[U-Boot] [PATCH v2 0/7] Improvements for the dwc3_generic driver
This series aims at bringing improvements to the dwc3_generic driver so that it can be used by most of the platforms using the dwc3 controller. This series applies on top of the master branch of USB tree. It also also available on github: https://github.com/jjhiblot/u-boot/tree/dwc3_generic_v2
I tested this on with DRA7 and AM57x platforms for both Peripheral and Host operations. The code to enable DM USB host & dev support for those platforms will be submitted in a separate series.
Enhancements: - use separate Kconfig option for DM USB Periphal and DM USB Host. This allow platforms to keep their non-DM USB peripheral code and use the DM USB host. - fixes the bind/probe confusion in dwc3_generic. The probe is done when the USB device is first needed. - handles PHYs when in the peripheral mode. The code to handle the PHYs is shared with the host side - handles clock and reset - bind host controller to the more generic driver 'xhci-dwc3'
Changes in v2: - Updated commit log - Fixed typo in thordown.c - select DM_USB_DEV by default for zynqmp platforms
Jean-Jacques Hiblot (7): usb: gadget: Do not call board_usb_xxx() directly in USB gadget drivers usb: introduce a separate config option for DM USB device usb: udc: implement DM versions of usb_gadget_initialize()/_release()/_handle_interrupt() dwc3_generic: do not probe the USB device driver when it's bound dwc3: move phy operation to core.c dwc3-generic: Handle the PHYs, the clocks and the reset lines dwc3-generic: Add select_dr_mode operation
arch/arm/Kconfig | 2 + cmd/fastboot.c | 4 +- cmd/rockusb.c | 4 +- cmd/thordown.c | 4 +- cmd/usb_gadget_sdp.c | 4 +- cmd/usb_mass_storage.c | 4 +- common/dfu.c | 6 +- drivers/usb/Kconfig | 6 ++ drivers/usb/dwc3/Kconfig | 7 +- drivers/usb/dwc3/core.c | 86 +++++++++++++++- drivers/usb/dwc3/dwc3-generic.c | 207 +++++++++++++++++++++++++++++--------- drivers/usb/dwc3/ep0.c | 1 - drivers/usb/gadget/ether.c | 38 +------ drivers/usb/gadget/udc/udc-core.c | 44 +++++++- drivers/usb/host/xhci-dwc3.c | 93 ++--------------- include/dwc3-uboot.h | 7 ++ include/linux/usb/gadget.h | 18 ++++ 17 files changed, 351 insertions(+), 184 deletions(-)
Add 2 functions to wrap the calls to board_usb_init() and board_usb_cleanup(). This is a preparatory work for DM support for UDC drivers (DM_USB_DEV).
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com
cmd/fastboot.c | 4 ++-- cmd/rockusb.c | 4 ++-- cmd/thordown.c | 4 ++-- cmd/usb_gadget_sdp.c | 4 ++-- cmd/usb_mass_storage.c | 4 ++-- common/dfu.c | 6 +++--- drivers/usb/gadget/ether.c | 38 +++++--------------------------------- include/linux/usb/gadget.h | 10 ++++++++++ 8 files changed, 28 insertions(+), 46 deletions(-)
diff --git a/cmd/fastboot.c b/cmd/fastboot.c index a5ec5f4..93f97fd 100644 --- a/cmd/fastboot.c +++ b/cmd/fastboot.c @@ -24,7 +24,7 @@ static int do_fastboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) usb_controller = argv[1]; controller_index = simple_strtoul(usb_controller, NULL, 0);
- ret = board_usb_init(controller_index, USB_INIT_DEVICE); + ret = usb_gadget_initialize(controller_index); if (ret) { pr_err("USB init failed: %d", ret); return CMD_RET_FAILURE; @@ -55,7 +55,7 @@ static int do_fastboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) exit: g_dnl_unregister(); g_dnl_clear_detach(); - board_usb_cleanup(controller_index, USB_INIT_DEVICE); + usb_gadget_release(controller_index);
return ret; } diff --git a/cmd/rockusb.c b/cmd/rockusb.c index 8206643..e0c1480 100644 --- a/cmd/rockusb.c +++ b/cmd/rockusb.c @@ -33,7 +33,7 @@ static int do_rockusb(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) dev_index = simple_strtoul(devnum, NULL, 0); rockusb_dev_init(devtype, dev_index);
- ret = board_usb_init(controller_index, USB_INIT_DEVICE); + ret = usb_gadget_initialize(controller_index); if (ret) { printf("USB init failed: %d\n", ret); return CMD_RET_FAILURE; @@ -62,7 +62,7 @@ static int do_rockusb(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) exit: g_dnl_unregister(); g_dnl_clear_detach(); - board_usb_cleanup(controller_index, USB_INIT_DEVICE); + usb_gadget_release(controller_index);
return ret; } diff --git a/cmd/thordown.c b/cmd/thordown.c index e297de2..05f308a 100644 --- a/cmd/thordown.c +++ b/cmd/thordown.c @@ -30,7 +30,7 @@ int do_thor_down(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) goto done;
