[U-Boot] [PATCH] trats/trats2: exynos_power_init: return 0 if no battery detected.
Generic board support is now enabled for Exynos 4, and if any init function returns an error then the init process is stopped.
This makes a boot issue on the Trats and Trats2 devices. If the device is supplied by USB cable or an external power supply then it can't boot because function exynos_power_init returns an error. Now this function returns 0 if battery is not connected.
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: Piotr Wilczek p.wilczek@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- board/samsung/trats/trats.c | 2 +- board/samsung/trats2/trats2.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index fec72d4..3dd340b 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -332,7 +332,7 @@ int exynos_power_init(void)
if (!p_chrg->chrg->chrg_bat_present(p_chrg)) { puts("No battery detected\n"); - return -1; + return 0; }
p_fg->fg->fg_battery_check(p_fg, p_bat); diff --git a/board/samsung/trats2/trats2.c b/board/samsung/trats2/trats2.c index e4987ce..fa26e61 100644 --- a/board/samsung/trats2/trats2.c +++ b/board/samsung/trats2/trats2.c @@ -214,7 +214,7 @@ int exynos_power_init(void)
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Minkyu Kang
Przemyslaw Marczak
