[PATCH v3 0/8] mmc: zynqmp_sdhci: Add support for Tap delay
this patchset adding support for Tap delay programming for ZynqMP and Versal. Based on mainline discussion also DT properties have been introduced which are documented here. https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/Do... The patchset is using these DT properties which are optional. Default values are also listed.
The patchset is based on: https://lists.denx.de/pipermail/u-boot/2020-May/410326.html
Also new code is adding checking for SOCs which are not needed at that time when patch is applied (For example "mmc: zynq_sdhci: Read clock phase delays from dt" and IS_ENABLED(CONFIG_ARCH_ZYNQMP)... But I kept it there for more cleaner patches built on the top.
Thanks, Michal
Changes in v3: - replace host->version by SDHCI_GET_VERSION(host) reported by Jaehoon - replace host->version by SDHCI_GET_VERSION(host) reported by Jaehoon
Changes in v2: - Timing macro's are common to all mmc drivers, hence remove zynq_sdhci from subject and description. - Add common function to set tapdelays based on the values read from DT - Remove tapdelay settings based on speed
Ashok Reddy Soma (6): Revert "mmc: zynq: parse dt when probing" mmc: Define timing macro's mmc: zynq_sdhci: Set tapdelays based on clk phase delays mmc: zynq_sdhci: Add clock phase delays for Versal mmc: zynq_sdhci: Extend UHS timings till hs200 mmc: zynq_sdhci: Add common function to set input/output tapdelays
Michal Simek (2): mmc: zynq_sdhci: Move macro to the top mmc: zynq_sdhci: Read clock phase delays from dt
board/xilinx/zynqmp/tap_delays.c | 199 +++------------ drivers/mmc/sdhci.c | 3 +- drivers/mmc/zynq_sdhci.c | 406 +++++++++++++++++++++++++++++-- include/mmc.h | 13 + include/sdhci.h | 1 + include/zynqmp_tap_delay.h | 5 +- 6 files changed, 434 insertions(+), 193 deletions(-)
This reverts commit 942b5fc03218d1c94468fc658e7dec65dabcc830.
This is partial revert of the above commit.
mmc_of_parse() is reading no-1-8-v from device tree and if set, it is clearing the UHS speed capabilities of cfg->host_caps. cfg->host_caps &= ~(UHS_CAPS | MMC_MODE_HS200 | MMC_MODE_HS400 | MMC_MODE_HS400_ES);
This is still missing to clear UHS speeds like SDHCI_SUPPORT_SDR104, SDHCI_SUPPORT_SDR50 and SDHCI_SUPPORT_DDR50.
Even if we clear the flags SDHCI_SUPPORT_XXX in mmc_of_parse(), these speed flags are getting set again in cfg->host_caps in sdhci_setup_cfg().
The reason for this is, SDHCI_SUPPORT_XXX flags are cleared only if controller is not capable of supporting MMC_VDD_165_195 volts.
if (caps & SDHCI_CAN_VDD_180) cfg->voltages |= MMC_VDD_165_195;
if (!(cfg->voltages & MMC_VDD_165_195)) caps_1 &= ~(SDHCI_SUPPORT_SDR104 | SDHCI_SUPPORT_SDR50 | SDHCI_SUPPORT_DDR50);
It means "no-1-8-v", which is read from DT is not coming in to effect. So it is better we keep the host quirks(SDHCI_QUIRK_NO_1_8_V) to clear UHS speeds based on no-1-8-v from device tree.
Hence revert the functionality related to no-1-8-v only, rest is fine in the patch.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Peng Fan peng.fan@nxp.com ---
(no changes since v1)
drivers/mmc/sdhci.c | 3 ++- drivers/mmc/zynq_sdhci.c | 5 +++++ include/sdhci.h | 1 + 3 files changed, 8 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index d549a264d73b..06289343124e 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -812,7 +812,8 @@ int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, cfg->host_caps &= ~MMC_MODE_HS_52MHz; }
- if (!(cfg->voltages & MMC_VDD_165_195)) + if (!(cfg->voltages & MMC_VDD_165_195) || + (host->quirks & SDHCI_QUIRK_NO_1_8_V)) caps_1 &= ~(SDHCI_SUPPORT_SDR104 | SDHCI_SUPPORT_SDR50 | SDHCI_SUPPORT_DDR50);
diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 775c17baac5b..88e478ee11c1 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -28,6 +28,7 @@ struct arasan_sdhci_priv { struct sdhci_host *host; u8 deviceid; u8 bank; + u8 no_1p8; };
#if defined(CONFIG_ARCH_ZYNQMP) @@ -236,6 +237,9 @@ static int arasan_sdhci_probe(struct udevice *dev) host->quirks |= SDHCI_QUIRK_BROKEN_HISPD_MODE; #endif
+ if (priv->no_1p8) + host->quirks |= SDHCI_QUIRK_NO_1_8_V; + plat->cfg.f_max = CONFIG_ZYNQ_SDHCI_MAX_FREQ;
ret = mmc_of_parse(dev, &plat->cfg); @@ -277,6 +281,7 @@ static int arasan_sdhci_ofdata_to_platdata(struct udevice *dev)