int controller_index = simple_strtoul(usb_controller, NULL, 0); - ret = board_usb_init(controller_index, USB_INIT_DEVICE); + ret = usb_gadget_initialize(controller_index); if (ret) { pr_err("USB init failed: %d", ret); ret = CMD_RET_FAILURE; @@ -55,7 +55,7 @@ int do_thor_down(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
exit: g_dnl_unregister(); - board_usb_cleanup(controller_index, USB_INIT_DEVICE); + usb_gadget_release(controller_index); done: dfu_free_entities();
diff --git a/cmd/usb_gadget_sdp.c b/cmd/usb_gadget_sdp.c index ba1f66a..808ed97 100644 --- a/cmd/usb_gadget_sdp.c +++ b/cmd/usb_gadget_sdp.c @@ -20,7 +20,7 @@ static int do_sdp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
char *usb_controller = argv[1]; int controller_index = simple_strtoul(usb_controller, NULL, 0); - board_usb_init(controller_index, USB_INIT_DEVICE); + usb_gadget_initialize(controller_index);
g_dnl_clear_detach(); g_dnl_register("usb_dnl_sdp"); @@ -37,7 +37,7 @@ static int do_sdp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
return ret; } diff --git a/cmd/usb_mass_storage.c b/cmd/usb_mass_storage.c index 89b9ddf..7c6d0c6 100644 --- a/cmd/usb_mass_storage.c +++ b/cmd/usb_mass_storage.c @@ -160,7 +160,7 @@ static int do_usb_mass_storage(cmd_tbl_t *cmdtp, int flag,
controller_index = (unsigned int)(simple_strtoul( usb_controller, NULL, 0)); - if (board_usb_init(controller_index, USB_INIT_DEVICE)) { + if (usb_gadget_initialize(controller_index)) { pr_err("Couldn't init USB controller."); rc = CMD_RET_FAILURE; goto cleanup_ums_init; @@ -231,7 +231,7 @@ static int do_usb_mass_storage(cmd_tbl_t *cmdtp, int flag, cleanup_register: g_dnl_unregister(); cleanup_board: - board_usb_cleanup(controller_index, USB_INIT_DEVICE); + usb_gadget_release(controller_index); cleanup_ums_init: ums_fini();
diff --git a/common/dfu.c b/common/dfu.c index 2620d32..44d1484 100644 --- a/common/dfu.c +++ b/common/dfu.c @@ -23,9 +23,9 @@ int run_usb_dnl_gadget(int usbctrl_index, char *usb_dnl_gadget) bool dfu_reset = false; int ret, i = 0;
- ret = board_usb_init(usbctrl_index, USB_INIT_DEVICE); + ret = usb_gadget_initialize(usbctrl_index); if (ret) { - pr_err("board usb init failed\n"); + pr_err("usb_gadget_initialize failed\n"); return CMD_RET_FAILURE; } g_dnl_clear_detach(); @@ -84,7 +84,7 @@ int run_usb_dnl_gadget(int usbctrl_index, char *usb_dnl_gadget) } exit: g_dnl_unregister(); - board_usb_cleanup(usbctrl_index, USB_INIT_DEVICE); + usb_gadget_release(usbctrl_index);
if (dfu_reset) do_reset(NULL, 0, 0, NULL); diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index 8ab9b9f..1c438c3 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -105,9 +105,6 @@ struct eth_dev { struct usb_gadget *gadget; struct usb_request *req; /* for control responses */ struct usb_request *stat_req; /* for cdc & rndis status */ -#ifdef CONFIG_DM_USB - struct udevice *usb_udev; -#endif
u8 config; struct usb_ep *in_ep, *out_ep, *status_ep; @@ -2341,40 +2338,17 @@ fail: }
/*-------------------------------------------------------------------------*/ - -#ifdef CONFIG_DM_USB -int dm_usb_init(struct eth_dev *e_dev) -{ - struct udevice *dev = NULL; - int ret; - - ret = uclass_first_device(UCLASS_USB_DEV_GENERIC, &dev); - if (!dev || ret) { - pr_err("No USB device found\n"); - return -ENODEV; - } - - e_dev->usb_udev = dev; - - return ret; -} -#endif - static int _usb_eth_init(struct ether_priv *priv) { struct eth_dev *dev = &priv->ethdev; struct usb_gadget *gadget; unsigned long ts; + int ret; unsigned long timeout = USB_CONNECT_TIMEOUT;
-#ifdef CONFIG_DM_USB - if (dm_usb_init(dev)) { - pr_err("USB ether not found\n"); - return -ENODEV; - } -#else - board_usb_init(0, USB_INIT_DEVICE); -#endif + ret = usb_gadget_initialize(0); + if (ret) + return ret;
/* Configure default mac-addresses for the USB ethernet device */ #ifdef CONFIG_USBNET_DEV_ADDR @@ -2546,9 +2520,7 @@ void _usb_eth_halt(struct ether_priv *priv) }
usb_gadget_unregister_driver(&priv->eth_driver); -#ifndef CONFIG_DM_USB - board_usb_cleanup(0, USB_INIT_DEVICE); -#endif + usb_gadget_release(0); }
#ifndef CONFIG_DM_ETH diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h index b824f13..40ca2d3 100644 --- a/include/linux/usb/gadget.h +++ b/include/linux/usb/gadget.h @@ -19,6 +19,7 @@ #define __LINUX_USB_GADGET_H
#include <errno.h> +#include <usb.h> #include <linux/compat.h> #include <linux/list.h>
@@ -926,4 +927,13 @@ extern void usb_ep_autoconfig_reset(struct usb_gadget *);
extern int usb_gadget_handle_interrupts(int index);
+static inline int usb_gadget_initialize(int index) +{ + return board_usb_init(index, USB_INIT_DEVICE); +} + +static inline int usb_gadget_release(int index) +{ + return board_usb_cleanup(index, USB_INIT_DEVICE); +} #endif /* __LINUX_USB_GADGET_H */
