[PATCH v5] board: purism: add the Purism Librem5 phone
Initial commit of Librem5 u-boot and SPL
Signed-off-by: Angus Ainslie angus@akkea.ca Co-developed-by: Sebastian Krzyszkowiak sebastian.krzyszkowiak@puri.sm Signed-off-by: Sebastian Krzyszkowiak sebastian.krzyszkowiak@puri.sm ---
All of the pre-requisite patches for this board are now upstream or in review.
Changes since v4:
Include imx8mq-u-boot.dtsi instead of adding a new copy
Changes since v3:
Dropped unused MMCROOT Rebased on u-boot-imx Needs this patch to supress SPL warnings https://lists.denx.de/pipermail/u-boot/2022-April/482369.html
Changes since v2:
Cleanup Kconfig symbols used in librem5.h Cleanup various checkpatch issues Drop some un-used functions
Changes since v1:
Merged patches into a monolithic board patch Using DM drivers for devices in u-boot Added USB storage support for uSD rootfs Dropped many SPL_BUILD guarded define's Fixed documentation index
arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi | 3 + arch/arm/dts/imx8mq-librem5-r4.dts | 35 + arch/arm/dts/imx8mq-librem5.dtsi | 1255 +++++++++++++++++ arch/arm/mach-imx/imx8m/Kconfig | 9 + board/purism/librem5/Kconfig | 15 + board/purism/librem5/MAINTAINERS | 8 + board/purism/librem5/Makefile | 13 + board/purism/librem5/imximage-8mq-lpddr4.cfg | 8 + board/purism/librem5/librem5.c | 425 ++++++ board/purism/librem5/librem5.h | 181 +++ board/purism/librem5/lpddr4_timing.c | 1324 ++++++++++++++++++ board/purism/librem5/lpddr4_timing_b0.c | 1191 ++++++++++++++++ board/purism/librem5/spl.c | 593 ++++++++ configs/librem5_defconfig | 142 ++ doc/board/index.rst | 1 + doc/board/purism/index.rst | 9 + doc/board/purism/librem5.rst | 60 + include/configs/librem5.h | 113 ++ 19 files changed, 5387 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mq-librem5-r4.dts create mode 100644 arch/arm/dts/imx8mq-librem5.dtsi create mode 100644 board/purism/librem5/Kconfig create mode 100644 board/purism/librem5/MAINTAINERS create mode 100644 board/purism/librem5/Makefile create mode 100644 board/purism/librem5/imximage-8mq-lpddr4.cfg create mode 100644 board/purism/librem5/librem5.c create mode 100644 board/purism/librem5/librem5.h create mode 100644 board/purism/librem5/lpddr4_timing.c create mode 100644 board/purism/librem5/lpddr4_timing_b0.c create mode 100644 board/purism/librem5/spl.c create mode 100644 configs/librem5_defconfig create mode 100644 doc/board/purism/index.rst create mode 100644 doc/board/purism/librem5.rst create mode 100644 include/configs/librem5.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 90f86e3fca..719fd7db8d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -937,7 +937,8 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mp-venice-gw74xx.dtb \ imx8mp-verdin.dtb \ imx8mq-pico-pi.dtb \ - imx8mq-kontron-pitx-imx8m.dtb + imx8mq-kontron-pitx-imx8m.dtb \ + imx8mq-librem5-r4.dtb
dtb-$(CONFIG_ARCH_IMXRT) += imxrt1050-evk.dtb \ imxrt1020-evk.dtb diff --git a/arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi b/arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi new file mode 100644 index 0000000000..8a68f53ace --- /dev/null +++ b/arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi @@ -0,0 +1,3 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) + +#include "imx8mq-u-boot.dtsi" diff --git a/arch/arm/dts/imx8mq-librem5-r4.dts b/arch/arm/dts/imx8mq-librem5-r4.dts new file mode 100644 index 0000000000..cbfb49aa25 --- /dev/null +++ b/arch/arm/dts/imx8mq-librem5-r4.dts @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (C) 2020 Purism SPC kernel@puri.sm + +/dts-v1/; + +#include "imx8mq-librem5.dtsi" + +/ { + model = "Purism Librem 5r4"; + compatible = "purism,librem5r4", "purism,librem5", "fsl,imx8mq"; +}; + +&accel_gyro { + mount-matrix = "1", "0", "0", + "0", "1", "0", + "0", "0", "-1"; +}; + +&bat { + maxim,rsns-microohm = <1667>; +}; + +&bq25895 { + ti,battery-regulation-voltage = <4200000>; /* uV */ + ti,charge-current = <1500000>; /* uA */ + ti,termination-current = <144000>; /* uA */ +}; + +&led_backlight { + led-max-microamp = <25000>; +}; + +&proximity { + proximity-near-level = <10>; +}; diff --git a/arch/arm/dts/imx8mq-librem5.dtsi b/arch/arm/dts/imx8mq-librem5.dtsi new file mode 100644 index 0000000000..60d47c7149 --- /dev/null +++ b/arch/arm/dts/imx8mq-librem5.dtsi @@ -0,0 +1,1255 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018-2020 Purism SPC + */ + +/dts-v1/; + +#include "dt-bindings/input/input.h" +#include <dt-bindings/interrupt-controller/irq.h> +#include "dt-bindings/pwm/pwm.h" +#include "dt-bindings/usb/pd.h" +#include "imx8mq.dtsi" + +/ { + model = "Purism Librem 5"; + compatible = "purism,librem5", "fsl,imx8mq"; + + backlight_dsi: backlight-dsi { + compatible = "led-backlight"; + leds = <&led_backlight>; + }; + + pmic_osc: clock-pmic { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "pmic_osc"; + }; + + chosen { + stdout-path = &uart1; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_keys>; + + vol-down { + label = "VOL_DOWN"; + gpios = <&gpio1 17 GPIO_ACTIVE_LOW>; + linux,code = <KEY_VOLUMEDOWN>; + debounce-interval = <50>; + }; + + vol-up { + label = "VOL_UP"; + gpios = <&gpio1 16 GPIO_ACTIVE_LOW>; + linux,code = <KEY_VOLUMEUP>; + debounce-interval = <50>; + }; + }; + + reg_aud_1v8: regulator-audio-1v8 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_audiopwr>; + regulator-name = "AUDIO_PWR_EN"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + gpio = <&gpio1 4 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_gnss: regulator-gnss { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gnsspwr>; + regulator-name = "GNSS"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio3 12 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_hub: regulator-hub { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hub_pwr>; + regulator-name = "HUB"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio1 14 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_lcd_1v8: regulator-lcd-1v8 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_dsien>; + regulator-name = "LCD_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <®_vdd_1v8>; + gpio = <&gpio1 5 GPIO_ACTIVE_HIGH>; + enable-active-high; + /* Otherwise i2c3 is not functional */ + regulator-always-on; + }; + + reg_lcd_3v4: regulator-lcd-3v4 { + compatible = "regulator-fixed"; + regulator-name = "LCD_3V4"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_dsibiasen>; + vin-supply = <®_vsys_3v4>; + gpio = <&gpio1 20 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_vdd_sen: regulator-vdd-sen { + compatible = "regulator-fixed"; + regulator-name = "VDD_SEN"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + reg_vdd_1v8: regulator-vdd-1v8 { + compatible = "regulator-fixed"; + regulator-name = "VDD_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&buck7_reg>; + }; + + reg_vdd_3v3: regulator-vdd-3v3 { + compatible = "regulator-fixed"; + regulator-name = "VDD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + reg_vsys_3v4: regulator-vsys-3v4 { + compatible = "regulator-fixed"; + regulator-name = "VSYS_3V4"; + regulator-min-microvolt = <3400000>; + regulator-max-microvolt = <3400000>; + regulator-always-on; + }; + + reg_wifi_3v3: regulator-wifi-3v3 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wifi_pwr>; + regulator-name = "3V3_WIFI"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio3 10 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <®_vdd_3v3>; + }; + + sound { + compatible = "simple-audio-card"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hp>; + simple-audio-card,name = "Librem 5"; + simple-audio-card,format = "i2s"; + simple-audio-card,widgets = + "Headphone", "Headphones", + "Microphone", "Headset Mic", + "Microphone", "Digital Mic", + "Speaker", "Speaker"; + simple-audio-card,routing = + "Headphones", "HPOUTL", + "Headphones", "HPOUTR", + "Speaker", "SPKOUTL", + "Speaker", "SPKOUTR", + "Headset Mic", "MICBIAS", + "IN3R", "Headset Mic", + "DMICDAT", "Digital Mic"; + simple-audio-card,hp-det-gpio = <&gpio3 9 GPIO_ACTIVE_HIGH>; + + simple-audio-card,cpu { + sound-dai = <&sai2>; + }; + + simple-audio-card,codec { + sound-dai = <&codec>; + clocks = <&clk IMX8MQ_CLK_SAI2_ROOT>; + frame-master; + bitclock-master; + }; + }; + + sound-wwan { + compatible = "simple-audio-card"; + simple-audio-card,name = "Modem"; + simple-audio-card,format = "i2s"; + + simple-audio-card,cpu { + sound-dai = <&sai6>; + frame-inversion; + }; + + simple-audio-card,codec { + sound-dai = <&bm818_codec>; + frame-master; + bitclock-master; + }; + }; + + usdhc2_pwrseq: pwrseq { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_bt>, <&pinctrl_wifi_disable>; + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&gpio3 25 GPIO_ACTIVE_HIGH>, + <&gpio4 29 GPIO_ACTIVE_HIGH>; + }; + + bm818_codec: sound-wwan-codec { + compatible = "broadmobi,bm818", "option,gtm601"; + #sound-dai-cells = <0>; + }; + + vibrator { + compatible = "pwm-vibrator"; + pwms = <&pwm1 0 1000000000 0>; + pwm-names = "enable"; + vcc-supply = <®_vdd_3v3>; + }; +}; + +&A53_0 { + cpu-supply = <&buck2_reg>; +}; + +&A53_1 { + cpu-supply = <&buck2_reg>; +}; + +&A53_2 { + cpu-supply = <&buck2_reg>; +}; + +&A53_3 { + cpu-supply = <&buck2_reg>; +}; + +&ddrc { + operating-points-v2 = <&ddrc_opp_table>; + + ddrc_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-25M { + opp-hz = /bits/ 64 <25000000>; + }; + + opp-100M { + opp-hz = /bits/ 64 <100000000>; + }; + + opp-800M { + opp-hz = /bits/ 64 <800000000>; + }; + }; +}; + +&dphy { + status = "okay"; +}; + +&ecspi1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi1>; + cs-gpios = <&gpio5 9 GPIO_ACTIVE_LOW>; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + nor_flash: flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <1000000>; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "protected0"; + reg = <0x0 0x30000>; + read-only; + }; + + partition@30000 { + label = "protected1"; + reg = <0x30000 0x10000>; + read-only; + }; + + partition@40000 { + label = "rw"; + reg = <0x40000 0x1C0000>; + }; + }; +}; + +&gpio1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pmic_5v>; + + pmic-5v-hog { + gpio-hog; + gpios = <1 GPIO_ACTIVE_HIGH>; + input; + lane-mapping = "pmic-5v"; + }; +}; + +&iomuxc { + pinctrl_audiopwr: audiopwrgrp { + fsl,pins = < + /* AUDIO_POWER_EN_3V3 */ + MX8MQ_IOMUXC_GPIO1_IO04_GPIO1_IO4 0x83 + >; + }; + + pinctrl_bl: blgrp { + fsl,pins = < + /* BACKLINGE_EN */ + MX8MQ_IOMUXC_NAND_DQS_GPIO3_IO14 0x83 + >; + }; + + pinctrl_bt: btgrp { + fsl,pins = < + /* BT_REG_ON */ + MX8MQ_IOMUXC_SAI5_MCLK_GPIO3_IO25 0x83 + >; + }; + + pinctrl_charger_in: chargeringrp { + fsl,pins = < + /* CHRG_INT */ + MX8MQ_IOMUXC_NAND_CE2_B_GPIO3_IO3 0x80 + /* CHG_STATUS_B */ + MX8MQ_IOMUXC_NAND_ALE_GPIO3_IO0 0x80 + >; + }; + + pinctrl_dsibiasen: dsibiasengrp { + fsl,pins = < + /* DSI_BIAS_EN */ + MX8MQ_IOMUXC_ENET_TD1_GPIO1_IO20 0x83 + >; + }; + + pinctrl_dsien: dsiengrp { + fsl,pins = < + /* DSI_EN_3V3 */ + MX8MQ_IOMUXC_GPIO1_IO05_GPIO1_IO5 0x83 + >; + }; + + pinctrl_dsirst: dsirstgrp { + fsl,pins = < + /* DSI_RST */ + MX8MQ_IOMUXC_ENET_RD3_GPIO1_IO29 0x83 + /* DSI_TE */ + MX8MQ_IOMUXC_ENET_RD2_GPIO1_IO28 0x83 + /* TP_RST */ + MX8MQ_IOMUXC_ENET_RX_CTL_GPIO1_IO24 0x83 + >; + }; + + pinctrl_ecspi1: ecspigrp { + fsl,pins = < + MX8MQ_IOMUXC_ECSPI1_MOSI_ECSPI1_MOSI 0x83 + MX8MQ_IOMUXC_ECSPI1_MISO_ECSPI1_MISO 0x83 + MX8MQ_IOMUXC_ECSPI1_SS0_GPIO5_IO9 0x19 + MX8MQ_IOMUXC_ECSPI1_SCLK_ECSPI1_SCLK 0x83 + >; + }; + + pinctrl_gauge: gaugegrp { + fsl,pins = < + /* BAT_LOW */ + MX8MQ_IOMUXC_SAI5_RXC_GPIO3_IO20 0x80 + >; + }; + + pinctrl_gnsspwr: gnsspwrgrp { + fsl,pins = < + /* GPS3V3_EN */ + MX8MQ_IOMUXC_NAND_DATA06_GPIO3_IO12 0x83 + >; + }; + + pinctrl_haptic: hapticgrp { + fsl,pins = < + /* MOTO */ + MX8MQ_IOMUXC_SPDIF_EXT_CLK_PWM1_OUT 0x83 + >; + }; + + pinctrl_hp: hpgrp { + fsl,pins = < + /* HEADPHONE_DET_1V8 */ + MX8MQ_IOMUXC_NAND_DATA03_GPIO3_IO9 0x180 + >; + }; + + pinctrl_hub_pwr: hubpwrgrp { + fsl,pins = < + /* HUB_PWR_3V3_EN */ + MX8MQ_IOMUXC_GPIO1_IO14_GPIO1_IO14 0x83 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MQ_IOMUXC_I2C1_SCL_I2C1_SCL 0x40000026 + MX8MQ_IOMUXC_I2C1_SDA_I2C1_SDA 0x40000026 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MQ_IOMUXC_I2C2_SCL_I2C2_SCL 0x40000026 + MX8MQ_IOMUXC_I2C2_SDA_I2C2_SDA 0x40000026 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX8MQ_IOMUXC_I2C3_SCL_I2C3_SCL 0x40000026 + MX8MQ_IOMUXC_I2C3_SDA_I2C3_SDA 0x40000026 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX8MQ_IOMUXC_I2C4_SCL_I2C4_SCL 0x40000026 + MX8MQ_IOMUXC_I2C4_SDA_I2C4_SDA 0x40000026 + >; + }; + + pinctrl_keys: keysgrp { + fsl,pins = < + /* VOL- */ + MX8MQ_IOMUXC_ENET_MDIO_GPIO1_IO17 0x01C0 + /* VOL+ */ + MX8MQ_IOMUXC_ENET_MDC_GPIO1_IO16 0x01C0 + >; + }; + + pinctrl_led_b: ledbgrp { + fsl,pins = < + /* LED_B */ + MX8MQ_IOMUXC_GPIO1_IO13_PWM2_OUT 0x06 + >; + }; + + pinctrl_led_g: ledggrp { + fsl,pins = < + /* LED_G */ + MX8MQ_IOMUXC_SAI3_MCLK_PWM4_OUT 0x06 + >; + }; + + pinctrl_led_r: ledrgrp { + fsl,pins = < + /* LED_R */ + MX8MQ_IOMUXC_SPDIF_TX_PWM3_OUT 0x06 + >; + }; + + pinctrl_mag: maggrp { + fsl,pins = < + /* INT_MAG */ + MX8MQ_IOMUXC_SAI5_RXD1_GPIO3_IO22 0x80 + >; + }; + + pinctrl_pmic: pmicgrp { + fsl,pins = < + /* PMIC_NINT */ + MX8MQ_IOMUXC_GPIO1_IO07_GPIO1_IO7 0x80 + >; + }; + + pinctrl_pmic_5v: pmic5vgrp { + fsl,pins = < + /* PMIC_5V */ + MX8MQ_IOMUXC_GPIO1_IO01_GPIO1_IO1 0x80 + >; + }; + + pinctrl_prox: proxgrp { + fsl,pins = < + /* INT_LIGHT */ + MX8MQ_IOMUXC_NAND_DATA01_GPIO3_IO7 0x80 + >; + }; + + pinctrl_rtc: rtcgrp { + fsl,pins = < + /* RTC_INT */ + MX8MQ_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x80 + >; + }; + + pinctrl_sai2: sai2grp { + fsl,pins = < + MX8MQ_IOMUXC_SAI2_TXD0_SAI2_TX_DATA0 0xd6 + MX8MQ_IOMUXC_SAI2_TXFS_SAI2_TX_SYNC 0xd6 + MX8MQ_IOMUXC_SAI2_MCLK_SAI2_MCLK 0xd6 + MX8MQ_IOMUXC_SAI2_RXD0_SAI2_RX_DATA0 0xd6 + MX8MQ_IOMUXC_SAI2_TXC_SAI2_TX_BCLK 0xd6 + >; + }; + + pinctrl_sai6: sai6grp { + fsl,pins = < + MX8MQ_IOMUXC_SAI1_RXD5_SAI6_RX_DATA0 0xd6 + MX8MQ_IOMUXC_SAI1_RXD6_SAI6_RX_SYNC 0xd6 + MX8MQ_IOMUXC_SAI1_TXD4_SAI6_RX_BCLK 0xd6 + MX8MQ_IOMUXC_SAI1_TXD5_SAI6_TX_DATA0 0xd6 + >; + }; + + pinctrl_tcpc: tcpcgrp { + fsl,pins = < + /* TCPC_INT */ + MX8MQ_IOMUXC_GPIO1_IO10_GPIO1_IO10 0x01C0 + >; + }; + + pinctrl_touch: touchgrp { + fsl,pins = < + /* TP_INT */ + MX8MQ_IOMUXC_ENET_RD1_GPIO1_IO27 0x80 + >; + }; + + pinctrl_typec: typecgrp { + fsl,pins = < + /* TYPEC_MUX_EN */ + MX8MQ_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x83 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX8MQ_IOMUXC_UART1_RXD_UART1_DCE_RX 0x49 + MX8MQ_IOMUXC_UART1_TXD_UART1_DCE_TX 0x49 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MQ_IOMUXC_UART2_TXD_UART2_DCE_TX 0x49 + MX8MQ_IOMUXC_UART2_RXD_UART2_DCE_RX 0x49 + >; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX8MQ_IOMUXC_UART3_RXD_UART3_DCE_RX 0x49 + MX8MQ_IOMUXC_UART3_TXD_UART3_DCE_TX 0x49 + >; + }; + + pinctrl_uart4: uart4grp { + fsl,pins = < + MX8MQ_IOMUXC_ECSPI2_SCLK_UART4_DCE_RX 0x49 + MX8MQ_IOMUXC_ECSPI2_MOSI_UART4_DCE_TX 0x49 + MX8MQ_IOMUXC_ECSPI2_MISO_UART4_DCE_CTS_B 0x49 + MX8MQ_IOMUXC_ECSPI2_SS0_UART4_DCE_RTS_B 0x49 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x83 + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xc3 + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xc3 + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xc3 + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xc3 + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xc3 + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xc3 + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xc3 + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xc3 + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xc3 + MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x83 + MX8MQ_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0xc1 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp100mhz { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x8d + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xcd + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xcd + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xcd + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xcd + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xcd + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xcd + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xcd + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xcd + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xcd + MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x8d + MX8MQ_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0xc1 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp200mhz { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x9f + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xdf + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xdf + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xdf + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xdf + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xdf + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xdf + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xdf + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xdf + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xdf + MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x9f + MX8MQ_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0xc1 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CD_B_GPIO2_IO12 0x80 + MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x83 + MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xc3 + MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xc3 + MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xc3 + MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xc3 + MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xc3 + MX8MQ_IOMUXC_SD2_RESET_B_USDHC2_RESET_B 0xc1 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2grp100mhz { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CD_B_GPIO2_IO12 0x80 + MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x8d + MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xcd + MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xcd + MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xcd + MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xcd + MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xcd + MX8MQ_IOMUXC_SD2_RESET_B_USDHC2_RESET_B 0xc1 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2grp200mhz { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CD_B_GPIO2_IO12 0x80 + MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x9f + MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xcf + MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xcf + MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xcf + MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xcf + MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xcf + MX8MQ_IOMUXC_SD2_RESET_B_USDHC2_RESET_B 0xc1 + >; + }; + + pinctrl_wifi_disable: wifidisablegrp { + fsl,pins = < + /* WIFI_REG_ON */ + MX8MQ_IOMUXC_SAI3_RXC_GPIO4_IO29 0x83 + >; + }; + + pinctrl_wifi_pwr: wifipwrgrp { + fsl,pins = < + /* WIFI3V3_EN */ + MX8MQ_IOMUXC_NAND_DATA04_GPIO3_IO10 0x83 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + /* nWDOG */ + MX8MQ_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0x1f + >; + }; +}; + +&i2c1 { + clock-frequency = <387000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + typec_pd: usb-pd@3f { + compatible = "ti,tps6598x"; + reg = <0x3f>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_typec>, <&pinctrl_tcpc>; + interrupt-parent = <&gpio1>; + interrupts = <10 IRQ_TYPE_LEVEL_LOW>; + interrupt-names = "irq"; + + connector { + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + usb_con_hs: endpoint { + remote-endpoint = <&typec_hs>; + }; + }; + + port@1 { + reg = <1>; + + usb_con_ss: endpoint { + remote-endpoint = <&typec_ss>; + }; + }; + }; + }; + }; + + pmic: pmic@4b { + compatible = "rohm,bd71837"; + reg = <0x4b>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pmic>; + clocks = <&pmic_osc>; + clock-names = "osc"; + clock-output-names = "pmic_clk"; + interrupt-parent = <&gpio1>; + interrupts = <7 IRQ_TYPE_LEVEL_LOW>; + rohm,reset-snvs-powered; + + regulators { + buck1_reg: BUCK1 { + regulator-name = "buck1"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-ramp-delay = <1250>; + rohm,dvs-run-voltage = <900000>; + rohm,dvs-idle-voltage = <850000>; + rohm,dvs-suspend-voltage = <800000>; + regulator-always-on; + }; + + buck2_reg: BUCK2 { + regulator-name = "buck2"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + regulator-ramp-delay = <1250>; + rohm,dvs-run-voltage = <1000000>; + rohm,dvs-idle-voltage = <900000>; + regulator-always-on; + }; + + buck3_reg: BUCK3 { + regulator-name = "buck3"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + regulator-boot-on; + rohm,dvs-run-voltage = <900000>; + }; + + buck4_reg: BUCK4 { + regulator-name = "buck4"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1300000>; + rohm,dvs-run-voltage = <1000000>; + }; + + buck5_reg: BUCK5 { + regulator-name = "buck5"; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1350000>; + regulator-boot-on; + regulator-always-on; + }; + + buck6_reg: BUCK6 { + regulator-name = "buck6"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + buck7_reg: BUCK7 { + regulator-name = "buck7"; + regulator-min-microvolt = <1605000>; + regulator-max-microvolt = <1995000>; + regulator-boot-on; + regulator-always-on; + }; + + buck8_reg: BUCK8 { + regulator-name = "buck8"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1_reg: LDO1 { + regulator-name = "ldo1"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + /* leave on for snvs power button */ + regulator-always-on; + }; + + ldo2_reg: LDO2 { + regulator-name = "ldo2"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-boot-on; + /* leave on for snvs power button */ + regulator-always-on; + }; + + ldo3_reg: LDO3 { + regulator-name = "ldo3"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4_reg: LDO4 { + regulator-name = "ldo4"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo5_reg: LDO5 { + /* VDD_PHY_0V9 - MIPI and HDMI domains */ + regulator-name = "ldo5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + ldo6_reg: LDO6 { + /* VDD_PHY_0V9 - MIPI, HDMI and USB domains */ + regulator-name = "ldo6"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo7_reg: LDO7 { + /* VDD_PHY_3V3 - USB domain */ + regulator-name = "ldo7"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; + + rtc@68 { + compatible = "microcrystal,rv4162"; + reg = <0x68>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_rtc>; + interrupt-parent = <&gpio1>; + interrupts = <9 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +&i2c2 { + clock-frequency = <387000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + magnetometer@1e { + compatible = "st,lsm9ds1-magn"; + reg = <0x1e>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_mag>; + interrupt-parent = <&gpio3>; + interrupts = <22 IRQ_TYPE_LEVEL_HIGH>; + vdd-supply = <®_vdd_sen>; + vddio-supply = <®_vdd_1v8>; + }; + + regulator@3e { + compatible = "tps65132"; + reg = <0x3e>; + + reg_lcd_avdd: outp { + regulator-name = "LCD_AVDD"; + vin-supply = <®_lcd_3v4>; + }; + + reg_lcd_avee: outn { + regulator-name = "LCD_AVEE"; + vin-supply = <®_lcd_3v4>; + }; + }; + + proximity: prox@60 { + compatible = "vishay,vcnl4040"; + reg = <0x60>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_prox>; + interrupt-parent = <&gpio3>; + interrupts = <7 IRQ_TYPE_LEVEL_LOW>; + }; + + accel_gyro: accel-gyro@6a { + compatible = "st,lsm9ds1-imu"; + reg = <0x6a>; + vdd-supply = <®_vdd_sen>; + vddio-supply = <®_vdd_1v8>; + }; +}; + +&i2c3 { + clock-frequency = <387000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; + + codec: audio-codec@1a { + compatible = "wlf,wm8962"; + reg = <0x1a>; + clocks = <&clk IMX8MQ_CLK_SAI2_ROOT>; + assigned-clocks = <&clk IMX8MQ_CLK_SAI2>; + assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1_OUT>; + assigned-clock-rates = <24576000>; + #sound-dai-cells = <0>; + mic-cfg = <0x200>; + DCVDD-supply = <®_aud_1v8>; + DBVDD-supply = <®_aud_1v8>; + AVDD-supply = <®_aud_1v8>; + CPVDD-supply = <®_aud_1v8>; + MICVDD-supply = <®_aud_1v8>; + PLLVDD-supply = <®_aud_1v8>; + SPKVDD1-supply = <®_vsys_3v4>; + SPKVDD2-supply = <®_vsys_3v4>; + gpio-cfg = < + 0x0000 /* n/c */ + 0x0001 /* gpio2, 1: default */ + 0x0013 /* gpio3, 2: dmicclk */ + 0x0000 /* n/c, 3: default */ + 0x8014 /* gpio5, 4: dmic_dat */ + 0x0000 /* gpio6, 5: default */ + >; + }; + + backlight@36 { + compatible = "ti,lm36922"; + reg = <0x36>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_bl>; + #address-cells = <1>; + #size-cells = <0>; + enable-gpios = <&gpio3 14 GPIO_ACTIVE_HIGH>; + vled-supply = <®_vsys_3v4>; + ti,ovp-microvolt = <25000000>; + + led_backlight: led@0 { + reg = <0>; + label = ":backlight"; + linux,default-trigger = "backlight"; + led-max-microamp = <20000>; + }; + }; + + touchscreen@38 { + compatible = "edt,edt-ft5506"; + reg = <0x38>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_touch>; + interrupt-parent = <&gpio1>; + interrupts = <27 IRQ_TYPE_EDGE_FALLING>; + touchscreen-size-x = <720>; + touchscreen-size-y = <1440>; + vcc-supply = <®_lcd_1v8>; + }; +}; + +&i2c4 { + clock-frequency = <387000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + status = "okay"; + + bat: fuel-gauge@36 { + compatible = "maxim,max17055"; + reg = <0x36>; + interrupt-parent = <&gpio3>; + interrupts = <20 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gauge>; + maxim,over-heat-temp = <700>; + maxim,over-volt = <4500>; + maxim,rsns-microohm = <5000>; + }; + + bq25895: charger@6a { + compatible = "ti,bq25895", "ti,bq25890"; + reg = <0x6a>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_charger_in>; + interrupt-parent = <&gpio3>; + interrupts = <3 IRQ_TYPE_EDGE_FALLING>; + phys = <&usb3_phy0>; + ti,precharge-current = <130000>; /* uA */ + ti,minimum-sys-voltage = <3700000>; /* uV */ + ti,boost-voltage = <5000000>; /* uV */ + ti,boost-max-current = <500000>; /* uA */ + ti,use-vinmin-threshold = <1>; /* enable VINDPM */ + ti,vinmin-threshold = <3900000>; /* uV */ + monitored-battery = <&bat>; + power-supplies = <&typec_pd>; + }; +}; + +&lcdif { + status = "okay"; +}; + +&mipi_dsi { + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + lcd_panel: panel@0 { + compatible = "mantix,mlaf057we51-x"; + reg = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_dsirst>; + avdd-supply = <®_lcd_avdd>; + avee-supply = <®_lcd_avee>; + vddi-supply = <®_lcd_1v8>; + backlight = <&backlight_dsi>; + reset-gpios = <&gpio1 29 GPIO_ACTIVE_LOW>; + mantix,tp-rstn-gpios = <&gpio1 24 GPIO_ACTIVE_LOW>; + + port { + panel_in: endpoint { + remote-endpoint = <&mipi_dsi_out>; + }; + }; + }; + + ports { + port@1 { + reg = <1>; + + mipi_dsi_out: endpoint { + remote-endpoint = <&panel_in>; + }; + }; + }; +}; + +&pgc_gpu { + power-supply = <&buck3_reg>; +}; + +&pgc_mipi { + power-supply = <&ldo5_reg>; +}; + +&pgc_vpu { + power-supply = <&buck4_reg>; +}; + +&pwm1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_haptic>; + status = "okay"; +}; + +&pwm2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_led_b>; + status = "okay"; +}; + +&pwm3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_led_r>; + status = "okay"; +}; + +&pwm4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_led_g>; + status = "okay"; +}; + +&sai2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai2>; + assigned-clocks = <&clk IMX8MQ_CLK_SAI2>; + assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1_OUT>; + assigned-clock-rates = <24576000>; + status = "okay"; +}; + +&sai6 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai6>; + assigned-clocks = <&clk IMX8MQ_CLK_SAI6>; + assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1_OUT>; + assigned-clock-rates = <24576000>; + fsl,sai-synchronous-rx; + status = "okay"; +}; + +&snvs_pwrkey { + status = "okay"; +}; + +&snvs_rtc { + status = "disabled"; +}; + +&uart1 { /* console */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&uart2 { /* TPS - GPS - DEBUG */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; + + gnss { + compatible = "globaltop,pa6h"; + vcc-supply = <®_gnss>; + current-speed = <9600>; + }; +}; + +&uart3 { /* SMC */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + status = "okay"; +}; + +&uart4 { /* BT */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart4>; + uart-has-rtscts; + status = "okay"; +}; + +&usb3_phy0 { + status = "okay"; +}; + +&usb3_phy1 { + vbus-supply = <®_hub>; + status = "okay"; +}; + +&usb_dwc3_0 { + #address-cells = <1>; + #size-cells = <0>; + dr_mode = "otg"; + snps,dis_u3_susphy_quirk; + status = "okay"; + + port@0 { + reg = <0>; + + typec_hs: endpoint { + remote-endpoint = <&usb_con_hs>; + }; + }; + + port@1 { + reg = <1>; + + typec_ss: endpoint { + remote-endpoint = <&usb_con_ss>; + }; + }; +}; + +&usb_dwc3_1 { + dr_mode = "host"; + status = "okay"; + #address-cells = <1>; + #size-cells = <0>; + + /* Microchip USB2642 */ + hub@1 { + compatible = "usb424,2640"; + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + mass-storage@1 { + compatible = "usb424,4041"; + reg = <1>; + }; + }; +}; + +&usdhc1 { + assigned-clocks = <&clk IMX8MQ_CLK_USDHC1>; + assigned-clock-rates = <400000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; + bus-width = <8>; + vmmc-supply = <®_vdd_3v3>; + power-supply = <®_vdd_1v8>; + non-removable; + status = "okay"; +}; + +&usdhc2 { + assigned-clocks = <&clk IMX8MQ_CLK_USDHC2>; + assigned-clock-rates = <200000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>; + bus-width = <4>; + vmmc-supply = <®_wifi_3v3>; + mmc-pwrseq = <&usdhc2_pwrseq>; + post-power-on-delay-ms = <1000>; + cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>; + max-frequency = <50000000>; + disable-wp; + cap-sdio-irq; + keep-power-in-suspend; + wakeup-source; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 24299ae037..11a2abf00c 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -257,6 +257,14 @@ config TARGET_IMX8MP_RSB3720A1_6G select IMX8MP select SUPPORT_SPL select IMX8M_LPDDR4 + +config TARGET_LIBREM5 + bool "Purism Librem5 Phone" + select BINMAN + select IMX8MQ + select SUPPORT_SPL + select IMX8M_LPDDR4 + endchoice
