Re: [U-Boot] [RFC PATCH 1/2] dm: Add support for scsi/sata based devices
Hi Simon,
2016-09-08 15:57 GMT+02:00 Michal Simek michal.simek@xilinx.com:
All sata based drivers are bind and corresponding block device is created. Based on this find_scsi_device() is able to get back block device based on scsi_curr_dev pointer.
intr_scsi() is commented now but it can be replaced by calling find_scsi_device() and scsi_scan().
scsi_dev_desc[] is commented out but common/scsi.c heavily depends on it. That's why CONFIG_SYS_SCSI_MAX_DEVICE is hardcoded to 1 and symbol is reassigned to a block description allocated by uclass. There is only one block description by device now but it doesn't need to be correct when more devices are present.
scsi_bind() ensures corresponding block device creation. uclass post_probe (scsi_post_probe()) is doing low level init.
SCSI/SATA DM based drivers requires to have 64bit base address as the first entry in platform data structure to setup mmio_base.
Signed-off-by: Michal Simek michal.simek@xilinx.com
cmd/scsi.c | 38 ++++++++++++++++++++++++++++++++++++++ common/board_r.c | 4 ++-- common/scsi.c | 17 ++++++++++++++++- drivers/block/ahci-uclass.c | 38 ++++++++++++++++++++++++++++++++++++++ drivers/block/ahci.c | 30 ++++++++++++++++++++++-------- include/ahci.h | 2 +- include/sata.h | 3 +++ include/scsi.h | 15 ++++++++++++++- 8 files changed, 134 insertions(+), 13 deletions(-)
diff --git a/cmd/scsi.c b/cmd/scsi.c index 387ca1a262ab..dc1176610672 100644 --- a/cmd/scsi.c +++ b/cmd/scsi.c @@ -10,6 +10,7 @@ */ #include <common.h> #include <command.h> +#include <dm.h> #include <scsi.h>
static int scsi_curr_dev; /* current device */ @@ -25,6 +26,23 @@ int do_scsiboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) /*
- scsi command intepreter
*/ +#ifdef CONFIG_DM_SATA +struct udevice *find_scsi_device(int dev_num) +{
struct udevice *bdev;
int ret;
ret = blk_get_device(IF_TYPE_SCSI, dev_num, &bdev);
if (ret) {
printf("SCSI Device %d not found\n", dev_num);
return NULL;
return bdev;
+} +#endif
int do_scsi(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) { switch (argc) { @@ -35,7 +53,18 @@ int do_scsi(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) if (strncmp(argv[1], "res", 3) == 0) { printf("\nReset SCSI\n"); scsi_bus_reset();
+#if defined(CONFIG_DM_SATA)
bdev = find_scsi_device(scsi_curr_dev);
if (!bdev)
return CMD_RET_FAILURE;
scsi_scan(1, bdev);
+#else scsi_scan(1); +#endif return 0; } if (strncmp(argv[1], "inf", 3) == 0) { @@ -51,7 +80,16 @@ int do_scsi(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) return 0; } if (strncmp(argv[1], "scan", 4) == 0) { +#if defined(CONFIG_DM_SATA)
if (!bdev)
scsi_scan(1, bdev);
+#else scsi_scan(1); +#endif return 0; } if (strncmp(argv[1], "part", 4) == 0) { diff --git a/common/board_r.c b/common/board_r.c index d959ad3c6f90..f3ea457507de 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -620,7 +620,7 @@ static int initr_ambapp_print(void) } #endif
-#if defined(CONFIG_SCSI) +#if defined(CONFIG_SCSI) && !defined(CONFIG_DM_SATA) static int initr_scsi(void) { puts("SCSI: "); @@ -923,7 +923,7 @@ init_fnc_t init_sequence_r[] = { initr_ambapp_print, #endif #endif -#ifdef CONFIG_SCSI +#if defined(CONFIG_SCSI) && !defined(CONFIG_DM_SATA) INIT_FUNC_WATCHDOG_RESET initr_scsi, #endif diff --git a/common/scsi.c b/common/scsi.c index dbbf4043b22a..1726898b06e2 100644 --- a/common/scsi.c +++ b/common/scsi.c @@ -26,7 +26,7 @@ #define SCSI_VEND_ID 0x10b9 #define SCSI_DEV_ID 0x5288
-#elif !defined(CONFIG_SCSI_AHCI_PLAT) +#elif !defined(CONFIG_SCSI_AHCI_PLAT) && !defined(CONFIG_DM_SATA) #error no scsi device defined #endif #define SCSI_DEV_LIST {SCSI_VEND_ID, SCSI_DEV_ID} @@ -43,7 +43,13 @@ static int scsi_max_devs; /* number of highest available scsi device */