Hi Jean-Jacques,
Changes in v2:
- ret = usb_gadget_initialize(controller_index); if (ret) { pr_err("USB init failed: %d", ret); return CMD_RET_FAILURE;
return ret;
- ret = usb_gadget_initialize(controller_index); if (ret) { printf("USB init failed: %d\n", ret); return CMD_RET_FAILURE;
return ret;
- ret = usb_gadget_initialize(controller_index); if (ret) { pr_err("USB init failed: %d", ret); ret = CMD_RET_FAILURE;
@@ -55,7 +55,7 @@ int do_thor_down(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) exit: g_dnl_unregister();
- usb_gadget_release(controller_index);
diff --git a/cmd/usb_gadget_sdp.c b/cmd/usb_gadget_sdp.c index ba1f66a..808ed97 100644 --- a/cmd/usb_gadget_sdp.c +++ b/cmd/usb_gadget_sdp.c @@ -20,7 +20,7 @@ static int do_sdp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) char *usb_controller = argv[1]; int controller_index = simple_strtoul(usb_controller, NULL, 0);
@@ -37,7 +37,7 @@ static int do_sdp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) exit: g_dnl_unregister();
return ret;
} diff --git a/cmd/usb_mass_storage.c b/cmd/usb_mass_storage.c index 89b9ddf..7c6d0c6 100644 --- a/cmd/usb_mass_storage.c +++ b/cmd/usb_mass_storage.c @@ -160,7 +160,7 @@ static int do_usb_mass_storage(cmd_tbl_t *cmdtp, int flag, controller_index = (unsigned int)(simple_strtoul( usb_controller, NULL, 0));
- if (usb_gadget_initialize(controller_index)) { pr_err("Couldn't init USB controller."); rc = CMD_RET_FAILURE; goto cleanup_ums_init;
- ret = usb_gadget_initialize(usbctrl_index); if (ret) {
return CMD_RET_FAILURE; } g_dnl_clear_detach();pr_err("usb_gadget_initialize failed\n");
-#endif
- int ret;
return -ENODEV;
- return ret;
-} -#endif
- int ret; unsigned long timeout = USB_CONNECT_TIMEOUT;
return -ENODEV;
-#else
-#endif
if (ret)
return ret;
-#endif
- usb_gadget_release(0);
@@ -926,4 +927,13 @@ extern void usb_ep_autoconfig_reset(struct usb_gadget *); extern int usb_gadget_handle_interrupts(int index);
- return board_usb_init(index, USB_INIT_DEVICE);
- return board_usb_cleanup(index, USB_INIT_DEVICE);
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Using CONFIG_DM_USB for this purpose prevents using DM_USB for host and not for device.
Changes in v2: - select DM_USB_DEV by default for zynqmp platforms
arch/arm/Kconfig | 2 ++ drivers/usb/Kconfig | 6 ++++++ drivers/usb/dwc3/core.c | 2 +- drivers/usb/dwc3/dwc3-generic.c | 4 +++- 4 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 0d1802b..caf7053 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -841,6 +841,7 @@ config ARCH_ZYNQMP_R5 select DM select DM_SERIAL select CLK + imply DM_USB_DEV
config ARCH_ZYNQMP bool "Xilinx ZynqMP based platform" @@ -855,6 +856,7 @@ config ARCH_ZYNQMP select SPL_CLK if SPL select DM_USB if USB imply FAT_WRITE + imply DM_USB_DEV
config TEGRA bool "NVIDIA Tegra" diff --git a/drivers/usb/Kconfig b/drivers/usb/Kconfig index 4fbe172..3587ba4 100644 --- a/drivers/usb/Kconfig +++ b/drivers/usb/Kconfig @@ -47,6 +47,12 @@ config DM_USB declared with the U_BOOT_USB_DEVICE() macro and will be automatically probed when found on the bus.
+config DM_USB_DEV + bool "Enable driver model for USB (Peripheral mode)" + depends on DM_USB + help + Enable driver model for USB (Peripheral mode). + source "drivers/usb/host/Kconfig"
source "drivers/usb/dwc3/Kconfig" diff --git a/drivers/usb/dwc3/core.c b/drivers/usb/dwc3/core.c index 1ab5cee..d5ee6d9 100644 --- a/drivers/usb/dwc3/core.c +++ b/drivers/usb/dwc3/core.c @@ -789,7 +789,7 @@ MODULE_AUTHOR("Felipe Balbi balbi@ti.com"); MODULE_LICENSE("GPL v2"); MODULE_DESCRIPTION("DesignWare USB3 DRD Controller Driver");
-#ifdef CONFIG_DM_USB +#ifdef CONFIG_DM_USB_DEV
int dwc3_init(struct dwc3 *dwc) { diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index ca63eac..2c1e696 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -21,7 +21,7 @@ #include "gadget.h" #include "linux-compat.h"
-DECLARE_GLOBAL_DATA_PTR; +#ifdef CONFIG_DM_USB_DEV
int usb_gadget_handle_interrupts(int index) { @@ -98,6 +98,8 @@ U_BOOT_DRIVER(dwc3_generic_peripheral) = { .flags = DM_FLAG_ALLOC_PRIV_DMA, };
+#endif + static int dwc3_generic_bind(struct udevice *parent) { const void *fdt = gd->fdt_blob;
Hi Jean-Jacques,
Changes in v2:
- imply DM_USB_DEV
- imply DM_USB_DEV
+config DM_USB_DEV
- bool "Enable driver model for USB (Peripheral mode)"
- depends on DM_USB
- help
Lukasz Majewski
When DM_USB_DEV the platform code for the USB device must be replaced by calls to a USB device driver.
