[U-Boot] [Patch V4 0/4] MIPS: add mips64 cpu support
This patch add mips64 cpu support. Changes in V4: - Add both big-endian and little-endian support - Remove cache probe - Add standalone support for mips64 Changes in V3: - merge related files into one patch, no longer one file one patch. - add detailed commit message. - remove standalone example. it's too complicate.
Zhizhou Zhang (4): MIPS: Add support for MIPS64 cpus MIPS: change related header files MIPS: add board qemu-mips64 support MIPS: add mips64 standalone support
arch/mips/cpu/mips64/Makefile | 46 +++++++ arch/mips/cpu/mips64/cache.S | 229 +++++++++++++++++++++++++++++++ arch/mips/cpu/mips64/config.mk | 40 ++++++ arch/mips/cpu/mips64/cpu.c | 111 +++++++++++++++ arch/mips/cpu/mips64/interrupts.c | 34 +++++ arch/mips/cpu/mips64/start.S | 256 +++++++++++++++++++++++++++++++++++ arch/mips/cpu/mips64/time.c | 87 ++++++++++++ arch/mips/include/asm/addrspace.h | 2 +- arch/mips/include/asm/io.h | 16 +++ arch/mips/include/asm/posix_types.h | 6 + board/qemu-mips/config.mk | 10 -- board/qemu-mips/u-boot.lds | 8 ++ boards.cfg | 2 + examples/standalone/mips64.lds | 59 ++++++++ include/configs/qemu-mips.h | 1 + include/configs/qemu-mips64.h | 179 ++++++++++++++++++++++++ 16 files changed, 1075 insertions(+), 11 deletions(-) create mode 100644 arch/mips/cpu/mips64/Makefile create mode 100644 arch/mips/cpu/mips64/cache.S create mode 100644 arch/mips/cpu/mips64/config.mk create mode 100644 arch/mips/cpu/mips64/cpu.c create mode 100644 arch/mips/cpu/mips64/interrupts.c create mode 100644 arch/mips/cpu/mips64/start.S create mode 100644 arch/mips/cpu/mips64/time.c delete mode 100644 board/qemu-mips/config.mk create mode 100644 examples/standalone/mips64.lds create mode 100644 include/configs/qemu-mips64.h
These files are derived from arch/mips/cpu/mips32/*. The main changes are: 1, changes ABI o32 to n64, 2, add mips64 build cflags.
Signed-off-by: Zhizhou Zhang etou.zh@gmail.com --- arch/mips/cpu/mips64/Makefile | 46 +++++++ arch/mips/cpu/mips64/cache.S | 229 +++++++++++++++++++++++++++++++++ arch/mips/cpu/mips64/config.mk | 40 ++++++ arch/mips/cpu/mips64/cpu.c | 111 ++++++++++++++++ arch/mips/cpu/mips64/interrupts.c | 34 +++++ arch/mips/cpu/mips64/start.S | 256 +++++++++++++++++++++++++++++++++++++ arch/mips/cpu/mips64/time.c | 87 +++++++++++++ 7 files changed, 803 insertions(+) create mode 100644 arch/mips/cpu/mips64/Makefile create mode 100644 arch/mips/cpu/mips64/cache.S create mode 100644 arch/mips/cpu/mips64/config.mk create mode 100644 arch/mips/cpu/mips64/cpu.c create mode 100644 arch/mips/cpu/mips64/interrupts.c create mode 100644 arch/mips/cpu/mips64/start.S create mode 100644 arch/mips/cpu/mips64/time.c
diff --git a/arch/mips/cpu/mips64/Makefile b/arch/mips/cpu/mips64/Makefile new file mode 100644 index 0000000..f4c88f5 --- /dev/null +++ b/arch/mips/cpu/mips64/Makefile @@ -0,0 +1,46 @@ +# +# (C) Copyright 2003-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(CPU).o + +START = start.o +COBJS-y = cpu.o interrupts.o time.o cache.o + +SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) +START := $(addprefix $(obj),$(START)) + +all: $(obj).depend $(START) $(LIB) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + diff --git a/arch/mips/cpu/mips64/cache.S b/arch/mips/cpu/mips64/cache.S new file mode 100644 index 0000000..ba7c1b8 --- /dev/null +++ b/arch/mips/cpu/mips64/cache.S @@ -0,0 +1,229 @@ +/* + * Cache-handling routined for MIPS CPUs + * + * Copyright (c) 2003 Wolfgang Denk wd@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm-offsets.h> +#include <config.