[U-Boot] [PATCH 00/12] ARM: dra7: Add support for dra76-evm
dra76 family is a high-performance, infotainment application device, based on OMAP architecture on a 28-nm technology. This contains most of the subsystems, peripherals that are available on dra74, dra72 family. This SoC mainly features Subsystems: - 2 x Cortex-A15 with max speed of 1.8GHz - 2 X DSP - 2 X Cortex-M4 IPU - ISS - CAL - DSS - VPE - VIP Connectivity peripherals: - 1 USB3.0 and 3 USB2.0 subsystems - 2 x SATA - 2 x PCI Express Gen2 - 3-port Gigabit ethernet switch - 2 x CAN - MCAN
This series adds support for dra76-evm.
Tested on dra76-evm: MMC boot: http://pastebin.ubuntu.com/25295219/ eMMC boot: http://pastebin.ubuntu.com/25295222/ SPI boot: http://pastebin.ubuntu.com/25295229/
Keerthy (2): configs: dra7xx: Enable LP87565 related configs board: ti: dra76-evm: Add the pmic data
Lokesh Vutla (9): arm: omap5+: Add board specific ldo powering palmas: Add support for powering different ldos board: ti: dra76-evm: Add epprom support board: ti: dra76-evm: Add DDR data board: ti: dra76-evm: Add the pinmux data board: ti: dra76-evm: Add support for powering on mmc ldo env: ti: boot: Select dtb name for dra76 ARM: dts: dra7-evm: sync DT with latest Linux ARM: dts: dra76-evm: Add initial support
Praneeth Bajjuri (1): arm: dra76: Add support for ES1.0 detection
arch/arm/dts/Makefile | 2 +- arch/arm/dts/dra7-evm.dts | 533 ++------------------------------ arch/arm/dts/dra76-evm.dts | 423 +++++++++++++++++++++++++ arch/arm/dts/dra76x.dtsi | 19 ++ arch/arm/include/asm/arch-omap5/clock.h | 9 + arch/arm/include/asm/arch-omap5/omap.h | 1 + arch/arm/include/asm/omap_common.h | 9 + arch/arm/include/asm/omap_mmc.h | 1 + arch/arm/mach-omap2/omap5/hw_data.c | 44 +++ arch/arm/mach-omap2/omap5/hwinit.c | 19 +- arch/arm/mach-omap2/omap5/sdram.c | 2 + board/ti/dra7xx/evm.c | 140 ++++++++- board/ti/dra7xx/mux_data.h | 294 ++++++++++++++++++ configs/dra7xx_evm_defconfig | 4 +- configs/dra7xx_hs_evm_defconfig | 4 +- drivers/power/palmas.c | 11 +- include/environment/ti/boot.h | 2 + include/palmas.h | 6 +- 18 files changed, 999 insertions(+), 524 deletions(-) create mode 100644 arch/arm/dts/dra76-evm.dts create mode 100644 arch/arm/dts/dra76x.dtsi
It is not necessary all omap5+ based uses the same PMIC to poweron mmc. So add support for enabling mmc based on board.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/include/asm/omap_mmc.h | 1 + arch/arm/mach-omap2/omap5/hwinit.c | 16 ++++++---------- board/ti/dra7xx/evm.c | 14 ++++++++++++++ 3 files changed, 21 insertions(+), 10 deletions(-)
diff --git a/arch/arm/include/asm/omap_mmc.h b/arch/arm/include/asm/omap_mmc.h index f6eb51ee3c..fd33408622 100644 --- a/arch/arm/include/asm/omap_mmc.h +++ b/arch/arm/include/asm/omap_mmc.h @@ -174,4 +174,5 @@ int omap_mmc_init(int dev_index, uint host_caps_mask, uint f_max, int cd_gpio, int wp_gpio);
void vmmc_pbias_config(uint voltage); +void board_mmc_poweron_ldo(uint voltage); #endif /* OMAP_MMC_H_ */ diff --git a/arch/arm/mach-omap2/omap5/hwinit.c b/arch/arm/mach-omap2/omap5/hwinit.c index afe59e0b58..42b0d6121c 100644 --- a/arch/arm/mach-omap2/omap5/hwinit.c +++ b/arch/arm/mach-omap2/omap5/hwinit.c @@ -455,10 +455,14 @@ void v7_arch_cp15_set_acr(u32 acr, u32 cpu_midr, u32 cpu_rev_comb, }
#if defined(CONFIG_PALMAS_POWER) +__weak void board_mmc_poweron_ldo(uint voltage) +{ + palmas_mmc1_poweron_ldo(voltage); + +} void vmmc_pbias_config(uint voltage) { u32 value = 0; - struct vcores_data const *vcores = *omap_vcores;
value = readl((*ctrl)->control_pbias); value &= ~SDCARD_PWRDNZ; @@ -467,15 +471,7 @@ void vmmc_pbias_config(uint voltage) value &= ~SDCARD_BIAS_PWRDNZ; writel(value, (*ctrl)->control_pbias);
- if (vcores->core.pmic->i2c_slave_addr == 0x60) { - if (voltage == LDO_VOLT_3V0) - voltage = 0x19; - else if (voltage == LDO_VOLT_1V8) - voltage = 0xa; - lp873x_mmc1_poweron_ldo(voltage); - } else { - palmas_mmc1_poweron_ldo(voltage); - } + board_mmc_poweron_ldo(voltage);
value = readl((*ctrl)->control_pbias); value |= SDCARD_BIAS_PWRDNZ; diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 7d36f03fa1..e202ebf207 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -710,6 +710,20 @@ int board_mmc_init(bd_t *bis) omap_mmc_init(1, 0, 0, -1, -1); return 0; } + +void board_mmc_poweron_ldo(uint voltage) +{ + if (board_is_dra71x_evm()) { + if (voltage == LDO_VOLT_3V0) + voltage = 0x19; + else if (voltage == LDO_VOLT_1V8) + voltage = 0xa; + lp873x_mmc1_poweron_ldo(voltage); + } else { + palmas_mmc1_poweron_ldo(voltage); + } + +} #endif
#ifdef CONFIG_USB_DWC3
It is not necessary that ldo1 is used to power on mmc. So, add support for passing ldo registers for powering on mmc.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/mach-omap2/omap5/hwinit.c | 2 +- board/ti/dra7xx/evm.c | 2 +- drivers/power/palmas.c | 11 ++++------- include/palmas.h | 2 +- 4 files changed, 7 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-omap2/omap5/hwinit.c b/arch/arm/mach-omap2/omap5/hwinit.c index 42b0d6121c..2050560a37 100644 --- a/arch/arm/mach-omap2/omap5/hwinit.c +++ b/arch/arm/mach-omap2/omap5/hwinit.c @@ -457,7 +457,7 @@ void v7_arch_cp15_set_acr(u32 acr, u32 cpu_midr, u32 cpu_rev_comb, #if defined(CONFIG_PALMAS_POWER) __weak void board_mmc_poweron_ldo(uint voltage) { - palmas_mmc1_poweron_ldo(voltage); + palmas_mmc1_poweron_ldo(LDO1_VOLTAGE, LDO1_CTRL, voltage);
} void vmmc_pbias_config(uint voltage) diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index e202ebf207..ba3b477a6f 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -720,7 +720,7 @@ void board_mmc_poweron_ldo(uint voltage) voltage = 0xa; lp873x_mmc1_poweron_ldo(voltage); } else { - palmas_mmc1_poweron_ldo(voltage); + palmas_mmc1_poweron_ldo(LDO1_VOLTAGE, LDO1_CTRL, voltage); }
} diff --git a/drivers/power/palmas.c b/drivers/power/palmas.c index 4e9895987c..ddf777c26b 100644 --- a/drivers/power/palmas.c +++ b/drivers/power/palmas.c @@ -42,24 +42,21 @@ int lp873x_mmc1_poweron_ldo(uint voltage) } #endif
-int palmas_mmc1_poweron_ldo(uint voltage) +int palmas_mmc1_poweron_ldo(uint ldo_volt, uint ldo_ctrl, uint voltage) { u8 val = 0;
#if defined(CONFIG_DRA7XX) int ret; - /* - * Currently valid for the dra7xx_evm board: - * Set TPS659038 LDO1 to 3.0 V or 1.8V - */ - ret = palmas_i2c_write_u8(TPS65903X_CHIP_P1, LDO1_VOLTAGE, voltage); + + ret = palmas_i2c_write_u8(TPS65903X_CHIP_P1, ldo_volt, voltage); if (ret) { printf("tps65903x: could not set LDO1 voltage.\n"); return ret; } /* TURN ON LDO1 */ val = RSC_MODE_SLEEP | RSC_MODE_ACTIVE; - ret = palmas_i2c_write_u8(TPS65903X_CHIP_P1, LDO1_CTRL, val); + ret = palmas_i2c_write_u8(TPS65903X_CHIP_P1, ldo_ctrl, val); if (ret) { printf("tps65903x: could not turn on LDO1.\n"); return ret; diff --git a/include/palmas.h b/include/palmas.h index d676617344..404c2b3ca7 100644 --- a/include/palmas.h +++ b/include/palmas.h @@ -129,7 +129,7 @@ static inline int palmas_i2c_read_u8(u8 chip_no, u8 reg, u8 *val) }
void palmas_init_settings(void); -int palmas_mmc1_poweron_ldo(uint voltage); +int palmas_mmc1_poweron_ldo(uint ldo_volt, uint ldo_ctrl, uint voltage); int lp873x_mmc1_poweron_ldo(uint voltage); int twl603x_mmc1_set_ldo9(u8 vsel); int twl603x_audio_power(u8 on);
Signed-off-by: Keerthy j-keerthy@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- configs/dra7xx_evm_defconfig | 2 ++ configs/dra7xx_hs_evm_defconfig | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 0c4452a1d1..c151f49e30 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -67,11 +67,13 @@ CONFIG_SPL_PHY=y CONFIG_DM_PMIC=y CONFIG_PMIC_PALMAS=y CONFIG_PMIC_LP873X=y +CONFIG_PMIC_LP87565=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_REGULATOR_PALMAS=y CONFIG_DM_REGULATOR_LP873X=y +CONFIG_DM_REGULATOR_LP87565=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 75b77fa947..dba9f06bd6 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -70,11 +70,13 @@ CONFIG_SPL_PHY=y CONFIG_DM_PMIC=y CONFIG_PMIC_PALMAS=y CONFIG_PMIC_LP873X=y +CONFIG_PMIC_LP87565=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_REGULATOR_PALMAS=y CONFIG_DM_REGULATOR_LP873X=y ++CONFIG_DM_REGULATOR_LP87565=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y
Please switch to imply'ing all of the relevant PMICs so that these do not get out of sync, thanks!
Adding CPU detection support for the dra76 ES1.0 soc and update prcm, control module, dplls data.
