[U-Boot] MPC83xx and uec
I can't find a way to get at uec_info_t/STD_UEC_INFO from my board_eth_init() in current u-boot. Am I missing something? Also drivers/qe/uec.h:int uec_initialize(bd_t *bis, uec_info_t *uec_info); include/netdev.h:int uec_initialize(int index); different prototypes for the same function.
BTW, I am looking for a way to swap the order of ethernet interfaces: static uec_info_t uec_info[] = { #ifdef CONFIG_UEC_ETH1 STD_UEC_INFO(1), /* UEC1 */ #endif #ifdef CONFIG_UEC_ETH2 STD_UEC_INFO(2), /* UEC2 */ #endif #ifdef CONFIG_UEC_ETH3 STD_UEC_INFO(3), /* UEC3 */ #endif };
Sometimes I want ETH2 to be the first and ETH1 the second I/F and I do this dynamically depending on actual HW detected.
Works for me:
http://lists.denx.de/pipermail/u-boot/2009-September/060821.html
You'll also need this patch:
http://lists.denx.de/pipermail/u-boot/2009-September/060819.html
Anton Vorontsov avorontsov@ru.mvista.com wrote on 22/09/2009 15:51:17:
To:
Joakim Tjernlund joakim.tjernlund@transmode.se
Cc:
u-boot@lists.denx.de, kim.phillips@freescale.com
Date:
22/09/2009 15:51
Subject:
Re: [U-Boot] MPC83xx and uec
Works for me:
Right, but I don't consider a include as this: +#include "../../../drivers/qe/uec.h" as the correct way of getting of required data types and macros. Consider that uec_initialize() is exported by netdev.h (although with the wrong prototype ATM). As far as I can tell, I should only have to include netdev.h to get the required types and macros.
Jocke
On Tue, Sep 22, 2009 at 04:03:16PM +0200, Joakim Tjernlund wrote: [...]
Works for me:
Not sure if having all-in-one netdev header is a good idea. It might be a good idea to move uec.h to "include/" though.
Works for me:
This needs to be cleaned up. THE prototype for the global initialize() function needs to be in netdev.h and nowhere else.
BTW - can't you effectively swap the order of the Ethernet interfaces at runtime using the 'ethprime' environment variable?
regards, Ben
Ben Warren biggerbadderben@gmail.com wrote on 22/09/2009 18:55:22:
Works for me:
I did this quite some time ago so memory isn't fresh, but at time I looked high and low(including ethprime) and nothing worked all the way so I ended up swapping by patching generic code instead. Now I can do the same in board code, but current u-boot is a bit fuzzy in this area.
Jocke
Works for me:
Does not seem like this has been cleaned up yet.
Jocke
Anton Vorontsov
Ben Warren
Joakim Tjernlund