+#if !defined(CONFIG_DM_SATA) static struct blk_desc scsi_dev_desc[CONFIG_SYS_SCSI_MAX_DEVICE]; +#else +#undef CONFIG_SYS_SCSI_MAX_DEVICE +#define CONFIG_SYS_SCSI_MAX_DEVICE 1 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#endif
/* almost the maximum amount of the scsi_ext command.. */ #define SCSI_MAX_READ_BLK 0xFFFF @@ -160,6 +166,7 @@ static ulong scsi_read(struct blk_desc *block_dev, lbaint_t blknr, { #ifdef CONFIG_BLK struct blk_desc *block_dev = dev_get_uclass_platdata(dev);
struct blk_desc *scsi_dev_desc = block_dev;
#endif int device = block_dev->devnum; lbaint_t start, blks; @@ -235,6 +242,7 @@ static ulong scsi_write(struct blk_desc *block_dev, lbaint_t blknr, { #ifdef CONFIG_BLK struct blk_desc *block_dev = dev_get_uclass_platdata(dev);
#endif int device = block_dev->devnum; lbaint_t start, blks; @@ -462,13 +470,20 @@ void scsi_setup_test_unit_ready(ccb *pccb)
- (re)-scan the scsi bus and reports scsi device info
- to the user if mode = 1
*/ +#ifdef CONFIG_DM_SATA +void scsi_scan(int mode, struct udevice *bdev) +#else void scsi_scan(int mode) +#endif { unsigned char i, perq, modi, lun; lbaint_t capacity; unsigned long blksz; ccb *pccb = (ccb *)&tempccb;
struct blk_desc *scsi_dev_desc = dev_get_uclass_platdata(bdev);
+#endif if (mode == 1) printf("scanning bus for devices...\n"); for (i = 0; i < CONFIG_SYS_SCSI_MAX_DEVICE; i++) { diff --git a/drivers/block/ahci-uclass.c b/drivers/block/ahci-uclass.c index 7b8c32699f53..f25b1bd336ae 100644 --- a/drivers/block/ahci-uclass.c +++ b/drivers/block/ahci-uclass.c @@ -1,14 +1,52 @@ /*
- Copyright (c) 2015 Google, Inc
- Written by Simon Glass sjg@chromium.org
- Copyright (c) 2016 Xilinx, Inc
- Written by Michal Simek
#include <common.h> #include <dm.h> +#include <scsi.h>
+#if defined(CONFIG_DM_SATA) +int scsi_bind(struct udevice *dev) +{
struct blk_desc *bdesc;
int ret;
* FIXME - maybe loop over CONFIG_SYS_SCSI_MAX_SCSI_ID
* here to support more ports
ret = blk_create_devicef(dev, "scsi_blk", "blk", IF_TYPE_SCSI, -1,
512,
0, &bdev);
if (ret) {
printf("Cannot create block device\n");
return ret;
bdesc = dev_get_uclass_platdata(bdev);
debug("device %p, block device %p, block description %p\n",
dev, bdev, bdesc);
+static int scsi_post_probe(struct udevice *dev) +{
debug("%s: device %p\n", __func__, dev);
scsi_low_level_init(0, dev);
+} +#endif
UCLASS_DRIVER(ahci) = { .id = UCLASS_AHCI, .name = "ahci", +#if defined(CONFIG_DM_SATA)
.post_probe = scsi_post_probe,
+#endif }; diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index e3e783a74cfd..03a95179eaa4 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -168,7 +168,7 @@ int ahci_reset(void __iomem *base)
static int ahci_host_init(struct ahci_probe_ent *probe_ent) { -#ifndef CONFIG_SCSI_AHCI_PLAT +#if !defined(CONFIG_SCSI_AHCI_PLAT) && !defined(CONFIG_DM_SATA) # ifdef CONFIG_DM_PCI struct udevice *dev = probe_ent->dev; struct pci_child_platdata *pplat = dev_get_parent_platdata(dev); @@ -198,7 +198,7 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) writel(cap_save, mmio + HOST_CAP); writel_with_flush(0xf, mmio + HOST_PORTS_IMPL);
-#ifndef CONFIG_SCSI_AHCI_PLAT +#if !defined(CONFIG_SCSI_AHCI_PLAT) && !defined(CONFIG_DM_SATA) # ifdef CONFIG_DM_PCI if (pplat->vendor == PCI_VENDOR_ID_INTEL) { u16 tmp16; @@ -327,6 +327,7 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) writel(tmp | HOST_IRQ_EN, mmio + HOST_CTL); tmp = readl(mmio + HOST_CTL); debug("HOST_CTL 0x%x\n", tmp); +#if !defined(CONFIG_DM_SATA) #ifndef CONFIG_SCSI_AHCI_PLAT # ifdef CONFIG_DM_PCI dm_pci_read_config16(dev, PCI_COMMAND, &tmp16); @@ -338,14 +339,15 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) pci_write_config_word(pdev, PCI_COMMAND, tmp16); # endif #endif +#endif return 0; }
