[PATCH v10 00/18] RISC-V SiFive FU540 support SPL
This series add support for SPL to FU540. U-Boot SPL can boot from L2 LIM (0x0800_0000) and jump to OpenSBI(FW_DYNAMIC firmware) and U-Boot proper from MMC devices.
This series depends on: [1] https://patchwork.ozlabs.org/patch/1281853 [2] https://patchwork.ozlabs.org/patch/1281852
All these together is available for testing here [3] [3] https://github.com/pragnesh26992/u-boot/tree/spl
How to test this patch: 1) Go to OpenSBI-dir : make PLATFORM=generic FW_DYNAMIC=y 2) export OPENSBI=<path/to/opensbi/build/platform/generic/firmware/fw_dynamic.bin> 3) Change to u-boot-dir 4) make sifive_fu540_defconfig 5) make all 6) Format the SD card (make sure the disk has GPT, otherwise use gdisk to switch)
# sudo sgdisk --clear \ > --set-alignment=2 \ > --new=1:34:2081 --change-name=1:loader1 --typecode=1:5B193300-FC78-40CD-8002-E86C45580B47 \ > --new=2:2082:10273 --change-name=2:loader2 --typecode=2:2E54B353-1271-4842-806F-E436D6AF6985 \ > --new=3:10274: --change-name=3:rootfs --typecode=3:0FC63DAF-8483-4772-8E79-3D69D8477DE4 \ > /dev/sda
7) sudo dd if=spl/u-boot-spl.bin of=/dev/sda seek=34 8) sudo dd if=u-boot.itb of=/dev/sda seek=2082
Changes in v10: - Update commit description for ethernet clock reset (https://patchwork.ozlabs.org/patch/1289003) - Update commit description for ddr clock initialization (https://patchwork.ozlabs.org/patch/1289000)
Changes in v9: - Remove cache related patches from this series sifive: dts: fu540: Enable L2 Cache in U-Boot (https://patchwork.ozlabs.org/patch/1286705) riscv: sifive: fu540: enable all cache ways from U-Boot proper (https://patchwork.ozlabs.org/patch/1286706) - Rename SiFive DDR driver from sdram_fu540.c to fu540_ddr.c and also do some typo correction in driver - Remove CONFIG_SPL_BUILD for __prci_ddr_release_reset() - Release ethernet clock reset instead of ethernet clock initialization (https://patchwork.ozlabs.org/patch/1286697) - Squash fu540 cpu patches (https://patchwork.ozlabs.org/patch/1286699) (https://patchwork.ozlabs.org/patch/1286700) - Use spl_boot_device() instead of board_boot_order()
Changes in v8: - Remove SPL_CRC7_SUPPORT Kconfig option and compile crc7.o when CONFIG_MMC_SPI selected - Add "TODO" in drivers/ram/sifive/sdram_fu540.c - Remove unnecessary TODO from drivers/clk/sifive/fu540-prci.c - Make fu540-hifive-unleashed-a00-sdram-ddr4.dtsi file dual-licensed - Add 2 new patches sifive: fu540: Add sample SD gpt partition layout (https://patchwork.ozlabs.org/patch/1092) sifive: fu540: Add U-Boot proper sector start (https://patchwork.ozlabs.org/patch/1093) - Remove patch riscv: Enable cpu clock if it is present (https://patchwork.ozlabs.org/patch/1281573) - Update doc/board/sifive/fu540.rst for PLATFORM=generic
Changes in v7: - Standardize SD gpt partition layout - Add delay for SiFive OTP driver - Use DM way for corepll and ddrpll - Add new cpu fu540 (arch/riscv/cpu/fu540) - Update document for FU540 (doc/board/sifive/fu540.rst)
Changes in v6: - Typo Correction - Make fu540-c000-u-boot.dtsi and hifive-unleashed-a00-u-boot.dtsi Dual Licensed - Sync Hifive unleashed dts from Linux - Add arch/riscv/fu540 for FU540 specific code
Changes in v5: - Return read/write bytes for sifive_otp_read and sifive_otp_write - Correct Palmer's email address
Changes in v4: - Split misc DM driver patch into multiple patches - Added new SPL_CRC7_SUPPORT Kconfig option - Added DM driver for DDR - Added clk_enable and clk_disable ops in SiFive PRCI driver - Added early clock initialization for SPL in SiFive PRCI driver - Added early clock initialization for SPL in SiFive PRCI driver - Added SPL config options in sifive_fu540_defconfig instead of creatiing a new config file for SPL - Update fu540.rst on how to build and flash U-boot SPL
Changes in v3: - Remove arch-fu540 and arch-sifive from arch/riscv/include/asm/ - Split SPL patches into DDR and SPL and spl defconfig - Update fu540/MAINTAINERS file - Update fu540.rst on how to build and flash U-boot SPL
Changes in v2: - Add DM driver Sifive OTP - Split SPL patches into multiple patches - Add a seprate patch for _image_binary_end and crc7.c - Add a seprate patch to add board -u-boot.dtsi files - Update FU540 RISC-V documentation
Jagan Teki (2): sifive: fu540: Add sample SD gpt partition layout sifive: fu540: Add U-Boot proper sector start
Pragnesh Patel (16): misc: add driver for the SiFive otp controller riscv: sifive: fu540: Use OTP DM driver for serial environment variable riscv: Add _image_binary_end for SPL lib: Makefile: build crc7.c when CONFIG_MMC_SPI riscv: sifive: dts: fu540: Add board -u-boot.dtsi files sifive: fu540: add ddr driver sifive: dts: fu540: Add DDR controller and phy register settings riscv: sifive: dts: fu540: add U-Boot dmc node clk: sifive: fu540-prci: Add clock enable and disable ops clk: sifive: fu540-prci: Add ddr clock initialization clk: sifive: fu540-prci: Release ethernet clock reset riscv: dts: sifive: Sync hifive-unleashed-a00 dts from linux riscv: cpu: fu540: Add support for cpu fu540 riscv: sifive: fu540: add SPL configuration configs: fu540: Add config options for U-Boot SPL doc: sifive: fu540: Add description for OpenSBI generic platform
arch/riscv/Kconfig | 1 + arch/riscv/cpu/fu540/Kconfig | 15 + arch/riscv/cpu/fu540/Makefile | 11 + arch/riscv/cpu/fu540/cpu.c | 22 + arch/riscv/cpu/fu540/dram.c | 38 + arch/riscv/cpu/fu540/spl.c | 23 + arch/riscv/cpu/u-boot-spl.lds | 1 + arch/riscv/dts/fu540-c000-u-boot.dtsi | 84 + arch/riscv/dts/fu540-c000.dtsi | 37 +- .../dts/fu540-hifive-unleashed-a00-ddr.dtsi | 1489 +++++++++++++++++ .../dts/hifive-unleashed-a00-u-boot.dtsi | 22 + arch/riscv/dts/hifive-unleashed-a00.dts | 9 + arch/riscv/include/asm/arch-fu540/clk.h | 14 + arch/riscv/include/asm/arch-fu540/gpio.h | 38 + arch/riscv/include/asm/arch-fu540/spl.h | 14 + board/sifive/fu540/Kconfig | 18 +- board/sifive/fu540/Makefile | 4 + board/sifive/fu540/fu540.c | 132 +- board/sifive/fu540/spl.c | 72 + common/spl/Kconfig | 3 +- configs/sifive_fu540_defconfig | 8 + doc/board/sifive/fu540.rst | 145 +- drivers/clk/sifive/fu540-prci.c | 177 +- drivers/misc/Kconfig | 7 + drivers/misc/Makefile | 1 + drivers/misc/sifive-otp.c | 273 +++ drivers/ram/Kconfig | 1 + drivers/ram/Makefile | 2 + drivers/ram/sifive/Kconfig | 13 + drivers/ram/sifive/Makefile | 6 + drivers/ram/sifive/fu540_ddr.c | 417 +++++ include/configs/sifive-fu540.h | 31 + lib/Makefile | 2 +- 33 files changed, 3025 insertions(+), 105 deletions(-) create mode 100644 arch/riscv/cpu/fu540/Kconfig create mode 100644 arch/riscv/cpu/fu540/Makefile create mode 100644 arch/riscv/cpu/fu540/cpu.c create mode 100644 arch/riscv/cpu/fu540/dram.c create mode 100644 arch/riscv/cpu/fu540/spl.c create mode 100644 arch/riscv/dts/fu540-c000-u-boot.dtsi create mode 100644 arch/riscv/dts/fu540-hifive-unleashed-a00-ddr.dtsi create mode 100644 arch/riscv/include/asm/arch-fu540/clk.h create mode 100644 arch/riscv/include/asm/arch-fu540/gpio.h create mode 100644 arch/riscv/include/asm/arch-fu540/spl.h create mode 100644 board/sifive/fu540/spl.c create mode 100644 drivers/misc/sifive-otp.c create mode 100644 drivers/ram/sifive/Kconfig create mode 100644 drivers/ram/sifive/Makefile create mode 100644 drivers/ram/sifive/fu540_ddr.c
Added a misc driver to handle OTP memory in SiFive SoCs.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com --- drivers/misc/Kconfig | 7 + drivers/misc/Makefile | 1 + drivers/misc/sifive-otp.c | 273 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 281 insertions(+) create mode 100644 drivers/misc/sifive-otp.c
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 766402745d..59f758661e 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -68,6 +68,13 @@ config ROCKCHIP_OTP addressing and a length or through child-nodes that are generated based on the e-fuse map retrieved from the DTS.
+config SIFIVE_OTP + bool "SiFive eMemory OTP driver" + depends on MISC + help + Enable support for reading and writing the eMemory OTP on the + SiFive SoCs. + config VEXPRESS_CONFIG bool "Enable support for Arm Versatile Express config bus" depends on MISC diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 68e0e7ad17..947bd3a647 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -59,6 +59,7 @@ obj-$(CONFIG_QFW) += qfw.o obj-$(CONFIG_ROCKCHIP_EFUSE) += rockchip-efuse.o obj-$(CONFIG_ROCKCHIP_OTP) += rockchip-otp.o obj-$(CONFIG_SANDBOX) += syscon_sandbox.o misc_sandbox.o +obj-$(CONFIG_SIFIVE_OTP) += sifive-otp.o obj-$(CONFIG_SMSC_LPC47M) += smsc_lpc47m.o obj-$(CONFIG_SMSC_SIO1007) += smsc_sio1007.o obj-$(CONFIG_STM32MP_FUSE) += stm32mp_fuse.o diff --git a/drivers/misc/sifive-otp.c b/drivers/misc/sifive-otp.c new file mode 100644 index 0000000000..6a788f540d --- /dev/null +++ b/drivers/misc/sifive-otp.c @@ -0,0 +1,273 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * This is a driver for the eMemory EG004K32TQ028XW01 NeoFuse + * One-Time-Programmable (OTP) memory used within the SiFive FU540. + * It is documented in the FU540 manual here: + * https://www.sifive.com/documentation/chips/freedom-u540-c000-manual/ + * + * Copyright (C) 2018 Philipp Hug philipp@hug.cx + * Copyright (C) 2018 Joey Hewitt joey@joeyhewitt.com + * + * Copyright (C) 2020 SiFive, Inc + */ + +/* + * The FU540 stores 4096x32 bit (16KiB) values. + * Index 0x00-0xff are reserved for SiFive internal use. (first 1KiB) + * Right now first 1KiB is used to store only serial number. + */ + +#include <common.h> +#include <dm/device.h> +#include <dm/read.h> +#include <linux/io.h> +#include <misc.h> + +#define BYTES_PER_FUSE 4 + +#define PA_RESET_VAL 0x00 +#define PAS_RESET_VAL 0x00 +#define PAIO_RESET_VAL 0x00 +#define PDIN_RESET_VAL 0x00 +#define PTM_RESET_VAL 0x00 + +#define PCLK_ENABLE_VAL BIT(0) +#define PCLK_DISABLE_VAL 0x00 + +#define PWE_WRITE_ENABLE BIT(0) +#define PWE_WRITE_DISABLE 0x00 + +#define PTM_FUSE_PROGRAM_VAL BIT(1) + +#define PCE_ENABLE_INPUT BIT(0) +#define PCE_DISABLE_INPUT 0x00 + +#define PPROG_ENABLE_INPUT BIT(0) +#define PPROG_DISABLE_INPUT 0x00 + +#define PTRIM_ENABLE_INPUT BIT(0) +#define PTRIM_DISABLE_INPUT 0x00 + +#define PDSTB_DEEP_STANDBY_ENABLE BIT(0) +#define PDSTB_DEEP_STANDBY_DISABLE 0x00 + +/* Tpw - Program Pulse width delay */ +#define TPW_DELAY 20 + +/* Tpwi - Program Pulse interval delay */ +#define TPWI_DELAY 5 + +/* Tasp - Program address setup delay */ +#define TASP_DELAY 1 + +/* Tcd - read data access delay */ +#define TCD_DELAY 40 + +/* Tkl - clok pulse low delay */ +#define TKL_DELAY 10 + +/* Tms - PTM mode setup delay */ +#define TMS_DELAY 1 + +struct sifive_otp_regs { + u32 pa; /* Address input */ + u32 paio; /* Program address input */ + u32 pas; /* Program redundancy cell selection input */ + u32 pce; /* OTP Macro enable input */ + u32 pclk; /* Clock input */ + u32 pdin; /* Write data input */ + u32 pdout; /* Read data output */ + u32 pdstb; /* Deep standby mode enable input (active low) */ + u32 pprog; /* Program mode enable input */ + u32 ptc; /* Test column enable input */ + u32 ptm; /* Test mode enable input */ + u32 ptm_rep;/* Repair function test mode enable input */ + u32 ptr; /* Test row enable input */ + u32 ptrim; /* Repair function enable input */ + u32 pwe; /* Write enable input (defines program cycle) */ +}; + +struct sifive_otp_platdata { + struct sifive_otp_regs __iomem *regs; + u32 total_fuses; +}; + +/* + * offset and size are assumed aligned to the size of the fuses (32-bit). + */ +static int sifive_otp_read(struct udevice *dev, int offset, + void *buf, int size) +{ + struct sifive_otp_platdata *plat = dev_get_platdata(dev); + struct sifive_otp_regs *regs = (struct sifive_otp_regs *)plat->regs; + + /* Check if offset and size are multiple of BYTES_PER_FUSE */ + if ((size % BYTES_PER_FUSE) || (offset % BYTES_PER_FUSE)) { + printf("%s: size and offset must be multiple of 4.\n", + __func__); + return -EINVAL; + } + + int fuseidx = offset / BYTES_PER_FUSE; + int fusecount = size / BYTES_PER_FUSE; + + /* check bounds */ + if (offset < 0 || size < 0) + return -EINVAL; + if (fuseidx >= plat->total_fuses) + return -EINVAL; + if ((fuseidx + fusecount) > plat->total_fuses) + return -EINVAL; + + u32 fusebuf[fusecount]; + + /* init OTP */ + writel(PDSTB_DEEP_STANDBY_ENABLE, ®s->pdstb); + writel(PTRIM_ENABLE_INPUT, ®s->ptrim); + writel(PCE_ENABLE_INPUT, ®s->pce); + + /* read all requested fuses */ + for (unsigned int i = 0; i < fusecount; i++, fuseidx++) { + writel(fuseidx, ®s->pa); + + /* cycle clock to read */ + writel(PCLK_ENABLE_VAL, ®s->pclk); + ndelay(TCD_DELAY * 1000); + writel(PCLK_DISABLE_VAL, ®s->pclk); + ndelay(TKL_DELAY * 1000); + + /* read the value */ + fusebuf[i] = readl(®s->pdout); + } + + /* shut down */ + writel(PCE_DISABLE_INPUT, ®s->pce); + writel(PTRIM_DISABLE_INPUT, ®s->ptrim); + writel(PDSTB_DEEP_STANDBY_DISABLE, ®s->pdstb); + + /* copy out */ + memcpy(buf, fusebuf, size); + + return size; +} + +/* + * Caution: + * OTP can be written only once, so use carefully. + * + * offset and size are assumed aligned to the size of the fuses (32-bit). + */ +static int sifive_otp_write(struct udevice *dev, int offset, + const void *buf, int size) +{ + struct sifive_otp_platdata *plat = dev_get_platdata(dev); + struct sifive_otp_regs *regs = (struct sifive_otp_regs *)plat->regs; + + /* Check if offset and size are multiple of BYTES_PER_FUSE */ + if ((size % BYTES_PER_FUSE) || (offset % BYTES_PER_FUSE)) { + printf("%s: size and offset must be multiple of 4.\n", + __func__); + return -EINVAL; + } + + int fuseidx = offset / BYTES_PER_FUSE; + int fusecount = size / BYTES_PER_FUSE; + u32 *write_buf = (u32 *)buf; + u32 write_data; + int i, pas, bit; + + /* check bounds */ + if (offset < 0 || size < 0) + return -EINVAL; + if (fuseidx >= plat->total_fuses) + return -EINVAL; + if ((fuseidx + fusecount) > plat->total_fuses) + return -EINVAL; + + /* init OTP */ + writel(PDSTB_DEEP_STANDBY_ENABLE, ®s->pdstb); + writel(PTRIM_ENABLE_INPUT, ®s->ptrim); + + /* reset registers */ + writel(PCLK_DISABLE_VAL, ®s->pclk); + writel(PA_RESET_VAL, ®s->pa); + writel(PAS_RESET_VAL, ®s->pas); + writel(PAIO_RESET_VAL, ®s->paio); + writel(PDIN_RESET_VAL, ®s->pdin); + writel(PWE_WRITE_DISABLE, ®s->pwe); + writel(PTM_FUSE_PROGRAM_VAL, ®s->ptm); + ndelay(TMS_DELAY * 1000); + + writel(PCE_ENABLE_INPUT, ®s->pce); + writel(PPROG_ENABLE_INPUT, ®s->pprog); + + /* write all requested fuses */ + for (i = 0; i < fusecount; i++, fuseidx++) { + writel(fuseidx, ®s->pa); + write_data = *(write_buf++); + + for (pas = 0; pas < 2; pas++) { + writel(pas, ®s->pas); + + for (bit = 0; bit < 32; bit++) { + writel(bit, ®s->paio); + writel(((write_data >> bit) & 1), + ®s->pdin); + ndelay(TASP_DELAY * 1000); + + writel(PWE_WRITE_ENABLE, ®s->pwe); + udelay(TPW_DELAY); + writel(PWE_WRITE_DISABLE, ®s->pwe); + udelay(TPWI_DELAY); + } + } + + writel(PAS_RESET_VAL, ®s->pas); + } + + /* shut down */ + writel(PWE_WRITE_DISABLE, ®s->pwe); + writel(PPROG_DISABLE_INPUT, ®s->pprog); + writel(PCE_DISABLE_INPUT, ®s->pce); + writel(PTM_RESET_VAL, ®s->ptm); + + writel(PTRIM_DISABLE_INPUT, ®s->ptrim); + writel(PDSTB_DEEP_STANDBY_DISABLE, ®s->pdstb); + + return size; +} + +static int sifive_otp_ofdata_to_platdata(struct udevice *dev) +{ + struct sifive_otp_platdata *plat = dev_get_platdata(dev); + int ret; + + plat->regs = dev_read_addr_ptr(dev); + + ret = dev_read_u32(dev, "fuse-count", &plat->total_fuses); + if (ret < 0) { + pr_err(""fuse-count" not found\n"); + return ret; + } + + return 0; +} + +static const struct misc_ops sifive_otp_ops = { + .read = sifive_otp_read, + .write = sifive_otp_write, +}; + +static const struct udevice_id sifive_otp_ids[] = { + { .compatible = "sifive,fu540-c000-otp" }, + {} +}; + +U_BOOT_DRIVER(sifive_otp) = { + .name = "sifive_otp", + .id = UCLASS_MISC, + .of_match = sifive_otp_ids, + .ofdata_to_platdata = sifive_otp_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct sifive_otp_platdata), + .ops = &sifive_otp_ops, +};
