[U-Boot] [AVR32] CONFIG_SYS_TEXT_BASE is missing from atngw100mkii board
Hi Andreass,
I noticed by chance atngw100mkii board does not define CONFIG_SYS_TEXT_BASE, although the other AVR32 boards define it.
Is this your intention, or mistake?
This is what I did:
$ git branch * master $ git describe v2014.07-rc1-79-g2072e72 $ make mrproper $ make atngw100mkii_config Configuring for atngw100mkii board... $ make -s -j8 CROSS_COMPILE=avr32-linux- $ grep CONFIG_SYS_TEXT_BASE include/autoconf.mk $
I can't find CONFIG_SYS_TEXT_BASE in include/autoconf.mk
Best Regards Masahiro Yamada
Hi Masahiro,
On 05/16/2014 07:48 AM, Masahiro Yamada wrote:
Hi Andreass,
oups. I can't remember why this is missing. Maybe cause the CONFIG_SYS_TEXT_BASE is set to 0x0 implicitly?
abiessmann@punisher % PATH=$AVR32_PATH:$PATH make atngw100mkii_config Configuring for atngw100mkii board... abiessmann@punisher % PATH=$AVR32_PATH:$PATH make V=1 -j16 CROSS_COMPILE=avr32-linux- | grep CONFIG_SYS_TEXT_BASE avr32-linux-gcc -x c -DDO_DEPS_ONLY -M -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -Os -fno-stack-protector -g -Wno-format-nonliteral -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x00000000 -DCONFIG_AVR32 -ffixed-r5 -fPIC -mno-init-got -mrelax -ffunction-sections -fdata-sections -mcpu=ap7000 -pipe -Iinclude -I/home/abiessmann/src/u-boot/arch/avr32/include -nostdinc -isystem /opt/OSELAS.Toolchain-2011.11.0/avr32-linux/gcc-4.4.7-uclibc-0.9.33.2-binutils-2.20.1a-kernel-2.6.39-sanitized/lib/gcc/avr32-linux/4.4.7/include -MQ include/autoconf.mk /home/abiessmann/src/u-boot/include/common.h > include/autoconf.mk.dep || rm include/autoconf.mk.dep ...
0x0 is the correct address for avr32 devices, so presumably the CONFIG_SYS_TEXT_BASE parameter was forgotten when writing the atngw100mkii header file. I'll prepare a patch to add it.
Best regards
Andreas
Hi Andreas,
If CONFIG_SYS_TEXT_BASE is missing, .text section will start at 0x00000000 and it works in this case.
But it would be better to fix it just in case.
Thank you for posting the patch.
Andreas Bießmann
Masahiro Yamada
