[U-Boot] [GIT PULL] Pull request: u-boot-imx u -boot-imx-20190110
Hi Tom,
some fixes for 2019.01. Tag: u -boot-imx-20190110 Travis: https://travis-ci.org/sbabic/u-boot-imx
The following changes since commit 54707a942009fae083dd78b58ff057127ba0e900:
Prepare v2019.01-rc3 (2019-01-07 22:58:17 -0500)
git://www.denx.de/git/u-boot-imx.git tags/u-boot-imx-20190110
for you to fetch changes up to d4a0c098925d4594355506a12ae0dbbe6eed00f2:
imx8m: clock: Fix oscillator values (2019-01-09 17:10:30 +0100)
---------------------------------------------------------------- Fixes for 2019.01
---------------------------------------------------------------- Chris Spencer (1): imx: Add Makefile dependency for mkimage_fit_atf.sh
Fabio Estevam (1): imx8m: clock: Fix oscillator values
Marek Vasut (1): arm: mx5: Enable WDT and bootcounter on M53Menlo
Peng Fan (6): MAINTAINERS: update NXP i.MX mail list address clk: imx8: fix build warning misc: imx: scu: avoid write null pointer misc: imx8: scu: use platdata instead of priv data imx8: cpu: correct info tools: imx8image: set dcd_skip to true
Soeren Moch (2): board: tbs2910: Add u-boot.imx size limit check board: tbs2910: Remove FIT support in defconfig to reduce u-boot size
Stefan Agner (6): board: toradex: colibri_vf: unset NFS and LOADS/B ARM: vf610: ddrmc: program Dummy DDRBYTE1/2 toradex: colibri_vf: fix memory initialization ARM: vf610: ddrmc: fix CR138 preprocessor define ARM: vf610: ddrmc: fix initialization completion detection ARM: vf610: ddrmc: do not write CR79 by default
MAINTAINERS | 2 +- Makefile | 3 +++ arch/arm/include/asm/arch-vf610/imx-regs.h | 5 +++-- arch/arm/include/asm/arch-vf610/iomux-vf610.h | 2 ++ arch/arm/mach-imx/ddrmc-vf610.c | 6 ++++-- arch/arm/mach-imx/imx8/cpu.c | 2 +- arch/arm/mach-imx/imx8m/clock.c | 4 ++-- board/toradex/colibri_vf/colibri_vf.c | 10 +--------- configs/colibri_vf_defconfig | 3 +++ configs/m53menlo_defconfig | 8 ++++++++ configs/tbs2910_defconfig | 1 - drivers/clk/imx/clk-imx8.c | 2 ++ drivers/misc/imx8/scu.c | 26 +++++++++++++------------- drivers/misc/imx8/scu_api.c | 4 ++-- include/configs/m53menlo.h | 3 +++ include/configs/tbs2910.h | 2 ++ tools/imx8image.c | 2 +- 17 files changed, 51 insertions(+), 34 deletions(-)
Regards, Stefano
On Thu, Jan 10, 2019 at 09:06:52AM +0100, Stefano Babic wrote:
Hi Tom,
Stefano Babic
