[PATCH] board: synquacer: Update the flash image layout
The SynQuacer Developerbox, in EFI mode, supports A/B capsule updates and single image ones. The flash layout in the latter case is outdated, update it with the new offsets and images
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- board/socionext/developerbox/developerbox.c | 23 +-------------------- 1 file changed, 1 insertion(+), 22 deletions(-)
diff --git a/board/socionext/developerbox/developerbox.c b/board/socionext/developerbox/developerbox.c index 9585944d80c1..ac4415ff3bbb 100644 --- a/board/socionext/developerbox/developerbox.c +++ b/board/socionext/developerbox/developerbox.c @@ -20,39 +20,18 @@
#if IS_ENABLED(CONFIG_EFI_HAVE_CAPSULE_SUPPORT) struct efi_fw_image fw_images[] = { -#if CONFIG_IS_ENABLED(FWU_MULTI_BANK_UPDATE) { .image_type_id = DEVELOPERBOX_FIP_IMAGE_GUID, .fw_name = u"DEVELOPERBOX-FIP", .image_index = 1, }, -#else - { - .image_type_id = DEVELOPERBOX_UBOOT_IMAGE_GUID, - .fw_name = u"DEVELOPERBOX-UBOOT", - .image_index = 1, - }, - { - .image_type_id = DEVELOPERBOX_FIP_IMAGE_GUID, - .fw_name = u"DEVELOPERBOX-FIP", - .image_index = 2, - }, - { - .image_type_id = DEVELOPERBOX_OPTEE_IMAGE_GUID, - .fw_name = u"DEVELOPERBOX-OPTEE", - .image_index = 3, - }, -#endif };
struct efi_capsule_update_info update_info = { - .dfu_string = "mtd nor1=u-boot.bin raw 200000 100000;" - "fip.bin raw 180000 78000;" - "optee.bin raw 500000 100000", + .dfu_string = "mtd nor1=fip.bin raw 600000 400000", .num_images = ARRAY_SIZE(fw_images), .images = fw_images, }; - #endif /* EFI_HAVE_CAPSULE_SUPPORT */
static struct mm_region sc2a11_mem_map[] = { -- 2.40.1
On Thu, 19 Oct 2023 at 22:54, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Tested-By: Masahisa Kojima masahisa.kojima@linaro.org
Thank you for fixing this issue. I have tested both A/B multi-bank and single image(multi-bank disabled) capsule updates work fine.
Thanks, Masahisa Kojima
.image_index = 1,
.image_index = 2,
.image_index = 3,
-#endif };
2.40.1
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org Tested-By: Masahisa Kojima masahisa.kojima@linaro.org
Ilias Apalodimas
Masahisa Kojima