Signed-off-by: Praneeth Bajjuri praneeth@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/include/asm/arch-omap5/omap.h | 1 + arch/arm/include/asm/omap_common.h | 8 ++++++++ arch/arm/mach-omap2/omap5/hw_data.c | 27 +++++++++++++++++++++++++++ arch/arm/mach-omap2/omap5/hwinit.c | 3 +++ 4 files changed, 39 insertions(+)
diff --git a/arch/arm/include/asm/arch-omap5/omap.h b/arch/arm/include/asm/arch-omap5/omap.h index 2f005dd3ad..3e15839858 100644 --- a/arch/arm/include/asm/arch-omap5/omap.h +++ b/arch/arm/include/asm/arch-omap5/omap.h @@ -58,6 +58,7 @@ #define OMAP5430_CONTROL_ID_CODE_ES2_0 0x1B94202F #define OMAP5432_CONTROL_ID_CODE_ES1_0 0x0B99802F #define OMAP5432_CONTROL_ID_CODE_ES2_0 0x1B99802F +#define DRA762_CONTROL_ID_CODE_ES1_0 0x0BB5002F #define DRA752_CONTROL_ID_CODE_ES1_0 0x0B99002F #define DRA752_CONTROL_ID_CODE_ES1_1 0x1B99002F #define DRA752_CONTROL_ID_CODE_ES2_0 0x2B99002F diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index ef5c481349..e951b232d6 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -722,6 +722,7 @@ static inline u8 is_omap54xx(void)
#define DRA7XX 0x07000000 #define DRA72X 0x07200000 +#define DRA76X 0x07600000
static inline u8 is_dra7xx(void) { @@ -734,6 +735,12 @@ static inline u8 is_dra72x(void) extern u32 *const omap_si_rev; return (*omap_si_rev & 0xFFF00000) == DRA72X; } + +static inline u8 is_dra76x(void) +{ + extern u32 *const omap_si_rev; + return ((*omap_si_rev & 0xFFF00000) == DRA76X); +} #endif
/* @@ -761,6 +768,7 @@ static inline u8 is_dra72x(void) #define OMAP5432_ES2_0 0x54320200
/* DRA7XX */ +#define DRA762_ES1_0 0x07620100 #define DRA752_ES1_0 0x07520100 #define DRA752_ES1_1 0x07520110 #define DRA752_ES2_0 0x07520200 diff --git a/arch/arm/mach-omap2/omap5/hw_data.c b/arch/arm/mach-omap2/omap5/hw_data.c index a8a6b8a869..4c4e245a6e 100644 --- a/arch/arm/mach-omap2/omap5/hw_data.c +++ b/arch/arm/mach-omap2/omap5/hw_data.c @@ -113,6 +113,16 @@ static const struct dpll_params per_dpll_params_768mhz_dra7xx[NUM_SYS_CLKS] = { {10, 0, 4, 1, 3, 4, 4, 2, -1, -1, -1, -1}, /* 38.4 MHz */ };
+static const struct dpll_params per_dpll_params_768mhz_dra76x[NUM_SYS_CLKS] = { + {32, 0, 4, 1, 3, 4, 8, 2, -1, -1, -1, -1}, /* 12 MHz */ + {96, 4, 4, 1, 3, 4, 8, 2, -1, -1, -1, -1}, /* 20 MHz */ + {160, 6, 4, 1, 3, 4, 8, 2, -1, -1, -1, -1}, /* 16.8 MHz */ + {20, 0, 4, 1, 3, 4, 8, 2, -1, -1, -1, -1}, /* 19.2 MHz */ + {192, 12, 4, 1, 3, 4, 8, 2, -1, -1, -1, -1}, /* 26 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {10, 0, 4, 1, 3, 4, 8, 2, -1, -1, -1, -1}, /* 38.4 MHz */ +}; + static const struct dpll_params iva_dpll_params_2330mhz[NUM_SYS_CLKS] = { {1165, 11, -1, -1, 5, 6, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ @@ -234,6 +244,17 @@ struct dplls omap5_dplls_es2 = { .ddr = NULL };
+struct dplls dra76x_dplls = { + .mpu = mpu_dpll_params_1ghz, + .core = core_dpll_params_2128mhz_dra7xx, + .per = per_dpll_params_768mhz_dra76x, + .abe = abe_dpll_params_sysclk2_361267khz, + .iva = iva_dpll_params_2330mhz_dra7xx, + .usb = usb_dpll_params_1920mhz, + .ddr = ddr_dpll_params_2664mhz, + .gmac = gmac_dpll_params_2000mhz, +}; + struct dplls dra7xx_dplls = { .mpu = mpu_dpll_params_1ghz, .core = core_dpll_params_2128mhz_dra7xx, @@ -700,6 +721,12 @@ void __weak hw_data_init(void) *ctrl = &omap5_ctrl; break;
+ case DRA762_ES1_0: + *prcm = &dra7xx_prcm; + *dplls_data = &dra76x_dplls; + *ctrl = &dra7xx_ctrl; + break; + case DRA752_ES1_0: case DRA752_ES1_1: case DRA752_ES2_0: diff --git a/arch/arm/mach-omap2/omap5/hwinit.c b/arch/arm/mach-omap2/omap5/hwinit.c index 2050560a37..e54547b5d9 100644 --- a/arch/arm/mach-omap2/omap5/hwinit.c +++ b/arch/arm/mach-omap2/omap5/hwinit.c @@ -362,6 +362,9 @@ void init_omap_revision(void) case OMAP5432_CONTROL_ID_CODE_ES2_0: *omap_si_rev = OMAP5432_ES2_0; break; + case DRA762_CONTROL_ID_CODE_ES1_0: + *omap_si_rev = DRA762_ES1_0; + break; case DRA752_CONTROL_ID_CODE_ES1_0: *omap_si_rev = DRA752_ES1_0; break;
- 2 X DSP
- 2 X Cortex-M4 IPU
- ISS
- CAL
- DSS
- VPE
- VIP
- 2 x SATA
- 2 x CAN
- MCAN
The dra76-evm is a board based on TI's DRA76 processor Add eeprom support
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/dra7xx/evm.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index ba3b477a6f..08d96c369d 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -34,6 +34,7 @@ #include "mux_data.h" #include "../common/board_detect.h"
+#define board_is_dra76x_evm() board_ti_is("DRA76/7x") #define board_is_dra74x_evm() board_ti_is("5777xCPU") #define board_is_dra72x_evm() board_ti_is("DRA72x-T") #define board_is_dra71x_evm() board_ti_is("DRA79x,D") @@ -547,6 +548,8 @@ int board_late_init(void) name = "dra71x"; else name = "dra72x"; + } else if (is_dra76x()) { + name = "dra76x"; } else { name = "dra7xx"; } @@ -595,6 +598,8 @@ void do_board_detect(void) bname = "DRA72x EVM"; } else if (board_is_dra71x_evm()) { bname = "DRA71x EVM"; + } else if (board_is_dra76x_evm()) { + bname = "DRA76x EVM"; } else { /* If EEPROM is not populated */ if (is_dra72x())
dra76-evm uses lp8736 and tps65917 pmic for powering on various peripherals. Add data for these pmics and register for dra76-evm.
Signed-off-by: Keerthy j-keerthy@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/include/asm/arch-omap5/clock.h | 9 ++++++ arch/arm/include/asm/omap_common.h | 1 + arch/arm/mach-omap2/omap5/hw_data.c | 16 +++++++++++ board/ti/dra7xx/evm.c | 50 +++++++++++++++++++++++++++++++++ 4 files changed, 76 insertions(+)
diff --git a/arch/arm/include/asm/arch-omap5/clock.h b/arch/arm/include/asm/arch-omap5/clock.h index 0c99bbdc93..d37c202c18 100644 --- a/arch/arm/include/asm/arch-omap5/clock.h +++ b/arch/arm/include/asm/arch-omap5/clock.h @@ -327,6 +327,9 @@ /* Offset is 0.73V for LP873x */ #define LP873X_BUCK_BASE_VOLT_UV 730000
+/* Offset is 0.73V for LP87565 */ +#define LP87565_BUCK_BASE_VOLT_UV 730000 + /* TPS659038 */ #define TPS659038_I2C_SLAVE_ADDR 0x58 #define TPS659038_REG_ADDR_SMPS12 0x23 @@ -340,6 +343,7 @@ #define TPS65917_REG_ADDR_SMPS1 0x23 #define TPS65917_REG_ADDR_SMPS2 0x27 #define TPS65917_REG_ADDR_SMPS3 0x2F +#define TPS65917_REG_ADDR_SMPS4 0x33
/* LP873X */ #define LP873X_I2C_SLAVE_ADDR 0x60 @@ -347,6 +351,11 @@ #define LP873X_REG_ADDR_BUCK1 0x7 #define LP873X_REG_ADDR_LDO1 0xA
+/* LP87565 */ +#define LP87565_I2C_SLAVE_ADDR 0x61 +#define LP87565_REG_ADDR_BUCK01 0xA +#define LP87565_REG_ADDR_BUCK23 0xE + /* TPS */ #define TPS62361_I2C_SLAVE_ADDR 0x60 #define TPS62361_REG_ADDR_SET0 0x0 diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index e951b232d6..b34ad41325 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -607,6 +607,7 @@ extern struct omap_sys_ctrl_regs const dra7xx_ctrl;
extern struct pmic_data tps659038; extern struct pmic_data lp8733; +extern struct pmic_data lp87565;
void hw_data_init(void);
diff --git a/arch/arm/mach-omap2/omap5/hw_data.c b/arch/arm/mach-omap2/omap5/hw_data.c index 4c4e245a6e..d6174fb5c7 100644 --- a/arch/arm/mach-omap2/omap5/hw_data.c +++ b/arch/arm/mach-omap2/omap5/hw_data.c @@ -306,6 +306,22 @@ struct pmic_data tps659038 = { .gpio_en = 0, };
