[PATCH v3] cmd: pxe: add support for FDT overlays
This adds support for specifying FDT overlays in an extlinux/pxelinux configuration file.
Without this, there is no simple way to apply overlays when the kernel and fdt is loaded by the pxe command.
This change adds the 'fdtoverlays' keyword for a label, supporting multiple overlay files to be applied on top of the fdt specified in the 'fdt' or 'devicetree' keyword.
Example: label linux kernel /Image fdt /soc-board.dtb fdtoverlays /soc-board-function.dtbo append console=ttyS0,115200 root=/dev/mmcblk0p2 rootwait
This code makes usage of a new variable called fdtoverlay_addr_r used to load the overlay files without overwritting anything important.
Cc: Tom Rini trini@konsulko.com Cc: Andre Heider a.heider@gmail.com Cc: Jernej Škrabec jernej.skrabec@siol.net Cc: Jonas Karlman jonas@kwiboo.se Tested-by: Jernej Škrabec jernej.skrabec@siol.net Reviewed-by: Jernej Škrabec jernej.skrabec@siol.net Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- Changes since v2: - fixed typo in commit log - fixed in README.pxe - added review & test tags from Jernej
cmd/pxe_utils.c | 103 ++++++++++++++++++++++++++++++++++++++++++++++++ cmd/pxe_utils.h | 1 + doc/README.pxe | 9 +++++ 3 files changed, 113 insertions(+)
diff --git a/cmd/pxe_utils.c b/cmd/pxe_utils.c index b9d9a5786c..3526a651d7 100644 --- a/cmd/pxe_utils.c +++ b/cmd/pxe_utils.c @@ -13,6 +13,8 @@ #include <mapmem.h> #include <lcd.h> #include <net.h> +#include <fdt_support.h> +#include <linux/libfdt.h> #include <linux/string.h> #include <linux/ctype.h> #include <errno.h> @@ -284,6 +286,9 @@ static void label_destroy(struct pxe_label *label) if (label->fdtdir) free(label->fdtdir);
+ if (label->fdtoverlays) + free(label->fdtoverlays); + free(label); }
@@ -332,6 +337,92 @@ static int label_localboot(struct pxe_label *label) return run_command_list(localcmd, strlen(localcmd), 0); }
+/* + * Loads fdt overlays specified in 'fdtoverlays'. + */ +#ifdef CONFIG_OF_LIBFDT_OVERLAY +static void label_boot_fdtoverlay(struct cmd_tbl *cmdtp, struct pxe_label *label) +{ + char *fdtoverlay = label->fdtoverlays; + struct fdt_header *working_fdt; + char *fdtoverlay_addr_env; + ulong fdtoverlay_addr; + ulong fdt_addr; + int err; + + /* Get the main fdt and map it */ + fdt_addr = simple_strtoul(env_get("fdt_addr_r"), NULL, 16); + working_fdt = map_sysmem(fdt_addr, 0); + err = fdt_check_header(working_fdt); + if (err) + return; + + /* Get the specific overlay loading address */ + fdtoverlay_addr_env = env_get("fdtoverlay_addr_r"); + if (!fdtoverlay_addr_env) { + printf("Invalid fdtoverlay_addr_r for loading overlays\n"); + return; + } + + fdtoverlay_addr = simple_strtoul(fdtoverlay_addr_env, NULL, 16); + + /* Cycle over the overlay files and apply them in order */ + do { + struct fdt_header *blob; + char *overlayfile; + char *end; + int len; + + /* Drop leading spaces */ + while (*fdtoverlay == ' ') + ++fdtoverlay; + + /* Copy a single filename if multiple provided */ + end = strstr(fdtoverlay, " "); + if (end) { + len = (int)(end - fdtoverlay); + overlayfile = malloc(len + 1); + strncpy(overlayfile, fdtoverlay, len); + overlayfile[len] = '\0'; + } else + overlayfile = fdtoverlay; + + if (!strlen(overlayfile)) + goto skip_overlay; + + /* Load overlay file */ + err = get_relfile_envaddr(cmdtp, overlayfile, + "fdtoverlay_addr_r"); + if (err < 0) { + printf("Failed loading overlay %s\n", overlayfile); + goto skip_overlay; + } + + /* Resize main fdt */ + fdt_shrink_to_minimum(working_fdt, 8192); + + blob = map_sysmem(fdtoverlay_addr, 0); + err = fdt_check_header(blob); + if (err) { + printf("Invalid overlay %s, skipping\n", + overlayfile); + goto skip_overlay; + } + + err = fdt_overlay_apply_verbose(working_fdt, blob); + if (err) { + printf("Failed to apply overlay %s, skipping\n", + overlayfile); + goto skip_overlay; + } + +skip_overlay: + if (end) + free(overlayfile); + } while ((fdtoverlay = strstr(fdtoverlay, " "))); +} +#endif + /* * Boot according to the contents of a pxe_label. * @@ -534,6 +625,11 @@ static int label_boot(struct cmd_tbl *cmdtp, struct pxe_label *label) goto cleanup; } } + +#ifdef CONFIG_OF_LIBFDT_OVERLAY + if (label->fdtoverlays) + label_boot_fdtoverlay(cmdtp, label); +#endif } else { bootm_argv[3] = NULL; } @@ -591,6 +687,7 @@ enum token_type { T_INCLUDE, T_FDT, T_FDTDIR, + T_FDTOVERLAYS, T_ONTIMEOUT, T_IPAPPEND, T_BACKGROUND, @@ -625,6 +722,7 @@ static const struct token keywords[] = { {"fdt", T_FDT}, {"devicetreedir", T_FDTDIR}, {"fdtdir", T_FDTDIR}, + {"fdtoverlays", T_FDTOVERLAYS}, {"ontimeout", T_ONTIMEOUT,}, {"ipappend", T_IPAPPEND,}, {"background", T_BACKGROUND,}, @@ -1057,6 +1155,11 @@ static int parse_label(char **c, struct pxe_menu *cfg) err = parse_sliteral(c, &label->fdtdir); break;
+ case T_FDTOVERLAYS: + if (!label->fdtoverlays) + err = parse_sliteral(c, &label->fdtoverlays); + break; + case T_LOCALBOOT: label->localboot = 1; err = parse_integer(c, &label->localboot_val); diff --git a/cmd/pxe_utils.h b/cmd/pxe_utils.h index 77d2588875..6af9523734 100644 --- a/cmd/pxe_utils.h +++ b/cmd/pxe_utils.h @@ -43,6 +43,7 @@ struct pxe_label { char *initrd; char *fdt; char *fdtdir; + char *fdtoverlays; int ipappend; int attempted; int localboot; diff --git a/doc/README.pxe b/doc/README.pxe index 42f913c61f..b67151ca51 100644 --- a/doc/README.pxe +++ b/doc/README.pxe @@ -89,6 +89,9 @@ pxe boot fdt_addr - the location of a fdt blob. 'fdt_addr' will be passed to bootm command if it is set and 'fdt_addr_r' is not passed to bootm command.
+ fdtoverlay_addr_r - location in RAM at which 'pxe boot' will temporarily store + fdt overlay(s) before applying them to the fdt blob stored at 'fdt_addr_r'. + pxe file format =============== The pxe file format is nearly a subset of the PXELINUX file format; see @@ -148,6 +151,12 @@ kernel <path> - if this label is chosen, use tftp to retrieve the kernel It useful for overlay selection in pxe file (see: doc/uImage.FIT/overlay-fdt-boot.txt)
+fdtoverlays <path> [...] - if this label is chosen, use tftp to retrieve the DT + overlay(s) at <path>. it will be temporarily stored at the + address indicated in the fdtoverlay_addr_r environment variable, + and then applied in the load order to the fdt blob stored at the + address indicated in the fdt_addr_r environment variable. + append <string> - use <string> as the kernel command line when booting this label.
Neil Armstrong