source "board/advantech/imx8mp_rsb3720a1/Kconfig" @@ -277,6 +285,7 @@ source "board/kontron/sl-mx8mm/Kconfig" source "board/menlo/mx8menlo/Kconfig" source "board/phytec/phycore_imx8mm/Kconfig" source "board/phytec/phycore_imx8mp/Kconfig" +source "board/purism/librem5/Kconfig" source "board/ronetix/imx8mq-cm/Kconfig" source "board/technexion/pico-imx8mq/Kconfig" source "board/variscite/imx8mn_var_som/Kconfig" diff --git a/board/purism/librem5/Kconfig b/board/purism/librem5/Kconfig new file mode 100644 index 0000000000..cf0f303683 --- /dev/null +++ b/board/purism/librem5/Kconfig @@ -0,0 +1,15 @@ +if TARGET_LIBREM5 + +config SYS_BOARD + default "librem5" + +config SYS_VENDOR + default "purism" + +config SYS_CONFIG_NAME + default "librem5" + +config IMX_CONFIG + default "board/purism/librem5/imximage-8mq-lpddr4.cfg" + +endif diff --git a/board/purism/librem5/MAINTAINERS b/board/purism/librem5/MAINTAINERS new file mode 100644 index 0000000000..09e7f20e33 --- /dev/null +++ b/board/purism/librem5/MAINTAINERS @@ -0,0 +1,8 @@ +PURISM LIBREM5 PHONE +M: Angus Ainslie angus@akkea.ca +R: kernel@puri.sm +S: Supported +F: arch/arm/dts/imx8mq-librem5* +F: board/purism/librem5/ +F: configs/librem5_defconfig +F: include/configs/librem5.h diff --git a/board/purism/librem5/Makefile b/board/purism/librem5/Makefile new file mode 100644 index 0000000000..47f25f047b --- /dev/null +++ b/board/purism/librem5/Makefile @@ -0,0 +1,13 @@ +# +# Copyright 2017 NXP +# Copyright 2019 Purism +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += librem5.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o lpddr4_timing_b0.o +endif diff --git a/board/purism/librem5/imximage-8mq-lpddr4.cfg b/board/purism/librem5/imximage-8mq-lpddr4.cfg new file mode 100644 index 0000000000..648471028f --- /dev/null +++ b/board/purism/librem5/imximage-8mq-lpddr4.cfg @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 NXP + */ + +BOOT_FROM sd +SIGNED_HDMI signed_dp_imx8m.bin +LOADER u-boot-spl-ddr.bin 0x7E1000 diff --git a/board/purism/librem5/librem5.c b/board/purism/librem5/librem5.c new file mode 100644 index 0000000000..caa02655fc --- /dev/null +++ b/board/purism/librem5/librem5.c @@ -0,0 +1,425 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * Copyright 2021 Purism + */ + +#include <common.h> +#include <malloc.h> +#include <errno.h> +#include <asm/io.h> +#include <miiphy.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm-generic/gpio.h> +#include <asm/arch/sys_proto.h> +#include <fsl_esdhc.h> +#include <mmc.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <asm/arch/clock.h> +#include <asm/mach-imx/video.h> +#include <fuse.h> +#include <i2c.h> +#include <spl.h> +#include <usb.h> +#include <dwc3-uboot.h> +#include <linux/delay.h> +#include <linux/bitfield.h> +#include <power/regulator.h> +#include <usb/xhci.h> +#include "librem5.h" + +DECLARE_GLOBAL_DATA_PTR; + +int board_early_init_f(void) +{ + return 0; +} + +#if IS_ENABLED(CONFIG_LOAD_ENV_FROM_MMC_BOOT_PARTITION) +uint board_mmc_get_env_part(struct mmc *mmc) +{ + uint part = (mmc->part_config >> 3) & PART_ACCESS_MASK; + + if (part == 7) + part = 0; + return part; +} +#endif + +int tps65982_wait_for_app(int timeout, int timeout_step) +{ + int ret; + char response[6]; + struct udevice *udev, *bus; + + log_debug("%s: starting\n", __func__); + + /* Set the i2c bus */ + ret = uclass_get_device_by_seq(UCLASS_I2C, 0, &bus); + if (ret) { + log_err("%s: No bus %d\n", __func__, 0); + return 1; + } + + ret = i2c_get_chip(bus, 0x3f, 1, &udev); + if (ret) { + log_err("%s: setting chip offset failed %d\n", __func__, ret); + return 1; + } + + while (timeout > 0) { + ret = dm_i2c_read(udev, 0x03, (u8 *)response, 5); + log_debug("tps65982 mode %s\n", response); + if (response[1] == 'A') + return 0; + mdelay(timeout_step); + timeout -= timeout_step; + log_debug("tps65982 waited %d ms %c\n", timeout_step, response[1]); + } + + return 1; +} + +int tps65982_clear_dead_battery(void) +{ + int ret; + char cmd[5] = "\04DBfg"; + struct udevice *udev, *bus; + + log_debug("%s: starting\n", __func__); + + /* Set the i2c bus */ + ret = uclass_get_device_by_seq(UCLASS_I2C, 0, &bus); + if (ret) { + log_err("%s: No bus %d\n", __func__, 0); + return 1; + } + + ret = i2c_get_chip(bus, 0x3f, 1, &udev); + if (ret) { + log_err("%s: setting chip offset failed %d\n", __func__, ret); + return 1; + } + + /* clearing the dead battery flag when not in dead battery condition + * is a no-op, so there's no need to check if it's in effect + */ + ret = dm_i2c_write(udev, 0x08, cmd, 5); + if (ret) { + log_err("%s: writing 4CC command failed %d", __func__, ret); + return 1; + } + + return 0; +} + +#define TPS_POWER_STATUS_PWROPMODE(x) FIELD_GET(GENMASK(3, 2), x) + +#define TPS_PDO_CONTRACT_TYPE(x) FIELD_GET(GENMASK(31, 30), x) +#define TPS_PDO_CONTRACT_FIXED 0 +#define TPS_PDO_CONTRACT_BATTERY 1 +#define TPS_PDO_CONTRACT_VARIABLE 2 + +#define TPS_TYPEC_PWR_MODE_USB 0 +#define TPS_TYPEC_PWR_MODE_1_5A 1 +#define TPS_TYPEC_PWR_MODE_3_0A 2 +#define TPS_TYPEC_PWR_MODE_PD 3 + +#define TPS_PDO_FIXED_CONTRACT_MAX_CURRENT(x) (FIELD_GET(GENMASK(9, 0), x) * 10) +#define TPS_PDO_VAR_CONTRACT_MAX_CURRENT(x) (FIELD_GET(GENMASK(9, 0), x) * 10) +#define TPS_PDO_BAT_CONTRACT_MAX_VOLTAGE(x) (FIELD_GET(GENMASK(29, 20), x) * 50) +#define TPS_PDO_BAT_CONTRACT_MAX_POWER(x) (FIELD_GET(GENMASK(9, 0), x) * 250) + +int tps65982_get_max_current(void) +{ + int ret; + u8 buf[7]; + u8 pwr_status; + u32 contract; + int type, mode; + struct udevice *udev, *bus; + + log_debug("%s: starting\n", __func__); + + /* Set the i2c bus */ + ret = uclass_get_device_by_seq(UCLASS_I2C, 0, &bus); + if (ret) { + log_debug("%s: No bus %d\n", __func__, 0); + return -1; + } + + ret = i2c_get_chip(bus, 0x3f, 1, &udev); + if (ret) { + log_debug("%s: setting chip offset failed %d\n", __func__, ret); + return -1; + } + + ret = dm_i2c_read(udev, 0x3f, buf, 3); + if (ret) { + log_debug("%s: reading pwr_status failed %d\n", __func__, ret); + return -1; + } + + pwr_status = buf[1]; + + if (!(pwr_status & 1)) + return 0; + + mode = TPS_POWER_STATUS_PWROPMODE(pwr_status); + switch (mode) { + case TPS_TYPEC_PWR_MODE_1_5A: + return 1500; + case TPS_TYPEC_PWR_MODE_3_0A: + return 3000; + case TPS_TYPEC_PWR_MODE_PD: + ret = dm_i2c_read(udev, 0x34, buf, 7); + if (ret) { + log_debug("%s: reading active contract failed %d\n", __func__, ret); + return -1; + } + + contract = buf[1] + (buf[2] << 8) + (buf[3] << 16) + (buf[4] << 24); + + type = TPS_PDO_CONTRACT_TYPE(contract); + + switch (type) { + case TPS_PDO_CONTRACT_FIXED: + return TPS_PDO_FIXED_CONTRACT_MAX_CURRENT(contract); + case TPS_PDO_CONTRACT_BATTERY: + return 1000 * TPS_PDO_BAT_CONTRACT_MAX_POWER(contract) + / TPS_PDO_BAT_CONTRACT_MAX_VOLTAGE(contract); + case TPS_PDO_CONTRACT_VARIABLE: + return TPS_PDO_VAR_CONTRACT_MAX_CURRENT(contract); + default: + log_debug("Unknown contract type: %d\n", type); + return -1; + } + case TPS_TYPEC_PWR_MODE_USB: + return 500; + default: + log_debug("Unknown power mode: %d\n", mode); + return -1; + } +} + +int init_tps65982(void) +{ + log_debug("%s: starting\n", __func__); + + if (tps65982_wait_for_app(500, 100)) { + log_err("tps65982 APP boot failed\n"); + return 1; + } + + log_info("tps65982 boot successful\n"); + return 0; +} + +int bq25895_set_iinlim(int current) +{ + u8 val, iinlim; + int ret; + struct udevice *udev, *bus; + + /* Set the i2c bus */ + ret = uclass_get_device_by_seq(UCLASS_I2C, 3, &bus); + if (ret) { + log_err("%s: No bus 3\n", __func__); + return ret; + } + + ret = i2c_get_chip(bus, 0x6a, 1, &udev); + if (ret) { + log_err("%s: setting chip offset failed %d\n", __func__, ret); + return ret; + } + + if (current > 3250) + current = 3250; + if (current < 100) + current = 100; + + val = dm_i2c_reg_read(udev, 0x00); + iinlim = ((current - 100) / 50) & 0x3f; + val = (val & 0xc0) | iinlim; + dm_i2c_reg_write(udev, 0x00, val); + log_debug("REG00 0x%x\n", val); + + return 0; +} + +bool bq25895_battery_present(void) +{ + u8 val; + int ret; + struct udevice *udev, *bus; + + /* Set the i2c bus */ + ret = uclass_get_device_by_seq(UCLASS_I2C, 3, &bus); + if (ret) { + log_err("%s: No bus 3\n", __func__); + return ret; + } + + ret = i2c_get_chip(bus, 0x6a, 1, &udev); + if (ret) { + log_err("%s: setting chip offset failed %d\n", __func__, ret); + return ret; + } + + /* note that this may return false negatives when there's + * no external power applied and the battery voltage is below + * Vsys. this isn't a problem when used for clearing the dead + * battery flag though, since it's certain that there's an external + * power applied in this case + */ + val = dm_i2c_reg_read(udev, 0x0e) & 0x7f; + if (val == 0x00 || val == 0x7f) + return false; + + return true; +} + +/* + * set some safe defaults for the battery charger + */ +int init_charger_bq25895(void) +{ + u8 val; + int iinlim, ret; + struct udevice *udev, *bus; + + /* Set the i2c bus */ + ret = uclass_get_device_by_seq(UCLASS_I2C, 3, &bus); + if (ret) { + log_debug("%s: No bus 3\n", __func__); + return ret; + } + + ret = i2c_get_chip(bus, 0x6a, 1, &udev); + if (ret) { + log_debug("%s: setting chip offset failed %d\n", __func__, ret); + return ret; + } + + val = dm_i2c_reg_read(udev, 0x0b); + log_debug("REG0B 0x%x\n", val); + + log_debug("VBUS_STAT 0x%x\n", val >> 5); + switch (val >> 5) { + case 0: + log_debug("VBUS not detected\n"); + break; + case 1: + log_debug("USB SDP IINLIM 500mA\n"); + break; + case 2: + log_debug("USB CDP IINLIM 1500mA\n"); + break; + case 3: + log_debug("USB DCP IINLIM 3500mA\n"); + break; + case 4: + log_debug("MAXCHARGE IINLIM 1500mA\n"); + break; + case 5: + log_debug("Unknown IINLIM 500mA\n"); + break; + case 6: + log_debug("DIVIDER IINLIM > 1000mA\n"); + break; + case 7: + log_debug("OTG\n"); + break; + }; + + log_debug("CHRG_STAT 0x%x\n", (val >> 3) & 0x3); + log_debug("PG_STAT 0x%x\n", (val >> 2) & 1); + log_debug("SDP_STAT 0x%x\n", (val >> 1) & 1); + log_debug("VSYS_STAT 0x%x\n", val & 1); + + val = dm_i2c_reg_read(udev, 0x00); + log_debug("REG00 0x%x\n", val); + iinlim = 100 + (val & 0x3f) * 50; + log_debug("IINLIM %d mA\n", iinlim); + log_debug("EN_HIZ 0x%x\n", (val >> 7) & 1); + log_debug("EN_ILIM 0x%x\n", (val >> 6) & 1); + + /* set 1.6A charge limit */ + dm_i2c_reg_write(udev, 0x04, 0x19); + + /* re-enable charger */ + val = dm_i2c_reg_read(udev, 0x03); + val = val | 0x10; + dm_i2c_reg_write(udev, 0x03, val); + + return 0; +} + +int board_init(void) +{ + struct udevice *dev; + int tps_ret; + + if (IS_ENABLED(CONFIG_USB_DWC3) || IS_ENABLED(CONFIG_USB_XHCI_IMX8M)) { + log_debug("%s: initializing USB clk\n", __func__); + + /* init_usb_clk won't enable the second clock if it's a USB boot */ + if (is_usb_boot()) { + clock_enable(CCGR_USB_CTRL2, 1); + clock_enable(CCGR_USB_PHY2, 1); + } + + printf("Enabling regulator-hub\n"); + if (!regulator_get_by_devname("regulator-hub", &dev)) { + if (regulator_set_enable(dev, true)) + pr_err("Failed to enable regulator-hub\n"); + } + } + + tps_ret = init_tps65982(); + init_charger_bq25895(); + + if (!tps_ret) { + int current = tps65982_get_max_current(); + + if (current > 500) + bq25895_set_iinlim(current); + + if (bq25895_battery_present()) + tps65982_clear_dead_battery(); + } + + return 0; +} + +int board_late_init(void) +{ + if (IS_ENABLED(CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG)) { + u32 rev; + char rev_str[3]; + + env_set("board_name", "librem5"); + if (fuse_read(9, 0, &rev)) { + env_set("board_rev", BOARD_REV_ERROR); + } else if (rev == 0) { + env_set("board_rev", BOARD_REV_UNKNOWN); + } else if (rev > 0) { + sprintf(rev_str, "%u", rev); + env_set("board_rev", rev_str); + } + + printf("Board name: %s\n", env_get("board_name")); + printf("Board rev: %s\n", env_get("board_rev")); + } + + if (is_usb_boot()) { + puts("USB Boot\n"); + env_set("bootcmd", "fastboot 0"); + } + + return 0; +} diff --git a/board/purism/librem5/librem5.h b/board/purism/librem5/librem5.h new file mode 100644 index 0000000000..0d24edea9b --- /dev/null +++ b/board/purism/librem5/librem5.h @@ -0,0 +1,181 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 Purism + */ + +#ifndef __LIBREM5_H__ +#define __LIBREM5_H__ + +#define CAMERA_EN IMX_GPIO_NR(1, 0) +#define SD_EN IMX_GPIO_NR(1, 3) +#define AUDIO_EN IMX_GPIO_NR(1, 4) +#define DSI_EN IMX_GPIO_NR(1, 5) +#define SMC_EN IMX_GPIO_NR(1, 6) +#define TYPEC_MUX_EN IMX_GPIO_NR(1, 11) +#define HUB_NRESET IMX_GPIO_NR(1, 12) +#define HUB_EN IMX_GPIO_NR(1, 14) +#define VOL_UP IMX_GPIO_NR(1, 16) +#define VOL_DOWN IMX_GPIO_NR(1, 17) +#define DSI_BIAS_EN IMX_GPIO_NR(1, 20) +#define FLASH_EN IMX_GPIO_NR(1, 23) +#define WWAN_NRESET IMX_GPIO_NR(3, 1) +#define CHG_EN IMX_GPIO_NR(3, 2) +#define CHG_OTG_OUT_EN IMX_GPIO_NR(3, 4) +#define WIFI_EN IMX_GPIO_NR(3, 10) +#define GPS_EN IMX_GPIO_NR(3, 12) +#define BL_EN IMX_GPIO_NR(3, 14) +#define WWAN_EN IMX_GPIO_NR(3, 18) +#define NFC_EN IMX_GPIO_NR(4, 28) +#define LED_G IMX_GPIO_NR(5, 2) +#define LED_R IMX_GPIO_NR(5, 3) +#define LED_B IMX_GPIO_NR(1, 13) +#define MOTO IMX_GPIO_NR(5, 5) +#define SPI1_SCLK IMX_GPIO_NR(5, 6) +#define SPI1_MOSI IMX_GPIO_NR(5, 7) +#define SPI1_MISO IMX_GPIO_NR(5, 8) +#define SPI1_SS0 IMX_GPIO_NR(5, 9) + +#define UART1_TX IMX_GPIO_NR(5, 23) +#define UART1_RX IMX_GPIO_NR(5, 22) +#define UART2_TX IMX_GPIO_NR(5, 25) +#define UART2_RX IMX_GPIO_NR(5, 24) +#define UART3_TX IMX_GPIO_NR(5, 27) +#define UART3_RX IMX_GPIO_NR(5, 26) +#define UART4_TX IMX_GPIO_NR(5, 11) +#define UART4_RX IMX_GPIO_NR(5, 10) + +#define TPS_RESET IMX_GPIO_NR(3, 24) + +#define PURISM_VID 0x316d +#define PURISM_PID 0x4c05 + +#define BOARD_REV_ERROR "unknown" +#define BOARD_REV_BIRCH "1" +#define BOARD_REV_CHESTNUT "2" +#define BOARD_REV_DOGWOOD "3" +#define BOARD_REV_EVERGREEN "4" +/* Could be ASPEN, BIRCH or CHESTNUT. assume CHESTNUT */ +#define BOARD_REV_UNKNOWN BOARD_REV_CHESTNUT + +#ifdef CONFIG_SPL_BUILD +static const iomux_v3_cfg_t configure_pads[] = { + IMX8MQ_PAD_GPIO1_IO00__GPIO1_IO0 | MUX_PAD_CTRL(PAD_CTL_DSE6), + IMX8MQ_PAD_GPIO1_IO03__GPIO1_IO3 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION, + IMX8MQ_PAD_GPIO1_IO04__GPIO1_IO4 | MUX_PAD_CTRL(PAD_CTL_DSE6), + IMX8MQ_PAD_GPIO1_IO05__GPIO1_IO5 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION, + IMX8MQ_PAD_GPIO1_IO06__GPIO1_IO6 | MUX_PAD_CTRL(PAD_CTL_DSE6), + IMX8MQ_PAD_GPIO1_IO11__GPIO1_IO11 | MUX_PAD_CTRL(PAD_CTL_DSE6), + IMX8MQ_PAD_GPIO1_IO12__GPIO1_IO12 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION, + IMX8MQ_PAD_GPIO1_IO13__GPIO1_IO13 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION, + IMX8MQ_PAD_GPIO1_IO14__GPIO1_IO14 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION, + IMX8MQ_PAD_ENET_MDC__GPIO1_IO16 | MUX_PAD_CTRL(PAD_CTL_PUE), + IMX8MQ_PAD_ENET_MDIO__GPIO1_IO17 | MUX_PAD_CTRL(PAD_CTL_PUE), + IMX8MQ_PAD_ENET_TD1__GPIO1_IO20 | MUX_PAD_CTRL(PAD_CTL_DSE6), + IMX8MQ_PAD_ENET_TXC__GPIO1_IO23 | MUX_PAD_CTRL(PAD_CTL_DSE6), + IMX8MQ_PAD_NAND_CE0_B__GPIO3_IO1 | MUX_PAD_CTRL(PAD_CTL_DSE6), + IMX8MQ_PAD_NAND_CE1_B__GPIO3_IO2 | MUX_PAD_CTRL(PAD_CTL_DSE6), + IMX8MQ_PAD_NAND_CE3_B__GPIO3_IO4 | MUX_PAD_CTRL(PAD_CTL_DSE6), + IMX8MQ_PAD_NAND_DATA04__GPIO3_IO10 | MUX_PAD_CTRL(PAD_CTL_DSE6), + IMX8MQ_PAD_NAND_DATA06__GPIO3_IO12 | MUX_PAD_CTRL(PAD_CTL_DSE6), + IMX8MQ_PAD_NAND_DQS__GPIO3_IO14 | MUX_PAD_CTRL(PAD_CTL_DSE6), + IMX8MQ_PAD_NAND_WP_B__GPIO3_IO18 | MUX_PAD_CTRL(PAD_CTL_DSE6), + IMX8MQ_PAD_SAI3_RXFS__GPIO4_IO28 | MUX_PAD_CTRL(PAD_CTL_DSE6), + IMX8MQ_PAD_SAI3_MCLK__GPIO5_IO2 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION, + IMX8MQ_PAD_SPDIF_TX__GPIO5_IO3 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION, + IMX8MQ_PAD_SAI5_RXD3__GPIO3_IO24 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION, +}; + +static inline void init_pinmux(void) +{ + imx_iomux_v3_setup_multiple_pads(configure_pads, ARRAY_SIZE(configure_pads)); + + gpio_request(LED_R, "LED_R"); + gpio_request(LED_G, "LED_G"); + gpio_request(LED_B, "LED_B"); + gpio_request(VOL_UP, "VOL_UP"); + gpio_request(VOL_DOWN, "VOL_DOWN"); + + gpio_request(NFC_EN, "NFC_EN"); + gpio_request(CHG_EN, "CHG_EN"); + gpio_request(CHG_OTG_OUT_EN, "CHG_OTG_OUT_EN"); + + gpio_request(TYPEC_MUX_EN, "TYPEC_MUX_EN"); + + gpio_request(TPS_RESET, "TPS_RESET"); + + gpio_request(WWAN_EN, "WWAN_EN"); + gpio_request(WWAN_NRESET, "WWAN_NRESET"); + + gpio_request(HUB_EN, "HUB_EN"); + gpio_request(HUB_NRESET, "HUB_NRESET"); + gpio_request(SD_EN, "SD_EN"); + gpio_request(AUDIO_EN, "AUDIO_EN"); + gpio_request(DSI_EN, "DSI_EN"); + gpio_request(SMC_EN, "SMC_EN"); + gpio_request(CAMERA_EN, "CAMERA_EN"); + gpio_request(FLASH_EN, "FLASH_EN"); + gpio_request(DSI_BIAS_EN, "DSI_BIAS_EN"); + gpio_request(GPS_EN, "GPS_EN"); + gpio_request(BL_EN, "BL_EN"); +#ifndef CONSOLE_ON_UART4 + gpio_request(WIFI_EN, "WIFI_EN"); + gpio_direction_output(WIFI_EN, 0); +#endif /* CONSOLE_ON_UART4 */ + gpio_direction_input(VOL_UP); + gpio_direction_input(VOL_DOWN); + + /* ensure charger is in the automated mode */ + gpio_direction_output(NFC_EN, 0); + gpio_direction_output(CHG_EN, 0); + gpio_direction_output(CHG_OTG_OUT_EN, 0); + + gpio_direction_input(TYPEC_MUX_EN); + + gpio_direction_output(TPS_RESET, 0); + + gpio_direction_output(WWAN_EN, 0); + gpio_direction_output(WWAN_NRESET, 1); + + gpio_direction_output(HUB_EN, 1); + gpio_direction_output(HUB_NRESET, 1); + mdelay(10); + gpio_direction_output(SD_EN, 1); + gpio_direction_output(SMC_EN, 0); + gpio_direction_output(CAMERA_EN, 0); + gpio_direction_output(FLASH_EN, 0); + gpio_direction_output(DSI_BIAS_EN, 0); + gpio_direction_output(GPS_EN, 0); + gpio_direction_output(BL_EN, 0); + + /* turn these on for i2c busses */ + gpio_direction_output(AUDIO_EN, 1); + gpio_direction_output(DSI_EN, 1); +} +#endif /* CONFIG_SPL_BUILD */ + +#define USB1_BASE_ADDR 0x38100000 +#define USB2_BASE_ADDR 0x38200000 +#define USB1_PHY_BASE_ADDR 0x381F0000 +#define USB2_PHY_BASE_ADDR 0x382F0000 + +#define USB_PHY_CTRL0 0xF0040 +#define USB_PHY_CTRL0_REF_SSP_EN BIT(2) +#define USB_PHY_CTRL0_SSC_RANGE_MASK GENMASK(23, 21) +#define USB_PHY_CTRL0_SSC_RANGE_4003PPM (0x2 << 21) + +#define USB_PHY_CTRL1 0xF0044 +#define USB_PHY_CTRL1_RESET BIT(0) +#define USB_PHY_CTRL1_COMMONONN BIT(1) +#define USB_PHY_CTRL1_ATERESET BIT(3) +#define USB_PHY_CTRL1_VDATSRCENB0 BIT(19) +#define USB_PHY_CTRL1_VDATDETENB0 BIT(20) + +#define USB_PHY_CTRL2 0xF0048 +#define USB_PHY_CTRL2_TXENABLEN0 BIT(8) + +#define USB_PHY_CTRL6 0x18 +#define USB_PHY_CTRL6_RXTERM_OVERRIDE_SEL BIT(29) + +extern struct dram_timing_info dram_timing_b0; + +#endif diff --git a/board/purism/librem5/lpddr4_timing.c b/board/purism/librem5/lpddr4_timing.c new file mode 100644 index 0000000000..46bc7f8591 --- /dev/null +++ b/board/purism/librem5/lpddr4_timing.c @@ -0,0 +1,1324 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + */ + +#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +#define WR_POST_EXT_3200 /* recommened to define */ + +struct dram_cfg_param lpddr4_ddrc_cfg[] = { + /* Start to config, default 3200mbps */ + { DDRC_DBG1(0), 0x00000001 }, + { DDRC_PWRCTL(0), 0x00000001 }, + { DDRC_MSTR(0), 0xa3080020 }, + { DDRC_MSTR2(0), 0x00000000 }, + { DDRC_RFSHTMG(0), 0x006100E0 }, + { DDRC_INIT0(0), 0xC003061B }, + { DDRC_INIT1(0), 0x009D0000 }, + { DDRC_INIT3(0), 0x00D4002D }, +#ifdef WR_POST_EXT_3200 + { DDRC_INIT4(0), 0x00330008 }, +#else + { DDRC_INIT4(0), 0x00310008 }, +#endif + { DDRC_INIT6(0), 0x0066004a }, + { DDRC_INIT7(0), 0x0006004a }, + + { DDRC_DRAMTMG0(0), 0x1A201B22 }, + { DDRC_DRAMTMG1(0), 0x00060633 }, + { DDRC_DRAMTMG3(0), 0x00C0C000 }, + { DDRC_DRAMTMG4(0), 0x0F04080F }, + { DDRC_DRAMTMG5(0), 0x02040C0C }, + { DDRC_DRAMTMG6(0), 0x01010007 }, + { DDRC_DRAMTMG7(0), 0x00000401 }, + { DDRC_DRAMTMG12(0), 0x00020600 }, + { DDRC_DRAMTMG13(0), 0x0C100002 }, + { DDRC_DRAMTMG14(0), 0x000000E6 }, + { DDRC_DRAMTMG17(0), 0x00A00050 }, + + { DDRC_ZQCTL0(0), 0x03200018 }, + { DDRC_ZQCTL1(0), 0x028061A8 }, + { DDRC_ZQCTL2(0), 0x00000000 }, + + { DDRC_DFITMG0(0), 0x0497820A }, + { DDRC_DFITMG1(0), 0x00080303 }, + { DDRC_DFIUPD0(0), 0xE0400018 }, + { DDRC_DFIUPD1(0), 0x00DF00E4 }, + { DDRC_DFIUPD2(0), 0x80000000 }, + { DDRC_DFIMISC(0), 0x00000011 }, + { DDRC_DFITMG2(0), 0x0000170A }, + + { DDRC_DBICTL(0), 0x00000001 }, + { DDRC_DFIPHYMSTR(0), 0x00000001 }, + { DDRC_RANKCTL(0), 0x00000c99 }, + { DDRC_DRAMTMG2(0), 0x070E171a }, + + /* address mapping */ + { DDRC_ADDRMAP0(0), 0x00000015 }, + { DDRC_ADDRMAP3(0), 0x00000000 }, + { DDRC_ADDRMAP4(0), 0x00001F1F }, + /* bank interleave */ + { DDRC_ADDRMAP1(0), 0x00080808 }, + { DDRC_ADDRMAP5(0), 0x07070707 }, + { DDRC_ADDRMAP6(0), 0x08080707 }, + + /* performance setting */ + { DDRC_ODTCFG(0), 0x0b060908 }, + { DDRC_ODTMAP(0), 0x00000000 }, + { DDRC_SCHED(0), 0x29511505 }, + { DDRC_SCHED1(0), 0x0000002c }, + { DDRC_PERFHPR1(0), 0x5900575b }, + /* 150T starve and 0x90 max tran len */ + { DDRC_PERFLPR1(0), 0x90000096 }, + /* 300T starve and 0x10 max tran len */ + { DDRC_PERFWR1(0), 0x1000012c }, + { DDRC_DBG0(0), 0x00000016 }, + { DDRC_DBG1(0), 0x00000000 }, + { DDRC_DBGCMD(0), 0x00000000 }, + { DDRC_SWCTL(0), 0x00000001 }, + { DDRC_POISONCFG(0), 0x00000011 }, + { DDRC_PCCFG(0), 0x00000111 }, + { DDRC_PCFGR_0(0), 0x000010f3 }, + { DDRC_PCFGW_0(0), 0x000072ff }, + { DDRC_PCTRL_0(0), 0x00000001 }, + /* disable Read Qos*/ + { DDRC_PCFGQOS0_0(0), 0x00000e00 }, + { DDRC_PCFGQOS1_0(0), 0x0062ffff }, + /* disable Write Qos*/ + { DDRC_PCFGWQOS0_0(0), 0x00000e00 }, + { DDRC_PCFGWQOS1_0(0), 0x0000ffff }, + + /* Frequency 1: 400mbps */ + { DDRC_FREQ1_DRAMTMG0(0), 0x0d0b010c }, + { DDRC_FREQ1_DRAMTMG1(0), 0x00030410 }, + { DDRC_FREQ1_DRAMTMG2(0), 0x0305090c }, + { DDRC_FREQ1_DRAMTMG3(0), 0x00505006 }, + { DDRC_FREQ1_DRAMTMG4(0), 0x05040305 }, + { DDRC_FREQ1_DRAMTMG5(0), 0x0d0e0504 }, + { DDRC_FREQ1_DRAMTMG6(0), 0x0a060004 }, + { DDRC_FREQ1_DRAMTMG7(0), 0x0000090e }, + { DDRC_FREQ1_DRAMTMG14(0), 0x00000032 }, + { DDRC_FREQ1_DRAMTMG15(0), 0x00000000 }, + { DDRC_FREQ1_DRAMTMG17(0), 0x0036001b }, + { DDRC_FREQ1_DERATEINT(0), 0x7e9fbeb1 }, + { DDRC_FREQ1_DFITMG0(0), 0x03818200 }, + { DDRC_FREQ1_DFITMG2(0), 0x00000000 }, + { DDRC_FREQ1_RFSHTMG(0), 0x000C001c }, + { DDRC_FREQ1_INIT3(0), 0x00840000 }, + { DDRC_FREQ1_INIT4(0), 0x00310008 }, + { DDRC_FREQ1_INIT6(0), 0x0066004a }, + { DDRC_FREQ1_INIT7(0), 0x0006004a }, + + /* Frequency 2: 100mbps */ + { DDRC_FREQ2_DRAMTMG0(0), 0x0d0b010c }, + { DDRC_FREQ2_DRAMTMG1(0), 0x00030410 }, + { DDRC_FREQ2_DRAMTMG2(0), 0x0305090c }, + { DDRC_FREQ2_DRAMTMG3(0), 0x00505006 }, + { DDRC_FREQ2_DRAMTMG4(0), 0x05040305 }, + { DDRC_FREQ2_DRAMTMG5(0), 0x0d0e0504 }, + { DDRC_FREQ2_DRAMTMG6(0), 0x0a060004 }, + { DDRC_FREQ2_DRAMTMG7(0), 0x0000090e }, + { DDRC_FREQ2_DRAMTMG14(0), 0x00000032 }, + { DDRC_FREQ2_DRAMTMG17(0), 0x0036001b }, + { DDRC_FREQ2_DERATEINT(0), 0x7e9fbeb1 }, + { DDRC_FREQ2_DFITMG0(0), 0x03818200 }, + { DDRC_FREQ2_DFITMG2(0), 0x00000000 }, + { DDRC_FREQ2_RFSHTMG(0), 0x00030007 }, + { DDRC_FREQ2_INIT3(0), 0x00840000 }, + { DDRC_FREQ2_INIT4(0), 0x00310008 }, + { DDRC_FREQ2_INIT6(0), 0x0066004a }, + { DDRC_FREQ2_INIT7(0), 0x0006004a }, +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param lpddr4_ddrphy_cfg[] = { + { 0x20110, 0x02 }, + { 0x20111, 0x03 }, + { 0x20112, 0x04 }, + { 0x20113, 0x05 }, + { 0x20114, 0x00 }, + { 0x20115, 0x01 }, + + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + +#ifdef WR_POST_EXT_3200 + { 0x20024, 0xeb }, +#else + { 0x20024, 0xab }, +#endif + { 0x2003a, 0x0 }, + { 0x120024, 0xab }, + { 0x2003a, 0x0 }, + { 0x220024, 0xab }, + { 0x2003a, 0x0 }, + { 0x20056, 0x3 }, + { 0x120056, 0xa }, + { 0x220056, 0xa }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + + { 0x10049, 0xfbe }, + { 0x10149, 0xfbe }, + { 0x11049, 0xfbe }, + { 0x11149, 0xfbe }, + { 0x12049, 0xfbe }, + { 0x12149, 0xfbe }, + { 0x13049, 0xfbe }, + { 0x13149, 0xfbe }, + { 0x110049, 0xfbe }, + { 0x110149, 0xfbe }, + { 0x111049, 0xfbe }, + { 0x111149, 0xfbe }, + { 0x112049, 0xfbe }, + { 0x112149, 0xfbe }, + { 0x113049, 0xfbe }, + { 0x113149, 0xfbe }, + { 0x210049, 0xfbe }, + { 0x210149, 0xfbe }, + { 0x211049, 0xfbe }, + { 0x211149, 0xfbe }, + { 0x212049, 0xfbe }, + { 0x212149, 0xfbe }, + { 0x213049, 0xfbe }, + { 0x213149, 0xfbe }, + + { 0x43, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) }, + { 0x1043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) }, + { 0x2043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) }, + { 0x3043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) }, + { 0x4043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) }, + { 0x5043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) }, + { 0x6043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) }, + { 0x7043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) }, + { 0x8043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) }, + { 0x9043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) }, + + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x320 }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0x104 }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0x104 }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0x104 }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + + { 0x200c7, 0x80 }, + { 0x1200c7, 0x80 }, + { 0x2200c7, 0x80 }, + { 0x200ca, 0x106 }, + { 0x1200ca, 0x106 }, + { 0x2200ca, 0x106 }, +}; + +/* P0 message block paremeter for training firmware */ +struct dram_cfg_param lpddr4_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54000, 0x0 }, + { 0x54001, 0x0 }, + { 0x54002, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT) }, /* PHY Ron/Rtt */ + { 0x54006, LPDDR4_PHY_VREF_VALUE }, + { 0x54007, 0x0 }, + { 0x54008, 0x131f }, + { 0x54009, LPDDR4_HDT_CTL_3200_1D }, + { 0x5400a, 0x0 }, + { 0x5400b, 0x2 }, + { 0x5400c, 0x0 }, + { 0x5400d, (LPDDR4_CATRAIN_3200_1d << 8) }, + { 0x5400e, 0x0 }, + { 0x5400f, 0x0 }, + { 0x54010, 0x0 }, + { 0x54011, 0x0 }, + { 0x54012, 0x310 }, + { 0x54013, 0x0 }, + { 0x54014, 0x0 }, + { 0x54015, 0x0 }, + { 0x54016, 0x0 }, + { 0x54017, 0x0 }, + { 0x54018, 0x0 }, + + { 0x54019, 0x2dd4 }, +#ifdef WR_POST_EXT_3200 + { 0x5401a, (((LPDDR4_RON) << 3) | 0x3) }, +#else + { 0x5401a, (((LPDDR4_RON) << 3) | 0x1) }, +#endif + { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) | + (LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) }, + { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08) }, + { 0x5401d, 0x0 }, + { 0x5401e, LPDDR4_MR22_RANK0 }, + { 0x5401f, 0x2dd4 }, +#ifdef WR_POST_EXT_3200 + { 0x54020, (((LPDDR4_RON) << 3) | 0x3) }, +#else + { 0x54020, (((LPDDR4_RON) << 3) | 0x1) }, +#endif + { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) | + (LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) }, + { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08) }, + { 0x54023, 0x0 }, + { 0x54024, LPDDR4_MR22_RANK1 }, + + { 0x54025, 0x0 }, + { 0x54026, 0x0 }, + { 0x54027, 0x0 }, + { 0x54028, 0x0 }, + { 0x54029, 0x0 }, + { 0x5402a, 0x0 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x5402d, 0x0 }, + { 0x5402e, 0x0 }, + { 0x5402f, 0x0 }, + { 0x54030, 0x0 }, + { 0x54031, 0x0 }, + { 0x54032, 0xd400 }, + /* MR3/MR2 */ +#ifdef WR_POST_EXT_3200 + { 0x54033, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d /*0x312d*/ }, +#else + { 0x54033, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x2d/*0x312d*/ }, +#endif + /* MR11/MR4 */ + { 0x54034, (((LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) << 8) }, + /* self:0x284d//MR13/MR12 */ + { 0x54035, (0x0800 | LPDDR4_VREF_VALUE_CA)/*0x084d*/ }, + /* MR16/MR14*/ + { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0/*0x4d*/ }, + { 0x54037, (LPDDR4_MR22_RANK0 << 8)/*0x500*/ }, + /* MR1 */ + { 0x54038, 0xd400 }, + /* MR3/MR2 */ +#ifdef WR_POST_EXT_3200 + { 0x54039, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d/*0x312d*/ }, +#else + { 0x54039, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x2d/*0x312d*/ }, +#endif + /* MR11/MR4 */ + { 0x5403a, (((LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) << 8) }, + /* self:0x284d//MR13/MR12 */ + { 0x5403b, (0x0800 | LPDDR4_VREF_VALUE_CA)/*0x084d*/ }, + /* MR16/MR14 */ + { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1/*0x4d*/ }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8)/*0x500*/ }, + /* { 0x5403d, 0x500 } */ + { 0x5403d, (LPDDR4_MR22_RANK1 << 8)/*0x500*/ }, + { 0x5403e, 0x0 }, + { 0x5403f, 0x0 }, + { 0x54040, 0x0 }, + { 0x54041, 0x0 }, + { 0x54042, 0x0 }, + { 0x54043, 0x0 }, + { 0x54044, 0x0 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +struct dram_cfg_param lpddr4_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54000, 0x0 }, + { 0x54001, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + /* PHY Ron/Rtt */ + { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT)/*0x2828*/ }, + { 0x54006, LPDDR4_PHY_VREF_VALUE }, + { 0x54007, 0x0 }, + { 0x54008, LPDDR4_TRAIN_SEQ_400 }, + { 0x54009, LPDDR4_HDT_CTL_400_1D }, + { 0x5400a, 0x0 }, + { 0x5400b, 0x2 }, + { 0x5400c, 0x0 }, + { 0x5400d, (LPDDR4_CATRAIN_400 << 8) }, + { 0x5400e, 0x0 }, + { 0x5400f, 0x0 }, + { 0x54010, 0x0 }, + { 0x54011, 0x0 }, + { 0x54012, 0x310 }, + { 0x54013, 0x0 }, + { 0x54014, 0x0 }, + { 0x54015, 0x0 }, + { 0x54016, 0x0 }, + { 0x54017, 0x0 }, + { 0x54018, 0x0 }, + { 0x54019, 0x84 }, + /* MR4/MR3 */ + { 0x5401a, (((LPDDR4_RON) << 3) | 0x1)/*0x31*/ }, + /* MR12/MR11 */ + { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA << 4) | + LPDDR4_RTT_DQ)/*0x4d46*/ }, + /* self:0x4d28//MR14/MR13 */ + { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08)/*0x4d08*/ }, + { 0x5401d, 0x0 }, + { 0x5401e, LPDDR4_MR22_RANK0/*0x5*/ }, + { 0x5401f, 0x84 }, + { 0x54020, (((LPDDR4_RON) << 3) | 0x1)/*0x31*/ }, /* MR4/MR3 */ + { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA << 4) | + LPDDR4_RTT_DQ)/*0x4d46*/ },/* MR12/MR11 */ + /* self:0x4d28//MR14/MR13 */ + { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08)/*0x4d08*/ }, + { 0x54023, 0x0 }, + { 0x54024, LPDDR4_MR22_RANK1 }, + { 0x54025, 0x0 }, + { 0x54026, 0x0 }, + { 0x54027, 0x0 }, + { 0x54028, 0x0 }, + { 0x54029, 0x0 }, + { 0x5402a, 0x0 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x5402d, 0x0 }, + { 0x5402e, 0x0 }, + { 0x5402f, 0x0 }, + { 0x54030, 0x0 }, + { 0x54031, 0x0 }, + { 0x54032, 0x8400 }, + { 0x54033, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x00 }, + { 0x54034, (((LPDDR4_RTT_CA << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x54035, (0x0800 | LPDDR4_VREF_VALUE_CA) }, + { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0 }, + { 0x54037, (LPDDR4_MR22_RANK0 << 8) }, + { 0x54038, 0x8400 }, + { 0x54039, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x00 }, + { 0x5403a, (((LPDDR4_RTT_CA << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x5403b, (0x0800 | LPDDR4_VREF_VALUE_CA) }, + { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1 }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403e, 0x0 }, + { 0x5403f, 0x0 }, + { 0x54040, 0x0 }, + { 0x54041, 0x0 }, + { 0x54042, 0x0 }, + { 0x54043, 0x0 }, + { 0x54044, 0x0 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +struct dram_cfg_param lpddr4_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54000, 0x0 }, + { 0x54001, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT) }, + { 0x54006, LPDDR4_PHY_VREF_VALUE }, + { 0x54007, 0x0 }, + { 0x54008, LPDDR4_TRAIN_SEQ_100 }, + { 0x54009, LPDDR4_HDT_CTL_100_1D }, + { 0x5400a, 0x0 }, + { 0x5400b, 0x2 }, + { 0x5400c, 0x0 }, + { 0x5400d, (LPDDR4_CATRAIN_100 << 8) }, + { 0x5400e, 0x0 }, + { 0x5400f, 0x0 }, + { 0x54010, 0x0 }, + { 0x54011, 0x0 }, + { 0x54012, 0x310 }, + { 0x54013, 0x0 }, + { 0x54014, 0x0 }, + { 0x54015, 0x0 }, + { 0x54016, 0x0 }, + { 0x54017, 0x0 }, + { 0x54018, 0x0 }, + { 0x54019, 0x84 }, + { 0x5401a, (((LPDDR4_RON) << 3) | 0x1) }, + { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA << 4) | + LPDDR4_RTT_DQ) }, + { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08) }, + { 0x5401d, 0x0 }, + { 0x5401e, LPDDR4_MR22_RANK0 }, + { 0x5401f, 0x84 }, + { 0x54020, (((LPDDR4_RON) << 3) | 0x1) }, + { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA << 4) | + LPDDR4_RTT_DQ) }, + { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08) }, + { 0x54023, 0x0 }, + { 0x54024, LPDDR4_MR22_RANK1 }, + { 0x54025, 0x0 }, + { 0x54026, 0x0 }, + { 0x54027, 0x0 }, + { 0x54028, 0x0 }, + { 0x54029, 0x0 }, + { 0x5402a, 0x0 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x5402d, 0x0 }, + { 0x5402e, 0x0 }, + { 0x5402f, 0x0 }, + { 0x54030, 0x0 }, + { 0x54031, 0x0 }, + { 0x54032, 0x8400 }, + { 0x54033, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x00 }, + { 0x54034, (((LPDDR4_RTT_CA << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x54035, (0x0800 | LPDDR4_VREF_VALUE_CA) }, + { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0 }, + { 0x54037, (LPDDR4_MR22_RANK0 << 8) }, + { 0x54038, 0x8400 }, + { 0x54039, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x00 }, + { 0x5403a, (((LPDDR4_RTT_CA << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x5403b, (0x0800 | LPDDR4_VREF_VALUE_CA) }, + { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1 }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403e, 0x0 }, + { 0x5403f, 0x0 }, + { 0x54040, 0x0 }, + { 0x54041, 0x0 }, + { 0x54042, 0x0 }, + { 0x54043, 0x0 }, + { 0x54044, 0x0 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +struct dram_cfg_param lpddr4_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54000, 0x0 }, + { 0x54001, 0x0 }, + { 0x54002, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT) }, + { 0x54006, LPDDR4_PHY_VREF_VALUE }, + { 0x54007, 0x0 }, + { 0x54008, 0x61 }, + { 0x54009, LPDDR4_HDT_CTL_2D }, + { 0x5400a, 0x0 }, + { 0x5400b, 0x2 }, + { 0x5400c, 0x0 }, + { 0x5400d, (LPDDR4_CATRAIN_3200_2d << 8) }, + { 0x5400e, 0x0 }, + { 0x5400f, (LPDDR4_2D_SHARE << 8) | 0x00 }, + { 0x54010, LPDDR4_2D_WEIGHT }, + { 0x54011, 0x0 }, + { 0x54012, 0x310 }, + { 0x54013, 0x0 }, + { 0x54014, 0x0 }, + { 0x54015, 0x0 }, + { 0x54016, 0x0 }, + { 0x54017, 0x0 }, + { 0x54018, 0x0 }, + { 0x54019, 0x2dd4 }, +#ifdef WR_POST_EXT_3200 + { 0x5401a, (((LPDDR4_RON) << 3) | 0x3) }, +#else + { 0x5401a, (((LPDDR4_RON) << 3) | 0x1) }, +#endif + { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) | + (LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) }, + { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08) }, + { 0x5401d, 0x0 }, + { 0x5401e, LPDDR4_MR22_RANK0 }, + { 0x5401f, 0x2dd4 }, +#ifdef WR_POST_EXT_3200 + { 0x54020, (((LPDDR4_RON) << 3) | 0x3) }, +#else + { 0x54020, (((LPDDR4_RON) << 3) | 0x1) }, +#endif + { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) | + (LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) }, + { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08) }, + { 0x54023, 0x0 }, + { 0x54024, LPDDR4_MR22_RANK1 }, + { 0x54025, 0x0 }, + { 0x54026, 0x0 }, + { 0x54027, 0x0 }, + { 0x54028, 0x0 }, + { 0x54029, 0x0 }, + { 0x5402a, 0x0 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x5402d, 0x0 }, + { 0x5402e, 0x0 }, + { 0x5402f, 0x0 }, + { 0x54030, 0x0 }, + { 0x54031, 0x0 }, + + { 0x54032, 0xd400 }, +#ifdef WR_POST_EXT_3200 + { 0x54033, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d }, +#else + { 0x54033, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x2d }, +#endif + { 0x54034, (((LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x54035, (0x0800 | LPDDR4_VREF_VALUE_CA) }, + { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0 }, + { 0x54037, (LPDDR4_MR22_RANK0 << 8) }, + { 0x54038, 0xd400 }, +#ifdef WR_POST_EXT_3200 + { 0x54039, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d }, +#else + { 0x54039, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x2d }, +#endif + { 0x5403a, (((LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x5403b, (0x0800 | LPDDR4_VREF_VALUE_CA) }, + { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1 }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403e, 0x0 }, + { 0x5403f, 0x0 }, + { 0x54040, 0x0 }, + { 0x54041, 0x0 }, + { 0x54042, 0x0 }, + { 0x54043, 0x0 }, + { 0x54044, 0x0 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param lpddr4_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xf }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x630 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x630 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x630 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x630 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x630 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x630 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x630 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x630 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x630 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x630 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x630 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x630 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x630 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xa }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x2 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x900a4, 0x10 }, + { 0x900a5, 0x10 }, + { 0x900a6, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x623 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x623 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a7, 0x0 }, + { 0x900a8, 0x790 }, + { 0x900a9, 0x11a }, + { 0x900aa, 0x8 }, + { 0x900ab, 0x7aa }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x10 }, + { 0x900ae, 0x7b2 }, + { 0x900af, 0x2a }, + { 0x900b0, 0x0 }, + { 0x900b1, 0x7c8 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x0 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xc }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x0 }, + { 0x90169, 0x8 }, + { 0x9016a, 0x8 }, + { 0x9016b, 0x448 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0xf }, + { 0x9016e, 0x7c0 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x0 }, + { 0x90171, 0xe8 }, + { 0x90172, 0x109 }, + { 0x90173, 0x47 }, + { 0x90174, 0x630 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0x618 }, + { 0x90178, 0x109 }, + { 0x90179, 0x8 }, + { 0x9017a, 0xe0 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x0 }, + { 0x9017d, 0x7c8 }, + { 0x9017e, 0x109 }, + { 0x9017f, 0x8 }, + { 0x90180, 0x8140 }, + { 0x90181, 0x10c }, + { 0x90182, 0x0 }, + { 0x90183, 0x1 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x4 }, + { 0x90187, 0x8 }, + { 0x90188, 0x8 }, + { 0x90189, 0x7c8 }, + { 0x9018a, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x2a }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x64 }, + { 0x2000c, 0xc8 }, + { 0x2000d, 0x7d0 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x60 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x2003a, 0x2 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 }, +}; + +struct dram_fsp_msg lpddr4_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = lpddr4_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = lpddr4_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp1_cfg), + }, + { + /* P1 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = lpddr4_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp2_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = lpddr4_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp0_2d_cfg), + }, +}; + +/* lpddr4 timing config params on EVK board */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = lpddr4_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(lpddr4_ddrc_cfg), + .ddrphy_cfg = lpddr4_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(lpddr4_ddrphy_cfg), + .fsp_msg = lpddr4_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(lpddr4_dram_fsp_msg), + .ddrphy_pie = lpddr4_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(lpddr4_phy_pie), + .fsp_table = { 3200, 400, 100, }, +}; diff --git a/board/purism/librem5/lpddr4_timing_b0.c b/board/purism/librem5/lpddr4_timing_b0.c new file mode 100644 index 0000000000..ec68edaf69 --- /dev/null +++ b/board/purism/librem5/lpddr4_timing_b0.c @@ -0,0 +1,1191 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + */ + +#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +#define WR_POST_EXT_3200 /* recommened to define */ + +static struct dram_cfg_param lpddr4_ddrc_cfg[] = { + /* Start to config, default 3200mbps */ + /* dis_dq=1, indicates no reads or writes are issued to SDRAM */ + { DDRC_DBG1(0), 0x00000001 }, + /* selfref_en=1, SDRAM enter self-refresh state */ + { DDRC_PWRCTL(0), 0x00000001 }, + { DDRC_MSTR(0), 0xa3080020 }, + { DDRC_MSTR2(0), 0x00000000 }, + { DDRC_RFSHTMG(0), 0x006100E0 }, + { DDRC_INIT0(0), 0xC003061B }, + { DDRC_INIT1(0), 0x009D0000 }, + { DDRC_INIT3(0), 0x00D4002D }, +#ifdef WR_POST_EXT_3200 /* recommened to define */ + { DDRC_INIT4(0), 0x00330008 }, +#else + { DDRC_INIT4(0), 0x00310008 }, +#endif + { DDRC_INIT6(0), 0x0066004a }, + { DDRC_INIT7(0), 0x0006004a }, + + { DDRC_DRAMTMG0(0), 0x1A201B22 }, + { DDRC_DRAMTMG1(0), 0x00060633 }, + { DDRC_DRAMTMG3(0), 0x00C0C000 }, + { DDRC_DRAMTMG4(0), 0x0F04080F }, + { DDRC_DRAMTMG5(0), 0x02040C0C }, + { DDRC_DRAMTMG6(0), 0x01010007 }, + { DDRC_DRAMTMG7(0), 0x00000401 }, + { DDRC_DRAMTMG12(0), 0x00020600 }, + { DDRC_DRAMTMG13(0), 0x0C100002 }, + { DDRC_DRAMTMG14(0), 0x000000E6 }, + { DDRC_DRAMTMG17(0), 0x00A00050 }, + + { DDRC_ZQCTL0(0), 0x03200018 }, + { DDRC_ZQCTL1(0), 0x028061A8 }, + { DDRC_ZQCTL2(0), 0x00000000 }, + + { DDRC_DFITMG0(0), 0x0497820A }, + { DDRC_DFITMG1(0), 0x00080303 }, + { DDRC_DFIUPD0(0), 0xE0400018 }, + { DDRC_DFIUPD1(0), 0x00DF00E4 }, + { DDRC_DFIUPD2(0), 0x80000000 }, + { DDRC_DFIMISC(0), 0x00000011 }, + { DDRC_DFITMG2(0), 0x0000170A }, + + { DDRC_DBICTL(0), 0x00000001 }, + { DDRC_DFIPHYMSTR(0), 0x00000001 }, + + /* need be refined by ddrphy trained value */ + { DDRC_RANKCTL(0), 0x00000c99 }, + { DDRC_DRAMTMG2(0), 0x070E171a }, + + /* address mapping */ + /* Address map is from MSB 29: r15, r14, cs, r13-r0, b2-b0, c9-c0 */ + { DDRC_ADDRMAP0(0), 0x00000015 }, + { DDRC_ADDRMAP3(0), 0x00000000 }, + /* addrmap_col_b10 addrmap_col_b11 set to de-activated (5-bit width) */ + { DDRC_ADDRMAP4(0), 0x00001F1F }, + /* bank interleave */ + /* addrmap_bank_b2, addrmap_bank_b1, addrmap_bank_b0 */ + { DDRC_ADDRMAP1(0), 0x00080808 }, + /* addrmap_row_b11 addrmap_row_b10_b2 addrmap_row_b1 addrmap_row_b0 */ + { DDRC_ADDRMAP5(0), 0x07070707 }, + /* addrmap_row_b15 addrmap_row_b14 addrmap_row_b13 addrmap_row_b12 */ + { DDRC_ADDRMAP6(0), 0x08080707 }, + + /* 667mts frequency setting */ + { DDRC_FREQ1_DERATEEN(0), 0x0000000 }, + { DDRC_FREQ1_DERATEINT(0), 0x0800000 }, + { DDRC_FREQ1_RFSHCTL0(0), 0x0210000 }, + { DDRC_FREQ1_RFSHTMG(0), 0x014001E }, + { DDRC_FREQ1_INIT3(0), 0x0140009 }, + { DDRC_FREQ1_INIT4(0), 0x00310008 }, + { DDRC_FREQ1_INIT6(0), 0x0066004a }, + { DDRC_FREQ1_INIT7(0), 0x0006004a }, + { DDRC_FREQ1_DRAMTMG0(0), 0xB070A07 }, + { DDRC_FREQ1_DRAMTMG1(0), 0x003040A }, + { DDRC_FREQ1_DRAMTMG2(0), 0x305080C }, + { DDRC_FREQ1_DRAMTMG3(0), 0x0505000 }, + { DDRC_FREQ1_DRAMTMG4(0), 0x3040203 }, + { DDRC_FREQ1_DRAMTMG5(0), 0x2030303 }, + { DDRC_FREQ1_DRAMTMG6(0), 0x2020004 }, + { DDRC_FREQ1_DRAMTMG7(0), 0x0000302 }, + { DDRC_FREQ1_DRAMTMG12(0), 0x0020310 }, + { DDRC_FREQ1_DRAMTMG13(0), 0xA100002 }, + { DDRC_FREQ1_DRAMTMG14(0), 0x0000020 }, + { DDRC_FREQ1_DRAMTMG17(0), 0x0220011 }, + { DDRC_FREQ1_ZQCTL0(0), 0x0A70005 }, + { DDRC_FREQ1_DFITMG0(0), 0x3858202 }, + { DDRC_FREQ1_DFITMG1(0), 0x0000404 }, + { DDRC_FREQ1_DFITMG2(0), 0x0000502 }, + + /* performance setting */ + { DDRC_ODTCFG(0), 0x0b060908 }, + { DDRC_ODTMAP(0), 0x00000000 }, + { DDRC_SCHED(0), 0x29511505 }, + { DDRC_SCHED1(0), 0x0000002c }, + { DDRC_PERFHPR1(0), 0x5900575b }, + /* 150T starve and 0x90 max tran len */ + { DDRC_PERFLPR1(0), 0x90000096 }, + /* 300T starve and 0x10 max tran len */ + { DDRC_PERFWR1(0), 0x1000012c }, + { DDRC_DBG0(0), 0x00000016 }, + { DDRC_DBG1(0), 0x00000000 }, + { DDRC_DBGCMD(0), 0x00000000 }, + { DDRC_SWCTL(0), 0x00000001 }, + { DDRC_POISONCFG(0), 0x00000011 }, + { DDRC_PCCFG(0), 0x00000111 }, + { DDRC_PCFGR_0(0), 0x000010f3 }, + { DDRC_PCFGW_0(0), 0x000072ff }, + { DDRC_PCTRL_0(0), 0x00000001 }, + /* disable Read Qos*/ + { DDRC_PCFGQOS0_0(0), 0x00000e00 }, + { DDRC_PCFGQOS1_0(0), 0x0062ffff }, + /* disable Write Qos*/ + { DDRC_PCFGWQOS0_0(0), 0x00000e00 }, + { DDRC_PCFGWQOS1_0(0), 0x0000ffff }, + { DDRC_FREQ1_DERATEEN(0), 0x00000202 }, + { DDRC_FREQ1_DERATEINT(0), 0xec78f4b5 }, + { DDRC_FREQ1_RFSHCTL0(0), 0x00618040 }, + { DDRC_FREQ1_RFSHTMG(0), 0x00610090 }, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param lpddr4_ddrphy_cfg[] = { + { 0x20110, 0x02 }, /* MapCAB0toDFI */ + { 0x20111, 0x03 }, /* MapCAB1toDFI */ + { 0x20112, 0x04 }, /* MapCAB2toDFI */ + { 0x20113, 0x05 }, /* MapCAB3toDFI */ + { 0x20114, 0x00 }, /* MapCAB4toDFI */ + { 0x20115, 0x01 }, /* MapCAB5toDFI */ + + /* Initialize PHY Configuration */ + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x1 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + + { 0x20024, 0xe3 }, + { 0x2003a, 0x2 }, + { 0x120024, 0xa3 }, + { 0x2003a, 0x2 }, + { 0x220024, 0xa3 }, + { 0x2003a, 0x2 }, + + { 0x20056, 0x3 }, + { 0x120056, 0xa }, + { 0x220056, 0xa }, + + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + + { 0x10049, 0xfbe }, + { 0x10149, 0xfbe }, + { 0x11049, 0xfbe }, + { 0x11149, 0xfbe }, + { 0x12049, 0xfbe }, + { 0x12149, 0xfbe }, + { 0x13049, 0xfbe }, + { 0x13149, 0xfbe }, + + { 0x110049, 0xfbe }, + { 0x110149, 0xfbe }, + { 0x111049, 0xfbe }, + { 0x111149, 0xfbe }, + { 0x112049, 0xfbe }, + { 0x112149, 0xfbe }, + { 0x113049, 0xfbe }, + { 0x113149, 0xfbe }, + + { 0x210049, 0xfbe }, + { 0x210149, 0xfbe }, + { 0x211049, 0xfbe }, + { 0x211149, 0xfbe }, + { 0x212049, 0xfbe }, + { 0x212149, 0xfbe }, + { 0x213049, 0xfbe }, + { 0x213149, 0xfbe }, + + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x320 }, + { 0x120008, 0xa7 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0x104 }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0x104 }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0x104 }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x600 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5655 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param lpddr4_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54000, 0x0 }, + { 0x54001, 0x0 }, + { 0x54002, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT) }, + { 0x54006, LPDDR4_PHY_VREF_VALUE }, + { 0x54007, 0x0 }, + { 0x54008, 0x131f }, + { 0x54009, LPDDR4_HDT_CTL_3200_1D }, + { 0x5400a, 0x0 }, + { 0x5400b, 0x2 }, + { 0x5400c, 0x0 }, + { 0x5400d, (LPDDR4_CATRAIN_3200_1d << 8) }, + { 0x5400e, 0x0 }, + { 0x5400f, 0x0 }, + { 0x54010, 0x0 }, + { 0x54011, 0x0 }, + { 0x54012, 0x310 }, + { 0x54013, 0x0 }, + { 0x54014, 0x0 }, + { 0x54015, 0x0 }, + { 0x54016, 0x0 }, + { 0x54017, 0x0 }, + { 0x54018, 0x0 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, (((LPDDR4_RON) << 3) | 0x3) }, + { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) | + (LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) }, + { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08) }, + { 0x5401d, 0x0 }, + { 0x5401e, LPDDR4_MR22_RANK0 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, (((LPDDR4_RON) << 3) | 0x3) }, + { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) | + (LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) }, + { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08) }, + { 0x54023, 0x0 }, + { 0x54024, LPDDR4_MR22_RANK1 }, + { 0x54025, 0x0 }, + { 0x54026, 0x0 }, + { 0x54027, 0x0 }, + { 0x54028, 0x0 }, + { 0x54029, 0x0 }, + { 0x5402a, 0x0 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x5402d, 0x0 }, + { 0x5402e, 0x0 }, + { 0x5402f, 0x0 }, + { 0x54030, 0x0 }, + { 0x54031, 0x0 }, + { 0x54032, 0xd400 }, + { 0x54033, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d }, + { 0x54034, (((LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x54035, (0x0800 | LPDDR4_VREF_VALUE_CA) }, + { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0 }, + { 0x54037, (LPDDR4_MR22_RANK0 << 8) }, + { 0x54038, 0xd400 }, + { 0x54039, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d }, + { 0x5403a, (((LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x5403b, (0x0800 | LPDDR4_VREF_VALUE_CA) }, + { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1 }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403e, 0x0 }, + { 0x5403f, 0x0 }, + { 0x54040, 0x0 }, + { 0x54041, 0x0 }, + { 0x54042, 0x0 }, + { 0x54043, 0x0 }, + { 0x54044, 0x0 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param lpddr4_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54000, 0x0 }, + { 0x54001, 0x0 }, + { 0x54002, 0x1 }, + { 0x54003, 0x29c }, + { 0x54004, 0x2 }, + { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT) }, + { 0x54006, LPDDR4_PHY_VREF_VALUE }, + { 0x54007, 0x0 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400a, 0x0 }, + { 0x5400b, 0x2 }, + { 0x5400c, 0x0 }, + { 0x5400d, 0x0 }, + { 0x5400e, 0x0 }, + { 0x5400f, 0x0 }, + { 0x54010, 0x0 }, + { 0x54011, 0x0 }, + { 0x54012, 0x310 }, + { 0x54013, 0x0 }, + { 0x54014, 0x0 }, + { 0x54015, 0x0 }, + { 0x54016, 0x0 }, + { 0x54017, 0x0 }, + { 0x54018, 0x0 }, + { 0x54019, 0x914 }, + { 0x5401a, (((LPDDR4_RON) << 3) | 0x1) }, + { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) | + (LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) }, + { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08) }, + { 0x5401e, 0x6 }, + { 0x5401f, 0x914 }, + { 0x54020, (((LPDDR4_RON) << 3) | 0x1) }, + { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) | + (LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) }, + { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08) }, + { 0x54023, 0x0 }, + { 0x54024, LPDDR4_MR22_RANK1 }, + { 0x54025, 0x0 }, + { 0x54026, 0x0 }, + { 0x54027, 0x0 }, + { 0x54028, 0x0 }, + { 0x54029, 0x0 }, + { 0x5402a, 0x0 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x5402d, 0x0 }, + { 0x5402e, 0x0 }, + { 0x5402f, 0x0 }, + { 0x54030, 0x0 }, + { 0x54031, 0x0 }, + { 0x54032, 0x1400 }, + { 0x54033, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x09 }, + { 0x54034, (((LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x54035, (0x0800 | LPDDR4_VREF_VALUE_CA) }, + { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0 }, + { 0x54037, 0x600 }, + { 0x54038, 0x1400 }, + { 0x54039, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x09 }, + { 0x5403a, (((LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x5403b, (0x0800 | LPDDR4_VREF_VALUE_CA) }, + { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1 }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403e, 0x0 }, + { 0x5403f, 0x0 }, + { 0x54040, 0x0 }, + { 0x54041, 0x0 }, + { 0x54042, 0x0 }, + { 0x54043, 0x0 }, + { 0xd0000, 0x1 }, + +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param lpddr4_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54000, 0x0 }, + { 0x54001, 0x0 }, + { 0x54002, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT) }, + { 0x54006, LPDDR4_PHY_VREF_VALUE }, + { 0x54007, 0x0 }, + { 0x54008, 0x61 }, + { 0x54009, LPDDR4_HDT_CTL_2D }, + { 0x5400a, 0x0 }, + { 0x5400b, 0x2 }, + { 0x5400c, 0x0 }, + { 0x5400d, (LPDDR4_CATRAIN_3200_2d << 8) }, + { 0x5400e, 0x0 }, + { 0x5400f, (LPDDR4_2D_SHARE << 8) | 0x00 }, + { 0x54010, LPDDR4_2D_WEIGHT }, + { 0x54011, 0x0 }, + { 0x54012, 0x310 }, + { 0x54013, 0x0 }, + { 0x54014, 0x0 }, + { 0x54015, 0x0 }, + { 0x54016, 0x0 }, + { 0x54017, 0x0 }, + { 0x54018, 0x0 }, + { 0x54024, 0x5 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, (((LPDDR4_RON) << 3) | 0x3) }, + { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) | + (LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) }, + { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08) }, + { 0x5401d, 0x0 }, + { 0x5401e, LPDDR4_MR22_RANK0 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, (((LPDDR4_RON) << 3) | 0x3) }, + { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) | + (LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) }, + { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08) }, + { 0x54023, 0x0 }, + { 0x54024, LPDDR4_MR22_RANK1 }, + { 0x54025, 0x0 }, + { 0x54026, 0x0 }, + { 0x54027, 0x0 }, + { 0x54028, 0x0 }, + { 0x54029, 0x0 }, + { 0x5402a, 0x0 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x5402d, 0x0 }, + { 0x5402e, 0x0 }, + { 0x5402f, 0x0 }, + { 0x54030, 0x0 }, + { 0x54031, 0x0 }, + { 0x54032, 0xd400 }, + { 0x54033, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d }, + { 0x54034, (((LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x54035, (0x0800 | LPDDR4_VREF_VALUE_CA) }, + { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0 }, + { 0x54037, (LPDDR4_MR22_RANK0 << 8) }, + { 0x54038, 0xd400 }, + { 0x54039, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d }, + { 0x5403a, (((LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x5403b, (0x0800 | LPDDR4_VREF_VALUE_CA) }, + { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1 }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403e, 0x0 }, + { 0x5403f, 0x0 }, + { 0x54040, 0x0 }, + { 0x54041, 0x0 }, + { 0x54042, 0x0 }, + { 0x54043, 0x0 }, + { 0x54044, 0x0 }, + { 0xd0000, 0x1 }, + +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param lpddr4_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xb }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x630 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x630 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x630 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x630 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x630 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x630 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x630 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x630 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x630 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x630 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x630 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x630 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x630 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xa }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x2 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x900a4, 0xd }, + { 0x900a5, 0x7c0 }, + { 0x900a6, 0x109 }, + { 0x900a7, 0x4 }, + { 0x900a8, 0x7c0 }, + { 0x900a9, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x623 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x623 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900aa, 0x0 }, + { 0x900ab, 0x790 }, + { 0x900ac, 0x11a }, + { 0x900ad, 0x8 }, + { 0x900ae, 0x7aa }, + { 0x900af, 0x2a }, + { 0x900b0, 0x10 }, + { 0x900b1, 0x7b2 }, + { 0x900b2, 0x2a }, + { 0x900b3, 0x0 }, + { 0x900b4, 0x7c8 }, + { 0x900b5, 0x109 }, + { 0x900b6, 0x10 }, + { 0x900b7, 0x10 }, + { 0x900b8, 0x109 }, + { 0x900b9, 0x10 }, + { 0x900ba, 0x2a8 }, + { 0x900bb, 0x129 }, + { 0x900bc, 0x8 }, + { 0x900bd, 0x370 }, + { 0x900be, 0x129 }, + { 0x900bf, 0xa }, + { 0x900c0, 0x3c8 }, + { 0x900c1, 0x1a9 }, + { 0x900c2, 0xc }, + { 0x900c3, 0x408 }, + { 0x900c4, 0x199 }, + { 0x900c5, 0x14 }, + { 0x900c6, 0x790 }, + { 0x900c7, 0x11a }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x4 }, + { 0x900ca, 0x18 }, + { 0x900cb, 0xe }, + { 0x900cc, 0x408 }, + { 0x900cd, 0x199 }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x8568 }, + { 0x900d0, 0x108 }, + { 0x900d1, 0x18 }, + { 0x900d2, 0x790 }, + { 0x900d3, 0x16a }, + { 0x900d4, 0x8 }, + { 0x900d5, 0x1d8 }, + { 0x900d6, 0x169 }, + { 0x900d7, 0x10 }, + { 0x900d8, 0x8558 }, + { 0x900d9, 0x168 }, + { 0x900da, 0x70 }, + { 0x900db, 0x788 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x1ff8 }, + { 0x900de, 0x85a8 }, + { 0x900df, 0x1e8 }, + { 0x900e0, 0x50 }, + { 0x900e1, 0x798 }, + { 0x900e2, 0x16a }, + { 0x900e3, 0x60 }, + { 0x900e4, 