/ethernet@16040000"); + + fdt_setprop_u32(fdt, offset, "assigned-clocks", phandle); + fdt_appendprop_u32(fdt, offset, "assigned-clocks", JH7110_SYSCLK_GMAC1_TX); + fdt_setprop_u32(fdt, offset, "assigned-clock-parents", phandle); + fdt_appendprop_u32(fdt, offset, "assigned-clock-parents", + JH7110_SYSCLK_GMAC1_RMII_RTX); + + for (i = 0; i < ARRAY_SIZE(star64_pine64); i++) { + offset = fdt_path_offset(fdt, star64_pine64[i].path); + + if (star64_pine64[i].value) + ret = fdt_setprop_u32(fdt, offset, star64_pine64[i].name, + dectoul(star64_pine64[i].value, NULL)); + else + ret = fdt_setprop_empty(fdt, offset, star64_pine64[i].name); + + if (ret) { + pr_err("%s set prop %s fail.\n", __func__, star64_pine64[i].name); + break; + } + } +} + void spl_perform_fixups(struct spl_image_info *spl_image) { u8 version; @@ -278,6 +367,8 @@ void spl_perform_fixups(struct spl_image_info *spl_image) spl_fdt_fixup_version_b(spl_image->fdt_addr); break; }; + } else if (!strncmp(product_id, "STAR64", 6)) { + spl_fdt_fixup_star64(spl_image->fdt_addr); } else { pr_err("Unknown product %s\n", product_id); }; diff --git a/board/starfive/visionfive2/starfive_visionfive2.c b/board/starfive/visionfive2/starfive_visionfive2.c index 6be5348962..f6114602f8 100644 --- a/board/starfive/visionfive2/starfive_visionfive2.c +++ b/board/starfive/visionfive2/starfive_visionfive2.c @@ -27,6 +27,8 @@ DECLARE_GLOBAL_DATA_PTR; "starfive/jh7110-starfive-visionfive-2-v1.2a.dtb" #define FDTFILE_VISIONFIVE2_1_3B \ "starfive/jh7110-starfive-visionfive-2-v1.3b.dtb" +#define FDTFILE_PINE64_STAR64 \ + "starfive/jh7110-pine64-star64.dtb"
/* enable U74-mc hart1~hart4 prefetcher */ static void enable_prefetcher(void) @@ -87,6 +89,8 @@ static void set_fdtfile(void) fdtfile = FDTFILE_VISIONFIVE2_1_3B; break; } + } else if (!strncmp(product_id, "STAR64", 6)) { + fdtfile = FDTFILE_PINE64_STAR64; } else { log_err("Unknown product\n"); return;
H Bell