static void ahci_print_info(struct ahci_probe_ent *probe_ent) { -#ifndef CONFIG_SCSI_AHCI_PLAT -# ifdef CONFIG_DM_PCI +#if !defined(CONFIG_SCSI_AHCI_PLAT) && !defined(CONFIG_DM_SATA) +# if defined(CONFIG_DM_PCI) || defined(CONFIG_DM_SATA) struct udevice *dev = probe_ent->dev; # else pci_dev_t pdev = probe_ent->dev; @@ -372,7 +374,7 @@ static void ahci_print_info(struct ahci_probe_ent *probe_ent) else speed_s = "?";
-#ifdef CONFIG_SCSI_AHCI_PLAT +#if defined(CONFIG_SCSI_AHCI_PLAT) || defined(CONFIG_DM_SATA) scc_s = "SATA"; #else # ifdef CONFIG_DM_PCI @@ -424,13 +426,15 @@ static void ahci_print_info(struct ahci_probe_ent *probe_ent) }
#ifndef CONFIG_SCSI_AHCI_PLAT -# ifdef CONFIG_DM_PCI +# if defined(CONFIG_DM_PCI) || defined(CONFIG_DM_SATA) static int ahci_init_one(struct udevice *dev) # else static int ahci_init_one(pci_dev_t dev) # endif { +#if defined(CONFIG_DM_PCI) u16 vendor; +#endif int rc;
probe_ent = malloc(sizeof(struct ahci_probe_ent));
@@ -450,6 +454,7 @@ static int ahci_init_one(pci_dev_t dev) probe_ent->pio_mask = 0x1f; probe_ent->udma_mask = 0x7f; /*Fixme,assume to support UDMA6 */
+#if !defined(CONFIG_DM_SATA) #ifdef CONFIG_DM_PCI probe_ent->mmio_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_5, PCI_REGION_MEM); @@ -473,6 +478,10 @@ static int ahci_init_one(pci_dev_t dev) if (vendor == 0x197b) pci_write_config_byte(dev, 0x41, 0xa1); #endif +#else
struct scsi_platdata *plat = dev_get_platdata(dev);
probe_ent->mmio_base = (void *)plat->base;
debug("ahci mmio_base=0x%p\n", probe_ent->mmio_base); /* initialize adapter */
@@ -954,14 +963,17 @@ int scsi_exec(ccb *pccb)
+#if defined(CONFIG_DM_SATA) +void scsi_low_level_init(int busdevfunc, struct udevice *dev) +#else void scsi_low_level_init(int busdevfunc) +#endif { int i; u32 linkmap;
#ifndef CONFIG_SCSI_AHCI_PLAT -# ifdef CONFIG_DM_PCI +# if defined(CONFIG_DM_PCI) struct udevice *dev; int ret;
@@ -969,6 +981,8 @@ void scsi_low_level_init(int busdevfunc) if (ret) return; ahci_init_one(dev); +# elif defined(CONFIG_DM_SATA)
ahci_init_one(dev);
# else ahci_init_one(busdevfunc); # endif diff --git a/include/ahci.h b/include/ahci.h index a956c6ff5df7..e740273de804 100644 --- a/include/ahci.h +++ b/include/ahci.h @@ -145,7 +145,7 @@ struct ahci_ioports { };
struct ahci_probe_ent { -#ifdef CONFIG_DM_PCI +#if defined(CONFIG_DM_PCI) || defined(CONFIG_DM_SATA) struct udevice *dev; #else pci_dev_t dev; diff --git a/include/sata.h b/include/sata.h index b35359aa5a19..26c8de730399 100644 --- a/include/sata.h +++ b/include/sata.h @@ -2,6 +2,8 @@ #define __SATA_H__ #include <part.h>
int init_sata(int dev); int reset_sata(int dev); int scan_sata(int dev); @@ -15,5 +17,6 @@ int __sata_stop(void); int sata_port_status(int dev, int port);
extern struct blk_desc sata_dev_desc[]; +#endif
#endif diff --git a/include/scsi.h b/include/scsi.h index 7e3759140b34..22d6bd0d02a7 100644 --- a/include/scsi.h +++ b/include/scsi.h @@ -166,14 +166,27 @@ typedef struct SCSI_cmd_block{ void scsi_print_error(ccb *pccb); int scsi_exec(ccb *pccb); void scsi_bus_reset(void); +#if !defined(CONFIG_DM_SATA) void scsi_low_level_init(int busdevfunc);
+#else +void scsi_low_level_init(int busdevfunc, struct udevice *dev); +#endif
- functions residing inside cmd_scsi.c
*/ void scsi_init(void); +#if !defined(CONFIG_DM_SATA) void scsi_scan(int mode); +#else
+struct scsi_platdata {
unsigned long base;
+void scsi_scan(int mode, struct udevice *bdev); +int scsi_bind(struct udevice *dev); +#endif
/** @return the number of scsi disks */ int scsi_get_disk_count(void); -- 1.9.1
Can you please look at these patches?
Thanks, Michal
Michal Simek
