[PATCH 0/5] imx8mn-var-som: fix ethernet for Variscite symphony board and imx8m nano SOM
Hello, This patch series fixes bugs and add missing features related to the ethernet PHY on Variscite symphony carrier board with an imx8m nano SOM (P/N VAR-SOM-MX8M-NANO).
Ethernet functionality is currently broken for the VAR-SOM-MX8M-NANO.
Variscite imx8m nano SOM comes in multiple hardware configuration options. One of this hardware configuration option is called EC: EC: Ethernet Controller PHY assembled on SOM
For SOM with the EC configuration, the ethernet PHY is located on the SOM itself, and connected to the CPU ethernet controller. It has a reset line controlled via GPIO1_IO9. In this configuration, the PHY located on the carrier board is not connected to anything and is therefore not used.
For SOM without EC configuration, the ethernet PHY on the carrier board is connected to the CPU ethernet controller. It has a reset line controlled via the GPIO expander PCA9534_IO5.
Patch 1 add code to read and display the SOM configuration stored in the SOM EEPROM. This patch is also submitted to the Linux kernel (section that adds the EEPROM to the device tree), so that it will be easier to sync the DT between kernel and U-Boot.
Patch 2 fixes bugs with the PHY reset properties.
Patch 3 fixes a bug with a missing PHY reset deassert delay (also submitted to kernel).
Patch 4 enables automatic read of PHY MAC address from the SOM EEPROM.
Patch 5 is used for auto-detecting at runtime the SOM hardware configuration option related to the PHY (EC), and dynamically adjust the device tree to support both SOM PHY options.
This series need the following patch to be applied first: https://lore.kernel.org/u-boot/20230425141935.2324406-1-hugo@hugovil.com/
I have succesfully tested the changes on a Variscite symphony carrier board with a VAR-SOM-MX8M-NANO having the EC configuration option.
Unfortunately, I do not have a VAR-SOM-MX8M-NANO with a non-EC configuration option so I couldn't test it on real hardware, altough I simulated it and confirmed that the device tree fixing seems to be correct by using debug/print statements.
Thank you.
Hugo Villeneuve (5): imx8mn-var-som: read and print SoM infos from eeprom on startup imx8mn-var-som: fix non-applied PHY reset-gpios properties arm: dts: imx8mn-var-som: fix PHY detection bug by adding deassert delay imx8mn-var-som: read eth MAC address from EEPROM imx8mn-var-som: adjust PHY reset gpios according to hardware configuration
.../dts/imx8mn-var-som-symphony-u-boot.dtsi | 17 ++ arch/arm/dts/imx8mn-var-som-symphony.dts | 4 - arch/arm/dts/imx8mn-var-som.dtsi | 18 +- arch/arm/mach-imx/imx8m/Kconfig | 4 + .../variscite/imx8mn_var_som/imx8mn_var_som.c | 214 ++++++++++++++++++ configs/imx8mn_var_som_defconfig | 4 + 6 files changed, 256 insertions(+), 5 deletions(-)
base-commit: 2e83d560c115d6a6616edc8054fe6be9803f9577
Enable support to read and display configuration/manufacturing infos from 4Kbit EEPROM located on SOM board.
Note: CONFIG_DISPLAY_BOARDINFO is automatically selected for ARM arch.