0x7a0 }, + { 0x900e5, 0x16a }, + { 0x900e6, 0x8 }, + { 0x900e7, 0x8310 }, + { 0x900e8, 0x168 }, + { 0x900e9, 0x8 }, + { 0x900ea, 0xa310 }, + { 0x900eb, 0x168 }, + { 0x900ec, 0xa }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x6e }, + { 0x900f0, 0x0 }, + { 0x900f1, 0x68 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0x408 }, + { 0x900f4, 0x169 }, + { 0x900f5, 0x0 }, + { 0x900f6, 0x8310 }, + { 0x900f7, 0x168 }, + { 0x900f8, 0x0 }, + { 0x900f9, 0xa310 }, + { 0x900fa, 0x168 }, + { 0x900fb, 0x1ff8 }, + { 0x900fc, 0x85a8 }, + { 0x900fd, 0x1e8 }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x798 }, + { 0x90100, 0x16a }, + { 0x90101, 0x78 }, + { 0x90102, 0x7a0 }, + { 0x90103, 0x16a }, + { 0x90104, 0x68 }, + { 0x90105, 0x790 }, + { 0x90106, 0x16a }, + { 0x90107, 0x8 }, + { 0x90108, 0x8b10 }, + { 0x90109, 0x168 }, + { 0x9010a, 0x8 }, + { 0x9010b, 0xab10 }, + { 0x9010c, 0x168 }, + { 0x9010d, 0xa }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x58 }, + { 0x90111, 0x0 }, + { 0x90112, 0x68 }, + { 0x90113, 0x0 }, + { 0x90114, 0x408 }, + { 0x90115, 0x169 }, + { 0x90116, 0x0 }, + { 0x90117, 0x8b10 }, + { 0x90118, 0x168 }, + { 0x90119, 0x0 }, + { 0x9011a, 0xab10 }, + { 0x9011b, 0x168 }, + { 0x9011c, 0x0 }, + { 0x9011d, 0x1d8 }, + { 0x9011e, 0x169 }, + { 0x9011f, 0x80 }, + { 0x90120, 0x790 }, + { 0x90121, 0x16a }, + { 0x90122, 0x18 }, + { 0x90123, 0x7aa }, + { 0x90124, 0x6a }, + { 0x90125, 0xa }, + { 0x90126, 0x0 }, + { 0x90127, 0x1e9 }, + { 0x90128, 0x8 }, + { 0x90129, 0x8080 }, + { 0x9012a, 0x108 }, + { 0x9012b, 0xf }, + { 0x9012c, 0x408 }, + { 0x9012d, 0x169 }, + { 0x9012e, 0xc }, + { 0x9012f, 0x0 }, + { 0x90130, 0x68 }, + { 0x90131, 0x9 }, + { 0x90132, 0x0 }, + { 0x90133, 0x1a9 }, + { 0x90134, 0x0 }, + { 0x90135, 0x408 }, + { 0x90136, 0x169 }, + { 0x90137, 0x0 }, + { 0x90138, 0x8080 }, + { 0x90139, 0x108 }, + { 0x9013a, 0x8 }, + { 0x9013b, 0x7aa }, + { 0x9013c, 0x6a }, + { 0x9013d, 0x0 }, + { 0x9013e, 0x8568 }, + { 0x9013f, 0x108 }, + { 0x90140, 0xb7 }, + { 0x90141, 0x790 }, + { 0x90142, 0x16a }, + { 0x90143, 0x1f }, + { 0x90144, 0x0 }, + { 0x90145, 0x68 }, + { 0x90146, 0x8 }, + { 0x90147, 0x8558 }, + { 0x90148, 0x168 }, + { 0x90149, 0xf }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0xc }, + { 0x9014d, 0x0 }, + { 0x9014e, 0x68 }, + { 0x9014f, 0x0 }, + { 0x90150, 0x408 }, + { 0x90151, 0x169 }, + { 0x90152, 0x0 }, + { 0x90153, 0x8558 }, + { 0x90154, 0x168 }, + { 0x90155, 0x8 }, + { 0x90156, 0x3c8 }, + { 0x90157, 0x1a9 }, + { 0x90158, 0x3 }, + { 0x90159, 0x370 }, + { 0x9015a, 0x129 }, + { 0x9015b, 0x20 }, + { 0x9015c, 0x2aa }, + { 0x9015d, 0x9 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x400 }, + { 0x90160, 0x10e }, + { 0x90161, 0x8 }, + { 0x90162, 0xe8 }, + { 0x90163, 0x109 }, + { 0x90164, 0x0 }, + { 0x90165, 0x8140 }, + { 0x90166, 0x10c }, + { 0x90167, 0x10 }, + { 0x90168, 0x8138 }, + { 0x90169, 0x10c }, + { 0x9016a, 0x8 }, + { 0x9016b, 0x7c8 }, + { 0x9016c, 0x101 }, + { 0x9016d, 0x8 }, + { 0x9016e, 0x0 }, + { 0x9016f, 0x8 }, + { 0x90170, 0x8 }, + { 0x90171, 0x448 }, + { 0x90172, 0x109 }, + { 0x90173, 0xf }, + { 0x90174, 0x7c0 }, + { 0x90175, 0x109 }, + { 0x90176, 0x0 }, + { 0x90177, 0xe8 }, + { 0x90178, 0x109 }, + { 0x90179, 0x47 }, + { 0x9017a, 0x630 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x8 }, + { 0x9017d, 0x618 }, + { 0x9017e, 0x109 }, + { 0x9017f, 0x8 }, + { 0x90180, 0xe0 }, + { 0x90181, 0x109 }, + { 0x90182, 0x0 }, + { 0x90183, 0x7c8 }, + { 0x90184, 0x109 }, + { 0x90185, 0x8 }, + { 0x90186, 0x8140 }, + { 0x90187, 0x10c }, + { 0x90188, 0x0 }, + { 0x90189, 0x1 }, + { 0x9018a, 0x8 }, + { 0x9018b, 0x8 }, + { 0x9018c, 0x4 }, + { 0x9018d, 0x8 }, + { 0x9018e, 0x8 }, + { 0x9018f, 0x7c8 }, + { 0x90190, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x2b }, + { 0x90026, 0x6c }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x64 }, + { 0x2000c, 0xc8 }, + { 0x2000d, 0x7d0 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0x14 }, + { 0x12000c, 0x29 }, + { 0x12000d, 0x1a1 }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x60 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x20089, 0x1 }, + { 0x20088, 0x19 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 }, +}; + +static struct dram_fsp_msg lpddr4_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = lpddr4_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp0_cfg), + }, + { + /* P1 667mts 1D */ + .drate = 667, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = lpddr4_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp1_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = lpddr4_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp0_2d_cfg), + }, +}; + +/* lpddr4 timing config params on EVK board */ +struct dram_timing_info dram_timing_b0 = { + .ddrc_cfg = lpddr4_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(lpddr4_ddrc_cfg), + .ddrphy_cfg = lpddr4_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(lpddr4_ddrphy_cfg), + .fsp_msg = lpddr4_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(lpddr4_dram_fsp_msg), + .ddrphy_pie = lpddr4_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(lpddr4_phy_pie), + /* + * this table must be initialized if DDRPHY bypass mode is + * not used: all fsp drate > 666MTS. + */ + .fsp_table = { 3200, 667, }, +}; diff --git a/board/purism/librem5/spl.c b/board/purism/librem5/spl.c new file mode 100644 index 0000000000..b35f11debe --- /dev/null +++ b/board/purism/librem5/spl.c @@ -0,0 +1,593 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + * Copyright 2021 Purism + */ + +#include <common.h> +#include <asm/io.h> +#include <errno.h> +#include <asm/io.h> +#include <asm/arch/ddr.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/clock.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <fsl_esdhc_imx.h> +#include <mmc.h> +#include <power/pmic.h> +#include <power/bd71837.h> +#include <hang.h> +#include <init.h> +#include <spl.h> +#include <usb.h> +#include <dwc3-uboot.h> +#include <linux/delay.h> +#include "librem5.h" + +DECLARE_GLOBAL_DATA_PTR; + +void spl_dram_init(void) +{ + /* ddr init */ + if ((get_cpu_rev() & 0xfff) == CHIP_REV_2_1) + ddr_init(&dram_timing); + else + ddr_init(&dram_timing_b0); +} + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ + log_debug("%s : starting\n", __func__); + + switch (boot_dev_spl) { + case SD1_BOOT: + case MMC1_BOOT: + return BOOT_DEVICE_MMC1; + case USB_BOOT: + return BOOT_DEVICE_BOARD; + default: + return BOOT_DEVICE_NONE; + } +} + +#define ECSPI_PAD_CTRL (PAD_CTL_DSE2 | PAD_CTL_HYS) + +static const iomux_v3_cfg_t ecspi_pads[] = { + IMX8MQ_PAD_ECSPI1_SCLK__ECSPI1_SCLK | MUX_PAD_CTRL(ECSPI_PAD_CTRL), + IMX8MQ_PAD_ECSPI1_SS0__GPIO5_IO9 | MUX_PAD_CTRL(ECSPI_PAD_CTRL), + IMX8MQ_PAD_ECSPI1_MOSI__ECSPI1_MOSI | MUX_PAD_CTRL(ECSPI_PAD_CTRL), + IMX8MQ_PAD_ECSPI1_MISO__ECSPI1_MISO | MUX_PAD_CTRL(ECSPI_PAD_CTRL), +}; + +int board_ecspi_init(void) +{ + imx_iomux_v3_setup_multiple_pads(ecspi_pads, ARRAY_SIZE(ecspi_pads)); + + return 0; +} + +int board_spi_cs_gpio(unsigned int bus, unsigned int cs) +{ + return (bus == 0 && cs == 0) ? (SPI1_SS0) : -1; +} + +#define I2C_PAD_CTRL (PAD_CTL_PUE | PAD_CTL_ODE | PAD_CTL_DSE7 | PAD_CTL_FSEL3) +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = IMX8MQ_PAD_I2C1_SCL__I2C1_SCL | PC, + .gpio_mode = IMX8MQ_PAD_I2C1_SCL__GPIO5_IO14 | PC, + .gp = IMX_GPIO_NR(5, 14), + }, + .sda = { + .i2c_mode = IMX8MQ_PAD_I2C1_SDA__I2C1_SDA | PC, + .gpio_mode = IMX8MQ_PAD_I2C1_SDA__GPIO5_IO15 | PC, + .gp = IMX_GPIO_NR(5, 15), + }, +}; + +struct i2c_pads_info i2c_pad_info2 = { + .scl = { + .i2c_mode = IMX8MQ_PAD_I2C2_SCL__I2C2_SCL | PC, + .gpio_mode = IMX8MQ_PAD_I2C2_SCL__GPIO5_IO16 | PC, + .gp = IMX_GPIO_NR(5, 16), + }, + .sda = { + .i2c_mode = IMX8MQ_PAD_I2C2_SDA__I2C2_SDA | PC, + .gpio_mode = IMX8MQ_PAD_I2C2_SDA__GPIO5_IO17 | PC, + .gp = IMX_GPIO_NR(5, 17), + }, +}; + +struct i2c_pads_info i2c_pad_info3 = { + .scl = { + .i2c_mode = IMX8MQ_PAD_I2C3_SCL__I2C3_SCL | PC, + .gpio_mode = IMX8MQ_PAD_I2C3_SCL__GPIO5_IO18 | PC, + .gp = IMX_GPIO_NR(5, 18), + }, + .sda = { + .i2c_mode = IMX8MQ_PAD_I2C3_SDA__I2C3_SDA | PC, + .gpio_mode = IMX8MQ_PAD_I2C3_SDA__GPIO5_IO19 | PC, + .gp = IMX_GPIO_NR(5, 19), + }, +}; + +struct i2c_pads_info i2c_pad_info4 = { + .scl = { + .i2c_mode = IMX8MQ_PAD_I2C4_SCL__I2C4_SCL | PC, + .gpio_mode = IMX8MQ_PAD_I2C4_SCL__GPIO5_IO20 | PC, + .gp = IMX_GPIO_NR(5, 20), + }, + .sda = { + .i2c_mode = IMX8MQ_PAD_I2C4_SDA__I2C4_SDA | PC, + .gpio_mode = IMX8MQ_PAD_I2C4_SDA__GPIO5_IO21 | PC, + .gp = IMX_GPIO_NR(5, 21), + }, +}; + +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) + +static const iomux_v3_cfg_t uart_pads[] = { + IMX8MQ_PAD_UART1_RXD__UART1_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_UART1_TXD__UART1_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_UART2_RXD__UART2_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_UART2_TXD__UART2_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_UART3_RXD__UART3_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_UART3_TXD__UART3_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_ECSPI2_SCLK__UART4_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_ECSPI2_MOSI__UART4_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +#define USDHC1_PWR_GPIO IMX_GPIO_NR(2, 10) +#define USDHC2_PWR_GPIO IMX_GPIO_NR(2, 19) + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = 1; + break; + case USDHC2_BASE_ADDR: + ret = 1; + break; + } + + return ret; +} + +#define USDHC_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE | \ + PAD_CTL_FSEL1) +#define USDHC_GPIO_PAD_CTRL (PAD_CTL_PUE | PAD_CTL_DSE1) + +static const iomux_v3_cfg_t usdhc1_pads[] = { + IMX8MQ_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA4__USDHC1_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA5__USDHC1_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA6__USDHC1_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA7__USDHC1_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_RESET_B__GPIO2_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static const iomux_v3_cfg_t usdhc2_pads[] = { + IMX8MQ_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_DATA0__USDHC2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_DATA1__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_DATA2__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0x16 */ + IMX8MQ_PAD_SD2_DATA3__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_RESET_B__GPIO2_IO19 | MUX_PAD_CTRL(USDHC_GPIO_PAD_CTRL), +}; + +static struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC1_BASE_ADDR, 0, 8}, + {USDHC2_BASE_ADDR, 0, 4}, +}; + +int board_mmc_init(struct bd_info *bis) +{ + int i, ret; + /* + * According to the board_mmc_init() the following map is done: + * (U-Boot device node) (Physical Port) + * mmc0 USDHC1 + * mmc1 USDHC2 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + log_debug("Initializing FSL USDHC port %d\n", i); + switch (i) { + case 0: + init_clk_usdhc(0); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(USDHC1_CLK_ROOT); + imx_iomux_v3_setup_multiple_pads(usdhc1_pads, + ARRAY_SIZE(usdhc1_pads)); + gpio_request(USDHC1_PWR_GPIO, "usdhc1_reset"); + gpio_direction_output(USDHC1_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC1_PWR_GPIO, 1); + break; + case 1: + init_clk_usdhc(1); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(USDHC2_CLK_ROOT); + imx_iomux_v3_setup_multiple_pads(usdhc2_pads, + ARRAY_SIZE(usdhc2_pads)); + gpio_request(USDHC2_PWR_GPIO, "usdhc2_reset"); + gpio_direction_output(USDHC2_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC2_PWR_GPIO, 1); + break; + default: + log_err("Warning: USDHC controller(%d) not supported\n", i + 1); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) + return ret; + } + + return 0; +} + +#define LDO_VOLT_EN BIT(6) + +/* + * Disable the charger - it will be re-enabled in u-boot + */ +void disable_charger_bq25895(void) +{ + u8 val; + int timeout = 1000; // ms + + /* Set the i2c bus */ + i2c_set_bus_num(3); + + /* disable ship mode if BATFET_DLY is set */ + val = i2c_reg_read(0x6a, 0x09); + log_debug("REG09 0x%x\n", val); + if (val & 0x28) { + val = val & ~0x28; + i2c_reg_write(0x6a, 0x09, val); + } + + /* disable and trigger DPDM, ICO, HVDCP and MaxCharge */ + val = i2c_reg_read(0x6a, 0x02); + log_debug("REG02 0x%x\n", val); + val &= 0xe0; + i2c_reg_write(0x6a, 0x02, val); + + /* disable charger and enable BAT_LOADEN */ + val = i2c_reg_read(0x6a, 0x03); + log_debug("REG03 0x%x\n", val); + val = (val | 0x80) & ~0x10; + i2c_reg_write(0x6a, 0x03, val); + + mdelay(10); + + /* force ADC conversions */ + val = i2c_reg_read(0x6a, 0x02); + log_debug("REG02 0x%x\n", val); + val = (val | 0x80) & ~0x40; + i2c_reg_write(0x6a, 0x02, val); + + do { + mdelay(10); + timeout -= 10; + } while ((i2c_reg_read(0x6a, 0x02) & 0x80) && (timeout > 0)); + + /* enable STAT pin */ + val = i2c_reg_read(0x6a, 0x07); + log_debug("REG07 0x%x\n", val); + val = val & ~0x40; + i2c_reg_write(0x6a, 0x07, val); + + /* check VBUS */ + val = i2c_reg_read(0x6a, 0x11); + log_debug("VBUS good %d\n", (val >> 7) & 1); + log_debug("VBUS mV %d\n", (val & 0x7f) * 100 + 2600); + + /* check VBAT */ + val = i2c_reg_read(0x6a, 0x0e); + log_debug("VBAT mV %d\n", (val & 0x7f) * 20 + 2304); + + /* limit the VINDPM to 3.9V */ + i2c_reg_write(0x6a, 0x0d, 0x8d); + + /* set the max voltage to 4.192V */ + val = i2c_reg_read(0x6a, 0x6); + val = (val & ~0xFC) | 0x16 << 2; + i2c_reg_write(0x6a, 0x6, val); + + /* set the SYS_MIN to 3.7V */ + val = i2c_reg_read(0x6a, 0x3); + val = val | 0xE; + i2c_reg_write(0x6a, 0x3, val); + + /* disable BAT_LOADEN */ + val = i2c_reg_read(0x6a, 0x03); + log_debug("REG03 0x%x\n", val); + val = val & ~0x80; + i2c_reg_write(0x6a, 0x03, val); +} + +#define I2C_PMIC 0 + +int power_bd71837_init(unsigned char bus) +{ + static const char name[] = BD718XX_REGULATOR_DRIVER; + struct pmic *p = pmic_alloc(); + + if (!p) { + log_err("%s: POWER allocation error!\n", __func__); + return -ENOMEM; + } + + p->name = name; + p->interface = I2C_PMIC; + p->number_of_regs = BD718XX_MAX_REGISTER; + p->hw.i2c.addr = CONFIG_POWER_BD71837_I2C_ADDR; + p->hw.i2c.tx_num = 1; + p->bus = bus; + + return 0; +} + +int power_init_board(void) +{ + struct pmic *p; + int ldo[] = {BD718XX_LDO5_VOLT, BD718XX_LDO6_VOLT, + BD71837_LDO7_VOLT}; + u32 val; + int i, rv; + + /* Set the i2c bus */ + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + + /* + * Init PMIC + */ + rv = power_bd71837_init(CONFIG_POWER_BD71837_I2C_BUS); + if (rv) { + log_err("%s: power_bd71837_init(%d) error %d\n", __func__, + CONFIG_POWER_BD71837_I2C_BUS, rv); + goto out; + } + + p = pmic_get(BD718XX_REGULATOR_DRIVER); + if (!p) { + log_err("%s: pmic_get(%s) failed\n", __func__, BD718XX_REGULATOR_DRIVER); + rv = -ENODEV; + goto out; + } + + rv = pmic_probe(p); + if (rv) { + log_err("%s: pmic_probe() error %d\n", __func__, rv); + goto out; + } + + /* + * Unlock all regs + */ + pmic_reg_write(p, BD718XX_REGLOCK, 0); + + /* find the reset cause */ + pmic_reg_read(p, 0x29, &val); + log_debug("%s: reset cause %d\n", __func__, val); + + /* + * Reconfigure default voltages and disable: + * - BUCK3: VDD_GPU_0V9 (1.00 -> 0.90) + * - BUCK4: VDD_VPU_0V9 (1.00 -> 0.90) + */ + pmic_reg_write(p, BD71837_BUCK3_VOLT_RUN, 0x14); + pmic_reg_write(p, BD71837_BUCK4_VOLT_RUN, 0x14); + + /* + * Enable PHYs voltages: LDO5-7 + */ + for (i = 0; i < ARRAY_SIZE(ldo); i++) { + rv = pmic_reg_read(p, ldo[i], &val); + if (rv) { + log_err("%s: pmic_read(%x) error %d\n", __func__, + ldo[i], rv); + continue; + } + + pmic_reg_write(p, ldo[i], val | LDO_VOLT_EN); + } + + udelay(500); + + rv = 0; +out: + return rv; +} + +int usb_gadget_handle_interrupts(void) +{ + dwc3_uboot_handle_interrupt(0); + return 0; +} + +static void dwc3_nxp_usb_phy_init(struct dwc3_device *dwc3) +{ + u32 RegData; + + RegData = readl(dwc3->base + USB_PHY_CTRL1); + RegData &= ~(USB_PHY_CTRL1_VDATSRCENB0 | USB_PHY_CTRL1_VDATDETENB0 | + USB_PHY_CTRL1_COMMONONN); + RegData |= USB_PHY_CTRL1_RESET | USB_PHY_CTRL1_ATERESET; + writel(RegData, dwc3->base + USB_PHY_CTRL1); + + RegData = readl(dwc3->base + USB_PHY_CTRL0); + RegData |= USB_PHY_CTRL0_REF_SSP_EN; + RegData &= ~USB_PHY_CTRL0_SSC_RANGE_MASK; + RegData |= USB_PHY_CTRL0_SSC_RANGE_4003PPM; + writel(RegData, dwc3->base + USB_PHY_CTRL0); + + RegData = readl(dwc3->base + USB_PHY_CTRL2); + RegData |= USB_PHY_CTRL2_TXENABLEN0; + writel(RegData, dwc3->base + USB_PHY_CTRL2); + + RegData = readl(dwc3->base + USB_PHY_CTRL1); + RegData &= ~(USB_PHY_CTRL1_RESET | USB_PHY_CTRL1_ATERESET); + writel(RegData, dwc3->base + USB_PHY_CTRL1); + + /* Disable rx term override */ + RegData = readl(dwc3->base + USB_PHY_CTRL6); + RegData &= ~USB_PHY_CTRL6_RXTERM_OVERRIDE_SEL; + writel(RegData, dwc3->base + USB_PHY_CTRL6); +} + +static struct dwc3_device dwc3_device0_data = { + .maximum_speed = USB_SPEED_HIGH, + .base = USB1_BASE_ADDR, + .dr_mode = USB_DR_MODE_PERIPHERAL, + .index = 0, +}; + +static struct dwc3_device dwc3_device1_data = { + .maximum_speed = USB_SPEED_HIGH, + .base = USB2_BASE_ADDR, + .dr_mode = USB_DR_MODE_HOST, + .index = 1, +}; + +int board_usb_init(int index, enum usb_init_type init) +{ + int ret = 0; + + printf("%s : index %d type %d\n", __func__, index, init); + + if (index == 0 && init == USB_INIT_DEVICE) { + dwc3_nxp_usb_phy_init(&dwc3_device0_data); + ret = dwc3_uboot_init(&dwc3_device0_data); + } + if (index == 1 && init == USB_INIT_HOST) { + dwc3_nxp_usb_phy_init(&dwc3_device1_data); + ret = dwc3_uboot_init(&dwc3_device1_data); + } + + return ret; +} + +int board_usb_cleanup(int index, enum usb_init_type init) +{ + u32 RegData; + struct dwc3_device *dwc3; + + printf("%s : %d\n", __func__, index); + + if (index == 0 && init == USB_INIT_DEVICE) + dwc3 = &dwc3_device0_data; + if (index == 1 && init == USB_INIT_HOST) + dwc3 = &dwc3_device1_data; + + dwc3_uboot_exit(index); + + /* reset the phy */ + RegData = readl(dwc3->base + USB_PHY_CTRL1); + RegData &= ~(USB_PHY_CTRL1_VDATSRCENB0 | USB_PHY_CTRL1_VDATDETENB0 | + USB_PHY_CTRL1_COMMONONN); + RegData |= USB_PHY_CTRL1_RESET | USB_PHY_CTRL1_ATERESET; + writel(RegData, dwc3->base + USB_PHY_CTRL1); + + /* enable rx term override */ + RegData = readl(dwc3->base + USB_PHY_CTRL6); + RegData |= USB_PHY_CTRL6_RXTERM_OVERRIDE_SEL; + writel(RegData, dwc3->base + USB_PHY_CTRL6); + + return 0; +} + +void spl_board_init(void) +{ + if (is_usb_boot()) + puts("USB Boot\n"); + else + puts("Normal Boot\n"); +} + +void board_boot_order(u32 *spl_boot_list) +{ + if (is_usb_boot()) + spl_boot_list[0] = BOOT_DEVICE_BOARD; + else + spl_boot_list[0] = BOOT_DEVICE_MMC1; +} + +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) + +static const iomux_v3_cfg_t wdog_pads[] = { + IMX8MQ_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), +}; + +void board_init_f(ulong dummy) +{ + int ret; + struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; + + arch_cpu_init(); + + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + set_wdog_reset(wdog); + + init_uart_clk(CONSOLE_UART_CLK); + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); + +#ifdef CONSOLE_ON_UART4 + gpio_request(WIFI_EN, "WIFI_EN"); + gpio_direction_output(WIFI_EN, 1); +#endif + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + ret = spl_init(); + if (ret) { + log_err("spl_init() failed: %d\n", ret); + hang(); + } + + enable_tzc380(); + + printf("Initializing pinmux\n"); + init_pinmux(); + gpio_direction_output(LED_G, 1); + gpio_direction_output(MOTO, 1); + mdelay(50); + gpio_direction_output(MOTO, 0); + + /* Enable and configure i2c buses not used below */ + setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2); + setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info3); + setup_i2c(3, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info4); + + power_init_board(); + + disable_charger_bq25895(); + + /* initialize this for M4 even if u-boot doesn't have SF_CMD */ + printf("Initializing ECSPI\n"); + board_ecspi_init(); + + /* DDR initialization */ + printf("Initializing DRAM\n"); + spl_dram_init(); +} + diff --git a/configs/librem5_defconfig b/configs/librem5_defconfig new file mode 100644 index 0000000000..dba20f1c8b --- /dev/null +++ b/configs/librem5_defconfig @@ -0,0 +1,142 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x3FE000 +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_SYS_I2C_MXC_I2C4=y +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mq-librem5-r4" +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_LIBREM5=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL=y +CONFIG_DEVRES=y +# CONFIG_SPL_DEVRES is not set +CONFIG_IMX_BOOTAUX=y +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_REMAKE_ELF=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y +# CONFIG_SYS_DEVICE_NULLDEV is not set +CONFIG_ARCH_MISC_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_USB_SDP_SUPPORT=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_CMD_MEMTEST=y +CONFIG_SYS_ALT_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_DM=y +# CONFIG_SPL_BLK is not set +CONFIG_BUTTON=y +CONFIG_BUTTON_GPIO=y +CONFIG_CLK_IMX8MQ=y +CONFIG_SAVED_DRAM_TIMING_BASE=0x40000000 +CONFIG_DMA=y +CONFIG_DMA_CHANNELS=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x43000000 +CONFIG_FASTBOOT_BUF_SIZE=0x40000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_UUU_SUPPORT=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_MMC_BOOT_SUPPORT=y +CONFIG_FASTBOOT_MMC_USER_SUPPORT=y +CONFIG_FASTBOOT_CMD_OEM_PARTCONF=y +CONFIG_FASTBOOT_CMD_OEM_BOOTBUS=y +# CONFIG_SPL_DM_GPIO is not set +CONFIG_GPIO_HOG=y +CONFIG_DM_GPIO_LOOKUP_LABEL=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +# CONFIG_SPL_DM_I2C is not set +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_SYS_I2C_EARLY_INIT=y +CONFIG_SYS_MXC_I2C1_SPEED=50000 +CONFIG_SYS_MXC_I2C2_SPEED=50000 +CONFIG_SYS_MXC_I2C3_SPEED=50000 +CONFIG_SYS_MXC_I2C4_SPEED=50000 +CONFIG_SYS_I2C_SPEED=50000 +CONFIG_LED=y +CONFIG_LED_BLINK=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_PWRSEQ=y +CONFIG_MMC_BROKEN_CD=y +# CONFIG_SPL_DM_MMC is not set +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_FSL_USDHC=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_DM_ETH=y +CONFIG_PHY=y +CONFIG_PHY_IMX8MQ_USB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_POWER_LEGACY=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_POWER_I2C=y +CONFIG_DM_RESET=y +CONFIG_MXC_UART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_MXC_SPI=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y +CONFIG_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Purism" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_SDP_LOADADDR=0x40400000 +CONFIG_USB_FUNCTION_ACM=y diff --git a/doc/board/index.rst b/doc/board/index.rst index f90a9cad45..ffa5def303 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -27,6 +27,7 @@ Board-specific doc nokia/index nxp/index openpiton/index + purism/index qualcomm/index rockchip/index samsung/index diff --git a/doc/board/purism/index.rst b/doc/board/purism/index.rst new file mode 100644 index 0000000000..a9cdc312d4 --- /dev/null +++ b/doc/board/purism/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Purism SPC +========== + +.. toctree:: + :maxdepth: 2 + + librem5 diff --git a/doc/board/purism/librem5.rst b/doc/board/purism/librem5.rst new file mode 100644 index 0000000000..61d9793ae9 --- /dev/null +++ b/doc/board/purism/librem5.rst @@ -0,0 +1,60 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Librem5 +========== + +U-Boot for the Purism Librem5 phone + +Quick Start +----------- + +- Build the ARM Trusted firmware binary +- Get ddr and hdmi firmware +- Build U-Boot + +Get and Build the ARM Trusted firmware +-------------------------------------- + +Note: srctree is U-Boot source directory +Get ATF from: https://source.puri.sm/Librem5/arm-trusted-firmware +branch: librem5 + +.. code-block:: bash + + $ make PLAT=imx8mq CROSS_COMPILE=aarch64-linux-gnu- bl31 + $ cp build/imx8mq/release/bl31.bin $(builddir) + +Get the ddr and hdmi firmware +----------------------------- + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.15.bin + $ chmod +x firmware-imx-8.15.bin + $ ./firmware-imx-8.15.bin + $ cp firmware-imx-8.15/firmware/hdmi/cadence/signed_hdmi_imx8m.bin $(builddir) + $ cp firmware-imx-8.15/firmware/ddr/synopsys/lpddr4*.bin $(builddir) + +Build U-Boot +------------ + +.. code-block:: bash + + $ export CROSS_COMPILE=aarch64-linux-gnu- + $ make librem5_defconfig + $ make ARCH=arm + +Burn the flash.bin +------------------ + +Use uuu to burn flash.bin. Power on the phone while holding vol+ to get it +into uuu mode. + +.. code-block:: bash + + $ git clone https://source.puri.sm/Librem5/librem5-devkit-tools.git + $ cd librem5-devkit-tools + $ cp $(builddir)/flash.bin files/u-boot-librem5.imx + $ uuu uuu_scripts/u-boot_flash_librem5.lst + +Reboot the phone. diff --git a/include/configs/librem5.h b/include/configs/librem5.h new file mode 100644 index 0000000000..8d21311a52 --- /dev/null +++ b/include/configs/librem5.h @@ -0,0 +1,113 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2017 NXP + * Copyright 2018 Emcraft Systems + * Copyright 2019 Purism + * + */ + +#ifndef __LIBREM5_H +#define __LIBREM5_H + +/* #define DEBUG */ + +#include <version.h> +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> + +#define CONFIG_SPL_MAX_SIZE (148 * 1024) +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_STACK 0x187FF0 +#define CONFIG_SPL_BSS_START_ADDR 0x00180000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 /* 512 KB */ + +#define CONFIG_MALLOC_F_ADDR 0x182000 /* malloc f used before GD_FLG_FULL_MALLOC_INIT */ + +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE /* For RAW image gives a error info not panic */ + +#define CONFIG_POWER_BD71837 +#define CONFIG_POWER_BD71837_I2C_BUS 0 +#define CONFIG_POWER_BD71837_I2C_ADDR 0x4B + +#endif /* CONFIG_SPL_BUILD*/ + +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 + +#define CONFIG_USBD_HS + +#define CONSOLE_ON_UART1 + +#ifdef CONSOLE_ON_UART1 +#define CONFIG_MXC_UART_BASE UART1_BASE_ADDR +#define CONSOLE_UART_CLK 0 +#define CONSOLE "ttymxc0" +#elif defined(CONSOLE_ON_UART2) +#define CONFIG_MXC_UART_BASE UART2_BASE_ADDR +#define CONSOLE_UART_CLK 1 +#define CONSOLE "ttymxc1" +#elif defined(CONSOLE_ON_UART3) +#define CONFIG_MXC_UART_BASE UART3_BASE_ADDR +#define CONSOLE_UART_CLK 2 +#define CONSOLE "ttymxc2" +#elif defined(CONSOLE_ON_UART4) +#define CONFIG_MXC_UART_BASE UART4_BASE_ADDR +#define CONSOLE_UART_CLK 3 +#define CONSOLE "ttymxc3" +#else +#define CONFIG_MXC_UART_BASE UART1_BASE_ADDR +#define CONSOLE_UART_CLK 0 +#define CONSOLE "ttymxc0" +#endif + +#ifndef CONFIG_SPL_BUILD +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(USB, usb, 0) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> +#else +#define BOOTENV +#endif + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "scriptaddr=0x80000000\0" \ + "pxefile_addr_r=0x80100000\0" \ + "kernel_addr_r=0x80800000\0" \ + "fdt_addr_r=0x84800000\0" \ + "ramdisk_addr_r=0x85000000\0" \ + "console=" CONSOLE ",115200\0" \ + "bootargs=u_boot_version=" PLAIN_VERSION "\0" \ + "stdin=usbacm,serial\0" \ + "stdout=usbacm,serial\0" \ + "stderr=usbacm,serial\0" \ + BOOTENV + +/* Link Definitions */ + +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x80000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 +#define PHYS_SDRAM_SIZE 0xc0000000 /* 3GB LPDDR4 one Rank */ + +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#endif
On 06.05.22 14:44, Angus Ainslie wrote:
Initial commit of Librem5 u-boot and SPL
Signed-off-by: Angus Ainslie angus@akkea.ca Co-developed-by: Sebastian Krzyszkowiak sebastian.krzyszkowiak@puri.sm Signed-off-by: Sebastian Krzyszkowiak sebastian.krzyszkowiak@puri.sm
Hi Angus,
with "configs: get rid of build warnings due to SPL_USB_DWC3_GENERIC" most issues are solved, but a TI board is still broken.
A second issue is for the blob signed_dp_imx8m.bin, it should be done like for signed_hdmi.bin to avoid CI breakages.
Here the result of pipeline:
https://source.denx.de/u-boot/custodians/u-boot-imx/-/jobs/437965
Best regards, Stefano
All of the pre-requisite patches for this board are now upstream or in review.
Changes since v4:
Include imx8mq-u-boot.dtsi instead of adding a new copy
Changes since v3:
Dropped unused MMCROOT Rebased on u-boot-imx Needs this patch to supress SPL warnings https://lists.denx.de/pipermail/u-boot/2022-April/482369.html
Changes since v2:
Cleanup Kconfig symbols used in librem5.h Cleanup various checkpatch issues Drop some un-used functions
Changes since v1:
Merged patches into a monolithic board patch Using DM drivers for devices in u-boot Added USB storage support for uSD rootfs Dropped many SPL_BUILD guarded define's Fixed documentation index
arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi | 3 + arch/arm/dts/imx8mq-librem5-r4.dts | 35 + arch/arm/dts/imx8mq-librem5.dtsi | 1255 +++++++++++++++++ arch/arm/mach-imx/imx8m/Kconfig | 9 + board/purism/librem5/Kconfig | 15 + board/purism/librem5/MAINTAINERS | 8 + board/purism/librem5/Makefile | 13 + board/purism/librem5/imximage-8mq-lpddr4.cfg | 8 + board/purism/librem5/librem5.c | 425 ++++++ board/purism/librem5/librem5.h | 181 +++ board/purism/librem5/lpddr4_timing.c | 1324 ++++++++++++++++++ board/purism/librem5/lpddr4_timing_b0.c | 1191 ++++++++++++++++ board/purism/librem5/spl.c | 593 ++++++++ configs/librem5_defconfig | 142 ++ doc/board/index.rst | 1 + doc/board/purism/index.rst | 9 + doc/board/purism/librem5.rst | 60 + include/configs/librem5.h | 113 ++ 19 files changed, 5387 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mq-librem5-r4.dts create mode 100644 arch/arm/dts/imx8mq-librem5.dtsi create mode 100644 board/purism/librem5/Kconfig create mode 100644 board/purism/librem5/MAINTAINERS create mode 100644 board/purism/librem5/Makefile create mode 100644 board/purism/librem5/imximage-8mq-lpddr4.cfg create mode 100644 board/purism/librem5/librem5.c create mode 100644 board/purism/librem5/librem5.h create mode 100644 board/purism/librem5/lpddr4_timing.c create mode 100644 board/purism/librem5/lpddr4_timing_b0.c create mode 100644 board/purism/librem5/spl.c create mode 100644 configs/librem5_defconfig create mode 100644 doc/board/purism/index.rst create mode 100644 doc/board/purism/librem5.rst create mode 100644 include/configs/librem5.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 90f86e3fca..719fd7db8d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -937,7 +937,8 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mp-venice-gw74xx.dtb \ imx8mp-verdin.dtb \ imx8mq-pico-pi.dtb \
- imx8mq-kontron-pitx-imx8m.dtb
imx8mq-kontron-pitx-imx8m.dtb \
imx8mq-librem5-r4.dtb
dtb-$(CONFIG_ARCH_IMXRT) += imxrt1050-evk.dtb \ imxrt1020-evk.dtb
diff --git a/arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi b/arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi new file mode 100644 index 0000000000..8a68f53ace --- /dev/null +++ b/arch/arm/dts/imx8mq-librem5-r4-u-boot.dtsi @@ -0,0 +1,3 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT)
+#include "imx8mq-u-boot.dtsi" diff --git a/arch/arm/dts/imx8mq-librem5-r4.dts b/arch/arm/dts/imx8mq-librem5-r4.dts new file mode 100644 index 0000000000..cbfb49aa25 --- /dev/null +++ b/arch/arm/dts/imx8mq-librem5-r4.dts @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (C) 2020 Purism SPC kernel@puri.sm
+/dts-v1/;
+#include "imx8mq-librem5.dtsi"
- model = "Purism Librem 5r4";
- compatible = "purism,librem5r4", "purism,librem5", "fsl,imx8mq";
+&accel_gyro {
- mount-matrix = "1", "0", "0",
"0", "1", "0",
"0", "0", "-1";
+&bat {
- maxim,rsns-microohm = <1667>;
+&bq25895 {
- ti,battery-regulation-voltage = <4200000>; /* uV */
- ti,charge-current = <1500000>; /* uA */
- ti,termination-current = <144000>; /* uA */
+&led_backlight {
- led-max-microamp = <25000>;
+&proximity {
- proximity-near-level = <10>;
+}; diff --git a/arch/arm/dts/imx8mq-librem5.dtsi b/arch/arm/dts/imx8mq-librem5.dtsi new file mode 100644 index 0000000000..60d47c7149 --- /dev/null +++ b/arch/arm/dts/imx8mq-librem5.dtsi @@ -0,0 +1,1255 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright 2018-2020 Purism SPC
+/dts-v1/;
+#include "dt-bindings/input/input.h" +#include <dt-bindings/interrupt-controller/irq.h> +#include "dt-bindings/pwm/pwm.h" +#include "dt-bindings/usb/pd.h" +#include "imx8mq.dtsi"
- model = "Purism Librem 5";
- compatible = "purism,librem5", "fsl,imx8mq";
- backlight_dsi: backlight-dsi {
compatible = "led-backlight";
leds = <&led_backlight>;
- pmic_osc: clock-pmic {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <32768>;
clock-output-names = "pmic_osc";
- chosen {
stdout-path = &uart1;
- gpio-keys {
compatible = "gpio-keys";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_keys>;
vol-down {
label = "VOL_DOWN";
gpios = <&gpio1 17 GPIO_ACTIVE_LOW>;
linux,code = <KEY_VOLUMEDOWN>;
debounce-interval = <50>;
vol-up {
label = "VOL_UP";
gpios = <&gpio1 16 GPIO_ACTIVE_LOW>;
linux,code = <KEY_VOLUMEUP>;
- reg_aud_1v8: regulator-audio-1v8 {
compatible = "regulator-fixed";
pinctrl-0 = <&pinctrl_audiopwr>;
regulator-name = "AUDIO_PWR_EN";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
gpio = <&gpio1 4 GPIO_ACTIVE_HIGH>;
enable-active-high;
- reg_gnss: regulator-gnss {
pinctrl-0 = <&pinctrl_gnsspwr>;
regulator-name = "GNSS";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
gpio = <&gpio3 12 GPIO_ACTIVE_HIGH>;
enable-active-high;
- reg_hub: regulator-hub {
pinctrl-0 = <&pinctrl_hub_pwr>;
regulator-name = "HUB";
gpio = <&gpio1 14 GPIO_ACTIVE_HIGH>;
enable-active-high;
- reg_lcd_1v8: regulator-lcd-1v8 {
pinctrl-0 = <&pinctrl_dsien>;
regulator-name = "LCD_1V8";
vin-supply = <®_vdd_1v8>;
gpio = <&gpio1 5 GPIO_ACTIVE_HIGH>;
enable-active-high;
/* Otherwise i2c3 is not functional */
regulator-always-on;
- reg_lcd_3v4: regulator-lcd-3v4 {
regulator-name = "LCD_3V4";
pinctrl-0 = <&pinctrl_dsibiasen>;
vin-supply = <®_vsys_3v4>;
gpio = <&gpio1 20 GPIO_ACTIVE_HIGH>;
enable-active-high;
- reg_vdd_sen: regulator-vdd-sen {
regulator-name = "VDD_SEN";
- reg_vdd_1v8: regulator-vdd-1v8 {
regulator-name = "VDD_1V8";
vin-supply = <&buck7_reg>;
- reg_vdd_3v3: regulator-vdd-3v3 {
regulator-name = "VDD_3V3";
- reg_vsys_3v4: regulator-vsys-3v4 {
regulator-name = "VSYS_3V4";
regulator-min-microvolt = <3400000>;
regulator-max-microvolt = <3400000>;
- reg_wifi_3v3: regulator-wifi-3v3 {
pinctrl-0 = <&pinctrl_wifi_pwr>;
regulator-name = "3V3_WIFI";
gpio = <&gpio3 10 GPIO_ACTIVE_HIGH>;
enable-active-high;
vin-supply = <®_vdd_3v3>;
- sound {
compatible = "simple-audio-card";
pinctrl-0 = <&pinctrl_hp>;
simple-audio-card,name = "Librem 5";
simple-audio-card,format = "i2s";
simple-audio-card,widgets =
"Headphone", "Headphones",
"Microphone", "Headset Mic",
"Microphone", "Digital Mic",
"Speaker", "Speaker";
simple-audio-card,routing =
"Headphones", "HPOUTL",
"Headphones", "HPOUTR",
"Speaker", "SPKOUTL",
"Speaker", "SPKOUTR",
"Headset Mic", "MICBIAS",
"IN3R", "Headset Mic",
"DMICDAT", "Digital Mic";
simple-audio-card,hp-det-gpio = <&gpio3 9 GPIO_ACTIVE_HIGH>;
simple-audio-card,cpu {
sound-dai = <&sai2>;
simple-audio-card,codec {
sound-dai = <&codec>;
clocks = <&clk IMX8MQ_CLK_SAI2_ROOT>;
frame-master;
bitclock-master;
- sound-wwan {
simple-audio-card,name = "Modem";
sound-dai = <&sai6>;
frame-inversion;
sound-dai = <&bm818_codec>;
frame-master;
bitclock-master;
- usdhc2_pwrseq: pwrseq {
pinctrl-0 = <&pinctrl_bt>, <&pinctrl_wifi_disable>;
compatible = "mmc-pwrseq-simple";
reset-gpios = <&gpio3 25 GPIO_ACTIVE_HIGH>,
<&gpio4 29 GPIO_ACTIVE_HIGH>;
- bm818_codec: sound-wwan-codec {
compatible = "broadmobi,bm818", "option,gtm601";
#sound-dai-cells = <0>;
- vibrator {
compatible = "pwm-vibrator";
pwms = <&pwm1 0 1000000000 0>;
pwm-names = "enable";
vcc-supply = <®_vdd_3v3>;
+&A53_0 {
- cpu-supply = <&buck2_reg>;
+&A53_1 {
+&A53_2 {
+&A53_3 {
+&ddrc {
- operating-points-v2 = <&ddrc_opp_table>;
- ddrc_opp_table: opp-table {
compatible = "operating-points-v2";
opp-25M {
opp-hz = /bits/ 64 <25000000>;
opp-100M {
opp-hz = /bits/ 64 <100000000>;
opp-800M {
opp-hz = /bits/ 64 <800000000>;
+&dphy {
- status = "okay";
+&ecspi1 {
- pinctrl-names = "default";
- pinctrl-0 = <&pinctrl_ecspi1>;
- cs-gpios = <&gpio5 9 GPIO_ACTIVE_LOW>;
- #address-cells = <1>;
- #size-cells = <0>;
- status = "okay";
- nor_flash: flash@0 {
compatible = "jedec,spi-nor";
reg = <0>;
spi-max-frequency = <1000000>;
#size-cells = <1>;
partition@0 {
label = "protected0";
reg = <0x0 0x30000>;
read-only;
partition@30000 {
label = "protected1";
reg = <0x30000 0x10000>;
read-only;
partition@40000 {
label = "rw";
reg = <0x40000 0x1C0000>;
+&gpio1 {
- pinctrl-0 = <&pinctrl_pmic_5v>;
- pmic-5v-hog {
gpio-hog;
gpios = <1 GPIO_ACTIVE_HIGH>;
input;
lane-mapping = "pmic-5v";
+&iomuxc {
- pinctrl_audiopwr: audiopwrgrp {
fsl,pins = <
/* AUDIO_POWER_EN_3V3 */
MX8MQ_IOMUXC_GPIO1_IO04_GPIO1_IO4 0x83
- pinctrl_bl: blgrp {
fsl,pins = <
/* BACKLINGE_EN */
MX8MQ_IOMUXC_NAND_DQS_GPIO3_IO14 0x83
- pinctrl_bt: btgrp {
fsl,pins = <
/* BT_REG_ON */
MX8MQ_IOMUXC_SAI5_MCLK_GPIO3_IO25 0x83
- pinctrl_charger_in: chargeringrp {
fsl,pins = <
/* CHRG_INT */
MX8MQ_IOMUXC_NAND_CE2_B_GPIO3_IO3 0x80
/* CHG_STATUS_B */
MX8MQ_IOMUXC_NAND_ALE_GPIO3_IO0 0x80
- pinctrl_dsibiasen: dsibiasengrp {
fsl,pins = <
/* DSI_BIAS_EN */
MX8MQ_IOMUXC_ENET_TD1_GPIO1_IO20 0x83
- pinctrl_dsien: dsiengrp {
fsl,pins = <
/* DSI_EN_3V3 */
MX8MQ_IOMUXC_GPIO1_IO05_GPIO1_IO5 0x83
- pinctrl_dsirst: dsirstgrp {
fsl,pins = <
/* DSI_RST */
MX8MQ_IOMUXC_ENET_RD3_GPIO1_IO29 0x83
/* DSI_TE */
MX8MQ_IOMUXC_ENET_RD2_GPIO1_IO28 0x83
/* TP_RST */
MX8MQ_IOMUXC_ENET_RX_CTL_GPIO1_IO24 0x83
- pinctrl_ecspi1: ecspigrp {
fsl,pins = <
MX8MQ_IOMUXC_ECSPI1_MOSI_ECSPI1_MOSI 0x83
MX8MQ_IOMUXC_ECSPI1_MISO_ECSPI1_MISO 0x83
MX8MQ_IOMUXC_ECSPI1_SS0_GPIO5_IO9 0x19
MX8MQ_IOMUXC_ECSPI1_SCLK_ECSPI1_SCLK 0x83
- pinctrl_gauge: gaugegrp {
fsl,pins = <
/* BAT_LOW */
MX8MQ_IOMUXC_SAI5_RXC_GPIO3_IO20 0x80
- pinctrl_gnsspwr: gnsspwrgrp {
fsl,pins = <
/* GPS3V3_EN */
MX8MQ_IOMUXC_NAND_DATA06_GPIO3_IO12 0x83
- pinctrl_haptic: hapticgrp {
fsl,pins = <
/* MOTO */
MX8MQ_IOMUXC_SPDIF_EXT_CLK_PWM1_OUT 0x83
- pinctrl_hp: hpgrp {
fsl,pins = <
/* HEADPHONE_DET_1V8 */
MX8MQ_IOMUXC_NAND_DATA03_GPIO3_IO9 0x180
- pinctrl_hub_pwr: hubpwrgrp {
fsl,pins = <
/* HUB_PWR_3V3_EN */
MX8MQ_IOMUXC_GPIO1_IO14_GPIO1_IO14 0x83
- pinctrl_i2c1: i2c1grp {
fsl,pins = <
MX8MQ_IOMUXC_I2C1_SCL_I2C1_SCL 0x40000026
MX8MQ_IOMUXC_I2C1_SDA_I2C1_SDA 0x40000026
- pinctrl_i2c2: i2c2grp {
fsl,pins = <
MX8MQ_IOMUXC_I2C2_SCL_I2C2_SCL 0x40000026
MX8MQ_IOMUXC_I2C2_SDA_I2C2_SDA 0x40000026
- pinctrl_i2c3: i2c3grp {
fsl,pins = <
MX8MQ_IOMUXC_I2C3_SCL_I2C3_SCL 0x40000026
MX8MQ_IOMUXC_I2C3_SDA_I2C3_SDA 0x40000026
- pinctrl_i2c4: i2c4grp {
fsl,pins = <
MX8MQ_IOMUXC_I2C4_SCL_I2C4_SCL 0x40000026
MX8MQ_IOMUXC_I2C4_SDA_I2C4_SDA 0x40000026
- pinctrl_keys: keysgrp {
fsl,pins = <
/* VOL- */
MX8MQ_IOMUXC_ENET_MDIO_GPIO1_IO17 0x01C0
/* VOL+ */
MX8MQ_IOMUXC_ENET_MDC_GPIO1_IO16 0x01C0
- pinctrl_led_b: ledbgrp {
fsl,pins = <
/* LED_B */
MX8MQ_IOMUXC_GPIO1_IO13_PWM2_OUT 0x06
- pinctrl_led_g: ledggrp {
fsl,pins = <
/* LED_G */
MX8MQ_IOMUXC_SAI3_MCLK_PWM4_OUT 0x06
- pinctrl_led_r: ledrgrp {
fsl,pins = <
/* LED_R */
MX8MQ_IOMUXC_SPDIF_TX_PWM3_OUT 0x06
- pinctrl_mag: maggrp {
fsl,pins = <
/* INT_MAG */
MX8MQ_IOMUXC_SAI5_RXD1_GPIO3_IO22 0x80
- pinctrl_pmic: pmicgrp {
fsl,pins = <
/* PMIC_NINT */
MX8MQ_IOMUXC_GPIO1_IO07_GPIO1_IO7 0x80
- pinctrl_pmic_5v: pmic5vgrp {
fsl,pins = <
/* PMIC_5V */
MX8MQ_IOMUXC_GPIO1_IO01_GPIO1_IO1 0x80
- pinctrl_prox: proxgrp {
fsl,pins = <
/* INT_LIGHT */
MX8MQ_IOMUXC_NAND_DATA01_GPIO3_IO7 0x80
- pinctrl_rtc: rtcgrp {
fsl,pins = <
/* RTC_INT */
MX8MQ_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x80
- pinctrl_sai2: sai2grp {
fsl,pins = <
MX8MQ_IOMUXC_SAI2_TXD0_SAI2_TX_DATA0 0xd6
MX8MQ_IOMUXC_SAI2_TXFS_SAI2_TX_SYNC 0xd6
MX8MQ_IOMUXC_SAI2_MCLK_SAI2_MCLK 0xd6
MX8MQ_IOMUXC_SAI2_RXD0_SAI2_RX_DATA0 0xd6
MX8MQ_IOMUXC_SAI2_TXC_SAI2_TX_BCLK 0xd6
- pinctrl_sai6: sai6grp {
fsl,pins = <
MX8MQ_IOMUXC_SAI1_RXD5_SAI6_RX_DATA0 0xd6
MX8MQ_IOMUXC_SAI1_RXD6_SAI6_RX_SYNC 0xd6
MX8MQ_IOMUXC_SAI1_TXD4_SAI6_RX_BCLK 0xd6
MX8MQ_IOMUXC_SAI1_TXD5_SAI6_TX_DATA0 0xd6
- pinctrl_tcpc: tcpcgrp {
fsl,pins = <
/* TCPC_INT */
MX8MQ_IOMUXC_GPIO1_IO10_GPIO1_IO10 0x01C0
- pinctrl_touch: touchgrp {
fsl,pins = <
/* TP_INT */
MX8MQ_IOMUXC_ENET_RD1_GPIO1_IO27 0x80
- pinctrl_typec: typecgrp {
fsl,pins = <
/* TYPEC_MUX_EN */
MX8MQ_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x83
- pinctrl_uart1: uart1grp {
fsl,pins = <
MX8MQ_IOMUXC_UART1_RXD_UART1_DCE_RX 0x49
MX8MQ_IOMUXC_UART1_TXD_UART1_DCE_TX 0x49
- pinctrl_uart2: uart2grp {
fsl,pins = <
MX8MQ_IOMUXC_UART2_TXD_UART2_DCE_TX 0x49
MX8MQ_IOMUXC_UART2_RXD_UART2_DCE_RX 0x49
- pinctrl_uart3: uart3grp {
fsl,pins = <
MX8MQ_IOMUXC_UART3_RXD_UART3_DCE_RX 0x49
MX8MQ_IOMUXC_UART3_TXD_UART3_DCE_TX 0x49
- pinctrl_uart4: uart4grp {
fsl,pins = <
MX8MQ_IOMUXC_ECSPI2_SCLK_UART4_DCE_RX 0x49
MX8MQ_IOMUXC_ECSPI2_MOSI_UART4_DCE_TX 0x49
MX8MQ_IOMUXC_ECSPI2_MISO_UART4_DCE_CTS_B 0x49
MX8MQ_IOMUXC_ECSPI2_SS0_UART4_DCE_RTS_B 0x49
- pinctrl_usdhc1: usdhc1grp {
fsl,pins = <
MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x83
MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xc3
MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xc3
MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xc3
MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xc3
MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xc3
MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xc3
MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xc3
MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xc3
MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xc3
MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x83
MX8MQ_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0xc1
- pinctrl_usdhc1_100mhz: usdhc1grp100mhz {
fsl,pins = <
MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x8d
MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xcd
MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xcd
MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xcd
MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xcd
MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xcd
MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xcd
MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xcd
MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xcd
MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xcd
MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x8d
- pinctrl_usdhc1_200mhz: usdhc1grp200mhz {
fsl,pins = <
MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x9f
MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xdf
MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xdf
MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xdf
MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xdf
MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xdf
MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xdf
MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xdf
MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xdf
MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xdf
MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x9f
- pinctrl_usdhc2: usdhc2grp {
fsl,pins = <
MX8MQ_IOMUXC_SD2_CD_B_GPIO2_IO12 0x80
MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x83
MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xc3
MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xc3
MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xc3
MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xc3
MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xc3
MX8MQ_IOMUXC_SD2_RESET_B_USDHC2_RESET_B 0xc1
- pinctrl_usdhc2_100mhz: usdhc2grp100mhz {
fsl,pins = <
MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x8d
MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xcd
MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xcd
MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xcd
MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xcd
MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xcd
- pinctrl_usdhc2_200mhz: usdhc2grp200mhz {
fsl,pins = <
MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x9f
MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xcf
MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xcf
MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xcf
MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xcf
MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xcf
- pinctrl_wifi_disable: wifidisablegrp {
fsl,pins = <
/* WIFI_REG_ON */
MX8MQ_IOMUXC_SAI3_RXC_GPIO4_IO29 0x83
- pinctrl_wifi_pwr: wifipwrgrp {
fsl,pins = <
/* WIFI3V3_EN */
MX8MQ_IOMUXC_NAND_DATA04_GPIO3_IO10 0x83
- pinctrl_wdog: wdoggrp {
fsl,pins = <
/* nWDOG */
MX8MQ_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0x1f
+&i2c1 {
- clock-frequency = <387000>;
- pinctrl-0 = <&pinctrl_i2c1>;
- status = "okay";
- typec_pd: usb-pd@3f {
compatible = "ti,tps6598x";
reg = <0x3f>;
pinctrl-0 = <&pinctrl_typec>, <&pinctrl_tcpc>;
interrupt-parent = <&gpio1>;
interrupts = <10 IRQ_TYPE_LEVEL_LOW>;
interrupt-names = "irq";
connector {
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
usb_con_hs: endpoint {
remote-endpoint = <&typec_hs>;
port@1 {
reg = <1>;
usb_con_ss: endpoint {
remote-endpoint = <&typec_ss>;
- pmic: pmic@4b {
compatible = "rohm,bd71837";
reg = <0x4b>;
pinctrl-0 = <&pinctrl_pmic>;
clocks = <&pmic_osc>;
clock-names = "osc";
clock-output-names = "pmic_clk";
interrupts = <7 IRQ_TYPE_LEVEL_LOW>;
rohm,reset-snvs-powered;
regulators {
buck1_reg: BUCK1 {
regulator-name = "buck1";
regulator-min-microvolt = <700000>;
regulator-max-microvolt = <1300000>;
regulator-boot-on;
regulator-ramp-delay = <1250>;
rohm,dvs-run-voltage = <900000>;
rohm,dvs-idle-voltage = <850000>;
rohm,dvs-suspend-voltage = <800000>;
buck2_reg: BUCK2 {
regulator-name = "buck2";
regulator-boot-on;
rohm,dvs-run-voltage = <1000000>;
rohm,dvs-idle-voltage = <900000>;
buck3_reg: BUCK3 {
regulator-name = "buck3";
regulator-boot-on;
buck4_reg: BUCK4 {
regulator-name = "buck4";
buck5_reg: BUCK5 {
regulator-name = "buck5";
regulator-max-microvolt = <1350000>;
regulator-boot-on;
buck6_reg: BUCK6 {
regulator-name = "buck6";
regulator-min-microvolt = <3000000>;
regulator-boot-on;
buck7_reg: BUCK7 {
regulator-name = "buck7";
regulator-min-microvolt = <1605000>;
regulator-max-microvolt = <1995000>;
regulator-boot-on;
buck8_reg: BUCK8 {
regulator-name = "buck8";
regulator-min-microvolt = <800000>;
regulator-max-microvolt = <1400000>;
regulator-boot-on;
ldo1_reg: LDO1 {
regulator-name = "ldo1";
regulator-boot-on;
/* leave on for snvs power button */
ldo2_reg: LDO2 {
regulator-name = "ldo2";
regulator-min-microvolt = <900000>;
regulator-max-microvolt = <900000>;
regulator-boot-on;
ldo3_reg: LDO3 {
regulator-name = "ldo3";
regulator-boot-on;
ldo4_reg: LDO4 {
regulator-name = "ldo4";
regulator-boot-on;
ldo5_reg: LDO5 {
/* VDD_PHY_0V9 - MIPI and HDMI domains */
regulator-name = "ldo5";
ldo6_reg: LDO6 {
/* VDD_PHY_0V9 - MIPI, HDMI and USB domains */
regulator-name = "ldo6";
regulator-boot-on;
ldo7_reg: LDO7 {
/* VDD_PHY_3V3 - USB domain */
regulator-name = "ldo7";
regulator-boot-on;
- rtc@68 {
compatible = "microcrystal,rv4162";
reg = <0x68>;
pinctrl-0 = <&pinctrl_rtc>;
interrupts = <9 IRQ_TYPE_LEVEL_LOW>;
+&i2c2 {
- pinctrl-0 = <&pinctrl_i2c2>;
- status = "okay";
- magnetometer@1e {
compatible = "st,lsm9ds1-magn";
reg = <0x1e>;
pinctrl-0 = <&pinctrl_mag>;
interrupt-parent = <&gpio3>;
interrupts = <22 IRQ_TYPE_LEVEL_HIGH>;
vdd-supply = <®_vdd_sen>;
vddio-supply = <®_vdd_1v8>;
- regulator@3e {
compatible = "tps65132";
reg = <0x3e>;
reg_lcd_avdd: outp {
regulator-name = "LCD_AVDD";
vin-supply = <®_lcd_3v4>;
reg_lcd_avee: outn {
regulator-name = "LCD_AVEE";
- proximity: prox@60 {
compatible = "vishay,vcnl4040";
reg = <0x60>;
pinctrl-0 = <&pinctrl_prox>;
- accel_gyro: accel-gyro@6a {
compatible = "st,lsm9ds1-imu";
reg = <0x6a>;
+&i2c3 {
- pinctrl-0 = <&pinctrl_i2c3>;
- status = "okay";
- codec: audio-codec@1a {
compatible = "wlf,wm8962";
reg = <0x1a>;
assigned-clocks = <&clk IMX8MQ_CLK_SAI2>;
assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1_OUT>;
assigned-clock-rates = <24576000>;
mic-cfg = <0x200>;
DCVDD-supply = <®_aud_1v8>;
DBVDD-supply = <®_aud_1v8>;
AVDD-supply = <®_aud_1v8>;
CPVDD-supply = <®_aud_1v8>;
MICVDD-supply = <®_aud_1v8>;
PLLVDD-supply = <®_aud_1v8>;
SPKVDD1-supply = <®_vsys_3v4>;
SPKVDD2-supply = <®_vsys_3v4>;
gpio-cfg = <
0x0000 /* n/c */
0x0001 /* gpio2, 1: default */
0x0013 /* gpio3, 2: dmicclk */
0x0000 /* n/c, 3: default */
0x8014 /* gpio5, 4: dmic_dat */
0x0000 /* gpio6, 5: default */
- backlight@36 {
compatible = "ti,lm36922";
reg = <0x36>;
pinctrl-0 = <&pinctrl_bl>;
#size-cells = <0>;
enable-gpios = <&gpio3 14 GPIO_ACTIVE_HIGH>;
vled-supply = <®_vsys_3v4>;
ti,ovp-microvolt = <25000000>;
led_backlight: led@0 {
reg = <0>;
label = ":backlight";
linux,default-trigger = "backlight";
led-max-microamp = <20000>;
- touchscreen@38 {
compatible = "edt,edt-ft5506";
reg = <0x38>;
pinctrl-0 = <&pinctrl_touch>;
interrupts = <27 IRQ_TYPE_EDGE_FALLING>;
touchscreen-size-x = <720>;
touchscreen-size-y = <1440>;
vcc-supply = <®_lcd_1v8>;
+&i2c4 {
- pinctrl-0 = <&pinctrl_i2c4>;
- status = "okay";
- bat: fuel-gauge@36 {
compatible = "maxim,max17055";
reg = <0x36>;
interrupts = <20 IRQ_TYPE_LEVEL_LOW>;
pinctrl-0 = <&pinctrl_gauge>;
maxim,over-heat-temp = <700>;
maxim,over-volt = <4500>;
maxim,rsns-microohm = <5000>;
- bq25895: charger@6a {
compatible = "ti,bq25895", "ti,bq25890";
reg = <0x6a>;
pinctrl-0 = <&pinctrl_charger_in>;
interrupts = <3 IRQ_TYPE_EDGE_FALLING>;
phys = <&usb3_phy0>;
ti,precharge-current = <130000>; /* uA */
ti,minimum-sys-voltage = <3700000>; /* uV */
ti,boost-voltage = <5000000>; /* uV */
ti,boost-max-current = <500000>; /* uA */
ti,use-vinmin-threshold = <1>; /* enable VINDPM */
ti,vinmin-threshold = <3900000>; /* uV */
monitored-battery = <&bat>;
power-supplies = <&typec_pd>;
+&lcdif {
- status = "okay";
+&mipi_dsi {
- status = "okay";
- lcd_panel: panel@0 {
compatible = "mantix,mlaf057we51-x";
reg = <0>;
pinctrl-0 = <&pinctrl_dsirst>;
avdd-supply = <®_lcd_avdd>;
avee-supply = <®_lcd_avee>;
vddi-supply = <®_lcd_1v8>;
backlight = <&backlight_dsi>;
reset-gpios = <&gpio1 29 GPIO_ACTIVE_LOW>;
mantix,tp-rstn-gpios = <&gpio1 24 GPIO_ACTIVE_LOW>;
port {
panel_in: endpoint {
remote-endpoint = <&mipi_dsi_out>;
- ports {
port@1 {
reg = <1>;
mipi_dsi_out: endpoint {
remote-endpoint = <&panel_in>;
+&pgc_gpu {
- power-supply = <&buck3_reg>;
+&pgc_mipi {
- power-supply = <&ldo5_reg>;
+&pgc_vpu {
- power-supply = <&buck4_reg>;
+&pwm1 {
- pinctrl-0 = <&pinctrl_haptic>;
- status = "okay";
+&pwm2 {
- pinctrl-0 = <&pinctrl_led_b>;
- status = "okay";
+&pwm3 {
- pinctrl-0 = <&pinctrl_led_r>;
- status = "okay";
+&pwm4 {
- pinctrl-0 = <&pinctrl_led_g>;
- status = "okay";
+&sai2 {
- pinctrl-0 = <&pinctrl_sai2>;
- assigned-clocks = <&clk IMX8MQ_CLK_SAI2>;
- assigned-clock-parents = <&clk IMX8MQ_AUDIO_PLL1_OUT>;
- assigned-clock-rates = <24576000>;
- status = "okay";
+&sai6 {
- pinctrl-0 = <&pinctrl_sai6>;
- assigned-clocks = <&clk IMX8MQ_CLK_SAI6>;
- fsl,sai-synchronous-rx;
- status = "okay";
+&snvs_pwrkey {
- status = "okay";
+&snvs_rtc {
- status = "disabled";
+&uart1 { /* console */
- pinctrl-0 = <&pinctrl_uart1>;
- status = "okay";
+&uart2 { /* TPS - GPS - DEBUG */
- pinctrl-0 = <&pinctrl_uart2>;
- status = "okay";
- gnss {
compatible = "globaltop,pa6h";
vcc-supply = <®_gnss>;
current-speed = <9600>;
+&uart3 { /* SMC */
- pinctrl-0 = <&pinctrl_uart3>;
- status = "okay";
+&uart4 { /* BT */
- pinctrl-0 = <&pinctrl_uart4>;
- uart-has-rtscts;
- status = "okay";
+&usb3_phy0 {
- status = "okay";
+&usb3_phy1 {
- vbus-supply = <®_hub>;
- status = "okay";
+&usb_dwc3_0 {
- dr_mode = "otg";
- snps,dis_u3_susphy_quirk;
- status = "okay";
- port@0 {
reg = <0>;
typec_hs: endpoint {
remote-endpoint = <&usb_con_hs>;
- port@1 {
reg = <1>;
typec_ss: endpoint {
remote-endpoint = <&usb_con_ss>;
+&usb_dwc3_1 {
- dr_mode = "host";
- status = "okay";
- /* Microchip USB2642 */
- hub@1 {
compatible = "usb424,2640";
reg = <1>;
#size-cells = <0>;
mass-storage@1 {
compatible = "usb424,4041";
reg = <1>;
+&usdhc1 {
- assigned-clocks = <&clk IMX8MQ_CLK_USDHC1>;
- assigned-clock-rates = <400000000>;
- pinctrl-names = "default", "state_100mhz", "state_200mhz";
- pinctrl-0 = <&pinctrl_usdhc1>;
- pinctrl-1 = <&pinctrl_usdhc1_100mhz>;
- pinctrl-2 = <&pinctrl_usdhc1_200mhz>;
- bus-width = <8>;
- vmmc-supply = <®_vdd_3v3>;
- power-supply = <®_vdd_1v8>;
- non-removable;
- status = "okay";
+&usdhc2 {
- assigned-clocks = <&clk IMX8MQ_CLK_USDHC2>;
- assigned-clock-rates = <200000000>;
- pinctrl-0 = <&pinctrl_usdhc2>;
- pinctrl-1 = <&pinctrl_usdhc2_100mhz>;
- pinctrl-2 = <&pinctrl_usdhc2_200mhz>;
- bus-width = <4>;
- vmmc-supply = <®_wifi_3v3>;
- mmc-pwrseq = <&usdhc2_pwrseq>;
- post-power-on-delay-ms = <1000>;
- cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>;
- max-frequency = <50000000>;
- disable-wp;
- cap-sdio-irq;
- keep-power-in-suspend;
- wakeup-source;
- status = "okay";
+&wdog1 {
- pinctrl-0 = <&pinctrl_wdog>;
- fsl,ext-reset-output;
- status = "okay";
+}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 24299ae037..11a2abf00c 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -257,6 +257,14 @@ config TARGET_IMX8MP_RSB3720A1_6G select IMX8MP select SUPPORT_SPL select IMX8M_LPDDR4
+config TARGET_LIBREM5
bool "Purism Librem5 Phone"
select BINMAN
select IMX8MQ
select SUPPORT_SPL
select IMX8M_LPDDR4
endchoice
source "board/advantech/imx8mp_rsb3720a1/Kconfig"
@@ -277,6 +285,7 @@ source "board/kontron/sl-mx8mm/Kconfig" source "board/menlo/mx8menlo/Kconfig" source "board/phytec/phycore_imx8mm/Kconfig" source "board/phytec/phycore_imx8mp/Kconfig" +source "board/purism/librem5/Kconfig" source "board/ronetix/imx8mq-cm/Kconfig" source "board/technexion/pico-imx8mq/Kconfig" source "board/variscite/imx8mn_var_som/Kconfig" diff --git a/board/purism/librem5/Kconfig b/board/purism/librem5/Kconfig new file mode 100644 index 0000000000..cf0f303683 --- /dev/null +++ b/board/purism/librem5/Kconfig @@ -0,0 +1,15 @@ +if TARGET_LIBREM5
+config SYS_BOARD
- default "librem5"
+config SYS_VENDOR
- default "purism"
+config SYS_CONFIG_NAME
- default "librem5"
+config IMX_CONFIG
- default "board/purism/librem5/imximage-8mq-lpddr4.cfg"
+endif diff --git a/board/purism/librem5/MAINTAINERS b/board/purism/librem5/MAINTAINERS new file mode 100644 index 0000000000..09e7f20e33 --- /dev/null +++ b/board/purism/librem5/MAINTAINERS @@ -0,0 +1,8 @@ +PURISM LIBREM5 PHONE +M: Angus Ainslie angus@akkea.ca +R: kernel@puri.sm +S: Supported +F: arch/arm/dts/imx8mq-librem5* +F: board/purism/librem5/ +F: configs/librem5_defconfig +F: include/configs/librem5.h diff --git a/board/purism/librem5/Makefile b/board/purism/librem5/Makefile new file mode 100644 index 0000000000..47f25f047b --- /dev/null +++ b/board/purism/librem5/Makefile @@ -0,0 +1,13 @@ +# +# Copyright 2017 NXP +# Copyright 2019 Purism +# +# SPDX-License-Identifier: GPL-2.0+ +#
+obj-y += librem5.o
+ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o lpddr4_timing_b0.o +endif diff --git a/board/purism/librem5/imximage-8mq-lpddr4.cfg b/board/purism/librem5/imximage-8mq-lpddr4.cfg new file mode 100644 index 0000000000..648471028f --- /dev/null +++ b/board/purism/librem5/imximage-8mq-lpddr4.cfg @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
- Copyright 2021 NXP
+BOOT_FROM sd +SIGNED_HDMI signed_dp_imx8m.bin +LOADER u-boot-spl-ddr.bin 0x7E1000 diff --git a/board/purism/librem5/librem5.c b/board/purism/librem5/librem5.c new file mode 100644 index 0000000000..caa02655fc --- /dev/null +++ b/board/purism/librem5/librem5.c @@ -0,0 +1,425 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright 2018 NXP
- Copyright 2021 Purism
+#include <common.h> +#include <malloc.h> +#include <errno.h> +#include <asm/io.h> +#include <miiphy.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm-generic/gpio.h> +#include <asm/arch/sys_proto.h> +#include <fsl_esdhc.h> +#include <mmc.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <asm/arch/clock.h> +#include <asm/mach-imx/video.h> +#include <fuse.h> +#include <i2c.h> +#include <spl.h> +#include <usb.h> +#include <dwc3-uboot.h> +#include <linux/delay.h> +#include <linux/bitfield.h> +#include <power/regulator.h> +#include <usb/xhci.h> +#include "librem5.h"
+int board_early_init_f(void) +{
+#if IS_ENABLED(CONFIG_LOAD_ENV_FROM_MMC_BOOT_PARTITION) +uint board_mmc_get_env_part(struct mmc *mmc) +{
- uint part = (mmc->part_config >> 3) & PART_ACCESS_MASK;
- if (part == 7)
part = 0;
- return part;
+} +#endif
+int tps65982_wait_for_app(int timeout, int timeout_step) +{
- int ret;
- char response[6];
- struct udevice *udev, *bus;
- log_debug("%s: starting\n", __func__);
- /* Set the i2c bus */
- ret = uclass_get_device_by_seq(UCLASS_I2C, 0, &bus);
- if (ret) {
log_err("%s: No bus %d\n", __func__, 0);
return 1;
- ret = i2c_get_chip(bus, 0x3f, 1, &udev);
- if (ret) {
log_err("%s: setting chip offset failed %d\n", __func__, ret);
return 1;
- while (timeout > 0) {
ret = dm_i2c_read(udev, 0x03, (u8 *)response, 5);
log_debug("tps65982 mode %s\n", response);
if (response[1] == 'A')
mdelay(timeout_step);
timeout -= timeout_step;
log_debug("tps65982 waited %d ms %c\n", timeout_step, response[1]);
- return 1;
+int tps65982_clear_dead_battery(void) +{