+/* The LP87565*/ +struct pmic_data lp87565 = { + .base_offset = LP873X_BUCK_BASE_VOLT_UV, + .step = 5000, /* 5 mV represented in uV */ + /* + * Offset codes 0 - 0x13 Invalid. + * Offset codes 0x14 0x17 give 10mV steps + * Offset codes 0x17 through 0x9D give 5mV steps + * So let us start with our operating range from .73V + */ + .start_code = 0x17, + .i2c_slave_addr = 0x60, + .pmic_bus_init = gpi2c_init, + .pmic_write = palmas_i2c_write_u8, +}; + /* The LP8732 and LP8733 are software-compatible, use common struct */ struct pmic_data lp8733 = { .base_offset = LP873X_BUCK_BASE_VOLT_UV, diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 08d96c369d..7ae8d2ff73 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -357,6 +357,54 @@ struct vcores_data dra752_volts = { .iva.abb_tx_done_mask = OMAP_ABB_IVA_TXDONE_MASK, };
+struct vcores_data dra76x_volts = { + .mpu.value[OPP_NOM] = VDD_MPU_DRA7_NOM, + .mpu.efuse.reg[OPP_NOM] = STD_FUSE_OPP_VMIN_MPU_NOM, + .mpu.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .mpu.addr = LP87565_REG_ADDR_BUCK01, + .mpu.pmic = &lp87565, + .mpu.abb_tx_done_mask = OMAP_ABB_MPU_TXDONE_MASK, + + .eve.value[OPP_NOM] = VDD_EVE_DRA7_NOM, + .eve.value[OPP_OD] = VDD_EVE_DRA7_OD, + .eve.value[OPP_HIGH] = VDD_EVE_DRA7_HIGH, + .eve.efuse.reg[OPP_NOM] = STD_FUSE_OPP_VMIN_DSPEVE_NOM, + .eve.efuse.reg[OPP_OD] = STD_FUSE_OPP_VMIN_DSPEVE_OD, + .eve.efuse.reg[OPP_HIGH] = STD_FUSE_OPP_VMIN_DSPEVE_HIGH, + .eve.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .eve.addr = TPS65917_REG_ADDR_SMPS1, + .eve.pmic = &tps659038, + .eve.abb_tx_done_mask = OMAP_ABB_EVE_TXDONE_MASK, + + .gpu.value[OPP_NOM] = VDD_GPU_DRA7_NOM, + .gpu.value[OPP_OD] = VDD_GPU_DRA7_OD, + .gpu.value[OPP_HIGH] = VDD_GPU_DRA7_HIGH, + .gpu.efuse.reg[OPP_NOM] = STD_FUSE_OPP_VMIN_GPU_NOM, + .gpu.efuse.reg[OPP_OD] = STD_FUSE_OPP_VMIN_GPU_OD, + .gpu.efuse.reg[OPP_HIGH] = STD_FUSE_OPP_VMIN_GPU_HIGH, + .gpu.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .gpu.addr = LP87565_REG_ADDR_BUCK23, + .gpu.pmic = &lp87565, + .gpu.abb_tx_done_mask = OMAP_ABB_GPU_TXDONE_MASK, + + .core.value[OPP_NOM] = VDD_CORE_DRA7_NOM, + .core.efuse.reg[OPP_NOM] = STD_FUSE_OPP_VMIN_CORE_NOM, + .core.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .core.addr = TPS65917_REG_ADDR_SMPS3, + .core.pmic = &tps659038, + + .iva.value[OPP_NOM] = VDD_IVA_DRA7_NOM, + .iva.value[OPP_OD] = VDD_IVA_DRA7_OD, + .iva.value[OPP_HIGH] = VDD_IVA_DRA7_HIGH, + .iva.efuse.reg[OPP_NOM] = STD_FUSE_OPP_VMIN_IVA_NOM, + .iva.efuse.reg[OPP_OD] = STD_FUSE_OPP_VMIN_IVA_OD, + .iva.efuse.reg[OPP_HIGH] = STD_FUSE_OPP_VMIN_IVA_HIGH, + .iva.efuse.reg_bits = DRA752_EFUSE_REGBITS, + .iva.addr = TPS65917_REG_ADDR_SMPS4, + .iva.pmic = &tps659038, + .iva.abb_tx_done_mask = OMAP_ABB_IVA_TXDONE_MASK, +}; + struct vcores_data dra722_volts = { .mpu.value[OPP_NOM] = VDD_MPU_DRA7_NOM, .mpu.efuse.reg[OPP_NOM] = STD_FUSE_OPP_VMIN_MPU_NOM, @@ -622,6 +670,8 @@ void vcores_init(void) *omap_vcores = &dra722_volts; } else if (board_is_dra71x_evm()) { *omap_vcores = &dra718_volts; + } else if (board_is_dra76x_evm()) { + *omap_vcores = &dra76x_volts; } else { /* If EEPROM is not populated */ if (is_dra72x())
dra76-evm has the ddr parts connectedi running at 666MHz: EMIF1: MT41K512M16HA-125 AIT:A x 2 EMIF2: MT41K512M8RH-125-AAT:E x 4 Add support for configuring the above DDR parts.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/mach-omap2/omap5/hw_data.c | 1 + arch/arm/mach-omap2/omap5/sdram.c | 2 ++ board/ti/dra7xx/evm.c | 61 +++++++++++++++++++++++++++++++++++-- 3 files changed, 62 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-omap2/omap5/hw_data.c b/arch/arm/mach-omap2/omap5/hw_data.c index d6174fb5c7..d0d5d6804c 100644 --- a/arch/arm/mach-omap2/omap5/hw_data.c +++ b/arch/arm/mach-omap2/omap5/hw_data.c @@ -781,6 +781,7 @@ void get_ioregs(const struct ctrl_ioregs **regs) case DRA752_ES1_0: case DRA752_ES1_1: case DRA752_ES2_0: + case DRA762_ES1_0: *regs = &ioregs_dra7xx_es1; break; case DRA722_ES1_0: diff --git a/arch/arm/mach-omap2/omap5/sdram.c b/arch/arm/mach-omap2/omap5/sdram.c index 7712923d85..67ff63b9f6 100644 --- a/arch/arm/mach-omap2/omap5/sdram.c +++ b/arch/arm/mach-omap2/omap5/sdram.c @@ -480,6 +480,7 @@ void __weak emif_get_ext_phy_ctrl_const_regs(u32 emif_nr, *regs = dra_ddr3_ext_phy_ctrl_const_base_666MHz; *size = ARRAY_SIZE(dra_ddr3_ext_phy_ctrl_const_base_666MHz); break; + case DRA762_ES1_0: case DRA722_ES2_0: *regs = dra_ddr3_ext_phy_ctrl_const_base_666MHz_es2; *size = ARRAY_SIZE(dra_ddr3_ext_phy_ctrl_const_base_666MHz_es2); @@ -709,6 +710,7 @@ const struct read_write_regs *get_bug_regs(u32 *iterations) *iterations = sizeof(omap5_bug_00339_regs)/ sizeof(omap5_bug_00339_regs[0]); break; + case DRA762_ES1_0: case DRA752_ES1_0: case DRA752_ES1_1: case DRA752_ES2_0: diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 7ae8d2ff73..f9d0b05a16 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -210,6 +210,56 @@ const struct emif_regs emif2_ddr3_532_mhz_1cs_2G = { .emif_rd_wr_exec_thresh = 0x00000305 };
+const struct emif_regs emif_1_regs_ddr3_666_mhz_1cs_dra76 = { + .sdram_config_init = 0x61862B32, + .sdram_config = 0x61862B32, + .sdram_config2 = 0x00000000, + .ref_ctrl = 0x0000514C, + .ref_ctrl_final = 0x0000144A, + .sdram_tim1 = 0xD113783C, + .sdram_tim2 = 0x30B47FE3, + .sdram_tim3 = 0x409F8AD8, + .read_idle_ctrl = 0x00050000, + .zq_config = 0x5007190B, + .temp_alert_config = 0x00000000, + .emif_ddr_phy_ctlr_1_init = 0x0824400D, + .emif_ddr_phy_ctlr_1 = 0x0E24400D, + .emif_ddr_ext_phy_ctrl_1 = 0x04040100, + .emif_ddr_ext_phy_ctrl_2 = 0x006B009F, + .emif_ddr_ext_phy_ctrl_3 = 0x006B00A2, + .emif_ddr_ext_phy_ctrl_4 = 0x006B00A8, + .emif_ddr_ext_phy_ctrl_5 = 0x006B00A8, + .emif_rd_wr_lvl_rmp_win = 0x00000000, + .emif_rd_wr_lvl_rmp_ctl = 0x80000000, + .emif_rd_wr_lvl_ctl = 0x00000000, + .emif_rd_wr_exec_thresh = 0x00000305 +}; + +const struct emif_regs emif_2_regs_ddr3_666_mhz_1cs_dra76 = { + .sdram_config_init = 0x61862B32, + .sdram_config = 0x61862B32, + .sdram_config2 = 0x00000000, + .ref_ctrl = 0x0000514C, + .ref_ctrl_final = 0x0000144A, + .sdram_tim1 = 0xD113781C, + .sdram_tim2 = 0x30B47FE3, + .sdram_tim3 = 0x409F8AD8, + .read_idle_ctrl = 0x00050000, + .zq_config = 0x5007190B, + .temp_alert_config = 0x00000000, + .emif_ddr_phy_ctlr_1_init = 0x0824400D, + .emif_ddr_phy_ctlr_1 = 0x0E24400D, + .emif_ddr_ext_phy_ctrl_1 = 0x04040100, + .emif_ddr_ext_phy_ctrl_2 = 0x006B009F, + .emif_ddr_ext_phy_ctrl_3 = 0x006B00A2, + .emif_ddr_ext_phy_ctrl_4 = 0x006B00A8, + .emif_ddr_ext_phy_ctrl_5 = 0x006B00A8, + .emif_rd_wr_lvl_rmp_win = 0x00000000, + .emif_rd_wr_lvl_rmp_ctl = 0x80000000, + .emif_rd_wr_lvl_ctl = 0x00000000, + .emif_rd_wr_exec_thresh = 0x00000305 +}; + void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs) { u64 ram_size; @@ -235,6 +285,12 @@ void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs) break; } break; + case DRA762_ES1_0: + if (emif_nr == 1) + *regs = &emif_1_regs_ddr3_666_mhz_1cs_dra76; + else + *regs = &emif_2_regs_ddr3_666_mhz_1cs_dra76; + break; case DRA722_ES1_0: case DRA722_ES2_0: if (ram_size < CONFIG_MAX_MEM_MAPPED) @@ -290,6 +346,7 @@ void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) ram_size = board_ti_get_emif_size();
switch (omap_revision()) { + case DRA762_ES1_0: case DRA752_ES1_0: case DRA752_ES1_1: case DRA752_ES2_0: @@ -1010,8 +1067,8 @@ static inline void vtt_regulator_enable(void) if (omap_hw_init_context() == OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL) return;
- /* Do not enable VTT for DRA722 */ - if (is_dra72x()) + /* Do not enable VTT for DRA722 or DRA76x */ + if (is_dra72x() || is_dra76x()) return;
Adding pinmux and IODELAY data for dra76-evm.