priv->deviceid = dev_read_u32_default(dev, "xlnx,device_id", -1); priv->bank = dev_read_u32_default(dev, "xlnx,mio-bank", 0); + priv->no_1p8 = dev_read_bool(dev, "no-1-8-v");
return 0; } diff --git a/include/sdhci.h b/include/sdhci.h index f69d5f81fb1b..1fd20ec0860b 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -244,6 +244,7 @@ #define SDHCI_QUIRK_BROKEN_HISPD_MODE BIT(5) #define SDHCI_QUIRK_WAIT_SEND_CMD (1 << 6) #define SDHCI_QUIRK_USE_WIDE8 (1 << 8) +#define SDHCI_QUIRK_NO_1_8_V (1 << 9)
/* to make gcc happy */ struct sdhci_host;
Define timing macro's for all the available speeds of mmc. This is done similar to linux. Replace speed macro's used with these new timing macro's wherever applicable.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Peng Fan peng.fan@nxp.com ---
(no changes since v2)
board/xilinx/zynqmp/tap_delays.c | 9 --------- drivers/mmc/zynq_sdhci.c | 24 +++++++++++------------- include/mmc.h | 13 +++++++++++++ 3 files changed, 24 insertions(+), 22 deletions(-)
diff --git a/board/xilinx/zynqmp/tap_delays.c b/board/xilinx/zynqmp/tap_delays.c index 5fde0aed7dbe..813650cabcc4 100644 --- a/board/xilinx/zynqmp/tap_delays.c +++ b/board/xilinx/zynqmp/tap_delays.c @@ -54,15 +54,6 @@
#define MMC_BANK2 0x2
-#define MMC_TIMING_UHS_SDR25 1 -#define MMC_TIMING_UHS_SDR50 2 -#define MMC_TIMING_UHS_SDR104 3 -#define MMC_TIMING_UHS_DDR50 4 -#define MMC_TIMING_MMC_HS200 5 -#define MMC_TIMING_SD_HS 6 -#define MMC_TIMING_MMC_DDR52 7 -#define MMC_TIMING_MMC_HS 8 - void zynqmp_dll_reset(u8 deviceid) { /* Issue DLL Reset */ diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 88e478ee11c1..4f62bd008d24 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -32,20 +32,18 @@ struct arasan_sdhci_priv { };
#if defined(CONFIG_ARCH_ZYNQMP) -#define MMC_HS200_BUS_SPEED 5 - static const u8 mode2timing[] = { - [MMC_LEGACY] = UHS_SDR12_BUS_SPEED, - [MMC_HS] = HIGH_SPEED_BUS_SPEED, - [SD_HS] = HIGH_SPEED_BUS_SPEED, - [MMC_HS_52] = HIGH_SPEED_BUS_SPEED, - [MMC_DDR_52] = HIGH_SPEED_BUS_SPEED, - [UHS_SDR12] = UHS_SDR12_BUS_SPEED, - [UHS_SDR25] = UHS_SDR25_BUS_SPEED, - [UHS_SDR50] = UHS_SDR50_BUS_SPEED, - [UHS_DDR50] = UHS_DDR50_BUS_SPEED, - [UHS_SDR104] = UHS_SDR104_BUS_SPEED, - [MMC_HS_200] = MMC_HS200_BUS_SPEED, + [MMC_LEGACY] = MMC_TIMING_LEGACY, + [MMC_HS] = MMC_TIMING_MMC_HS, + [SD_HS] = MMC_TIMING_SD_HS, + [MMC_HS_52] = MMC_TIMING_UHS_SDR50, + [MMC_DDR_52] = MMC_TIMING_UHS_DDR50, + [UHS_SDR12] = MMC_TIMING_UHS_SDR12, + [UHS_SDR25] = MMC_TIMING_UHS_SDR25, + [UHS_SDR50] = MMC_TIMING_UHS_SDR50, + [UHS_DDR50] = MMC_TIMING_UHS_DDR50, + [UHS_SDR104] = MMC_TIMING_UHS_SDR104, + [MMC_HS_200] = MMC_TIMING_MMC_HS200, };
#define SDHCI_TUNING_LOOP_COUNT 40 diff --git a/include/mmc.h b/include/mmc.h index ac7b54f1a7e0..1d377e0281f1 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -360,6 +360,19 @@ enum mmc_voltage { #define MMC_NUM_BOOT_PARTITION 2 #define MMC_PART_RPMB 3 /* RPMB partition number */
+/* timing specification used */ +#define MMC_TIMING_LEGACY 0 +#define MMC_TIMING_MMC_HS 1 +#define MMC_TIMING_SD_HS 2 +#define MMC_TIMING_UHS_SDR12 3 +#define MMC_TIMING_UHS_SDR25 4 +#define MMC_TIMING_UHS_SDR50 5 +#define MMC_TIMING_UHS_SDR104 6 +#define MMC_TIMING_UHS_DDR50 7 +#define MMC_TIMING_MMC_DDR52 8 +#define MMC_TIMING_MMC_HS200 9 +#define MMC_TIMING_MMC_HS400 10 + /* Driver model support */
Just group macros below headers. Other patches will be using this location too.
Signed-off-by: Michal Simek michal.simek@xilinx.com Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com Reviewed-by: Peng Fan peng.fan@nxp.com ---
drivers/mmc/zynq_sdhci.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 4f62bd008d24..998a38450680 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -19,6 +19,8 @@ #include <sdhci.h> #include <zynqmp_tap_delay.h>
+#define SDHCI_TUNING_LOOP_COUNT 40 + struct arasan_sdhci_plat { struct mmc_config cfg; struct mmc mmc; @@ -46,8 +48,6 @@ static const u8 mode2timing[] = { [MMC_HS_200] = MMC_TIMING_MMC_HS200, };
-#define SDHCI_TUNING_LOOP_COUNT 40 - static void arasan_zynqmp_dll_reset(struct sdhci_host *host, u8 deviceid) { u16 clk;
Best Regards, Jaehoon Chung
Define input and output clock phase delays with pre-defined values.
Define arasan_sdhci_clk_data type structure and add it to priv structure and store these clock phase delays in it.
