[U-Boot-Users] Does u-boot handle packet fragmentation during TFTP?
I searched the archives and the docs and didn't see anything specific to fragmentation. I'm developing an LL TEMAC driver for u-boot on Xilinx boards and am seeing an issue.
If the TFTP server providing the kernel image is not fragmenting packets, I can transfer a kernel image fine. But if the TFTP server fragments packets I see problems. I'm sure it's a problem with my new driver, but wanted to make sure there's not any known issues with u-boot in this area.
Thanks,
John
Xilinx is looking for embedded Linux developers...
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
John Linn wrote:
I searched the archives and the docs and didn’t see anything specific to fragmentation. I’m developing an LL TEMAC driver for u-boot on Xilinx boards and am seeing an issue.
If the TFTP server providing the kernel image is not fragmenting packets, I can transfer a kernel image fine. But if the TFTP server fragments packets I see problems. I’m sure it’s a problem with my new driver, but wanted to make sure there’s not any known issues with u-boot in this area.
Thanks, John
The code says "no."
if (ip->ip_off & htons(0x1fff)) { /* Can't deal w/ fragments */ return;
That's too bad, bigger packets can help substantially with throughput on TFTP (throughput is hammered by latency with TFTP). Something to think about... doing simple reassembly (only handle in-sequence reassembly) is fairly simple.
Best regards, gvb
Jerry Van Baren
John Linn