Signed-off-by: Vignesh R vigneshr@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/dra7xx/evm.c | 6 + board/ti/dra7xx/mux_data.h | 294 +++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 300 insertions(+)
diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index f9d0b05a16..d66bbeafca 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -783,6 +783,12 @@ void recalibrate_iodelay(void) iodelay = dra742_es1_1_iodelay_cfg_array; niodelays = ARRAY_SIZE(dra742_es1_1_iodelay_cfg_array); break; + case DRA762_ES1_0: + pads = dra76x_core_padconf_array; + npads = ARRAY_SIZE(dra76x_core_padconf_array); + iodelay = dra76x_es1_0_iodelay_cfg_array; + niodelays = ARRAY_SIZE(dra76x_es1_0_iodelay_cfg_array); + break; default: case DRA752_ES2_0: pads = dra74x_core_padconf_array; diff --git a/board/ti/dra7xx/mux_data.h b/board/ti/dra7xx/mux_data.h index 2cc4be31b2..3c3a19a0e1 100644 --- a/board/ti/dra7xx/mux_data.h +++ b/board/ti/dra7xx/mux_data.h @@ -698,6 +698,194 @@ const struct pad_conf_entry dra74x_core_padconf_array[] = { {WAKEUP2, (M14)}, /* Wakeup2.gpio1_2 */ };
+const struct pad_conf_entry dra76x_core_padconf_array[] = { + {GPMC_AD0, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad0.vout3_d0 */ + {GPMC_AD1, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad1.vout3_d1 */ + {GPMC_AD2, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad2.vout3_d2 */ + {GPMC_AD3, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad3.vout3_d3 */ + {GPMC_AD4, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad4.vout3_d4 */ + {GPMC_AD5, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad5.vout3_d5 */ + {GPMC_AD6, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad6.vout3_d6 */ + {GPMC_AD7, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad7.vout3_d7 */ + {GPMC_AD8, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad8.vout3_d8 */ + {GPMC_AD9, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad9.vout3_d9 */ + {GPMC_AD10, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad10.vout3_d10 */ + {GPMC_AD11, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad11.vout3_d11 */ + {GPMC_AD12, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad12.vout3_d12 */ + {GPMC_AD13, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad13.vout3_d13 */ + {GPMC_AD14, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad14.vout3_d14 */ + {GPMC_AD15, (M3 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_ad15.vout3_d15 */ + {GPMC_A0, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a0.vout3_d16 */ + {GPMC_A1, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a1.vout3_d17 */ + {GPMC_A2, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a2.vout3_d18 */ + {GPMC_A3, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a3.vout3_d19 */ + {GPMC_A4, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a4.vout3_d20 */ + {GPMC_A5, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a5.vout3_d21 */ + {GPMC_A6, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a6.vout3_d22 */ + {GPMC_A7, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a7.vout3_d23 */ + {GPMC_A8, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a8.vout3_hsync */ + {GPMC_A9, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a9.vout3_vsync */ + {GPMC_A10, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a10.vout3_de */ + {GPMC_A11, (M14 | PIN_INPUT_PULLUP)}, /* gpmc_a11.gpio2_1 */ + {GPMC_A12, (M14 | PIN_INPUT_PULLUP)}, /* gpmc_a12.gpio2_2 */ + {GPMC_A13, (M1 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a13.qspi1_rtclk */ + {GPMC_A14, (M1 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a14.qspi1_d3 */ + {GPMC_A15, (M1 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a15.qspi1_d2 */ + {GPMC_A16, (M1 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a16.qspi1_d0 */ + {GPMC_A17, (M1 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a17.qspi1_d1 */ + {GPMC_A18, (M1 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* gpmc_a18.qspi1_sclk */ + {GPMC_A19, (M1 | PIN_INPUT_PULLDOWN)}, /* gpmc_a19.mmc2_dat4 */ + {GPMC_A20, (M1 | PIN_INPUT_PULLDOWN)}, /* gpmc_a20.mmc2_dat5 */ + {GPMC_A21, (M1 | PIN_INPUT_PULLDOWN)}, /* gpmc_a21.mmc2_dat6 */ + {GPMC_A22, (M1 | PIN_INPUT_PULLDOWN)}, /* gpmc_a22.mmc2_dat7 */ + {GPMC_A23, (M1 | PIN_INPUT_PULLDOWN)}, /* gpmc_a23.mmc2_clk */ + {GPMC_A24, (M1 | PIN_INPUT_PULLDOWN)}, /* gpmc_a24.mmc2_dat0 */ + {GPMC_A25, (M1 | PIN_INPUT_PULLDOWN)}, /* gpmc_a25.mmc2_dat1 */ + {GPMC_A26, (M1 | PIN_INPUT_PULLDOWN)}, /* gpmc_a26.mmc2_dat2 */ + {GPMC_A27, (M1 | PIN_INPUT_PULLDOWN)}, /* gpmc_a27.mmc2_dat3 */ + {GPMC_CS1, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_cs1.mmc2_cmd */ + {GPMC_CS0, (M0 | PIN_INPUT_PULLUP)}, /* gpmc_cs0.gpmc_cs0 */ + {GPMC_CS2, (M1 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_cs2.qspi1_cs0 */ + {GPMC_CS3, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* gpmc_cs3.vout3_clk */ + {GPMC_ADVN_ALE, (M0 | PIN_INPUT_PULLUP)}, /* gpmc_advn_ale.gpmc_advn_ale */ + {GPMC_OEN_REN, (M0 | PIN_INPUT_PULLUP)}, /* gpmc_oen_ren.gpmc_oen_ren */ + {GPMC_WEN, (M0 | PIN_INPUT_PULLUP)}, /* gpmc_wen.gpmc_wen */ + {GPMC_BEN0, (M0 | PIN_INPUT_PULLUP)}, /* gpmc_ben0.gpmc_ben0 */ + {GPMC_WAIT0, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* gpmc_wait0.gpmc_wait0 */ + {VIN1A_FLD0, (M14 | PIN_INPUT_PULLUP)}, /* vin1a_fld0.gpio3_1 */ + {VIN2A_CLK0, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_clk0.vin2a_clk0 */ + {VIN2A_DE0, (M15 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_de0.Driveroff */ + {VIN2A_FLD0, (M14 | PIN_INPUT_PULLDOWN)}, /* vin2a_fld0.gpio3_30 */ + {VIN2A_HSYNC0, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_hsync0.vin2a_hsync0 */ + {VIN2A_VSYNC0, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_vsync0.vin2a_vsync0 */ + {VIN2A_D0, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d0.vin2a_d0 */ + {VIN2A_D1, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d1.vin2a_d1 */ + {VIN2A_D2, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d2.vin2a_d2 */ + {VIN2A_D3, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d3.vin2a_d3 */ + {VIN2A_D4, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d4.vin2a_d4 */ + {VIN2A_D5, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d5.vin2a_d5 */ + {VIN2A_D6, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d6.vin2a_d6 */ + {VIN2A_D7, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d7.vin2a_d7 */ + {VIN2A_D8, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d8.vin2a_d8 */ + {VIN2A_D9, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d9.vin2a_d9 */ + {VIN2A_D10, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d10.vin2a_d10 */ + {VIN2A_D11, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d11.vin2a_d11 */ + {VIN2A_D12, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d12.rgmii1_txc */ + {VIN2A_D13, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d13.rgmii1_txctl */ + {VIN2A_D14, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d14.rgmii1_txd3 */ + {VIN2A_D15, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d15.rgmii1_txd2 */ + {VIN2A_D16, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d16.rgmii1_txd1 */ + {VIN2A_D17, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d17.rgmii1_txd0 */ + {VIN2A_D18, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d18.rgmii1_rxc */ + {VIN2A_D19, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d19.rgmii1_rxctl */ + {VIN2A_D20, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d20.rgmii1_rxd3 */ + {VIN2A_D21, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d21.rgmii1_rxd2 */ + {VIN2A_D22, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d22.rgmii1_rxd1 */ + {VIN2A_D23, (M3 | PIN_INPUT | MANUAL_MODE)}, /* vin2a_d23.rgmii1_rxd0 */ + {VOUT1_CLK, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_clk.vout1_clk */ + {VOUT1_DE, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_de.vout1_de */ + {VOUT1_FLD, (M14 | PIN_INPUT_PULLUP)}, /* vout1_fld.gpio4_21 */ + {VOUT1_HSYNC, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_hsync.vout1_hsync */ + {VOUT1_VSYNC, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_vsync.vout1_vsync */ + {VOUT1_D0, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d0.vout1_d0 */ + {VOUT1_D1, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d1.vout1_d1 */ + {VOUT1_D2, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d2.vout1_d2 */ + {VOUT1_D3, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d3.vout1_d3 */ + {VOUT1_D4, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d4.vout1_d4 */ + {VOUT1_D5, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d5.vout1_d5 */ + {VOUT1_D6, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d6.vout1_d6 */ + {VOUT1_D7, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d7.vout1_d7 */ + {VOUT1_D8, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d8.vout1_d8 */ + {VOUT1_D9, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d9.vout1_d9 */ + {VOUT1_D10, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d10.vout1_d10 */ + {VOUT1_D11, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d11.vout1_d11 */ + {VOUT1_D12, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d12.vout1_d12 */ + {VOUT1_D13, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d13.vout1_d13 */ + {VOUT1_D14, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d14.vout1_d14 */ + {VOUT1_D15, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d15.vout1_d15 */ + {VOUT1_D16, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d16.vout1_d16 */ + {VOUT1_D17, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d17.vout1_d17 */ + {VOUT1_D18, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d18.vout1_d18 */ + {VOUT1_D19, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d19.vout1_d19 */ + {VOUT1_D20, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d20.vout1_d20 */ + {VOUT1_D21, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d21.vout1_d21 */ + {VOUT1_D22, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d22.vout1_d22 */ + {VOUT1_D23, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vout1_d23.vout1_d23 */ + {MDIO_MCLK, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mdio_mclk.mdio_mclk */ + {MDIO_D, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mdio_d.mdio_d */ + {RGMII0_TXC, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_txc.rgmii0_txc */ + {RGMII0_TXCTL, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_txctl.rgmii0_txctl */ + {RGMII0_TXD3, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_txd3.rgmii0_txd3 */ + {RGMII0_TXD2, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_txd2.rgmii0_txd2 */ + {RGMII0_TXD1, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_txd1.rgmii0_txd1 */ + {RGMII0_TXD0, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_txd0.rgmii0_txd0 */ + {RGMII0_RXC, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_rxc.rgmii0_rxc */ + {RGMII0_RXCTL, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_rxctl.rgmii0_rxctl */ + {RGMII0_RXD3, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_rxd3.rgmii0_rxd3 */ + {RGMII0_RXD2, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_rxd2.rgmii0_rxd2 */ + {RGMII0_RXD1, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_rxd1.rgmii0_rxd1 */ + {RGMII0_RXD0, (M0 | PIN_INPUT | MANUAL_MODE)}, /* rgmii0_rxd0.rgmii0_rxd0 */ + {USB1_DRVVBUS, (M0 | PIN_INPUT_SLEW)}, /* usb1_drvvbus.usb1_drvvbus */ + {USB2_DRVVBUS, (M0 | PIN_INPUT_SLEW)}, /* usb2_drvvbus.usb2_drvvbus */ + {GPIO6_14, (M9 | PIN_INPUT_PULLUP)}, /* gpio6_14.i2c3_sda */ + {GPIO6_15, (M9 | PIN_INPUT_PULLUP)}, /* gpio6_15.i2c3_scl */ + {GPIO6_16, (M0 | PIN_INPUT_PULLUP)}, /* gpio6_16.gpio6_16 */ + {XREF_CLK2, (M5 | PIN_INPUT_PULLDOWN)}, /* xref_clk2.atl_clk2 */ + {MCASP1_ACLKX, (M14 | 0x00070000)}, /* mcasp1_aclkx.gpio7_31 */ + {MCASP1_FSX, (M14 | PIN_INPUT | SLEWCONTROL)}, /* mcasp1_fsx.gpio7_30 */ + {MCASP1_AXR0, (M10 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp1_axr0.i2c5_sda */ + {MCASP1_AXR1, (M10 | 0x000f0000)}, /* mcasp1_axr1.i2c5_scl */ + {MCASP1_AXR2, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr2.gpio5_4 */ + {MCASP1_AXR3, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr3.gpio5_5 */ + {MCASP1_AXR4, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr4.gpio5_6 */ + {MCASP1_AXR5, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr5.gpio5_7 */ + {MCASP1_AXR6, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr6.gpio5_8 */ + {MCASP1_AXR7, (M14 | PIN_INPUT_PULLDOWN)}, /* mcasp1_axr7.gpio5_9 */ + {MCASP1_AXR12, (M1 | PIN_INPUT_SLEW | VIRTUAL_MODE10)}, /* mcasp1_axr12.mcasp7_axr0 */ + {MCASP1_AXR13, (M1 | PIN_INPUT_SLEW)}, /* mcasp1_axr13.mcasp7_axr1 */ + {MCASP1_AXR14, (M1 | PIN_INPUT_SLEW | VIRTUAL_MODE10)}, /* mcasp1_axr14.mcasp7_aclkx */ + {MCASP1_AXR15, (M1 | PIN_INPUT_SLEW | VIRTUAL_MODE10)}, /* mcasp1_axr15.mcasp7_fsx */ + {MCASP2_ACLKR, (M15 | PIN_INPUT_PULLUP)}, /* mcasp2_aclkr.Driveroff */ + {MCASP3_ACLKX, (M0 | PIN_INPUT_PULLDOWN)}, /* mcasp3_aclkx.mcasp3_aclkx */ + {MCASP3_FSX, (M0 | PIN_INPUT_SLEW)}, /* mcasp3_fsx.mcasp3_fsx */ + {MCASP3_AXR0, (M0 | PIN_INPUT_SLEW)}, /* mcasp3_axr0.mcasp3_axr0 */ + {MCASP3_AXR1, (M0 | PIN_INPUT_SLEW | VIRTUAL_MODE6)}, /* mcasp3_axr1.mcasp3_axr1 */ + {MMC1_CLK, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_clk.mmc1_clk */ + {MMC1_CMD, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_cmd.mmc1_cmd */ + {MMC1_DAT0, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat0.mmc1_dat0 */ + {MMC1_DAT1, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat1.mmc1_dat1 */ + {MMC1_DAT2, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat2.mmc1_dat2 */ + {MMC1_DAT3, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat3.mmc1_dat3 */ + {MMC1_SDCD, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mmc1_sdcd.mmc1_sdcd */ + {MMC1_SDWP, (M14 | PIN_INPUT_SLEW)}, /* mmc1_sdwp.gpio6_28 */ + {SPI1_SCLK, (M0 | PIN_INPUT_PULLDOWN)}, /* spi1_sclk.spi1_sclk */ + {SPI1_D1, (M0 | PIN_INPUT_PULLDOWN)}, /* spi1_d1.spi1_d1 */ + {SPI1_D0, (M0 | PIN_INPUT_PULLDOWN)}, /* spi1_d0.spi1_d0 */ + {SPI1_CS0, (M0 | PIN_INPUT_PULLUP)}, /* spi1_cs0.spi1_cs0 */ + {SPI1_CS2, (M6 | 0x000f0000)}, /* spi1_cs2.hdmi1_hpd */ + {SPI1_CS3, (M6 | 0x000f0000)}, /* spi1_cs3.hdmi1_cec */ + {SPI2_SCLK, (M1 | PIN_INPUT_PULLDOWN)}, /* spi2_sclk.uart3_rxd */ + {SPI2_D1, (M1 | PIN_INPUT_SLEW)}, /* spi2_d1.uart3_txd */ + {SPI2_D0, (M1 | PIN_INPUT_SLEW)}, /* spi2_d0.uart3_ctsn */ + {SPI2_CS0, (M1 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* spi2_cs0.uart3_rtsn */ + {DCAN1_TX, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* dcan1_tx.dcan1_tx */ + {DCAN1_RX, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* dcan1_rx.dcan1_rx */ + {UART1_RXD, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* uart1_rxd.uart1_rxd */ + {UART1_TXD, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* uart1_txd.uart1_txd */ + {UART1_CTSN, (M3 | PIN_INPUT_PULLUP)}, /* uart1_ctsn.mmc4_clk */ + {UART1_RTSN, (M3 | PIN_INPUT_PULLUP)}, /* uart1_rtsn.mmc4_cmd */ + {UART2_RXD, (M3 | PIN_INPUT_PULLUP)}, /* N/A.mmc4_dat0 */ + {UART2_TXD, (M3 | PIN_INPUT_PULLUP)}, /* uart2_txd.mmc4_dat1 */ + {UART2_CTSN, (M3 | PIN_INPUT_PULLUP)}, /* uart2_ctsn.mmc4_dat2 */ + {UART2_RTSN, (M3 | PIN_INPUT_PULLUP)}, /* uart2_rtsn.mmc4_dat3 */ + {I2C2_SDA, (M1 | PIN_INPUT_PULLUP)}, /* i2c2_sda.hdmi1_ddc_scl */ + {I2C2_SCL, (M1 | PIN_INPUT_PULLUP)}, /* i2c2_scl.hdmi1_ddc_sda */ + {WAKEUP0, (M14 | PIN_OUTPUT)}, /* N/A.gpio1_0 */ + {WAKEUP1, (M14 | PIN_OUTPUT)}, /* N/A.gpio1_1 */ + {WAKEUP2, (M1 | PIN_OUTPUT)}, /* N/A.sys_nirq2 */ + {WAKEUP3, (M1 | PIN_OUTPUT)}, /* N/A.sys_nirq1 */ +}; + #ifdef CONFIG_IODELAY_RECALIBRATION const struct iodelay_cfg_entry dra742_es1_1_iodelay_cfg_array[] = { {0x06F0, 480, 0}, /* CFG_RGMII0_RXC_IN */ @@ -826,6 +1014,112 @@ const struct iodelay_cfg_entry dra742_es2_0_iodelay_cfg_array[] = { {0x0188, 590, 0}, /* CFG_GPMC_A18_OUT */ {0x0374, 0, 0}, /* CFG_GPMC_CS2_OUT */ }; + +const struct iodelay_cfg_entry dra76x_es1_0_iodelay_cfg_array[] = { + {0x011C, 787, 0}, /* CFG_GPMC_A0_OUT */ + {0x0128, 1181, 0}, /* CFG_GPMC_A10_OUT */ + {0x0144, 0, 0}, /* CFG_GPMC_A13_IN */ + {0x0150, 2149, 1052}, /* CFG_GPMC_A14_IN */ + {0x015C, 2121, 997}, /* CFG_GPMC_A15_IN */ + {0x0168, 2159, 1134}, /* CFG_GPMC_A16_IN */ + {0x0170, 0, 0}, /* CFG_GPMC_A16_OUT */ + {0x0174, 2135, 1085}, /* CFG_GPMC_A17_IN */ + {0x0188, 0, 0}, /* CFG_GPMC_A18_OUT */ + {0x01A0, 592, 0}, /* CFG_GPMC_A1_OUT */ + {0x020C, 641, 0}, /* CFG_GPMC_A2_OUT */ + {0x0218, 1481, 0}, /* CFG_GPMC_A3_OUT */ + {0x0224, 1775, 0}, /* CFG_GPMC_A4_OUT */ + {0x0230, 785, 0}, /* CFG_GPMC_A5_OUT */ + {0x023C, 848, 0}, /* CFG_GPMC_A6_OUT */ + {0x0248, 851, 0}, /* CFG_GPMC_A7_OUT */ + {0x0254, 1783, 0}, /* CFG_GPMC_A8_OUT */ + {0x0260, 951, 0}, /* CFG_GPMC_A9_OUT */ + {0x026C, 1091, 0}, /* CFG_GPMC_AD0_OUT */ + {0x0278, 1027, 0}, /* CFG_GPMC_AD10_OUT */ + {0x0284, 824, 0}, /* CFG_GPMC_AD11_OUT */ + {0x0290, 1196, 0}, /* CFG_GPMC_AD12_OUT */ + {0x029C, 754, 0}, /* CFG_GPMC_AD13_OUT */ + {0x02A8, 665, 0}, /* CFG_GPMC_AD14_OUT */ + {0x02B4, 1027, 0}, /* CFG_GPMC_AD15_OUT */ + {0x02C0, 937, 0}, /* CFG_GPMC_AD1_OUT */ + {0x02CC, 1168, 0}, /* CFG_GPMC_AD2_OUT */ + {0x02D8, 872, 0}, /* CFG_GPMC_AD3_OUT */ + {0x02E4, 1092, 0}, /* CFG_GPMC_AD4_OUT */ + {0x02F0, 576, 0}, /* CFG_GPMC_AD5_OUT */ + {0x02FC, 1113, 0}, /* CFG_GPMC_AD6_OUT */ + {0x0308, 943, 0}, /* CFG_GPMC_AD7_OUT */ + {0x0314, 0, 0}, /* CFG_GPMC_AD8_OUT */ + {0x0320, 0, 0}, /* CFG_GPMC_AD9_OUT */ + {0x0374, 0, 0}, /* CFG_GPMC_CS2_OUT */ + {0x0380, 1801, 948}, /* CFG_GPMC_CS3_OUT */ + {0x06F0, 451, 0}, /* CFG_RGMII0_RXC_IN */ + {0x06FC, 127, 1571}, /* CFG_RGMII0_RXCTL_IN */ + {0x0708, 165, 1178}, /* CFG_RGMII0_RXD0_IN */ + {0x0714, 136, 1302}, /* CFG_RGMII0_RXD1_IN */ + {0x0720, 0, 1520}, /* CFG_RGMII0_RXD2_IN */ + {0x072C, 28, 1690}, /* CFG_RGMII0_RXD3_IN */ + {0x0740, 121, 0}, /* CFG_RGMII0_TXC_OUT */ + {0x074C, 60, 0}, /* CFG_RGMII0_TXCTL_OUT */ + {0x0758, 153, 0}, /* CFG_RGMII0_TXD0_OUT */ + {0x0764, 35, 0}, /* CFG_RGMII0_TXD1_OUT */ + {0x0770, 0, 0}, /* CFG_RGMII0_TXD2_OUT */ + {0x077C, 172, 0}, /* CFG_RGMII0_TXD3_OUT */ + {0x0A38, 0, 0}, /* CFG_VIN2A_CLK0_IN */ + {0x0A44, 2180, 0}, /* CFG_VIN2A_D0_IN */ + {0x0A50, 2297, 110}, /* CFG_VIN2A_D10_IN */ + {0x0A5C, 1938, 0}, /* CFG_VIN2A_D11_IN */ + {0x0A70, 147, 0}, /* CFG_VIN2A_D12_OUT */ + {0x0A7C, 110, 0}, /* CFG_VIN2A_D13_OUT */ + {0x0A88, 18, 0}, /* CFG_VIN2A_D14_OUT */ + {0x0A94, 82, 0}, /* CFG_VIN2A_D15_OUT */ + {0x0AA0, 33, 0}, /* CFG_VIN2A_D16_OUT */ + {0x0AAC, 0, 0}, /* CFG_VIN2A_D17_OUT */ + {0x0AB0, 417, 0}, /* CFG_VIN2A_D18_IN */ + {0x0ABC, 156, 843}, /* CFG_VIN2A_D19_IN */ + {0x0AC8, 2326, 309}, /* CFG_VIN2A_D1_IN */ + {0x0AD4, 223, 1413}, /* CFG_VIN2A_D20_IN */ + {0x0AE0, 169, 1415}, /* CFG_VIN2A_D21_IN */ + {0x0AEC, 43, 1150}, /* CFG_VIN2A_D22_IN */ + {0x0AF8, 0, 1210}, /* CFG_VIN2A_D23_IN */ + {0x0B04, 2057, 0}, /* CFG_VIN2A_D2_IN */ + {0x0B10, 2440, 257}, /* CFG_VIN2A_D3_IN */ + {0x0B1C, 2142, 0}, /* CFG_VIN2A_D4_IN */ + {0x0B28, 2455, 252}, /* CFG_VIN2A_D5_IN */ + {0x0B34, 1883, 0}, /* CFG_VIN2A_D6_IN */ + {0x0B40, 2229, 0}, /* CFG_VIN2A_D7_IN */ + {0x0B4C, 2250, 151}, /* CFG_VIN2A_D8_IN */ + {0x0B58, 2279, 27}, /* CFG_VIN2A_D9_IN */ + {0x0B7C, 2233, 0}, /* CFG_VIN2A_HSYNC0_IN */ + {0x0B88, 1936, 0}, /* CFG_VIN2A_VSYNC0_IN */ + {0x0B9C, 1281, 497}, /* CFG_VOUT1_CLK_OUT */ + {0x0BA8, 379, 0}, /* CFG_VOUT1_D0_OUT */ + {0x0BB4, 441, 0}, /* CFG_VOUT1_D10_OUT */ + {0x0BC0, 461, 0}, /* CFG_VOUT1_D11_OUT */ + {0x0BCC, 1189, 0}, /* CFG_VOUT1_D12_OUT */ + {0x0BD8, 312, 0}, /* CFG_VOUT1_D13_OUT */ + {0x0BE4, 298, 0}, /* CFG_VOUT1_D14_OUT */ + {0x0BF0, 284, 0}, /* CFG_VOUT1_D15_OUT */ + {0x0BFC, 152, 0}, /* CFG_VOUT1_D16_OUT */ + {0x0C08, 216, 0}, /* CFG_VOUT1_D17_OUT */ + {0x0C14, 408, 0}, /* CFG_VOUT1_D18_OUT */ + {0x0C20, 519, 0}, /* CFG_VOUT1_D19_OUT */ + {0x0C2C, 475, 0}, /* CFG_VOUT1_D1_OUT */ + {0x0C38, 316, 0}, /* CFG_VOUT1_D20_OUT */ + {0x0C44, 59, 0}, /* CFG_VOUT1_D21_OUT */ + {0x0C50, 221, 0}, /* CFG_VOUT1_D22_OUT */ + {0x0C5C, 96, 0}, /* CFG_VOUT1_D23_OUT */ + {0x0C68, 264, 0}, /* CFG_VOUT1_D2_OUT */ + {0x0C74, 421, 0}, /* CFG_VOUT1_D3_OUT */ + {0x0C80, 1257, 0}, /* CFG_VOUT1_D4_OUT */ + {0x0C8C, 432, 0}, /* CFG_VOUT1_D5_OUT */ + {0x0C98, 436, 0}, /* CFG_VOUT1_D6_OUT */ + {0x0CA4, 440, 0}, /* CFG_VOUT1_D7_OUT */ + {0x0CB0, 81, 100}, /* CFG_VOUT1_D8_OUT */ + {0x0CBC, 471, 0}, /* CFG_VOUT1_D9_OUT */ + {0x0CC8, 0, 0}, /* CFG_VOUT1_DE_OUT */ + {0x0CE0, 0, 0}, /* CFG_VOUT1_HSYNC_OUT */ + {0x0CEC, 815, 0}, /* CFG_VOUT1_VSYNC_OUT */ +}; #endif
#endif /* _MUX_DATA_DRA7XX_H_ */
ldo4 is used to poweron mmc on dra76-evm. Enable it.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/dra7xx/evm.c | 2 ++ include/palmas.h | 4 ++++ 2 files changed, 6 insertions(+)
diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index d66bbeafca..14c06f5eda 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -837,6 +837,8 @@ void board_mmc_poweron_ldo(uint voltage) else if (voltage == LDO_VOLT_1V8) voltage = 0xa; lp873x_mmc1_poweron_ldo(voltage); + } else if (board_is_dra76x_evm()) { + palmas_mmc1_poweron_ldo(LDO4_VOLTAGE, LDO4_CTRL, voltage); } else { palmas_mmc1_poweron_ldo(LDO1_VOLTAGE, LDO1_CTRL, voltage); } diff --git a/include/palmas.h b/include/palmas.h index 404c2b3ca7..d366c98d22 100644 --- a/include/palmas.h +++ b/include/palmas.h @@ -38,6 +38,10 @@ #define LDO2_CTRL 0x52 #define LDO2_VOLTAGE 0x53
+/* LDO2 control/voltage */ +#define LDO4_CTRL 0x5e +#define LDO4_VOLTAGE 0x5f + /* LDO9 control/voltage */ #define LDO9_CTRL 0x60 #define LDO9_VOLTAGE 0x61
Select dtb name for dra76-evm.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- include/environment/ti/boot.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/environment/ti/boot.h b/include/environment/ti/boot.h index 1c3ae40a99..01f7f7a300 100644 --- a/include/environment/ti/boot.h +++ b/include/environment/ti/boot.h @@ -44,6 +44,8 @@ "setenv fdtfile dra72-evm.dtb; fi;" \ "if test $board_name = dra71x; then " \ "setenv fdtfile dra71-evm.dtb; fi;" \ + "if test $board_name = dra76x; then " \ + "setenv fdtfile dra76-evm.dtb; fi;" \ "if test $board_name = beagle_x15; then " \ "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ "if test $board_name = beagle_x15_revb1; then " \
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/dts/dra7-evm.dts | 276 ++++------------------------------------------ 1 file changed, 23 insertions(+), 253 deletions(-)
diff --git a/arch/arm/dts/dra7-evm.dts b/arch/arm/dts/dra7-evm.dts index 4d882ab338..511862c5f3 100644 --- a/arch/arm/dts/dra7-evm.dts +++ b/arch/arm/dts/dra7-evm.dts @@ -156,204 +156,6 @@ };