Read input and output clock phase delays from dt. If these values are not passed through dt, use pre-defined values.
drivers/mmc/zynq_sdhci.c | 85 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 85 insertions(+)
diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 998a38450680..e69f375cce07 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -20,6 +20,12 @@ #include <zynqmp_tap_delay.h>
#define SDHCI_TUNING_LOOP_COUNT 40 +#define MMC_BANK2 0x2 + +struct arasan_sdhci_clk_data { + int clk_phase_in[MMC_TIMING_MMC_HS400 + 1]; + int clk_phase_out[MMC_TIMING_MMC_HS400 + 1]; +};
struct arasan_sdhci_plat { struct mmc_config cfg; @@ -28,12 +34,17 @@ struct arasan_sdhci_plat {
struct arasan_sdhci_priv { struct sdhci_host *host; + struct arasan_sdhci_clk_data clk_data; u8 deviceid; u8 bank; u8 no_1p8; };
#if defined(CONFIG_ARCH_ZYNQMP) +/* Default settings for ZynqMP Clock Phases */ +const u32 zynqmp_iclk_phases[] = {0, 63, 63, 0, 63, 0, 0, 183, 54, 0, 0}; +const u32 zynqmp_oclk_phases[] = {0, 72, 60, 0, 60, 72, 135, 48, 72, 135, 0}; + static const u8 mode2timing[] = { [MMC_LEGACY] = MMC_TIMING_LEGACY, [MMC_HS] = MMC_TIMING_MMC_HS, @@ -168,6 +179,79 @@ static void arasan_sdhci_set_tapdelay(struct sdhci_host *host) priv->bank); }
+static void arasan_dt_read_clk_phase(struct udevice *dev, unsigned char timing, + const char *prop) +{ + struct arasan_sdhci_priv *priv = dev_get_priv(dev); + struct arasan_sdhci_clk_data *clk_data = &priv->clk_data; + u32 clk_phase[2] = {0}; + + /* + * Read Tap Delay values from DT, if the DT does not contain the + * Tap Values then use the pre-defined values + */ + if (dev_read_u32_array(dev, prop, &clk_phase[0], 2)) { + dev_dbg(dev, "Using predefined clock phase for %s = %d %d\n", + prop, clk_data->clk_phase_in[timing], + clk_data->clk_phase_out[timing]); + return; + } + + /* The values read are Input and Output Clock Delays in order */ + clk_data->clk_phase_in[timing] = clk_phase[0]; + clk_data->clk_phase_out[timing] = clk_phase[1]; +} + +/** + * arasan_dt_parse_clk_phases - Read Tap Delay values from DT + * + * Called at initialization to parse the values of Tap Delays. + * + * @dev: Pointer to our struct udevice. + */ +static void arasan_dt_parse_clk_phases(struct udevice *dev) +{ + struct arasan_sdhci_priv *priv = dev_get_priv(dev); + struct arasan_sdhci_clk_data *clk_data = &priv->clk_data; + int i; + + if (IS_ENABLED(CONFIG_ARCH_ZYNQMP) && + device_is_compatible(dev, "xlnx,zynqmp-8.9a")) { + for (i = 0; i <= MMC_TIMING_MMC_HS400; i++) { + clk_data->clk_phase_in[i] = zynqmp_iclk_phases[i]; + clk_data->clk_phase_out[i] = zynqmp_oclk_phases[i]; + } + + if (priv->bank == MMC_BANK2) { + clk_data->clk_phase_out[MMC_TIMING_UHS_SDR104] = 90; + clk_data->clk_phase_out[MMC_TIMING_MMC_HS200] = 90; + } + } + + arasan_dt_read_clk_phase(dev, MMC_TIMING_LEGACY, + "clk-phase-legacy"); + arasan_dt_read_clk_phase(dev, MMC_TIMING_MMC_HS, + "clk-phase-mmc-hs"); + arasan_dt_read_clk_phase(dev, MMC_TIMING_SD_HS, + "clk-phase-sd-hs"); + arasan_dt_read_clk_phase(dev, MMC_TIMING_UHS_SDR12, + "clk-phase-uhs-sdr12"); + arasan_dt_read_clk_phase(dev, MMC_TIMING_UHS_SDR25, + "clk-phase-uhs-sdr25"); + arasan_dt_read_clk_phase(dev, MMC_TIMING_UHS_SDR50, + "clk-phase-uhs-sdr50"); + arasan_dt_read_clk_phase(dev, MMC_TIMING_UHS_SDR104, + "clk-phase-uhs-sdr104"); + arasan_dt_read_clk_phase(dev, MMC_TIMING_UHS_DDR50, + "clk-phase-uhs-ddr50"); + arasan_dt_read_clk_phase(dev, MMC_TIMING_MMC_DDR52, + "clk-phase-mmc-ddr52"); + arasan_dt_read_clk_phase(dev, MMC_TIMING_MMC_HS200, + "clk-phase-mmc-hs200"); + arasan_dt_read_clk_phase(dev, MMC_TIMING_MMC_HS400, + "clk-phase-mmc-hs400"); +} + static void arasan_sdhci_set_control_reg(struct sdhci_host *host) { struct mmc *mmc = (struct mmc *)host->mmc; @@ -271,6 +355,7 @@ static int arasan_sdhci_ofdata_to_platdata(struct udevice *dev)
#if defined(CONFIG_ARCH_ZYNQMP) priv->host->ops = &arasan_ops; + arasan_dt_parse_clk_phases(dev); #endif
priv->host->ioaddr = (void *)dev_read_addr(dev);
- int clk_phase_in[MMC_TIMING_MMC_HS400 + 1];
- int clk_phase_out[MMC_TIMING_MMC_HS400 + 1];
- struct arasan_sdhci_clk_data clk_data; u8 deviceid; u8 bank; u8 no_1p8;
const char *prop)
- struct arasan_sdhci_priv *priv = dev_get_priv(dev);
- struct arasan_sdhci_clk_data *clk_data = &priv->clk_data;
- u32 clk_phase[2] = {0};
- if (dev_read_u32_array(dev, prop, &clk_phase[0], 2)) {
return;
- /* The values read are Input and Output Clock Delays in order */
- clk_data->clk_phase_in[timing] = clk_phase[0];
- clk_data->clk_phase_out[timing] = clk_phase[1];
- arasan_dt_parse_clk_phases - Read Tap Delay values from DT
- Called at initialization to parse the values of Tap Delays.
- @dev: Pointer to our struct udevice.