usb_gadget_initialize() probes the USB device driver. usb_gadget_release() removes the USB device driver.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Reviewed-by: Lukasz Majewski lukma@denx.de ---
Changes in v2: None
drivers/usb/dwc3/dwc3-generic.c | 14 ++----------- drivers/usb/gadget/udc/udc-core.c | 44 ++++++++++++++++++++++++++++++++++++++- include/linux/usb/gadget.h | 8 +++++++ 3 files changed, 53 insertions(+), 13 deletions(-)
diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index 2c1e696..43e97be 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -23,19 +23,9 @@
-int usb_gadget_handle_interrupts(int index) +int dm_usb_gadget_handle_interrupts(struct udevice *dev) { - struct dwc3 *priv; - struct udevice *dev; - int ret; - - ret = uclass_first_device(UCLASS_USB_DEV_GENERIC, &dev); - if (!dev || ret) { - pr_err("No USB device found\n"); - return -ENODEV; - } - - priv = dev_get_priv(dev); + struct dwc3 *priv = dev_get_priv(dev);
dwc3_gadget_uboot_handle_interrupt(priv);
diff --git a/drivers/usb/gadget/udc/udc-core.c b/drivers/usb/gadget/udc/udc-core.c index f5c30dd..42c9ea9 100644 --- a/drivers/usb/gadget/udc/udc-core.c +++ b/drivers/usb/gadget/udc/udc-core.c @@ -18,7 +18,8 @@ #include <asm/cache.h> #include <asm/dma-mapping.h> #include <common.h> - +#include <dm.h> +#include <dm/device-internal.h> #include <linux/usb/ch9.h> #include <linux/usb/gadget.h>
@@ -351,3 +352,44 @@ EXPORT_SYMBOL_GPL(usb_gadget_unregister_driver); MODULE_DESCRIPTION("UDC Framework"); MODULE_AUTHOR("Felipe Balbi balbi@ti.com"); MODULE_LICENSE("GPL v2"); + +#ifdef CONFIG_DM_USB_DEV +#define MAX_UDC_DEVICES 4 +static struct udevice *dev_array[MAX_UDC_DEVICES]; +int usb_gadget_initialize(int index) +{ + int ret; + struct udevice *dev = NULL; + + if (index < 0 || index >= ARRAY_SIZE(dev_array)) + return -EINVAL; + if (dev_array[index]) + return 0; + ret = uclass_get_device(UCLASS_USB_DEV_GENERIC, index, &dev); + if (!dev || ret) { + pr_err("No USB device found\n"); + return -ENODEV; + } + dev_array[index] = dev; + return 0; +} + +int usb_gadget_release(int index) +{ + int ret; + + if (index < 0 || index >= ARRAY_SIZE(dev_array)) + return -EINVAL; + ret = device_remove(dev_array[index], DM_REMOVE_NORMAL); + if (!ret) + dev_array[index] = NULL; + return ret; +} + +int usb_gadget_handle_interrupts(int index) +{ + if (index < 0 || index >= ARRAY_SIZE(dev_array)) + return -EINVAL; + return dm_usb_gadget_handle_interrupts(dev_array[index]); +} +#endif diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h index 40ca2d3..a094e31 100644 --- a/include/linux/usb/gadget.h +++ b/include/linux/usb/gadget.h @@ -927,6 +927,12 @@ extern void usb_ep_autoconfig_reset(struct usb_gadget *);
+#ifdef CONFIG_DM_USB_DEV +int usb_gadget_initialize(int index); +int usb_gadget_release(int index); +int dm_usb_gadget_handle_interrupts(struct udevice *dev); +#else +#include <usb.h> static inline int usb_gadget_initialize(int index) { return board_usb_init(index, USB_INIT_DEVICE); @@ -936,4 +942,6 @@ static inline int usb_gadget_release(int index) { return board_usb_cleanup(index, USB_INIT_DEVICE); } +#endif + #endif /* __LINUX_USB_GADGET_H */
The driver will be probed when usb_gadget_initialize() is called.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com ---
Changes in v2: None
drivers/usb/dwc3/dwc3-generic.c | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index 43e97be..3ec0c0e 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -71,21 +71,14 @@ static int dwc3_generic_peripheral_ofdata_to_platdata(struct udevice *dev) return 0; }
-static int dwc3_generic_peripheral_bind(struct udevice *dev) -{ - return device_probe(dev); -} - U_BOOT_DRIVER(dwc3_generic_peripheral) = { .name = "dwc3-generic-peripheral", .id = UCLASS_USB_DEV_GENERIC, .ofdata_to_platdata = dwc3_generic_peripheral_ofdata_to_platdata, .probe = dwc3_generic_peripheral_probe, .remove = dwc3_generic_peripheral_remove, - .bind = dwc3_generic_peripheral_bind, .platdata_auto_alloc_size = sizeof(struct usb_platdata), .priv_auto_alloc_size = sizeof(struct dwc3), - .flags = DM_FLAG_ALLOC_PRIV_DMA, };
#endif
Those operations can be used for peripheral operation as well as host operation.