- int ret;
- char cmd[5] = "\04DBfg";
- if (ret) {
return 1;
- if (ret) {
return 1;
- /* clearing the dead battery flag when not in dead battery condition
* is a no-op, so there's no need to check if it's in effect
- ret = dm_i2c_write(udev, 0x08, cmd, 5);
- if (ret) {
log_err("%s: writing 4CC command failed %d", __func__, ret);
return 1;
+#define TPS_POWER_STATUS_PWROPMODE(x) FIELD_GET(GENMASK(3, 2), x)
+#define TPS_PDO_CONTRACT_TYPE(x) FIELD_GET(GENMASK(31, 30), x) +#define TPS_PDO_CONTRACT_FIXED 0 +#define TPS_PDO_CONTRACT_BATTERY 1 +#define TPS_PDO_CONTRACT_VARIABLE 2
+#define TPS_TYPEC_PWR_MODE_USB 0 +#define TPS_TYPEC_PWR_MODE_1_5A 1 +#define TPS_TYPEC_PWR_MODE_3_0A 2 +#define TPS_TYPEC_PWR_MODE_PD 3
+#define TPS_PDO_FIXED_CONTRACT_MAX_CURRENT(x) (FIELD_GET(GENMASK(9, 0), x) * 10) +#define TPS_PDO_VAR_CONTRACT_MAX_CURRENT(x) (FIELD_GET(GENMASK(9, 0), x) * 10) +#define TPS_PDO_BAT_CONTRACT_MAX_VOLTAGE(x) (FIELD_GET(GENMASK(29, 20), x) * 50) +#define TPS_PDO_BAT_CONTRACT_MAX_POWER(x) (FIELD_GET(GENMASK(9, 0), x) * 250)
+int tps65982_get_max_current(void) +{
- int ret;
- u8 buf[7];
- u8 pwr_status;
- u32 contract;
- int type, mode;
- if (ret) {
log_debug("%s: No bus %d\n", __func__, 0);
return -1;
- if (ret) {
log_debug("%s: setting chip offset failed %d\n", __func__, ret);
return -1;
- ret = dm_i2c_read(udev, 0x3f, buf, 3);
- if (ret) {
log_debug("%s: reading pwr_status failed %d\n", __func__, ret);
return -1;
- pwr_status = buf[1];
- if (!(pwr_status & 1))
- mode = TPS_POWER_STATUS_PWROPMODE(pwr_status);
- switch (mode) {
- case TPS_TYPEC_PWR_MODE_1_5A:
return 1500;
- case TPS_TYPEC_PWR_MODE_3_0A:
return 3000;
- case TPS_TYPEC_PWR_MODE_PD:
ret = dm_i2c_read(udev, 0x34, buf, 7);
if (ret) {
log_debug("%s: reading active contract failed %d\n", __func__, ret);
return -1;
contract = buf[1] + (buf[2] << 8) + (buf[3] << 16) + (buf[4] << 24);
type = TPS_PDO_CONTRACT_TYPE(contract);
switch (type) {
case TPS_PDO_CONTRACT_FIXED:
return TPS_PDO_FIXED_CONTRACT_MAX_CURRENT(contract);
case TPS_PDO_CONTRACT_BATTERY:
return 1000 * TPS_PDO_BAT_CONTRACT_MAX_POWER(contract)
/ TPS_PDO_BAT_CONTRACT_MAX_VOLTAGE(contract);
case TPS_PDO_CONTRACT_VARIABLE:
return TPS_PDO_VAR_CONTRACT_MAX_CURRENT(contract);
default:
log_debug("Unknown contract type: %d\n", type);
return -1;
- case TPS_TYPEC_PWR_MODE_USB:
return 500;
- default:
log_debug("Unknown power mode: %d\n", mode);
return -1;
+int init_tps65982(void) +{
- if (tps65982_wait_for_app(500, 100)) {
log_err("tps65982 APP boot failed\n");
return 1;
- log_info("tps65982 boot successful\n");
+int bq25895_set_iinlim(int current) +{
- u8 val, iinlim;
- int ret;
- ret = uclass_get_device_by_seq(UCLASS_I2C, 3, &bus);
- if (ret) {
log_err("%s: No bus 3\n", __func__);
return ret;
- ret = i2c_get_chip(bus, 0x6a, 1, &udev);
- if (ret) {
return ret;
- if (current > 3250)
current = 3250;
- if (current < 100)
current = 100;
- val = dm_i2c_reg_read(udev, 0x00);
- iinlim = ((current - 100) / 50) & 0x3f;
- val = (val & 0xc0) | iinlim;
- dm_i2c_reg_write(udev, 0x00, val);
- log_debug("REG00 0x%x\n", val);
+bool bq25895_battery_present(void) +{
- u8 val;
- int ret;
- if (ret) {
return ret;
- if (ret) {
return ret;
- /* note that this may return false negatives when there's
* no external power applied and the battery voltage is below
* Vsys. this isn't a problem when used for clearing the dead
* battery flag though, since it's certain that there's an external
* power applied in this case
- val = dm_i2c_reg_read(udev, 0x0e) & 0x7f;
- if (val == 0x00 || val == 0x7f)
return false;
- return true;
- set some safe defaults for the battery charger
+int init_charger_bq25895(void) +{
- u8 val;
- int iinlim, ret;
- if (ret) {
log_debug("%s: No bus 3\n", __func__);
return ret;
- if (ret) {
return ret;
- val = dm_i2c_reg_read(udev, 0x0b);
- log_debug("REG0B 0x%x\n", val);
- log_debug("VBUS_STAT 0x%x\n", val >> 5);
- switch (val >> 5) {
- case 0:
log_debug("VBUS not detected\n");
break;
- case 1:
log_debug("USB SDP IINLIM 500mA\n");
break;
- case 2:
log_debug("USB CDP IINLIM 1500mA\n");
break;
- case 3:
log_debug("USB DCP IINLIM 3500mA\n");
break;
- case 4:
log_debug("MAXCHARGE IINLIM 1500mA\n");
break;
- case 5:
log_debug("Unknown IINLIM 500mA\n");
break;
- case 6:
log_debug("DIVIDER IINLIM > 1000mA\n");
break;
- case 7:
log_debug("OTG\n");
break;
- log_debug("CHRG_STAT 0x%x\n", (val >> 3) & 0x3);
- log_debug("PG_STAT 0x%x\n", (val >> 2) & 1);
- log_debug("SDP_STAT 0x%x\n", (val >> 1) & 1);
- log_debug("VSYS_STAT 0x%x\n", val & 1);
- iinlim = 100 + (val & 0x3f) * 50;
- log_debug("IINLIM %d mA\n", iinlim);
- log_debug("EN_HIZ 0x%x\n", (val >> 7) & 1);
- log_debug("EN_ILIM 0x%x\n", (val >> 6) & 1);
- /* set 1.6A charge limit */
- dm_i2c_reg_write(udev, 0x04, 0x19);
- /* re-enable charger */
- val = dm_i2c_reg_read(udev, 0x03);
- val = val | 0x10;
- dm_i2c_reg_write(udev, 0x03, val);
+int board_init(void) +{
- struct udevice *dev;
- int tps_ret;
- if (IS_ENABLED(CONFIG_USB_DWC3) || IS_ENABLED(CONFIG_USB_XHCI_IMX8M)) {
log_debug("%s: initializing USB clk\n", __func__);
/* init_usb_clk won't enable the second clock if it's a USB boot */
if (is_usb_boot()) {
clock_enable(CCGR_USB_CTRL2, 1);
clock_enable(CCGR_USB_PHY2, 1);
printf("Enabling regulator-hub\n");
if (!regulator_get_by_devname("regulator-hub", &dev)) {
if (regulator_set_enable(dev, true))
pr_err("Failed to enable regulator-hub\n");
- tps_ret = init_tps65982();
- init_charger_bq25895();
- if (!tps_ret) {
int current = tps65982_get_max_current();
if (current > 500)
bq25895_set_iinlim(current);
if (bq25895_battery_present())
tps65982_clear_dead_battery();
+int board_late_init(void) +{
- if (IS_ENABLED(CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG)) {
u32 rev;
char rev_str[3];
env_set("board_name", "librem5");
if (fuse_read(9, 0, &rev)) {
env_set("board_rev", BOARD_REV_ERROR);
} else if (rev == 0) {
env_set("board_rev", BOARD_REV_UNKNOWN);
} else if (rev > 0) {
sprintf(rev_str, "%u", rev);
env_set("board_rev", rev_str);
printf("Board name: %s\n", env_get("board_name"));
printf("Board rev: %s\n", env_get("board_rev"));
- if (is_usb_boot()) {
puts("USB Boot\n");
env_set("bootcmd", "fastboot 0");
+} diff --git a/board/purism/librem5/librem5.h b/board/purism/librem5/librem5.h new file mode 100644 index 0000000000..0d24edea9b --- /dev/null +++ b/board/purism/librem5/librem5.h @@ -0,0 +1,181 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef __LIBREM5_H__ +#define __LIBREM5_H__
+#define CAMERA_EN IMX_GPIO_NR(1, 0) +#define SD_EN IMX_GPIO_NR(1, 3) +#define AUDIO_EN IMX_GPIO_NR(1, 4) +#define DSI_EN IMX_GPIO_NR(1, 5) +#define SMC_EN IMX_GPIO_NR(1, 6) +#define TYPEC_MUX_EN IMX_GPIO_NR(1, 11) +#define HUB_NRESET IMX_GPIO_NR(1, 12) +#define HUB_EN IMX_GPIO_NR(1, 14) +#define VOL_UP IMX_GPIO_NR(1, 16) +#define VOL_DOWN IMX_GPIO_NR(1, 17) +#define DSI_BIAS_EN IMX_GPIO_NR(1, 20) +#define FLASH_EN IMX_GPIO_NR(1, 23) +#define WWAN_NRESET IMX_GPIO_NR(3, 1) +#define CHG_EN IMX_GPIO_NR(3, 2) +#define CHG_OTG_OUT_EN IMX_GPIO_NR(3, 4) +#define WIFI_EN IMX_GPIO_NR(3, 10) +#define GPS_EN IMX_GPIO_NR(3, 12) +#define BL_EN IMX_GPIO_NR(3, 14) +#define WWAN_EN IMX_GPIO_NR(3, 18) +#define NFC_EN IMX_GPIO_NR(4, 28) +#define LED_G IMX_GPIO_NR(5, 2) +#define LED_R IMX_GPIO_NR(5, 3) +#define LED_B IMX_GPIO_NR(1, 13) +#define MOTO IMX_GPIO_NR(5, 5) +#define SPI1_SCLK IMX_GPIO_NR(5, 6) +#define SPI1_MOSI IMX_GPIO_NR(5, 7) +#define SPI1_MISO IMX_GPIO_NR(5, 8) +#define SPI1_SS0 IMX_GPIO_NR(5, 9)
+#define UART1_TX IMX_GPIO_NR(5, 23) +#define UART1_RX IMX_GPIO_NR(5, 22) +#define UART2_TX IMX_GPIO_NR(5, 25) +#define UART2_RX IMX_GPIO_NR(5, 24) +#define UART3_TX IMX_GPIO_NR(5, 27) +#define UART3_RX IMX_GPIO_NR(5, 26) +#define UART4_TX IMX_GPIO_NR(5, 11) +#define UART4_RX IMX_GPIO_NR(5, 10)
+#define TPS_RESET IMX_GPIO_NR(3, 24)
+#define PURISM_VID 0x316d +#define PURISM_PID 0x4c05
+#define BOARD_REV_ERROR "unknown" +#define BOARD_REV_BIRCH "1" +#define BOARD_REV_CHESTNUT "2" +#define BOARD_REV_DOGWOOD "3" +#define BOARD_REV_EVERGREEN "4" +/* Could be ASPEN, BIRCH or CHESTNUT. assume CHESTNUT */ +#define BOARD_REV_UNKNOWN BOARD_REV_CHESTNUT
+#ifdef CONFIG_SPL_BUILD +static const iomux_v3_cfg_t configure_pads[] = {
- IMX8MQ_PAD_GPIO1_IO00__GPIO1_IO0 | MUX_PAD_CTRL(PAD_CTL_DSE6),
- IMX8MQ_PAD_GPIO1_IO03__GPIO1_IO3 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION,
- IMX8MQ_PAD_GPIO1_IO04__GPIO1_IO4 | MUX_PAD_CTRL(PAD_CTL_DSE6),
- IMX8MQ_PAD_GPIO1_IO05__GPIO1_IO5 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION,
- IMX8MQ_PAD_GPIO1_IO06__GPIO1_IO6 | MUX_PAD_CTRL(PAD_CTL_DSE6),
- IMX8MQ_PAD_GPIO1_IO11__GPIO1_IO11 | MUX_PAD_CTRL(PAD_CTL_DSE6),
- IMX8MQ_PAD_GPIO1_IO12__GPIO1_IO12 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION,
- IMX8MQ_PAD_GPIO1_IO13__GPIO1_IO13 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION,
- IMX8MQ_PAD_GPIO1_IO14__GPIO1_IO14 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION,
- IMX8MQ_PAD_ENET_MDC__GPIO1_IO16 | MUX_PAD_CTRL(PAD_CTL_PUE),
- IMX8MQ_PAD_ENET_MDIO__GPIO1_IO17 | MUX_PAD_CTRL(PAD_CTL_PUE),
- IMX8MQ_PAD_ENET_TD1__GPIO1_IO20 | MUX_PAD_CTRL(PAD_CTL_DSE6),
- IMX8MQ_PAD_ENET_TXC__GPIO1_IO23 | MUX_PAD_CTRL(PAD_CTL_DSE6),
- IMX8MQ_PAD_NAND_CE0_B__GPIO3_IO1 | MUX_PAD_CTRL(PAD_CTL_DSE6),
- IMX8MQ_PAD_NAND_CE1_B__GPIO3_IO2 | MUX_PAD_CTRL(PAD_CTL_DSE6),
- IMX8MQ_PAD_NAND_CE3_B__GPIO3_IO4 | MUX_PAD_CTRL(PAD_CTL_DSE6),
- IMX8MQ_PAD_NAND_DATA04__GPIO3_IO10 | MUX_PAD_CTRL(PAD_CTL_DSE6),
- IMX8MQ_PAD_NAND_DATA06__GPIO3_IO12 | MUX_PAD_CTRL(PAD_CTL_DSE6),
- IMX8MQ_PAD_NAND_DQS__GPIO3_IO14 | MUX_PAD_CTRL(PAD_CTL_DSE6),
- IMX8MQ_PAD_NAND_WP_B__GPIO3_IO18 | MUX_PAD_CTRL(PAD_CTL_DSE6),
- IMX8MQ_PAD_SAI3_RXFS__GPIO4_IO28 | MUX_PAD_CTRL(PAD_CTL_DSE6),
- IMX8MQ_PAD_SAI3_MCLK__GPIO5_IO2 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION,
- IMX8MQ_PAD_SPDIF_TX__GPIO5_IO3 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION,
- IMX8MQ_PAD_SAI5_RXD3__GPIO3_IO24 | MUX_PAD_CTRL(PAD_CTL_DSE6) | MUX_MODE_SION,
+static inline void init_pinmux(void) +{
- imx_iomux_v3_setup_multiple_pads(configure_pads, ARRAY_SIZE(configure_pads));
- gpio_request(LED_R, "LED_R");
- gpio_request(LED_G, "LED_G");
- gpio_request(LED_B, "LED_B");
- gpio_request(VOL_UP, "VOL_UP");
- gpio_request(VOL_DOWN, "VOL_DOWN");
- gpio_request(NFC_EN, "NFC_EN");
- gpio_request(CHG_EN, "CHG_EN");
- gpio_request(CHG_OTG_OUT_EN, "CHG_OTG_OUT_EN");
- gpio_request(TYPEC_MUX_EN, "TYPEC_MUX_EN");
- gpio_request(TPS_RESET, "TPS_RESET");
- gpio_request(WWAN_EN, "WWAN_EN");
- gpio_request(WWAN_NRESET, "WWAN_NRESET");
- gpio_request(HUB_EN, "HUB_EN");
- gpio_request(HUB_NRESET, "HUB_NRESET");
- gpio_request(SD_EN, "SD_EN");
- gpio_request(AUDIO_EN, "AUDIO_EN");
- gpio_request(DSI_EN, "DSI_EN");
- gpio_request(SMC_EN, "SMC_EN");
- gpio_request(CAMERA_EN, "CAMERA_EN");
- gpio_request(FLASH_EN, "FLASH_EN");
- gpio_request(DSI_BIAS_EN, "DSI_BIAS_EN");
- gpio_request(GPS_EN, "GPS_EN");
- gpio_request(BL_EN, "BL_EN");
+#ifndef CONSOLE_ON_UART4
- gpio_request(WIFI_EN, "WIFI_EN");
- gpio_direction_output(WIFI_EN, 0);
+#endif /* CONSOLE_ON_UART4 */
- gpio_direction_input(VOL_UP);
- gpio_direction_input(VOL_DOWN);
- /* ensure charger is in the automated mode */
- gpio_direction_output(NFC_EN, 0);
- gpio_direction_output(CHG_EN, 0);
- gpio_direction_output(CHG_OTG_OUT_EN, 0);
- gpio_direction_input(TYPEC_MUX_EN);
- gpio_direction_output(TPS_RESET, 0);
- gpio_direction_output(WWAN_EN, 0);
- gpio_direction_output(WWAN_NRESET, 1);
- gpio_direction_output(HUB_EN, 1);
- gpio_direction_output(HUB_NRESET, 1);
- mdelay(10);
- gpio_direction_output(SD_EN, 1);
- gpio_direction_output(SMC_EN, 0);
- gpio_direction_output(CAMERA_EN, 0);
- gpio_direction_output(FLASH_EN, 0);
- gpio_direction_output(DSI_BIAS_EN, 0);
- gpio_direction_output(GPS_EN, 0);
- gpio_direction_output(BL_EN, 0);
- /* turn these on for i2c busses */
- gpio_direction_output(AUDIO_EN, 1);
- gpio_direction_output(DSI_EN, 1);
+} +#endif /* CONFIG_SPL_BUILD */
+#define USB1_BASE_ADDR 0x38100000 +#define USB2_BASE_ADDR 0x38200000 +#define USB1_PHY_BASE_ADDR 0x381F0000 +#define USB2_PHY_BASE_ADDR 0x382F0000
+#define USB_PHY_CTRL0 0xF0040 +#define USB_PHY_CTRL0_REF_SSP_EN BIT(2) +#define USB_PHY_CTRL0_SSC_RANGE_MASK GENMASK(23, 21) +#define USB_PHY_CTRL0_SSC_RANGE_4003PPM (0x2 << 21)
+#define USB_PHY_CTRL1 0xF0044 +#define USB_PHY_CTRL1_RESET BIT(0) +#define USB_PHY_CTRL1_COMMONONN BIT(1) +#define USB_PHY_CTRL1_ATERESET BIT(3) +#define USB_PHY_CTRL1_VDATSRCENB0 BIT(19) +#define USB_PHY_CTRL1_VDATDETENB0 BIT(20)
+#define USB_PHY_CTRL2 0xF0048 +#define USB_PHY_CTRL2_TXENABLEN0 BIT(8)
+#define USB_PHY_CTRL6 0x18 +#define USB_PHY_CTRL6_RXTERM_OVERRIDE_SEL BIT(29)
+extern struct dram_timing_info dram_timing_b0;
+#endif diff --git a/board/purism/librem5/lpddr4_timing.c b/board/purism/librem5/lpddr4_timing.c new file mode 100644 index 0000000000..46bc7f8591 --- /dev/null +++ b/board/purism/librem5/lpddr4_timing.c @@ -0,0 +1,1324 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h>
+#define WR_POST_EXT_3200 /* recommened to define */
+struct dram_cfg_param lpddr4_ddrc_cfg[] = {
- /* Start to config, default 3200mbps */
- { DDRC_DBG1(0), 0x00000001 },
- { DDRC_PWRCTL(0), 0x00000001 },
- { DDRC_MSTR(0), 0xa3080020 },
- { DDRC_MSTR2(0), 0x00000000 },
- { DDRC_RFSHTMG(0), 0x006100E0 },
- { DDRC_INIT0(0), 0xC003061B },
- { DDRC_INIT1(0), 0x009D0000 },
- { DDRC_INIT3(0), 0x00D4002D },
+#ifdef WR_POST_EXT_3200
- { DDRC_INIT4(0), 0x00330008 },
+#else
- { DDRC_INIT4(0), 0x00310008 },
- { DDRC_INIT6(0), 0x0066004a },
- { DDRC_INIT7(0), 0x0006004a },
- { DDRC_DRAMTMG0(0), 0x1A201B22 },
- { DDRC_DRAMTMG1(0), 0x00060633 },
- { DDRC_DRAMTMG3(0), 0x00C0C000 },
- { DDRC_DRAMTMG4(0), 0x0F04080F },
- { DDRC_DRAMTMG5(0), 0x02040C0C },
- { DDRC_DRAMTMG6(0), 0x01010007 },
- { DDRC_DRAMTMG7(0), 0x00000401 },
- { DDRC_DRAMTMG12(0), 0x00020600 },
- { DDRC_DRAMTMG13(0), 0x0C100002 },
- { DDRC_DRAMTMG14(0), 0x000000E6 },
- { DDRC_DRAMTMG17(0), 0x00A00050 },
- { DDRC_ZQCTL0(0), 0x03200018 },
- { DDRC_ZQCTL1(0), 0x028061A8 },
- { DDRC_ZQCTL2(0), 0x00000000 },
- { DDRC_DFITMG0(0), 0x0497820A },
- { DDRC_DFITMG1(0), 0x00080303 },
- { DDRC_DFIUPD0(0), 0xE0400018 },
- { DDRC_DFIUPD1(0), 0x00DF00E4 },
- { DDRC_DFIUPD2(0), 0x80000000 },
- { DDRC_DFIMISC(0), 0x00000011 },
- { DDRC_DFITMG2(0), 0x0000170A },
- { DDRC_DBICTL(0), 0x00000001 },
- { DDRC_DFIPHYMSTR(0), 0x00000001 },
- { DDRC_RANKCTL(0), 0x00000c99 },
- { DDRC_DRAMTMG2(0), 0x070E171a },
- /* address mapping */
- { DDRC_ADDRMAP0(0), 0x00000015 },
- { DDRC_ADDRMAP3(0), 0x00000000 },
- { DDRC_ADDRMAP4(0), 0x00001F1F },
- /* bank interleave */
- { DDRC_ADDRMAP1(0), 0x00080808 },
- { DDRC_ADDRMAP5(0), 0x07070707 },
- { DDRC_ADDRMAP6(0), 0x08080707 },
- /* performance setting */
- { DDRC_ODTCFG(0), 0x0b060908 },
- { DDRC_ODTMAP(0), 0x00000000 },
- { DDRC_SCHED(0), 0x29511505 },
- { DDRC_SCHED1(0), 0x0000002c },
- { DDRC_PERFHPR1(0), 0x5900575b },
- /* 150T starve and 0x90 max tran len */
- { DDRC_PERFLPR1(0), 0x90000096 },
- /* 300T starve and 0x10 max tran len */
- { DDRC_PERFWR1(0), 0x1000012c },
- { DDRC_DBG0(0), 0x00000016 },
- { DDRC_DBG1(0), 0x00000000 },
- { DDRC_DBGCMD(0), 0x00000000 },
- { DDRC_SWCTL(0), 0x00000001 },
- { DDRC_POISONCFG(0), 0x00000011 },
- { DDRC_PCCFG(0), 0x00000111 },
- { DDRC_PCFGR_0(0), 0x000010f3 },
- { DDRC_PCFGW_0(0), 0x000072ff },
- { DDRC_PCTRL_0(0), 0x00000001 },
- /* disable Read Qos*/
- { DDRC_PCFGQOS0_0(0), 0x00000e00 },
- { DDRC_PCFGQOS1_0(0), 0x0062ffff },
- /* disable Write Qos*/
- { DDRC_PCFGWQOS0_0(0), 0x00000e00 },
- { DDRC_PCFGWQOS1_0(0), 0x0000ffff },
- /* Frequency 1: 400mbps */
- { DDRC_FREQ1_DRAMTMG0(0), 0x0d0b010c },
- { DDRC_FREQ1_DRAMTMG1(0), 0x00030410 },
- { DDRC_FREQ1_DRAMTMG2(0), 0x0305090c },
- { DDRC_FREQ1_DRAMTMG3(0), 0x00505006 },
- { DDRC_FREQ1_DRAMTMG4(0), 0x05040305 },
- { DDRC_FREQ1_DRAMTMG5(0), 0x0d0e0504 },
- { DDRC_FREQ1_DRAMTMG6(0), 0x0a060004 },
- { DDRC_FREQ1_DRAMTMG7(0), 0x0000090e },
- { DDRC_FREQ1_DRAMTMG14(0), 0x00000032 },
- { DDRC_FREQ1_DRAMTMG15(0), 0x00000000 },
- { DDRC_FREQ1_DRAMTMG17(0), 0x0036001b },
- { DDRC_FREQ1_DERATEINT(0), 0x7e9fbeb1 },
- { DDRC_FREQ1_DFITMG0(0), 0x03818200 },
- { DDRC_FREQ1_DFITMG2(0), 0x00000000 },
- { DDRC_FREQ1_RFSHTMG(0), 0x000C001c },
- { DDRC_FREQ1_INIT3(0), 0x00840000 },
- { DDRC_FREQ1_INIT4(0), 0x00310008 },
- { DDRC_FREQ1_INIT6(0), 0x0066004a },
- { DDRC_FREQ1_INIT7(0), 0x0006004a },
- /* Frequency 2: 100mbps */
- { DDRC_FREQ2_DRAMTMG0(0), 0x0d0b010c },
- { DDRC_FREQ2_DRAMTMG1(0), 0x00030410 },
- { DDRC_FREQ2_DRAMTMG2(0), 0x0305090c },
- { DDRC_FREQ2_DRAMTMG3(0), 0x00505006 },
- { DDRC_FREQ2_DRAMTMG4(0), 0x05040305 },
- { DDRC_FREQ2_DRAMTMG5(0), 0x0d0e0504 },
- { DDRC_FREQ2_DRAMTMG6(0), 0x0a060004 },
- { DDRC_FREQ2_DRAMTMG7(0), 0x0000090e },
- { DDRC_FREQ2_DRAMTMG14(0), 0x00000032 },
- { DDRC_FREQ2_DRAMTMG17(0), 0x0036001b },
- { DDRC_FREQ2_DERATEINT(0), 0x7e9fbeb1 },
- { DDRC_FREQ2_DFITMG0(0), 0x03818200 },
- { DDRC_FREQ2_DFITMG2(0), 0x00000000 },
- { DDRC_FREQ2_RFSHTMG(0), 0x00030007 },
- { DDRC_FREQ2_INIT3(0), 0x00840000 },
- { DDRC_FREQ2_INIT4(0), 0x00310008 },
- { DDRC_FREQ2_INIT6(0), 0x0066004a },
- { DDRC_FREQ2_INIT7(0), 0x0006004a },
+/* PHY Initialize Configuration */ +struct dram_cfg_param lpddr4_ddrphy_cfg[] = {
- { 0x20110, 0x02 },
- { 0x20111, 0x03 },
- { 0x20112, 0x04 },
- { 0x20113, 0x05 },
- { 0x20114, 0x00 },
- { 0x20115, 0x01 },
- { 0x1005f, 0x1ff },
- { 0x1015f, 0x1ff },
- { 0x1105f, 0x1ff },
- { 0x1115f, 0x1ff },
- { 0x1205f, 0x1ff },
- { 0x1215f, 0x1ff },
- { 0x1305f, 0x1ff },
- { 0x1315f, 0x1ff },
- { 0x11005f, 0x1ff },
- { 0x11015f, 0x1ff },
- { 0x11105f, 0x1ff },
- { 0x11115f, 0x1ff },
- { 0x11205f, 0x1ff },
- { 0x11215f, 0x1ff },
- { 0x11305f, 0x1ff },
- { 0x11315f, 0x1ff },
- { 0x21005f, 0x1ff },
- { 0x21015f, 0x1ff },
- { 0x21105f, 0x1ff },
- { 0x21115f, 0x1ff },
- { 0x21205f, 0x1ff },
- { 0x21215f, 0x1ff },
- { 0x21305f, 0x1ff },
- { 0x21315f, 0x1ff },
- { 0x55, 0x1ff },
- { 0x1055, 0x1ff },
- { 0x2055, 0x1ff },
- { 0x3055, 0x1ff },
- { 0x4055, 0x1ff },
- { 0x5055, 0x1ff },
- { 0x6055, 0x1ff },
- { 0x7055, 0x1ff },
- { 0x8055, 0x1ff },
- { 0x9055, 0x1ff },
- { 0x200c5, 0x19 },
- { 0x1200c5, 0x7 },
- { 0x2200c5, 0x7 },
- { 0x2002e, 0x2 },
- { 0x12002e, 0x2 },
- { 0x22002e, 0x2 },
- { 0x90204, 0x0 },
- { 0x190204, 0x0 },
- { 0x290204, 0x0 },
- { 0x20024, 0xeb },
+#else
- { 0x20024, 0xab },
- { 0x2003a, 0x0 },
- { 0x120024, 0xab },
- { 0x2003a, 0x0 },
- { 0x220024, 0xab },
- { 0x2003a, 0x0 },
- { 0x20056, 0x3 },
- { 0x120056, 0xa },
- { 0x220056, 0xa },
- { 0x1004d, 0xe00 },
- { 0x1014d, 0xe00 },
- { 0x1104d, 0xe00 },
- { 0x1114d, 0xe00 },
- { 0x1204d, 0xe00 },
- { 0x1214d, 0xe00 },
- { 0x1304d, 0xe00 },
- { 0x1314d, 0xe00 },
- { 0x11004d, 0xe00 },
- { 0x11014d, 0xe00 },
- { 0x11104d, 0xe00 },
- { 0x11114d, 0xe00 },
- { 0x11204d, 0xe00 },
- { 0x11214d, 0xe00 },
- { 0x11304d, 0xe00 },
- { 0x11314d, 0xe00 },
- { 0x21004d, 0xe00 },
- { 0x21014d, 0xe00 },
- { 0x21104d, 0xe00 },
- { 0x21114d, 0xe00 },
- { 0x21204d, 0xe00 },
- { 0x21214d, 0xe00 },
- { 0x21304d, 0xe00 },
- { 0x21314d, 0xe00 },
- { 0x10049, 0xfbe },
- { 0x10149, 0xfbe },
- { 0x11049, 0xfbe },
- { 0x11149, 0xfbe },
- { 0x12049, 0xfbe },
- { 0x12149, 0xfbe },
- { 0x13049, 0xfbe },
- { 0x13149, 0xfbe },
- { 0x110049, 0xfbe },
- { 0x110149, 0xfbe },
- { 0x111049, 0xfbe },
- { 0x111149, 0xfbe },
- { 0x112049, 0xfbe },
- { 0x112149, 0xfbe },
- { 0x113049, 0xfbe },
- { 0x113149, 0xfbe },
- { 0x210049, 0xfbe },
- { 0x210149, 0xfbe },
- { 0x211049, 0xfbe },
- { 0x211149, 0xfbe },
- { 0x212049, 0xfbe },
- { 0x212149, 0xfbe },
- { 0x213049, 0xfbe },
- { 0x213149, 0xfbe },
- { 0x43, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) },
- { 0x1043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) },
- { 0x2043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) },
- { 0x3043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) },
- { 0x4043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) },
- { 0x5043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) },
- { 0x6043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) },
- { 0x7043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) },
- { 0x8043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) },
- { 0x9043, ((LPDDR4_PHY_ADDR_RON << 5) | LPDDR4_PHY_ADDR_RON) },
- { 0x20018, 0x3 },
- { 0x20075, 0x4 },
- { 0x20050, 0x0 },
- { 0x20008, 0x320 },
- { 0x120008, 0x64 },
- { 0x220008, 0x19 },
- { 0x20088, 0x9 },
- { 0x200b2, 0x104 },
- { 0x10043, 0x5a1 },
- { 0x10143, 0x5a1 },
- { 0x11043, 0x5a1 },
- { 0x11143, 0x5a1 },
- { 0x12043, 0x5a1 },
- { 0x12143, 0x5a1 },
- { 0x13043, 0x5a1 },
- { 0x13143, 0x5a1 },
- { 0x1200b2, 0x104 },
- { 0x110043, 0x5a1 },
- { 0x110143, 0x5a1 },
- { 0x111043, 0x5a1 },
- { 0x111143, 0x5a1 },
- { 0x112043, 0x5a1 },
- { 0x112143, 0x5a1 },
- { 0x113043, 0x5a1 },
- { 0x113143, 0x5a1 },
- { 0x2200b2, 0x104 },
- { 0x210043, 0x5a1 },
- { 0x210143, 0x5a1 },
- { 0x211043, 0x5a1 },
- { 0x211143, 0x5a1 },
- { 0x212043, 0x5a1 },
- { 0x212143, 0x5a1 },
- { 0x213043, 0x5a1 },
- { 0x213143, 0x5a1 },
- { 0x200fa, 0x1 },
- { 0x1200fa, 0x1 },
- { 0x2200fa, 0x1 },
- { 0x20019, 0x1 },
- { 0x120019, 0x1 },
- { 0x220019, 0x1 },
- { 0x200f0, 0x660 },
- { 0x200f1, 0x0 },
- { 0x200f2, 0x4444 },
- { 0x200f3, 0x8888 },
- { 0x200f4, 0x5665 },
- { 0x200f5, 0x0 },
- { 0x200f6, 0x0 },
- { 0x200f7, 0xf000 },
- { 0x20025, 0x0 },
- { 0x2002d, 0x0 },
- { 0x12002d, 0x0 },
- { 0x22002d, 0x0 },
- { 0x200c7, 0x80 },
- { 0x1200c7, 0x80 },
- { 0x2200c7, 0x80 },
- { 0x200ca, 0x106 },
- { 0x1200ca, 0x106 },
- { 0x2200ca, 0x106 },
+/* P0 message block paremeter for training firmware */ +struct dram_cfg_param lpddr4_fsp0_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54000, 0x0 },
- { 0x54001, 0x0 },
- { 0x54002, 0x0 },
- { 0x54003, 0xc80 },
- { 0x54004, 0x2 },
- { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT) }, /* PHY Ron/Rtt */
- { 0x54006, LPDDR4_PHY_VREF_VALUE },
- { 0x54007, 0x0 },
- { 0x54008, 0x131f },
- { 0x54009, LPDDR4_HDT_CTL_3200_1D },
- { 0x5400a, 0x0 },
- { 0x5400b, 0x2 },
- { 0x5400c, 0x0 },
- { 0x5400d, (LPDDR4_CATRAIN_3200_1d << 8) },
- { 0x5400e, 0x0 },
- { 0x5400f, 0x0 },
- { 0x54010, 0x0 },
- { 0x54011, 0x0 },
- { 0x54012, 0x310 },
- { 0x54013, 0x0 },
- { 0x54014, 0x0 },
- { 0x54015, 0x0 },
- { 0x54016, 0x0 },
- { 0x54017, 0x0 },
- { 0x54018, 0x0 },
- { 0x54019, 0x2dd4 },
- { 0x5401a, (((LPDDR4_RON) << 3) | 0x3) },
+#else
- { 0x5401a, (((LPDDR4_RON) << 3) | 0x1) },
- { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) |
(LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) },
- { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08) },
- { 0x5401d, 0x0 },
- { 0x5401e, LPDDR4_MR22_RANK0 },
- { 0x5401f, 0x2dd4 },
- { 0x54020, (((LPDDR4_RON) << 3) | 0x3) },
+#else
- { 0x54020, (((LPDDR4_RON) << 3) | 0x1) },
- { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) |
(LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) },
- { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08) },
- { 0x54023, 0x0 },
- { 0x54024, LPDDR4_MR22_RANK1 },
- { 0x54025, 0x0 },
- { 0x54026, 0x0 },
- { 0x54027, 0x0 },
- { 0x54028, 0x0 },
- { 0x54029, 0x0 },
- { 0x5402a, 0x0 },
- { 0x5402b, 0x1000 },
- { 0x5402c, 0x3 },
- { 0x5402d, 0x0 },
- { 0x5402e, 0x0 },
- { 0x5402f, 0x0 },
- { 0x54030, 0x0 },
- { 0x54031, 0x0 },
- { 0x54032, 0xd400 },
- /* MR3/MR2 */
- { 0x54033, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d /*0x312d*/ },
+#else
- { 0x54033, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x2d/*0x312d*/ },
- /* MR11/MR4 */
- { 0x54034, (((LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) << 8) },
- /* self:0x284d//MR13/MR12 */
- { 0x54035, (0x0800 | LPDDR4_VREF_VALUE_CA)/*0x084d*/ },
- /* MR16/MR14*/
- { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0/*0x4d*/ },
- { 0x54037, (LPDDR4_MR22_RANK0 << 8)/*0x500*/ },
- /* MR1 */
- { 0x54038, 0xd400 },
- /* MR3/MR2 */
- { 0x54039, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d/*0x312d*/ },
+#else
- { 0x54039, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x2d/*0x312d*/ },
- /* MR11/MR4 */
- { 0x5403a, (((LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) << 8) },
- { 0x5403b, (0x0800 | LPDDR4_VREF_VALUE_CA)/*0x084d*/ },
- /* MR16/MR14 */
- { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1/*0x4d*/ },
- { 0x5403d, (LPDDR4_MR22_RANK1 << 8)/*0x500*/ },
- /* { 0x5403d, 0x500 } */
- { 0x5403e, 0x0 },
- { 0x5403f, 0x0 },
- { 0x54040, 0x0 },
- { 0x54041, 0x0 },
- { 0x54042, 0x0 },
- { 0x54043, 0x0 },
- { 0x54044, 0x0 },
- { 0xd0000, 0x1 },
+/* P1 message block paremeter for training firmware */ +struct dram_cfg_param lpddr4_fsp1_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54000, 0x0 },
- { 0x54001, 0x0 },
- { 0x54002, 0x101 },
- { 0x54003, 0x190 },
- { 0x54004, 0x2 },
- /* PHY Ron/Rtt */
- { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT)/*0x2828*/ },
- { 0x54007, 0x0 },
- { 0x54008, LPDDR4_TRAIN_SEQ_400 },
- { 0x54009, LPDDR4_HDT_CTL_400_1D },
- { 0x5400a, 0x0 },
- { 0x5400b, 0x2 },
- { 0x5400c, 0x0 },
- { 0x5400d, (LPDDR4_CATRAIN_400 << 8) },
- { 0x5400e, 0x0 },
- { 0x5400f, 0x0 },
- { 0x54010, 0x0 },
- { 0x54011, 0x0 },
- { 0x54013, 0x0 },
- { 0x54014, 0x0 },
- { 0x54015, 0x0 },
- { 0x54016, 0x0 },
- { 0x54017, 0x0 },
- { 0x54018, 0x0 },
- { 0x54019, 0x84 },
- /* MR4/MR3 */
- { 0x5401a, (((LPDDR4_RON) << 3) | 0x1)/*0x31*/ },
- /* MR12/MR11 */
- { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA << 4) |
LPDDR4_RTT_DQ)/*0x4d46*/ },
- /* self:0x4d28//MR14/MR13 */
- { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08)/*0x4d08*/ },
- { 0x5401d, 0x0 },
- { 0x5401e, LPDDR4_MR22_RANK0/*0x5*/ },
- { 0x5401f, 0x84 },
- { 0x54020, (((LPDDR4_RON) << 3) | 0x1)/*0x31*/ }, /* MR4/MR3 */
- { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA << 4) |
LPDDR4_RTT_DQ)/*0x4d46*/ },/* MR12/MR11 */
- { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08)/*0x4d08*/ },
- { 0x54023, 0x0 },
- { 0x54025, 0x0 },
- { 0x54026, 0x0 },
- { 0x54027, 0x0 },
- { 0x54028, 0x0 },
- { 0x54029, 0x0 },
- { 0x5402a, 0x0 },
- { 0x5402c, 0x3 },
- { 0x5402d, 0x0 },
- { 0x5402e, 0x0 },
- { 0x5402f, 0x0 },
- { 0x54030, 0x0 },
- { 0x54031, 0x0 },
- { 0x54032, 0x8400 },
- { 0x54033, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x00 },
- { 0x54034, (((LPDDR4_RTT_CA << 4) | LPDDR4_RTT_DQ) << 8) },
- { 0x54035, (0x0800 | LPDDR4_VREF_VALUE_CA) },
- { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0 },
- { 0x54037, (LPDDR4_MR22_RANK0 << 8) },
- { 0x54038, 0x8400 },
- { 0x54039, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x00 },
- { 0x5403a, (((LPDDR4_RTT_CA << 4) | LPDDR4_RTT_DQ) << 8) },
- { 0x5403b, (0x0800 | LPDDR4_VREF_VALUE_CA) },
- { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1 },
- { 0x5403d, (LPDDR4_MR22_RANK1 << 8) },
- { 0x5403e, 0x0 },
- { 0x5403f, 0x0 },
- { 0x54040, 0x0 },
- { 0x54041, 0x0 },
- { 0x54042, 0x0 },
- { 0x54043, 0x0 },
- { 0x54044, 0x0 },
- { 0xd0000, 0x1 },
+/* P2 message block paremeter for training firmware */ +struct dram_cfg_param lpddr4_fsp2_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54000, 0x0 },
- { 0x54001, 0x0 },
- { 0x54002, 0x102 },
- { 0x54003, 0x64 },
- { 0x54004, 0x2 },
- { 0x54007, 0x0 },
- { 0x54008, LPDDR4_TRAIN_SEQ_100 },
- { 0x54009, LPDDR4_HDT_CTL_100_1D },
- { 0x5400a, 0x0 },
- { 0x5400b, 0x2 },
- { 0x5400c, 0x0 },
- { 0x5400d, (LPDDR4_CATRAIN_100 << 8) },
- { 0x5400e, 0x0 },
- { 0x5400f, 0x0 },
- { 0x54010, 0x0 },
- { 0x54011, 0x0 },
- { 0x54013, 0x0 },
- { 0x54014, 0x0 },
- { 0x54015, 0x0 },
- { 0x54016, 0x0 },
- { 0x54017, 0x0 },
- { 0x54018, 0x0 },
LPDDR4_RTT_DQ) },
- { 0x5401d, 0x0 },
LPDDR4_RTT_DQ) },
- { 0x54023, 0x0 },
- { 0x54025, 0x0 },
- { 0x54026, 0x0 },
- { 0x54027, 0x0 },
- { 0x54028, 0x0 },
- { 0x54029, 0x0 },
- { 0x5402a, 0x0 },
- { 0x5402c, 0x3 },
- { 0x5402d, 0x0 },
- { 0x5402e, 0x0 },
- { 0x5402f, 0x0 },
- { 0x54030, 0x0 },
- { 0x54031, 0x0 },
- { 0x5403e, 0x0 },
- { 0x5403f, 0x0 },
- { 0x54040, 0x0 },
- { 0x54041, 0x0 },
- { 0x54042, 0x0 },
- { 0x54043, 0x0 },
- { 0x54044, 0x0 },
- { 0xd0000, 0x1 },
+/* P0 2D message block paremeter for training firmware */ +struct dram_cfg_param lpddr4_fsp0_2d_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54000, 0x0 },
- { 0x54001, 0x0 },
- { 0x54002, 0x0 },
- { 0x54004, 0x2 },
- { 0x54007, 0x0 },
- { 0x54008, 0x61 },
- { 0x54009, LPDDR4_HDT_CTL_2D },
- { 0x5400a, 0x0 },
- { 0x5400b, 0x2 },
- { 0x5400c, 0x0 },
- { 0x5400d, (LPDDR4_CATRAIN_3200_2d << 8) },
- { 0x5400e, 0x0 },
- { 0x5400f, (LPDDR4_2D_SHARE << 8) | 0x00 },
- { 0x54010, LPDDR4_2D_WEIGHT },
- { 0x54011, 0x0 },
- { 0x54013, 0x0 },
- { 0x54014, 0x0 },
- { 0x54015, 0x0 },
- { 0x54016, 0x0 },
- { 0x54017, 0x0 },
