[U-Boot] [PATCH 1/2] at91: fixed at91sam9263 system file
Signed-off-by: Daniel Gorsulowski Daniel.Gorsulowski@esd.eu --- arch/arm/cpu/arm926ejs/at91/at91sam9263_devices.c | 55 +++++++-------------- 1 files changed, 18 insertions(+), 37 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/at91/at91sam9263_devices.c b/arch/arm/cpu/arm926ejs/at91/at91sam9263_devices.c index deda3e5..15e880a 100644 --- a/arch/arm/cpu/arm926ejs/at91/at91sam9263_devices.c +++ b/arch/arm/cpu/arm926ejs/at91/at91sam9263_devices.c @@ -3,7 +3,7 @@ * Stelian Pop stelian.pop@leadtechdesign.com * Lead Tech Design <www.leadtechdesign.com> * - * (C) Copyright 2009 + * (C) Copyright 2009-2011 * Daniel Gorsulowski daniel.gorsulowski@esd.eu * esd electronic system design gmbh <www.esd.eu> * @@ -27,78 +27,59 @@ */
#include <common.h> +#include <asm/io.h> #include <asm/arch/hardware.h> -#include <asm/arch/io.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_pio.h>
void at91_serial0_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTA, 26, 1); /* TXD0 */ at91_set_a_periph(AT91_PIO_PORTA, 27, 0); /* RXD0 */ - writel(1 << AT91SAM9263_ID_US0, &pmc->pcer); + writel(1 << ATMEL_ID_USART0, &pmc->pcer); }
void at91_serial1_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTD, 0, 1); /* TXD1 */ at91_set_a_periph(AT91_PIO_PORTD, 1, 0); /* RXD1 */ - writel(1 << AT91SAM9263_ID_US1, &pmc->pcer); + writel(1 << ATMEL_ID_USART1, &pmc->pcer); }
void at91_serial2_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTD, 2, 1); /* TXD2 */ at91_set_a_periph(AT91_PIO_PORTD, 3, 0); /* RXD2 */ - writel(1 << AT91SAM9263_ID_US2, &pmc->pcer); + writel(1 << ATMEL_ID_USART2, &pmc->pcer); }
-void at91_serial3_hw_init(void) +void at91_seriald_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTC, 30, 0); /* DRXD */ at91_set_a_periph(AT91_PIO_PORTC, 31, 1); /* DTXD */ - writel(1 << AT91_ID_SYS, &pmc->pcer); + writel(1 << ATMEL_ID_SYS, &pmc->pcer); }
-void at91_serial_hw_init(void) -{ -#ifdef CONFIG_USART0 - at91_serial0_hw_init(); -#endif - -#ifdef CONFIG_USART1 - at91_serial1_hw_init(); -#endif - -#ifdef CONFIG_USART2 - at91_serial2_hw_init(); -#endif - -#ifdef CONFIG_USART3 /* DBGU */ - at91_serial3_hw_init(); -#endif -} - -#ifdef CONFIG_HAS_DATAFLASH +#if defined(CONFIG_HAS_DATAFLASH) || defined(CONFIG_ATMEL_SPI) void at91_spi0_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_b_periph(AT91_PIO_PORTA, 0, 0); /* SPI0_MISO */ at91_set_b_periph(AT91_PIO_PORTA, 1, 0); /* SPI0_MOSI */ at91_set_b_periph(AT91_PIO_PORTA, 2, 0); /* SPI0_SPCK */
/* Enable clock */ - writel(1 << AT91SAM9263_ID_SPI0, &pmc->pcer); + writel(1 << ATMEL_ID_SPI0, &pmc->pcer);
if (cs_mask & (1 << 0)) { at91_set_b_periph(AT91_PIO_PORTA, 5, 1); @@ -128,14 +109,14 @@ void at91_spi0_hw_init(unsigned long cs_mask)
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTB, 12, 0); /* SPI1_MISO */ at91_set_a_periph(AT91_PIO_PORTB, 13, 0); /* SPI1_MOSI */ at91_set_a_periph(AT91_PIO_PORTB, 14, 0); /* SPI1_SPCK */
/* Enable clock */ - writel(1 << AT91SAM9263_ID_SPI1, &pmc->pcer); + writel(1 << ATMEL_ID_SPI1, &pmc->pcer);
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTB, 15, 1); @@ -203,12 +184,12 @@ void at91_uhp_hw_init(void) #ifdef CONFIG_AT91_CAN void at91_can_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
at91_set_a_periph(AT91_PIO_PORTA, 13, 0); /* CAN_TX */ at91_set_a_periph(AT91_PIO_PORTA, 14, 1); /* CAN_RX */
/* Enable clock */ - writel(1 << AT91SAM9263_ID_CAN, &pmc->pcer); + writel(1 << ATMEL_ID_CAN, &pmc->pcer); } #endif
Dear Daniel Gorsulowski,
Applied to u-boot-atmel/next.
Thanks,
Reinhard
Daniel Gorsulowski
Reinhard Meyer