Changes in v2: None
drivers/usb/dwc3/core.c | 88 ++++++++++++++++++++++++++++++++++++++++- drivers/usb/dwc3/ep0.c | 1 - drivers/usb/host/xhci-dwc3.c | 93 +++----------------------------------------- include/dwc3-uboot.h | 7 ++++ 4 files changed, 99 insertions(+), 90 deletions(-)
diff --git a/drivers/usb/dwc3/core.c b/drivers/usb/dwc3/core.c index d5ee6d9..538c603 100644 --- a/drivers/usb/dwc3/core.c +++ b/drivers/usb/dwc3/core.c @@ -19,7 +19,7 @@ #include <asm/dma-mapping.h> #include <linux/ioport.h> #include <dm.h> - +#include <generic-phy.h> #include <linux/usb/ch9.h> #include <linux/usb/gadget.h>
@@ -789,8 +789,92 @@ MODULE_AUTHOR("Felipe Balbi balbi@ti.com"); MODULE_LICENSE("GPL v2"); MODULE_DESCRIPTION("DesignWare USB3 DRD Controller Driver");
-#ifdef CONFIG_DM_USB_DEV +#ifdef CONFIG_DM_USB +int dwc3_setup_phy(struct udevice *dev, struct phy **array, int *num_phys) +{ + int i, ret, count; + struct phy *usb_phys; + + /* Return if no phy declared */ + if (!dev_read_prop(dev, "phys", NULL)) + return 0; + + count = dev_count_phandle_with_args(dev, "phys", "#phy-cells"); + if (count <= 0) + return count; + + usb_phys = devm_kcalloc(dev, count, sizeof(struct phy), + GFP_KERNEL); + if (!usb_phys) + return -ENOMEM; + + for (i = 0; i < count; i++) { + ret = generic_phy_get_by_index(dev, i, &usb_phys[i]); + if (ret && ret != -ENOENT) { + pr_err("Failed to get USB PHY%d for %s\n", + i, dev->name); + return ret; + } + } + + for (i = 0; i < count; i++) { + ret = generic_phy_init(&usb_phys[i]); + if (ret) { + pr_err("Can't init USB PHY%d for %s\n", + i, dev->name); + goto phys_init_err; + } + } + + for (i = 0; i < count; i++) { + ret = generic_phy_power_on(&usb_phys[i]); + if (ret) { + pr_err("Can't power USB PHY%d for %s\n", + i, dev->name); + goto phys_poweron_err; + } + } + + *num_phys = count; + return 0;
+phys_poweron_err: + for (i = count - 1; i >= 0; i--) + generic_phy_power_off(&usb_phys[i]); + + for (i = 0; i < count; i++) + generic_phy_exit(&usb_phys[i]); + + return ret; + +phys_init_err: + for (; i >= 0; i--) + generic_phy_exit(&usb_phys[i]); + + return ret; +} + +int dwc3_shutdown_phy(struct udevice *dev, struct phy *usb_phys, int num_phys) +{ + int i, ret; + + for (i = 0; i < num_phys; i++) { + if (!generic_phy_valid(&usb_phys[i])) + continue; + + ret = generic_phy_power_off(&usb_phys[i]); + ret |= generic_phy_exit(&usb_phys[i]); + if (ret) { + pr_err("Can't shutdown USB PHY%d for %s\n", + i, dev->name); + } + } + + return 0; +} +#endif + +#ifdef CONFIG_DM_USB_DEV int dwc3_init(struct dwc3 *dwc) { int ret; diff --git a/drivers/usb/dwc3/ep0.c b/drivers/usb/dwc3/ep0.c index 4f68887..433e5f6 100644 --- a/drivers/usb/dwc3/ep0.c +++ b/drivers/usb/dwc3/ep0.c @@ -19,7 +19,6 @@ #include <linux/usb/ch9.h> #include <linux/usb/gadget.h> #include <linux/usb/composite.h> - #include "core.h" #include "gadget.h" #include "io.h" diff --git a/drivers/usb/host/xhci-dwc3.c b/drivers/usb/host/xhci-dwc3.c index 80754d7..052e704 100644 --- a/drivers/usb/host/xhci-dwc3.c +++ b/drivers/usb/host/xhci-dwc3.c @@ -12,6 +12,7 @@ #include <fdtdec.h> #include <generic-phy.h> #include <usb.h> +#include <dwc3-uboot.h>
#include "xhci.h" #include <asm/io.h> @@ -110,104 +111,20 @@ void dwc3_set_fladj(struct dwc3 *dwc3_reg, u32 val) }