- { 0x54018, 0x0 },
+#else
- { 0x5401d, 0x0 },
+#else
- { 0x54023, 0x0 },
- { 0x54025, 0x0 },
- { 0x54026, 0x0 },
- { 0x54027, 0x0 },
- { 0x54028, 0x0 },
- { 0x54029, 0x0 },
- { 0x5402a, 0x0 },
- { 0x5402c, 0x3 },
- { 0x5402d, 0x0 },
- { 0x5402e, 0x0 },
- { 0x5402f, 0x0 },
- { 0x54030, 0x0 },
- { 0x54031, 0x0 },
- { 0x54033, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d },
+#else
- { 0x54033, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x2d },
- { 0x54039, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d },
+#else
- { 0x54039, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x2d },
- { 0x5403e, 0x0 },
- { 0x5403f, 0x0 },
- { 0x54040, 0x0 },
- { 0x54041, 0x0 },
- { 0x54042, 0x0 },
- { 0x54043, 0x0 },
- { 0x54044, 0x0 },
- { 0xd0000, 0x1 },
+/* DRAM PHY init engine image */ +struct dram_cfg_param lpddr4_phy_pie[] = {
- { 0xd0000, 0x0 },
- { 0x90000, 0x10 },
- { 0x90001, 0x400 },
- { 0x90002, 0x10e },
- { 0x90003, 0x0 },
- { 0x90004, 0x0 },
- { 0x90005, 0x8 },
- { 0x90029, 0xb },
- { 0x9002a, 0x480 },
- { 0x9002b, 0x109 },
- { 0x9002c, 0x8 },
- { 0x9002d, 0x448 },
- { 0x9002e, 0x139 },
- { 0x9002f, 0x8 },
- { 0x90030, 0x478 },
- { 0x90031, 0x109 },
- { 0x90032, 0x0 },
- { 0x90033, 0xe8 },
- { 0x90034, 0x109 },
- { 0x90035, 0x2 },
- { 0x90036, 0x10 },
- { 0x90037, 0x139 },
- { 0x90038, 0xf },
- { 0x90039, 0x7c0 },
- { 0x9003a, 0x139 },
- { 0x9003b, 0x44 },
- { 0x9003c, 0x630 },
- { 0x9003d, 0x159 },
- { 0x9003e, 0x14f },
- { 0x9003f, 0x630 },
- { 0x90040, 0x159 },
- { 0x90041, 0x47 },
- { 0x90042, 0x630 },
- { 0x90043, 0x149 },
- { 0x90044, 0x4f },
- { 0x90045, 0x630 },
- { 0x90046, 0x179 },
- { 0x90047, 0x8 },
- { 0x90048, 0xe0 },
- { 0x90049, 0x109 },
- { 0x9004a, 0x0 },
- { 0x9004b, 0x7c8 },
- { 0x9004c, 0x109 },
- { 0x9004d, 0x0 },
- { 0x9004e, 0x1 },
- { 0x9004f, 0x8 },
- { 0x90050, 0x0 },
- { 0x90051, 0x45a },
- { 0x90052, 0x9 },
- { 0x90053, 0x0 },
- { 0x90054, 0x448 },
- { 0x90055, 0x109 },
- { 0x90056, 0x40 },
- { 0x90057, 0x630 },
- { 0x90058, 0x179 },
- { 0x90059, 0x1 },
- { 0x9005a, 0x618 },
- { 0x9005b, 0x109 },
- { 0x9005c, 0x40c0 },
- { 0x9005d, 0x630 },
- { 0x9005e, 0x149 },
- { 0x9005f, 0x8 },
- { 0x90060, 0x4 },
- { 0x90061, 0x48 },
- { 0x90062, 0x4040 },
- { 0x90063, 0x630 },
- { 0x90064, 0x149 },
- { 0x90065, 0x0 },
- { 0x90066, 0x4 },
- { 0x90067, 0x48 },
- { 0x90068, 0x40 },
- { 0x90069, 0x630 },
- { 0x9006a, 0x149 },
- { 0x9006b, 0x10 },
- { 0x9006c, 0x4 },
- { 0x9006d, 0x18 },
- { 0x9006e, 0x0 },
- { 0x9006f, 0x4 },
- { 0x90070, 0x78 },
- { 0x90071, 0x549 },
- { 0x90072, 0x630 },
- { 0x90073, 0x159 },
- { 0x90074, 0xd49 },
- { 0x90075, 0x630 },
- { 0x90076, 0x159 },
- { 0x90077, 0x94a },
- { 0x90078, 0x630 },
- { 0x90079, 0x159 },
- { 0x9007a, 0x441 },
- { 0x9007b, 0x630 },
- { 0x9007c, 0x149 },
- { 0x9007d, 0x42 },
- { 0x9007e, 0x630 },
- { 0x9007f, 0x149 },
- { 0x90080, 0x1 },
- { 0x90081, 0x630 },
- { 0x90082, 0x149 },
- { 0x90083, 0x0 },
- { 0x90084, 0xe0 },
- { 0x90085, 0x109 },
- { 0x90086, 0xa },
- { 0x90087, 0x10 },
- { 0x90088, 0x109 },
- { 0x90089, 0x9 },
- { 0x9008a, 0x3c0 },
- { 0x9008b, 0x149 },
- { 0x9008c, 0x9 },
- { 0x9008d, 0x3c0 },
- { 0x9008e, 0x159 },
- { 0x9008f, 0x18 },
- { 0x90090, 0x10 },
- { 0x90091, 0x109 },
- { 0x90092, 0x0 },
- { 0x90093, 0x3c0 },
- { 0x90094, 0x109 },
- { 0x90095, 0x18 },
- { 0x90096, 0x4 },
- { 0x90097, 0x48 },
- { 0x90098, 0x18 },
- { 0x90099, 0x4 },
- { 0x9009a, 0x58 },
- { 0x9009b, 0xa },
- { 0x9009c, 0x10 },
- { 0x9009d, 0x109 },
- { 0x9009e, 0x2 },
- { 0x9009f, 0x10 },
- { 0x900a0, 0x109 },
- { 0x900a1, 0x5 },
- { 0x900a2, 0x7c0 },
- { 0x900a3, 0x109 },
- { 0x900a4, 0x10 },
- { 0x900a5, 0x10 },
- { 0x900a6, 0x109 },
- { 0x40000, 0x811 },
- { 0x40020, 0x880 },
- { 0x40040, 0x0 },
- { 0x40060, 0x0 },
- { 0x40001, 0x4008 },
- { 0x40021, 0x83 },
- { 0x40041, 0x4f },
- { 0x40061, 0x0 },
- { 0x40002, 0x4040 },
- { 0x40022, 0x83 },
- { 0x40042, 0x51 },
- { 0x40062, 0x0 },
- { 0x40003, 0x811 },
- { 0x40023, 0x880 },
- { 0x40043, 0x0 },
- { 0x40063, 0x0 },
- { 0x40004, 0x720 },
- { 0x40024, 0xf },
- { 0x40044, 0x1740 },
- { 0x40064, 0x0 },
- { 0x40005, 0x16 },
- { 0x40025, 0x83 },
- { 0x40045, 0x4b },
- { 0x40065, 0x0 },
- { 0x40006, 0x716 },
- { 0x40026, 0xf },
- { 0x40046, 0x2001 },
- { 0x40066, 0x0 },
- { 0x40007, 0x716 },
- { 0x40027, 0xf },
- { 0x40047, 0x2800 },
- { 0x40067, 0x0 },
- { 0x40008, 0x716 },
- { 0x40028, 0xf },
- { 0x40048, 0xf00 },
- { 0x40068, 0x0 },
- { 0x40009, 0x720 },
- { 0x40029, 0xf },
- { 0x40049, 0x1400 },
- { 0x40069, 0x0 },
- { 0x4000a, 0xe08 },
- { 0x4002a, 0xc15 },
- { 0x4004a, 0x0 },
- { 0x4006a, 0x0 },
- { 0x4000b, 0x623 },
- { 0x4002b, 0x15 },
- { 0x4004b, 0x0 },
- { 0x4006b, 0x0 },
- { 0x4000c, 0x4028 },
- { 0x4002c, 0x80 },
- { 0x4004c, 0x0 },
- { 0x4006c, 0x0 },
- { 0x4000d, 0xe08 },
- { 0x4002d, 0xc1a },
- { 0x4004d, 0x0 },
- { 0x4006d, 0x0 },
- { 0x4000e, 0x623 },
- { 0x4002e, 0x1a },
- { 0x4004e, 0x0 },
- { 0x4006e, 0x0 },
- { 0x4000f, 0x4040 },
- { 0x4002f, 0x80 },
- { 0x4004f, 0x0 },
- { 0x4006f, 0x0 },
- { 0x40010, 0x2604 },
- { 0x40030, 0x15 },
- { 0x40050, 0x0 },
- { 0x40070, 0x0 },
- { 0x40011, 0x708 },
- { 0x40031, 0x5 },
- { 0x40051, 0x0 },
- { 0x40071, 0x2002 },
- { 0x40012, 0x8 },
- { 0x40032, 0x80 },
- { 0x40052, 0x0 },
- { 0x40072, 0x0 },
- { 0x40013, 0x2604 },
- { 0x40033, 0x1a },
- { 0x40053, 0x0 },
- { 0x40073, 0x0 },
- { 0x40014, 0x708 },
- { 0x40034, 0xa },
- { 0x40054, 0x0 },
- { 0x40074, 0x2002 },
- { 0x40015, 0x4040 },
- { 0x40035, 0x80 },
- { 0x40055, 0x0 },
- { 0x40075, 0x0 },
- { 0x40016, 0x60a },
- { 0x40036, 0x15 },
- { 0x40056, 0x1200 },
- { 0x40076, 0x0 },
- { 0x40017, 0x61a },
- { 0x40037, 0x15 },
- { 0x40057, 0x1300 },
- { 0x40077, 0x0 },
- { 0x40018, 0x60a },
- { 0x40038, 0x1a },
- { 0x40058, 0x1200 },
- { 0x40078, 0x0 },
- { 0x40019, 0x642 },
- { 0x40039, 0x1a },
- { 0x40059, 0x1300 },
- { 0x40079, 0x0 },
- { 0x4001a, 0x4808 },
- { 0x4003a, 0x880 },
- { 0x4005a, 0x0 },
- { 0x4007a, 0x0 },
- { 0x900a7, 0x0 },
- { 0x900a8, 0x790 },
- { 0x900a9, 0x11a },
- { 0x900aa, 0x8 },
- { 0x900ab, 0x7aa },
- { 0x900ac, 0x2a },
- { 0x900ad, 0x10 },
- { 0x900ae, 0x7b2 },
- { 0x900af, 0x2a },
- { 0x900b0, 0x0 },
- { 0x900b1, 0x7c8 },
- { 0x900b2, 0x109 },
- { 0x900b3, 0x10 },
- { 0x900b4, 0x2a8 },
- { 0x900b5, 0x129 },
- { 0x900b6, 0x8 },
- { 0x900b7, 0x370 },
- { 0x900b8, 0x129 },
- { 0x900b9, 0xa },
- { 0x900ba, 0x3c8 },
- { 0x900bb, 0x1a9 },
- { 0x900bc, 0xc },
- { 0x900bd, 0x408 },
- { 0x900be, 0x199 },
- { 0x900bf, 0x14 },
- { 0x900c0, 0x790 },
- { 0x900c1, 0x11a },
- { 0x900c2, 0x8 },
- { 0x900c3, 0x4 },
- { 0x900c4, 0x18 },
- { 0x900c5, 0xe },
- { 0x900c6, 0x408 },
- { 0x900c7, 0x199 },
- { 0x900c8, 0x8 },
- { 0x900c9, 0x8568 },
- { 0x900ca, 0x108 },
- { 0x900cb, 0x18 },
- { 0x900cc, 0x790 },
- { 0x900cd, 0x16a },
- { 0x900ce, 0x8 },
- { 0x900cf, 0x1d8 },
- { 0x900d0, 0x169 },
- { 0x900d1, 0x10 },
- { 0x900d2, 0x8558 },
- { 0x900d3, 0x168 },
- { 0x900d4, 0x70 },
- { 0x900d5, 0x788 },
- { 0x900d6, 0x16a },
- { 0x900d7, 0x1ff8 },
- { 0x900d8, 0x85a8 },
- { 0x900d9, 0x1e8 },
- { 0x900da, 0x50 },
- { 0x900db, 0x798 },
- { 0x900dc, 0x16a },
- { 0x900dd, 0x60 },
- { 0x900de, 0x7a0 },
- { 0x900df, 0x16a },
- { 0x900e0, 0x8 },
- { 0x900e1, 0x8310 },
- { 0x900e2, 0x168 },
- { 0x900e3, 0x8 },
- { 0x900e4, 0xa310 },
- { 0x900e5, 0x168 },
- { 0x900e6, 0xa },
- { 0x900e7, 0x408 },
- { 0x900e8, 0x169 },
- { 0x900e9, 0x6e },
- { 0x900ea, 0x0 },
- { 0x900eb, 0x68 },
- { 0x900ec, 0x0 },
- { 0x900ed, 0x408 },
- { 0x900ee, 0x169 },
- { 0x900ef, 0x0 },
- { 0x900f0, 0x8310 },
- { 0x900f1, 0x168 },
- { 0x900f2, 0x0 },
- { 0x900f3, 0xa310 },
- { 0x900f4, 0x168 },
- { 0x900f5, 0x1ff8 },
- { 0x900f6, 0x85a8 },
- { 0x900f7, 0x1e8 },
- { 0x900f8, 0x68 },
- { 0x900f9, 0x798 },
- { 0x900fa, 0x16a },
- { 0x900fb, 0x78 },
- { 0x900fc, 0x7a0 },
- { 0x900fd, 0x16a },
- { 0x900fe, 0x68 },
- { 0x900ff, 0x790 },
- { 0x90100, 0x16a },
- { 0x90101, 0x8 },
- { 0x90102, 0x8b10 },
- { 0x90103, 0x168 },
- { 0x90104, 0x8 },
- { 0x90105, 0xab10 },
- { 0x90106, 0x168 },
- { 0x90107, 0xa },
- { 0x90108, 0x408 },
- { 0x90109, 0x169 },
- { 0x9010a, 0x58 },
- { 0x9010b, 0x0 },
- { 0x9010c, 0x68 },
- { 0x9010d, 0x0 },
- { 0x9010e, 0x408 },
- { 0x9010f, 0x169 },
- { 0x90110, 0x0 },
- { 0x90111, 0x8b10 },
- { 0x90112, 0x168 },
- { 0x90113, 0x0 },
- { 0x90114, 0xab10 },
- { 0x90115, 0x168 },
- { 0x90116, 0x0 },
- { 0x90117, 0x1d8 },
- { 0x90118, 0x169 },
- { 0x90119, 0x80 },
- { 0x9011a, 0x790 },
- { 0x9011b, 0x16a },
- { 0x9011c, 0x18 },
- { 0x9011d, 0x7aa },
- { 0x9011e, 0x6a },
- { 0x9011f, 0xa },
- { 0x90120, 0x0 },
- { 0x90121, 0x1e9 },
- { 0x90122, 0x8 },
- { 0x90123, 0x8080 },
- { 0x90124, 0x108 },
- { 0x90125, 0xf },
- { 0x90126, 0x408 },
- { 0x90127, 0x169 },
- { 0x90128, 0xc },
- { 0x90129, 0x0 },
- { 0x9012a, 0x68 },
- { 0x9012b, 0x9 },
- { 0x9012c, 0x0 },
- { 0x9012d, 0x1a9 },
- { 0x9012e, 0x0 },
- { 0x9012f, 0x408 },
- { 0x90130, 0x169 },
- { 0x90131, 0x0 },
- { 0x90132, 0x8080 },
- { 0x90133, 0x108 },
- { 0x90134, 0x8 },
- { 0x90135, 0x7aa },
- { 0x90136, 0x6a },
- { 0x90137, 0x0 },
- { 0x90138, 0x8568 },
- { 0x90139, 0x108 },
- { 0x9013a, 0xb7 },
- { 0x9013b, 0x790 },
- { 0x9013c, 0x16a },
- { 0x9013d, 0x1f },
- { 0x9013e, 0x0 },
- { 0x9013f, 0x68 },
- { 0x90140, 0x8 },
- { 0x90141, 0x8558 },
- { 0x90142, 0x168 },
- { 0x90143, 0xf },
- { 0x90144, 0x408 },
- { 0x90145, 0x169 },
- { 0x90146, 0xc },
- { 0x90147, 0x0 },
- { 0x90148, 0x68 },
- { 0x90149, 0x0 },
- { 0x9014a, 0x408 },
- { 0x9014b, 0x169 },
- { 0x9014c, 0x0 },
- { 0x9014d, 0x8558 },
- { 0x9014e, 0x168 },
- { 0x9014f, 0x8 },
- { 0x90150, 0x3c8 },
- { 0x90151, 0x1a9 },
- { 0x90152, 0x3 },
- { 0x90153, 0x370 },
- { 0x90154, 0x129 },
- { 0x90155, 0x20 },
- { 0x90156, 0x2aa },
- { 0x90157, 0x9 },
- { 0x90158, 0x0 },
- { 0x90159, 0x400 },
- { 0x9015a, 0x10e },
- { 0x9015b, 0x8 },
- { 0x9015c, 0xe8 },
- { 0x9015d, 0x109 },
- { 0x9015e, 0x0 },
- { 0x9015f, 0x8140 },
- { 0x90160, 0x10c },
- { 0x90161, 0x10 },
- { 0x90162, 0x8138 },
- { 0x90163, 0x10c },
- { 0x90164, 0x8 },
- { 0x90165, 0x7c8 },
- { 0x90166, 0x101 },
- { 0x90167, 0x8 },
- { 0x90168, 0x0 },
- { 0x90169, 0x8 },
- { 0x9016a, 0x8 },
- { 0x9016b, 0x448 },
- { 0x9016c, 0x109 },
- { 0x9016d, 0xf },
- { 0x9016e, 0x7c0 },
- { 0x9016f, 0x109 },
- { 0x90170, 0x0 },
- { 0x90171, 0xe8 },
- { 0x90172, 0x109 },
- { 0x90173, 0x47 },
- { 0x90174, 0x630 },
- { 0x90175, 0x109 },
- { 0x90176, 0x8 },
- { 0x90177, 0x618 },
- { 0x90178, 0x109 },
- { 0x90179, 0x8 },
- { 0x9017a, 0xe0 },
- { 0x9017b, 0x109 },
- { 0x9017c, 0x0 },
- { 0x9017d, 0x7c8 },
- { 0x9017e, 0x109 },
- { 0x9017f, 0x8 },
- { 0x90180, 0x8140 },
- { 0x90181, 0x10c },
- { 0x90182, 0x0 },
- { 0x90183, 0x1 },
- { 0x90184, 0x8 },
- { 0x90185, 0x8 },
- { 0x90186, 0x4 },
- { 0x90187, 0x8 },
- { 0x90188, 0x8 },
- { 0x90189, 0x7c8 },
- { 0x9018a, 0x101 },
- { 0x90006, 0x0 },
- { 0x90007, 0x0 },
- { 0x90008, 0x8 },
- { 0x90009, 0x0 },
- { 0x9000a, 0x0 },
- { 0x9000b, 0x0 },
- { 0xd00e7, 0x400 },
- { 0x90017, 0x0 },
- { 0x9001f, 0x2a },
- { 0x90026, 0x6a },
- { 0x400d0, 0x0 },
- { 0x400d1, 0x101 },
- { 0x400d2, 0x105 },
- { 0x400d3, 0x107 },
- { 0x400d4, 0x10f },
- { 0x400d5, 0x202 },
- { 0x400d6, 0x20a },
- { 0x400d7, 0x20b },
- { 0x2003a, 0x2 },
- { 0x2000b, 0x64 },
- { 0x2000c, 0xc8 },
- { 0x2000d, 0x7d0 },
- { 0x2000e, 0x2c },
- { 0x12000b, 0xc },
- { 0x12000c, 0x19 },
- { 0x12000d, 0xfa },
- { 0x12000e, 0x10 },
- { 0x22000b, 0x3 },
- { 0x22000c, 0x6 },
- { 0x22000d, 0x3e },
- { 0x22000e, 0x10 },
- { 0x9000c, 0x0 },
- { 0x9000d, 0x173 },
- { 0x9000e, 0x60 },
- { 0x9000f, 0x6110 },
- { 0x90010, 0x2152 },
- { 0x90011, 0xdfbd },
- { 0x90012, 0x60 },
- { 0x90013, 0x6152 },
- { 0x20010, 0x5a },
- { 0x20011, 0x3 },
- { 0x40080, 0xe0 },
- { 0x40081, 0x12 },
- { 0x40082, 0xe0 },
- { 0x40083, 0x12 },
- { 0x40084, 0xe0 },
- { 0x40085, 0x12 },
- { 0x140080, 0xe0 },
- { 0x140081, 0x12 },
- { 0x140082, 0xe0 },
- { 0x140083, 0x12 },
- { 0x140084, 0xe0 },
- { 0x140085, 0x12 },
- { 0x240080, 0xe0 },
- { 0x240081, 0x12 },
- { 0x240082, 0xe0 },
- { 0x240083, 0x12 },
- { 0x240084, 0xe0 },
- { 0x240085, 0x12 },
- { 0x400fd, 0xf },
- { 0x10011, 0x1 },
- { 0x10012, 0x1 },
- { 0x10013, 0x180 },
- { 0x10018, 0x1 },
- { 0x10002, 0x6209 },
- { 0x100b2, 0x1 },
- { 0x101b4, 0x1 },
- { 0x102b4, 0x1 },
- { 0x103b4, 0x1 },
- { 0x104b4, 0x1 },
- { 0x105b4, 0x1 },
- { 0x106b4, 0x1 },
- { 0x107b4, 0x1 },
- { 0x108b4, 0x1 },
- { 0x11011, 0x1 },
- { 0x11012, 0x1 },
- { 0x11013, 0x180 },
- { 0x11018, 0x1 },
- { 0x11002, 0x6209 },
- { 0x110b2, 0x1 },
- { 0x111b4, 0x1 },
- { 0x112b4, 0x1 },
- { 0x113b4, 0x1 },
- { 0x114b4, 0x1 },
- { 0x115b4, 0x1 },
- { 0x116b4, 0x1 },
- { 0x117b4, 0x1 },
- { 0x118b4, 0x1 },
- { 0x12011, 0x1 },
- { 0x12012, 0x1 },
- { 0x12013, 0x180 },
- { 0x12018, 0x1 },
- { 0x12002, 0x6209 },
- { 0x120b2, 0x1 },
- { 0x121b4, 0x1 },
- { 0x122b4, 0x1 },
- { 0x123b4, 0x1 },
- { 0x124b4, 0x1 },
- { 0x125b4, 0x1 },
- { 0x126b4, 0x1 },
- { 0x127b4, 0x1 },
- { 0x128b4, 0x1 },
- { 0x13011, 0x1 },
- { 0x13012, 0x1 },
- { 0x13013, 0x180 },
- { 0x13018, 0x1 },
- { 0x13002, 0x6209 },
- { 0x130b2, 0x1 },
- { 0x131b4, 0x1 },
- { 0x132b4, 0x1 },
- { 0x133b4, 0x1 },
- { 0x134b4, 0x1 },
- { 0x135b4, 0x1 },
- { 0x136b4, 0x1 },
- { 0x137b4, 0x1 },
- { 0x138b4, 0x1 },
- { 0x2003a, 0x2 },
- { 0xc0080, 0x2 },
- { 0xd0000, 0x1 },
+struct dram_fsp_msg lpddr4_dram_fsp_msg[] = {
/* P0 3200mts 1D */
.drate = 3200,
.fw_type = FW_1D_IMAGE,
.fsp_cfg = lpddr4_fsp0_cfg,
.fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp0_cfg),
/* P1 400mts 1D */
.drate = 400,
.fsp_cfg = lpddr4_fsp1_cfg,
.fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp1_cfg),
/* P1 100mts 1D */
.drate = 100,
.fsp_cfg = lpddr4_fsp2_cfg,
.fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp2_cfg),
/* P0 3200mts 2D */
.drate = 3200,
.fw_type = FW_2D_IMAGE,
.fsp_cfg = lpddr4_fsp0_2d_cfg,
.fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp0_2d_cfg),
+/* lpddr4 timing config params on EVK board */ +struct dram_timing_info dram_timing = {
- .ddrc_cfg = lpddr4_ddrc_cfg,
- .ddrc_cfg_num = ARRAY_SIZE(lpddr4_ddrc_cfg),
- .ddrphy_cfg = lpddr4_ddrphy_cfg,
- .ddrphy_cfg_num = ARRAY_SIZE(lpddr4_ddrphy_cfg),
- .fsp_msg = lpddr4_dram_fsp_msg,
- .fsp_msg_num = ARRAY_SIZE(lpddr4_dram_fsp_msg),
- .ddrphy_pie = lpddr4_phy_pie,
- .ddrphy_pie_num = ARRAY_SIZE(lpddr4_phy_pie),
- .fsp_table = { 3200, 400, 100, },
+}; diff --git a/board/purism/librem5/lpddr4_timing_b0.c b/board/purism/librem5/lpddr4_timing_b0.c new file mode 100644 index 0000000000..ec68edaf69 --- /dev/null +++ b/board/purism/librem5/lpddr4_timing_b0.c @@ -0,0 +1,1191 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+static struct dram_cfg_param lpddr4_ddrc_cfg[] = {
- /* dis_dq=1, indicates no reads or writes are issued to SDRAM */
- /* selfref_en=1, SDRAM enter self-refresh state */
+#ifdef WR_POST_EXT_3200 /* recommened to define */
+#else
- /* need be refined by ddrphy trained value */
- /* Address map is from MSB 29: r15, r14, cs, r13-r0, b2-b0, c9-c0 */
- /* addrmap_col_b10 addrmap_col_b11 set to de-activated (5-bit width) */
- /* addrmap_bank_b2, addrmap_bank_b1, addrmap_bank_b0 */
- /* addrmap_row_b11 addrmap_row_b10_b2 addrmap_row_b1 addrmap_row_b0 */
- /* addrmap_row_b15 addrmap_row_b14 addrmap_row_b13 addrmap_row_b12 */
- /* 667mts frequency setting */
- { DDRC_FREQ1_DERATEEN(0), 0x0000000 },
- { DDRC_FREQ1_DERATEINT(0), 0x0800000 },
- { DDRC_FREQ1_RFSHCTL0(0), 0x0210000 },
- { DDRC_FREQ1_RFSHTMG(0), 0x014001E },
- { DDRC_FREQ1_INIT3(0), 0x0140009 },
- { DDRC_FREQ1_DRAMTMG0(0), 0xB070A07 },
- { DDRC_FREQ1_DRAMTMG1(0), 0x003040A },
- { DDRC_FREQ1_DRAMTMG2(0), 0x305080C },
- { DDRC_FREQ1_DRAMTMG3(0), 0x0505000 },
- { DDRC_FREQ1_DRAMTMG4(0), 0x3040203 },
- { DDRC_FREQ1_DRAMTMG5(0), 0x2030303 },
- { DDRC_FREQ1_DRAMTMG6(0), 0x2020004 },
- { DDRC_FREQ1_DRAMTMG7(0), 0x0000302 },
- { DDRC_FREQ1_DRAMTMG12(0), 0x0020310 },
- { DDRC_FREQ1_DRAMTMG13(0), 0xA100002 },
- { DDRC_FREQ1_DRAMTMG14(0), 0x0000020 },
- { DDRC_FREQ1_DRAMTMG17(0), 0x0220011 },
- { DDRC_FREQ1_ZQCTL0(0), 0x0A70005 },
- { DDRC_FREQ1_DFITMG0(0), 0x3858202 },
- { DDRC_FREQ1_DFITMG1(0), 0x0000404 },
- { DDRC_FREQ1_DFITMG2(0), 0x0000502 },
- { DDRC_FREQ1_DERATEEN(0), 0x00000202 },
- { DDRC_FREQ1_DERATEINT(0), 0xec78f4b5 },
- { DDRC_FREQ1_RFSHCTL0(0), 0x00618040 },
- { DDRC_FREQ1_RFSHTMG(0), 0x00610090 },
+/* PHY Initialize Configuration */ +static struct dram_cfg_param lpddr4_ddrphy_cfg[] = {
- { 0x20110, 0x02 }, /* MapCAB0toDFI */
- { 0x20111, 0x03 }, /* MapCAB1toDFI */
- { 0x20112, 0x04 }, /* MapCAB2toDFI */
- { 0x20113, 0x05 }, /* MapCAB3toDFI */
- { 0x20114, 0x00 }, /* MapCAB4toDFI */
- { 0x20115, 0x01 }, /* MapCAB5toDFI */
- /* Initialize PHY Configuration */
- { 0x55, 0x1ff },
- { 0x2002e, 0x2 },
- { 0x12002e, 0x1 },
- { 0x90204, 0x0 },
- { 0x20024, 0xe3 },
- { 0x2003a, 0x2 },
- { 0x120024, 0xa3 },
- { 0x2003a, 0x2 },
- { 0x220024, 0xa3 },
- { 0x2003a, 0x2 },
- { 0x20056, 0x3 },
- { 0x43, 0x63 },
- { 0x1043, 0x63 },
- { 0x2043, 0x63 },
- { 0x3043, 0x63 },
- { 0x4043, 0x63 },
- { 0x5043, 0x63 },
- { 0x6043, 0x63 },
- { 0x7043, 0x63 },
- { 0x8043, 0x63 },
- { 0x9043, 0x63 },
- { 0x20018, 0x3 },
- { 0x20075, 0x4 },
- { 0x20050, 0x0 },
- { 0x120008, 0xa7 },
- { 0x20088, 0x9 },
- { 0x200fa, 0x1 },
- { 0x20019, 0x1 },
- { 0x200f0, 0x600 },
- { 0x200f1, 0x0 },
- { 0x200f4, 0x5655 },
- { 0x200f5, 0x0 },
- { 0x200f6, 0x0 },
- { 0x20025, 0x0 },
- { 0x2002d, 0x0 },
+/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param lpddr4_fsp0_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54000, 0x0 },
- { 0x54001, 0x0 },
- { 0x54002, 0x0 },
- { 0x54004, 0x2 },
- { 0x54007, 0x0 },
- { 0x5400a, 0x0 },
- { 0x5400b, 0x2 },
- { 0x5400c, 0x0 },
- { 0x5400e, 0x0 },
- { 0x5400f, 0x0 },
- { 0x54010, 0x0 },
- { 0x54011, 0x0 },
- { 0x54013, 0x0 },
- { 0x54014, 0x0 },
- { 0x54015, 0x0 },
- { 0x54016, 0x0 },
- { 0x54017, 0x0 },
- { 0x54018, 0x0 },
- { 0x5401d, 0x0 },
- { 0x54023, 0x0 },
- { 0x54025, 0x0 },
- { 0x54026, 0x0 },
- { 0x54027, 0x0 },
- { 0x54028, 0x0 },
- { 0x54029, 0x0 },
- { 0x5402a, 0x0 },
- { 0x5402c, 0x3 },
- { 0x5402d, 0x0 },
- { 0x5402e, 0x0 },
- { 0x5402f, 0x0 },
- { 0x54030, 0x0 },
- { 0x54031, 0x0 },
- { 0x5403e, 0x0 },
- { 0x5403f, 0x0 },
- { 0x54040, 0x0 },
- { 0x54041, 0x0 },
- { 0x54042, 0x0 },
- { 0x54043, 0x0 },
- { 0x54044, 0x0 },
- { 0xd0000, 0x1 },
+/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param lpddr4_fsp1_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54000, 0x0 },
- { 0x54001, 0x0 },
- { 0x54002, 0x1 },
- { 0x54003, 0x29c },
- { 0x54004, 0x2 },
- { 0x54007, 0x0 },
- { 0x54008, 0x121f },
- { 0x54009, 0xc8 },
- { 0x5400a, 0x0 },
- { 0x5400b, 0x2 },
- { 0x5400c, 0x0 },
- { 0x5400d, 0x0 },
- { 0x5400e, 0x0 },
- { 0x5400f, 0x0 },
- { 0x54010, 0x0 },
- { 0x54011, 0x0 },
- { 0x54013, 0x0 },
- { 0x54014, 0x0 },
- { 0x54015, 0x0 },
- { 0x54016, 0x0 },
- { 0x54017, 0x0 },
- { 0x54018, 0x0 },
- { 0x54019, 0x914 },
- { 0x5401e, 0x6 },
- { 0x5401f, 0x914 },
- { 0x54023, 0x0 },
- { 0x54025, 0x0 },
- { 0x54026, 0x0 },
- { 0x54027, 0x0 },
- { 0x54028, 0x0 },
- { 0x54029, 0x0 },
- { 0x5402a, 0x0 },
- { 0x5402c, 0x3 },
- { 0x5402d, 0x0 },
- { 0x5402e, 0x0 },
- { 0x5402f, 0x0 },
- { 0x54030, 0x0 },
- { 0x54031, 0x0 },
- { 0x54032, 0x1400 },
- { 0x54033, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x09 },
- { 0x54037, 0x600 },
- { 0x54038, 0x1400 },
- { 0x54039, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x09 },
- { 0x5403e, 0x0 },
- { 0x5403f, 0x0 },
- { 0x54040, 0x0 },
- { 0x54041, 0x0 },
- { 0x54042, 0x0 },
- { 0x54043, 0x0 },
- { 0xd0000, 0x1 },
+/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param lpddr4_fsp0_2d_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54000, 0x0 },
- { 0x54001, 0x0 },
- { 0x54002, 0x0 },
- { 0x54004, 0x2 },
- { 0x54007, 0x0 },
- { 0x5400a, 0x0 },
- { 0x5400b, 0x2 },
- { 0x5400c, 0x0 },
- { 0x5400e, 0x0 },
- { 0x54011, 0x0 },
- { 0x54013, 0x0 },
- { 0x54014, 0x0 },
- { 0x54015, 0x0 },
- { 0x54016, 0x0 },
- { 0x54017, 0x0 },
- { 0x54018, 0x0 },
- { 0x54024, 0x5 },
- { 0x5401d, 0x0 },
- { 0x54023, 0x0 },
- { 0x54025, 0x0 },
- { 0x54026, 0x0 },
- { 0x54027, 0x0 },
- { 0x54028, 0x0 },
- { 0x54029, 0x0 },
- { 0x5402a, 0x0 },
- { 0x5402c, 0x3 },
- { 0x5402d, 0x0 },
- { 0x5402e, 0x0 },
- { 0x5402f, 0x0 },
- { 0x54030, 0x0 },
- { 0x54031, 0x0 },
- { 0x5403e, 0x0 },
- { 0x5403f, 0x0 },
- { 0x54040, 0x0 },
- { 0x54041, 0x0 },
- { 0x54042, 0x0 },
- { 0x54043, 0x0 },
- { 0x54044, 0x0 },
- { 0xd0000, 0x1 },
+/* DRAM PHY init engine image */ +static struct dram_cfg_param lpddr4_phy_pie[] = {
- { 0xd0000, 0x0 },
- { 0x90003, 0x0 },
- { 0x90004, 0x0 },
- { 0x90005, 0x8 },
- { 0x90029, 0xb },
- { 0x9002c, 0x8 },
- { 0x9002f, 0x8 },
- { 0x90032, 0x0 },
- { 0x90035, 0x2 },
- { 0x90038, 0xb },
- { 0x90047, 0x8 },
- { 0x9004a, 0x0 },
- { 0x9004d, 0x0 },
- { 0x9004e, 0x1 },
- { 0x9004f, 0x8 },
- { 0x90050, 0x0 },
- { 0x90052, 0x9 },
- { 0x90053, 0x0 },
- { 0x90059, 0x1 },
- { 0x9005f, 0x8 },
- { 0x90060, 0x4 },
- { 0x90065, 0x0 },
- { 0x90066, 0x4 },
- { 0x9006c, 0x4 },
- { 0x9006e, 0x0 },
- { 0x9006f, 0x4 },
- { 0x90080, 0x1 },
- { 0x90083, 0x0 },
- { 0x90086, 0xa },
- { 0x90089, 0x9 },
- { 0x9008c, 0x9 },
- { 0x90092, 0x0 },
- { 0x90096, 0x4 },
- { 0x90099, 0x4 },
- { 0x9009b, 0xa },
- { 0x9009e, 0x2 },
- { 0x900a1, 0x5 },
- { 0x900a4, 0xd },
- { 0x900a5, 0x7c0 },
- { 0x900a7, 0x4 },
- { 0x900a8, 0x7c0 },
- { 0x900a9, 0x109 },
- { 0x40040, 0x0 },
- { 0x40060, 0x0 },
- { 0x40061, 0x0 },
- { 0x40062, 0x0 },
- { 0x40043, 0x0 },
- { 0x40063, 0x0 },
- { 0x40024, 0xf },
- { 0x40064, 0x0 },
- { 0x40065, 0x0 },
- { 0x40026, 0xf },
- { 0x40066, 0x0 },
- { 0x40027, 0xf },
- { 0x40067, 0x0 },
- { 0x40028, 0xf },
- { 0x40068, 0x0 },
- { 0x40029, 0xf },
- { 0x40069, 0x0 },
- { 0x4004a, 0x0 },
- { 0x4006a, 0x0 },
- { 0x4004b, 0x0 },
- { 0x4006b, 0x0 },
- { 0x4004c, 0x0 },
- { 0x4006c, 0x0 },
- { 0x4004d, 0x0 },
- { 0x4006d, 0x0 },
- { 0x4004e, 0x0 },
- { 0x4006e, 0x0 },
- { 0x4004f, 0x0 },
- { 0x4006f, 0x0 },
- { 0x40050, 0x0 },
- { 0x40070, 0x0 },
- { 0x40031, 0x5 },
- { 0x40051, 0x0 },
- { 0x40012, 0x8 },
- { 0x40052, 0x0 },
- { 0x40072, 0x0 },
- { 0x40053, 0x0 },
- { 0x40073, 0x0 },
- { 0x40034, 0xa },
- { 0x40054, 0x0 },
- { 0x40055, 0x0 },
- { 0x40075, 0x0 },
- { 0x40076, 0x0 },
- { 0x40077, 0x0 },
- { 0x40078, 0x0 },
- { 0x40079, 0x0 },
- { 0x4005a, 0x0 },
- { 0x4007a, 0x0 },
- { 0x900aa, 0x0 },
- { 0x900ab, 0x790 },
- { 0x900ac, 0x11a },
- { 0x900ad, 0x8 },
- { 0x900ae, 0x7aa },
- { 0x900b0, 0x10 },
- { 0x900b1, 0x7b2 },
- { 0x900b2, 0x2a },
- { 0x900b3, 0x0 },
- { 0x900b4, 0x7c8 },
- { 0x900b5, 0x109 },
- { 0x900b6, 0x10 },
- { 0x900b7, 0x10 },
- { 0x900b8, 0x109 },
- { 0x900b9, 0x10 },
- { 0x900ba, 0x2a8 },
- { 0x900bb, 0x129 },
- { 0x900bc, 0x8 },
- { 0x900bd, 0x370 },
- { 0x900be, 0x129 },
- { 0x900bf, 0xa },
- { 0x900c0, 0x3c8 },
- { 0x900c1, 0x1a9 },
- { 0x900c2, 0xc },
- { 0x900c3, 0x408 },
- { 0x900c4, 0x199 },
- { 0x900c5, 0x14 },
- { 0x900c6, 0x790 },
- { 0x900c7, 0x11a },
- { 0x900c8, 0x8 },
- { 0x900c9, 0x4 },
- { 0x900ca, 0x18 },
- { 0x900cb, 0xe },
- { 0x900cc, 0x408 },
- { 0x900cd, 0x199 },
- { 0x900ce, 0x8 },
- { 0x900cf, 0x8568 },
- { 0x900d0, 0x108 },
- { 0x900d1, 0x18 },
- { 0x900d2, 0x790 },
- { 0x900d3, 0x16a },
- { 0x900d4, 0x8 },
- { 0x900d5, 0x1d8 },
- { 0x900d6, 0x169 },
- { 0x900d7, 0x10 },
- { 0x900d8, 0x8558 },
- { 0x900d9, 0x168 },
- { 0x900da, 0x70 },
- { 0x900db, 0x788 },
- { 0x900dd, 0x1ff8 },
- { 0x900de, 0x85a8 },
- { 0x900df, 0x1e8 },
- { 0x900e0, 0x50 },
- { 0x900e1, 0x798 },
- { 0x900e2, 0x16a },
- { 0x900e3, 0x60 },
- { 0x900e4, 0x7a0 },
- { 0x900e5, 0x16a },
- { 0x900e6, 0x8 },
- { 0x900e7, 0x8310 },
- { 0x900e8, 0x168 },
- { 0x900e9, 0x8 },
- { 0x900ea, 0xa310 },
- { 0x900eb, 0x168 },
- { 0x900ec, 0xa },
- { 0x900ef, 0x6e },
- { 0x900f0, 0x0 },
- { 0x900f1, 0x68 },
- { 0x900f2, 0x0 },
- { 0x900f3, 0x408 },
- { 0x900f4, 0x169 },
- { 0x900f5, 0x0 },
- { 0x900f6, 0x8310 },
- { 0x900f7, 0x168 },
- { 0x900f8, 0x0 },
- { 0x900f9, 0xa310 },
- { 0x900fa, 0x168 },
- { 0x900fb, 0x1ff8 },
- { 0x900fc, 0x85a8 },
- { 0x900fd, 0x1e8 },
- { 0x900ff, 0x798 },
- { 0x90101, 0x78 },
- { 0x90102, 0x7a0 },
- { 0x90103, 0x16a },
- { 0x90104, 0x68 },
- { 0x90105, 0x790 },
- { 0x90106, 0x16a },
- { 0x90107, 0x8 },
- { 0x90108, 0x8b10 },
- { 0x90109, 0x168 },
- { 0x9010a, 0x8 },
- { 0x9010b, 0xab10 },
- { 0x9010c, 0x168 },
- { 0x9010d, 0xa },
- { 0x90110, 0x58 },
- { 0x90111, 0x0 },
- { 0x90112, 0x68 },
- { 0x90113, 0x0 },
- { 0x90114, 0x408 },
- { 0x90115, 0x169 },
- { 0x90116, 0x0 },
- { 0x90117, 0x8b10 },
- { 0x90118, 0x168 },
- { 0x90119, 0x0 },
- { 0x9011a, 0xab10 },
- { 0x9011b, 0x168 },
- { 0x9011c, 0x0 },
- { 0x9011d, 0x1d8 },
- { 0x9011e, 0x169 },
- { 0x9011f, 0x80 },
- { 0x90120, 0x790 },
- { 0x90121, 0x16a },
- { 0x90122, 0x18 },
- { 0x90123, 0x7aa },
- { 0x90124, 0x6a },
- { 0x90125, 0xa },
- { 0x90126, 0x0 },
- { 0x90127, 0x1e9 },
- { 0x90128, 0x8 },
- { 0x90129, 0x8080 },
- { 0x9012a, 0x108 },
- { 0x9012b, 0xf },
- { 0x9012c, 0x408 },
- { 0x9012d, 0x169 },
- { 0x9012e, 0xc },
- { 0x9012f, 0x0 },
- { 0x90130, 0x68 },
- { 0x90131, 0x9 },
- { 0x90132, 0x0 },
- { 0x90133, 0x1a9 },
- { 0x90134, 0x0 },
- { 0x90135, 0x408 },
- { 0x90136, 0x169 },
- { 0x90137, 0x0 },
- { 0x90138, 0x8080 },
- { 0x9013a, 0x8 },
- { 0x9013b, 0x7aa },
- { 0x9013c, 0x6a },
- { 0x9013d, 0x0 },
- { 0x9013e, 0x8568 },
- { 0x9013f, 0x108 },
- { 0x90140, 0xb7 },
- { 0x90141, 0x790 },
- { 0x90142, 0x16a },
- { 0x90143, 0x1f },
- { 0x90144, 0x0 },
- { 0x90145, 0x68 },
- { 0x90146, 0x8 },
- { 0x90147, 0x8558 },
- { 0x90148, 0x168 },
- { 0x90149, 0xf },
- { 0x9014c, 0xc },
- { 0x9014d, 0x0 },
- { 0x9014e, 0x68 },
- { 0x9014f, 0x0 },
- { 0x90150, 0x408 },
- { 0x90151, 0x169 },
- { 0x90152, 0x0 },
- { 0x90153, 0x8558 },
- { 0x90154, 0x168 },
- { 0x90155, 0x8 },
- { 0x90156, 0x3c8 },
- { 0x90157, 0x1a9 },
- { 0x90158, 0x3 },
- { 0x90159, 0x370 },
- { 0x9015a, 0x129 },
- { 0x9015b, 0x20 },
- { 0x9015c, 0x2aa },
- { 0x9015d, 0x9 },
- { 0x9015e, 0x0 },
- { 0x9015f, 0x400 },
- { 0x90160, 0x10e },
- { 0x90161, 0x8 },
- { 0x90162, 0xe8 },
- { 0x90163, 0x109 },
- { 0x90164, 0x0 },
- { 0x90165, 0x8140 },
- { 0x90166, 0x10c },
- { 0x90167, 0x10 },
- { 0x90168, 0x8138 },
- { 0x90169, 0x10c },
- { 0x9016a, 0x8 },
- { 0x9016b, 0x7c8 },
- { 0x9016c, 0x101 },
- { 0x9016d, 0x8 },
- { 0x9016e, 0x0 },
- { 0x9016f, 0x8 },
- { 0x90170, 0x8 },
- { 0x90171, 0x448 },
- { 0x90173, 0xf },
- { 0x90174, 0x7c0 },
- { 0x90176, 0x0 },
- { 0x90177, 0xe8 },
- { 0x90179, 0x47 },
- { 0x9017a, 0x630 },
- { 0x9017c, 0x8 },
- { 0x9017d, 0x618 },
- { 0x9017f, 0x8 },
- { 0x90180, 0xe0 },
- { 0x90181, 0x109 },
- { 0x90182, 0x0 },
- { 0x90183, 0x7c8 },
- { 0x90184, 0x109 },
- { 0x90185, 0x8 },
- { 0x90186, 0x8140 },
- { 0x90187, 0x10c },
- { 0x90188, 0x0 },
- { 0x90189, 0x1 },
- { 0x9018a, 0x8 },
- { 0x9018b, 0x8 },
- { 0x9018c, 0x4 },
- { 0x9018d, 0x8 },
- { 0x9018e, 0x8 },
- { 0x9018f, 0x7c8 },
- { 0x90190, 0x101 },
- { 0x90006, 0x0 },
- { 0x90007, 0x0 },
- { 0x90008, 0x8 },
- { 0x90009, 0x0 },
- { 0x9000a, 0x0 },
- { 0x9000b, 0x0 },
- { 0x90017, 0x0 },
- { 0x9001f, 0x2b },
- { 0x90026, 0x6c },
- { 0x400d0, 0x0 },
- { 0x2003a, 0x2 },
- { 0x12000b, 0x14 },
- { 0x12000c, 0x29 },
- { 0x12000d, 0x1a1 },
- { 0x9000c, 0x0 },
- { 0x20011, 0x3 },
- { 0x400fd, 0xf },
- { 0x10011, 0x1 },
- { 0x10012, 0x1 },
- { 0x10018, 0x1 },
- { 0x100b2, 0x1 },
- { 0x101b4, 0x1 },
- { 0x102b4, 0x1 },
- { 0x103b4, 0x1 },
- { 0x104b4, 0x1 },
- { 0x105b4, 0x1 },
- { 0x106b4, 0x1 },
- { 0x107b4, 0x1 },
- { 0x108b4, 0x1 },
- { 0x11011, 0x1 },
- { 0x11012, 0x1 },
- { 0x11018, 0x1 },
- { 0x110b2, 0x1 },
- { 0x111b4, 0x1 },
- { 0x112b4, 0x1 },
- { 0x113b4, 0x1 },
- { 0x114b4, 0x1 },
- { 0x115b4, 0x1 },
- { 0x116b4, 0x1 },
- { 0x117b4, 0x1 },
- { 0x118b4, 0x1 },
- { 0x12011, 0x1 },
- { 0x12012, 0x1 },
- { 0x12018, 0x1 },
- { 0x120b2, 0x1 },
- { 0x121b4, 0x1 },
- { 0x122b4, 0x1 },
- { 0x123b4, 0x1 },
- { 0x124b4, 0x1 },
- { 0x125b4, 0x1 },
- { 0x126b4, 0x1 },
- { 0x127b4, 0x1 },
- { 0x128b4, 0x1 },
- { 0x13011, 0x1 },
- { 0x13012, 0x1 },
- { 0x13018, 0x1 },
- { 0x130b2, 0x1 },
- { 0x131b4, 0x1 },
- { 0x132b4, 0x1 },
- { 0x133b4, 0x1 },
- { 0x134b4, 0x1 },
- { 0x135b4, 0x1 },
- { 0x136b4, 0x1 },
- { 0x137b4, 0x1 },
- { 0x138b4, 0x1 },
- { 0x20089, 0x1 },
- { 0x20088, 0x19 },
- { 0xc0080, 0x2 },
- { 0xd0000, 0x1 },
+static struct dram_fsp_msg lpddr4_dram_fsp_msg[] = {
/* P0 3200mts 1D */
.drate = 3200,
/* P1 667mts 1D */
.drate = 667,
/* P0 3200mts 2D */
.drate = 3200,
+/* lpddr4 timing config params on EVK board */ +struct dram_timing_info dram_timing_b0 = {
* this table must be initialized if DDRPHY bypass mode is
* not used: all fsp drate > 666MTS.