- int i;
- if (IS_ENABLED(CONFIG_ARCH_ZYNQMP) &&
- arasan_dt_read_clk_phase(dev, MMC_TIMING_LEGACY,
- arasan_dt_read_clk_phase(dev, MMC_TIMING_MMC_HS,
- arasan_dt_read_clk_phase(dev, MMC_TIMING_SD_HS,
"clk-phase-sd-hs");
- arasan_dt_read_clk_phase(dev, MMC_TIMING_UHS_SDR12,
- arasan_dt_read_clk_phase(dev, MMC_TIMING_UHS_SDR25,
- arasan_dt_read_clk_phase(dev, MMC_TIMING_UHS_SDR50,
- arasan_dt_read_clk_phase(dev, MMC_TIMING_UHS_SDR104,
- arasan_dt_read_clk_phase(dev, MMC_TIMING_UHS_DDR50,
- arasan_dt_read_clk_phase(dev, MMC_TIMING_MMC_DDR52,
- arasan_dt_read_clk_phase(dev, MMC_TIMING_MMC_HS200,
- arasan_dt_read_clk_phase(dev, MMC_TIMING_MMC_HS400,
- arasan_dt_parse_clk_phases(dev);
#endif
Define and use functions for setting input and output tapdelays based on clk phase delays.
drivers/mmc/zynq_sdhci.c | 128 +++++++++++++++++++++++++++++++++++++-- 1 file changed, 123 insertions(+), 5 deletions(-)
diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index e69f375cce07..8871765711d4 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -166,17 +166,135 @@ static int arasan_sdhci_execute_tuning(struct mmc *mmc, u8 opcode) return 0; }
+/** + * sdhci_zynqmp_sdcardclk_set_phase - Set the SD Output Clock Tap Delays + * + * Set the SD Output Clock Tap Delays for Output path + * + * @host: Pointer to the sdhci_host structure. + * @degrees: The clock phase shift between 0 - 359. + * Return: 0 on success and error value on error + */ +static int sdhci_zynqmp_sdcardclk_set_phase(struct sdhci_host *host, + int degrees) +{ + struct arasan_sdhci_priv *priv = dev_get_priv(host->mmc->dev); + struct mmc *mmc = (struct mmc *)host->mmc; + u8 tap_delay, tap_max = 0; + int ret; + int timing = mode2timing[mmc->selected_mode]; + + /* + * This is applicable for SDHCI_SPEC_300 and above + * ZynqMP does not set phase for <=25MHz clock. + * If degrees is zero, no need to do anything. + */ + if (SDHCI_GET_VERSION(host) < SDHCI_SPEC_300 || + timing == MMC_TIMING_LEGACY || + timing == MMC_TIMING_UHS_SDR12 || !degrees) + return 0; + + switch (timing) { + case MMC_TIMING_MMC_HS: + case MMC_TIMING_SD_HS: + case MMC_TIMING_UHS_SDR25: + case MMC_TIMING_UHS_DDR50: + case MMC_TIMING_MMC_DDR52: + /* For 50MHz clock, 30 Taps are available */ + tap_max = 30; + break; + case MMC_TIMING_UHS_SDR50: + /* For 100MHz clock, 15 Taps are available */ + tap_max = 15; + break; + case MMC_TIMING_UHS_SDR104: + case MMC_TIMING_MMC_HS200: + /* For 200MHz clock, 8 Taps are available */ + tap_max = 8; + default: + break; + } + + tap_delay = (degrees * tap_max) / 360; + + arasan_zynqmp_set_tapdelay(priv->deviceid, 0, tap_delay); + + return ret; +} + +/** + * sdhci_zynqmp_sampleclk_set_phase - Set the SD Input Clock Tap Delays + * + * Set the SD Input Clock Tap Delays for Input path + * + * @host: Pointer to the sdhci_host structure. + * @degrees: The clock phase shift between 0 - 359. + * Return: 0 on success and error value on error + */ +static int sdhci_zynqmp_sampleclk_set_phase(struct sdhci_host *host, + int degrees) +{ + struct arasan_sdhci_priv *priv = dev_get_priv(host->mmc->dev); + struct mmc *mmc = (struct mmc *)host->mmc; + u8 tap_delay, tap_max = 0; + int ret; + int timing = mode2timing[mmc->selected_mode]; + + /* + * This is applicable for SDHCI_SPEC_300 and above + * ZynqMP does not set phase for <=25MHz clock. + * If degrees is zero, no need to do anything. + */ + if (SDHCI_GET_VERSION(host) < SDHCI_SPEC_300 || + timing == MMC_TIMING_LEGACY || + timing == MMC_TIMING_UHS_SDR12 || !degrees) + return 0; + + switch (timing) { + case MMC_TIMING_MMC_HS: + case MMC_TIMING_SD_HS: + case MMC_TIMING_UHS_SDR25: + case MMC_TIMING_UHS_DDR50: + case MMC_TIMING_MMC_DDR52: + /* For 50MHz clock, 120 Taps are available */ + tap_max = 120; + break; + case MMC_TIMING_UHS_SDR50: + /* For 100MHz clock, 60 Taps are available */ + tap_max = 60; + break; + case MMC_TIMING_UHS_SDR104: + case MMC_TIMING_MMC_HS200: + /* For 200MHz clock, 30 Taps are available */ + tap_max = 30; + default: + break; + } + + tap_delay = (degrees * tap_max) / 360; + + arasan_zynqmp_set_tapdelay(priv->deviceid, tap_delay, 0); + + return ret; +} + static void arasan_sdhci_set_tapdelay(struct sdhci_host *host) { struct arasan_sdhci_priv *priv = dev_get_priv(host->mmc->dev); + struct arasan_sdhci_clk_data *clk_data = &priv->clk_data; struct mmc *mmc = (struct mmc *)host->mmc; - u8 uhsmode; + struct udevice *dev = mmc->dev; + u8 timing = mode2timing[mmc->selected_mode]; + u32 iclk_phase = clk_data->clk_phase_in[timing]; + u32 oclk_phase = clk_data->clk_phase_out[timing];
- uhsmode = mode2timing[mmc->selected_mode]; + dev_dbg(dev, "%s, host:%s, mode:%d\n", __func__, host->name, timing);
- if (uhsmode >= UHS_SDR25_BUS_SPEED) - arasan_zynqmp_set_tapdelay(priv->deviceid, uhsmode, - priv->bank); + if (IS_ENABLED(CONFIG_ARCH_ZYNQMP) && + device_is_compatible(dev, "xlnx,zynqmp-8.9a")) { + sdhci_zynqmp_sampleclk_set_phase(host, iclk_phase); + sdhci_zynqmp_sdcardclk_set_phase(host, oclk_phase); + } }
Changes in v3:
- sdhci_zynqmp_sdcardclk_set_phase - Set the SD Output Clock Tap Delays
- Set the SD Output Clock Tap Delays for Output path
- @host: Pointer to the sdhci_host structure.