#ifdef CONFIG_DM_USB -static int xhci_dwc3_setup_phy(struct udevice *dev) -{ - struct xhci_dwc3_platdata *plat = dev_get_platdata(dev); - int i, ret, count; - - /* Return if no phy declared */ - if (!dev_read_prop(dev, "phys", NULL)) - return 0; - - count = dev_count_phandle_with_args(dev, "phys", "#phy-cells"); - if (count <= 0) - return count; - - plat->usb_phys = devm_kcalloc(dev, count, sizeof(struct phy), - GFP_KERNEL); - if (!plat->usb_phys) - return -ENOMEM; - - for (i = 0; i < count; i++) { - ret = generic_phy_get_by_index(dev, i, &plat->usb_phys[i]); - if (ret && ret != -ENOENT) { - pr_err("Failed to get USB PHY%d for %s\n", - i, dev->name); - return ret; - } - - ++plat->num_phys; - } - - for (i = 0; i < plat->num_phys; i++) { - ret = generic_phy_init(&plat->usb_phys[i]); - if (ret) { - pr_err("Can't init USB PHY%d for %s\n", - i, dev->name); - goto phys_init_err; - } - } - - for (i = 0; i < plat->num_phys; i++) { - ret = generic_phy_power_on(&plat->usb_phys[i]); - if (ret) { - pr_err("Can't power USB PHY%d for %s\n", - i, dev->name); - goto phys_poweron_err; - } - } - - return 0; - -phys_poweron_err: - for (; i >= 0; i--) - generic_phy_power_off(&plat->usb_phys[i]); - - for (i = 0; i < plat->num_phys; i++) - generic_phy_exit(&plat->usb_phys[i]); - - return ret; - -phys_init_err: - for (; i >= 0; i--) - generic_phy_exit(&plat->usb_phys[i]); - - return ret; -} - -static int xhci_dwc3_shutdown_phy(struct udevice *dev) -{ - struct xhci_dwc3_platdata *plat = dev_get_platdata(dev); - int i, ret; - - for (i = 0; i < plat->num_phys; i++) { - if (!generic_phy_valid(&plat->usb_phys[i])) - continue; - - ret = generic_phy_power_off(&plat->usb_phys[i]); - ret |= generic_phy_exit(&plat->usb_phys[i]); - if (ret) { - pr_err("Can't shutdown USB PHY%d for %s\n", - i, dev->name); - } - } - - return 0; -} - static int xhci_dwc3_probe(struct udevice *dev) { struct xhci_hcor *hcor; struct xhci_hccr *hccr; struct dwc3 *dwc3_reg; enum usb_dr_mode dr_mode; + struct xhci_dwc3_platdata *plat = dev_get_platdata(dev); int ret;
hccr = (struct xhci_hccr *)((uintptr_t)dev_read_addr(dev)); hcor = (struct xhci_hcor *)((uintptr_t)hccr + HC_LENGTH(xhci_readl(&(hccr)->cr_capbase)));
- ret = xhci_dwc3_setup_phy(dev); + ret = dwc3_setup_phy(dev, &plat->usb_phys, &plat->num_phys); if (ret) return ret;
@@ -227,7 +144,9 @@ static int xhci_dwc3_probe(struct udevice *dev)
static int xhci_dwc3_remove(struct udevice *dev) { - xhci_dwc3_shutdown_phy(dev); + struct xhci_dwc3_platdata *plat = dev_get_platdata(dev); + + dwc3_shutdown_phy(dev, plat->usb_phys, plat->num_phys);
return xhci_deregister(dev); } diff --git a/include/dwc3-uboot.h b/include/dwc3-uboot.h index 228ab3b..a2da081 100644 --- a/include/dwc3-uboot.h +++ b/include/dwc3-uboot.h @@ -38,4 +38,11 @@ struct dwc3_device { int dwc3_uboot_init(struct dwc3_device *dev); void dwc3_uboot_exit(int index); void dwc3_uboot_handle_interrupt(int index); + +#ifdef CONFIG_DM_USB +struct phy; +int dwc3_setup_phy(struct udevice *dev, struct phy **array, int *num_phys); +int dwc3_shutdown_phy(struct udevice *dev, struct phy *usb_phys, int num_phys); +#endif + #endif /* __DWC3_UBOOT_H_ */
This make the driver more generic. At this point this driver can replace the dwc3-of-simple implementation. Make the description in the Kconfig more generic too.
Changes in v2: None
drivers/usb/dwc3/Kconfig | 7 +- drivers/usb/dwc3/dwc3-generic.c | 160 +++++++++++++++++++++++++++++++++------- 2 files changed, 137 insertions(+), 30 deletions(-)
diff --git a/drivers/usb/dwc3/Kconfig b/drivers/usb/dwc3/Kconfig index 943b763..bbd8105 100644 --- a/drivers/usb/dwc3/Kconfig +++ b/drivers/usb/dwc3/Kconfig @@ -38,10 +38,11 @@ config USB_DWC3_OMAP Say 'Y' here if you have one such device
config USB_DWC3_GENERIC - bool "Xilinx ZynqMP and similar Platforms" - depends on DM_USB && USB_DWC3 + bool "Generic implementation of a DWC3 wrapper (aka dwc3 glue)" + depends on DM_USB && USB_DWC3 && MISC help - Some platforms can reuse this DWC3 generic implementation. + Select this for Xilinx ZynqMP and similar Platforms. + This wrapper supports Host and Peripheral operation modes.