- .fsp_table = { 3200, 667, },
+}; diff --git a/board/purism/librem5/spl.c b/board/purism/librem5/spl.c new file mode 100644 index 0000000000..b35f11debe --- /dev/null +++ b/board/purism/librem5/spl.c @@ -0,0 +1,593 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include <common.h> +#include <asm/io.h> +#include <errno.h> +#include <asm/io.h> +#include <asm/arch/ddr.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/clock.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <fsl_esdhc_imx.h> +#include <mmc.h> +#include <power/pmic.h> +#include <power/bd71837.h> +#include <hang.h> +#include <init.h> +#include <spl.h> +#include <usb.h> +#include <dwc3-uboot.h> +#include <linux/delay.h> +#include "librem5.h"
+DECLARE_GLOBAL_DATA_PTR;
+void spl_dram_init(void) +{
- /* ddr init */
- if ((get_cpu_rev() & 0xfff) == CHIP_REV_2_1)
ddr_init(&dram_timing);
- else
ddr_init(&dram_timing_b0);
+int spl_board_boot_device(enum boot_device boot_dev_spl) +{
- log_debug("%s : starting\n", __func__);
- switch (boot_dev_spl) {
- case SD1_BOOT:
- case MMC1_BOOT:
return BOOT_DEVICE_MMC1;
- case USB_BOOT:
return BOOT_DEVICE_BOARD;
- default:
return BOOT_DEVICE_NONE;
+#define ECSPI_PAD_CTRL (PAD_CTL_DSE2 | PAD_CTL_HYS)
+static const iomux_v3_cfg_t ecspi_pads[] = {
- IMX8MQ_PAD_ECSPI1_SCLK__ECSPI1_SCLK | MUX_PAD_CTRL(ECSPI_PAD_CTRL),
- IMX8MQ_PAD_ECSPI1_SS0__GPIO5_IO9 | MUX_PAD_CTRL(ECSPI_PAD_CTRL),
- IMX8MQ_PAD_ECSPI1_MOSI__ECSPI1_MOSI | MUX_PAD_CTRL(ECSPI_PAD_CTRL),
- IMX8MQ_PAD_ECSPI1_MISO__ECSPI1_MISO | MUX_PAD_CTRL(ECSPI_PAD_CTRL),
+int board_ecspi_init(void) +{
- imx_iomux_v3_setup_multiple_pads(ecspi_pads, ARRAY_SIZE(ecspi_pads));
+int board_spi_cs_gpio(unsigned int bus, unsigned int cs) +{
- return (bus == 0 && cs == 0) ? (SPI1_SS0) : -1;
+#define I2C_PAD_CTRL (PAD_CTL_PUE | PAD_CTL_ODE | PAD_CTL_DSE7 | PAD_CTL_FSEL3) +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +struct i2c_pads_info i2c_pad_info1 = {
- .scl = {
.i2c_mode = IMX8MQ_PAD_I2C1_SCL__I2C1_SCL | PC,
.gpio_mode = IMX8MQ_PAD_I2C1_SCL__GPIO5_IO14 | PC,
.gp = IMX_GPIO_NR(5, 14),
- .sda = {
.i2c_mode = IMX8MQ_PAD_I2C1_SDA__I2C1_SDA | PC,
.gpio_mode = IMX8MQ_PAD_I2C1_SDA__GPIO5_IO15 | PC,
.gp = IMX_GPIO_NR(5, 15),
+struct i2c_pads_info i2c_pad_info2 = {
- .scl = {
.i2c_mode = IMX8MQ_PAD_I2C2_SCL__I2C2_SCL | PC,
.gpio_mode = IMX8MQ_PAD_I2C2_SCL__GPIO5_IO16 | PC,
.gp = IMX_GPIO_NR(5, 16),
- .sda = {
.i2c_mode = IMX8MQ_PAD_I2C2_SDA__I2C2_SDA | PC,
.gpio_mode = IMX8MQ_PAD_I2C2_SDA__GPIO5_IO17 | PC,
.gp = IMX_GPIO_NR(5, 17),
+struct i2c_pads_info i2c_pad_info3 = {
- .scl = {
.i2c_mode = IMX8MQ_PAD_I2C3_SCL__I2C3_SCL | PC,
.gpio_mode = IMX8MQ_PAD_I2C3_SCL__GPIO5_IO18 | PC,
.gp = IMX_GPIO_NR(5, 18),
- .sda = {
.i2c_mode = IMX8MQ_PAD_I2C3_SDA__I2C3_SDA | PC,
.gpio_mode = IMX8MQ_PAD_I2C3_SDA__GPIO5_IO19 | PC,
.gp = IMX_GPIO_NR(5, 19),
+struct i2c_pads_info i2c_pad_info4 = {
- .scl = {
.i2c_mode = IMX8MQ_PAD_I2C4_SCL__I2C4_SCL | PC,
.gpio_mode = IMX8MQ_PAD_I2C4_SCL__GPIO5_IO20 | PC,
.gp = IMX_GPIO_NR(5, 20),
- .sda = {
.i2c_mode = IMX8MQ_PAD_I2C4_SDA__I2C4_SDA | PC,
.gpio_mode = IMX8MQ_PAD_I2C4_SDA__GPIO5_IO21 | PC,
.gp = IMX_GPIO_NR(5, 21),
+#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1)
+static const iomux_v3_cfg_t uart_pads[] = {
- IMX8MQ_PAD_UART1_RXD__UART1_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
- IMX8MQ_PAD_UART1_TXD__UART1_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
- IMX8MQ_PAD_UART2_RXD__UART2_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
- IMX8MQ_PAD_UART2_TXD__UART2_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
- IMX8MQ_PAD_UART3_RXD__UART3_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
- IMX8MQ_PAD_UART3_TXD__UART3_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
- IMX8MQ_PAD_ECSPI2_SCLK__UART4_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
- IMX8MQ_PAD_ECSPI2_MOSI__UART4_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
+#define USDHC1_PWR_GPIO IMX_GPIO_NR(2, 10) +#define USDHC2_PWR_GPIO IMX_GPIO_NR(2, 19)
+int board_mmc_getcd(struct mmc *mmc) +{
- struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv;
- int ret = 0;
- switch (cfg->esdhc_base) {
- case USDHC1_BASE_ADDR:
ret = 1;
break;
- case USDHC2_BASE_ADDR:
ret = 1;
break;
- return ret;
+#define USDHC_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE | \
PAD_CTL_FSEL1)
+#define USDHC_GPIO_PAD_CTRL (PAD_CTL_PUE | PAD_CTL_DSE1)
+static const iomux_v3_cfg_t usdhc1_pads[] = {
- IMX8MQ_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA4__USDHC1_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA5__USDHC1_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA6__USDHC1_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA7__USDHC1_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_RESET_B__GPIO2_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL),
+static const iomux_v3_cfg_t usdhc2_pads[] = {
- IMX8MQ_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */
- IMX8MQ_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */
- IMX8MQ_PAD_SD2_DATA0__USDHC2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */
- IMX8MQ_PAD_SD2_DATA1__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */
- IMX8MQ_PAD_SD2_DATA2__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0x16 */
- IMX8MQ_PAD_SD2_DATA3__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */
- IMX8MQ_PAD_SD2_RESET_B__GPIO2_IO19 | MUX_PAD_CTRL(USDHC_GPIO_PAD_CTRL),
+static struct fsl_esdhc_cfg usdhc_cfg[2] = {
- {USDHC1_BASE_ADDR, 0, 8},
- {USDHC2_BASE_ADDR, 0, 4},
+int board_mmc_init(struct bd_info *bis) +{
- int i, ret;
* According to the board_mmc_init() the following map is done:
* (U-Boot device node) (Physical Port)
* mmc0 USDHC1
* mmc1 USDHC2
- for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) {
log_debug("Initializing FSL USDHC port %d\n", i);
switch (i) {
case 0:
init_clk_usdhc(0);
usdhc_cfg[0].sdhc_clk = mxc_get_clock(USDHC1_CLK_ROOT);
imx_iomux_v3_setup_multiple_pads(usdhc1_pads,
ARRAY_SIZE(usdhc1_pads));
gpio_request(USDHC1_PWR_GPIO, "usdhc1_reset");
gpio_direction_output(USDHC1_PWR_GPIO, 0);
udelay(500);
gpio_direction_output(USDHC1_PWR_GPIO, 1);
break;
case 1:
init_clk_usdhc(1);
usdhc_cfg[1].sdhc_clk = mxc_get_clock(USDHC2_CLK_ROOT);
imx_iomux_v3_setup_multiple_pads(usdhc2_pads,
ARRAY_SIZE(usdhc2_pads));
gpio_request(USDHC2_PWR_GPIO, "usdhc2_reset");
gpio_direction_output(USDHC2_PWR_GPIO, 0);
udelay(500);
gpio_direction_output(USDHC2_PWR_GPIO, 1);
break;
default:
log_err("Warning: USDHC controller(%d) not supported\n", i + 1);
return -EINVAL;
ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]);
if (ret)
return ret;
+#define LDO_VOLT_EN BIT(6)
- Disable the charger - it will be re-enabled in u-boot
+void disable_charger_bq25895(void) +{
- u8 val;
- int timeout = 1000; // ms
- /* Set the i2c bus */
- i2c_set_bus_num(3);
- /* disable ship mode if BATFET_DLY is set */
- val = i2c_reg_read(0x6a, 0x09);
- log_debug("REG09 0x%x\n", val);
- if (val & 0x28) {
val = val & ~0x28;
i2c_reg_write(0x6a, 0x09, val);
- /* disable and trigger DPDM, ICO, HVDCP and MaxCharge */
- val = i2c_reg_read(0x6a, 0x02);
- log_debug("REG02 0x%x\n", val);
- val &= 0xe0;
- i2c_reg_write(0x6a, 0x02, val);
- /* disable charger and enable BAT_LOADEN */
- val = i2c_reg_read(0x6a, 0x03);
- log_debug("REG03 0x%x\n", val);
- val = (val | 0x80) & ~0x10;
- i2c_reg_write(0x6a, 0x03, val);
- mdelay(10);
- /* force ADC conversions */
- val = (val | 0x80) & ~0x40;
- do {
mdelay(10);
timeout -= 10;
- } while ((i2c_reg_read(0x6a, 0x02) & 0x80) && (timeout > 0));
- /* enable STAT pin */
- val = i2c_reg_read(0x6a, 0x07);
- log_debug("REG07 0x%x\n", val);
- val = val & ~0x40;
- i2c_reg_write(0x6a, 0x07, val);
- /* check VBUS */
- val = i2c_reg_read(0x6a, 0x11);
- log_debug("VBUS good %d\n", (val >> 7) & 1);
- log_debug("VBUS mV %d\n", (val & 0x7f) * 100 + 2600);
- /* check VBAT */
- val = i2c_reg_read(0x6a, 0x0e);
- log_debug("VBAT mV %d\n", (val & 0x7f) * 20 + 2304);
- /* limit the VINDPM to 3.9V */
- i2c_reg_write(0x6a, 0x0d, 0x8d);
- /* set the max voltage to 4.192V */
- val = i2c_reg_read(0x6a, 0x6);
- val = (val & ~0xFC) | 0x16 << 2;
- i2c_reg_write(0x6a, 0x6, val);
- /* set the SYS_MIN to 3.7V */
- val = i2c_reg_read(0x6a, 0x3);
- val = val | 0xE;
- i2c_reg_write(0x6a, 0x3, val);
- /* disable BAT_LOADEN */
- val = val & ~0x80;
+#define I2C_PMIC 0
+int power_bd71837_init(unsigned char bus) +{
- static const char name[] = BD718XX_REGULATOR_DRIVER;
- struct pmic *p = pmic_alloc();
- if (!p) {
log_err("%s: POWER allocation error!\n", __func__);
return -ENOMEM;
- p->name = name;
- p->interface = I2C_PMIC;
- p->number_of_regs = BD718XX_MAX_REGISTER;
- p->hw.i2c.addr = CONFIG_POWER_BD71837_I2C_ADDR;
- p->hw.i2c.tx_num = 1;
- p->bus = bus;
+int power_init_board(void) +{
- struct pmic *p;
- int ldo[] = {BD718XX_LDO5_VOLT, BD718XX_LDO6_VOLT,
BD71837_LDO7_VOLT};
- u32 val;
- int i, rv;
- setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1);
* Init PMIC
- rv = power_bd71837_init(CONFIG_POWER_BD71837_I2C_BUS);
- if (rv) {
log_err("%s: power_bd71837_init(%d) error %d\n", __func__,
CONFIG_POWER_BD71837_I2C_BUS, rv);
goto out;
- p = pmic_get(BD718XX_REGULATOR_DRIVER);
- if (!p) {
log_err("%s: pmic_get(%s) failed\n", __func__, BD718XX_REGULATOR_DRIVER);
rv = -ENODEV;
goto out;
- rv = pmic_probe(p);
- if (rv) {
log_err("%s: pmic_probe() error %d\n", __func__, rv);
goto out;
* Unlock all regs
- pmic_reg_write(p, BD718XX_REGLOCK, 0);
- /* find the reset cause */
- pmic_reg_read(p, 0x29, &val);
- log_debug("%s: reset cause %d\n", __func__, val);
* Reconfigure default voltages and disable:
* - BUCK3: VDD_GPU_0V9 (1.00 -> 0.90)
* - BUCK4: VDD_VPU_0V9 (1.00 -> 0.90)
- pmic_reg_write(p, BD71837_BUCK3_VOLT_RUN, 0x14);
- pmic_reg_write(p, BD71837_BUCK4_VOLT_RUN, 0x14);
* Enable PHYs voltages: LDO5-7
- for (i = 0; i < ARRAY_SIZE(ldo); i++) {
rv = pmic_reg_read(p, ldo[i], &val);
if (rv) {
log_err("%s: pmic_read(%x) error %d\n", __func__,
ldo[i], rv);
continue;
pmic_reg_write(p, ldo[i], val | LDO_VOLT_EN);
- udelay(500);
- rv = 0;
+out:
- return rv;
+int usb_gadget_handle_interrupts(void) +{
- dwc3_uboot_handle_interrupt(0);
+static void dwc3_nxp_usb_phy_init(struct dwc3_device *dwc3) +{
- u32 RegData;
- RegData = readl(dwc3->base + USB_PHY_CTRL1);
- RegData &= ~(USB_PHY_CTRL1_VDATSRCENB0 | USB_PHY_CTRL1_VDATDETENB0 |
USB_PHY_CTRL1_COMMONONN);
- RegData |= USB_PHY_CTRL1_RESET | USB_PHY_CTRL1_ATERESET;
- writel(RegData, dwc3->base + USB_PHY_CTRL1);
- RegData = readl(dwc3->base + USB_PHY_CTRL0);
- RegData |= USB_PHY_CTRL0_REF_SSP_EN;
- RegData &= ~USB_PHY_CTRL0_SSC_RANGE_MASK;
- RegData |= USB_PHY_CTRL0_SSC_RANGE_4003PPM;
- writel(RegData, dwc3->base + USB_PHY_CTRL0);
- RegData = readl(dwc3->base + USB_PHY_CTRL2);
- RegData |= USB_PHY_CTRL2_TXENABLEN0;
- writel(RegData, dwc3->base + USB_PHY_CTRL2);
- RegData &= ~(USB_PHY_CTRL1_RESET | USB_PHY_CTRL1_ATERESET);
- /* Disable rx term override */
- RegData = readl(dwc3->base + USB_PHY_CTRL6);
- RegData &= ~USB_PHY_CTRL6_RXTERM_OVERRIDE_SEL;
- writel(RegData, dwc3->base + USB_PHY_CTRL6);
+static struct dwc3_device dwc3_device0_data = {
- .maximum_speed = USB_SPEED_HIGH,
- .base = USB1_BASE_ADDR,
- .dr_mode = USB_DR_MODE_PERIPHERAL,
- .index = 0,
+static struct dwc3_device dwc3_device1_data = {
- .base = USB2_BASE_ADDR,
- .dr_mode = USB_DR_MODE_HOST,
- .index = 1,
+int board_usb_init(int index, enum usb_init_type init) +{
- int ret = 0;
- printf("%s : index %d type %d\n", __func__, index, init);
- if (index == 0 && init == USB_INIT_DEVICE) {
dwc3_nxp_usb_phy_init(&dwc3_device0_data);
ret = dwc3_uboot_init(&dwc3_device0_data);
- if (index == 1 && init == USB_INIT_HOST) {
dwc3_nxp_usb_phy_init(&dwc3_device1_data);
ret = dwc3_uboot_init(&dwc3_device1_data);
- return ret;
+int board_usb_cleanup(int index, enum usb_init_type init) +{
- u32 RegData;
- struct dwc3_device *dwc3;
- printf("%s : %d\n", __func__, index);
dwc3 = &dwc3_device0_data;
dwc3 = &dwc3_device1_data;
- dwc3_uboot_exit(index);
- /* reset the phy */
- /* enable rx term override */
- RegData |= USB_PHY_CTRL6_RXTERM_OVERRIDE_SEL;
+void spl_board_init(void) +{
- if (is_usb_boot())
puts("USB Boot\n");
- else
puts("Normal Boot\n");
+void board_boot_order(u32 *spl_boot_list) +{
spl_boot_list[0] = BOOT_DEVICE_BOARD;
- else
spl_boot_list[0] = BOOT_DEVICE_MMC1;
+#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE)
+static const iomux_v3_cfg_t wdog_pads[] = {
- IMX8MQ_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL),
+void board_init_f(ulong dummy) +{
- int ret;
- struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR;
- arch_cpu_init();
- imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads));
- set_wdog_reset(wdog);
- init_uart_clk(CONSOLE_UART_CLK);
- imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads));
+#ifdef CONSOLE_ON_UART4
- gpio_direction_output(WIFI_EN, 1);
- board_early_init_f();
- timer_init();
- preloader_console_init();
- ret = spl_init();
- if (ret) {
log_err("spl_init() failed: %d\n", ret);
hang();
- enable_tzc380();
- printf("Initializing pinmux\n");
- init_pinmux();
- gpio_direction_output(LED_G, 1);
- gpio_direction_output(MOTO, 1);
- mdelay(50);
- gpio_direction_output(MOTO, 0);
- /* Enable and configure i2c buses not used below */
- setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2);
- setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info3);
- setup_i2c(3, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info4);
- power_init_board();
- disable_charger_bq25895();
- /* initialize this for M4 even if u-boot doesn't have SF_CMD */
- printf("Initializing ECSPI\n");
- board_ecspi_init();
- /* DDR initialization */
- printf("Initializing DRAM\n");
- spl_dram_init();
diff --git a/configs/librem5_defconfig b/configs/librem5_defconfig new file mode 100644 index 0000000000..dba20f1c8b --- /dev/null +++ b/configs/librem5_defconfig @@ -0,0 +1,142 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x3FE000 +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_SYS_I2C_MXC_I2C4=y +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mq-librem5-r4" +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_LIBREM5=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL=y +CONFIG_DEVRES=y +# CONFIG_SPL_DEVRES is not set +CONFIG_IMX_BOOTAUX=y +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_REMAKE_ELF=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y +# CONFIG_SYS_DEVICE_NULLDEV is not set +CONFIG_ARCH_MISC_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_USB_SDP_SUPPORT=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_CMD_MEMTEST=y +CONFIG_SYS_ALT_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_DM=y +# CONFIG_SPL_BLK is not set +CONFIG_BUTTON=y +CONFIG_BUTTON_GPIO=y +CONFIG_CLK_IMX8MQ=y +CONFIG_SAVED_DRAM_TIMING_BASE=0x40000000 +CONFIG_DMA=y +CONFIG_DMA_CHANNELS=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x43000000 +CONFIG_FASTBOOT_BUF_SIZE=0x40000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_UUU_SUPPORT=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_MMC_BOOT_SUPPORT=y +CONFIG_FASTBOOT_MMC_USER_SUPPORT=y +CONFIG_FASTBOOT_CMD_OEM_PARTCONF=y +CONFIG_FASTBOOT_CMD_OEM_BOOTBUS=y +# CONFIG_SPL_DM_GPIO is not set +CONFIG_GPIO_HOG=y +CONFIG_DM_GPIO_LOOKUP_LABEL=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +# CONFIG_SPL_DM_I2C is not set +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_SYS_I2C_EARLY_INIT=y +CONFIG_SYS_MXC_I2C1_SPEED=50000 +CONFIG_SYS_MXC_I2C2_SPEED=50000 +CONFIG_SYS_MXC_I2C3_SPEED=50000 +CONFIG_SYS_MXC_I2C4_SPEED=50000 +CONFIG_SYS_I2C_SPEED=50000 +CONFIG_LED=y +CONFIG_LED_BLINK=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_PWRSEQ=y +CONFIG_MMC_BROKEN_CD=y +# CONFIG_SPL_DM_MMC is not set +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_FSL_USDHC=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_DM_ETH=y +CONFIG_PHY=y +CONFIG_PHY_IMX8MQ_USB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_POWER_LEGACY=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_POWER_I2C=y +CONFIG_DM_RESET=y +CONFIG_MXC_UART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_MXC_SPI=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y +CONFIG_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Purism" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_SDP_LOADADDR=0x40400000 +CONFIG_USB_FUNCTION_ACM=y diff --git a/doc/board/index.rst b/doc/board/index.rst index f90a9cad45..ffa5def303 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -27,6 +27,7 @@ Board-specific doc nokia/index nxp/index openpiton/index
- purism/index qualcomm/index rockchip/index samsung/index
diff --git a/doc/board/purism/index.rst b/doc/board/purism/index.rst new file mode 100644 index 0000000000..a9cdc312d4 --- /dev/null +++ b/doc/board/purism/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+
+Purism SPC +==========
+.. toctree::
- :maxdepth: 2
- librem5
diff --git a/doc/board/purism/librem5.rst b/doc/board/purism/librem5.rst new file mode 100644 index 0000000000..61d9793ae9 --- /dev/null +++ b/doc/board/purism/librem5.rst @@ -0,0 +1,60 @@ +.. SPDX-License-Identifier: GPL-2.0+
+Librem5 +==========
+U-Boot for the Purism Librem5 phone
+Quick Start +-----------
+- Build the ARM Trusted firmware binary +- Get ddr and hdmi firmware +- Build U-Boot
+Get and Build the ARM Trusted firmware +--------------------------------------
+Note: srctree is U-Boot source directory +Get ATF from: https://source.puri.sm/Librem5/arm-trusted-firmware +branch: librem5
+.. code-block:: bash
- $ make PLAT=imx8mq CROSS_COMPILE=aarch64-linux-gnu- bl31
- $ cp build/imx8mq/release/bl31.bin $(builddir)
+Get the ddr and hdmi firmware +-----------------------------
- $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.15.bin
- $ chmod +x firmware-imx-8.15.bin
- $ ./firmware-imx-8.15.bin
- $ cp firmware-imx-8.15/firmware/hdmi/cadence/signed_hdmi_imx8m.bin $(builddir)
- $ cp firmware-imx-8.15/firmware/ddr/synopsys/lpddr4*.bin $(builddir)
+Build U-Boot +------------
- $ export CROSS_COMPILE=aarch64-linux-gnu-
- $ make librem5_defconfig
- $ make ARCH=arm
+Burn the flash.bin +------------------
+Use uuu to burn flash.bin. Power on the phone while holding vol+ to get it +into uuu mode.
- $ git clone https://source.puri.sm/Librem5/librem5-devkit-tools.git
- $ cd librem5-devkit-tools
- $ cp $(builddir)/flash.bin files/u-boot-librem5.imx
- $ uuu uuu_scripts/u-boot_flash_librem5.lst
+Reboot the phone. diff --git a/include/configs/librem5.h b/include/configs/librem5.h new file mode 100644 index 0000000000..8d21311a52 --- /dev/null +++ b/include/configs/librem5.h @@ -0,0 +1,113 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
- Copyright 2017 NXP
- Copyright 2018 Emcraft Systems
- Copyright 2019 Purism
+#ifndef __LIBREM5_H +#define __LIBREM5_H
+/* #define DEBUG */
+#include <version.h> +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h>
+#define CONFIG_SPL_MAX_SIZE (148 * 1024) +#define CONFIG_SYS_MONITOR_LEN (512 * 1024)
+#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_STACK 0x187FF0 +#define CONFIG_SPL_BSS_START_ADDR 0x00180000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 /* 512 KB */
+#define CONFIG_MALLOC_F_ADDR 0x182000 /* malloc f used before GD_FLG_FULL_MALLOC_INIT */
+#define CONFIG_SPL_ABORT_ON_RAW_IMAGE /* For RAW image gives a error info not panic */
+#define CONFIG_POWER_BD71837 +#define CONFIG_POWER_BD71837_I2C_BUS 0 +#define CONFIG_POWER_BD71837_I2C_ADDR 0x4B
+#endif /* CONFIG_SPL_BUILD*/
+#define CONFIG_SYS_FSL_USDHC_NUM 2
+#define CONFIG_USB_MAX_CONTROLLER_COUNT 1
+#define CONFIG_USBD_HS
+#define CONSOLE_ON_UART1
+#ifdef CONSOLE_ON_UART1 +#define CONFIG_MXC_UART_BASE UART1_BASE_ADDR +#define CONSOLE_UART_CLK 0 +#define CONSOLE "ttymxc0" +#elif defined(CONSOLE_ON_UART2) +#define CONFIG_MXC_UART_BASE UART2_BASE_ADDR +#define CONSOLE_UART_CLK 1 +#define CONSOLE "ttymxc1" +#elif defined(CONSOLE_ON_UART3) +#define CONFIG_MXC_UART_BASE UART3_BASE_ADDR +#define CONSOLE_UART_CLK 2 +#define CONSOLE "ttymxc2" +#elif defined(CONSOLE_ON_UART4) +#define CONFIG_MXC_UART_BASE UART4_BASE_ADDR +#define CONSOLE_UART_CLK 3 +#define CONSOLE "ttymxc3" +#else +#define CONFIG_MXC_UART_BASE UART1_BASE_ADDR +#define CONSOLE_UART_CLK 0 +#define CONSOLE "ttymxc0" +#endif
+#ifndef CONFIG_SPL_BUILD +#define BOOT_TARGET_DEVICES(func) \
- func(MMC, mmc, 0) \
- func(USB, usb, 0) \
- func(DHCP, dhcp, na)
+#include <config_distro_bootcmd.h> +#else +#define BOOTENV +#endif
+/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \
- "scriptaddr=0x80000000\0" \
- "pxefile_addr_r=0x80100000\0" \
- "kernel_addr_r=0x80800000\0" \
- "fdt_addr_r=0x84800000\0" \
- "ramdisk_addr_r=0x85000000\0" \
- "console=" CONSOLE ",115200\0" \
- "bootargs=u_boot_version=" PLAIN_VERSION "\0" \
- "stdin=usbacm,serial\0" \
- "stdout=usbacm,serial\0" \
- "stderr=usbacm,serial\0" \
- BOOTENV
+/* Link Definitions */
+#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x80000 +#define CONFIG_SYS_INIT_SP_OFFSET \
- (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
+#define CONFIG_SYS_INIT_SP_ADDR \
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
+#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 +#define PHYS_SDRAM_SIZE 0xc0000000 /* 3GB LPDDR4 one Rank */
+/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \
sizeof(CONFIG_SYS_PROMPT) + 16)
+#define CONFIG_SYS_FSL_ESDHC_ADDR 0
Hi Stefano,
On 2022-05-23 02:36, Stefano Babic wrote:
On 06.05.22 14:44, Angus Ainslie wrote:
Initial commit of Librem5 u-boot and SPL
Signed-off-by: Angus Ainslie angus@akkea.ca Co-developed-by: Sebastian Krzyszkowiak sebastian.krzyszkowiak@puri.sm Signed-off-by: Sebastian Krzyszkowiak sebastian.krzyszkowiak@puri.sm
Hi Angus,
with "configs: get rid of build warnings due to SPL_USB_DWC3_GENERIC" most issues are solved, but a TI board is still broken.
I'll resend the patch that includes a fix for the aarch64 board.
A second issue is for the blob signed_dp_imx8m.bin, it should be done like for signed_hdmi.bin to avoid CI breakages.
Here the result of pipeline:
https://source.denx.de/u-boot/custodians/u-boot-imx/-/jobs/437965
I see that the imx8mq_evk does not fail CI build but I'm not seeing how the missing signed_hdmi.bin file is handled. Any hints ?
Thanks Angus
Best regards, Stefano
On Tue, May 24, 2022 at 07:15:01AM -0700, Angus Ainslie wrote:
Hi Stefano,
Hi Angus,
You need to use binman to handle it, does arch/arm/dts/imx8mq-u-boot.dtsi provide some clues?
Hi Stefano,
Hi Angus,
Currently the librem5-r4-u-boot.dtsi ( text below ) includes imx8mq-u-boot.dtsi and I tried deleting the signed-hdmi and including a signed-dp in it's place. Now instead of an error about a missing "signed_hdmi_imx8m.bin" I get an error about a missing "signed_dp_imx8m.bin" so I know I'm having an effect but not enough of one.
// SPDX-License-Identifier: (GPL-2.0 OR MIT)
#include "imx8mq-u-boot.dtsi"
&pinctrl_uart1 { u-boot,dm-spl; };
&uart1 { /* console */ u-boot,dm-spl; };
&binman { /delete-node/ signed-hdmi;
signed-dp { filename = "signed_dp_imx8m.bin";
signed-dp-imx8m { filename = "signed_dp_imx8m.bin"; type = "blob-ext"; }; }; };
Angus Ainslie
Stefano Babic
