[U-Boot] [PATCH] dm: core: Add dev_get_addr_ptr() to return a pointer to the reg address
On some platforms (e.g. x86), the return value of dev_get_addr() can't be assigned to a pointer type variable directly. As there might be a difference between the size of fdt_addr_t and the pointer type. On x86 for example, "fdt_addr_t" is 64bit but "void *" only 32bit. So assigning the register base directly in dev_get_addr() results in this compilation warning: warning: cast to pointer from integer of different size
This patch introduces the new function dev_get_addr_ptr() that returns a pointer to the 'reg' address that can be used by drivers in this case.
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org --- drivers/core/device.c | 5 +++++ include/dm/device.h | 10 ++++++++++ 2 files changed, 15 insertions(+)
diff --git a/drivers/core/device.c b/drivers/core/device.c index 269087a..1322991 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -673,6 +673,11 @@ fdt_addr_t dev_get_addr(struct udevice *dev) return dev_get_addr_index(dev, 0); }
+void *dev_get_addr_ptr(struct udevice *dev) +{ + return (void *)(uintptr_t)dev_get_addr_index(dev, 0); +} + bool device_has_children(struct udevice *dev) { return !list_empty(&dev->child_head); diff --git a/include/dm/device.h b/include/dm/device.h index dad7591..0bcbead 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -454,6 +454,16 @@ int device_find_next_child(struct udevice **devp); fdt_addr_t dev_get_addr(struct udevice *dev);
/** + * dev_get_addr_ptr() - Return pointer to the address of the reg property + * of a device + * + * @dev: Pointer to a device + * + * @return Pointer to addr + */ +void *dev_get_addr_ptr(struct udevice *dev); + +/** * dev_get_addr_index() - Get the indexed reg property of a device * * @dev: Pointer to a device
Hi Stefan,
Request below...
- dev_get_addr_ptr() - Return pointer to the address of the reg property
of a device
- @dev: Pointer to a device
- @return Pointer to addr
Please mention the error condition, e.g. ", or NULL if there is no such property"
- dev_get_addr_index() - Get the indexed reg property of a device
-- 2.8.1
Hi Stefan,
On 20 April 2016 at 10:10, Simon Glass sjg@chromium.org wrote:
Hi Stefan,
Request below...
of a device
I'd like to get this applied. If you like I can fix this when applying?
-- 2.8.1
Hi Simon,
On Sat, May 7, 2016 at 11:19 PM, Simon Glass sjg@chromium.org wrote:
Hi Stefan,
Hi Stefan,
Request below...
of a device
Looks this was already applied an in mainline. See 28027521be95d27fcb83669e09ce3563bb4dd977
Regards, Bin
Hi Bin,
On 7 May 2016 at 09:31, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Stefan,
Hi Stefan,
Request below...
of a device
OK thanks, not sure what happened there.
Hi Simon,
On 07.05.2016 17:33, Simon Glass wrote:
Hi Bin,
Hi Simon,
Hi Stefan,
Hi Stefan,
Request below...
- bool device_has_children(struct udevice *dev) { return !list_empty(&dev->child_head);
of a device
Yes, IIRC, Heiko applied it with the I2C DWC patches. I've also added the comment in the header, so this should hopefully be okay.
Thanks, Stefan
Bin Meng
Stefan Roese