config USB_DWC3_UNIPHIER bool "DesignWare USB3 Host Support on UniPhier Platforms" diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index 3ec0c0e..2c27dbc 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -11,59 +11,86 @@ #include <dm.h> #include <dm/device-internal.h> #include <dm/lists.h> -#include <linux/usb/otg.h> -#include <linux/compat.h> +#include <dwc3-uboot.h> #include <linux/usb/ch9.h> #include <linux/usb/gadget.h> #include <malloc.h> #include <usb.h> #include "core.h" #include "gadget.h" -#include "linux-compat.h" +#include <reset.h> +#include <clk.h>
+struct dwc3_generic_peripheral { + struct dwc3 dwc3; + struct phy *phys; + int num_phys; + fdt_addr_t base; +}; + int dm_usb_gadget_handle_interrupts(struct udevice *dev) { - struct dwc3 *priv = dev_get_priv(dev); + struct dwc3_generic_peripheral *priv = dev_get_priv(dev); + struct dwc3 *dwc3 = &priv->dwc3;
- dwc3_gadget_uboot_handle_interrupt(priv); + dwc3_gadget_uboot_handle_interrupt(dwc3);
return 0; }
static int dwc3_generic_peripheral_probe(struct udevice *dev) { - struct dwc3 *priv = dev_get_priv(dev); + int rc; + struct dwc3_generic_peripheral *priv = dev_get_priv(dev); + struct dwc3 *dwc3 = &priv->dwc3; + + rc = dwc3_setup_phy(dev, &priv->phys, &priv->num_phys); + if (rc) + return rc; + + dwc3->regs = map_physmem(priv->base, DWC3_OTG_REGS_END, MAP_NOCACHE); + dwc3->regs += DWC3_GLOBALS_REGS_START; + dwc3->dev = dev; + + rc = dwc3_init(dwc3); + if (rc) { + unmap_physmem(dwc3->regs, MAP_NOCACHE); + return rc; + }
- return dwc3_init(priv); + return 0; }
static int dwc3_generic_peripheral_remove(struct udevice *dev) { - struct dwc3 *priv = dev_get_priv(dev); + struct dwc3_generic_peripheral *priv = dev_get_priv(dev); + struct dwc3 *dwc3 = &priv->dwc3;
- dwc3_remove(priv); + dwc3_remove(dwc3); + dwc3_shutdown_phy(dev, priv->phys, priv->num_phys); + unmap_physmem(dwc3->regs, MAP_NOCACHE);
return 0; }
static int dwc3_generic_peripheral_ofdata_to_platdata(struct udevice *dev) { - struct dwc3 *priv = dev_get_priv(dev); + struct dwc3_generic_peripheral *priv = dev_get_priv(dev); + struct dwc3 *dwc3 = &priv->dwc3; int node = dev_of_offset(dev);
- priv->regs = (void *)devfdt_get_addr(dev); - priv->regs += DWC3_GLOBALS_REGS_START; + priv->base = devfdt_get_addr(dev);
- priv->maximum_speed = usb_get_maximum_speed(node); - if (priv->maximum_speed == USB_SPEED_UNKNOWN) { + dwc3->maximum_speed = usb_get_maximum_speed(node); + if (dwc3->maximum_speed == USB_SPEED_UNKNOWN) { pr_err("Invalid usb maximum speed\n"); return -ENODEV; }
- priv->dr_mode = usb_get_dr_mode(node); - if (priv->dr_mode == USB_DR_MODE_UNKNOWN) { + dwc3->dr_mode = usb_get_dr_mode(node); + if (dwc3->dr_mode == USB_DR_MODE_UNKNOWN) { pr_err("Invalid usb mode setup\n"); return -ENODEV; } @@ -77,13 +104,16 @@ U_BOOT_DRIVER(dwc3_generic_peripheral) = { .ofdata_to_platdata = dwc3_generic_peripheral_ofdata_to_platdata, .probe = dwc3_generic_peripheral_probe, .remove = dwc3_generic_peripheral_remove, - .platdata_auto_alloc_size = sizeof(struct usb_platdata), - .priv_auto_alloc_size = sizeof(struct dwc3), + .priv_auto_alloc_size = sizeof(struct dwc3_generic_peripheral), }; - #endif
-static int dwc3_generic_bind(struct udevice *parent) +struct dwc3_glue_data { + struct clk_bulk clks; + struct reset_ctl_bulk resets; +}; + +static int dwc3_glue_bind(struct udevice *parent) { const void *fdt = gd->fdt_blob; int node; @@ -94,29 +124,32 @@ static int dwc3_generic_bind(struct udevice *parent) const char *name = fdt_get_name(fdt, node, NULL); enum usb_dr_mode dr_mode; struct udevice *dev; - const char *driver; + const char *driver = NULL;
debug("%s: subnode name: %s\n", __func__, name); - if (strncmp(name, "dwc3@", 4)) - continue;
switch (dr_mode) { case USB_DR_MODE_PERIPHERAL: case USB_DR_MODE_OTG: +#ifdef CONFIG_DM_USB_DEV debug("%s: dr_mode: OTG or Peripheral\n", __func__); driver = "dwc3-generic-peripheral"; +#endif break; case USB_DR_MODE_HOST: debug("%s: dr_mode: HOST\n", __func__); - driver = "dwc3-generic-host"; + driver = "xhci-dwc3"; break; default: debug("%s: unsupported dr_mode\n", __func__); return -ENODEV; };