- @degrees: The clock phase shift between 0 - 359.
- Return: 0 on success and error value on error
int degrees)
- struct arasan_sdhci_priv *priv = dev_get_priv(host->mmc->dev);
- struct mmc *mmc = (struct mmc *)host->mmc;
- u8 tap_delay, tap_max = 0;
- int ret;
- int timing = mode2timing[mmc->selected_mode];
- if (SDHCI_GET_VERSION(host) < SDHCI_SPEC_300 ||
- switch (timing) {
- case MMC_TIMING_MMC_HS:
- case MMC_TIMING_SD_HS:
- case MMC_TIMING_UHS_SDR25:
- case MMC_TIMING_UHS_DDR50:
- case MMC_TIMING_MMC_DDR52:
tap_max = 30;
break;
- case MMC_TIMING_UHS_SDR50:
tap_max = 15;
break;
- case MMC_TIMING_UHS_SDR104:
- case MMC_TIMING_MMC_HS200:
tap_max = 8;
- default:
break;
- tap_delay = (degrees * tap_max) / 360;
- arasan_zynqmp_set_tapdelay(priv->deviceid, 0, tap_delay);
- return ret;
- sdhci_zynqmp_sampleclk_set_phase - Set the SD Input Clock Tap Delays
- Set the SD Input Clock Tap Delays for Input path
int degrees)
- int ret;
- switch (timing) {
tap_max = 120;
break;
tap_max = 60;
break;
tap_max = 30;
- default:
break;
- arasan_zynqmp_set_tapdelay(priv->deviceid, tap_delay, 0);
- return ret;
- struct arasan_sdhci_clk_data *clk_data = &priv->clk_data; struct mmc *mmc = (struct mmc *)host->mmc;
- u8 uhsmode;
- struct udevice *dev = mmc->dev;
- u8 timing = mode2timing[mmc->selected_mode];
- u32 iclk_phase = clk_data->clk_phase_in[timing];
- u32 oclk_phase = clk_data->clk_phase_out[timing];
- dev_dbg(dev, "%s, host:%s, mode:%d\n", __func__, host->name, timing);
priv->bank);
Define default values for input and output clock phase delays for Versal. Also define functions for setting tapdelays based on these clock phase delays.
drivers/mmc/zynq_sdhci.c | 160 ++++++++++++++++++++++++++++++++++++++- 1 file changed, 156 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 8871765711d4..d55ba74b2c38 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -19,6 +19,12 @@ #include <sdhci.h> #include <zynqmp_tap_delay.h>
+#define SDHCI_ARASAN_ITAPDLY_REGISTER 0xF0F8 +#define SDHCI_ARASAN_OTAPDLY_REGISTER 0xF0FC +#define SDHCI_ITAPDLY_CHGWIN 0x200 +#define SDHCI_ITAPDLY_ENABLE 0x100 +#define SDHCI_OTAPDLY_ENABLE 0x40 + #define SDHCI_TUNING_LOOP_COUNT 40 #define MMC_BANK2 0x2
@@ -40,11 +46,15 @@ struct arasan_sdhci_priv { u8 no_1p8; };
-#if defined(CONFIG_ARCH_ZYNQMP) +#if defined(CONFIG_ARCH_ZYNQMP) || defined(CONFIG_ARCH_VERSAL) /* Default settings for ZynqMP Clock Phases */ const u32 zynqmp_iclk_phases[] = {0, 63, 63, 0, 63, 0, 0, 183, 54, 0, 0}; const u32 zynqmp_oclk_phases[] = {0, 72, 60, 0, 60, 72, 135, 48, 72, 135, 0};
+/* Default settings for Versal Clock Phases */ +const u32 versal_iclk_phases[] = {0, 132, 132, 0, 132, 0, 0, 162, 90, 0, 0}; +const u32 versal_oclk_phases[] = {0, 60, 48, 0, 48, 72, 90, 36, 60, 90, 0}; + static const u8 mode2timing[] = { [MMC_LEGACY] = MMC_TIMING_LEGACY, [MMC_HS] = MMC_TIMING_MMC_HS, @@ -278,6 +288,138 @@ static int sdhci_zynqmp_sampleclk_set_phase(struct sdhci_host *host, return ret; }
+/** + * sdhci_versal_sdcardclk_set_phase - Set the SD Output Clock Tap Delays + * + * Set the SD Output Clock Tap Delays for Output path + * + * @host: Pointer to the sdhci_host structure. + * @degrees The clock phase shift between 0 - 359. + * Return: 0 on success and error value on error + */ +static int sdhci_versal_sdcardclk_set_phase(struct sdhci_host *host, + int degrees) +{ + struct mmc *mmc = (struct mmc *)host->mmc; + u8 tap_delay, tap_max = 0; + int ret; + int timing = mode2timing[mmc->selected_mode]; + + /* + * This is applicable for SDHCI_SPEC_300 and above + * Versal does not set phase for <=25MHz clock. + * If degrees is zero, no need to do anything. + */ + if (SDHCI_GET_VERSION(host) < SDHCI_SPEC_300 || + timing == MMC_TIMING_LEGACY || + timing == MMC_TIMING_UHS_SDR12 || !degrees) + return 0; + + switch (timing) { + case MMC_TIMING_MMC_HS: + case MMC_TIMING_SD_HS: + case MMC_TIMING_UHS_SDR25: + case MMC_TIMING_UHS_DDR50: + case MMC_TIMING_MMC_DDR52: + /* For 50MHz clock, 30 Taps are available */ + tap_max = 30; + break; + case MMC_TIMING_UHS_SDR50: + /* For 100MHz clock, 15 Taps are available */ + tap_max = 15; + break; + case MMC_TIMING_UHS_SDR104: + case MMC_TIMING_MMC_HS200: + /* For 200MHz clock, 8 Taps are available */ + tap_max = 8; + default: + break; + } + + tap_delay = (degrees * tap_max) / 360; + + /* Set the Clock Phase */ + if (tap_delay) { + u32 regval; + + regval = sdhci_readl(host, SDHCI_ARASAN_OTAPDLY_REGISTER); + regval |= SDHCI_OTAPDLY_ENABLE; + sdhci_writel(host, regval, SDHCI_ARASAN_OTAPDLY_REGISTER); + regval |= tap_delay; + sdhci_writel(host, regval, SDHCI_ARASAN_OTAPDLY_REGISTER); + } + + return ret; +} + +/** + * sdhci_versal_sampleclk_set_phase - Set the SD Input Clock Tap Delays + * + * Set the SD Input Clock Tap Delays for Input path + * + * @host: Pointer to the sdhci_host structure. + * @degrees The clock phase shift between 0 - 359. + * Return: 0 on success and error value on error + */ +static int sdhci_versal_sampleclk_set_phase(struct sdhci_host *host, + int degrees) +{ + struct mmc *mmc = (struct mmc *)host->mmc; + u8 tap_delay, tap_max = 0; + int ret; + int timing = mode2timing[mmc->selected_mode]; + + /* + * This is applicable for SDHCI_SPEC_300 and above + * Versal does not set phase for <=25MHz clock. + * If degrees is zero, no need to do anything. + */ + if (SDHCI_GET_VERSION(host) < SDHCI_SPEC_300 || + timing == MMC_TIMING_LEGACY || + timing == MMC_TIMING_UHS_SDR12 || !degrees) + return 0; + + switch (timing) { + case MMC_TIMING_MMC_HS: + case MMC_TIMING_SD_HS: + case MMC_TIMING_UHS_SDR25: + case MMC_TIMING_UHS_DDR50: + case MMC_TIMING_MMC_DDR52: + /* For 50MHz clock, 120 Taps are available */ + tap_max = 120; + break; + case MMC_TIMING_UHS_SDR50: + /* For 100MHz clock, 60 Taps are available */ + tap_max = 60; + break; + case MMC_TIMING_UHS_SDR104: + case MMC_TIMING_MMC_HS200: + /* For 200MHz clock, 30 Taps are available */ + tap_max = 30; + default: + break; + } + + tap_delay = (degrees * tap_max) / 360; + + /* Set the Clock Phase */ + if (tap_delay) { + u32 regval; + + regval = sdhci_readl(host, SDHCI_ARASAN_ITAPDLY_REGISTER); + regval |= SDHCI_ITAPDLY_CHGWIN; + sdhci_writel(host, regval, SDHCI_ARASAN_ITAPDLY_REGISTER); + regval |= SDHCI_ITAPDLY_ENABLE; + sdhci_writel(host, regval, SDHCI_ARASAN_ITAPDLY_REGISTER); + regval |= tap_delay; + sdhci_writel(host, regval, SDHCI_ARASAN_ITAPDLY_REGISTER); + regval &= ~SDHCI_ITAPDLY_CHGWIN; + sdhci_writel(host, regval, SDHCI_ARASAN_ITAPDLY_REGISTER); + } + + return ret; +} + static void arasan_sdhci_set_tapdelay(struct sdhci_host *host) { struct arasan_sdhci_priv *priv = dev_get_priv(host->mmc->dev); @@ -294,6 +436,10 @@ static void arasan_sdhci_set_tapdelay(struct sdhci_host *host) device_is_compatible(dev, "xlnx,zynqmp-8.9a")) { sdhci_zynqmp_sampleclk_set_phase(host, iclk_phase); sdhci_zynqmp_sdcardclk_set_phase(host, oclk_phase); + } else if (IS_ENABLED(CONFIG_ARCH_VERSAL) && + device_is_compatible(dev, "xlnx,versal-8.9a")) { + sdhci_versal_sampleclk_set_phase(host, iclk_phase); + sdhci_versal_sdcardclk_set_phase(host, oclk_phase); } }
@@ -346,6 +492,14 @@ static void arasan_dt_parse_clk_phases(struct udevice *dev) } }
+ if (IS_ENABLED(CONFIG_ARCH_VERSAL) && + device_is_compatible(dev, "xlnx,versal-8.9a")) { + for (i = 0; i <= MMC_TIMING_MMC_HS400; i++) { + clk_data->clk_phase_in[i] = versal_iclk_phases[i]; + clk_data->clk_phase_out[i] = versal_oclk_phases[i]; + } + } + arasan_dt_read_clk_phase(dev, MMC_TIMING_LEGACY, "clk-phase-legacy"); arasan_dt_read_clk_phase(dev, MMC_TIMING_MMC_HS, @@ -388,9 +542,7 @@ static void arasan_sdhci_set_control_reg(struct sdhci_host *host) mmc->selected_mode <= UHS_DDR50) sdhci_set_uhs_timing(host); } -#endif
-#if defined(CONFIG_ARCH_ZYNQMP) const struct sdhci_ops arasan_ops = { .platform_execute_tuning = &arasan_sdhci_execute_tuning, .set_delay = &arasan_sdhci_set_tapdelay, @@ -471,7 +623,7 @@ static int arasan_sdhci_ofdata_to_platdata(struct udevice *dev)
priv->host->name = dev->name;
-#if defined(CONFIG_ARCH_ZYNQMP) +#if defined(CONFIG_ARCH_ZYNQMP) || defined(CONFIG_ARCH_VERSAL) priv->host->ops = &arasan_ops; arasan_dt_parse_clk_phases(dev); #endif
Changes in v3:
- sdhci_versal_sdcardclk_set_phase - Set the SD Output Clock Tap Delays
- @degrees The clock phase shift between 0 - 359.