Use the OTP DM driver to set the serial environment variable.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com --- arch/riscv/dts/fu540-c000-u-boot.dtsi | 14 +++ .../dts/hifive-unleashed-a00-u-boot.dtsi | 2 + board/sifive/fu540/Kconfig | 2 + board/sifive/fu540/fu540.c | 111 ++++++------------ 4 files changed, 57 insertions(+), 72 deletions(-) create mode 100644 arch/riscv/dts/fu540-c000-u-boot.dtsi
diff --git a/arch/riscv/dts/fu540-c000-u-boot.dtsi b/arch/riscv/dts/fu540-c000-u-boot.dtsi new file mode 100644 index 0000000000..db55773bd2 --- /dev/null +++ b/arch/riscv/dts/fu540-c000-u-boot.dtsi @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * (C) Copyright 2019 SiFive, Inc + */ + +/ { + soc { + otp: otp@10070000 { + compatible = "sifive,fu540-c000-otp"; + reg = <0x0 0x10070000 0x0 0x0FFF>; + fuse-count = <0x1000>; + }; + }; +}; diff --git a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi index 2aebfab646..9af089ffe7 100644 --- a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi +++ b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com */
+#include "fu540-c000-u-boot.dtsi" + / { aliases { spi0 = &qspi0; diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index 75661f35f8..4330ac4491 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -51,5 +51,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply SIFIVE_GPIO imply CMD_GPIO imply SMP + imply MISC + imply SIFIVE_OTP
endif diff --git a/board/sifive/fu540/fu540.c b/board/sifive/fu540/fu540.c index 47a2090251..540638c919 100644 --- a/board/sifive/fu540/fu540.c +++ b/board/sifive/fu540/fu540.c @@ -10,94 +10,61 @@ #include <dm.h> #include <linux/delay.h> #include <linux/io.h> +#include <misc.h> + +/* + * This define is a value used for error/unknown serial. + * If we really care about distinguishing errors and 0 is + * valid, we'll need a different one. + */ +#define ERROR_READING_SERIAL_NUMBER 0
#ifdef CONFIG_MISC_INIT_R
-#define FU540_OTP_BASE_ADDR 0x10070000 - -struct fu540_otp_regs { - u32 pa; /* Address input */ - u32 paio; /* Program address input */ - u32 pas; /* Program redundancy cell selection input */ - u32 pce; /* OTP Macro enable input */ - u32 pclk; /* Clock input */ - u32 pdin; /* Write data input */ - u32 pdout; /* Read data output */ - u32 pdstb; /* Deep standby mode enable input (active low) */ - u32 pprog; /* Program mode enable input */ - u32 ptc; /* Test column enable input */ - u32 ptm; /* Test mode enable input */ - u32 ptm_rep;/* Repair function test mode enable input */ - u32 ptr; /* Test row enable input */ - u32 ptrim; /* Repair function enable input */ - u32 pwe; /* Write enable input (defines program cycle) */ -} __packed; - -#define BYTES_PER_FUSE 4 -#define NUM_FUSES 0x1000 - -static int fu540_otp_read(int offset, void *buf, int size) +#if CONFIG_IS_ENABLED(SIFIVE_OTP) +static u32 otp_read_serialnum(struct udevice *dev) { - struct fu540_otp_regs *regs = (void __iomem *)FU540_OTP_BASE_ADDR; - unsigned int i; - int fuseidx = offset / BYTES_PER_FUSE; - int fusecount = size / BYTES_PER_FUSE; - u32 fusebuf[fusecount]; - - /* check bounds */ - if (offset < 0 || size < 0) - return -EINVAL; - if (fuseidx >= NUM_FUSES) - return -EINVAL; - if ((fuseidx + fusecount) > NUM_FUSES) - return -EINVAL; + int ret; + u32 serial[2] = {0};
- /* init OTP */ - writel(0x01, ®s->pdstb); /* wake up from stand-by */ - writel(0x01, ®s->ptrim); /* enable repair function */ - writel(0x01, ®s->pce); /* enable input */ - - /* read all requested fuses */ - for (i = 0; i < fusecount; i++, fuseidx++) { - writel(fuseidx, ®s->pa); - - /* cycle clock to read */ - writel(0x01, ®s->pclk); - mdelay(1); - writel(0x00, ®s->pclk); - mdelay(1); - - /* read the value */ - fusebuf[i] = readl(®s->pdout); - } + for (int i = 0xfe * 4; i > 0; i -= 8) { + ret = misc_read(dev, i, serial, sizeof(serial));
- /* shut down */ - writel(0, ®s->pce); - writel(0, ®s->ptrim); - writel(0, ®s->pdstb); + if (ret != sizeof(serial)) { + printf("%s: error reading serial from OTP\n", __func__); + break; + }
- /* copy out */ - memcpy(buf, fusebuf, size); + if (serial[0] == ~serial[1]) + return serial[0]; + }
- return 0; + return ERROR_READING_SERIAL_NUMBER; } +#endif
static u32 fu540_read_serialnum(void) { + u32 serial = ERROR_READING_SERIAL_NUMBER; + +#if CONFIG_IS_ENABLED(SIFIVE_OTP) + struct udevice *dev; int ret; - u32 serial[2] = {0};
- for (int i = 0xfe * 4; i > 0; i -= 8) { - ret = fu540_otp_read(i, serial, sizeof(serial)); - if (ret) { - printf("%s: error reading from OTP\n", __func__); - break; - } - if (serial[0] == ~serial[1]) - return serial[0]; + /* init OTP */ + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(sifive_otp), &dev); + + if (ret) { + debug("%s: could not find otp device\n", __func__); + return serial; }
- return 0; + /* read serial from OTP and set env var */ + serial = otp_read_serialnum(dev); +#endif + + return serial; }
static void fu540_setup_macaddr(u32 serialnum)
For SPL_SEPARATE_BSS, Device tree will be put at _image_binary_end
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Anup Patel anup.patel@wdc.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com --- arch/riscv/cpu/u-boot-spl.lds | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/riscv/cpu/u-boot-spl.lds b/arch/riscv/cpu/u-boot-spl.lds index 955dd3106d..d0495ce248 100644 --- a/arch/riscv/cpu/u-boot-spl.lds +++ b/arch/riscv/cpu/u-boot-spl.lds @@ -72,6 +72,7 @@ SECTIONS . = ALIGN(4);
_end = .; + _image_binary_end = .;
.bss : { __bss_start = .;
When build U-Boot SPL, meet an issue of undefined reference to 'crc7' for drivers/mmc/mmc_spi.c, so let's compile crc7.c when CONFIG_MMC_SPI selected.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/Makefile b/lib/Makefile index c6f862b0c2..a6812ea4a3 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -30,7 +30,6 @@ obj-y += charset.o endif endif obj-$(CONFIG_USB_TTY) += circbuf.o -obj-y += crc7.o obj-y += crc8.o obj-y += crc16.o obj-$(CONFIG_ERRNO_STR) += errno_str.o @@ -90,6 +89,7 @@ obj-y += errno.o obj-y += display_options.o CFLAGS_display_options.o := $(if $(BUILD_TAG),-DBUILD_TAG='"$(BUILD_TAG)"') obj-$(CONFIG_BCH) += bch.o +obj-$(CONFIG_MMC_SPI) += crc7.o obj-y += crc32.o obj-$(CONFIG_CRC32C) += crc32c.o obj-y += ctype.o
Devicetree files in FU540 platform is synced from Linux, like other platforms does. Apart from these U-Boot in FU540 would also require some U-Boot specific node like clint.
So, create board specific -u-boot.dtsi files. This would help of maintain U-Boot specific changes separately without touching Linux dts(i) files which indeed easy for syncing from Linux between releases.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Anup Patel anup.patel@wdc.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Bin Meng bmeng.cn@gmail.com --- arch/riscv/dts/fu540-c000-u-boot.dtsi | 61 +++++++++++++++++++ .../dts/hifive-unleashed-a00-u-boot.dtsi | 15 +++++ 2 files changed, 76 insertions(+)
diff --git a/arch/riscv/dts/fu540-c000-u-boot.dtsi b/arch/riscv/dts/fu540-c000-u-boot.dtsi index db55773bd2..fbfe296a03 100644 --- a/arch/riscv/dts/fu540-c000-u-boot.dtsi +++ b/arch/riscv/dts/fu540-c000-u-boot.dtsi @@ -4,11 +4,72 @@ */
/ { + cpus { + assigned-clocks = <&prci PRCI_CLK_COREPLL>; + assigned-clock-rates = <1000000000>; + u-boot,dm-spl; + cpu0: cpu@0 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + status = "okay"; + cpu0_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + cpu1: cpu@1 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + cpu1_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + cpu2: cpu@2 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + cpu2_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + cpu3: cpu@3 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + cpu3_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + cpu4: cpu@4 { + clocks = <&prci PRCI_CLK_COREPLL>; + u-boot,dm-spl; + cpu4_intc: interrupt-controller { + u-boot,dm-spl; + }; + }; + }; + soc { + u-boot,dm-spl; otp: otp@10070000 { compatible = "sifive,fu540-c000-otp"; reg = <0x0 0x10070000 0x0 0x0FFF>; fuse-count = <0x1000>; }; + clint@2000000 { + compatible = "riscv,clint0"; + interrupts-extended = <&cpu0_intc 3 &cpu0_intc 7 &cpu1_intc 3 &cpu1_intc 7 &cpu2_intc 3 &cpu2_intc 7 &cpu3_intc 3 &cpu3_intc 7 &cpu4_intc 3 &cpu4_intc 7>; + reg = <0x0 0x2000000 0x0 0xc0000>; + u-boot,dm-spl; + }; }; }; + +&prci { + u-boot,dm-spl; +}; + +&uart0 { + u-boot,dm-spl; +}; + +&qspi2 { + u-boot,dm-spl; +}; diff --git a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi index 9af089ffe7..9787332bf1 100644 --- a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi +++ b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi @@ -10,4 +10,19 @@ spi0 = &qspi0; spi2 = &qspi2; }; + + hfclk { + u-boot,dm-spl; + }; + + rtcclk { + u-boot,dm-spl; + }; + +}; + +&qspi2 { + mmc@0 { + u-boot,dm-spl; + }; };
Add driver for fu540 to support ddr initialization in SPL. This driver is based on FSBL (https://github.com/sifive/freedom-u540-c000-bootloader.git)
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com --- board/sifive/fu540/Kconfig | 2 + drivers/ram/Kconfig | 1 + drivers/ram/Makefile | 2 + drivers/ram/sifive/Kconfig | 13 + drivers/ram/sifive/Makefile | 6 + drivers/ram/sifive/fu540_ddr.c | 417 +++++++++++++++++++++++++++++++++ 6 files changed, 441 insertions(+) create mode 100644 drivers/ram/sifive/Kconfig create mode 100644 drivers/ram/sifive/Makefile create mode 100644 drivers/ram/sifive/fu540_ddr.c
diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index 4330ac4491..d41c305227 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -19,6 +19,8 @@ config SYS_TEXT_BASE config BOARD_SPECIFIC_OPTIONS # dummy def_bool y select GENERIC_RISCV + select RAM + select SPL_RAM if SPL imply CMD_DHCP imply CMD_EXT2 imply CMD_EXT4 diff --git a/drivers/ram/Kconfig b/drivers/ram/Kconfig index 56fea7c94c..66074d1feb 100644 --- a/drivers/ram/Kconfig +++ b/drivers/ram/Kconfig @@ -75,3 +75,4 @@ config IMXRT_SDRAM
source "drivers/ram/rockchip/Kconfig" source "drivers/ram/stm32mp1/Kconfig" +source "drivers/ram/sifive/Kconfig" diff --git a/drivers/ram/Makefile b/drivers/ram/Makefile index 5c897410c6..769c9d6218 100644 --- a/drivers/ram/Makefile +++ b/drivers/ram/Makefile @@ -17,3 +17,5 @@ obj-$(CONFIG_ARCH_MEDIATEK) += mediatek/ obj-$(CONFIG_K3_J721E_DDRSS) += k3-j721e/
