[U-Boot] Issue with running commands
hi, While testing on hawkboard with the latest commit, i hit an issue of commands not being accepted.
hawkboard > reset Unknown command '�����' - try 'help' hawkboard >
Running git bisect showed that this is caused due to commit 054ea170f271: cmd_mem: cmp: unify size code paths. Has anyone seen this issue -- i don't think this is board/arch specific.
-sughosh
Dear Sughosh Ganu,
In message CAM6zRufYHPfuSNxEAtOaoCTyKpYRGFn0U6+YxkNCtD6_cL2j6g@mail.gmail.com you wrote:
hawkboard > reset Unknown command '�����' - try 'help> ' hawkboard >
You must have a different kind of problem with your board. Commit 054ea170f271 is only changing the code of common/cmd_mem.c, which is not used in any way by the reset command or by the command handler or so - this cannot be causing such an effect; it could only trigger another problem by changing code size or alignment or such.
Hi Sughosh,
I tried to reproduce this on the calimain board (AM1808 SoC), but without success. The reset command works fine with current mainline u-boot.
Regards, Christian
hi Christian,
On Tue, Jul 3, 2012 at 11:52 AM, Christian Riesch < christian.riesch@omicron.at> wrote:
Hi Sughosh,
hawkboard > rese Unknown command '�����' - try 'help' hawkboard >
don't
Thanks for testing this. This looks to be some kind of an alignment issue on my board, which is getting introduced due to the commit i mentioned. The said commit is not directly responsible for the problem, but it introduces some kind of misalignment. I am looking into this -- at such times i so dearly wish i had a jtag debugger :)
-sughosh
Hi Sughosh
On Wed, Jul 4, 2012 at 4:35 AM, Sughosh Ganu urwithsughosh@gmail.com wrote:
hi Christian,
Hi Sughosh,
don't
I may be totally off track, but I saw a patch recently 'arm: armv7: add compile option -mno-unaligned-access if available' - I wonder if its related
Regards,
Graeme
hi Graeme, On Wed Jul 04, 2012 at 09:28:07AM +1000, Graeme Russ wrote:
<snip>
don't
The SoC on my board uses a armv5 based core(arm926ejs), so this patch won't apply for my board.
-sughosh
Hi Sughosh,
<snip>
don't
Tested on Logic Pd's OMAPL138, and found no issues as you mentioned.
Thx, --Prabhakar Lad
-sughosh _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
I was trying to debug the issue, and i found different behaviour with different toolchains.
Codesourcery(gcc - 4.5.2, binutils - 2.20.51)
With commit 211e47549b668c7, which is the top of master, i don't hit the issue anymore.
ELDK-5.2(gcc - 4.6.4, binutils - 2.22)
With this toolchain, i never hit the issue. But enabling DEBUG in board.c, i get a hang after nand initialisation. I am not able to use debug messages, as the board starts to boot with inclusion of even a single debug message.
I am not sure now if this is something specific to my board, as i see different results with different toolchains. It'd be great if this change(DEBUG enabled in board.c with an eldk toolchain) can be checked on other boards(preferably davinci boards). Thanks.
-sughosh
Worked with my friend during the last week to figure out the issue. That he had a jtag debugger with him actually helped us track down the issue. The issue was that the board was using the wrong version of the nand_read_page function in spl -- we are supposed to use the page read version with oob read first, while the other version was being used. This resulted in corruptions being introduced in the u-boot image that was being copied from the nand.
-sughosh
participants (5)
Christian Riesch
Graeme Russ
Prabhakar Lad
Sughosh Ganu