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> +#include <asm/addrspace.h> +#include <asm/cacheops.h> + +#define RA t9 + +/* + * 16kB is the maximum size of instruction and data caches on MIPS 4K, + * 64kB is on 4KE, 24K, 5K, etc. Set bigger size for convenience. + * + * Note that the above size is the maximum size of primary cache. U-Boot + * doesn't have L2 cache support for now. + */ +#define MIPS_MAX_CACHE_SIZE 0x10000 + +#define INDEX_BASE CKSEG0 + + .macro cache_op op addr + .set push + .set noreorder + .set mips3 + cache \op, 0(\addr) + .set pop + .endm + + .macro f_fill64 dst, offset, val + LONG_S \val, (\offset + 0 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 1 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 2 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 3 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 4 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 5 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 6 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 7 * LONGSIZE)(\dst) +#if LONGSIZE == 4 + LONG_S \val, (\offset + 8 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 9 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 10 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 11 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 12 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 13 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 14 * LONGSIZE)(\dst) + LONG_S \val, (\offset + 15 * LONGSIZE)(\dst) +#endif + .endm + +/* + * mips_init_icache(uint PRId, ulong icache_size, unchar icache_linesz) + */ +LEAF(mips_init_icache) + blez a1, 9f + mtc0 zero, CP0_TAGLO + /* clear tag to invalidate */ + PTR_LI t0, INDEX_BASE + PTR_ADDU t1, t0, a1 +1: cache_op Index_Store_Tag_I t0 + PTR_ADDU t0, a2 + bne t0, t1, 1b + /* fill once, so data field parity is correct */ + PTR_LI t0, INDEX_BASE +2: cache_op Fill t0 + PTR_ADDU t0, a2 + bne t0, t1, 2b + /* invalidate again - prudent but not strictly neccessary */ + PTR_LI t0, INDEX_BASE +1: cache_op Index_Store_Tag_I t0 + PTR_ADDU t0, a2 + bne t0, t1, 1b +9: jr ra + END(mips_init_icache) + +/* + * mips_init_dcache(uint PRId, ulong dcache_size, unchar dcache_linesz) + */ +LEAF(mips_init_dcache) + blez a1, 9f + mtc0 zero, CP0_TAGLO + /* clear all tags */ + PTR_LI t0, INDEX_BASE + PTR_ADDU t1, t0, a1 +1: cache_op Index_Store_Tag_D t0 + PTR_ADDU t0, a2 + bne t0, t1, 1b + /* load from each line (in cached space) */ + PTR_LI t0, INDEX_BASE +2: LONG_L zero, 0(t0) + PTR_ADDU t0, a2 + bne t0, t1, 2b + /* clear all tags */ + PTR_LI t0, INDEX_BASE +1: cache_op Index_Store_Tag_D t0 + PTR_ADDU t0, a2 + bne t0, t1, 1b +9: jr ra + END(mips_init_dcache) + +/* + * mips_cache_reset - low level initialisation of the primary caches + * + * This routine initialises the primary caches to ensure that they have good + * parity. It must be called by the ROM before any cached locations are used + * to prevent the possibility of data with bad parity being written to memory. + * + * To initialise the instruction cache it is essential that a source of data + * with good parity is available. This routine will initialise an area of + * memory starting at location zero to be used as a source of parity. + * + * RETURNS: N/A + * + */ +NESTED(mips_cache_reset, 0, ra) + move RA, ra + li t2, CONFIG_SYS_ICACHE_SIZE + li t3, CONFIG_SYS_DCACHE_SIZE + li t8, CONFIG_SYS_CACHELINE_SIZE + + li v0, MIPS_MAX_CACHE_SIZE + + /* + * Now clear that much memory starting from zero. + */ + PTR_LI a0, CKSEG1 + PTR_ADDU a1, a0, v0 +2: PTR_ADDIU a0, 64 + f_fill64 a0, -64, zero + bne a0, a1, 2b + + /* + * The caches are probably in an indeterminate state, + * so we force good parity into them by doing an + * invalidate, load/fill, invalidate for each line. + */ + + /* + * Assume bottom of RAM will generate good parity for the cache. + */ + + /* + * Initialize the I-cache first, + */ + move a1, t2 + move a2, t8 + PTR_LA v1, mips_init_icache + jalr v1 + + /* + * then initialize D-cache. + */ + move a1, t3 + move a2, t8 + PTR_LA v1, mips_init_dcache + jalr v1 + + jr RA + END(mips_cache_reset) + +/* + * dcache_status - get cache status + * + * RETURNS: 0 - cache disabled; 1 - cache enabled + * + */ +LEAF(dcache_status) + mfc0 t0, CP0_CONFIG + li t1, CONF_CM_UNCACHED + andi t0, t0, CONF_CM_CMASK + move v0, zero + beq t0, t1, 2f + li v0, 1 +2: jr ra + END(dcache_status) + +/* + * dcache_disable - disable cache + * + * RETURNS: N/A + * + */ +LEAF(dcache_disable) + mfc0 t0, CP0_CONFIG + li t1, -8 + and t0, t0, t1 + ori t0, t0, CONF_CM_UNCACHED + mtc0 t0, CP0_CONFIG + jr ra + END(dcache_disable) + +/* + * dcache_enable - enable cache + * + * RETURNS: N/A + * + */ +LEAF(dcache_enable) + mfc0 t0, CP0_CONFIG + ori t0, CONF_CM_CMASK + xori t0, CONF_CM_CMASK + ori t0, CONF_CM_CACHABLE_NONCOHERENT + mtc0 t0, CP0_CONFIG + jr ra + END(dcache_enable) diff --git a/arch/mips/cpu/mips64/config.mk b/arch/mips/cpu/mips64/config.mk new file mode 100644 index 0000000..4fe6ea0 --- /dev/null +++ b/arch/mips/cpu/mips64/config.mk @@ -0,0 +1,40 @@ +# +# (C) Copyright 2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +# +# Default optimization level for MIPS64 +# +# Note: Toolchains with binutils prior to v2.16 +# are no longer supported by U-Boot MIPS tree! +# +MIPSFLAGS = -march=mips64 + +PLATFORM_CPPFLAGS += $(MIPSFLAGS) +PLATFORM_CPPFLAGS += -mabi=64 -DCONFIG_64BIT +ifdef CONFIG_SYS_BIG_ENDIAN +PLATFORM_LDFLAGS += -m elf64btsmip +else +PLATFORM_LDFLAGS += -m elf64ltsmip +endif + +CONFIG_STANDALONE_LOAD_ADDR ?= 0xFfffFfff80200000 -T mips64.lds diff --git a/arch/mips/cpu/mips64/cpu.c b/arch/mips/cpu/mips64/cpu.c new file mode 100644 index 0000000..c890e15 --- /dev/null +++ b/arch/mips/cpu/mips64/cpu.c @@ -0,0 +1,111 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <netdev.h> +#include <asm/mipsregs.h> +#include <asm/cacheops.h> +#include <asm/reboot.h> + +#define cache_op(op, addr) \ + __asm__ __volatile__( \ + " .set push \n" \ + " .set noreorder \n" \ + " .set mips64\n\t \n" \ + " cache %0, %1 \n" \ + " .set pop \n" \ + : \ + : "i" (op), "R" (*(unsigned char *)(addr))) + +void __attribute__((weak)) _machine_restart(void) +{ + fprintf(stderr, "*** reset failed ***\n"); + + while (1) + /* NOP */; +} + +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + _machine_restart(); + + return 0; +} + +void flush_cache(ulong start_addr, ulong size) +{ + unsigned long lsize = CONFIG_SYS_CACHELINE_SIZE; + unsigned long addr = start_addr & ~(lsize - 1); + unsigned long aend = (start_addr + size - 1) & ~(lsize - 1); + + /* aend will be miscalculated when size is zero, so we return here */ + if (size == 0) + return; + + while (1) { + cache_op(Hit_Writeback_Inv_D, addr); + cache_op(Hit_Invalidate_I, addr); + if (addr == aend) + break; + addr += lsize; + } +} + +void flush_dcache_range(ulong start_addr, ulong stop) +{ + unsigned long lsize = CONFIG_SYS_CACHELINE_SIZE; + unsigned long addr = start_addr & ~(lsize - 1); + unsigned long aend = (stop - 1) & ~(lsize - 1); + + while (1) { + cache_op(Hit_Writeback_Inv_D, addr); + if (addr == aend) + break; + addr += lsize; + } +} + +void invalidate_dcache_range(ulong start_addr, ulong stop) +{ + unsigned long lsize = CONFIG_SYS_CACHELINE_SIZE; + unsigned long addr = start_addr & ~(lsize - 1); + unsigned long aend = (stop - 1) & ~(lsize - 1); + + while (1) { + cache_op(Hit_Invalidate_D, addr); + if (addr == aend) + break; + addr += lsize; + } +} + +void write_one_tlb(int index, u32 pagemask, u32 hi, u32 low0, u32 low1) +{ + write_c0_entrylo0(low0); + write_c0_pagemask(pagemask); + write_c0_entrylo1(low1); + write_c0_entryhi(hi); + write_c0_index(index); + tlb_write_indexed(); +} diff --git a/arch/mips/cpu/mips64/interrupts.c b/arch/mips/cpu/mips64/interrupts.c new file mode 100644 index 0000000..e4e9aae --- /dev/null +++ b/arch/mips/cpu/mips64/interrupts.c @@ -0,0 +1,34 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mipsregs.h> + +void enable_interrupts(void) +{ +} + +int disable_interrupts(void) +{ + return 0; +} diff --git a/arch/mips/cpu/mips64/start.S b/arch/mips/cpu/mips64/start.S new file mode 100644 index 0000000..dc941b8 --- /dev/null +++ b/arch/mips/cpu/mips64/start.S @@ -0,0 +1,256 @@ +/* + * Startup Code for MIPS64 CPU-core + * + * Copyright (c) 2003 Wolfgang Denk wd@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any dlater version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICUdlaR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Pdlace, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm-offsets.h> +#include <config.