[PATCH 1/1] efi_loader: configuration of variables store
The file based and the OP-TEE based UEFI variable store are mutually exclusive. Define them as choice options in Kconfig.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/Kconfig | 30 ++++++++++++++++++------------ 1 file changed, 18 insertions(+), 12 deletions(-)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 4324694d48..8827c76cc9 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -27,13 +27,28 @@ config EFI_LOADER
if EFI_LOADER
+choice + prompt "Store for non-volatile UEFI variables" + default EFI_VARIABLE_FILE_STORE + help + Select where non-volatile UEFI variables shall be stored. + config EFI_VARIABLE_FILE_STORE bool "Store non-volatile UEFI variables as file" depends on FAT_WRITE - default y help - Select tis option if you want non-volatile UEFI variables to be stored - as file /ubootefi.var on the EFI system partition. + Select this option if you want non-volatile UEFI variables to be + stored as file /ubootefi.var on the EFI system partition. + +config EFI_MM_COMM_TEE + bool "UEFI variables storage service via OP-TEE" + depends on OPTEE + help + If OP-TEE is present and running StandAloneMM, dispatch all UEFI + variable related operations to that. The application will verify, + authenticate and store the variables on an RPMB. + +endchoice
config EFI_GET_TIME bool "GetTime() runtime service" @@ -174,13 +189,4 @@ config EFI_SECURE_BOOT it is signed with a trusted key. To do that, you need to install, at least, PK, KEK and db.
-config EFI_MM_COMM_TEE - bool "UEFI variables storage service via OP-TEE" - depends on OPTEE - default n - help - If OP-TEE is present and running StandAloneMM, dispatch all UEFI variable - related operations to that. The application will verify, authenticate and - store the variables on an RPMB. - endif -- 2.27.0
if EFI_LOADER
+choice
- prompt "Store for non-volatile UEFI variables"
- default EFI_VARIABLE_FILE_STORE
- help
- default y help
- depends on OPTEE
- help
+endchoice
- depends on OPTEE
- default n
- help
endif
2.27.0
Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org