int degrees)
- int ret;
- switch (timing) {
tap_max = 30;
break;
tap_max = 15;
break;
tap_max = 8;
- default:
break;
- /* Set the Clock Phase */
- if (tap_delay) {
u32 regval;
- return ret;
- sdhci_versal_sampleclk_set_phase - Set the SD Input Clock Tap Delays
int degrees)
- int ret;
- switch (timing) {
tap_max = 120;
break;
tap_max = 60;
break;
tap_max = 30;
- default:
break;
- if (tap_delay) {
u32 regval;
- return ret;
- } else if (IS_ENABLED(CONFIG_ARCH_VERSAL) &&
}sdhci_versal_sdcardclk_set_phase(host, oclk_phase);
- if (IS_ENABLED(CONFIG_ARCH_VERSAL) &&
- arasan_dt_read_clk_phase(dev, MMC_TIMING_LEGACY, "clk-phase-legacy"); arasan_dt_read_clk_phase(dev, MMC_TIMING_MMC_HS,
Fix the condition to set UHS timings for speeds upto HS200.
drivers/mmc/zynq_sdhci.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index d55ba74b2c38..147ecc0d708d 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -539,7 +539,7 @@ static void arasan_sdhci_set_control_reg(struct sdhci_host *host) }
if (mmc->selected_mode > SD_HS && - mmc->selected_mode <= UHS_DDR50) + mmc->selected_mode <= MMC_HS_200) sdhci_set_uhs_timing(host); }
sdhci_set_uhs_timing(host);mmc->selected_mode <= MMC_HS_200)
Remove setting tapdelays for different speeds separately. Instead use the ITAP and OTAP delay values which are read from the device tree. If the DT does not contain tap delay values, the predefined values will be used for the same.
Changes in v2: - Add common function to set tapdelays based on the values read from DT - Remove tapdelay settings based on speed
board/xilinx/zynqmp/tap_delays.c | 190 ++++++------------------------- include/zynqmp_tap_delay.h | 5 +- 2 files changed, 36 insertions(+), 159 deletions(-)
diff --git a/board/xilinx/zynqmp/tap_delays.c b/board/xilinx/zynqmp/tap_delays.c index 813650cabcc4..c4770c8fb6e9 100644 --- a/board/xilinx/zynqmp/tap_delays.c +++ b/board/xilinx/zynqmp/tap_delays.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <zynqmp_tap_delay.h> #include <asm/arch/sys_proto.h> #include <linux/delay.h>
@@ -25,34 +26,9 @@ #define SD1_ITAPDLYENA_MASK 0x01000000 #define SD1_ITAPDLYENA 0x01000000 #define SD0_ITAPDLYSEL_MASK 0x000000FF -#define SD0_ITAPDLYSEL_HSD 0x00000015 -#define SD0_ITAPDLYSEL_SD_DDR50 0x0000003D -#define SD0_ITAPDLYSEL_MMC_DDR50 0x00000012 - #define SD1_ITAPDLYSEL_MASK 0x00FF0000 -#define SD1_ITAPDLYSEL_HSD 0x00150000 -#define SD1_ITAPDLYSEL_SD_DDR50 0x003D0000 -#define SD1_ITAPDLYSEL_MMC_DDR50 0x00120000 - #define SD0_OTAPDLYSEL_MASK 0x0000003F -#define SD0_OTAPDLYSEL_MMC_HSD 0x00000006 -#define SD0_OTAPDLYSEL_SD_HSD 0x00000005 -#define SD0_OTAPDLYSEL_SDR50 0x00000003 -#define SD0_OTAPDLYSEL_SDR104_B0 0x00000003 -#define SD0_OTAPDLYSEL_SDR104_B2 0x00000002 -#define SD0_OTAPDLYSEL_SD_DDR50 0x00000004 -#define SD0_OTAPDLYSEL_MMC_DDR50 0x00000006 - #define SD1_OTAPDLYSEL_MASK 0x003F0000 -#define SD1_OTAPDLYSEL_MMC_HSD 0x00060000 -#define SD1_OTAPDLYSEL_SD_HSD 0x00050000 -#define SD1_OTAPDLYSEL_SDR50 0x00030000 -#define SD1_OTAPDLYSEL_SDR104_B0 0x00030000 -#define SD1_OTAPDLYSEL_SDR104_B2 0x00020000 -#define SD1_OTAPDLYSEL_SD_DDR50 0x00040000 -#define SD1_OTAPDLYSEL_MMC_DDR50 0x00060000 - -#define MMC_BANK2 0x2
void zynqmp_dll_reset(u8 deviceid) { @@ -73,149 +49,49 @@ void zynqmp_dll_reset(u8 deviceid) zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST_MASK, 0x0); }
-static void arasan_zynqmp_tap_sdr104(u8 deviceid, u8 timing, u8 bank) -{ - if (deviceid == 0) { - /* Program OTAP */ - if (bank == MMC_BANK2) - zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, - SD0_OTAPDLYSEL_SDR104_B2); - else - zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, - SD0_OTAPDLYSEL_SDR104_B0); - } else { - /* Program OTAP */ - if (bank == MMC_BANK2) - zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, - SD1_OTAPDLYSEL_SDR104_B2); - else - zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, - SD1_OTAPDLYSEL_SDR104_B0); - } -} - -static void arasan_zynqmp_tap_hs(u8 deviceid, u8 timing, u8 bank) -{ - if (deviceid == 0) { - /* Program ITAP */ - zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN_MASK, - SD0_ITAPCHGWIN); - zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYENA_MASK, - SD0_ITAPDLYENA); - zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYSEL_MASK, - SD0_ITAPDLYSEL_HSD); - zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN_MASK, 0x0); - /* Program OTAP */ - if (timing == MMC_TIMING_MMC_HS) - zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, - SD0_OTAPDLYSEL_MMC_HSD); - else - zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, - SD0_OTAPDLYSEL_SD_HSD); - } else { - /* Program ITAP */ - zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN_MASK, - SD1_ITAPCHGWIN); - zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYENA_MASK, - SD1_ITAPDLYENA); - zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYSEL_MASK, - SD1_ITAPDLYSEL_HSD); - zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN_MASK, 