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> + +#ifndef CONFIG_SYS_MIPS_CACHE_MODE +#define CONFIG_SYS_MIPS_CACHE_MODE CONF_CM_CACHABLE_NONCOHERENT +#endif + + /* + * For the moment disable interrupts, mark the kernel mode and + * set ST0_KX so that the CPU does not spit fire when using + * 64-bit addresses. + */ + .macro setup_c0_status set clr + .set push + mfc0 t0, CP0_STATUS + or t0, ST0_CU0 | \set | 0x1f | \clr + xor t0, 0x1f | \clr + mtc0 t0, CP0_STATUS + .set noreorder + sll zero, 3 # ehb + .set pop + .endm + + .set noreorder + + .globl _start + .text +_start: + .org 0x000 + b reset + nop + .org 0x080 + b romReserved + nop + .org 0x100 + b romReserved + nop + .org 0x180 + b romReserved + nop + .org 0x200 + b romReserved + nop + .org 0x280 + b romReserved + nop + .org 0x300 + b romReserved + nop + .org 0x380 + b romReserved + nop + .org 0x480 + b romReserved + nop + + /* + * We hope there are no more reserved vectors! + * 128 * 8 == 1024 == 0x400 + * so this is address R_VEC+0x400 == 0xbfc00400 + */ + .org 0x500 + .align 4 +reset: + + /* Clear watch registers */ + dmtc0 zero, CP0_WATCHLO + dmtc0 zero, CP0_WATCHHI + + /* WP(Watch Pending), SW0/1 should be cleared */ + mtc0 zero, CP0_CAUSE + + setup_c0_status ST0_KX 0 + + /* Init Timer */ + mtc0 zero, CP0_COUNT + mtc0 zero, CP0_COMPARE + +#ifndef CONFIG_SKIP_LOWLEVEL_INIT + /* CONFIG0 register */ + li t0, CONF_CM_UNCACHED + mtc0 t0, CP0_CONFIG +#endif + + /* Initialize $gp */ + bal 1f + nop + .dword _gp +1: + ld gp, 0(ra) + +#ifndef CONFIG_SKIP_LOWLEVEL_INIT + /* Initialize any external memory */ + dla t9, lowlevel_init + jalr t9 + nop + + /* Initialize caches... */ + dla t9, mips_cache_reset + jalr t9 + nop + + /* ... and enable them */ + li t0, CONFIG_SYS_MIPS_CACHE_MODE + mtc0 t0, CP0_CONFIG +#endif + + /* Set up temporary stack */ + li t0, CONFIG_SYS_SDRAM_BASE + CONFIG_SYS_INIT_SP_OFFSET + dla sp, 0(t0) + + dla t9, board_init_f + jr t9 + nop + +/* + * void relocate_code (addr_sp, gd, addr_moni) + * + * This "function" does not return, instead it continues in RAM + * after relocating the monitor code. + * + * a0 = addr_sp + * a1 = gd + * a2 = destination address + */ + .globl relocate_code + .ent relocate_code +relocate_code: + move sp, a0 # set new stack pointer + + li t0, CONFIG_SYS_MONITOR_BASE + dla t3, in_ram + ld t2, -24(t3) # t2 <-- uboot_end_data + move t1, a2 + move s2, a2 # s2 <-- destination address + + /* + * Fix $gp: + * + * New $gp = (Old $gp - CONFIG_SYS_MONITOR_BASE) + Destination Address + */ + move t8, gp + dsub gp, CONFIG_SYS_MONITOR_BASE + dadd gp, a2 # gp now adjusted + dsub s1, gp, t8 # s1 <-- relocation offset + + /* + * t0 = source address + * t1 = target address + * t2 = source end address + */ + + /* + * Save destination address and size for dlater usage in flush_cache() + */ + move s0, a1 # save gd in s0 + move a0, t1 # a0 <-- destination addr + dsub a1, t2, t0 # a1 <-- size + +1: + lw t3, 0(t0) + sw t3, 0(t1) + daddu t0, 4 + ble t0, t2, 1b + daddu t1, 4 + + /* If caches were enabled, we would have to flush them here. */ + + /* a0 & a1 are already set up for flush_cache(start, size) */ + dla t9, flush_cache + jalr t9 + nop + + /* Jump to where we've relocated ourselves */ + daddi t0, s2, in_ram - _start + jr t0 + nop + + .dword _gp + .dword _GLOBAL_OFFSET_TABLE_ + .dword uboot_end_data + .dword uboot_end + .dword num_got_entries + +in_ram: + /* + * Now we want to update GOT. + * + * GOT[0] is reserved. GOT[1] is also reserved for the dynamic object + * generated by GNU ld. Skip these reserved entries from relocation. + */ + ld t3, -8(t0) # t3 <-- num_got_entries + ld t8, -32(t0) # t8 <-- _GLOBAL_OFFSET_TABLE_ + ld t9, -40(t0) # t9 <-- _gp + dsub t8, t9 # compute offset + dadd t8, t8, gp # t8 now holds relocated _G_O_T_ + daddi t8, t8, 16 # skipping first two entries + li t2, 2 +1: + ld t1, 0(t8) + beqz t1, 2f + dadd t1, s1 + sd t1, 0(t8) +2: + daddi t2, 1 + blt t2, t3, 