Signed-off-by: Hugo Villeneuve hvilleneuve@dimonoff.com --- .../dts/imx8mn-var-som-symphony-u-boot.dtsi | 4 + arch/arm/dts/imx8mn-var-som.dtsi | 10 ++ arch/arm/mach-imx/imx8m/Kconfig | 2 + .../variscite/imx8mn_var_som/imx8mn_var_som.c | 134 ++++++++++++++++++ configs/imx8mn_var_som_defconfig | 1 + 5 files changed, 151 insertions(+)
diff --git a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi index af80aaea0b..7272fc2b4c 100644 --- a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi @@ -68,3 +68,7 @@ &usdhc3 { bootph-pre-ram; }; + +&eeprom_som { + bootph-pre-ram; +}; diff --git a/arch/arm/dts/imx8mn-var-som.dtsi b/arch/arm/dts/imx8mn-var-som.dtsi index 87b5e23c76..dea9eff3f0 100644 --- a/arch/arm/dts/imx8mn-var-som.dtsi +++ b/arch/arm/dts/imx8mn-var-som.dtsi @@ -11,6 +11,10 @@ model = "Variscite VAR-SOM-MX8MN module"; compatible = "variscite,var-som-mx8mn", "fsl,imx8mn";
+ aliases { + eeprom-som = &eeprom_som; + }; + chosen { stdout-path = &uart4; }; @@ -222,6 +226,12 @@ }; }; }; + + eeprom_som: eeprom@52 { + compatible = "atmel,24c04"; + reg = <0x52>; + pagesize = <16>; + }; };
&i2c3 { diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index dc51f971d4..ec0abb92b8 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -239,6 +239,8 @@ config TARGET_IMX8MN_VAR_SOM select IMX8MN select SUPPORT_SPL select IMX8M_DDR4 + select MISC + select I2C_EEPROM
config TARGET_KONTRON_PITX_IMX8M bool "Support Kontron pITX-imx8m" diff --git a/board/variscite/imx8mn_var_som/imx8mn_var_som.c b/board/variscite/imx8mn_var_som/imx8mn_var_som.c index d40f4d0176..a89457e8f5 100644 --- a/board/variscite/imx8mn_var_som/imx8mn_var_som.c +++ b/board/variscite/imx8mn_var_som/imx8mn_var_som.c @@ -1,11 +1,49 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2021 Collabora Ltd. + * Copyright 2018-2020 Variscite Ltd. + * Copyright 2023 DimOnOff Inc. */
#include <common.h> +#include <dm.h> #include <env.h> +#include <fdtdec.h> +#include <fdt_support.h> +#include <i2c_eeprom.h> +#include <malloc.h> #include <asm/io.h> +#include <asm/global_data.h> +#include <linux/libfdt.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Optional SOM features flags. */ +#define VAR_EEPROM_F_WIFI BIT(0) +#define VAR_EEPROM_F_ETH BIT(1) /* Ethernet PHY on SOM. */ +#define VAR_EEPROM_F_AUDIO BIT(2) +#define VAR_EEPROM_F_MX8M_LVDS BIT(3) /* i.MX8MM, i.MX8MN, i.MX8MQ only */ +#define VAR_EEPROM_F_MX8Q_SOC_ID BIT(3) /* 0 = i.MX8QM, 1 = i.MX8QP */ +#define VAR_EEPROM_F_NAND BIT(4) + +#define VAR_IMX8_EEPROM_MAGIC 0x384D /* "8M" */ + +/* Number of DRAM adjustment tables. */ +#define DRAM_TABLES_NUM 7 + +struct var_imx8_eeprom_info { + u16 magic; + u8 partnumber[3]; /* Part number */ + u8 assembly[10]; /* Assembly number */ + u8 date[9]; /* Build date */ + u8 mac[6]; /* MAC address */ + u8 somrev; + u8 eeprom_version; + u8 features; /* SOM features */ + u8 dramsize; /* DRAM size */ + u8 off[DRAM_TABLES_NUM + 1]; /* DRAM table offsets */ + u8 partnumber2[5]; /* Part number 2 */ +} __packed;