&dra7_pmx_core { - pinctrl-names = "default"; - pinctrl-0 = <&vtt_pin>; - - vtt_pin: pinmux_vtt_pin { - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x37b4, PIN_OUTPUT | MUX_MODE14) /* spi1_cs1.gpio7_11 */ - >; - }; - - i2c1_pins: pinmux_i2c1_pins { - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x3800, PIN_INPUT | MUX_MODE0) /* i2c1_sda */ - DRA7XX_CORE_IOPAD(0x3804, PIN_INPUT | MUX_MODE0) /* i2c1_scl */ - >; - }; - - i2c2_pins: pinmux_i2c2_pins { - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x3808, PIN_INPUT | MUX_MODE0) /* i2c2_sda */ - DRA7XX_CORE_IOPAD(0x380c, PIN_INPUT | MUX_MODE0) /* i2c2_scl */ - >; - }; - - i2c3_pins: pinmux_i2c3_pins { - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x3688, PIN_INPUT | MUX_MODE9) /* gpio6_14.i2c3_sda */ - DRA7XX_CORE_IOPAD(0x368c, PIN_INPUT | MUX_MODE9) /* gpio6_15.i2c3_scl */ - >; - }; - - mcspi1_pins: pinmux_mcspi1_pins { - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x37a4, PIN_INPUT | MUX_MODE0) /* spi1_sclk */ - DRA7XX_CORE_IOPAD(0x37a8, PIN_INPUT | MUX_MODE0) /* spi1_d1 */ - DRA7XX_CORE_IOPAD(0x37ac, PIN_INPUT | MUX_MODE0) /* spi1_d0 */ - DRA7XX_CORE_IOPAD(0x37b0, PIN_INPUT_SLEW | MUX_MODE0) /* spi1_cs0 */ - DRA7XX_CORE_IOPAD(0x37b8, PIN_INPUT_SLEW | MUX_MODE6) /* spi1_cs2.hdmi1_hpd */ - DRA7XX_CORE_IOPAD(0x37bc, PIN_INPUT_SLEW | MUX_MODE6) /* spi1_cs3.hdmi1_cec */ - >; - }; - - mcspi2_pins: pinmux_mcspi2_pins { - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x37c0, PIN_INPUT | MUX_MODE0) /* spi2_sclk */ - DRA7XX_CORE_IOPAD(0x37c4, PIN_INPUT_SLEW | MUX_MODE0) /* spi2_d1 */ - DRA7XX_CORE_IOPAD(0x37c8, PIN_INPUT_SLEW | MUX_MODE0) /* spi2_d1 */ - DRA7XX_CORE_IOPAD(0x37cc, PIN_INPUT_SLEW | MUX_MODE0) /* spi2_cs0 */ - >; - }; - - uart1_pins: pinmux_uart1_pins { - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x37e0, PIN_INPUT_SLEW | MUX_MODE0) /* uart1_rxd */ - DRA7XX_CORE_IOPAD(0x37e4, PIN_INPUT_SLEW | MUX_MODE0) /* uart1_txd */ - DRA7XX_CORE_IOPAD(0x37e8, PIN_INPUT | MUX_MODE3) /* uart1_ctsn */ - DRA7XX_CORE_IOPAD(0x37ec, PIN_INPUT | MUX_MODE3) /* uart1_rtsn */ - >; - }; - - uart2_pins: pinmux_uart2_pins { - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x37f0, PIN_INPUT | MUX_MODE0) /* uart2_rxd */ - DRA7XX_CORE_IOPAD(0x37f4, PIN_INPUT | MUX_MODE0) /* uart2_txd */ - DRA7XX_CORE_IOPAD(0x37f8, PIN_INPUT | MUX_MODE0) /* uart2_ctsn */ - DRA7XX_CORE_IOPAD(0x37fc, PIN_INPUT | MUX_MODE0) /* uart2_rtsn */ - >; - }; - - uart3_pins: pinmux_uart3_pins { - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x3648, PIN_INPUT_SLEW | MUX_MODE0) /* uart3_rxd */ - DRA7XX_CORE_IOPAD(0x364c, PIN_INPUT_SLEW | MUX_MODE0) /* uart3_txd */ - >; - }; - - usb1_pins: pinmux_usb1_pins { - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x3680, PIN_INPUT_SLEW | MUX_MODE0) /* usb1_drvvbus */ - >; - }; - - usb2_pins: pinmux_usb2_pins { - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x3684, PIN_INPUT_SLEW | MUX_MODE0) /* usb2_drvvbus */ - >; - }; - - nand_flash_x16: nand_flash_x16 { - /* On DRA7 EVM, GPMC_WPN and NAND_BOOTn comes from DIP switch - * So NAND flash requires following switch settings: - * SW5.1 (NAND_BOOTn) = ON (LOW) - * SW5.9 (GPMC_WPN) = OFF (HIGH) - */ - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x3400, PIN_INPUT | MUX_MODE0) /* gpmc_ad0 */ - DRA7XX_CORE_IOPAD(0x3404, PIN_INPUT | MUX_MODE0) /* gpmc_ad1 */ - DRA7XX_CORE_IOPAD(0x3408, PIN_INPUT | MUX_MODE0) /* gpmc_ad2 */ - DRA7XX_CORE_IOPAD(0x340c, PIN_INPUT | MUX_MODE0) /* gpmc_ad3 */ - DRA7XX_CORE_IOPAD(0x3410, PIN_INPUT | MUX_MODE0) /* gpmc_ad4 */ - DRA7XX_CORE_IOPAD(0x3414, PIN_INPUT | MUX_MODE0) /* gpmc_ad5 */ - DRA7XX_CORE_IOPAD(0x3418, PIN_INPUT | MUX_MODE0) /* gpmc_ad6 */ - DRA7XX_CORE_IOPAD(0x341c, PIN_INPUT | MUX_MODE0) /* gpmc_ad7 */ - DRA7XX_CORE_IOPAD(0x3420, PIN_INPUT | MUX_MODE0) /* gpmc_ad8 */ - DRA7XX_CORE_IOPAD(0x3424, PIN_INPUT | MUX_MODE0) /* gpmc_ad9 */ - DRA7XX_CORE_IOPAD(0x3428, PIN_INPUT | MUX_MODE0) /* gpmc_ad10 */ - DRA7XX_CORE_IOPAD(0x342c, PIN_INPUT | MUX_MODE0) /* gpmc_ad11 */ - DRA7XX_CORE_IOPAD(0x3430, PIN_INPUT | MUX_MODE0) /* gpmc_ad12 */ - DRA7XX_CORE_IOPAD(0x3434, PIN_INPUT | MUX_MODE0) /* gpmc_ad13 */ - DRA7XX_CORE_IOPAD(0x3438, PIN_INPUT | MUX_MODE0) /* gpmc_ad14 */ - DRA7XX_CORE_IOPAD(0x343c, PIN_INPUT | MUX_MODE0) /* gpmc_ad15 */ - DRA7XX_CORE_IOPAD(0x34d8, PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_wait0 */ - DRA7XX_CORE_IOPAD(0x34cc, PIN_OUTPUT | MUX_MODE0) /* gpmc_wen */ - DRA7XX_CORE_IOPAD(0x34b4, PIN_OUTPUT_PULLUP | MUX_MODE0) /* gpmc_csn0 */ - DRA7XX_CORE_IOPAD(0x34c4, PIN_OUTPUT | MUX_MODE0) /* gpmc_advn_ale */ - DRA7XX_CORE_IOPAD(0x34c8, PIN_OUTPUT | MUX_MODE0) /* gpmc_oen_ren */ - DRA7XX_CORE_IOPAD(0x34d0, PIN_OUTPUT | MUX_MODE0) /* gpmc_be0n_cle */ - >; - }; - - cpsw_default: cpsw_default { - pinctrl-single,pins = < - /* Slave 1 */ - DRA7XX_CORE_IOPAD(0x3650, PIN_OUTPUT | MUX_MODE0) /* rgmii0_txc.rgmii0_txc */ - DRA7XX_CORE_IOPAD(0x3654, PIN_OUTPUT | MUX_MODE0) /* rgmii0_txctl.rgmii0_txctl */ - DRA7XX_CORE_IOPAD(0x3658, PIN_OUTPUT | MUX_MODE0) /* rgmii0_td3.rgmii0_txd3 */ - DRA7XX_CORE_IOPAD(0x365c, PIN_OUTPUT | MUX_MODE0) /* rgmii0_txd2.rgmii0_txd2 */ - DRA7XX_CORE_IOPAD(0x3660, PIN_OUTPUT | MUX_MODE0) /* rgmii0_txd1.rgmii0_txd1 */ - DRA7XX_CORE_IOPAD(0x3664, PIN_OUTPUT | MUX_MODE0) /* rgmii0_txd0.rgmii0_txd0 */ - DRA7XX_CORE_IOPAD(0x3668, PIN_INPUT | MUX_MODE0) /* rgmii0_rxc.rgmii0_rxc */ - DRA7XX_CORE_IOPAD(0x366c, PIN_INPUT | MUX_MODE0) /* rgmii0_rxctl.rgmii0_rxctl */ - DRA7XX_CORE_IOPAD(0x3670, PIN_INPUT | MUX_MODE0) /* rgmii0_rxd3.rgmii0_rxd3 */ - DRA7XX_CORE_IOPAD(0x3674, PIN_INPUT | MUX_MODE0) /* rgmii0_rxd2.rgmii0_rxd2 */ - DRA7XX_CORE_IOPAD(0x3678, PIN_INPUT | MUX_MODE0) /* rgmii0_rxd1.rgmii0_rxd1 */ - DRA7XX_CORE_IOPAD(0x367c, PIN_INPUT | MUX_MODE0) /* rgmii0_rxd0.rgmii0_rxd0 */ - - /* Slave 2 */ - DRA7XX_CORE_IOPAD(0x3598, PIN_OUTPUT | MUX_MODE3) /* vin2a_d12.rgmii1_txc */ - DRA7XX_CORE_IOPAD(0x359c, PIN_OUTPUT | MUX_MODE3) /* vin2a_d13.rgmii1_tctl */ - DRA7XX_CORE_IOPAD(0x35a0, PIN_OUTPUT | MUX_MODE3) /* vin2a_d14.rgmii1_td3 */ - DRA7XX_CORE_IOPAD(0x35a4, PIN_OUTPUT | MUX_MODE3) /* vin2a_d15.rgmii1_td2 */ - DRA7XX_CORE_IOPAD(0x35a8, PIN_OUTPUT | MUX_MODE3) /* vin2a_d16.rgmii1_td1 */ - DRA7XX_CORE_IOPAD(0x35ac, PIN_OUTPUT | MUX_MODE3) /* vin2a_d17.rgmii1_td0 */ - DRA7XX_CORE_IOPAD(0x35b0, PIN_INPUT | MUX_MODE3) /* vin2a_d18.rgmii1_rclk */ - DRA7XX_CORE_IOPAD(0x35b4, PIN_INPUT | MUX_MODE3) /* vin2a_d19.rgmii1_rctl */ - DRA7XX_CORE_IOPAD(0x35b8, PIN_INPUT | MUX_MODE3) /* vin2a_d20.rgmii1_rd3 */ - DRA7XX_CORE_IOPAD(0x35bc, PIN_INPUT | MUX_MODE3) /* vin2a_d21.rgmii1_rd2 */ - DRA7XX_CORE_IOPAD(0x35c0, PIN_INPUT | MUX_MODE3) /* vin2a_d22.rgmii1_rd1 */ - DRA7XX_CORE_IOPAD(0x35c4, PIN_INPUT | MUX_MODE3) /* vin2a_d23.rgmii1_rd0 */ - >; - - }; - - cpsw_sleep: cpsw_sleep { - pinctrl-single,pins = < - /* Slave 1 */ - DRA7XX_CORE_IOPAD(0x3650, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x3654, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x3658, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x365c, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x3660, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x3664, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x3668, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x366c, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x3670, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x3674, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x3678, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x367c, MUX_MODE15) - - /* Slave 2 */ - DRA7XX_CORE_IOPAD(0x3598, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x359c, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x35a0, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x35a4, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x35a8, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x35ac, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x35b0, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x35b4, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x35b8, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x35bc, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x35c0, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x35c4, MUX_MODE15) - >; - }; - - davinci_mdio_default: davinci_mdio_default { - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x363c, PIN_OUTPUT_PULLUP | MUX_MODE0) /* mdio_d.mdio_d */ - DRA7XX_CORE_IOPAD(0x3640, PIN_INPUT_PULLUP | MUX_MODE0) /* mdio_clk.mdio_clk */ - >; - }; - - davinci_mdio_sleep: davinci_mdio_sleep { - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x363c, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x3640, MUX_MODE15) - >; - }; - dcan1_pins_default: dcan1_pins_default { pinctrl-single,pins = < DRA7XX_CORE_IOPAD(0x37d0, PIN_OUTPUT_PULLUP | MUX_MODE0) /* dcan1_tx */ @@ -368,41 +170,39 @@ >; };
- atl_pins: pinmux_atl_pins { + mmc1_pins_default: mmc1_pins_default { pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x3698, PIN_OUTPUT | MUX_MODE5) /* xref_clk1.atl_clk1 */ - DRA7XX_CORE_IOPAD(0x369c, PIN_OUTPUT | MUX_MODE5) /* xref_clk2.atl_clk2 */ + DRA7XX_CORE_IOPAD(0x376c, PIN_INPUT | MUX_MODE14) /* mmc1sdcd.gpio219 */ + DRA7XX_CORE_IOPAD(0x3754, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_clk.clk */ + DRA7XX_CORE_IOPAD(0x3758, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_cmd.cmd */ + DRA7XX_CORE_IOPAD(0x375c, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat0.dat0 */ + DRA7XX_CORE_IOPAD(0x3760, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat1.dat1 */ + DRA7XX_CORE_IOPAD(0x3764, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat2.dat2 */ + DRA7XX_CORE_IOPAD(0x3768, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat3.dat3 */ >; };
- mcasp3_pins: pinmux_mcasp3_pins { + mmc1_pins_sdr12: pinmux_mmc1_sdr12_pins { pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x3724, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mcasp3_aclkx */ - DRA7XX_CORE_IOPAD(0x3728, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mcasp3_fsx */ - DRA7XX_CORE_IOPAD(0x372c, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mcasp3_axr0 */ - DRA7XX_CORE_IOPAD(0x3730, PIN_INPUT_PULLDOWN | MUX_MODE0) /* mcasp3_axr1 */ - >; - }; - - mcasp3_sleep_pins: pinmux_mcasp3_sleep_pins { - pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x3724, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x3728, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x372c, MUX_MODE15) - DRA7XX_CORE_IOPAD(0x3730, MUX_MODE15) + DRA7XX_CORE_IOPAD(0x3754, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_clk.clk */ + DRA7XX_CORE_IOPAD(0x3758, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_cmd.cmd */ + DRA7XX_CORE_IOPAD(0x375c, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat0.dat0 */ + DRA7XX_CORE_IOPAD(0x3760, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat1.dat1 */ + DRA7XX_CORE_IOPAD(0x3764, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat2.dat2 */ + DRA7XX_CORE_IOPAD(0x3768, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat3.dat3 */ >; }; };
&i2c1 { status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_pins>; clock-frequency = <400000>;
tps659038: tps659038@58 { compatible = "ti,tps659038"; reg = <0x58>; + ti,palmas-override-powerhold; + ti,system-power-controller;
tps659038_pmic { compatible = "ti,tps659038-pmic"; @@ -587,8 +387,6 @@
&i2c2 { status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins>; clock-frequency = <400000>;
pcf_hdmi: gpio@26 { @@ -608,41 +406,29 @@
&i2c3 { status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c3_pins>; clock-frequency = <400000>; };
&mcspi1 { status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mcspi1_pins>; };
&mcspi2 { status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mcspi2_pins>; };
&uart1 { status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&uart1_pins>; interrupts-extended = <&crossbar_mpu GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, <&dra7_pmx_core 0x3e0>; };
&uart2 { status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&uart2_pins>; };
&uart3 { status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&uart3_pins>; };
&mmc1 { @@ -738,14 +524,10 @@
&usb1 { dr_mode = "peripheral"; - pinctrl-names = "default"; - pinctrl-0 = <&usb1_pins>; };
&usb2 { dr_mode = "host"; - pinctrl-names = "default"; - pinctrl-0 = <&usb2_pins>; };
&elm { @@ -753,9 +535,12 @@ };
&gpmc { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&nand_flash_x16>; + /* + * For the existing IOdelay configuration via U-Boot we don't + * support NAND on dra7-evm. Keep it disabled. Enabling it + * requires a different configuration by U-Boot. + */ + status = "disabled"; ranges = <0 0 0x08000000 0x01000000>; /* minimum GPMC partition = 16MB */ nand@0,0 { compatible = "ti,omap2-nand"; @@ -851,9 +636,6 @@
&mac { status = "okay"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&cpsw_default>; - pinctrl-1 = <&cpsw_sleep>; dual_emac; };
@@ -869,12 +651,6 @@ dual_emac_res_vlan = <2>; };
-&davinci_mdio { - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&davinci_mdio_default>; - pinctrl-1 = <&davinci_mdio_sleep>; -}; - &dcan1 { status = "ok"; pinctrl-names = "default", "sleep", "active"; @@ -884,9 +660,6 @@ };
&atl { - pinctrl-names = "default"; - pinctrl-0 = <&atl_pins>; - assigned-clocks = <&abe_dpll_sys_clk_mux>, <&atl_gfclk_mux>, <&dpll_abe_ck>, @@ -905,9 +678,6 @@
&mcasp3 { #sound-dai-cells = <0>; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&mcasp3_pins>; - pinctrl-1 = <&mcasp3_sleep_pins>;
assigned-clocks = <&mcasp3_ahclkx_mux>; assigned-clock-parents = <&atl_clkin2_ck>;
Please include a commit message to say what rev we're syncing with, and we should probably cover dra7* while we're at it (and first move anything U-Boot centric to a -u-boot.dtsi so this goes cleaner in the future, if we're not there already). Thanks!
Sure, Ill take care of this in v2.