1b + daddi t8, 8 + + /* Clear BSS */ + ld t1, -24(t0) # t1 <-- uboot_end_data + ld t2, -16(t0) # t2 <-- uboot_end + dadd t1, s1 # adjust pointers + dadd t2, s1 + + dsub t1, 8 +1: + daddi t1, 8 + bltl t1, t2, 1b + sd zero, 0(t1) + + move a0, s0 # a0 <-- gd + dla t9, board_init_r + jr t9 + move a1, s2 + + .end relocate_code + + /* Exception handlers */ +romReserved: + b romReserved diff --git a/arch/mips/cpu/mips64/time.c b/arch/mips/cpu/mips64/time.c new file mode 100644 index 0000000..5154280 --- /dev/null +++ b/arch/mips/cpu/mips64/time.c @@ -0,0 +1,87 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mipsregs.h> + +static unsigned long timestamp; + +/* how many counter cycles in a jiffy */ +#define CYCLES_PER_JIFFY \ + (CONFIG_SYS_MIPS_TIMER_FREQ + CONFIG_SYS_HZ / 2) / CONFIG_SYS_HZ + +/* + * timer without interrupts + */ + +int timer_init(void) +{ + /* Set up the timer for the first expiration. */ + timestamp = 0; + write_c0_compare(read_c0_count() + CYCLES_PER_JIFFY); + + return 0; +} + +ulong get_timer(ulong base) +{ + unsigned int count; + unsigned int expirelo = read_c0_compare(); + + /* Check to see if we have missed any timestamps. */ + count = read_c0_count(); + while ((count - expirelo) < 0x7fffffff) { + expirelo += CYCLES_PER_JIFFY; + timestamp++; + } + write_c0_compare(expirelo); + + return timestamp - base; +} + +void __udelay(unsigned long usec) +{ + unsigned int tmo; + + tmo = read_c0_count() + (usec * (CONFIG_SYS_MIPS_TIMER_FREQ / 1000000)); + while ((tmo - read_c0_count()) < 0x7fffffff) + /*NOP*/; +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On MIPS it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On MIPS it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + return CONFIG_SYS_HZ; +}
The most important difference between mips32 and mips64 is the address space. This patch solve This problem.
Signed-off-by: Zhizhou Zhang etou.zh@gmail.com --- arch/mips/include/asm/addrspace.h | 2 +- arch/mips/include/asm/io.h | 16 ++++++++++++++++ arch/mips/include/asm/posix_types.h | 6 ++++++ 3 files changed, 23 insertions(+), 1 deletion(-)
diff --git a/arch/mips/include/asm/addrspace.h b/arch/mips/include/asm/addrspace.h index 3a1e6d6..b768bb5 100644 --- a/arch/mips/include/asm/addrspace.h +++ b/arch/mips/include/asm/addrspace.h @@ -136,7 +136,7 @@ cannot access physical memory directly from core */ #define UNCACHED_SDRAM(a) (((unsigned long)(a)) | 0x20000000) #else /* !CONFIG_SOC_AU1X00 */ -#define UNCACHED_SDRAM(a) KSEG1ADDR(a) +#define UNCACHED_SDRAM(a) CKSEG1ADDR(a) #endif /* CONFIG_SOC_AU1X00 */ #endif /* __ASSEMBLY__ */
diff --git a/arch/mips/include/asm/io.h b/arch/mips/include/asm/io.h index 025012a..80eab75 100644 --- a/arch/mips/include/asm/io.h +++ b/arch/mips/include/asm/io.h @@ -120,12 +120,20 @@ static inline void set_io_port_base(unsigned long base) */ extern inline phys_addr_t virt_to_phys(volatile void * address) { +#ifndef CONFIG_64BIT return CPHYSADDR(address); +#else + return XPHYSADDR(address); +#endif }
extern inline void * phys_to_virt(unsigned long address) { +#ifndef CONFIG_64BIT return (void *)KSEG0ADDR(address); +#else + return (void *)CKSEG0ADDR(address); +#endif }
/* @@ -133,12 +141,20 @@ extern inline void * phys_to_virt(unsigned long address) */ extern inline unsigned long virt_to_bus(volatile void * address) { +#ifndef CONFIG_64BIT return CPHYSADDR(address); +#else + return XPHYSADDR(address); +#endif }
extern inline void * bus_to_virt(unsigned long address) { +#ifndef CONFIG_64BIT return (void *)KSEG0ADDR(address); +#else + return (void *)CKSEG0ADDR(address); +#endif }
/* diff --git a/arch/mips/include/asm/posix_types.h b/arch/mips/include/asm/posix_types.h index 879aae2..1164652 100644 --- a/arch/mips/include/asm/posix_types.h +++ b/arch/mips/include/asm/posix_types.h @@ -24,9 +24,15 @@ typedef int __kernel_pid_t; typedef int __kernel_ipc_pid_t; typedef int __kernel_uid_t; typedef int __kernel_gid_t; +#ifndef CONFIG_MIPS64 typedef unsigned int __kernel_size_t; typedef int __kernel_ssize_t; typedef int __kernel_ptrdiff_t; +#else +typedef unsigned long __kernel_size_t; +typedef long __kernel_ssize_t; +typedef long __kernel_ptrdiff_t; +#endif typedef long __kernel_time_t; typedef long __kernel_suseconds_t; typedef long __kernel_clock_t;
