[U-Boot] Add option to send files with y-modem protocol [from U-boot => to target host]
when a network connection is not available, U-Boot can load files via the serial port.
The U-Boot commands for loading files over the UART all have the same options.
Is it possible implement two way file transfer in xyzModem - use loady, loadb to send files from U-boot to target host?
So, by analogy with using loady to load files,
# Loading with the y-modem protocol board> loady [load address] [baud rate]
we will use 'sendy'to send files:
# Sending with the y-modem protocol from U-boot to target host
sendy [offset address] [size] [baud rate] or maybe sendy /path/to/file/we/want/to/transfer [baud rate]
And on target host we use Minicom, TeraTerm or Hyper Terminal to receive files. How to modify xuzModem.c, cmd_load.c for sending files?
B.Regards, Alex
Alex Rodriges