static void setup_fec(void) { @@ -28,3 +66,99 @@ int board_mmc_get_env_dev(int devno) { return devno; } + +#if !defined(CONFIG_SPL_BUILD) + +#if defined(CONFIG_DISPLAY_BOARDINFO) + +static void display_som_infos(struct var_imx8_eeprom_info *info) +{ + char partnumber[sizeof(info->partnumber) + + sizeof(info->partnumber2) + 1]; + char assembly[sizeof(info->assembly) + 1]; + char date[sizeof(info->date) + 1]; + + /* Read first part of P/N. */ + memcpy(partnumber, info->partnumber, sizeof(info->partnumber)); + + /* Read second part of P/N. */ + if (info->eeprom_version >= 3) + memcpy(partnumber + sizeof(info->partnumber), info->partnumber2, + sizeof(info->partnumber2)); + + memcpy(assembly, info->assembly, sizeof(info->assembly)); + memcpy(date, info->date, sizeof(info->date)); + + /* Make sure strings are null terminated. */ + partnumber[sizeof(partnumber) - 1] = '\0'; + assembly[sizeof(assembly) - 1] = '\0'; + date[sizeof(date) - 1] = '\0'; + + printf("SOM board: P/N: %s, Assy: %s, Date: %s\n" + " Wifi: %s, EthPhy: %s, Rev: %d\n", + partnumber, assembly, date, + info->features & VAR_EEPROM_F_WIFI ? "yes" : "no", + info->features & VAR_EEPROM_F_ETH ? "yes" : "no", + info->somrev); +} + +static int var_read_som_eeprom(struct var_imx8_eeprom_info *info) +{ + const char *path = "eeprom-som"; + struct udevice *dev; + int ret, off; + + off = fdt_path_offset(gd->fdt_blob, path); + if (off < 0) { + pr_err("%s: fdt_path_offset() failed: %d\n", __func__, off); + return off; + } + + ret = uclass_get_device_by_of_offset(UCLASS_I2C_EEPROM, off, &dev); + if (ret) { + pr_err("%s: uclass_get_device_by_of_offset() failed: %d\n", + __func__, ret); + return ret; + } + + ret = i2c_eeprom_read(dev, 0, (uint8_t *)info, + sizeof(struct var_imx8_eeprom_info)); + if (ret) { + pr_err("%s: i2c_eeprom_read() failed: %d\n", __func__, ret); + return ret; + } + + if (htons(info->magic) != VAR_IMX8_EEPROM_MAGIC) { + /* Do not fail if the content is invalid */ + pr_err("Board: Invalid board info magic: 0x%08x, expected 0x%08x\n", + htons(info->magic), VAR_IMX8_EEPROM_MAGIC); + } + + return 0; +} + +int checkboard(void) +{ + int rc; + struct var_imx8_eeprom_info *info; + + info = malloc(sizeof(struct var_imx8_eeprom_info)); + if (!info) + return -ENOMEM; + + rc = var_read_som_eeprom(info); + if (rc) + return rc; + + display_som_infos(info); + +#if defined(CONFIG_BOARD_TYPES) + gd->board_type = info->features; +#endif /* CONFIG_BOARD_TYPES */ + + return 0; +} + +#endif /* CONFIG_DISPLAY_BOARDINFO */ + +#endif /* CONFIG_SPL_BUILD */ diff --git a/configs/imx8mn_var_som_defconfig b/configs/imx8mn_var_som_defconfig index f02cbab839..bb1245bd35 100644 --- a/configs/imx8mn_var_som_defconfig +++ b/configs/imx8mn_var_som_defconfig @@ -34,6 +34,7 @@ CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x950000 CONFIG_SPL_BSS_MAX_SIZE=0x2000 CONFIG_SPL_BOARD_INIT=y +CONFIG_BOARD_TYPES=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SYS_SPL_MALLOC=y
Select DM_ETH_PHY so that the reset-gpios property of the ethphy node can be used.
Also select DM_PCA953X, which is needed for resetting the ethernet PHY on the carrier board via the PCA9534 I/O expander.
Commit 4e5114daf9eb ("imx8mn: synchronise device tree with linux") did synchronise device tree with linux, which in effect removed obsolete PHY reset properties and replaced them with new mdio DM properties. But the commit didn't activate DM_ETH_PHY or DM_PCA953X.