Thanks and regards, Lokesh
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/dts/Makefile | 2 +- arch/arm/dts/dra7-evm-common.dtsi | 259 +++++++++++++++++++++++ arch/arm/dts/dra7-evm.dts | 271 ++---------------------- arch/arm/dts/dra76-evm.dts | 423 ++++++++++++++++++++++++++++++++++++++ arch/arm/dts/dra76x.dtsi | 19 ++ board/ti/dra7xx/evm.c | 4 +- configs/dra7xx_evm_defconfig | 2 +- configs/dra7xx_hs_evm_defconfig | 2 +- 8 files changed, 723 insertions(+), 259 deletions(-) create mode 100644 arch/arm/dts/dra7-evm-common.dtsi create mode 100644 arch/arm/dts/dra76-evm.dts create mode 100644 arch/arm/dts/dra76x.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c2dc240edf..67f4bffefd 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -174,7 +174,7 @@ dtb-$(CONFIG_ARCH_SOCFPGA) += \ socfpga_cyclone5_vining_fpga.dtb
dtb-$(CONFIG_TARGET_DRA7XX_EVM) += dra72-evm.dtb dra7-evm.dtb \ - dra72-evm-revc.dtb dra71-evm.dtb + dra72-evm-revc.dtb dra71-evm.dtb dra76-evm.dtb dtb-$(CONFIG_TARGET_AM57XX_EVM) += am57xx-beagle-x15.dtb \ am57xx-beagle-x15-revb1.dtb \ am572x-idk.dtb \ diff --git a/arch/arm/dts/dra7-evm-common.dtsi b/arch/arm/dts/dra7-evm-common.dtsi new file mode 100644 index 0000000000..9a4314b5ef --- /dev/null +++ b/arch/arm/dts/dra7-evm-common.dtsi @@ -0,0 +1,259 @@ +/* + * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/clk/ti-dra7-atl.h> +#include <dt-bindings/input/input.h> + +/ { + chosen { + stdout-path = &uart1; + tick-timer = &timer2; + }; + + extcon_usb1: extcon_usb1 { + compatible = "linux,extcon-usb-gpio"; + id-gpio = <&pcf_gpio_21 1 GPIO_ACTIVE_HIGH>; + }; + + sound0: sound0 { + compatible = "simple-audio-card"; + simple-audio-card,name = "DRA7xx-EVM"; + simple-audio-card,widgets = + "Headphone", "Headphone Jack", + "Line", "Line Out", + "Microphone", "Mic Jack", + "Line", "Line In"; + simple-audio-card,routing = + "Headphone Jack", "HPLOUT", + "Headphone Jack", "HPROUT", + "Line Out", "LLOUT", + "Line Out", "RLOUT", + "MIC3L", "Mic Jack", + "MIC3R", "Mic Jack", + "Mic Jack", "Mic Bias", + "LINE1L", "Line In", + "LINE1R", "Line In"; + simple-audio-card,format = "dsp_b"; + simple-audio-card,bitclock-master = <&sound0_master>; + simple-audio-card,frame-master = <&sound0_master>; + simple-audio-card,bitclock-inversion; + + sound0_master: simple-audio-card,cpu { + sound-dai = <&mcasp3>; + system-clock-frequency = <5644800>; + }; + + simple-audio-card,codec { + sound-dai = <&tlv320aic3106>; + clocks = <&atl_clkin2_ck>; + }; + }; + + leds { + compatible = "gpio-leds"; + led0 { + label = "dra7:usr1"; + gpios = <&pcf_lcd 4 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led1 { + label = "dra7:usr2"; + gpios = <&pcf_lcd 5 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led2 { + label = "dra7:usr3"; + gpios = <&pcf_lcd 6 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + + led3 { + label = "dra7:usr4"; + gpios = <&pcf_lcd 7 GPIO_ACTIVE_LOW>; + default-state = "off"; + }; + }; + + gpio_keys { + compatible = "gpio-keys"; + #address-cells = <1>; + #size-cells = <0>; + autorepeat; + + USER1 { + label = "btnUser1"; + linux,code = <BTN_0>; + gpios = <&pcf_lcd 2 GPIO_ACTIVE_LOW>; + }; + + USER2 { + label = "btnUser2"; + linux,code = <BTN_1>; + gpios = <&pcf_lcd 3 GPIO_ACTIVE_LOW>; + }; + }; +}; + +&i2c3 { + status = "okay"; + clock-frequency = <400000>; +}; + +&mcspi1 { + status = "okay"; +}; + +&mcspi2 { + status = "okay"; +}; + +&uart1 { + status = "okay"; + interrupts-extended = <&crossbar_mpu GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, + <&dra7_pmx_core 0x3e0>; +}; + +&uart2 { + status = "okay"; +}; + +&uart3 { + status = "okay"; +}; + +&qspi { + status = "okay"; + + spi-max-frequency = <76800000>; + m25p80@0 { + compatible = "s25fl256s1", "spi-flash"; + spi-max-frequency = <76800000>; + reg = <0>; + spi-tx-bus-width = <1>; + spi-rx-bus-width = <4>; + #address-cells = <1>; + #size-cells = <1>; + + /* MTD partition table. + * The ROM checks the first four physical blocks + * for a valid file to boot and the flash here is + * 64KiB block size. + */ + partition@0 { + label = "QSPI.SPL"; + reg = <0x00000000 0x000010000>; + }; + partition@1 { + label = "QSPI.SPL.backup1"; + reg = <0x00010000 0x00010000>; + }; + partition@2 { + label = "QSPI.SPL.backup2"; + reg = <0x00020000 0x00010000>; + }; + partition@3 { + label = "QSPI.SPL.backup3"; + reg = <0x00030000 0x00010000>; + }; + partition@4 { + label = "QSPI.u-boot"; + reg = <0x00040000 0x00100000>; + }; + partition@5 { + label = "QSPI.u-boot-spl-os"; + reg = <0x00140000 0x00080000>; + }; + partition@6 { + label = "QSPI.u-boot-env"; + reg = <0x001c0000 0x00010000>; + }; + partition@7 { + label = "QSPI.u-boot-env.backup1"; + reg = <0x001d0000 0x0010000>; + }; + partition@8 { + label = "QSPI.kernel"; + reg = <0x001e0000 0x0800000>; + }; + partition@9 { + label = "QSPI.file-system"; + reg = <0x009e0000 0x01620000>; + }; + }; +}; + +&omap_dwc3_1 { + extcon = <&extcon_usb1>; +}; + +&usb1 { + dr_mode = "otg"; + extcon = <&extcon_usb1>; +}; + +&usb2 { + dr_mode = "host"; +}; + +&atl { + assigned-clocks = <&abe_dpll_sys_clk_mux>, + <&atl_gfclk_mux>, + <&dpll_abe_ck>, + <&dpll_abe_m2x2_ck>, + <&atl_clkin2_ck>; + assigned-clock-parents = <&sys_clkin2>, <&dpll_abe_m2_ck>; + assigned-clock-rates = <0>, <0>, <180633600>, <361267200>, <5644800>; + + status = "okay"; + + atl2 { + bws = <DRA7_ATL_WS_MCASP2_FSX>; + aws = <DRA7_ATL_WS_MCASP3_FSX>; + }; +}; + +&mcasp3 { + #sound-dai-cells = <0>; + + assigned-clocks = <&mcasp3_ahclkx_mux>; + assigned-clock-parents = <&atl_clkin2_ck>; + + status = "okay"; + + op-mode = <0>; /* MCASP_IIS_MODE */ + tdm-slots = <2>; + /* 4 serializer */ + serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ + 1 2 0 0 + >; + tx-num-evt = <32>; + rx-num-evt = <32>; +}; + +&mailbox5 { + status = "okay"; + mbox_ipu1_ipc3x: mbox_ipu1_ipc3x { + status = "okay"; + }; + mbox_dsp1_ipc3x: mbox_dsp1_ipc3x { + status = "okay"; + }; +}; + +&mailbox6 { + status = "okay"; + mbox_ipu2_ipc3x: mbox_ipu2_ipc3x { + status = "okay"; + }; + mbox_dsp2_ipc3x: mbox_dsp2_ipc3x { + status = "okay"; + }; +}; diff --git a/arch/arm/dts/dra7-evm.dts b/arch/arm/dts/dra7-evm.dts index 511862c5f3..c3009bda62 100644 --- a/arch/arm/dts/dra7-evm.dts +++ b/arch/arm/dts/dra7-evm.dts @@ -8,19 +8,12 @@ /dts-v1/;
#include "dra74x.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/clk/ti-dra7-atl.h> -#include <dt-bindings/input/input.h> +#include "dra7-evm-common.dtsi"
/ { model = "TI DRA742"; compatible = "ti,dra7-evm", "ti,dra742", "ti,dra74", "ti,dra7";
- chosen { - stdout-path = &uart1; - tick-timer = &timer2; - }; - memory@0 { device_type = "memory"; reg = <0x0 0x80000000 0x0 0x60000000>; /* 1536 MB */ @@ -52,11 +45,6 @@ regulator-max-microvolt = <1800000>; };
- extcon_usb1: extcon_usb1 { - compatible = "linux,extcon-usb-gpio"; - id-gpio = <&pcf_gpio_21 1 GPIO_ACTIVE_HIGH>; - }; - extcon_usb2: extcon_usb2 { compatible = "linux,extcon-usb-gpio"; id-gpio = <&pcf_gpio_21 2 GPIO_ACTIVE_HIGH>; @@ -74,85 +62,6 @@ gpio = <&gpio7 11 GPIO_ACTIVE_HIGH>; };
- sound0: sound0 { - compatible = "simple-audio-card"; - simple-audio-card,name = "DRA7xx-EVM"; - simple-audio-card,widgets = - "Headphone", "Headphone Jack", - "Line", "Line Out", - "Microphone", "Mic Jack", - "Line", "Line In"; - simple-audio-card,routing = - "Headphone Jack", "HPLOUT", - "Headphone Jack", "HPROUT", - "Line Out", "LLOUT", - "Line Out", "RLOUT", - "MIC3L", "Mic Jack", - "MIC3R", "Mic Jack", - "Mic Jack", "Mic Bias", - "LINE1L", "Line In", - "LINE1R", "Line In"; - simple-audio-card,format = "dsp_b"; - simple-audio-card,bitclock-master = <&sound0_master>; - simple-audio-card,frame-master = <&sound0_master>; - simple-audio-card,bitclock-inversion; - - sound0_master: simple-audio-card,cpu { - sound-dai = <&mcasp3>; - system-clock-frequency = <5644800>; - }; - - simple-audio-card,codec { - sound-dai = <&tlv320aic3106>; - clocks = <&atl_clkin2_ck>; - }; - }; - - leds { - compatible = "gpio-leds"; - led0 { - label = "dra7:usr1"; - gpios = <&pcf_lcd 4 GPIO_ACTIVE_LOW>; - default-state = "off"; - }; - - led1 { - label = "dra7:usr2"; - gpios = <&pcf_lcd 5 GPIO_ACTIVE_LOW>; - default-state = "off"; - }; - - led2 { - label = "dra7:usr3"; - gpios = <&pcf_lcd 6 GPIO_ACTIVE_LOW>; - default-state = "off"; - }; - - led3 { - label = "dra7:usr4"; - gpios = <&pcf_lcd 7 GPIO_ACTIVE_LOW>; - default-state = "off"; - }; - }; - - gpio_keys { - compatible = "gpio-keys"; - #address-cells = <1>; - #size-cells = <0>; - autorepeat; - - USER1 { - label = "btnUser1"; - linux,code = <BTN_0>; - gpios = <&pcf_lcd 2 GPIO_ACTIVE_LOW>; - }; - - USER2 { - label = "btnUser2"; - linux,code = <BTN_1>; - gpios = <&pcf_lcd 3 GPIO_ACTIVE_LOW>; - }; - }; };
&dra7_pmx_core { @@ -182,14 +91,18 @@ >; };
- mmc1_pins_sdr12: pinmux_mmc1_sdr12_pins { + mmc2_pins_default: mmc2_pins_default { pinctrl-single,pins = < - DRA7XX_CORE_IOPAD(0x3754, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_clk.clk */ - DRA7XX_CORE_IOPAD(0x3758, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_cmd.cmd */ - DRA7XX_CORE_IOPAD(0x375c, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat0.dat0 */ - DRA7XX_CORE_IOPAD(0x3760, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat1.dat1 */ - DRA7XX_CORE_IOPAD(0x3764, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat2.dat2 */ - DRA7XX_CORE_IOPAD(0x3768, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat3.dat3 */ + DRA7XX_CORE_IOPAD(0x349c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a23.mmc2_clk */ + DRA7XX_CORE_IOPAD(0x34b0, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_cs1.mmc2_cmd */ + DRA7XX_CORE_IOPAD(0x34a0, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a24.mmc2_dat0 */ + DRA7XX_CORE_IOPAD(0x34a4, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a25.mmc2_dat1 */ + DRA7XX_CORE_IOPAD(0x34a8, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a26.mmc2_dat2 */ + DRA7XX_CORE_IOPAD(0x34ac, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a27.mmc2_dat3 */ + DRA7XX_CORE_IOPAD(0x348c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a19.mmc2_dat4 */ + DRA7XX_CORE_IOPAD(0x3490, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a20.mmc2_dat5 */ + DRA7XX_CORE_IOPAD(0x3494, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a21.mmc2_dat6 */ + DRA7XX_CORE_IOPAD(0x3498, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a22.mmc2_dat7 */ >; }; }; @@ -366,7 +279,6 @@ interrupts = <11 IRQ_TYPE_EDGE_FALLING>; interrupt-controller; #interrupt-cells = <2>; - u-boot,i2c-offset-len = <0>; };
tlv320aic3106: tlv320aic3106@19 { @@ -404,35 +316,10 @@ }; };
-&i2c3 { - status = "okay"; - clock-frequency = <400000>; -}; - -&mcspi1 { - status = "okay"; -}; - -&mcspi2 { - status = "okay"; -}; - -&uart1 { - status = "okay"; - interrupts-extended = <&crossbar_mpu GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <&dra7_pmx_core 0x3e0>; -}; - -&uart2 { - status = "okay"; -}; - -&uart3 { - status = "okay"; -}; - &mmc1 { status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins_default>; vmmc-supply = <&evm_3v3_sd>; vmmc_aux-supply = <&ldo1_reg>; bus-width = <4>; @@ -445,6 +332,8 @@
&mmc2 { status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins_default>; vmmc-supply = <&evm_3v3_sw>; bus-width = <8>; }; @@ -453,83 +342,10 @@ cpu0-supply = <&smps123_reg>; };
-&qspi { - status = "okay"; - - spi-max-frequency = <76800000>; - m25p80@0 { - compatible = "s25fl256s1", "spi-flash"; - spi-max-frequency = <76800000>; - reg = <0>; - spi-tx-bus-width = <1>; - spi-rx-bus-width = <4>; - #address-cells = <1>; - #size-cells = <1>; - - /* MTD partition table. - * The ROM checks the first four physical blocks - * for a valid file to boot and the flash here is - * 64KiB block size. - */ - partition@0 { - label = "QSPI.SPL"; - reg = <0x00000000 0x000010000>; - }; - partition@1 { - label = "QSPI.SPL.backup1"; - reg = <0x00010000 0x00010000>; - }; - partition@2 { - label = "QSPI.SPL.backup2"; - reg = <0x00020000 0x00010000>; - }; - partition@3 { - label = "QSPI.SPL.backup3"; - reg = <0x00030000 0x00010000>; - }; - partition@4 { - label = "QSPI.u-boot"; - reg = <0x00040000 0x00100000>; - }; - partition@5 { - label = "QSPI.u-boot-spl-os"; - reg = <0x00140000 0x00080000>; - }; - partition@6 { - label = "QSPI.u-boot-env"; - reg = <0x001c0000 0x00010000>; - }; - partition@7 { - label = "QSPI.u-boot-env.backup1"; - reg = <0x001d0000 0x0010000>; - }; - partition@8 { - label = "QSPI.kernel"; - reg = <0x001e0000 0x0800000>; - }; - partition@9 { - label = "QSPI.file-system"; - reg = <0x009e0000 0x01620000>; - }; - }; -}; - -&omap_dwc3_1 { - extcon = <&extcon_usb1>; -}; - &omap_dwc3_2 { extcon = <&extcon_usb2>; };
