[PATCH] linker_list: Fix ll_entry_get alignment
When ll_entry_get is used on a list entry ll_entry_declare'd in the same file, the lack of alignment on the access will override the ll_entry_declare alignment. This causes GCC to use the default section alignment of 32 bytes. As list entries are not necessarily 32-byte aligned, this will cause a gap in the linker list, corrupting further entries.
As a specific example, get_fs_loader uses DM_DRIVER_GET(fs_loader) in the same file where U_BOOT_DRIVER(fs_loader) is present. This causes a crash when walking the driver list.
Fix this by adding appropriate alignment to all accesses.
Fixes: 42ebaae3a33 ("common: Implement support for linker-generated arrays") Signed-off-by: Sean Anderson seanga2@gmail.com ---
include/linker_lists.h | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/include/linker_lists.h b/include/linker_lists.h index f9a2ee0c762..e0c8a01b9ba 100644 --- a/include/linker_lists.h +++ b/include/linker_lists.h @@ -209,7 +209,8 @@ */ #define ll_entry_get(_type, _name, _list) \ ({ \ - extern _type _u_boot_list_2_##_list##_2_##_name; \ + extern _type __aligned(4) \ + _u_boot_list_2_##_list##_2_##_name; \ _type *_ll_result = \ &_u_boot_list_2_##_list##_2_##_name; \ _ll_result; \ @@ -229,7 +230,7 @@ * @_list: name of the list */ #define ll_entry_ref(_type, _name, _list) \ - ((_type *)&_u_boot_list_2_##_list##_2_##_name) + ((_type __aligned(4) *)&_u_boot_list_2_##_list##_2_##_name)
/** * ll_start() - Point to first entry of first linker-generated array
_type *_ll_result = \ &_u_boot_list_2_##_list##_2_##_name; \ _ll_result; \_u_boot_list_2_##_list##_2_##_name; \
@@ -229,7 +230,7 @@
- @_list: name of the list
- ((_type __aligned(4) *)&_u_boot_list_2_##_list##_2_##_name)
OK, so this causes an error in clang. And it isn't really necessary because the entry is already declared at this point.
So I guess the right fix is to replace DM_DRIVER_GET with DM_DRIVER_REF in get_fs_loader. But this seems like a really big footgun. You can use the wrong one and there are no errors except at runtime. I wonder if we can add a warning of some kind?
--Sean
- ll_start() - Point to first entry of first linker-generated array
Hi Sean,
@@ -229,7 +230,7 @@
I can imagine having a runtime check, something like:
ll_check(sizeof(struct something))
which checks that the linker list (end - start) is a multiple of the struct size. Do you think that would find the problem?
If so, then it could be perhaps be turned into a link-time check. This produces a list of the linker lists along with their individual members:
or ll in $(nm /tmp/b/coreboot/u-boot |grep u_boot_list_2 |sed 's/.*_u_boot_list_2_(.*)_2_.*/\1/' |uniq); do echo; echo "linker list: %ll"; nm /tmp/b/coreboot/u-boot |grep $ll; done
... linker list: ut_str_test 011a9a20 D _u_boot_list_2_ut_str_test_2_str_dectoul 011a9a30 D _u_boot_list_2_ut_str_test_2_str_hextoul 011a9a40 D _u_boot_list_2_ut_str_test_2_str_itoa 011a9a50 D _u_boot_list_2_ut_str_test_2_str_simple_strtoul 011a9a60 D _u_boot_list_2_ut_str_test_2_str_simple_strtoull 011a9a70 D _u_boot_list_2_ut_str_test_2_str_trailing 011a9a80 D _u_boot_list_2_ut_str_test_2_str_upper 011a9a90 D _u_boot_list_2_ut_str_test_2_str_xtoa 011a9aa0 D _u_boot_list_2_ut_str_test_2_test_str_to_list ...
Then you can check that the address of each one increments by the same amount.
Maybe.
On 10/1/23 21:16, Simon Glass wrote:
Hi Sean,
Most of the time, yes.
Maybe.
Yeah, this would be the best way to find errors in the current system.
But maybe ll_entry_get should look like
#define ll_entry_get(_type, _name, _list) \ ({ \ ll_entry_declare(_type, _name, _list); \ _type *_ll_result = \ &_u_boot_list_2_##_list##_2_##_name; \ _ll_result; \ })
(untested)
Regardless, I think a link-time check would be a good sanity check.
--Sean
Hi Sean,
Hi Sean,
Maybe.
(untested)
OK, well if you take a crack at it, you have a failing case to test with!
Sean Anderson