Both big-endian and little-endian are tested with below commands: qemu-system-mips64el -M mips -cpu MIPS64R2-generic -kernel u-boot -nographic qemu-system-mips64 -M mips -cpu MIPS64R2-generic -kernel u-boot -nographic
Signed-off-by: Zhizhou Zhang etou.zh@gmail.com --- board/qemu-mips/u-boot.lds | 8 ++ boards.cfg | 2 + include/configs/qemu-mips64.h | 179 +++++++++++++++++++++++++++++++++++++++++ 3 files changed, 189 insertions(+) create mode 100644 include/configs/qemu-mips64.h
diff --git a/board/qemu-mips/u-boot.lds b/board/qemu-mips/u-boot.lds index 9460b20..4d9580f 100644 --- a/board/qemu-mips/u-boot.lds +++ b/board/qemu-mips/u-boot.lds @@ -24,7 +24,11 @@ /* OUTPUT_FORMAT("elf32-bigmips", "elf32-bigmips", "elf32-bigmips") */ +#if defined(CONFIG_64BIT) +OUTPUT_FORMAT("elf64-tradbigmips", "elf64-tradbigmips", "elf64-tradlittlemips") +#else OUTPUT_FORMAT("elf32-tradbigmips", "elf32-tradbigmips", "elf32-tradlittlemips") +#endif OUTPUT_ARCH(mips) ENTRY(_start) SECTIONS @@ -63,7 +67,11 @@ SECTIONS }
uboot_end_data = .; +#if defined(CONFIG_64BIT) + num_got_entries = (__got_end - __got_start) >> 3; +#else num_got_entries = (__got_end - __got_start) >> 2; +#endif
. = ALIGN(4); .sbss : { *(.sbss*) } diff --git a/boards.cfg b/boards.cfg index 6b54941..ff4bb0c 100644 --- a/boards.cfg +++ b/boards.cfg @@ -380,6 +380,8 @@ M5485HFE m68k mcf547x_8x m548xevb freescale - microblaze-generic microblaze microblaze microblaze-generic xilinx qemu_mips mips mips32 qemu-mips - - qemu-mips:SYS_BIG_ENDIAN qemu_mipsel mips mips32 qemu-mips - - qemu-mips:SYS_LITTLE_ENDIAN +qemu_mips64 mips mips64 qemu-mips - - qemu-mips64:SYS_BIG_ENDIAN +qemu_mips64el mips mips64 qemu-mips - - qemu-mips64:SYS_LITTLE_ENDIAN vct_platinum mips mips32 vct micronas - vct:VCT_PLATINUM vct_platinumavc mips mips32 vct micronas - vct:VCT_PLATINUMAVC vct_platinumavc_onenand mips mips32 vct micronas - vct:VCT_PLATINUMAVC,VCT_ONENAND diff --git a/include/configs/qemu-mips64.h b/include/configs/qemu-mips64.h new file mode 100644 index 0000000..c1962a0 --- /dev/null +++ b/include/configs/qemu-mips64.h @@ -0,0 +1,179 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * This file contains the configuration parameters for qemu-mips64 target. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_MIPS64 /* MIPS64 CPU core */ +#define CONFIG_QEMU_MIPS1 +#define CONFIG_MISC_INIT_R + +/*IP address is default used by Qemu*/ +#define CONFIG_IPADDR 10.0.2.15 /* Our IP address */ +#define CONFIG_SERVERIP 10.0.2.2 /* Server IP address */ + +#define CONFIG_BOOTDELAY 10 /* autoboot after 10 seconds */ + +#define CONFIG_BAUDRATE 115200 + +/* valid baudrates */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +#define CONFIG_TIMESTAMP /* Print image info with timestamp */ +#undef CONFIG_BOOTARGS + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "addmisc=setenv bootargs ${bootargs} " \ + "console=ttyS0,${baudrate} " \ + "panic=1\0" \ + "bootfile=/tftpboot/vmlinux\0" \ + "load=tftp ffffffff80500000 ${u-boot}\0" \ + "" + +#define CONFIG_BOOTCOMMAND "" + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#define CONFIG_DP83902A + +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#undef CONFIG_CMD_LOADB +#undef CONFIG_CMD_LOADS +#define CONFIG_CMD_DHCP + +#define CONFIG_DRIVER_NE2000 +#define CONFIG_DRIVER_NE2000_BASE (0xffffffffb4000300) + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK 115200 +#define CONFIG_SYS_NS16550_COM1 (0xffffffffb40003f8) +#define CONFIG_CONS_INDEX 1 + +#define CONFIG_CMD_IDE +#define CONFIG_DOS_PARTITION + +#define CONFIG_SYS_IDE_MAXBUS 2 +#define CONFIG_SYS_ATA_IDE0_OFFSET (0x1f0) +#define CONFIG_SYS_ATA_IDE1_OFFSET (0x170) +#define CONFIG_SYS_ATA_DATA_OFFSET (0) +#define CONFIG_SYS_ATA_REG_OFFSET (0) +#define CONFIG_SYS_ATA_BASE_ADDR (0xffffffffb4000000) + +#define CONFIG_SYS_IDE_MAXDEVICE (4) + +#define CONFIG_CMD_RARP + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ + +/* Monitor Command Prompt */ +#if defined(CONFIG_SYS_LITTLE_ENDIAN) +#define CONFIG_SYS_PROMPT "qemu-mips64el # " +#else +#define CONFIG_SYS_PROMPT "qemu-mips64 # " +#endif + +#define CONFIG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 256 +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +/* max number of command args */ +#define CONFIG_SYS_MAXARGS 16 + +#define CONFIG_SYS_MALLOC_LEN 128*1024 + +#define CONFIG_SYS_BOOTPARAMS_LEN 128*1024 + +#define CONFIG_SYS_MHZ 132 + +#define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) + +#define CONFIG_SYS_HZ 1000 + +/* Cached addr */ +#define CONFIG_SYS_SDRAM_BASE 0xffffffff80000000 + +/* default load address */ +#define CONFIG_SYS_LOAD_ADDR 0xffffffff81000000 + +#define CONFIG_SYS_MEMTEST_START 0xffffffff80100000 +#define CONFIG_SYS_MEMTEST_END 0xffffffff80800000 + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ +#define CONFIG_CMD_NO_FLASH +#define CONFIG_SYS_NO_FLASH +#undef CONFIG_CMD_IMLS + +/* The following #defines are needed to get flash environment right */ +#undef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE 0xffffffff80200000 /* RAM Version */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_INIT_SP_OFFSET 0x400000 +#define CONFIG_ENV_IS_NOWHERE 1 + +/* Address and size of Primary Environment Sector */ +#define CONFIG_ENV_SIZE 0x8000 + +#define CONFIG_ENV_OVERWRITE 1 + +#define MEM_SIZE 128 + +#undef CONFIG_MEMSIZE_IN_BYTES + +#define CONFIG_LZA + +/*----------------------------------------------------------------------- + * Cache Configuration + */ +#define CONFIG_SYS_DCACHE_SIZE 16384 +#define CONFIG_SYS_ICACHE_SIZE 16384 +#define CONFIG_SYS_CACHELINE_SIZE 32 + +#endif /* __CONFIG_H */
Move CONFIG_SYS_TEXT_BASE to the board specified header file. So change qemu-mips.h also. board/qemu-mips/config.mk is not used, then remove it.
Signed-off-by: Zhizhou Zhang etou.zh@gmail.com --- board/qemu-mips/config.mk | 10 ------- examples/standalone/mips64.lds | 59 ++++++++++++++++++++++++++++++++++++++++ include/configs/qemu-mips.h | 1 + 3 files changed, 60 insertions(+), 10 deletions(-) delete mode 100644 board/qemu-mips/config.mk create mode 100644 examples/standalone/mips64.lds
diff --git a/board/qemu-mips/config.mk b/board/qemu-mips/config.mk deleted file mode 100644 index 27cd34a..0000000 --- a/board/qemu-mips/config.mk +++ /dev/null @@ -1,10 +0,0 @@ -# -# Qemu -M mips system emulator -# See http://fabrice.bellard.free.fr/qemu -# - -# ROM version -CONFIG_SYS_TEXT_BASE = 0xbfc00000 - -# RAM version -#CONFIG_SYS_TEXT_BASE = 0x80001000 diff --git a/examples/standalone/mips64.lds b/examples/standalone/mips64.lds new file mode 100644 index 0000000..9b27ef4 --- /dev/null +++ b/examples/standalone/mips64.lds @@ -0,0 +1,59 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk Engineering, wd@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* +OUTPUT_FORMAT("elf32-bigmips", "elf32-bigmips", "elf32-bigmips") +*/ +OUTPUT_FORMAT("elf64-tradbigmips", "elf64-tradbigmips", "elf64-tradlittlemips") +OUTPUT_ARCH(mips) +SECTIONS +{ + .text : + { + *(.text*) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data*) } + + . = .; + _gp = ALIGN(16) + 0x7ff0; + + .got : { + __got_start = .; + *(.got) + __got_end = .; + } + + .sdata : { *(.sdata*) } + + . = ALIGN(4); + __bss_start = .; + .sbss (NOLOAD) : { *(.sbss*) } + .bss (NOLOAD) : { *(.bss*) . = ALIGN(4); } + + _end = .; +} diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index b8b9705..bab3fb1 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -137,6 +137,7 @@ */
/* The following #defines are needed to get flash environment right */ +#define CONFIG_SYS_TEXT_BASE 0xbfc00000 /* Rom version */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_MONITOR_LEN (192 << 10)
Dear Zhizhou Zhang,
Checkpatch reports a number of "unnecessary whitespace before a quoted newline" warnings; please fix these.