0x0); - /* Program OTAP */ - if (timing == MMC_TIMING_MMC_HS) - zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, - SD1_OTAPDLYSEL_MMC_HSD); - else - zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, - SD1_OTAPDLYSEL_SD_HSD); - } -} - -static void arasan_zynqmp_tap_ddr50(u8 deviceid, u8 timing, u8 bank) +void arasan_zynqmp_set_tapdelay(u8 deviceid, u32 itap_delay, u32 otap_delay) { if (deviceid == 0) { + zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST_MASK, + SD0_DLL_RST); /* Program ITAP */ - zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN_MASK, - SD0_ITAPCHGWIN); - zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYENA_MASK, - SD0_ITAPDLYENA); - if (timing == MMC_TIMING_UHS_DDR50) - zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYSEL_MASK, - SD0_ITAPDLYSEL_SD_DDR50); - else + if (itap_delay) { + zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN_MASK, + SD0_ITAPCHGWIN); + zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYENA_MASK, + SD0_ITAPDLYENA); zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPDLYSEL_MASK, - SD0_ITAPDLYSEL_MMC_DDR50); - zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN_MASK, 0x0); + itap_delay); + zynqmp_mmio_write(SD_ITAP_DLY, SD0_ITAPCHGWIN_MASK, + 0x0); + } + /* Program OTAP */ - if (timing == MMC_TIMING_UHS_DDR50) - zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, - SD0_OTAPDLYSEL_SD_DDR50); - else + if (otap_delay) zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, - SD0_OTAPDLYSEL_MMC_DDR50); - } else { - /* Program ITAP */ - zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN_MASK, - SD1_ITAPCHGWIN); - zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYENA_MASK, - SD1_ITAPDLYENA); - if (timing == MMC_TIMING_UHS_DDR50) - zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYSEL_MASK, - SD1_ITAPDLYSEL_SD_DDR50); - else - zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYSEL_MASK, - SD1_ITAPDLYSEL_MMC_DDR50); - zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN_MASK, 0x0); - /* Program OTAP */ - if (timing == MMC_TIMING_UHS_DDR50) - zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, - SD1_OTAPDLYSEL_SD_DDR50); - else - zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, - SD1_OTAPDLYSEL_MMC_DDR50); - } -} + otap_delay);
-static void arasan_zynqmp_tap_sdr50(u8 deviceid, u8 timing, u8 bank) -{ - if (deviceid == 0) { - /* Program OTAP */ - zynqmp_mmio_write(SD_OTAP_DLY, SD0_OTAPDLYSEL_MASK, - SD0_OTAPDLYSEL_SDR50); + zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST_MASK, 0x0); } else { - /* Program OTAP */ - zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, - SD1_OTAPDLYSEL_SDR50); - } -} - -void arasan_zynqmp_set_tapdelay(u8 deviceid, u8 timing, u8 bank) -{ - if (deviceid == 0) - zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST_MASK, - SD0_DLL_RST); - else zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST_MASK, SD1_DLL_RST); + /* Program ITAP */ + if (itap_delay) { + zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN_MASK, + SD1_ITAPCHGWIN); + zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYENA_MASK, + SD1_ITAPDLYENA); + zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPDLYSEL_MASK, + (itap_delay << 16)); + zynqmp_mmio_write(SD_ITAP_DLY, SD1_ITAPCHGWIN_MASK, + 0x0); + }
- switch (timing) { - case MMC_TIMING_UHS_SDR25: - arasan_zynqmp_tap_hs(deviceid, timing, bank); - break; - case MMC_TIMING_UHS_SDR50: - arasan_zynqmp_tap_sdr50(deviceid, timing, bank); - break; - case MMC_TIMING_UHS_SDR104: - case MMC_TIMING_MMC_HS200: - arasan_zynqmp_tap_sdr104(deviceid, timing, bank); - break; - case MMC_TIMING_UHS_DDR50: - arasan_zynqmp_tap_ddr50(deviceid, timing, bank); - break; - } + /* Program OTAP */ + if (otap_delay) + zynqmp_mmio_write(SD_OTAP_DLY, SD1_OTAPDLYSEL_MASK, + (otap_delay << 16));
- if (deviceid == 0) - zynqmp_mmio_write(SD_DLL_CTRL, SD0_DLL_RST_MASK, 0x0); - else zynqmp_mmio_write(SD_DLL_CTRL, SD1_DLL_RST_MASK, 0x0); + } } diff --git a/include/zynqmp_tap_delay.h b/include/zynqmp_tap_delay.h index b07e3e069224..7b713438f752 100644 --- a/include/zynqmp_tap_delay.h +++ b/include/zynqmp_tap_delay.h @@ -10,10 +10,11 @@
#ifdef CONFIG_ARCH_ZYNQMP void zynqmp_dll_reset(u8 deviceid); -void arasan_zynqmp_set_tapdelay(u8 device_id, u8 uhsmode, u8 bank); +void arasan_zynqmp_set_tapdelay(u8 device_id, u32 itap_delay, u32 otap_delay); #else inline void zynqmp_dll_reset(u8 deviceid) {} -inline void arasan_zynqmp_set_tapdelay(u8 device_id, u8 uhsmode, u8 bank) {} +inline void arasan_zynqmp_set_tapdelay(u8 device_id, u32 itap_delay, + u32 otap_delay) {} #endif
#endif
po 26. 10. 2020 v 12:43 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
Thanks, Michal
Changes in v3:
Changes in v2:
-- 2.28.0
The whole series is acked. Applied to my tree.
Thanks, Michal
Jaehoon Chung
Michal Simek
Michal Simek