obj-$(CONFIG_IMXRT_SDRAM) += imxrt_sdram.o + +obj-$(CONFIG_RAM_SIFIVE) += sifive/ diff --git a/drivers/ram/sifive/Kconfig b/drivers/ram/sifive/Kconfig new file mode 100644 index 0000000000..6aca22ab2a --- /dev/null +++ b/drivers/ram/sifive/Kconfig @@ -0,0 +1,13 @@ +config RAM_SIFIVE + bool "Ram drivers support for SiFive SoCs" + depends on RAM && RISCV + default y + help + This enables support for ram drivers of SiFive SoCs. + +config SIFIVE_FU540_DDR + bool "SiFive FU540 DDR driver" + depends on RAM_SIFIVE + default y if TARGET_SIFIVE_FU540 + help + This enables DDR support for the platforms based on SiFive FU540 SoC. diff --git a/drivers/ram/sifive/Makefile b/drivers/ram/sifive/Makefile new file mode 100644 index 0000000000..d66efec264 --- /dev/null +++ b/drivers/ram/sifive/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (c) 2020 SiFive, Inc +# + +obj-$(CONFIG_SIFIVE_FU540_DDR) += fu540_ddr.o diff --git a/drivers/ram/sifive/fu540_ddr.c b/drivers/ram/sifive/fu540_ddr.c new file mode 100644 index 0000000000..7ace6447eb --- /dev/null +++ b/drivers/ram/sifive/fu540_ddr.c @@ -0,0 +1,417 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * (C) Copyright 2020 SiFive, Inc. + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifive.com + */ + +#include <common.h> +#include <dm.h> +#include <init.h> +#include <ram.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> +#include <clk.h> +#include <wait_bit.h> + +#define DENALI_CTL_0 0 +#define DENALI_CTL_21 21 +#define DENALI_CTL_120 120 +#define DENALI_CTL_132 132 +#define DENALI_CTL_136 136 +#define DENALI_CTL_170 170 +#define DENALI_CTL_181 181 +#define DENALI_CTL_182 182 +#define DENALI_CTL_184 184 +#define DENALI_CTL_208 208 +#define DENALI_CTL_209 209 +#define DENALI_CTL_210 210 +#define DENALI_CTL_212 212 +#define DENALI_CTL_214 214 +#define DENALI_CTL_216 216 +#define DENALI_CTL_224 224 +#define DENALI_CTL_225 225 +#define DENALI_CTL_260 260 + +#define DENALI_PHY_1152 1152 +#define DENALI_PHY_1214 1214 + +#define PAYLOAD_DEST 0x80000000 +#define DDR_MEM_SIZE (8UL * 1024UL * 1024UL * 1024UL) + +#define DRAM_CLASS_OFFSET 8 +#define DRAM_CLASS_DDR4 0xA +#define OPTIMAL_RMODW_EN_OFFSET 0 +#define DISABLE_RD_INTERLEAVE_OFFSET 16 +#define OUT_OF_RANGE_OFFSET 1 +#define MULTIPLE_OUT_OF_RANGE_OFFSET 2 +#define PORT_COMMAND_CHANNEL_ERROR_OFFSET 7 +#define MC_INIT_COMPLETE_OFFSET 8 +#define LEVELING_OPERATION_COMPLETED_OFFSET 22 +#define DFI_PHY_WRLELV_MODE_OFFSET 24 +#define DFI_PHY_RDLVL_MODE_OFFSET 24 +#define DFI_PHY_RDLVL_GATE_MODE_OFFSET 0 +#define VREF_EN_OFFSET 24 +#define PORT_ADDR_PROTECTION_EN_OFFSET 0 +#define AXI0_ADDRESS_RANGE_ENABLE 8 +#define AXI0_RANGE_PROT_BITS_0_OFFSET 24 +#define RDLVL_EN_OFFSET 16 +#define RDLVL_GATE_EN_OFFSET 24 +#define WRLVL_EN_OFFSET 0 + +#define PHY_RX_CAL_DQ0_0_OFFSET 0 +#define PHY_RX_CAL_DQ1_0_OFFSET 16 + +struct fu540_ddrctl { + volatile u32 denali_ctl[265]; +}; + +struct fu540_ddrphy { + volatile u32 denali_phy[1215]; +}; + +/** + * struct fu540_ddr_info + * + * @dev : pointer for the device + * @info : UCLASS RAM information + * @ctl : DDR controller base address + * @phy : DDR PHY base address + * @ctrl : DDR control base address + * @physical_filter_ctrl : DDR physical filter control base address + */ +struct fu540_ddr_info { + struct udevice *dev; + struct ram_info info; + struct fu540_ddrctl *ctl; + struct fu540_ddrphy *phy; + struct clk ddr_clk; + u32 *physical_filter_ctrl; +}; + +#if defined(CONFIG_TPL_BUILD) || \ + (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + +struct fu540_ddr_params { + struct fu540_ddrctl pctl_regs; + struct fu540_ddrphy phy_regs; +}; + +struct sifive_dmc_plat { +#if CONFIG_IS_ENABLED(OF_PLATDATA) + struct dtd_sifive_fu540_dmc dtplat; +#else + struct fu540_ddr_params ddr_params; +#endif +}; + +/* + * TODO : It can be possible to use common sdram_copy_to_reg() API + * n: Unit bytes + */ +static void sdram_copy_to_reg(volatile u32 *dest, + volatile u32 *src, u32 n) +{ + int i; + + for (i = 0; i < n / sizeof(u32); i++) { + writel(*src, dest); + src++; + dest++; + } +} + +static void fu540_ddr_setup_range_protection(volatile u32 *ctl, u64 end_addr) +{ + u32 end_addr_16kblocks = ((end_addr >> 14) & 0x7FFFFF) - 1; + + writel(0x0, DENALI_CTL_209 + ctl); + writel(end_addr_16kblocks, DENALI_CTL_210 + ctl); + writel(0x0, DENALI_CTL_212 + ctl); + writel(0x0, DENALI_CTL_214 + ctl); + writel(0x0, DENALI_CTL_216 + ctl); + setbits_le32(DENALI_CTL_224 + ctl, + 0x3 << AXI0_RANGE_PROT_BITS_0_OFFSET); + writel(0xFFFFFFFF, DENALI_CTL_225 + ctl); + setbits_le32(DENALI_CTL_208 + ctl, 0x1 << AXI0_ADDRESS_RANGE_ENABLE); + setbits_le32(DENALI_CTL_208 + ctl, + 0x1 << PORT_ADDR_PROTECTION_EN_OFFSET); +} + +static void fu540_ddr_start(volatile u32 *ctl, u32 *physical_filter_ctrl, + u64 ddr_end) +{ + volatile u64 *filterreg = (volatile u64 *)physical_filter_ctrl; + + setbits_le32(DENALI_CTL_0 + ctl, 0x1); + + wait_for_bit_le32((void *)ctl + DENALI_CTL_132, + BIT(MC_INIT_COMPLETE_OFFSET), false, 100, false); + + /* Disable the BusBlocker in front of the controller AXI slave ports */ + filterreg[0] = 0x0f00000000000000UL | (ddr_end >> 2); +} + +static void fu540_ddr_check_errata(u32 regbase, u32 updownreg) +{ + u64 fails = 0; + u32 dq = 0; + u32 down, up; + u8 failc0, failc1; + u32 phy_rx_cal_dqn_0_offset; + + for (u32 bit = 0; bit < 2; bit++) { + if (bit == 0) { + phy_rx_cal_dqn_0_offset = + PHY_RX_CAL_DQ0_0_OFFSET; + } else { + phy_rx_cal_dqn_0_offset = + PHY_RX_CAL_DQ1_0_OFFSET; + } + + down = (updownreg >> + phy_rx_cal_dqn_0_offset) & 0x3F; + up = (updownreg >> + (phy_rx_cal_dqn_0_offset + 6)) & + 0x3F; + + failc0 = ((down == 0) && (up == 0x3F)); + failc1 = ((up == 0) && (down == 0x3F)); + + /* print error message on failure */ + if (failc0 || failc1) { + if (fails == 0) + printf("DDR error in fixing up\n"); + + fails |= (1 << dq); + + char slicelsc = '0'; + char slicemsc = '0'; + + slicelsc += (dq % 10); + slicemsc += (dq / 10); + printf("S "); + printf("%c", slicemsc); + printf("%c", slicelsc); + + if (failc0) + printf("U"); + else + printf("D"); + + printf("\n"); + } + dq++; + } +} + +static u64 fu540_ddr_phy_fixup(volatile u32 *ddrphyreg) +{ + u32 slicebase = 0; + + /* check errata condition */ + for (u32 slice = 0; slice < 8; slice++) { + u32 regbase = slicebase + 34; + + for (u32 reg = 0; reg < 4; reg++) { + u32 updownreg = readl(regbase + reg + ddrphyreg); + + fu540_ddr_check_errata(regbase, updownreg); + } + slicebase += 128; + } + + return(0); +} + +static u32 fu540_ddr_get_dram_class(volatile u32 *ctl) +{ + u32 reg = readl(DENALI_CTL_0 + ctl); + + return ((reg >> DRAM_CLASS_OFFSET) & 0xF); +} + +static int fu540_ddr_setup(struct udevice *dev) +{ + struct fu540_ddr_info *priv = dev_get_priv(dev); + struct sifive_dmc_plat *plat = dev_get_platdata(dev); + struct fu540_ddr_params *params = &plat->ddr_params; + volatile u32 *denali_ctl = priv->ctl->denali_ctl; + volatile u32 *denali_phy = priv->phy->denali_phy; + const u64 ddr_size = DDR_MEM_SIZE; + const u64 ddr_end = PAYLOAD_DEST + ddr_size; + int ret, i; + u32 physet; + + ret = dev_read_u32_array(dev, "sifive,ddr-params", + (u32 *)&plat->ddr_params, + sizeof(plat->ddr_params) / sizeof(u32)); + if (ret) { + printf("%s: Cannot read sifive,ddr-params %d\n", + __func__, ret); + return ret; + } + + sdram_copy_to_reg(priv->ctl->denali_ctl, + params->pctl_regs.denali_ctl, + sizeof(struct fu540_ddrctl)); + + /* phy reset */ + for (i = DENALI_PHY_1152; i <= DENALI_PHY_1214; i++) { + physet = params->phy_regs.denali_phy[i]; + priv->phy->denali_phy[i] = physet; + } + + for (i = 0; i < DENALI_PHY_1152; i++) { + physet = params->phy_regs.denali_phy[i]; + priv->phy->denali_phy[i] = physet; + } + + /* Disable read interleave DENALI_CTL_120 */ + setbits_le32(DENALI_CTL_120 + denali_ctl, + 1 << DISABLE_RD_INTERLEAVE_OFFSET); + + /* Disable optimal read/modify/write logic DENALI_CTL_21 */ + clrbits_le32(DENALI_CTL_21 + denali_ctl, 1 << OPTIMAL_RMODW_EN_OFFSET); + + /* Enable write Leveling DENALI_CTL_170 */ + setbits_le32(DENALI_CTL_170 + denali_ctl, (1 << WRLVL_EN_OFFSET) + | (1 << DFI_PHY_WRLELV_MODE_OFFSET)); + + /* Enable read leveling DENALI_CTL_181 and DENALI_CTL_260 */ + setbits_le32(DENALI_CTL_181 + denali_ctl, + 1 << DFI_PHY_RDLVL_MODE_OFFSET); + setbits_le32(DENALI_CTL_260 + denali_ctl, 1 << RDLVL_EN_OFFSET); + + /* Enable read leveling gate DENALI_CTL_260 and DENALI_CTL_182 */ + setbits_le32(DENALI_CTL_260 + denali_ctl, 1 << RDLVL_GATE_EN_OFFSET); + setbits_le32(DENALI_CTL_182 + denali_ctl, + 1 << DFI_PHY_RDLVL_GATE_MODE_OFFSET); + + if (fu540_ddr_get_dram_class(denali_ctl) == DRAM_CLASS_DDR4) { + /* Enable vref training DENALI_CTL_184 */ + setbits_le32(DENALI_CTL_184 + denali_ctl, 1 << VREF_EN_OFFSET); + } + + /* Mask off leveling completion interrupt DENALI_CTL_136 */ + setbits_le32(DENALI_CTL_136 + denali_ctl, + 1 << LEVELING_OPERATION_COMPLETED_OFFSET); + + /* Mask off MC init complete interrupt DENALI_CTL_136 */ + setbits_le32(DENALI_CTL_136 + denali_ctl, 1 << MC_INIT_COMPLETE_OFFSET); + + /* Mask off out of range interrupts DENALI_CTL_136 */ + setbits_le32(DENALI_CTL_136 + denali_ctl, (1 << OUT_OF_RANGE_OFFSET) + | (1 << MULTIPLE_OUT_OF_RANGE_OFFSET)); + + /* set up range protection */ + fu540_ddr_setup_range_protection(denali_ctl, DDR_MEM_SIZE); + + /* Mask off port command error interrupt DENALI_CTL_136 */ + setbits_le32(DENALI_CTL_136 + denali_ctl, + 1 << PORT_COMMAND_CHANNEL_ERROR_OFFSET); + + fu540_ddr_start(denali_ctl, priv->physical_filter_ctrl, ddr_end); + + fu540_ddr_phy_fixup(denali_phy); + + /* check size */ + priv->info.size = get_ram_size((long *)priv->info.base, + DDR_MEM_SIZE); + + debug("%s : %lx\n", __func__, priv->info.size); + + /* check memory access for all memory */ + if (priv->info.size != DDR_MEM_SIZE) { + printf("DDR invalid size : 0x%lx, expected 0x%lx\n", + priv->info.size, DDR_MEM_SIZE); + return -EINVAL; + } + + return 0; +} +#endif + +static int fu540_ddr_probe(struct udevice *dev) +{ + struct fu540_ddr_info *priv = dev_get_priv(dev); + +#if defined(CONFIG_TPL_BUILD) || \ + (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + struct regmap *map; + int ret; + u32 clock = 0; + + debug("FU540 DDR probe\n"); + priv->dev = dev; + + ret = regmap_init_mem(dev_ofnode(dev), &map); + if (ret) + return ret; + + ret = clk_get_by_index(dev, 0, &priv->ddr_clk); + if (ret) { + debug("clk get failed %d\n", ret); + return ret; + } + + ret = dev_read_u32(dev, "clock-frequency", &clock); + if (ret) { + debug("clock-frequency not found in dt %d\n", ret); + return ret; + } else { + ret = clk_set_rate(&priv->ddr_clk, clock); + if (ret < 0) { + debug("Could not set DDR clock\n"); + return ret; + } + } + + ret = clk_enable(&priv->ddr_clk); + priv->ctl = regmap_get_range(map, 0); + priv->phy = regmap_get_range(map, 1); + priv->physical_filter_ctrl = regmap_get_range(map, 2); + + priv->info.base = CONFIG_SYS_SDRAM_BASE; + + priv->info.size = 0; + return fu540_ddr_setup(dev); +#else + priv->info.base = CONFIG_SYS_SDRAM_BASE; + priv->info.size = DDR_MEM_SIZE; +#endif + return 0; +} + +static int fu540_ddr_get_info(struct udevice *dev, struct ram_info *info) +{ + struct fu540_ddr_info *priv = dev_get_priv(dev); + + *info = priv->info; + + return 0; +} + +static struct ram_ops fu540_ddr_ops = { + .get_info = fu540_ddr_get_info, +}; + +static const struct udevice_id fu540_ddr_ids[] = { + { .compatible = "sifive,fu540-c000-ddr" }, + { } +}; + +U_BOOT_DRIVER(fu540_ddr) = { + .name = "fu540_ddr", + .id = UCLASS_RAM, + .of_match = fu540_ddr_ids, + .ops = &fu540_ddr_ops, + .probe = fu540_ddr_probe, + .priv_auto_alloc_size = sizeof(struct fu540_ddr_info), +#if defined(CONFIG_TPL_BUILD) || \ + (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + .platdata_auto_alloc_size = sizeof(struct sifive_dmc_plat), +#endif +};
On Thu, May 14, 2020 at 7:53 PM Pragnesh Patel pragnesh.patel@sifive.com wrote:
select RAM
nits: please insert this line after the rockchip one, by following the alphabetical order
default y
help
help
- (C) Copyright 2020 SiFive, Inc.
- Authors:
- Pragnesh Patel pragnesh.patel@sifive.com
- struct fu540_ddr_info
- @dev : pointer for the device
- @info : UCLASS RAM information
- @ctl : DDR controller base address
- @phy : DDR PHY base address
- @ctrl : DDR control base address
- @physical_filter_ctrl : DDR physical filter control base address
struct clk ddr_clk;
nits: we don't support TPL, so the logic can be simplified to:
#if defined(CONFIG_SPL_BUILD)
Please fix this globally in this file
nits: OF_PLATDATA is not supported. Drop this?
+#else
+#endif +};
[snip]
Regards, Bin
Hi Bin,
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 17 May 2020 17:38 To: Pragnesh Patel pragnesh.patel@sifive.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Atish Patra atish.patra@wdc.com; Palmer Dabbelt palmerdabbelt@google.com; Paul Walmsley paul.walmsley@sifive.com; Jagan Teki jagan@amarulasolutions.com; Anup Patel anup.patel@wdc.com; Sagar Kadam sagar.kadam@sifive.com; Rick Chen rick@andestech.com; Palmer Dabbelt palmer@dabbelt.com; Kever Yang kever.yang@rock-chips.com; YouMin Chen cym@rock-chips.com; Giulio Benetti giulio.benetti@benettiengineering.com; Kevin Scholz k-scholz@ti.com; Lokesh Vutla lokeshvutla@ti.com Subject: Re: [PATCH v10 06/18] sifive: fu540: add ddr driver
[External Email] Do not click links or attachments unless you recognize the sender and know the content is safe
select RAM
Will update in v11.
default y
help
help
SoC.
- Authors:
volatile u32 denali_phy[1215]; };
struct clk ddr_clk;
Will update in v11.
Yes, will update in v11.
struct dtd_sifive_fu540_dmc dtplat; #else
struct fu540_ddr_params ddr_params; #endif };
[snip]
Regards, Bin
Add DDR controller and phy register settings, taken from fsbl (https://github.com/sifive/freedom-u540-c000-bootloader.git)
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com --- .../dts/fu540-hifive-unleashed-a00-ddr.dtsi | 1489 +++++++++++++++++ 1 file changed, 1489 insertions(+) create mode 100644 arch/riscv/dts/fu540-hifive-unleashed-a00-ddr.dtsi
diff --git a/arch/riscv/dts/fu540-hifive-unleashed-a00-ddr.dtsi b/arch/riscv/dts/fu540-hifive-unleashed-a00-ddr.dtsi new file mode 100644 index 0000000000..6ed5ccdbcb --- /dev/null +++ b/arch/riscv/dts/fu540-hifive-unleashed-a00-ddr.dtsi @@ -0,0 +1,1489 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * (C) Copyright 2020 SiFive, Inc + */ + +&dmc { + sifive,ddr-params = < + 0x00000a00 /* DENALI_CTL_00_DATA */ + 0x00000000 /* DENALI_CTL_01_DATA */ + 0x00000000 /* DENALI_CTL_02_DATA */ + 0x00000000 /* DENALI_CTL_03_DATA */ + 0x00000000 /* DENALI_CTL_04_DATA */ + 0x00000000 /* DENALI_CTL_05_DATA */ + 0x0000000a /* DENALI_CTL_06_DATA */ + 0x0002d362 /* DENALI_CTL_07_DATA */ + 0x00071073 /* DENALI_CTL_08_DATA */ + 0x0a1c0255 /* DENALI_CTL_09_DATA */ + 0x1c1c0400 /* DENALI_CTL_10_DATA */ + 0x0404990b /* DENALI_CTL_11_DATA */ + 0x2b050405 /* DENALI_CTL_12_DATA */ + 0x0e0c081e /* DENALI_CTL_13_DATA */ + 0x08090914 /* DENALI_CTL_14_DATA */ + 0x00fde718 /* DENALI_CTL_15_DATA */ + 0x00180a05 /* DENALI_CTL_16_DATA */ + 0x008b130e /* DENALI_CTL_17_DATA */ + 0x01000118 /* DENALI_CTL_18_DATA */ + 0x0e032101 /* DENALI_CTL_19_DATA */ + 0x00000000 /* DENALI_CTL_20_DATA */ + 0x00000101 /* DENALI_CTL_21_DATA */ + 0x00000000 /* DENALI_CTL_22_DATA */ + 0x0a000000 /* DENALI_CTL_23_DATA */ + 0x00000000 /* DENALI_CTL_24_DATA */ + 0x01450100 /* DENALI_CTL_25_DATA */ + 0x00001c36 /* DENALI_CTL_26_DATA */ + 0x00000005 /* DENALI_CTL_27_DATA */ + 0x00170006 /* DENALI_CTL_28_DATA */ + 0x014e0300 /* DENALI_CTL_29_DATA */ + 0x03010000 /* DENALI_CTL_30_DATA */ + 0x000a0e00 /* DENALI_CTL_31_DATA */ + 0x04030200 /* DENALI_CTL_32_DATA */ + 0x0000031f /* DENALI_CTL_33_DATA */ + 0x00070004 /* DENALI_CTL_34_DATA */ + 0x00000000 /* DENALI_CTL_35_DATA */ + 0x00000000 /* DENALI_CTL_36_DATA */ + 0x00000000 /* DENALI_CTL_37_DATA */ + 0x00000000 /* DENALI_CTL_38_DATA */ + 0x00000000 /* DENALI_CTL_39_DATA */ + 0x00000000 /* DENALI_CTL_40_DATA */ + 0x00000000 /* DENALI_CTL_41_DATA */ + 0x00000000 /* DENALI_CTL_42_DATA */ + 0x00000000 /* DENALI_CTL_43_DATA */ + 0x00000000 /* DENALI_CTL_44_DATA */ + 0x00000000 /* DENALI_CTL_45_DATA */ + 0x00000000 /* DENALI_CTL_46_DATA */ + 0x00000000 /* DENALI_CTL_47_DATA */ + 0x00000000 /* DENALI_CTL_48_DATA */ + 0x00000000 /* DENALI_CTL_49_DATA */ + 0x00000000 /* DENALI_CTL_50_DATA */ + 0x00000000 /* DENALI_CTL_51_DATA */ + 0x00000000 /* DENALI_CTL_52_DATA */ + 0x00000000 /* DENALI_CTL_53_DATA */ + 0x00000000 /* DENALI_CTL_54_DATA */ + 0x00000000 /* DENALI_CTL_55_DATA */ + 0x00000000 /* DENALI_CTL_56_DATA */ + 0x00000000 /* DENALI_CTL_57_DATA */ + 0x00000000 /* DENALI_CTL_58_DATA */ + 0x00000000 /* DENALI_CTL_59_DATA */ + 0x00000424 /* DENALI_CTL_60_DATA */ + 0x00000201 /* DENALI_CTL_61_DATA */ + 0x00001008 /* DENALI_CTL_62_DATA */ + 0x00000000 /* DENALI_CTL_63_DATA */ + 0x00000200 /* DENALI_CTL_64_DATA */ + 0x00000000 /* DENALI_CTL_65_DATA */ + 0x00000481 /* DENALI_CTL_66_DATA */ + 0x00000400 /* DENALI_CTL_67_DATA */ + 0x00000424 /* DENALI_CTL_68_DATA */ + 0x00000201 /* DENALI_CTL_69_DATA */ + 0x00001008 /* DENALI_CTL_70_DATA */ + 0x00000000 /* DENALI_CTL_71_DATA */ + 0x00000200 /* DENALI_CTL_72_DATA */ + 0x00000000 /* DENALI_CTL_73_DATA */ + 0x00000481 /* DENALI_CTL_74_DATA */ + 0x00000400 /* DENALI_CTL_75_DATA */ + 0x01010000 /* DENALI_CTL_76_DATA */ + 0x00000000 /* DENALI_CTL_77_DATA */ + 0x00000000 /* DENALI_CTL_78_DATA */ + 0x00000000 /* DENALI_CTL_79_DATA */ + 0x00000000 /* DENALI_CTL_80_DATA */ + 0x00000000 /* DENALI_CTL_81_DATA */ + 0x00000000 /* DENALI_CTL_82_DATA */ + 0x00000000 /* DENALI_CTL_83_DATA */ + 0x00000000 /* DENALI_CTL_84_DATA */ + 0x00000000 /* DENALI_CTL_85_DATA */ + 0x00000000 /* DENALI_CTL_86_DATA */ + 0x00000000 /* DENALI_CTL_87_DATA */ + 0x00000000 /* DENALI_CTL_88_DATA */ + 0x00000000 /* DENALI_CTL_89_DATA */ + 0x00000000 /* DENALI_CTL_90_DATA */ + 0x00000000 /* DENALI_CTL_91_DATA */ + 0x00000000 /* DENALI_CTL_92_DATA */ + 0x00000000 /* DENALI_CTL_93_DATA */ + 0x00000000 /* DENALI_CTL_94_DATA */ + 0x00000000 /* DENALI_CTL_95_DATA */ + 0x00000000 /* DENALI_CTL_96_DATA */ + 0x00000000 /* DENALI_CTL_97_DATA */ + 0x00000000 /* DENALI_CTL_98_DATA */ + 0x00000000 /* DENALI_CTL_99_DATA */ + 0x00000000 /* DENALI_CTL_100_DATA */ + 0x00000000 /* DENALI_CTL_101_DATA */ + 0x00000000 /* DENALI_CTL_102_DATA */ + 0x00000000 /* DENALI_CTL_103_DATA */ + 0x00000000 /* DENALI_CTL_104_DATA */ + 0x00000003 /* DENALI_CTL_105_DATA */ + 0x00000000 /* DENALI_CTL_106_DATA */ + 0x00000000 /* DENALI_CTL_107_DATA */ + 0x00000000 /* DENALI_CTL_108_DATA */ + 0x00000000 /* DENALI_CTL_109_DATA */ + 0x01000000 /* DENALI_CTL_110_DATA */ + 0x00040000 /* DENALI_CTL_111_DATA */ + 0x00800200 /* DENALI_CTL_112_DATA */ + 0x00000200 /* DENALI_CTL_113_DATA */ + 0x00000040 /* DENALI_CTL_114_DATA */ + 0x01000100 /* DENALI_CTL_115_DATA */ + 0x0a000002 /* DENALI_CTL_116_DATA */ + 0x0101ffff /* DENALI_CTL_117_DATA */ + 0x01010101 /* DENALI_CTL_118_DATA */ + 0x01010101 /* DENALI_CTL_119_DATA */ + 0x0000010b /* DENALI_CTL_120_DATA */ + 0x00000c01 /* DENALI_CTL_121_DATA */ + 0x00000000 /* DENALI_CTL_122_DATA */ + 0x00000000 /* DENALI_CTL_123_DATA */ + 0x00000000 /* DENALI_CTL_124_DATA */ + 0x00000000 /* DENALI_CTL_125_DATA */ + 0x00030300 /* DENALI_CTL_126_DATA */ + 0x00000000 /* DENALI_CTL_127_DATA */ + 0x00010001 /* DENALI_CTL_128_DATA */ + 0x00000000 /* DENALI_CTL_129_DATA */ + 0x00000000 /* DENALI_CTL_130_DATA */ + 0x00000000 /* DENALI_CTL_131_DATA */ + 0x00000000 /* DENALI_CTL_132_DATA */ + 0x00000000 /* DENALI_CTL_133_DATA */ + 0x00000000 /* DENALI_CTL_134_DATA */ + 0x00000000 /* DENALI_CTL_135_DATA */ + 0x00000000 /* DENALI_CTL_136_DATA */ + 0x00000000 /* DENALI_CTL_137_DATA */ + 0x00000000 /* DENALI_CTL_138_DATA */ + 0x00000000 /* DENALI_CTL_139_DATA */ + 0x00000000 /* DENALI_CTL_140_DATA */ + 0x00000000 /* DENALI_CTL_141_DATA */ + 0x00000000 /* DENALI_CTL_142_DATA */ + 0x00000000 /* DENALI_CTL_143_DATA */ + 0x00000000 /* DENALI_CTL_144_DATA */ + 0x00000000 /* DENALI_CTL_145_DATA */ + 0x00000000 /* DENALI_CTL_146_DATA */ + 0x00000000 /* DENALI_CTL_147_DATA */ + 0x00000000 /* DENALI_CTL_148_DATA */ + 0x00000000 /* DENALI_CTL_149_DATA */ + 0x00000000 /* DENALI_CTL_150_DATA */ + 0x00000000 /* DENALI_CTL_151_DATA */ + 0x00000000 /* DENALI_CTL_152_DATA */ + 0x00000000 /* DENALI_CTL_153_DATA */ + 0x00000000 /* DENALI_CTL_154_DATA */ + 0x00000000 /* DENALI_CTL_155_DATA */ + 0x00000000 /* DENALI_CTL_156_DATA */ + 0x00000000 /* DENALI_CTL_157_DATA */ + 0x00000000 /* DENALI_CTL_158_DATA */ + 0x00000000 /* DENALI_CTL_159_DATA */ + 0x00000000 /* DENALI_CTL_160_DATA */ + 0x02010102 /* DENALI_CTL_161_DATA */ + 0x0107070d /* DENALI_CTL_162_DATA */ + 0x04040400 /* DENALI_CTL_163_DATA */ + 0x03000503 /* DENALI_CTL_164_DATA */ + 0x00000000 /* DENALI_CTL_165_DATA */ + 0x00000000 /* DENALI_CTL_166_DATA */ + 0x00000000 /* DENALI_CTL_167_DATA */ + 0x00000000 /* DENALI_CTL_168_DATA */ + 0x280d0000 /* DENALI_CTL_169_DATA */ + 0x01000000 /* DENALI_CTL_170_DATA */ + 0x00000000 /* DENALI_CTL_171_DATA */ + 0x00010001 /* DENALI_CTL_172_DATA */ + 0x00000000 /* DENALI_CTL_173_DATA */ + 0x00000000 /* DENALI_CTL_174_DATA */ + 0x00000000 /* DENALI_CTL_175_DATA */ + 0x00000000 /* DENALI_CTL_176_DATA */ + 0x00000000 /* DENALI_CTL_177_DATA */ + 0x00000000 /* DENALI_CTL_178_DATA */ + 0x00000000 /* DENALI_CTL_179_DATA */ + 0x00000000 /* DENALI_CTL_180_DATA */ + 0x01000000 /* DENALI_CTL_181_DATA */ + 0x00000001 /* DENALI_CTL_182_DATA */ + 0x00000100 /* DENALI_CTL_183_DATA */ + 0x00000101 /* DENALI_CTL_184_DATA */ + 0x67676701 /* DENALI_CTL_185_DATA */ + 0x67676767 /* DENALI_CTL_186_DATA */ + 0x67676767 /* DENALI_CTL_187_DATA */ + 0x67676767 /* DENALI_CTL_188_DATA */ + 0x67676767 /* DENALI_CTL_189_DATA */ + 0x67676767 /* DENALI_CTL_190_DATA */ + 0x67676767 /* DENALI_CTL_191_DATA */ + 0x67676767 /* DENALI_CTL_192_DATA */ + 0x67676767 /* DENALI_CTL_193_DATA */ + 0x01000067 /* DENALI_CTL_194_DATA */ + 0x00000001 /* DENALI_CTL_195_DATA */ + 0x00000101 /* DENALI_CTL_196_DATA */ + 0x00000000 /* DENALI_CTL_197_DATA */ + 0x00000000 /* DENALI_CTL_198_DATA */ + 0x00000000 /* DENALI_CTL_199_DATA */ + 0x00000000 /* DENALI_CTL_200_DATA */ + 0x00000000 /* DENALI_CTL_201_DATA */ + 0x00000000 /* DENALI_CTL_202_DATA */ + 0x00000000 /* DENALI_CTL_203_DATA */ + 0x00000000 /* DENALI_CTL_204_DATA */ + 0x00000000 /* DENALI_CTL_205_DATA */ + 0x00000000 /* DENALI_CTL_206_DATA */ + 0x00000000 /* DENALI_CTL_207_DATA */ + 0x00000001 /* DENALI_CTL_208_DATA */ + 0x00000000 /* DENALI_CTL_209_DATA */ + 0x007fffff /* DENALI_CTL_210_DATA */ + 0x00000000 /* DENALI_CTL_211_DATA */ + 0x007fffff /* DENALI_CTL_212_DATA */ + 0x00000000 /* DENALI_CTL_213_DATA */ + 0x007fffff /* DENALI_CTL_214_DATA */ + 0x00000000 /* DENALI_CTL_215_DATA */ + 0x007fffff /* DENALI_CTL_216_DATA */ + 0x00000000 /* DENALI_CTL_217_DATA */ + 0x007fffff /* DENALI_CTL_218_DATA */ + 0x00000000 /* DENALI_CTL_219_DATA */ + 0x007fffff /* DENALI_CTL_220_DATA */ + 0x00000000 /* DENALI_CTL_221_DATA */ + 0x007fffff /* DENALI_CTL_222_DATA */ + 0x00000000 /* DENALI_CTL_223_DATA */ + 0x037fffff /* DENALI_CTL_224_DATA */ + 0xffffffff /* DENALI_CTL_225_DATA */ + 0x000f000f /* DENALI_CTL_226_DATA */ + 0x00ffff03 /* DENALI_CTL_227_DATA */ + 0x000fffff /* DENALI_CTL_228_DATA */ + 0x0003000f /* DENALI_CTL_229_DATA */ + 0xffffffff /* DENALI_CTL_230_DATA */ + 0x000f000f /* DENALI_CTL_231_DATA */ + 0x00ffff03 /* DENALI_CTL_232_DATA */ + 0x000fffff /* DENALI_CTL_233_DATA */ + 0x0003000f /* DENALI_CTL_234_DATA */ + 0xffffffff /* DENALI_CTL_235_DATA */ + 0x000f000f /* DENALI_CTL_236_DATA */ + 0x00ffff03 /* DENALI_CTL_237_DATA */ + 0x000fffff /* DENALI_CTL_238_DATA */ + 0x0003000f /* DENALI_CTL_239_DATA */ + 0xffffffff /* DENALI_CTL_240_DATA */ + 0x000f000f /* DENALI_CTL_241_DATA */ + 0x00ffff03 /* DENALI_CTL_242_DATA */ + 0x000fffff /* DENALI_CTL_243_DATA */ + 0x6407000f /* DENALI_CTL_244_DATA */ + 0x01640001 /* DENALI_CTL_245_DATA */ + 0x00000000 /* DENALI_CTL_246_DATA */ + 0x00000000 /* DENALI_CTL_247_DATA */ + 0x00001700 /* DENALI_CTL_248_DATA */ + 0x00386c05 /* DENALI_CTL_249_DATA */ + 0x02000200 /* DENALI_CTL_250_DATA */ + 0x02000200 /* DENALI_CTL_251_DATA */ + 0x0000386c /* DENALI_CTL_252_DATA */ + 0x00023438 /* DENALI_CTL_253_DATA */ + 0x02020d10 /* DENALI_CTL_254_DATA */ + 0x00140303 /* DENALI_CTL_255_DATA */ + 0x00000000 /* DENALI_CTL_256_DATA */ + 0x00000000 /* DENALI_CTL_257_DATA */ + 0x00001403 /* DENALI_CTL_258_DATA */ + 0x00000000 /* DENALI_CTL_259_DATA */ + 0x00000000 /* DENALI_CTL_260_DATA */ + 0x00000000 /* DENALI_CTL_261_DATA */ + 0x00000000 /* DENALI_CTL_262_DATA */ + 0x0d010000 /* DENALI_CTL_263_DATA */ + 0x00000008 /* DENALI_CTL_264_DATA */ + 0x31706542 /* DENALI_PHY_00_DATA */ + 0x0004c008 /* DENALI_PHY_01_DATA */ + 0x000000da /* DENALI_PHY_02_DATA */ + 0x00000000 /* DENALI_PHY_03_DATA */ + 0x00000000 /* DENALI_PHY_04_DATA */ + 0x00010000 /* DENALI_PHY_05_DATA */ + 0x01DDDD90 /* DENALI_PHY_06_DATA */ + 0x01DDDD90 /* DENALI_PHY_07_DATA */ + 0x01030000 /* DENALI_PHY_08_DATA */ + 0x01000000 /* DENALI_PHY_09_DATA */ + 0x00c00000 /* DENALI_PHY_10_DATA */ + 0x00000007 /* DENALI_PHY_11_DATA */ + 0x00000000 /* DENALI_PHY_12_DATA */ + 0x00000000 /* DENALI_PHY_13_DATA */ + 0x04000408 /* DENALI_PHY_14_DATA */ + 0x00000408 /* DENALI_PHY_15_DATA */ + 0x00e4e400 /* DENALI_PHY_16_DATA */ + 0x00000000 /* DENALI_PHY_17_DATA */ + 0x00000000 /* DENALI_PHY_18_DATA */ + 0x00000000 /* DENALI_PHY_19_DATA */ + 0x00000000 /* DENALI_PHY_20_DATA */ + 0x00000000 /* DENALI_PHY_21_DATA */ + 0x00000000 /* DENALI_PHY_22_DATA */ + 0x00000000 /* DENALI_PHY_23_DATA */ + 0x00000000 /* DENALI_PHY_24_DATA */ + 0x00000000 /* DENALI_PHY_25_DATA */ + 0x00000000 /* DENALI_PHY_26_DATA */ + 0x00000000 /* DENALI_PHY_27_DATA */ + 0x00000000 /* DENALI_PHY_28_DATA */ + 0x00000000 /* DENALI_PHY_29_DATA */ + 0x00000000 /* DENALI_PHY_30_DATA */ + 0x00000000 /* DENALI_PHY_31_DATA */ + 0x00000000 /* DENALI_PHY_32_DATA */ + 0x00200000 /* DENALI_PHY_33_DATA */ + 0x00000000 /* DENALI_PHY_34_DATA */ + 0x00000000 /* DENALI_PHY_35_DATA */ + 0x00000000 /* DENALI_PHY_36_DATA */ + 0x00000000 /* DENALI_PHY_37_DATA */ + 0x00000000 /* DENALI_PHY_38_DATA */ + 0x00000000 /* DENALI_PHY_39_DATA */ + 0x02800280 /* DENALI_PHY_40_DATA */ + 0x02800280 /* DENALI_PHY_41_DATA */ + 0x02800280 /* DENALI_PHY_42_DATA */ + 0x02800280 /* DENALI_PHY_43_DATA */ + 0x00000280 /* DENALI_PHY_44_DATA */ + 0x00000000 /* DENALI_PHY_45_DATA */ + 0x00000000 /* DENALI_PHY_46_DATA */ + 0x00000000 /* DENALI_PHY_47_DATA */ + 0x00000000 /* DENALI_PHY_48_DATA */ + 0x00000000 /* DENALI_PHY_49_DATA */ + 0x00800080 /* DENALI_PHY_50_DATA */ + 0x00800080 /* DENALI_PHY_51_DATA */ + 0x00800080 /* DENALI_PHY_52_DATA */ + 0x00800080 /* DENALI_PHY_53_DATA */ + 0x00800080 /* DENALI_PHY_54_DATA */ + 0x00800080 /* DENALI_PHY_55_DATA */ + 0x00800080 /* DENALI_PHY_56_DATA */ + 0x00800080 /* DENALI_PHY_57_DATA */ + 0x00800080 /* DENALI_PHY_58_DATA */ + 0x000100da /* DENALI_PHY_59_DATA */ + 0x01000200 /* DENALI_PHY_60_DATA */ + 0x00000000 /* DENALI_PHY_61_DATA */ + 0x00000000 /* DENALI_PHY_62_DATA */ + 0x00000002 /* DENALI_PHY_63_DATA */ + 0x51313152 /* DENALI_PHY_64_DATA */ + 0x80013130 /* DENALI_PHY_65_DATA */ + 0x02000080 /* DENALI_PHY_66_DATA */ + 0x00100001 /* DENALI_PHY_67_DATA */ + 0x0c064208 /* DENALI_PHY_68_DATA */ + 0x000f0c0f /* DENALI_PHY_69_DATA */ + 0x01000140 /* DENALI_PHY_70_DATA */ + 0x0000000c /* DENALI_PHY_71_DATA */ + 0x00000000 /* DENALI_PHY_72_DATA */ + 0x00000000 /* DENALI_PHY_73_DATA */ + 0x00000000 /* DENALI_PHY_74_DATA */ + 0x00000000 /* DENALI_PHY_75_DATA */ + 0x00000000 /* DENALI_PHY_76_DATA */ + 0x00000000 /* DENALI_PHY_77_DATA */ + 0x00000000 /* DENALI_PHY_78_DATA */ + 0x00000000 /* DENALI_PHY_79_DATA */ + 0x00000000 /* DENALI_PHY_80_DATA */ + 0x00000000 /* DENALI_PHY_81_DATA */ + 0x00000000 /* DENALI_PHY_82_DATA */ + 0x00000000 /* DENALI_PHY_83_DATA */ + 0x00000000 /* DENALI_PHY_84_DATA */ + 0x00000000 /* DENALI_PHY_85_DATA */ + 0x00000000 /* DENALI_PHY_86_DATA */ + 0x00000000 /* DENALI_PHY_87_DATA */ + 0x00000000 /* DENALI_PHY_88_DATA */ + 0x00000000 /* DENALI_PHY_89_DATA */ + 0x00000000 /* DENALI_PHY_90_DATA */ + 0x00000000 /* DENALI_PHY_91_DATA */ + 0x00000000 /* DENALI_PHY_92_DATA */ + 0x00000000 /* DENALI_PHY_93_DATA */ + 0x00000000 /* DENALI_PHY_94_DATA */ + 0x00000000 /* DENALI_PHY_95_DATA */ + 0x00000000 /* DENALI_PHY_96_DATA */ + 0x00000000 /* DENALI_PHY_97_DATA */ + 0x00000000 /* DENALI_PHY_98_DATA */ + 0x00000000 /* DENALI_PHY_99_DATA */ + 0x00000000 /* DENALI_PHY_100_DATA */ + 0x00000000 /* DENALI_PHY_101_DATA */ + 0x00000000 /* DENALI_PHY_102_DATA */ + 0x00000000 /* DENALI_PHY_103_DATA */ + 0x00000000 /* DENALI_PHY_104_DATA */ + 0x00000000 /* DENALI_PHY_105_DATA */ + 0x00000000 /* DENALI_PHY_106_DATA */ + 0x00000000 /* DENALI_PHY_107_DATA */ + 0x00000000 /* DENALI_PHY_108_DATA */ + 0x00000000 /* DENALI_PHY_109_DATA */ + 0x00000000 /* DENALI_PHY_110_DATA */ + 0x00000000 /* DENALI_PHY_111_DATA */ + 0x00000000 /* DENALI_PHY_112_DATA */ + 0x00000000 /* DENALI_PHY_113_DATA */ + 0x00000000 /* DENALI_PHY_114_DATA */ + 0x00000000 /* DENALI_PHY_115_DATA */ + 0x00000000 /* DENALI_PHY_116_DATA */ + 0x00000000 /* DENALI_PHY_117_DATA */ + 0x00000000 /* DENALI_PHY_118_DATA */ + 0x00000000 /* DENALI_PHY_119_DATA */ + 0x00000000 /* DENALI_PHY_120_DATA */ + 0x00000000 /* DENALI_PHY_121_DATA */ + 0x00000000 /* DENALI_PHY_122_DATA */ + 0x00000000 /* DENALI_PHY_123_DATA */ + 0x00000000 /* DENALI_PHY_124_DATA */ + 0x00000000 /* DENALI_PHY_125_DATA */ + 0x00000000 /* DENALI_PHY_126_DATA */ + 0x00000000 /* DENALI_PHY_127_DATA */ + 0x40263571 /* DENALI_PHY_128_DATA */ + 0x0004c008 /* DENALI_PHY_129_DATA */ + 0x000000da /* DENALI_PHY_130_DATA */ + 0x00000000 /* DENALI_PHY_131_DATA */ + 0x00000000 /* DENALI_PHY_132_DATA */ + 0x00010000 /* DENALI_PHY_133_DATA */ + 0x01DDDD90 /* DENALI_PHY_134_DATA */ + 0x01DDDD90 /* DENALI_PHY_135_DATA */ + 0x01030000 /* DENALI_PHY_136_DATA */ + 0x01000000 /* DENALI_PHY_137_DATA */ + 0x00c00000 /* DENALI_PHY_138_DATA */ + 0x00000007 /* DENALI_PHY_139_DATA */ + 0x00000000 /* DENALI_PHY_140_DATA */ + 0x00000000 /* DENALI_PHY_141_DATA */ + 0x04000408 /* DENALI_PHY_142_DATA */ + 0x00000408 /* DENALI_PHY_143_DATA */ + 0x00e4e400 /* DENALI_PHY_144_DATA */ + 0x00000000 /* DENALI_PHY_145_DATA */ + 0x00000000 /* DENALI_PHY_146_DATA */ + 0x00000000 /* DENALI_PHY_147_DATA */ + 0x00000000 /* DENALI_PHY_148_DATA */ + 0x00000000 /* DENALI_PHY_149_DATA */ + 0x00000000 /* DENALI_PHY_150_DATA */ + 0x00000000 /* DENALI_PHY_151_DATA */ + 0x00000000 /* DENALI_PHY_152_DATA */ + 0x00000000 /* DENALI_PHY_153_DATA */ + 0x00000000 /* DENALI_PHY_154_DATA */ + 0x00000000 /* DENALI_PHY_155_DATA */ + 0x00000000 /* DENALI_PHY_156_DATA */ + 0x00000000 /* DENALI_PHY_157_DATA */ + 0x00000000 /* DENALI_PHY_158_DATA */ + 0x00000000 /* DENALI_PHY_159_DATA */ + 0x00000000 /* DENALI_PHY_160_DATA */ + 0x00200000 /* DENALI_PHY_161_DATA */ + 0x00000000 /* DENALI_PHY_162_DATA */ + 0x00000000 /* DENALI_PHY_163_DATA */ + 0x00000000 /* DENALI_PHY_164_DATA */ + 0x00000000 /* DENALI_PHY_165_DATA */ + 0x00000000 /* DENALI_PHY_166_DATA */ + 0x00000000 /* DENALI_PHY_167_DATA */ + 0x02800280 /* DENALI_PHY_168_DATA */ + 0x02800280 /* DENALI_PHY_169_DATA */ + 0x02800280 /* DENALI_PHY_170_DATA */ + 0x02800280 /* DENALI_PHY_171_DATA */ + 0x00000280 /* DENALI_PHY_172_DATA */ + 0x00000000 /* DENALI_PHY_173_DATA */ + 0x00000000 /* DENALI_PHY_174_DATA */ + 0x00000000 /* DENALI_PHY_175_DATA */ + 0x00000000 /* DENALI_PHY_176_DATA */ + 0x00000000 /* DENALI_PHY_177_DATA */ + 0x00800080 /* DENALI_PHY_178_DATA */ + 0x00800080 /* DENALI_PHY_179_DATA */ + 0x00800080 /* DENALI_PHY_180_DATA */ + 0x00800080 /* DENALI_PHY_181_DATA */ + 0x00800080 /* DENALI_PHY_182_DATA */ + 0x00800080 /* DENALI_PHY_183_DATA */ + 0x00800080 /* DENALI_PHY_184_DATA */ + 0x00800080 /* DENALI_PHY_185_DATA */ + 0x00800080 /* DENALI_PHY_186_DATA */ + 0x000100da /* DENALI_PHY_187_DATA */ + 0x01000200 /* DENALI_PHY_188_DATA */ + 0x00000000 /* DENALI_PHY_189_DATA */ + 0x00000000 /* DENALI_PHY_190_DATA */ + 0x00000002 /* DENALI_PHY_191_DATA */ + 0x51313152 /* DENALI_PHY_192_DATA */ + 0x80013130 /* DENALI_PHY_193_DATA */ + 0x02000080 /* DENALI_PHY_194_DATA */ + 0x00100001 /* DENALI_PHY_195_DATA */ + 0x0c064208 /* DENALI_PHY_196_DATA */ + 0x000f0c0f /* DENALI_PHY_197_DATA */ + 0x01000140 /* DENALI_PHY_198_DATA */ + 0x0000000c /* DENALI_PHY_199_DATA */ + 0x00000000 /* DENALI_PHY_200_DATA */ + 0x00000000 /* DENALI_PHY_201_DATA */ + 0x00000000 /* DENALI_PHY_202_DATA */ + 0x00000000 /* DENALI_PHY_203_DATA */ + 0x00000000 /* DENALI_PHY_204_DATA */ + 0x00000000 /* DENALI_PHY_205_DATA */ + 0x00000000 /* DENALI_PHY_206_DATA */ + 0x00000000 /* DENALI_PHY_207_DATA */ + 0x00000000 /* DENALI_PHY_208_DATA */ + 0x00000000 /* DENALI_PHY_209_DATA */ + 0x00000000 /* DENALI_PHY_210_DATA */ + 0x00000000 /* DENALI_PHY_211_DATA */ + 0x00000000 /* DENALI_PHY_212_DATA */ + 0x00000000 /* DENALI_PHY_213_DATA */ + 0x00000000 /* DENALI_PHY_214_DATA */ + 0x00000000 /* DENALI_PHY_215_DATA */ + 0x00000000 /* DENALI_PHY_216_DATA */ + 0x00000000 /* DENALI_PHY_217_DATA */ + 0x00000000 /* DENALI_PHY_218_DATA */ + 0x00000000 /* DENALI_PHY_219_DATA */ + 0x00000000 /* DENALI_PHY_220_DATA */ + 0x00000000 /* DENALI_PHY_221_DATA */ + 0x00000000 /* DENALI_PHY_222_DATA */ + 0x00000000 /* DENALI_PHY_223_DATA */ + 0x00000000 /* DENALI_PHY_224_DATA */ + 0x00000000 /* DENALI_PHY_225_DATA */ + 0x00000000 /* DENALI_PHY_226_DATA */ + 0x00000000 /* DENALI_PHY_227_DATA */ + 0x00000000 /* DENALI_PHY_228_DATA */ + 0x00000000 /* DENALI_PHY_229_DATA */ + 0x00000000 /* DENALI_PHY_230_DATA */ + 0x00000000 /* DENALI_PHY_231_DATA */ + 0x00000000 /* DENALI_PHY_232_DATA */ + 0x00000000 /* DENALI_PHY_233_DATA */ + 0x00000000 /* DENALI_PHY_234_DATA */ + 0x00000000 /* DENALI_PHY_235_DATA */ + 0x00000000 /* DENALI_PHY_236_DATA */ + 0x00000000 /* DENALI_PHY_237_DATA */ + 0x00000000 /* DENALI_PHY_238_DATA */ + 0x00000000 /* DENALI_PHY_239_DATA */ + 0x00000000 /* DENALI_PHY_240_DATA */ + 0x00000000 /* DENALI_PHY_241_DATA */ + 0x00000000 /* DENALI_PHY_242_DATA */ + 0x00000000 /* DENALI_PHY_243_DATA */ + 0x00000000 /* DENALI_PHY_244_DATA */ + 0x00000000 /* DENALI_PHY_245_DATA */ + 0x00000000 /* DENALI_PHY_246_DATA */ + 0x00000000 /* DENALI_PHY_247_DATA */ + 0x00000000 /* DENALI_PHY_248_DATA */ + 0x00000000 /* DENALI_PHY_249_DATA */ + 0x00000000 /* DENALI_PHY_250_DATA */ + 0x00000000 /* DENALI_PHY_251_DATA */ + 0x00000000 /* DENALI_PHY_252_DATA */ + 0x00000000 /* DENALI_PHY_253_DATA */ + 0x00000000 /* DENALI_PHY_254_DATA */ + 0x00000000 /* DENALI_PHY_255_DATA */ + 0x46052371 /* DENALI_PHY_256_DATA */ + 0x0004c008 /* DENALI_PHY_257_DATA */ + 0x000000da /* DENALI_PHY_258_DATA */ + 0x00000000 /* DENALI_PHY_259_DATA */ + 0x00000000 /* DENALI_PHY_260_DATA */ + 0x00010000 /* DENALI_PHY_261_DATA */ + 0x01DDDD90 /* DENALI_PHY_262_DATA */ + 0x01DDDD90 /* DENALI_PHY_263_DATA */ + 0x01030000 /* DENALI_PHY_264_DATA */ + 0x01000000 /* DENALI_PHY_265_DATA */ + 0x00c00000 /* DENALI_PHY_266_DATA */ + 0x00000007 /* DENALI_PHY_267_DATA */ + 0x00000000 /* DENALI_PHY_268_DATA */ + 0x00000000 /* DENALI_PHY_269_DATA */ + 0x04000408 /* DENALI_PHY_270_DATA */ + 0x00000408 /* DENALI_PHY_271_DATA */ + 0x00e4e400 /* DENALI_PHY_272_DATA */ + 0x00000000 /* DENALI_PHY_273_DATA */ + 0x00000000 /* DENALI_PHY_274_DATA */ + 0x00000000 /* DENALI_PHY_275_DATA */ + 0x00000000 /* DENALI_PHY_276_DATA */ + 0x00000000 /* DENALI_PHY_277_DATA */ + 0x00000000 /* DENALI_PHY_278_DATA */ + 0x00000000 /* DENALI_PHY_279_DATA */ + 0x00000000 /* DENALI_PHY_280_DATA */ + 0x00000000 /* DENALI_PHY_281_DATA */ + 0x00000000 /* DENALI_PHY_282_DATA */ + 0x00000000 /* DENALI_PHY_283_DATA */ + 0x00000000 /* DENALI_PHY_284_DATA */ + 0x00000000 /* DENALI_PHY_285_DATA */ + 0x00000000 /* DENALI_PHY_286_DATA */ + 0x00000000 /* DENALI_PHY_287_DATA */ + 0x00000000 /* DENALI_PHY_288_DATA */ + 0x00200000 /* DENALI_PHY_289_DATA */ + 0x00000000 /* DENALI_PHY_290_DATA */ + 0x00000000 /* DENALI_PHY_291_DATA */ + 0x00000000 /* DENALI_PHY_292_DATA */ + 0x00000000 /* DENALI_PHY_293_DATA */ + 0x00000000 /* DENALI_PHY_294_DATA */ + 0x00000000 /* DENALI_PHY_295_DATA */ + 0x02800280 /* DENALI_PHY_296_DATA */ + 0x02800280 /* DENALI_PHY_297_DATA */ + 0x02800280 /* DENALI_PHY_298_DATA */ + 0x02800280 /* DENALI_PHY_299_DATA */ + 0x00000280 /* DENALI_PHY_300_DATA */ + 0x00000000 /* DENALI_PHY_301_DATA */ + 0x00000000 /* DENALI_PHY_302_DATA */ + 0x00000000 /* DENALI_PHY_303_DATA */ + 0x00000000 /* DENALI_PHY_304_DATA */ + 0x00000000 /* DENALI_PHY_305_DATA */ + 0x00800080 /* DENALI_PHY_306_DATA */ + 0x00800080 /* DENALI_PHY_307_DATA */ + 0x00800080 /* DENALI_PHY_308_DATA */ + 0x00800080 /* DENALI_PHY_309_DATA */ + 0x00800080 /* DENALI_PHY_310_DATA */ + 0x00800080 /* DENALI_PHY_311_DATA */ + 0x00800080 /* DENALI_PHY_312_DATA */ + 0x00800080 /* DENALI_PHY_313_DATA */ + 0x00800080 /* DENALI_PHY_314_DATA */ + 0x000100da /* DENALI_PHY_315_DATA */ + 0x00000200 /* DENALI_PHY_316_DATA */ + 0x00000000 /* DENALI_PHY_317_DATA */ + 0x00000000 /* DENALI_PHY_318_DATA */ + 0x00000002 /* DENALI_PHY_319_DATA */ + 0x51313152 /* DENALI_PHY_320_DATA */ + 0x80013130 /* DENALI_PHY_321_DATA */ + 0x02000080 /* DENALI_PHY_322_DATA */ + 0x00100001 /* DENALI_PHY_323_DATA */ + 0x0c064208 /* DENALI_PHY_324_DATA */ + 0x000f0c0f /* DENALI_PHY_325_DATA */ + 0x01000140 /* DENALI_PHY_326_DATA */ + 0x0000000c /* DENALI_PHY_327_DATA */ + 0x00000000 /* DENALI_PHY_328_DATA */ + 0x00000000 /* DENALI_PHY_329_DATA */ + 0x00000000 /* DENALI_PHY_330_DATA */ + 0x00000000 /* DENALI_PHY_331_DATA */ + 0x00000000 /* DENALI_PHY_332_DATA */ + 0x00000000 /* DENALI_PHY_333_DATA */ + 0x00000000 /* DENALI_PHY_334_DATA */ + 0x00000000 /* DENALI_PHY_335_DATA */ + 0x00000000 /* DENALI_PHY_336_DATA */ + 0x00000000 /* DENALI_PHY_337_DATA */ + 0x00000000 /* DENALI_PHY_338_DATA */ + 0x00000000 /* DENALI_PHY_339_DATA */ + 0x00000000 /* DENALI_PHY_340_DATA */ + 0x00000000 /* DENALI_PHY_341_DATA */ + 0x00000000 /* DENALI_PHY_342_DATA */ + 0x00000000 /* DENALI_PHY_343_DATA */ + 0x00000000 /* DENALI_PHY_344_DATA */ + 0x00000000 /* DENALI_PHY_345_DATA */ + 0x00000000 /* DENALI_PHY_346_DATA */ + 0x00000000 /* DENALI_PHY_347_DATA */ + 0x00000000 /* DENALI_PHY_348_DATA */ + 0x00000000 /* DENALI_PHY_349_DATA */ + 0x00000000 /* DENALI_PHY_350_DATA */ + 0x00000000 /* DENALI_PHY_351_DATA */ + 0x00000000 /* DENALI_PHY_352_DATA */ + 0x00000000 /* DENALI_PHY_353_DATA */ + 0x00000000 /* DENALI_PHY_354_DATA */ + 0x00000000 /* DENALI_PHY_355_DATA */ + 0x00000000 /* DENALI_PHY_356_DATA */ + 0x00000000 /* DENALI_PHY_357_DATA */ + 0x00000000 /* DENALI_PHY_358_DATA */ + 0x00000000 /* DENALI_PHY_359_DATA */ + 0x00000000 /* DENALI_PHY_360_DATA */ + 0x00000000 /* DENALI_PHY_361_DATA */ + 0x00000000 /* DENALI_PHY_362_DATA */ + 0x00000000 /* DENALI_PHY_363_DATA */ + 0x00000000 /* DENALI_PHY_364_DATA */ + 0x00000000 /* DENALI_PHY_365_DATA */ + 0x00000000 /* DENALI_PHY_366_DATA */ + 0x00000000 /* DENALI_PHY_367_DATA */ + 0x00000000 /* DENALI_PHY_368_DATA */ + 0x00000000 /* DENALI_PHY_369_DATA */ + 0x00000000 /* DENALI_PHY_370_DATA */ + 0x00000000 /* DENALI_PHY_371_DATA */ + 0x00000000 /* DENALI_PHY_372_DATA */ + 0x00000000 /* DENALI_PHY_373_DATA */ + 0x00000000 /* DENALI_PHY_374_DATA */ + 0x00000000 /* DENALI_PHY_375_DATA */ + 0x00000000 /* DENALI_PHY_376_DATA */ + 0x00000000 /* DENALI_PHY_377_DATA */ + 0x00000000 /* DENALI_PHY_378_DATA */ + 0x00000000 /* DENALI_PHY_379_DATA */ + 0x00000000 /* DENALI_PHY_380_DATA */ + 0x00000000 /* DENALI_PHY_381_DATA */ + 0x00000000 /* DENALI_PHY_382_DATA */ + 0x00000000 /* DENALI_PHY_383_DATA */ + 0x37654120 /* DENALI_PHY_384_DATA */ + 0x0004c008 /* DENALI_PHY_385_DATA */ + 0x000000da /* DENALI_PHY_386_DATA */ + 0x00000000 /* DENALI_PHY_387_DATA */ + 0x00000000 /* DENALI_PHY_388_DATA */ + 0x00010000 /* DENALI_PHY_389_DATA */ + 0x01DDDD90 /* DENALI_PHY_390_DATA */ + 0x01DDDD90 /* DENALI_PHY_391_DATA */ + 0x01030000 /* DENALI_PHY_392_DATA */ + 0x01000000 /* DENALI_PHY_393_DATA */ + 0x00c00000 /* DENALI_PHY_394_DATA */ + 0x00000007 /* DENALI_PHY_395_DATA */ + 0x00000000 /* DENALI_PHY_396_DATA */ + 0x00000000 /* DENALI_PHY_397_DATA */ + 0x04000408 /* DENALI_PHY_398_DATA */ + 0x00000408 /* DENALI_PHY_399_DATA */ + 0x00e4e400 /* DENALI_PHY_400_DATA */ + 0x00000000 /* DENALI_PHY_401_DATA */ + 0x00000000 /* DENALI_PHY_402_DATA */ + 0x00000000 /* DENALI_PHY_403_DATA */ + 0x00000000 /* DENALI_PHY_404_DATA */ + 0x00000000 /* DENALI_PHY_405_DATA */ + 0x00000000 /* DENALI_PHY_406_DATA */ + 0x00000000 /* DENALI_PHY_407_DATA */ + 0x00000000 /* DENALI_PHY_408_DATA */ + 0x00000000 /* DENALI_PHY_409_DATA */ + 0x00000000 /* DENALI_PHY_410_DATA */ + 0x00000000 /* DENALI_PHY_411_DATA */ + 0x00000000 /* DENALI_PHY_412_DATA */ + 0x00000000 /* DENALI_PHY_413_DATA */ + 0x00000000 /* DENALI_PHY_414_DATA */ + 0x00000000 /* DENALI_PHY_415_DATA */ + 0x00000000 /* DENALI_PHY_416_DATA */ + 0x00200000 /* DENALI_PHY_417_DATA */ + 0x00000000 /* DENALI_PHY_418_DATA */ + 0x00000000 /* DENALI_PHY_419_DATA */ + 0x00000000 /* DENALI_PHY_420_DATA */ + 0x00000000 /* DENALI_PHY_421_DATA */ + 0x00000000 /* DENALI_PHY_422_DATA */ + 0x00000000 /* DENALI_PHY_423_DATA */ + 0x02800280 /* DENALI_PHY_424_DATA */ + 0x02800280 /* DENALI_PHY_425_DATA */ + 0x02800280 /* DENALI_PHY_426_DATA */ + 0x02800280 /* DENALI_PHY_427_DATA */ + 0x00000280 /* DENALI_PHY_428_DATA */ + 0x00000000 /* DENALI_PHY_429_DATA */ + 0x00000000 /* DENALI_PHY_430_DATA */ + 0x00000000 /* DENALI_PHY_431_DATA */ + 0x00000000 /* DENALI_PHY_432_DATA */ + 0x00000000 /* DENALI_PHY_433_DATA */ + 0x00800080 /* DENALI_PHY_434_DATA */ + 0x00800080 /* DENALI_PHY_435_DATA */ + 0x00800080 /* DENALI_PHY_436_DATA */ + 0x00800080 /* DENALI_PHY_437_DATA */ + 0x00800080 /* DENALI_PHY_438_DATA */ + 0x00800080 /* DENALI_PHY_439_DATA */ + 0x00800080 /* DENALI_PHY_440_DATA */ + 0x00800080 /* DENALI_PHY_441_DATA */ + 0x00800080 /* DENALI_PHY_442_DATA */ + 0x000100da /* DENALI_PHY_443_DATA */ + 0x00000200 /* DENALI_PHY_444_DATA */ + 0x00000000 /* DENALI_PHY_445_DATA */ + 0x00000000 /* DENALI_PHY_446_DATA */ + 0x00000002 /* DENALI_PHY_447_DATA */ + 0x51313152 /* DENALI_PHY_448_DATA */ + 0x80013130 /* DENALI_PHY_449_DATA */ + 0x02000080 /* DENALI_PHY_450_DATA */ + 0x00100001 /* DENALI_PHY_451_DATA */ + 0x0c064208 /* DENALI_PHY_452_DATA */ + 0x000f0c0f /* DENALI_PHY_453_DATA */ + 0x01000140 /* DENALI_PHY_454_DATA */ + 0x0000000c /* DENALI_PHY_455_DATA */ + 0x00000000 /* DENALI_PHY_456_DATA */ + 0x00000000 /* DENALI_PHY_457_DATA */ + 0x00000000 /* DENALI_PHY_458_DATA */ + 0x00000000 /* DENALI_PHY_459_DATA */ + 0x00000000 /* DENALI_PHY_460_DATA */ + 0x00000000 /* DENALI_PHY_461_DATA */ + 0x00000000 /* DENALI_PHY_462_DATA */ + 0x00000000 /* DENALI_PHY_463_DATA */ + 0x00000000 /* DENALI_PHY_464_DATA */ + 0x00000000 /* DENALI_PHY_465_DATA */ + 0x00000000 /* DENALI_PHY_466_DATA */ + 0x00000000 /* DENALI_PHY_467_DATA */ + 0x00000000 /* DENALI_PHY_468_DATA */ + 0x00000000 /* DENALI_PHY_469_DATA */ + 0x00000000 /* DENALI_PHY_470_DATA */ + 0x00000000 /* DENALI_PHY_471_DATA */ + 0x00000000 /* DENALI_PHY_472_DATA */ + 0x00000000 /* DENALI_PHY_473_DATA */ + 0x00000000 /* DENALI_PHY_474_DATA */ + 0x00000000 /* DENALI_PHY_475_DATA */ + 0x00000000 /* DENALI_PHY_476_DATA */ + 0x00000000 /* DENALI_PHY_477_DATA */ + 0x00000000 /* DENALI_PHY_478_DATA */ + 0x00000000 /* DENALI_PHY_479_DATA */ + 0x00000000 /* DENALI_PHY_480_DATA */ + 0x00000000 /* DENALI_PHY_481_DATA */ + 0x00000000 /* DENALI_PHY_482_DATA */ + 0x00000000 /* DENALI_PHY_483_DATA */ + 0x00000000 /* DENALI_PHY_484_DATA */ + 0x00000000 /* DENALI_PHY_485_DATA */ + 0x00000000 /* DENALI_PHY_486_DATA */ + 0x00000000 /* DENALI_PHY_487_DATA */ + 0x00000000 /* DENALI_PHY_488_DATA */ + 0x00000000 /* DENALI_PHY_489_DATA */ + 0x00000000 /* DENALI_PHY_490_DATA */ + 0x00000000 /* DENALI_PHY_491_DATA */ + 0x00000000 /* DENALI_PHY_492_DATA */ + 0x00000000 /* DENALI_PHY_493_DATA */ + 0x00000000 /* DENALI_PHY_494_DATA */ + 0x00000000 /* DENALI_PHY_495_DATA */ + 0x00000000 /* DENALI_PHY_496_DATA */ + 0x00000000 /* DENALI_PHY_497_DATA */ + 0x00000000 /* DENALI_PHY_498_DATA */ + 0x00000000 /* DENALI_PHY_499_DATA */ + 0x00000000 /* DENALI_PHY_500_DATA */ + 0x00000000 /* DENALI_PHY_501_DATA */ + 0x00000000 /* DENALI_PHY_502_DATA */ + 0x00000000 /* DENALI_PHY_503_DATA */ + 0x00000000 /* DENALI_PHY_504_DATA */ + 0x00000000 /* DENALI_PHY_505_DATA */ + 0x00000000 /* DENALI_PHY_506_DATA */ + 0x00000000 /* DENALI_PHY_507_DATA */ + 0x00000000 /* DENALI_PHY_508_DATA */ + 0x00000000 /* DENALI_PHY_509_DATA */ + 0x00000000 /* DENALI_PHY_510_DATA */ + 0x00000000 /* DENALI_PHY_511_DATA */ + 0x24316750 /* DENALI_PHY_512_DATA */ + 0x0004c008 /* DENALI_PHY_513_DATA */ + 0x000000da /* DENALI_PHY_514_DATA */ + 0x00000000 /* DENALI_PHY_515_DATA */ + 0x00000000 /* DENALI_PHY_516_DATA */ + 0x00010000 /* DENALI_PHY_517_DATA */ + 0x01DDDD90 /* DENALI_PHY_518_DATA */ + 0x01DDDD90 /* DENALI_PHY_519_DATA */ + 0x01030000 /* DENALI_PHY_520_DATA */ + 0x01000000 /* DENALI_PHY_521_DATA */ + 0x00c00000 /* DENALI_PHY_522_DATA */ + 0x00000007 /* DENALI_PHY_523_DATA */ + 0x00000000 /* DENALI_PHY_524_DATA */ + 0x00000000 /* DENALI_PHY_525_DATA */ + 0x04000408 /* DENALI_PHY_526_DATA */ + 0x00000408 /* DENALI_PHY_527_DATA */ + 0x00e4e400 /* DENALI_PHY_528_DATA */ + 0x00000000 /* DENALI_PHY_529_DATA */ + 0x00000000 /* DENALI_PHY_530_DATA */ + 0x00000000 /* DENALI_PHY_531_DATA */ + 0x00000000 /* DENALI_PHY_532_DATA */ + 0x00000000 /* DENALI_PHY_533_DATA */ + 0x00000000 /* DENALI_PHY_534_DATA */ + 0x00000000 /* DENALI_PHY_535_DATA */ + 0x00000000 /* DENALI_PHY_536_DATA */ + 0x00000000 /* DENALI_PHY_537_DATA */ + 0x00000000 /* DENALI_PHY_538_DATA */ + 0x00000000 /* DENALI_PHY_539_DATA */ + 0x00000000 /* DENALI_PHY_540_DATA */ + 0x00000000 /* DENALI_PHY_541_DATA */ + 0x00000000 /* DENALI_PHY_542_DATA */ + 0x00000000 /* DENALI_PHY_543_DATA */ + 0x00000000 /* DENALI_PHY_544_DATA */ + 0x00200000 /* DENALI_PHY_545_DATA */ + 0x00000000 /* DENALI_PHY_546_DATA */ + 0x00000000 /* DENALI_PHY_547_DATA */ + 0x00000000 /* DENALI_PHY_548_DATA */ + 0x00000000 /* DENALI_PHY_549_DATA */ + 0x00000000 /* DENALI_PHY_550_DATA */ + 0x00000000 /* DENALI_PHY_551_DATA */ + 0x02800280 /* DENALI_PHY_552_DATA */ + 0x02800280 /* DENALI_PHY_553_DATA */ + 0x02800280 /* DENALI_PHY_554_DATA */ + 0x02800280 /* DENALI_PHY_555_DATA */ + 0x00000280 /* DENALI_PHY_556_DATA */ + 0x00000000 /* DENALI_PHY_557_DATA */ + 0x00000000 /* DENALI_PHY_558_DATA */ + 0x00000000 /* DENALI_PHY_559_DATA */ + 0x00000000 /* DENALI_PHY_560_DATA */ + 0x00000000 /* DENALI_PHY_561_DATA */ + 0x00800080 /* DENALI_PHY_562_DATA */ + 0x00800080 /* DENALI_PHY_563_DATA */ + 0x00800080 /* DENALI_PHY_564_DATA */ + 0x00800080 /* DENALI_PHY_565_DATA */ + 0x00800080 /* DENALI_PHY_566_DATA */ + 0x00800080 /* DENALI_PHY_567_DATA */ + 0x00800080 /* DENALI_PHY_568_DATA */ + 0x00800080 /* DENALI_PHY_569_DATA */ + 0x00800080 /* DENALI_PHY_570_DATA */ + 0x000100da /* DENALI_PHY_571_DATA */ + 0x00000200 /* DENALI_PHY_572_DATA */ + 0x00000000 /* DENALI_PHY_573_DATA */ + 0x00000000 /* DENALI_PHY_574_DATA */ + 0x00000002 /* DENALI_PHY_575_DATA */ + 0x51313152 /* DENALI_PHY_576_DATA */ + 0x80013130 /* DENALI_PHY_577_DATA */ + 0x02000080 /* DENALI_PHY_578_DATA */ + 0x00100001 /* DENALI_PHY_579_DATA */ + 0x0c064208 /* DENALI_PHY_580_DATA */ + 0x000f0c0f /* DENALI_PHY_581_DATA */ + 0x01000140 /* DENALI_PHY_582_DATA */ + 0x0000000c /* DENALI_PHY_583_DATA */ + 0x00000000 /* DENALI_PHY_584_DATA */ + 0x00000000 /* DENALI_PHY_585_DATA */ + 0x00000000 /* DENALI_PHY_586_DATA */ + 0x00000000 /* DENALI_PHY_587_DATA */ + 0x00000000 /* DENALI_PHY_588_DATA */ + 0x00000000 /* DENALI_PHY_589_DATA */ + 0x00000000 /* DENALI_PHY_590_DATA */ + 0x00000000 /* DENALI_PHY_591_DATA */ + 0x00000000 /* DENALI_PHY_592_DATA */ + 0x00000000 /* DENALI_PHY_593_DATA */ + 0x00000000 /* DENALI_PHY_594_DATA */ + 0x00000000 /* DENALI_PHY_595_DATA */ + 0x00000000 /* DENALI_PHY_596_DATA */ + 0x00000000 /* DENALI_PHY_597_DATA */ + 0x00000000 /* DENALI_PHY_598_DATA */ + 0x00000000 /* DENALI_PHY_599_DATA */ + 0x00000000 /* DENALI_PHY_600_DATA */ + 0x00000000 /* DENALI_PHY_601_DATA */ + 0x00000000 /* DENALI_PHY_602_DATA */ + 0x00000000 /* DENALI_PHY_603_DATA */ + 0x00000000 /* DENALI_PHY_604_DATA */ + 0x00000000 /* DENALI_PHY_605_DATA */ + 0x00000000 /* DENALI_PHY_606_DATA */ + 0x00000000 /* DENALI_PHY_607_DATA */ + 0x00000000 /* DENALI_PHY_608_DATA */ + 0x00000000 /* DENALI_PHY_609_DATA */ + 0x00000000 /* DENALI_PHY_610_DATA */ + 0x00000000 /* DENALI_PHY_611_DATA */ + 0x00000000 /* DENALI_PHY_612_DATA */ + 0x00000000 /* DENALI_PHY_613_DATA */ + 0x00000000 /* DENALI_PHY_614_DATA */ + 0x00000000 /* DENALI_PHY_615_DATA */ + 0x00000000 /* DENALI_PHY_616_DATA */ + 0x00000000 /* DENALI_PHY_617_DATA */ + 0x00000000 /* DENALI_PHY_618_DATA */ + 0x00000000 /* DENALI_PHY_619_DATA */ + 0x00000000 /* DENALI_PHY_620_DATA */ + 0x00000000 /* DENALI_PHY_621_DATA */ + 0x00000000 /* DENALI_PHY_622_DATA */ + 0x00000000 /* DENALI_PHY_623_DATA */ + 0x00000000 /* DENALI_PHY_624_DATA */ + 0x00000000 /* DENALI_PHY_625_DATA */ + 0x00000000 /* DENALI_PHY_626_DATA */ + 0x00000000 /* DENALI_PHY_627_DATA */ + 0x00000000 /* DENALI_PHY_628_DATA */ + 0x00000000 /* DENALI_PHY_629_DATA */ + 0x00000000 /* DENALI_PHY_630_DATA */ + 0x00000000 /* DENALI_PHY_631_DATA */ + 0x00000000 /* DENALI_PHY_632_DATA */ + 0x00000000 /* DENALI_PHY_633_DATA */ + 0x00000000 /* DENALI_PHY_634_DATA */ + 0x00000000 /* DENALI_PHY_635_DATA */ + 0x00000000 /* DENALI_PHY_636_DATA */ + 0x00000000 /* DENALI_PHY_637_DATA */ + 0x00000000 /* DENALI_PHY_638_DATA */ + 0x00000000 /* DENALI_PHY_639_DATA */ + 0x35174620 /* DENALI_PHY_640_DATA */ + 0x0004c008 /* DENALI_PHY_641_DATA */ + 0x000000da /* DENALI_PHY_642_DATA */ + 0x00000000 /* DENALI_PHY_643_DATA */ + 0x00000000 /* DENALI_PHY_644_DATA */ + 0x00010000 /* DENALI_PHY_645_DATA */ + 0x01DDDD90 /* DENALI_PHY_646_DATA */ + 0x01DDDD90 /* DENALI_PHY_647_DATA */ + 0x01030000 /* DENALI_PHY_648_DATA */ + 0x01000000 /* DENALI_PHY_649_DATA */ + 0x00c00000 /* DENALI_PHY_650_DATA */ + 0x00000007 /* DENALI_PHY_651_DATA */ + 0x00000000 /* DENALI_PHY_652_DATA */ + 0x00000000 /* DENALI_PHY_653_DATA */ + 0x04000408 /* DENALI_PHY_654_DATA */ + 0x00000408 /* DENALI_PHY_655_DATA */ + 0x00e4e400 /* DENALI_PHY_656_DATA */ + 0x00000000 /* DENALI_PHY_657_DATA */ + 0x00000000 /* DENALI_PHY_658_DATA */ + 0x00000000 /* DENALI_PHY_659_DATA */ + 0x00000000 /* DENALI_PHY_660_DATA */ + 0x00000000 /* DENALI_PHY_661_DATA */ + 0x00000000 /* DENALI_PHY_662_DATA */ + 0x00000000 /* DENALI_PHY_663_DATA */ + 0x00000000 /* DENALI_PHY_664_DATA */ + 0x00000000 /* DENALI_PHY_665_DATA */ + 0x00000000 /* DENALI_PHY_666_DATA */ + 0x00000000 /* DENALI_PHY_667_DATA */ + 0x00000000 /* DENALI_PHY_668_DATA */ + 0x00000000 /* DENALI_PHY_669_DATA */ + 0x00000000 /* DENALI_PHY_670_DATA */ + 0x00000000 /* DENALI_PHY_671_DATA */ + 0x00000000 /* DENALI_PHY_672_DATA */ + 0x00200000 /* DENALI_PHY_673_DATA */ + 0x00000000 /* DENALI_PHY_674_DATA */ + 0x00000000 /* DENALI_PHY_675_DATA */ + 0x00000000 /* DENALI_PHY_676_DATA */ + 0x00000000 /* DENALI_PHY_677_DATA */ + 0x00000000 /* DENALI_PHY_678_DATA */ + 0x00000000 /* DENALI_PHY_679_DATA */ + 0x02800280 /* DENALI_PHY_680_DATA */ + 0x02800280 /* DENALI_PHY_681_DATA */ + 0x02800280 /* DENALI_PHY_682_DATA */ + 0x02800280 /* DENALI_PHY_683_DATA */ + 0x00000280 /* DENALI_PHY_684_DATA */ + 0x00000000 /* DENALI_PHY_685_DATA */ + 0x00000000 /* DENALI_PHY_686_DATA */ + 0x00000000 /* DENALI_PHY_687_DATA */ + 0x00000000 /* DENALI_PHY_688_DATA */ + 0x00000000 /* DENALI_PHY_689_DATA */ + 0x00800080 /* DENALI_PHY_690_DATA */ + 0x00800080 /* DENALI_PHY_691_DATA */ + 0x00800080 /* DENALI_PHY_692_DATA */ + 0x00800080 /* DENALI_PHY_693_DATA */ + 0x00800080 /* DENALI_PHY_694_DATA */ + 0x00800080 /* DENALI_PHY_695_DATA */ + 0x00800080 /* DENALI_PHY_696_DATA */ + 0x00800080 /* DENALI_PHY_697_DATA */ + 0x00800080 /* DENALI_PHY_698_DATA */ + 0x000100da /* DENALI_PHY_699_DATA */ + 0x00000200 /* DENALI_PHY_700_DATA */ + 0x00000000 /* DENALI_PHY_701_DATA */ + 0x00000000 /* DENALI_PHY_702_DATA */ + 0x00000002 /* DENALI_PHY_703_DATA */ + 0x51313152 /* DENALI_PHY_704_DATA */ + 0x80013130 /* DENALI_PHY_705_DATA */ + 0x02000080 /* DENALI_PHY_706_DATA */ + 0x00100001 /* DENALI_PHY_707_DATA */ + 0x0c064208 /* DENALI_PHY_708_DATA */ + 0x000f0c0f /* DENALI_PHY_709_DATA */ + 0x01000140 /* DENALI_PHY_710_DATA */ + 0x0000000c /* DENALI_PHY_711_DATA */ + 0x00000000 /* DENALI_PHY_712_DATA */ + 0x00000000 /* DENALI_PHY_713_DATA */ + 0x00000000 /* DENALI_PHY_714_DATA */ + 0x00000000 /* DENALI_PHY_715_DATA */ + 0x00000000 /* DENALI_PHY_716_DATA */ + 0x00000000 /* DENALI_PHY_717_DATA */ + 0x00000000 /* DENALI_PHY_718_DATA */ + 0x00000000 /* DENALI_PHY_719_DATA */ + 0x00000000 /* DENALI_PHY_720_DATA */ + 0x00000000 /* DENALI_PHY_721_DATA */ + 0x00000000 /* DENALI_PHY_722_DATA */ + 0x00000000 /* DENALI_PHY_723_DATA */ + 0x00000000 /* DENALI_PHY_724_DATA */ + 0x00000000 /* DENALI_PHY_725_DATA */ + 0x00000000 /* DENALI_PHY_726_DATA */ + 0x00000000 /* DENALI_PHY_727_DATA */ + 0x00000000 /* DENALI_PHY_728_DATA */ + 0x00000000 /* DENALI_PHY_729_DATA */ + 0x00000000 /* DENALI_PHY_730_DATA */ + 0x00000000 /* DENALI_PHY_731_DATA */ + 0x00000000 /* DENALI_PHY_732_DATA */ + 0x00000000 /* DENALI_PHY_733_DATA */ + 0x00000000 /* DENALI_PHY_734_DATA */ + 0x00000000 /* DENALI_PHY_735_DATA */ + 0x00000000 /* DENALI_PHY_736_DATA */ + 0x00000000 /* DENALI_PHY_737_DATA */ + 0x00000000 /* DENALI_PHY_738_DATA */ + 0x00000000 /* DENALI_PHY_739_DATA */ + 0x00000000 /* DENALI_PHY_740_DATA */ + 0x00000000 /* DENALI_PHY_741_DATA */ + 0x00000000 /* DENALI_PHY_742_DATA */ + 0x00000000 /* DENALI_PHY_743_DATA */ + 0x00000000 /* DENALI_PHY_744_DATA */ + 0x00000000 /* DENALI_PHY_745_DATA */ + 0x00000000 /* DENALI_PHY_746_DATA */ + 0x00000000 /* DENALI_PHY_747_DATA */ + 0x00000000 /* DENALI_PHY_748_DATA */ + 0x00000000 /* DENALI_PHY_749_DATA */ + 0x00000000 /* DENALI_PHY_750_DATA */ + 0x00000000 /* DENALI_PHY_751_DATA */ + 0x00000000 /* DENALI_PHY_752_DATA */ + 0x00000000 /* DENALI_PHY_753_DATA */ + 0x00000000 /* DENALI_PHY_754_DATA */ + 0x00000000 /* DENALI_PHY_755_DATA */ + 0x00000000 /* DENALI_PHY_756_DATA */ + 0x00000000 /* DENALI_PHY_757_DATA */ + 0x00000000 /* DENALI_PHY_758_DATA */ + 0x00000000 /* DENALI_PHY_759_DATA */ + 0x00000000 /* DENALI_PHY_760_DATA */ + 0x00000000 /* DENALI_PHY_761_DATA */ + 0x00000000 /* DENALI_PHY_762_DATA */ + 0x00000000 /* DENALI_PHY_763_DATA */ + 0x00000000 /* DENALI_PHY_764_DATA */ + 0x00000000 /* DENALI_PHY_765_DATA */ + 0x00000000 /* DENALI_PHY_766_DATA */ + 0x00000000 /* DENALI_PHY_767_DATA */ + 0x15203476 /* DENALI_PHY_768_DATA */ + 0x0004c008 /* DENALI_PHY_769_DATA */ + 0x000000da /* DENALI_PHY_770_DATA */ + 0x00000000 /* DENALI_PHY_771_DATA */ + 0x00000000 /* DENALI_PHY_772_DATA */ + 0x00010000 /* DENALI_PHY_773_DATA */ + 0x01DDDD90 /* DENALI_PHY_774_DATA */ + 0x01DDDD90 /* DENALI_PHY_775_DATA */ + 0x01030000 /* DENALI_PHY_776_DATA */ + 0x01000000 /* DENALI_PHY_777_DATA */ + 0x00c00000 /* DENALI_PHY_778_DATA */ + 0x00000007 /* DENALI_PHY_779_DATA */ + 0x00000000 /* DENALI_PHY_780_DATA */ + 0x00000000 /* DENALI_PHY_781_DATA */ + 0x04000408 /* DENALI_PHY_782_DATA */ + 0x00000408 /* DENALI_PHY_783_DATA */ + 0x00e4e400 /* DENALI_PHY_784_DATA */ + 0x00000000 /* DENALI_PHY_785_DATA */ + 0x00000000 /* DENALI_PHY_786_DATA */ + 0x00000000 /* DENALI_PHY_787_DATA */ + 0x00000000 /* DENALI_PHY_788_DATA */ + 0x00000000 /* DENALI_PHY_789_DATA */ + 0x00000000 /* DENALI_PHY_790_DATA */ + 0x00000000 /* DENALI_PHY_791_DATA */ + 0x00000000 /* DENALI_PHY_792_DATA */ + 0x00000000 /* DENALI_PHY_793_DATA */ + 0x00000000 /* DENALI_PHY_794_DATA */ + 0x00000000 /* DENALI_PHY_795_DATA */ + 0x00000000 /* DENALI_PHY_796_DATA */ + 0x00000000 /* DENALI_PHY_797_DATA */ + 0x00000000 /* DENALI_PHY_798_DATA */ + 0x00000000 /* DENALI_PHY_799_DATA */ + 0x00000000 /* DENALI_PHY_800_DATA */ + 0x00200000 /* DENALI_PHY_801_DATA */ + 0x00000000 /* DENALI_PHY_802_DATA */ + 0x00000000 /* DENALI_PHY_803_DATA */ + 0x00000000 /* DENALI_PHY_804_DATA */ + 0x00000000 /* DENALI_PHY_805_DATA */ + 0x00000000 /* DENALI_PHY_806_DATA */ + 0x00000000 /* DENALI_PHY_807_DATA */ + 0x02800280 /* DENALI_PHY_808_DATA */ + 0x02800280 /* DENALI_PHY_809_DATA */ + 0x02800280 /* DENALI_PHY_810_DATA */ + 0x02800280 /* DENALI_PHY_811_DATA */ + 0x00000280 /* DENALI_PHY_812_DATA */ + 0x00000000 /* DENALI_PHY_813_DATA */ + 0x00000000 /* DENALI_PHY_814_DATA */ + 0x00000000 /* DENALI_PHY_815_DATA */ + 0x00000000 /* DENALI_PHY_816_DATA */ + 0x00000000 /* DENALI_PHY_817_DATA */ + 0x00800080 /* DENALI_PHY_818_DATA */ + 0x00800080 /* DENALI_PHY_819_DATA */ + 0x00800080 /* DENALI_PHY_820_DATA */ + 0x00800080 /* DENALI_PHY_821_DATA */ + 0x00800080 /* DENALI_PHY_822_DATA */ + 0x00800080 /* DENALI_PHY_823_DATA */ + 0x00800080 /* DENALI_PHY_824_DATA */ + 0x00800080 /* DENALI_PHY_825_DATA */ + 0x00800080 /* DENALI_PHY_826_DATA */ + 0x000100da /* DENALI_PHY_827_DATA */ + 0x00000200 /* DENALI_PHY_828_DATA */ + 0x00000000 /* DENALI_PHY_829_DATA */ + 0x00000000 /* DENALI_PHY_830_DATA */ + 0x00000002 /* DENALI_PHY_831_DATA */ + 0x51313152 /* DENALI_PHY_832_DATA */ + 0x80013130 /* DENALI_PHY_833_DATA */ + 0x02000080 /* DENALI_PHY_834_DATA */ + 0x00100001 /* DENALI_PHY_835_DATA */ + 0x0c064208 /* DENALI_PHY_836_DATA */ + 0x000f0c0f /* DENALI_PHY_837_DATA */ + 0x01000140 /* DENALI_PHY_838_DATA */ + 0x0000000c /* DENALI_PHY_839_DATA */ + 0x00000000 /* DENALI_PHY_840_DATA */ + 0x00000000 /* DENALI_PHY_841_DATA */ + 0x00000000 /* DENALI_PHY_842_DATA */ + 0x00000000 /* DENALI_PHY_843_DATA */ + 0x00000000 /* DENALI_PHY_844_DATA */ + 0x00000000 /* DENALI_PHY_845_DATA */ + 0x00000000 /* DENALI_PHY_846_DATA */ + 0x00000000 /* DENALI_PHY_847_DATA */ + 0x00000000 /* DENALI_PHY_848_DATA */ + 0x00000000 /* DENALI_PHY_849_DATA */ + 0x00000000 /* DENALI_PHY_850_DATA */ + 0x00000000 /* DENALI_PHY_851_DATA */ + 0x00000000 /* DENALI_PHY_852_DATA */ + 0x00000000 /* DENALI_PHY_853_DATA */ + 0x00000000 /* DENALI_PHY_854_DATA */ + 0x00000000 /* DENALI_PHY_855_DATA */ + 0x00000000 /* DENALI_PHY_856_DATA */ + 0x00000000 /* DENALI_PHY_857_DATA */ + 0x00000000 /* DENALI_PHY_858_DATA */ + 0x00000000 /* DENALI_PHY_859_DATA */ + 0x00000000 /* DENALI_PHY_860_DATA */ + 0x00000000 /* DENALI_PHY_861_DATA */ + 0x00000000 /* DENALI_PHY_862_DATA */ + 0x00000000 /* DENALI_PHY_863_DATA */ + 0x00000000 /* DENALI_PHY_864_DATA */ + 0x00000000 /* DENALI_PHY_865_DATA */ + 0x00000000 /* DENALI_PHY_866_DATA */ + 0x00000000 /* DENALI_PHY_867_DATA */ + 0x00000000 /* DENALI_PHY_868_DATA */ + 0x00000000 /* DENALI_PHY_869_DATA */ + 0x00000000 /* DENALI_PHY_870_DATA */ + 0x00000000 /* DENALI_PHY_871_DATA */ + 0x00000000 /* DENALI_PHY_872_DATA */ + 0x00000000 /* DENALI_PHY_873_DATA */ + 0x00000000 /* DENALI_PHY_874_DATA */ + 0x00000000 /* DENALI_PHY_875_DATA */ + 0x00000000 /* DENALI_PHY_876_DATA */ + 0x00000000 /* DENALI_PHY_877_DATA */ + 0x00000000 /* DENALI_PHY_878_DATA */ + 0x00000000 /* DENALI_PHY_879_DATA */ + 0x00000000 /* DENALI_PHY_880_DATA */ + 0x00000000 /* DENALI_PHY_881_DATA */ + 0x00000000 /* DENALI_PHY_882_DATA */ + 0x00000000 /* DENALI_PHY_883_DATA */ + 0x00000000 /* DENALI_PHY_884_DATA */ + 0x00000000 /* DENALI_PHY_885_DATA */ + 0x00000000 /* DENALI_PHY_886_DATA */ + 0x00000000 /* DENALI_PHY_887_DATA */ + 0x00000000 /* DENALI_PHY_888_DATA */ + 0x00000000 /* DENALI_PHY_889_DATA */ + 0x00000000 /* DENALI_PHY_890_DATA */ + 0x00000000 /* DENALI_PHY_891_DATA */ + 0x00000000 /* DENALI_PHY_892_DATA */ + 0x00000000 /* DENALI_PHY_893_DATA */ + 0x00000000 /* DENALI_PHY_894_DATA */ + 0x00000000 /* DENALI_PHY_895_DATA */ + 0x41753206 /* DENALI_PHY_896_DATA */ + 0x0004c008 /* DENALI_PHY_897_DATA */ + 0x000000da /* DENALI_PHY_898_DATA */ + 0x00000000 /* DENALI_PHY_899_DATA */ + 0x00000000 /* DENALI_PHY_900_DATA */ + 0x00010000 /* DENALI_PHY_901_DATA */ + 0x01DDDD90 /* DENALI_PHY_902_DATA */ + 0x01DDDD90 /* DENALI_PHY_903_DATA */ + 0x01030000 /* DENALI_PHY_904_DATA */ + 0x01000000 /* DENALI_PHY_905_DATA */ + 0x00c00000 /* DENALI_PHY_906_DATA */ + 0x00000007 /* DENALI_PHY_907_DATA */ + 0x00000000 /* DENALI_PHY_908_DATA */ + 0x00000000 /* DENALI_PHY_909_DATA */ + 0x04000408 /* DENALI_PHY_910_DATA */ + 0x00000408 /* DENALI_PHY_911_DATA */ + 0x00e4e400 /* DENALI_PHY_912_DATA */ + 0x00000000 /* DENALI_PHY_913_DATA */ + 0x00000000 /* DENALI_PHY_914_DATA */ + 0x00000000 /* DENALI_PHY_915_DATA */ + 0x00000000 /* DENALI_PHY_916_DATA */ + 0x00000000 /* DENALI_PHY_917_DATA */ + 0x00000000 /* DENALI_PHY_918_DATA */ + 0x00000000 /* DENALI_PHY_919_DATA */ + 0x00000000 /* DENALI_PHY_920_DATA */ + 0x00000000 /* DENALI_PHY_921_DATA */ + 0x00000000 /* DENALI_PHY_922_DATA */ + 0x00000000 /* DENALI_PHY_923_DATA */ + 0x00000000 /* DENALI_PHY_924_DATA */ + 0x00000000 /* DENALI_PHY_925_DATA */ + 0x00000000 /* DENALI_PHY_926_DATA */ + 0x00000000 /* DENALI_PHY_927_DATA */ + 0x00000000 /* DENALI_PHY_928_DATA */ + 0x00200000 /* DENALI_PHY_929_DATA */ + 0x00000000 /* DENALI_PHY_930_DATA */ + 0x00000000 /* DENALI_PHY_931_DATA */ + 0x00000000 /* DENALI_PHY_932_DATA */ + 0x00000000 /* DENALI_PHY_933_DATA */ + 0x00000000 /* DENALI_PHY_934_DATA */ + 0x00000000 /* DENALI_PHY_935_DATA */ + 0x02800280 /* DENALI_PHY_936_DATA */ + 0x02800280 /* DENALI_PHY_937_DATA */ + 0x02800280 /* DENALI_PHY_938_DATA */ + 0x02800280 /* DENALI_PHY_939_DATA */ + 0x00000280 /* DENALI_PHY_940_DATA */ + 0x00000000 /* DENALI_PHY_941_DATA */ + 0x00000000 /* DENALI_PHY_942_DATA */ + 0x00000000 /* DENALI_PHY_943_DATA */ + 0x00000000 /* DENALI_PHY_944_DATA */ + 0x00000000 /* DENALI_PHY_945_DATA */ + 0x00800080 /* DENALI_PHY_946_DATA */ + 0x00800080 /* DENALI_PHY_947_DATA */ + 0x00800080 /* DENALI_PHY_948_DATA */ + 0x00800080 /* DENALI_PHY_949_DATA */ + 0x00800080 /* DENALI_PHY_950_DATA */ + 0x00800080 /* DENALI_PHY_951_DATA */ + 0x00800080 /* DENALI_PHY_952_DATA */ + 0x00800080 /* DENALI_PHY_953_DATA */ + 0x00800080 /* DENALI_PHY_954_DATA */ + 0x000100da /* DENALI_PHY_955_DATA */ + 0x00000200 /* DENALI_PHY_956_DATA */ + 0x00000000 /* DENALI_PHY_957_DATA */ + 0x00000000 /* DENALI_PHY_958_DATA */ + 0x00000002 /* DENALI_PHY_959_DATA */ + 0x51313152 /* DENALI_PHY_960_DATA */ + 0x80013130 /* DENALI_PHY_961_DATA */ + 0x02000080 /* DENALI_PHY_962_DATA */ + 0x00100001 /* DENALI_PHY_963_DATA */ + 0x0c064208 /* DENALI_PHY_964_DATA */ + 0x000f0c0f /* DENALI_PHY_965_DATA */ + 0x01000140 /* DENALI_PHY_966_DATA */ + 0x0000000c /* DENALI_PHY_967_DATA */ + 0x00000000 /* DENALI_PHY_968_DATA */ + 0x00000000 /* DENALI_PHY_969_DATA */ + 0x00000000 /* DENALI_PHY_970_DATA */ + 0x00000000 /* DENALI_PHY_971_DATA */ + 0x00000000 /* DENALI_PHY_972_DATA */ + 0x00000000 /* DENALI_PHY_973_DATA */ + 0x00000000 /* DENALI_PHY_974_DATA */ + 0x00000000 /* DENALI_PHY_975_DATA */ + 0x00000000 /* DENALI_PHY_976_DATA */ + 0x00000000 /* DENALI_PHY_977_DATA */ + 0x00000000 /* DENALI_PHY_978_DATA */ + 0x00000000 /* DENALI_PHY_979_DATA */ + 0x00000000 /* DENALI_PHY_980_DATA */ + 0x00000000 /* DENALI_PHY_981_DATA */ + 0x00000000 /* DENALI_PHY_982_DATA */ + 0x00000000 /* DENALI_PHY_983_DATA */ + 0x00000000 /* DENALI_PHY_984_DATA */ + 0x00000000 /* DENALI_PHY_985_DATA */ + 0x00000000 /* DENALI_PHY_986_DATA */ + 0x00000000 /* DENALI_PHY_987_DATA */ + 0x00000000 /* DENALI_PHY_988_DATA */ + 0x00000000 /* DENALI_PHY_989_DATA */ + 0x00000000 /* DENALI_PHY_990_DATA */ + 0x00000000 /* DENALI_PHY_991_DATA */ + 0x00000000 /* DENALI_PHY_992_DATA */ + 0x00000000 /* DENALI_PHY_993_DATA */ + 0x00000000 /* DENALI_PHY_994_DATA */ + 0x00000000 /* DENALI_PHY_995_DATA */ + 0x00000000 /* DENALI_PHY_996_DATA */ + 0x00000000 /* DENALI_PHY_997_DATA */ + 0x00000000 /* DENALI_PHY_998_DATA */ + 0x00000000 /* DENALI_PHY_999_DATA */ + 0x00000000 /* DENALI_PHY_1000_DATA */ + 0x00000000 /* DENALI_PHY_1001_DATA */ + 0x00000000 /* DENALI_PHY_1002_DATA */ + 0x00000000 /* DENALI_PHY_1003_DATA */ + 0x00000000 /* DENALI_PHY_1004_DATA */ + 0x00000000 /* DENALI_PHY_1005_DATA */ + 0x00000000 /* DENALI_PHY_1006_DATA */ + 0x00000000 /* DENALI_PHY_1007_DATA */ + 0x00000000 /* DENALI_PHY_1008_DATA */ + 0x00000000 /* DENALI_PHY_1009_DATA */ + 0x00000000 /* DENALI_PHY_1010_DATA */ + 0x00000000 /* DENALI_PHY_1011_DATA */ + 0x00000000 /* DENALI_PHY_1012_DATA */ + 0x00000000 /* DENALI_PHY_1013_DATA */ + 0x00000000 /* DENALI_PHY_1014_DATA */ + 0x00000000 /* DENALI_PHY_1015_DATA */ + 0x00000000 /* DENALI_PHY_1016_DATA */ + 0x00000000 /* DENALI_PHY_1017_DATA */ + 0x00000000 /* DENALI_PHY_1018_DATA */ + 0x00000000 /* DENALI_PHY_1019_DATA */ + 0x00000000 /* DENALI_PHY_1020_DATA */ + 0x00000000 /* DENALI_PHY_1021_DATA */ + 0x00000000 /* DENALI_PHY_1022_DATA */ + 0x00000000 /* DENALI_PHY_1023_DATA */ + 0x36025174 /* DENALI_PHY_1024_DATA */ + 0x0004c008 /* DENALI_PHY_1025_DATA */ + 0x000000da /* DENALI_PHY_1026_DATA */ + 0x00000000 /* DENALI_PHY_1027_DATA */ + 0x00000000 /* DENALI_PHY_1028_DATA */ + 0x00010000 /* DENALI_PHY_1029_DATA */ + 0x01DDDD90 /* DENALI_PHY_1030_DATA */ + 0x01DDDD90 /* DENALI_PHY_1031_DATA */ + 0x01030000 /* DENALI_PHY_1032_DATA */ + 0x01000000 /* DENALI_PHY_1033_DATA */ + 0x00c00000 /* DENALI_PHY_1034_DATA */ + 0x00000007 /* DENALI_PHY_1035_DATA */ + 0x00000000 /* DENALI_PHY_1036_DATA */ + 0x00000000 /* DENALI_PHY_1037_DATA */ + 0x04000408 /* DENALI_PHY_1038_DATA */ + 0x00000408 /* DENALI_PHY_1039_DATA */ + 0x00e4e400 /* DENALI_PHY_1040_DATA */ + 0x00000000 /* DENALI_PHY_1041_DATA */ + 0x00000000 /* DENALI_PHY_1042_DATA */ + 0x00000000 /* DENALI_PHY_1043_DATA */ + 0x00000000 /* DENALI_PHY_1044_DATA */ + 0x00000000 /* DENALI_PHY_1045_DATA */ + 0x00000000 /* DENALI_PHY_1046_DATA */ + 0x00000000 /* DENALI_PHY_1047_DATA */ + 0x00000000 /* DENALI_PHY_1048_DATA */ + 0x00000000 /* DENALI_PHY_1049_DATA */ + 0x00000000 /* DENALI_PHY_1050_DATA */ + 0x00000000 /* DENALI_PHY_1051_DATA */ + 0x00000000 /* DENALI_PHY_1052_DATA */ + 0x00000000 /* DENALI_PHY_1053_DATA */ + 0x00000000 /* DENALI_PHY_1054_DATA */ + 0x00000000 /* DENALI_PHY_1055_DATA */ + 0x00000000 /* DENALI_PHY_1056_DATA */ + 0x00200000 /* DENALI_PHY_1057_DATA */ + 0x00000000 /* DENALI_PHY_1058_DATA */ + 0x00000000 /* DENALI_PHY_1059_DATA */ + 0x00000000 /* DENALI_PHY_1060_DATA */ + 0x00000000 /* DENALI_PHY_1061_DATA */ + 0x00000000 /* DENALI_PHY_1062_DATA */ + 0x00000000 /* DENALI_PHY_1063_DATA */ + 0x02800280 /* DENALI_PHY_1064_DATA */ + 0x02800280 /* DENALI_PHY_1065_DATA */ + 0x02800280 /* DENALI_PHY_1066_DATA */ + 0x02800280 /* DENALI_PHY_1067_DATA */ + 0x00000280 /* DENALI_PHY_1068_DATA */ + 0x00000000 /* DENALI_PHY_1069_DATA */ + 0x00000000 /* DENALI_PHY_1070_DATA */ + 0x00000000 /* DENALI_PHY_1071_DATA */ + 0x00000000 /* DENALI_PHY_1072_DATA */ + 0x00000000 /* DENALI_PHY_1073_DATA */ + 0x00800080 /* DENALI_PHY_1074_DATA */ + 0x00800080 /* DENALI_PHY_1075_DATA */ + 0x00800080 /* DENALI_PHY_1076_DATA */ + 0x00800080 /* DENALI_PHY_1077_DATA */ + 0x00800080 /* DENALI_PHY_1078_DATA */ + 0x00800080 /* DENALI_PHY_1079_DATA */ + 0x00800080 /* DENALI_PHY_1080_DATA */ + 0x00800080 /* DENALI_PHY_1081_DATA */ + 0x00800080 /* DENALI_PHY_1082_DATA */ + 0x000100da /* DENALI_PHY_1083_DATA */ + 0x00000200 /* DENALI_PHY_1084_DATA */ + 0x00000000 /* DENALI_PHY_1085_DATA */ + 0x00000000 /* DENALI_PHY_1086_DATA */ + 0x00000002 /* DENALI_PHY_1087_DATA */ + 0x51313152 /* DENALI_PHY_1088_DATA */ + 0x80013130 /* DENALI_PHY_1089_DATA */ + 0x02000080 /* DENALI_PHY_1090_DATA */ + 0x00100001 /* DENALI_PHY_1091_DATA */ + 0x0c064208 /* DENALI_PHY_1092_DATA */ + 0x000f0c0f /* DENALI_PHY_1093_DATA */ + 0x01000140 /* DENALI_PHY_1094_DATA */ + 0x0000000c /* DENALI_PHY_1095_DATA */ + 0x00000000 /* DENALI_PHY_1096_DATA */ + 0x00000000 /* DENALI_PHY_1097_DATA */ + 0x00000000 /* DENALI_PHY_1098_DATA */ + 0x00000000 /* DENALI_PHY_1099_DATA */ + 0x00000000 /* DENALI_PHY_1100_DATA */ + 0x00000000 /* DENALI_PHY_1101_DATA */ + 0x00000000 /* DENALI_PHY_1102_DATA */ + 0x00000000 /* DENALI_PHY_1103_DATA */ + 0x00000000 /* DENALI_PHY_1104_DATA */ + 0x00000000 /* DENALI_PHY_1105_DATA */ + 0x00000000 /* DENALI_PHY_1106_DATA */ + 0x00000000 /* DENALI_PHY_1107_DATA */ + 0x00000000 /* DENALI_PHY_1108_DATA */ + 0x00000000 /* DENALI_PHY_1109_DATA */ + 0x00000000 /* DENALI_PHY_1110_DATA */ + 0x00000000 /* DENALI_PHY_1111_DATA */ + 0x00000000 /* DENALI_PHY_1112_DATA */ + 0x00000000 /* DENALI_PHY_1113_DATA */ + 0x00000000 /* DENALI_PHY_1114_DATA */ + 0x00000000 /* DENALI_PHY_1115_DATA */ + 0x00000000 /* DENALI_PHY_1116_DATA */ + 0x00000000 /* DENALI_PHY_1117_DATA */ + 0x00000000 /* DENALI_PHY_1118_DATA */ + 0x00000000 /* DENALI_PHY_1119_DATA */ + 0x00000000 /* DENALI_PHY_1120_DATA */ + 0x00000000 /* DENALI_PHY_1121_DATA */ + 0x00000000 /* DENALI_PHY_1122_DATA */ + 0x00000000 /* DENALI_PHY_1123_DATA */ + 0x00000000 /* DENALI_PHY_1124_DATA */ + 0x00000000 /* DENALI_PHY_1125_DATA */ + 0x00000000 /* DENALI_PHY_1126_DATA */ + 0x00000000 /* DENALI_PHY_1127_DATA */ + 0x00000000 /* DENALI_PHY_1128_DATA */ + 0x00000000 /* DENALI_PHY_1129_DATA */ + 0x00000000 /* DENALI_PHY_1130_DATA */ + 0x00000000 /* DENALI_PHY_1131_DATA */ + 0x00000000 /* DENALI_PHY_1132_DATA */ + 0x00000000 /* DENALI_PHY_1133_DATA */ + 0x00000000 /* DENALI_PHY_1134_DATA */ + 0x00000000 /* DENALI_PHY_1135_DATA */ + 0x00000000 /* DENALI_PHY_1136_DATA */ + 0x00000000 /* DENALI_PHY_1137_DATA */ + 0x00000000 /* DENALI_PHY_1138_DATA */ + 0x00000000 /* DENALI_PHY_1139_DATA */ + 0x00000000 /* DENALI_PHY_1140_DATA */ + 0x00000000 /* DENALI_PHY_1141_DATA */ + 0x00000000 /* DENALI_PHY_1142_DATA */ + 0x00000000 /* DENALI_PHY_1143_DATA */ + 0x00000000 /* DENALI_PHY_1144_DATA */ + 0x00000000 /* DENALI_PHY_1145_DATA */ + 0x00000000 /* DENALI_PHY_1146_DATA */ + 0x00000000 /* DENALI_PHY_1147_DATA */ + 0x00000000 /* DENALI_PHY_1148_DATA */ + 0x00000000 /* DENALI_PHY_1149_DATA */ + 0x00000000 /* DENALI_PHY_1150_DATA */ + 0x00000000 /* DENALI_PHY_1151_DATA */ + 0x00000000 /* DENALI_PHY_1152_DATA */ + 0x00000000 /* DENALI_PHY_1153_DATA */ + 0x00050000 /* DENALI_PHY_1154_DATA */ + 0x00000000 /* DENALI_PHY_1155_DATA */ + 0x00000000 /* DENALI_PHY_1156_DATA */ + 0x00000000 /* DENALI_PHY_1157_DATA */ + 0x00000100 /* DENALI_PHY_1158_DATA */ + 0x00000000 /* DENALI_PHY_1159_DATA */ + 0x00000000 /* DENALI_PHY_1160_DATA */ + 0x00506401 /* DENALI_PHY_1161_DATA */ + 0x01221102 /* DENALI_PHY_1162_DATA */ + 0x00000122 /* DENALI_PHY_1163_DATA */ + 0x00000000 /* DENALI_PHY_1164_DATA */ + 0x000B1F00 /* DENALI_PHY_1165_DATA */ + 0x0B1F0B1F /* DENALI_PHY_1166_DATA */ + 0x0B1F0B1B /* DENALI_PHY_1167_DATA */ + 0x0B1F0B1F /* DENALI_PHY_1168_DATA */ + 0x0B1F0B1F /* DENALI_PHY_1169_DATA */ + 0x00000B00 /* DENALI_PHY_1170_DATA */ + 0x42080010 /* DENALI_PHY_1171_DATA */ + 0x01000100 /* DENALI_PHY_1172_DATA */ + 0x01000100 /* DENALI_PHY_1173_DATA */ + 0x01000100 /* DENALI_PHY_1174_DATA */ + 0x01000100 /* DENALI_PHY_1175_DATA */ + 0x00000000 /* DENALI_PHY_1176_DATA */ + 0x00000000 /* DENALI_PHY_1177_DATA */ + 0x00000000 /* DENALI_PHY_1178_DATA */ + 0x00000000 /* DENALI_PHY_1179_DATA */ + 0x00000000 /* DENALI_PHY_1180_DATA */ + 0x00000803 /* DENALI_PHY_1181_DATA */ + 0x223FFF00 /* DENALI_PHY_1182_DATA */ + 0x000008FF /* DENALI_PHY_1183_DATA */ + 0x0000057F /* DENALI_PHY_1184_DATA */ + 0x0000057F /* DENALI_PHY_1185_DATA */ + 0x00037FFF /* DENALI_PHY_1186_DATA */ + 0x00037FFF /* DENALI_PHY_1187_DATA */ + 0x00004410 /* DENALI_PHY_1188_DATA */ + 0x00004410 /* DENALI_PHY_1189_DATA */ + 0x00004410 /* DENALI_PHY_1190_DATA */ + 0x00004410 /* DENALI_PHY_1191_DATA */ + 0x00004410 /* DENALI_PHY_1192_DATA */ + 0x00037FFF /* DENALI_PHY_1193_DATA */ + 0x00037FFF /* DENALI_PHY_1194_DATA */ + 0x00000000 /* DENALI_PHY_1195_DATA */ + 0x00000000 /* DENALI_PHY_1196_DATA */ + 0x00000000 /* DENALI_PHY_1197_DATA */ + 0x04000000 /* DENALI_PHY_1198_DATA */ + 0x00000000 /* DENALI_PHY_1199_DATA */ + 0x00000000 /* DENALI_PHY_1200_DATA */ + 0x00000108 /* DENALI_PHY_1201_DATA */ + 0x00000000 /* DENALI_PHY_1202_DATA */ + 0x00000000 /* DENALI_PHY_1203_DATA */ + 0x00000000 /* DENALI_PHY_1204_DATA */ + 0x00000001 /* DENALI_PHY_1205_DATA */ + 0x00000000 /* DENALI_PHY_1206_DATA */ + 0x00000000 /* DENALI_PHY_1207_DATA */ + 0x00000000 /* DENALI_PHY_1208_DATA */ + 0x00000000 /* DENALI_PHY_1209_DATA */ + 0x00000000 /* DENALI_PHY_1210_DATA */ + 0x00000000 /* DENALI_PHY_1211_DATA */ + 0x00020100 /* DENALI_PHY_1212_DATA */ + 0x00000000 /* DENALI_PHY_1213_DATA */ + 0x00000000 /* DENALI_PHY_1214_DATA */ + >; +};
On Thu, May 14, 2020 at 7:54 PM Pragnesh Patel pragnesh.patel@sifive.com wrote:
Tested-by: Bin Meng bmeng.cn@gmail.com
Add dmc node to enable ddr driver. dmc is used to initialize the memory controller.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com --- arch/riscv/dts/fu540-c000-u-boot.dtsi | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/riscv/dts/fu540-c000-u-boot.dtsi b/arch/riscv/dts/fu540-c000-u-boot.dtsi index fbfe296a03..fc91a7c987 100644 --- a/arch/riscv/dts/fu540-c000-u-boot.dtsi +++ b/arch/riscv/dts/fu540-c000-u-boot.dtsi @@ -59,6 +59,15 @@ reg = <0x0 0x2000000 0x0 0xc0000>; u-boot,dm-spl; }; + dmc: dmc@100b0000 { + compatible = "sifive,fu540-c000-ddr"; + reg = <0x0 0x100b0000 0x0 0x0800 + 0x0 0x100b2000 0x0 0x2000 + 0x0 0x100b8000 0x0 0x0fff>; + clocks = <&prci PRCI_CLK_DDRPLL>; + clock-frequency = <933333324>; + u-boot,dm-spl; + }; }; };