Fixes: 4e5114daf9eb ("imx8mn: synchronise device tree with linux")
Signed-off-by: Hugo Villeneuve hvilleneuve@dimonoff.com --- arch/arm/mach-imx/imx8m/Kconfig | 1 + configs/imx8mn_var_som_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index ec0abb92b8..94f4d584f1 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -241,6 +241,7 @@ config TARGET_IMX8MN_VAR_SOM select IMX8M_DDR4 select MISC select I2C_EEPROM + select DM_ETH_PHY
config TARGET_KONTRON_PITX_IMX8M bool "Support Kontron pITX-imx8m" diff --git a/configs/imx8mn_var_som_defconfig b/configs/imx8mn_var_som_defconfig index bb1245bd35..da48ec0a21 100644 --- a/configs/imx8mn_var_som_defconfig +++ b/configs/imx8mn_var_som_defconfig @@ -9,6 +9,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xFFFFDE00 CONFIG_DM_GPIO=y +CONFIG_DM_PCA953X=y CONFIG_DEFAULT_DEVICE_TREE="imx8mn-var-som-symphony" CONFIG_SPL_TEXT_BASE=0x912000 CONFIG_TARGET_IMX8MN_VAR_SOM=y
While testing the ethernet interface on a Variscite symphony carrier board using an imx8mn SOM with an onboard ADIN1300 PHY (EC hardware configuration), the ethernet PHY is not detected.
The ADIN1300 datasheet indicate that the "Management interface active (t4)" state is reached at most 5ms after the reset signal is deasserted.
The device tree in Variscite custom git repository uses the following property:
phy-reset-post-delay = <20>;
Add a new MDIO property 'reset-deassert-us' of 20ms to have the same delay inside the ethphy node. Adding this property fixes the problem with the PHY detection.
Note that this SOM can also have an Atheros AR8033 PHY. In this case, a 1ms deassert delay is sufficient. Add a comment to that effect.
Fixes: c4c1ed68c1e8 ("imx8mn_var_som: Add support for Variscite VAR-SOM-MX8M-NANO board")
Signed-off-by: Hugo Villeneuve hvilleneuve@dimonoff.com --- arch/arm/dts/imx8mn-var-som.dtsi | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/imx8mn-var-som.dtsi b/arch/arm/dts/imx8mn-var-som.dtsi index dea9eff3f0..4eb578a03f 100644 --- a/arch/arm/dts/imx8mn-var-som.dtsi +++ b/arch/arm/dts/imx8mn-var-som.dtsi @@ -102,11 +102,17 @@ #address-cells = <1>; #size-cells = <0>;
- ethphy: ethernet-phy@4 { + ethphy: ethernet-phy@4 { /* AR8033 or ADIN1300 */ compatible = "ethernet-phy-ieee802.3-c22"; reg = <4>; reset-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>; reset-assert-us = <10000>; + /* + * Deassert delay: + * ADIN1300 requires 5ms. + * AR8033 requires 1ms. + */ + reset-deassert-us = <20000>; }; }; };
Read ethernet MAC address from EEPROM located on the SOM.
Signed-off-by: Hugo Villeneuve hvilleneuve@dimonoff.com --- arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi | 13 +++++++++++++ arch/arm/mach-imx/imx8m/Kconfig | 1 + 2 files changed, 14 insertions(+)
diff --git a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi index 7272fc2b4c..e0caf3179e 100644 --- a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi @@ -13,6 +13,19 @@ bootph-pre-ram; };
+&eeprom_som { + #address-cells = <1>; + #size-cells = <1>; + eth_mac_address: eth-mac-address@19 { + reg = <0x19 0x06>; + }; +}; + +&fec1 { + nvmem-cells = <ð_mac_address>; + nvmem-cell-names = "mac-address"; +}; + &gpio1 { bootph-pre-ram; }; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 94f4d584f1..7e5a3e31dd 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -242,6 +242,7 @@ config TARGET_IMX8MN_VAR_SOM select MISC select I2C_EEPROM select DM_ETH_PHY + select NVMEM
The hardware configuration (EC) is determined at runtime by reading from the SOM EEPROM.
To support both hardware configurations (EC and non-EC), adjust/fix the PHY reset gpios according to the hardware configuration read at runtime from the SOM EEPROM. This adjustement is done in U-Boot (OF_BOARD_FIXUP) and kernel (OF_BOARD_SETUP) device trees.