+ if (!driver) + continue; + ret = device_bind_driver_to_node(parent, driver, name, offset_to_ofnode(node), &dev); if (ret) { @@ -129,7 +162,76 @@ static int dwc3_generic_bind(struct udevice *parent) return 0; }
-static const struct udevice_id dwc3_generic_ids[] = { +static int dwc3_glue_reset_init(struct udevice *dev, + struct dwc3_glue_data *glue) +{ + int ret; + + ret = reset_get_bulk(dev, &glue->resets); + if (ret == -ENOTSUPP) + return 0; + else if (ret) + return ret; + + ret = reset_deassert_bulk(&glue->resets); + if (ret) { + reset_release_bulk(&glue->resets); + return ret; + } + + return 0; +} + +static int dwc3_glue_clk_init(struct udevice *dev, + struct dwc3_glue_data *glue) +{ + int ret; + + ret = clk_get_bulk(dev, &glue->clks); + if (ret == -ENOSYS) + return 0; + if (ret) + return ret; + +#if CONFIG_IS_ENABLED(CLK) + ret = clk_enable_bulk(&glue->clks); + if (ret) { + clk_release_bulk(&glue->clks); + return ret; + } +#endif + + return 0; +} + +static int dwc3_glue_probe(struct udevice *dev) +{ + struct dwc3_glue_data *glue = dev_get_platdata(dev); + int ret; + + ret = dwc3_glue_clk_init(dev, glue); + if (ret) + return ret; + + ret = dwc3_glue_reset_init(dev, glue); + if (ret) + return ret; + + return 0; +} + +static int dwc3_glue_remove(struct udevice *dev) +{ + struct dwc3_glue_data *glue = dev_get_platdata(dev); + + reset_release_bulk(&glue->resets); + + clk_release_bulk(&glue->clks); + + return dm_scan_fdt_dev(dev); +} + +static const struct udevice_id dwc3_glue_ids[] = { { .compatible = "xlnx,zynqmp-dwc3" }, { } }; @@ -137,6 +239,10 @@ static const struct udevice_id dwc3_generic_ids[] = { U_BOOT_DRIVER(dwc3_generic_wrapper) = { .name = "dwc3-generic-wrapper", .id = UCLASS_MISC, - .of_match = dwc3_generic_ids, - .bind = dwc3_generic_bind, + .of_match = dwc3_glue_ids, + .bind = dwc3_glue_bind, + .probe = dwc3_glue_probe, + .remove = dwc3_glue_remove, + .platdata_auto_alloc_size = sizeof(struct dwc3_glue_data), + };
The select_dr_mode operation is executed when the glue driver is probed. The role of this optional function is to configure the operating mode of the controller at the glue level.
Changes in v2: None
drivers/usb/dwc3/dwc3-generic.c | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index 2c27dbc..169188c 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -8,6 +8,7 @@ */
#include <common.h> +#include <asm-generic/io.h> #include <dm.h> #include <dm/device-internal.h> #include <dm/lists.h> @@ -111,6 +112,12 @@ U_BOOT_DRIVER(dwc3_generic_peripheral) = { struct dwc3_glue_data { struct clk_bulk clks; struct reset_ctl_bulk resets; + fdt_addr_t regs; +}; + +struct dwc3_glue_ops { + void (*select_dr_mode)(struct udevice *dev, int index, + enum usb_dr_mode mode); };
static int dwc3_glue_bind(struct udevice *parent) @@ -206,9 +213,14 @@ static int dwc3_glue_clk_init(struct udevice *dev,
static int dwc3_glue_probe(struct udevice *dev) { + struct dwc3_glue_ops *ops = (struct dwc3_glue_ops *)dev_get_driver_data(dev); struct dwc3_glue_data *glue = dev_get_platdata(dev); + struct udevice *child = NULL; + int index = 0; int ret;
+ glue->regs = dev_read_addr(dev); + ret = dwc3_glue_clk_init(dev, glue); if (ret) return ret; @@ -217,6 +229,20 @@ static int dwc3_glue_probe(struct udevice *dev) if (ret) return ret;
+ ret = device_find_first_child(dev, &child); + if (ret) + return ret; + + while (child) { + enum usb_dr_mode dr_mode; + + dr_mode = usb_get_dr_mode(dev_of_offset(child)); + device_find_next_child(&child); + if (ops && ops->select_dr_mode) + ops->select_dr_mode(dev, index, dr_mode); + index++; + } + return 0; }
Enhancements:
Changes in v2:
I have tested it on zcu100 with usb stick, usb to ethernet converter and also dfu.
Tested-by: Michal Simek michal.simek@xilinx.com
Thanks, Michal
Hi Marek,
Do you plan to take this series or does it need some rework?
I'm hoping to build on it to support DM_USB on the TI platforms.
JJ
Enhancements:
Changes in v2:
Jean-Jacques Hiblot
Lukasz Majewski
Michal Simek