Please do not add trailing empty lines. Please fix globally.
As requested before: please don't mix upper and lower case letters in a number; use a consistent styile everywhere. PLease fix globally.
As requested before: please make sure your patches are bisectable. This references file mips64.lds, but doesn;t add it, so it cannot work.
- __asm__ __volatile__( \
- " .set push \n" \
- " .set noreorder \n" \
- " .set mips64\n\t \n" \
- " cache %0, %1 \n" \
- " .set pop \n" \
Fix checkpatch warnings here (and globally).
- while (1) {
We don't allow camel-case identifiers. Please fix globally.
Dear Wolfgang Denk,
On Sat, Sep 1, 2012 at 8:42 PM, Wolfgang Denk wd@denx.de wrote:
Dear Zhizhou Zhang,
are:
I'm a new learner, Please forgive my faults. So do you mean that we should can build u-boot on each submit? If it is, should I resend these patch?
" .set push \n" \
" .set pop \n" \
while (1) {
I thought these identifiers come from Linux Kernel and mips spec.
I will fix it as you command
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de If it has syntax, it isn't user friendly.
Dear Zhi-zhou Zhang,
In message CACFOYQmTwH-7SwnS_QgPcXMCZovbXhkJPJhJnFi92zXcZazVug@mail.gmail.com you wrote:
When running "git bisect", any commit may be selected for building, so it is essential that the code is at least compile clean for all commits. That means for example that you cannot add files in a later commit, because then any earlier commits which try to reference these would cause build errors.
Your patches need to be reorganized to make sure of this.
Dear Wolfgang,
2012/9/1 Wolfgang Denk wd@denx.de:
Dear Zhizhou Zhang,
while (1) {
those identifiers are from arch/mips/include/asm/cacheops.h which is imported from Linux like many other header files in U-Boot. Does it really make sense to fix the coding style of imported files?
According to http://www.denx.de/wiki/U-Boot/CodingStyle you allow exceptions: "Source files originating from different projects (for example the MTD subsystem or the hush shell code from the BusyBox project) may, after careful consideration, be exempted from these rules. For such files, the original coding style may be kept to ease subsequent migration to newer versions of those sources. "
Dear Zhizhou Zhang,
NAK. We don't allow static network settings in board config files. Please remove.
This makes no sense. Please fix or omit.
Please remove parens around simple numbers. Please fix globally.
Please don't define values for logical variables. Please fix globally.
Please don't undef what is not defined anyway.
Dear Zhizhou Zhang,
This patch appears to be too late in this patch series Either re-order and/or squash with other parts to ensure bisectability.
Dear Wolfgang Denk,
On Sat, Sep 1, 2012 at 8:48 PM, Wolfgang Denk wd@denx.de wrote:
Dear Zhizhou Zhang,
I'm sorry, I can't catch you. So what should I do now? Do you mean I
should resend these patch again?
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de If I ever needed a brain transplant, I'd choose a teenager's because I'd want a brain that had never been used.
In message CACFOYQ=x-8G27oznZMeY66y6Nrr54-tZFUSr8cwFvea05EdU-Q@mail.gmail.com you wrote:
I'm sorry, I can't catch you. So what should I do now? Do you mean I should
No. I already wrote what to do: please either re-order the patches so thatfiles get added before they are referenced, or squash with other parts so that they get added with the code that references them first.
Hi Zhizhou,
2012/8/27 Zhizhou Zhang etou.zh@gmail.com:
Changes in V3:
looks good now, thanks. I'll try to review and test it tonight (CEST time).
Dear Zhizhou Zhang,
Changes in V3:
Is there any specific reason why you post all patches _twice_? Please stop doing his.
Daniel Schwierzeck
Zhi-zhou Zhang
Zhizhou Zhang
