[PATCH 1/1] doc: qfw man-page
Provide a man-page for the qfw command.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/usage/index.rst | 1 + doc/usage/qfw.rst | 89 +++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 90 insertions(+) create mode 100644 doc/usage/qfw.rst
diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 5754958d7e..153a8df3f8 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -27,5 +27,6 @@ Shell commands loady mbr pstore + qfw sbi true diff --git a/doc/usage/qfw.rst b/doc/usage/qfw.rst new file mode 100644 index 0000000000..87463e1e5b --- /dev/null +++ b/doc/usage/qfw.rst @@ -0,0 +1,89 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +qfw command +=========== + +Synopsis +-------- + +:: + + qfw list + qfw cpus + qfw load [kernel_addr [initrd_addr]] + +Description +----------- + +The *qfw* command is used to retrieve information form the QEMU firmware. + +The *qfw list* sub-command displays the QEMU firmware files. + +The *qfw cpus* sub-command displays the available CPUs. + +The *qfw load* command is used to load a kernel and an initial RAM disk. + +kernel_addr + address to which the file specified by the -kernel parameter of QEMU shall + be loaded. Defaults to environment variable *loadaddr* and further to + the value of *CONFIG_LOADADDR*. + +initrd_addr + address to which the file specified by the -initrd parameter of QEMU shall + be loaded. Defaults to environment variable *ramdiskaddr* and further to + the value of *CONFIG_RAMDISK_ADDR*. + +Examples +-------- + +QEMU firmware files are listed via the *qfw list* command: + +:: + + => qfw list + etc/boot-fail-wait + etc/smbios/smbios-tables + etc/smbios/smbios-anchor + etc/e820 + genroms/kvmvapic.bin + genroms/linuxboot.bin + etc/system-states + etc/acpi/tables + etc/table-loader + etc/tpm/log + etc/acpi/rsdp + bootorder + +The available CPUs can be shown via the *qfw cpus* command: + +:: + + => qfw cpu + 2 cpu(s) online + +The *-kernel* and *-initrd* parameters allow to specify a kernel and an +initial RAM disk for QEMU: + +.. code-block:: bash + + $ qemu-system-x86_64 -machine pc-i440fx-2.5 -bios u-boot.rom -m 1G \ + -nographic -kernel vmlinuz -initrd initrd + +Now the kernel and the initial RAM disk can be loaded to the U-Boot memory via +the *qfw load* command and booted thereafter. + +:: + + => qfw load ${kernel_addr_r} ${ramdisk_addr_r} + loading kernel to address 0000000001000000 size 5048f0 initrd 0000000004000000 size 3c94891 + => zboot 1000000 5048f0 4000000 3c94891 + Valid Boot Flag + Magic signature found + Linux kernel version 4.19.0-14-amd64 (debian-kernel@lists.debian.org) #1 SMP Debian 4.19.171-2 (2021-01-30) + Building boot_params at 0x00090000 + Loading bzImage at address 100000 (5260160 bytes) + +Configuration +------------- + +The qfw command is only available if CONFIG_CMD_QFW=y. -- 2.30.0