Signed-off-by: Hugo Villeneuve hvilleneuve@dimonoff.com --- arch/arm/dts/imx8mn-var-som-symphony.dts | 4 - .../variscite/imx8mn_var_som/imx8mn_var_som.c | 80 +++++++++++++++++++ configs/imx8mn_var_som_defconfig | 2 + 3 files changed, 82 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/imx8mn-var-som-symphony.dts b/arch/arm/dts/imx8mn-var-som-symphony.dts index 3ed7021a48..5c8e4e8175 100644 --- a/arch/arm/dts/imx8mn-var-som-symphony.dts +++ b/arch/arm/dts/imx8mn-var-som-symphony.dts @@ -56,10 +56,6 @@ }; };
-ðphy { - reset-gpios = <&pca9534 5 GPIO_ACTIVE_HIGH>; -}; - &i2c2 { clock-frequency = <400000>; pinctrl-names = "default"; diff --git a/board/variscite/imx8mn_var_som/imx8mn_var_som.c b/board/variscite/imx8mn_var_som/imx8mn_var_som.c index a89457e8f5..61b9455a8f 100644 --- a/board/variscite/imx8mn_var_som/imx8mn_var_som.c +++ b/board/variscite/imx8mn_var_som/imx8mn_var_som.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <asm/io.h> #include <asm/global_data.h> +#include <dt-bindings/gpio/gpio.h> #include <linux/libfdt.h>
DECLARE_GLOBAL_DATA_PTR; @@ -161,4 +162,83 @@ int checkboard(void)
+static int insert_gpios_prop(void *blob, int node, const char *prop, + unsigned int phandle, u32 gpio, u32 flags) +{ + fdt32_t val[3] = { cpu_to_fdt32(phandle), cpu_to_fdt32(gpio), + cpu_to_fdt32(flags) }; + return fdt_setprop(blob, node, prop, &val, sizeof(val)); +} + +static int configure_phy_reset_gpios(void *blob) +{ + int node; + int phynode; + int ret; + u32 handle; + u32 gpio; + u32 flags; + char path[1024]; + const char *eth_alias = "ethernet0"; + + snprintf(path, sizeof(path), "%s/mdio/ethernet-phy@4", + fdt_get_alias(blob, eth_alias)); + + phynode = fdt_path_offset(blob, path); + if (phynode < 0) { + pr_err("%s(): unable to locate PHY node: %s\n", __func__, path); + return 0; + } + + if (gd_board_type() & VAR_EEPROM_F_ETH) { + snprintf(path, sizeof(path), "%s", + fdt_get_alias(blob, "gpio0")); /* Alias to gpio1 */ + gpio = 9; + flags = GPIO_ACTIVE_LOW; + } else { + snprintf(path, sizeof(path), "%s/gpio@20", + fdt_get_alias(blob, "i2c1")); /* Alias to i2c2 */ + gpio = 5; + flags = GPIO_ACTIVE_HIGH; + } + + node = fdt_path_offset(blob, path); + if (node < 0) { + pr_err("%s(): unable to locate GPIO node: %s\n", __func__, + path); + return 0; + } + + handle = fdt_get_phandle(blob, node); + if (handle < 0) { + pr_err("%s(): unable to locate GPIO controller handle: %s\n", + __func__, path); + } + + ret = insert_gpios_prop(blob, phynode, "reset-gpios", + handle, gpio, flags); + if (ret < 0) { + pr_err("%s(): failed to set reset-gpios property\n", __func__); + return ret; + } + + return 0; +} + +#if defined(CONFIG_OF_BOARD_FIXUP) +int board_fix_fdt(void *blob) +{ + /* Fix U-Boot device tree: */ + return configure_phy_reset_gpios(blob); +} +#endif /* CONFIG_OF_BOARD_FIXUP */ + +#if defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, struct bd_info *bd) +{ + /* Fix kernel device tree: */ + return configure_phy_reset_gpios(blob); +} +#endif /* CONFIG_OF_BOARD_SETUP */ + #endif /* CONFIG_SPL_BUILD */ diff --git a/configs/imx8mn_var_som_defconfig b/configs/imx8mn_var_som_defconfig index da48ec0a21..0f3d2a0288 100644 --- a/configs/imx8mn_var_som_defconfig +++ b/configs/imx8mn_var_som_defconfig @@ -112,3 +112,5 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_IMX_WATCHDOG=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_OF_BOARD_FIXUP=y +CONFIG_OF_BOARD_SETUP=y
Hugo Villeneuve
