[U-Boot] [PATCH v2] TI: DaVinci: GPIO header file and definitions
Some DaVinci SOC's use GPIOs to enable EMAC and DM9000. This patch adds some definitions for GPIO registers and also adds structures for GPIO. A separate header file is being added so that in future we can have a DaVinci GPIO driver similer to OMAP.
Signed-off-by: Sandeep Paulraj s-paulraj@ti.com --- Changes since v1: fix whitespace issue mentioned by Tom include/asm-arm/arch-davinci/gpio_defs.h | 53 ++++++++++++++++++++++++++++++ 1 files changed, 53 insertions(+), 0 deletions(-) create mode 100644 include/asm-arm/arch-davinci/gpio_defs.h
diff --git a/include/asm-arm/arch-davinci/gpio_defs.h b/include/asm-arm/arch-davinci/gpio_defs.h new file mode 100644 index 0000000..ec43969 --- /dev/null +++ b/include/asm-arm/arch-davinci/gpio_defs.h @@ -0,0 +1,53 @@ +/* + * Copyright (C) 2009 Texas Instruments Incorporated + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _GPIO_DEFS_H_ +#define _GPIO_DEFS_H_ + +#define DAVINCI_GPIO_BINTEN 0x01C67008 +#define DAVINCI_GPIO_BANK01 0x01C67010 +#define DAVINCI_GPIO_BANK23 0x01C67038 +#define DAVINCI_GPIO_BANK45 0x01C67060 +#define DAVINCI_GPIO_BANK67 0x01C67088 + +struct davinci_gpio { + unsigned int dir; + unsigned int out_data; + unsigned int set_data; + unsigned int clr_data; + unsigned int in_data; + unsigned int set_rising; + unsigned int clr_rising; + unsigned int set_falling; + unsigned int clr_falling; + unsigned int intstat; +}; + +struct davinci_gpio_bank { + int num_gpio; + unsigned int irq_num; + unsigned int irq_mask; + unsigned long *in_use; + unsigned long base; +}; + +#endif +
- Copyright (C) 2009 Texas Instruments Incorporated
- project.
- MA 02111-1307 USA
- unsigned int dir;
- unsigned int out_data;
- unsigned int set_data;
- unsigned int clr_data;
- unsigned int in_data;
- unsigned int set_rising;
- unsigned int clr_rising;
- unsigned int set_falling;
- unsigned int clr_falling;
- unsigned int intstat;
- int num_gpio;
- unsigned int irq_num;
- unsigned int irq_mask;
- unsigned long *in_use;
- unsigned long base;
Ack-ed Tom
s-paulraj@ti.com
Tom