-&usb1 { - dr_mode = "peripheral"; -}; - -&usb2 { - dr_mode = "host"; -}; - &elm { status = "okay"; }; @@ -658,58 +474,3 @@ pinctrl-1 = <&dcan1_pins_sleep>; pinctrl-2 = <&dcan1_pins_default>; }; - -&atl { - assigned-clocks = <&abe_dpll_sys_clk_mux>, - <&atl_gfclk_mux>, - <&dpll_abe_ck>, - <&dpll_abe_m2x2_ck>, - <&atl_clkin2_ck>; - assigned-clock-parents = <&sys_clkin2>, <&dpll_abe_m2_ck>; - assigned-clock-rates = <0>, <0>, <180633600>, <361267200>, <5644800>; - - status = "okay"; - - atl2 { - bws = <DRA7_ATL_WS_MCASP2_FSX>; - aws = <DRA7_ATL_WS_MCASP3_FSX>; - }; -}; - -&mcasp3 { - #sound-dai-cells = <0>; - - assigned-clocks = <&mcasp3_ahclkx_mux>; - assigned-clock-parents = <&atl_clkin2_ck>; - - status = "okay"; - - op-mode = <0>; /* MCASP_IIS_MODE */ - tdm-slots = <2>; - /* 4 serializer */ - serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ - 1 2 0 0 - >; - tx-num-evt = <32>; - rx-num-evt = <32>; -}; - -&mailbox5 { - status = "okay"; - mbox_ipu1_ipc3x: mbox_ipu1_ipc3x { - status = "okay"; - }; - mbox_dsp1_ipc3x: mbox_dsp1_ipc3x { - status = "okay"; - }; -}; - -&mailbox6 { - status = "okay"; - mbox_ipu2_ipc3x: mbox_ipu2_ipc3x { - status = "okay"; - }; - mbox_dsp2_ipc3x: mbox_dsp2_ipc3x { - status = "okay"; - }; -}; diff --git a/arch/arm/dts/dra76-evm.dts b/arch/arm/dts/dra76-evm.dts new file mode 100644 index 0000000000..0f8b983e66 --- /dev/null +++ b/arch/arm/dts/dra76-evm.dts @@ -0,0 +1,423 @@ +/* + * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +/dts-v1/; + +#include "dra76x.dtsi" +#include "dra7-evm-common.dtsi" +#include <dt-bindings/net/ti-dp83867.h> + +/ { + model = "TI DRA762 EVM"; + compatible = "ti,dra76-evm", "ti,dra762", "ti,dra7"; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x80000000 0x0 0x80000000>; + }; + + vsys_12v0: fixedregulator-vsys12v0 { + /* main supply */ + compatible = "regulator-fixed"; + regulator-name = "vsys_12v0"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + regulator-boot-on; + }; + + vsys_5v0: fixedregulator-vsys5v0 { + /* Output of Cntlr B of TPS43351-Q1 on dra76-evm */ + compatible = "regulator-fixed"; + regulator-name = "vsys_5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vsys_12v0>; + regulator-always-on; + regulator-boot-on; + }; + + vsys_3v3: fixedregulator-vsys3v3 { + /* Output of Cntlr A of TPS43351-Q1 on dra76-evm */ + compatible = "regulator-fixed"; + regulator-name = "vsys_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vsys_12v0>; + regulator-always-on; + regulator-boot-on; + }; + + vio_3v3: fixedregulator-vio_3v3 { + compatible = "regulator-fixed"; + regulator-name = "vio_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vsys_3v3>; + regulator-always-on; + regulator-boot-on; + }; + + vio_3v3_sd: fixedregulator-sd { + compatible = "regulator-fixed"; + regulator-name = "vio_3v3_sd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vio_3v3>; + enable-active-high; + gpio = <&gpio4 21 GPIO_ACTIVE_HIGH>; + }; + + vio_1v8: fixedregulator-vio_1v8 { + compatible = "regulator-fixed"; + regulator-name = "vio_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&smps5_reg>; + }; + + vtt_fixed: fixedregulator-vtt { + compatible = "regulator-fixed"; + regulator-name = "vtt_fixed"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + vin-supply = <&vsys_3v3>; + regulator-always-on; + regulator-boot-on; + }; + + aic_dvdd: fixedregulator-aic_dvdd { + /* TPS77018DBVT */ + compatible = "regulator-fixed"; + regulator-name = "aic_dvdd"; + vin-supply = <&vio_3v3>; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; +}; + +&dra7_pmx_core { + mmc1_pins_default: mmc1_pins_default { + pinctrl-single,pins = < + DRA7XX_CORE_IOPAD(0x376c, PIN_INPUT | MUX_MODE14) /* mmc1sdcd.gpio219 */ + DRA7XX_CORE_IOPAD(0x3754, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_clk.clk */ + DRA7XX_CORE_IOPAD(0x3758, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_cmd.cmd */ + DRA7XX_CORE_IOPAD(0x375c, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat0.dat0 */ + DRA7XX_CORE_IOPAD(0x3760, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat1.dat1 */ + DRA7XX_CORE_IOPAD(0x3764, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat2.dat2 */ + DRA7XX_CORE_IOPAD(0x3768, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat3.dat3 */ + >; + }; + + mmc1_pins_sdr12: pinmux_mmc1_sdr12_pins { + pinctrl-single,pins = < + DRA7XX_CORE_IOPAD(0x3754, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_clk.clk */ + DRA7XX_CORE_IOPAD(0x3758, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_cmd.cmd */ + DRA7XX_CORE_IOPAD(0x375c, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat0.dat0 */ + DRA7XX_CORE_IOPAD(0x3760, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat1.dat1 */ + DRA7XX_CORE_IOPAD(0x3764, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat2.dat2 */ + DRA7XX_CORE_IOPAD(0x3768, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc1_dat3.dat3 */ + >; + }; + + mmc2_pins_default: mmc2_pins_default { + pinctrl-single,pins = < + DRA7XX_CORE_IOPAD(0x349c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a23.mmc2_clk */ + DRA7XX_CORE_IOPAD(0x34b0, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_cs1.mmc2_cmd */ + DRA7XX_CORE_IOPAD(0x34a0, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a24.mmc2_dat0 */ + DRA7XX_CORE_IOPAD(0x34a4, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a25.mmc2_dat1 */ + DRA7XX_CORE_IOPAD(0x34a8, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a26.mmc2_dat2 */ + DRA7XX_CORE_IOPAD(0x34ac, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a27.mmc2_dat3 */ + DRA7XX_CORE_IOPAD(0x348c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a19.mmc2_dat4 */ + DRA7XX_CORE_IOPAD(0x3490, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a20.mmc2_dat5 */ + DRA7XX_CORE_IOPAD(0x3494, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a21.mmc2_dat6 */ + DRA7XX_CORE_IOPAD(0x3498, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a22.mmc2_dat7 */ + >; + }; +}; + +&i2c1 { + status = "okay"; + clock-frequency = <400000>; + + tps65917: tps65917@58 { + compatible = "ti,tps65917"; + reg = <0x58>; + ti,system-power-controller; + interrupt-controller; + #interrupt-cells = <2>; + + tps65917_pmic { + compatible = "ti,tps65917-pmic"; + + smps12-in-supply = <&vsys_3v3>; + smps3-in-supply = <&vsys_3v3>; + smps4-in-supply = <&vsys_3v3>; + smps5-in-supply = <&vsys_3v3>; + ldo1-in-supply = <&vsys_3v3>; + ldo2-in-supply = <&vsys_3v3>; + ldo3-in-supply = <&vsys_5v0>; + ldo4-in-supply = <&vsys_5v0>; + ldo5-in-supply = <&vsys_3v3>; + + tps65917_regulators: regulators { + smps12_reg: smps12 { + /* VDD_DSPEVE */ + regulator-name = "smps12"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1250000>; + regulator-always-on; + regulator-boot-on; + }; + + smps3_reg: smps3 { + /* VDD_CORE */ + regulator-name = "smps3"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1250000>; + regulator-boot-on; + regulator-always-on; + }; + + smps4_reg: smps4 { + /* VDD_IVA */ + regulator-name = "smps4"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1250000>; + regulator-always-on; + regulator-boot-on; + }; + + smps5_reg: smps5 { + /* VDDS1V8 */ + regulator-name = "smps5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1_reg: ldo1 { + /* LDO1_OUT --> VDA_PHY1_1V8 */ + regulator-name = "ldo1"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-allow-bypass; + }; + + ldo2_reg: ldo2 { + /* LDO2_OUT --> VDA_PHY2_1V8 */ + regulator-name = "ldo2"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-allow-bypass; + regulator-always-on; + }; + + ldo3_reg: ldo3 { + /* VDA_USB_3V3 */ + regulator-name = "ldo3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo5_reg: ldo5 { + /* VDDA_1V8_PLL */ + regulator-name = "ldo5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + ldo4_reg: ldo4 { + /* VDD_SDIO_DV */ + regulator-name = "ldo4"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; + + tps65917_power_button { + compatible = "ti,palmas-pwrbutton"; + interrupt-parent = <&tps65917>; + interrupts = <1 IRQ_TYPE_NONE>; + wakeup-source; + ti,palmas-long-press-seconds = <6>; + }; + }; + + lp87565: lp87565@60 { + compatible = "ti,lp87565-q1"; + reg = <0x60>; + + buck10-in-supply =<&vsys_3v3>; + buck23-in-supply =<&vsys_3v3>; + + regulators: regulators { + buck10_reg: buck10 { + /*VDD_MPU*/ + regulator-name = "buck10"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1250000>; + regulator-always-on; + regulator-boot-on; + }; + + buck23_reg: buck23 { + /* VDD_GPU*/ + regulator-name = "buck23"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1250000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; + + pcf_lcd: pcf8757@20 { + compatible = "ti,pcf8575", "nxp,pcf8575"; + reg = <0x20>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + interrupt-parent = <&gpio1>; + interrupts = <3 IRQ_TYPE_EDGE_FALLING>; + }; + + pcf_gpio_21: pcf8757@21 { + compatible = "ti,pcf8575", "nxp,pcf8575"; + reg = <0x21>; + gpio-controller; + #gpio-cells = <2>; + interrupt-parent = <&gpio1>; + interrupts = <3 IRQ_TYPE_EDGE_FALLING>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + pcf_hdmi: pcf8575@26 { + compatible = "ti,pcf8575", "nxp,pcf8575"; + reg = <0x26>; + gpio-controller; + #gpio-cells = <2>; + p1 { + /* vin6_sel_s0: high: VIN6, low: audio */ + gpio-hog; + gpios = <1 GPIO_ACTIVE_HIGH>; + output-low; + line-name = "vin6_sel_s0"; + }; + }; + + tlv320aic3106: tlv320aic3106@19 { + #sound-dai-cells = <0>; + compatible = "ti,tlv320aic3106"; + reg = <0x19>; + adc-settle-ms = <40>; + ai3x-micbias-vg = <1>; /* 2.0V */ + status = "okay"; + + /* Regulators */ + AVDD-supply = <&vio_3v3>; + IOVDD-supply = <&vio_3v3>; + DRVDD-supply = <&vio_3v3>; + DVDD-supply = <&aic_dvdd>; + }; +}; + +&cpu0 { + vdd-supply = <&buck10_reg>; +}; + +&mmc1 { + status = "okay"; + vmmc-supply = <&vio_3v3_sd>; + vmmc_aux-supply = <&ldo4_reg>; + bus-width = <4>; + /* + * SDCD signal is not being used here - using the fact that GPIO mode + * is always hardwired. + */ + cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins_default>; +}; + +&mmc2 { + status = "okay"; + vmmc-supply = <&vio_1v8>; + bus-width = <8>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins_default>; +}; + +/* No RTC on this device */ +&rtc { + status = "disabled"; +}; + +&mac { + status = "okay"; + + dual_emac; +}; + +&cpsw_emac0 { + phy-handle = <&dp83867_0>; + phy-mode = "rgmii-id"; + dual_emac_res_vlan = <1>; +}; + +&cpsw_emac1 { + phy-handle = <&dp83867_1>; + phy-mode = "rgmii-id"; + dual_emac_res_vlan = <2>; +}; + +&davinci_mdio { + dp83867_0: ethernet-phy@2 { + reg = <2>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_25_NS>; + ti,tx-internal-delay = <DP83867_RGMIIDCTL_250_PS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_8_B_NIB>; + ti,min-output-impedance; + ti,dp83867-rxctrl-strap-quirk; + }; + + dp83867_1: ethernet-phy@3 { + reg = <3>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_25_NS>; + ti,tx-internal-delay = <DP83867_RGMIIDCTL_250_PS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_8_B_NIB>; + ti,min-output-impedance; + ti,dp83867-rxctrl-strap-quirk; + }; +}; + +&usb2_phy1 { + phy-supply = <&ldo3_reg>; +}; + +&usb2_phy2 { + phy-supply = <&ldo3_reg>; +}; + +&qspi { + spi-max-frequency = <96000000>; + m25p80@0 { + spi-max-frequency = <96000000>; + }; +}; diff --git a/arch/arm/dts/dra76x.dtsi b/arch/arm/dts/dra76x.dtsi new file mode 100644 index 0000000000..1c88c581ff --- /dev/null +++ b/arch/arm/dts/dra76x.dtsi @@ -0,0 +1,19 @@ +/* + * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#include "dra74x.dtsi" + +/ { + compatible = "ti,dra762", "ti,dra7"; + +}; + +/* MCAN interrupts are hard-wired to irqs 67, 68 */ +&crossbar_mpu { + ti,irqs-skip = <10 67 68 133 139 140>; +}; diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 14c06f5eda..c57ce3b3ac 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -1116,7 +1116,9 @@ int board_fit_config_name_match(const char *name) } else if (!strcmp(name, "dra72-evm")) { return 0; } - } else if (!is_dra72x() && !strcmp(name, "dra7-evm")) { + } else if (is_dra76x() && !strcmp(name, "dra76-evm")) { + return 0; + } else if (!is_dra72x() && !is_dra76x() && !strcmp(name, "dra7-evm")) { return 0; }
diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index c151f49e30..f74328e3d6 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -37,7 +37,7 @@ CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm" +CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm dra76-evm" CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index dba9f06bd6..0f25b25e2c 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -42,7 +42,7 @@ CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm" +CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm dra76-evm" CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_REGMAP=y
Some of these syncs should be in the previous patch, please have a commit message, and if the skeleton of dra76-evm.dts isn't upstream just yet, have you submitted it? Thanks!
Lokesh Vutla
