[U-Boot] [PATCH] board: ti: Move fastboot functions out of TI_SECURE_DEVICE ifdef
When these were moved from mach-omap2 to board files they got placed inside TI_SECURE_DEVICE ifdef block, they are not secure only, move them up and out.
Fixes: 413b90777f8d ("ti: fastboot: Move weak overrides to board files") Signed-off-by: Andrew F. Davis afd@ti.com --- board/ti/am57xx/board.c | 20 ++++++++++---------- board/ti/dra7xx/evm.c | 20 ++++++++++---------- 2 files changed, 20 insertions(+), 20 deletions(-)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 7063345dcc..1a903f13a6 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -1096,6 +1096,16 @@ int board_fit_config_name_match(const char *name) } #endif
+#if CONFIG_IS_ENABLED(FASTBOOT) && !CONFIG_IS_ENABLED(ENV_IS_NOWHERE) +int fastboot_set_reboot_flag(void) +{ + printf("Setting reboot to fastboot flag ...\n"); + env_set("dofastboot", "1"); + env_save(); + return 0; +} +#endif + #ifdef CONFIG_TI_SECURE_DEVICE void board_fit_image_post_process(void **p_image, size_t *p_size) { @@ -1107,15 +1117,5 @@ void board_tee_image_process(ulong tee_image, size_t tee_size) secure_tee_install((u32)tee_image); }
-#if CONFIG_IS_ENABLED(FASTBOOT) && !CONFIG_IS_ENABLED(ENV_IS_NOWHERE) -int fastboot_set_reboot_flag(void) -{ - printf("Setting reboot to fastboot flag ...\n"); - env_set("dofastboot", "1"); - env_save(); - return 0; -} -#endif - U_BOOT_FIT_LOADABLE_HANDLER(IH_TYPE_TEE, board_tee_image_process); #endif diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index d69641e3a0..060c471032 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -1092,6 +1092,16 @@ int board_fit_config_name_match(const char *name) } #endif
+#if CONFIG_IS_ENABLED(FASTBOOT) && !CONFIG_IS_ENABLED(ENV_IS_NOWHERE) +int fastboot_set_reboot_flag(void) +{ + printf("Setting reboot to fastboot flag ...\n"); + env_set("dofastboot", "1"); + env_save(); + return 0; +} +#endif + #ifdef CONFIG_TI_SECURE_DEVICE void board_fit_image_post_process(void **p_image, size_t *p_size) { @@ -1103,15 +1113,5 @@ void board_tee_image_process(ulong tee_image, size_t tee_size) secure_tee_install((u32)tee_image); }
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
Fixes: 413b90777f8d ("ti: fastboot: Move weak overrides to board files") Signed-off-by: Andrew F. Davis afd@ti.com Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Andrew F. Davis
Lokesh Vutla