Added clock enable and disable functions in prci ops
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com --- drivers/clk/sifive/fu540-prci.c | 108 ++++++++++++++++++++++++++++---- 1 file changed, 96 insertions(+), 12 deletions(-)
diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index 8847178001..bf06c3a3bb 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -68,6 +68,11 @@ #define PRCI_COREPLLCFG0_LOCK_SHIFT 31 #define PRCI_COREPLLCFG0_LOCK_MASK (0x1 << PRCI_COREPLLCFG0_LOCK_SHIFT)
+/* COREPLLCFG1 */ +#define PRCI_COREPLLCFG1_OFFSET 0x8 +#define PRCI_COREPLLCFG1_CKE_SHIFT 31 +#define PRCI_COREPLLCFG1_CKE_MASK (0x1 << PRCI_COREPLLCFG1_CKE_SHIFT) + /* DDRPLLCFG0 */ #define PRCI_DDRPLLCFG0_OFFSET 0xc #define PRCI_DDRPLLCFG0_DIVR_SHIFT 0 @@ -87,7 +92,7 @@
/* DDRPLLCFG1 */ #define PRCI_DDRPLLCFG1_OFFSET 0x10 -#define PRCI_DDRPLLCFG1_CKE_SHIFT 24 +#define PRCI_DDRPLLCFG1_CKE_SHIFT 31 #define PRCI_DDRPLLCFG1_CKE_MASK (0x1 << PRCI_DDRPLLCFG1_CKE_SHIFT)
/* GEMGXLPLLCFG0 */ @@ -114,7 +119,7 @@
/* GEMGXLPLLCFG1 */ #define PRCI_GEMGXLPLLCFG1_OFFSET 0x20 -#define PRCI_GEMGXLPLLCFG1_CKE_SHIFT 24 +#define PRCI_GEMGXLPLLCFG1_CKE_SHIFT 31 #define PRCI_GEMGXLPLLCFG1_CKE_MASK (0x1 << PRCI_GEMGXLPLLCFG1_CKE_SHIFT)
/* CORECLKSEL */ @@ -142,7 +147,7 @@ (0x1 << PRCI_DEVICESRESETREG_GEMGXL_RST_N_SHIFT)
/* CLKMUXSTATUSREG */ -#define PRCI_CLKMUXSTATUSREG_OFFSET 0x2c +#define PRCI_CLKMUXSTATUSREG_OFFSET 0x2c #define PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_SHIFT 1 #define PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_MASK \ (0x1 << PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_SHIFT) @@ -170,6 +175,7 @@ struct __prci_data { * @enable_bypass: fn ptr to code to bypass the WRPLL (if applicable; else NULL) * @disable_bypass: fn ptr to code to not bypass the WRPLL (or NULL) * @cfg0_offs: WRPLL CFG0 register offset (in bytes) from the PRCI base address + * @cfg1_offs: WRPLL CFG1 register offset (in bytes) from the PRCI base address * * @enable_bypass and @disable_bypass are used for WRPLL instances * that contain a separate external glitchless clock mux downstream @@ -180,6 +186,7 @@ struct __prci_wrpll_data { void (*enable_bypass)(struct __prci_data *pd); void (*disable_bypass)(struct __prci_data *pd); u8 cfg0_offs; + u8 cfg1_offs; };
struct __prci_clock; @@ -194,6 +201,7 @@ struct __prci_clock_ops { unsigned long *parent_rate); unsigned long (*recalc_rate)(struct __prci_clock *pc, unsigned long parent_rate); + int (*enable_clk)(struct __prci_clock *pc, bool enable); };
/** @@ -316,7 +324,7 @@ static u32 __prci_wrpll_pack(const struct wrpll_cfg *c) }
/** - * __prci_wrpll_read_cfg() - read the WRPLL configuration from the PRCI + * __prci_wrpll_read_cfg0() - read the WRPLL configuration from the PRCI * @pd: PRCI context * @pwd: PRCI WRPLL metadata * @@ -327,14 +335,14 @@ static u32 __prci_wrpll_pack(const struct wrpll_cfg *c) * Context: Any context. Caller must prevent the records pointed to by * @pd and @pwd from changing during execution. */ -static void __prci_wrpll_read_cfg(struct __prci_data *pd, - struct __prci_wrpll_data *pwd) +static void __prci_wrpll_read_cfg0(struct __prci_data *pd, + struct __prci_wrpll_data *pwd) { __prci_wrpll_unpack(&pwd->c, __prci_readl(pd, pwd->cfg0_offs)); }
/** - * __prci_wrpll_write_cfg() - write WRPLL configuration into the PRCI + * __prci_wrpll_write_cfg0() - write WRPLL configuration into the PRCI * @pd: PRCI context * @pwd: PRCI WRPLL metadata * @c: WRPLL configuration record to write @@ -347,15 +355,29 @@ static void __prci_wrpll_read_cfg(struct __prci_data *pd, * Context: Any context. Caller must prevent the records pointed to by * @pd and @pwd from changing during execution. */ -static void __prci_wrpll_write_cfg(struct __prci_data *pd, - struct __prci_wrpll_data *pwd, - struct wrpll_cfg *c) +static void __prci_wrpll_write_cfg0(struct __prci_data *pd, + struct __prci_wrpll_data *pwd, + struct wrpll_cfg *c) { __prci_writel(__prci_wrpll_pack(c), pwd->cfg0_offs, pd);
memcpy(&pwd->c, c, sizeof(*c)); }
+/** + * __prci_wrpll_write_cfg1() - write Clock enable/disable configuration + * into the PRCI + * @pd: PRCI context + * @pwd: PRCI WRPLL metadata + * @enable: Clock enable or disable value + */ +static void __prci_wrpll_write_cfg1(struct __prci_data *pd, + struct __prci_wrpll_data *pwd, + u32 enable) +{ + __prci_writel(enable, pwd->cfg1_offs, pd); +} + /* Core clock mux control */
/** @@ -437,7 +459,7 @@ static int sifive_fu540_prci_wrpll_set_rate(struct __prci_clock *pc, if (pwd->enable_bypass) pwd->enable_bypass(pd);
- __prci_wrpll_write_cfg(pd, pwd, &pwd->c); + __prci_wrpll_write_cfg0(pd, pwd, &pwd->c);
udelay(wrpll_calc_max_lock_us(&pwd->c));
@@ -447,14 +469,35 @@ static int sifive_fu540_prci_wrpll_set_rate(struct __prci_clock *pc, return 0; }
+static int sifive_fu540_prci_clock_enable(struct __prci_clock *pc, bool enable) +{ + struct __prci_wrpll_data *pwd = pc->pwd; + struct __prci_data *pd = pc->pd; + + if (enable) { + __prci_wrpll_write_cfg1(pd, pwd, PRCI_COREPLLCFG1_CKE_MASK); + } else { + u32 r; + + r = __prci_readl(pd, pwd->cfg1_offs); + r &= ~PRCI_COREPLLCFG1_CKE_MASK; + + __prci_wrpll_write_cfg1(pd, pwd, r); + } + + return 0; +} + static const struct __prci_clock_ops sifive_fu540_prci_wrpll_clk_ops = { .set_rate = sifive_fu540_prci_wrpll_set_rate, .round_rate = sifive_fu540_prci_wrpll_round_rate, .recalc_rate = sifive_fu540_prci_wrpll_recalc_rate, + .enable_clk = sifive_fu540_prci_clock_enable, };
static const struct __prci_clock_ops sifive_fu540_prci_wrpll_ro_clk_ops = { .recalc_rate = sifive_fu540_prci_wrpll_recalc_rate, + .enable_clk = sifive_fu540_prci_clock_enable, };
/* TLCLKSEL clock integration */ @@ -484,16 +527,19 @@ static const struct __prci_clock_ops sifive_fu540_prci_tlclksel_clk_ops = {
static struct __prci_wrpll_data __prci_corepll_data = { .cfg0_offs = PRCI_COREPLLCFG0_OFFSET, + .cfg1_offs = PRCI_COREPLLCFG1_OFFSET, .enable_bypass = __prci_coreclksel_use_hfclk, .disable_bypass = __prci_coreclksel_use_corepll, };
static struct __prci_wrpll_data __prci_ddrpll_data = { .cfg0_offs = PRCI_DDRPLLCFG0_OFFSET, + .cfg1_offs = PRCI_DDRPLLCFG1_OFFSET, };
static struct __prci_wrpll_data __prci_gemgxlpll_data = { .cfg0_offs = PRCI_GEMGXLPLLCFG0_OFFSET, + .cfg1_offs = PRCI_GEMGXLPLLCFG1_OFFSET, };
/* @@ -580,6 +626,42 @@ static ulong sifive_fu540_prci_set_rate(struct clk *clk, ulong rate) return rate; }
+static int sifive_fu540_prci_enable(struct clk *clk) +{ + struct __prci_clock *pc; + int ret = 0; + + if (ARRAY_SIZE(__prci_init_clocks) <= clk->id) + return -ENXIO; + + pc = &__prci_init_clocks[clk->id]; + if (!pc->pd) + return -ENXIO; + + if (pc->ops->enable_clk) + ret = pc->ops->enable_clk(pc, 1); + + return ret; +} + +static int sifive_fu540_prci_disable(struct clk *clk) +{ + struct __prci_clock *pc; + int ret = 0; + + if (ARRAY_SIZE(__prci_init_clocks) <= clk->id) + return -ENXIO; + + pc = &__prci_init_clocks[clk->id]; + if (!pc->pd) + return -ENXIO; + + if (pc->ops->enable_clk) + ret = pc->ops->enable_clk(pc, 0); + + return ret; +} + static int sifive_fu540_prci_probe(struct udevice *dev) { int i, err; @@ -602,7 +684,7 @@ static int sifive_fu540_prci_probe(struct udevice *dev) pc = &__prci_init_clocks[i]; pc->pd = pd; if (pc->pwd) - __prci_wrpll_read_cfg(pd, pc->pwd); + __prci_wrpll_read_cfg0(pd, pc->pwd); }
return 0; @@ -611,6 +693,8 @@ static int sifive_fu540_prci_probe(struct udevice *dev) static struct clk_ops sifive_fu540_prci_ops = { .set_rate = sifive_fu540_prci_set_rate, .get_rate = sifive_fu540_prci_get_rate, + .enable = sifive_fu540_prci_enable, + .disable = sifive_fu540_prci_disable, };
static const struct udevice_id sifive_fu540_prci_ids[] = {
Release ddr clock reset once clock is initialized
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com --- drivers/clk/sifive/fu540-prci.c | 51 +++++++++++++++++++++++++++++---- 1 file changed, 45 insertions(+), 6 deletions(-)
diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index bf06c3a3bb..f26a370a64 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -152,6 +152,12 @@ #define PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_MASK \ (0x1 << PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_SHIFT)
+/* PROCMONCFG */ +#define PRCI_PROCMONCFG_OFFSET 0xF0 +#define PRCI_PROCMONCFG_CORE_CLOCK_SHIFT 24 +#define PRCI_PROCMONCFG_CORE_CLOCK_MASK \ + (0x1 << PRCI_PROCMONCFG_CORE_CLOCK_SHIFT) + /* * Private structures */ @@ -176,6 +182,7 @@ struct __prci_data { * @disable_bypass: fn ptr to code to not bypass the WRPLL (or NULL) * @cfg0_offs: WRPLL CFG0 register offset (in bytes) from the PRCI base address * @cfg1_offs: WRPLL CFG1 register offset (in bytes) from the PRCI base address + * @release_reset: fn ptr to code to release clock reset * * @enable_bypass and @disable_bypass are used for WRPLL instances * that contain a separate external glitchless clock mux downstream @@ -187,6 +194,7 @@ struct __prci_wrpll_data { void (*disable_bypass)(struct __prci_data *pd); u8 cfg0_offs; u8 cfg1_offs; + void (*release_reset)(struct __prci_data *pd); };
struct __prci_clock; @@ -476,6 +484,9 @@ static int sifive_fu540_prci_clock_enable(struct __prci_clock *pc, bool enable)
if (enable) { __prci_wrpll_write_cfg1(pd, pwd, PRCI_COREPLLCFG1_CKE_MASK); + + if (pwd->release_reset) + pwd->release_reset(pd); } else { u32 r;
@@ -495,11 +506,6 @@ static const struct __prci_clock_ops sifive_fu540_prci_wrpll_clk_ops = { .enable_clk = sifive_fu540_prci_clock_enable, };
-static const struct __prci_clock_ops sifive_fu540_prci_wrpll_ro_clk_ops = { - .recalc_rate = sifive_fu540_prci_wrpll_recalc_rate, - .enable_clk = sifive_fu540_prci_clock_enable, -}; - /* TLCLKSEL clock integration */
static unsigned long sifive_fu540_prci_tlclksel_recalc_rate( @@ -521,6 +527,38 @@ static const struct __prci_clock_ops sifive_fu540_prci_tlclksel_clk_ops = { .recalc_rate = sifive_fu540_prci_tlclksel_recalc_rate, };
+/** + * __prci_ddr_release_reset() - Release DDR reset + * @pd: struct __prci_data * for the PRCI containing the DDRCLK mux reg + * + */ +static void __prci_ddr_release_reset(struct __prci_data *pd) +{ + u32 v; + + v = __prci_readl(pd, PRCI_DEVICESRESETREG_OFFSET); + v |= PRCI_DEVICESRESETREG_DDR_CTRL_RST_N_MASK; + __prci_writel(v, PRCI_DEVICESRESETREG_OFFSET, pd); + + /* HACK to get the '1 full controller clock cycle'. */ + asm volatile ("fence"); + v = __prci_readl(pd, PRCI_DEVICESRESETREG_OFFSET); + v |= (PRCI_DEVICESRESETREG_DDR_AXI_RST_N_MASK | + PRCI_DEVICESRESETREG_DDR_AHB_RST_N_MASK | + PRCI_DEVICESRESETREG_DDR_PHY_RST_N_MASK); + __prci_writel(v, PRCI_DEVICESRESETREG_OFFSET, pd); + + /* HACK to get the '1 full controller clock cycle'. */ + asm volatile ("fence"); + + /* + * These take like 16 cycles to actually propagate. We can't go sending + * stuff before they come out of reset. So wait. + */ + for (int i = 0; i < 256; i++) + asm volatile ("nop"); +} + /* * PRCI integration data for each WRPLL instance */ @@ -535,6 +573,7 @@ static struct __prci_wrpll_data __prci_corepll_data = { static struct __prci_wrpll_data __prci_ddrpll_data = { .cfg0_offs = PRCI_DDRPLLCFG0_OFFSET, .cfg1_offs = PRCI_DDRPLLCFG1_OFFSET, + .release_reset = __prci_ddr_release_reset, };
static struct __prci_wrpll_data __prci_gemgxlpll_data = { @@ -556,7 +595,7 @@ static struct __prci_clock __prci_init_clocks[] = { [PRCI_CLK_DDRPLL] = { .name = "ddrpll", .parent_name = "hfclk", - .ops = &sifive_fu540_prci_wrpll_ro_clk_ops, + .ops = &sifive_fu540_prci_wrpll_clk_ops, .pwd = &__prci_ddrpll_data, }, [PRCI_CLK_GEMGXLPLL] = {
Release ethernet clock reset once clock is initialized. This is necessary to do as U-Boot proper needs ethernet clock.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com --- drivers/clk/sifive/fu540-prci.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index f26a370a64..45491a77d5 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -559,6 +559,25 @@ static void __prci_ddr_release_reset(struct __prci_data *pd) asm volatile ("nop"); }
+/** + * __prci_ethernet_release_reset() - Release ethernet reset + * @pd: struct __prci_data * for the PRCI containing the Ethernet CLK mux reg + * + */ +static void __prci_ethernet_release_reset(struct __prci_data *pd) +{ + u32 v; + + /* Release GEMGXL reset */ + v = __prci_readl(pd, PRCI_DEVICESRESETREG_OFFSET); + v |= PRCI_DEVICESRESETREG_GEMGXL_RST_N_MASK; + __prci_writel(v, PRCI_DEVICESRESETREG_OFFSET, pd); + + /* Procmon => core clock */ + __prci_writel(PRCI_PROCMONCFG_CORE_CLOCK_MASK, PRCI_PROCMONCFG_OFFSET, + pd); +} + /* * PRCI integration data for each WRPLL instance */ @@ -579,6 +598,7 @@ static struct __prci_wrpll_data __prci_ddrpll_data = { static struct __prci_wrpll_data __prci_gemgxlpll_data = { .cfg0_offs = PRCI_GEMGXLPLLCFG0_OFFSET, .cfg1_offs = PRCI_GEMGXLPLLCFG1_OFFSET, + .release_reset = __prci_ethernet_release_reset, };
This sync has changes required to use GPIO in U-Boot and U-Boot SPL.
Sync dts from linux v5.7-rc2 commit: "riscv: dts: Add GPIO reboot method to HiFive Unleashed DTS file" (sha1: 0a91330b2af9f71ceeeed483f92774182b58f6d9)
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- arch/riscv/dts/fu540-c000.dtsi | 37 ++++++++++++++++++++++++- arch/riscv/dts/hifive-unleashed-a00.dts | 9 ++++++ 2 files changed, 45 insertions(+), 1 deletion(-)
diff --git a/arch/riscv/dts/fu540-c000.dtsi b/arch/riscv/dts/fu540-c000.dtsi index afa43c7ea3..7db8610534 100644 --- a/arch/riscv/dts/fu540-c000.dtsi +++ b/arch/riscv/dts/fu540-c000.dtsi @@ -54,6 +54,7 @@ reg = <1>; riscv,isa = "rv64imafdc"; tlb-split; + next-level-cache = <&l2cache>; cpu1_intc: interrupt-controller { #interrupt-cells = <1>; compatible = "riscv,cpu-intc"; @@ -77,6 +78,7 @@ reg = <2>; riscv,isa = "rv64imafdc"; tlb-split; + next-level-cache = <&l2cache>; cpu2_intc: interrupt-controller { #interrupt-cells = <1>; compatible = "riscv,cpu-intc"; @@ -100,6 +102,7 @@ reg = <3>; riscv,isa = "rv64imafdc"; tlb-split; + next-level-cache = <&l2cache>; cpu3_intc: interrupt-controller { #interrupt-cells = <1>; compatible = "riscv,cpu-intc"; @@ -123,6 +126,7 @@ reg = <4>; riscv,isa = "rv64imafdc"; tlb-split; + next-level-cache = <&l2cache>; cpu4_intc: interrupt-controller { #interrupt-cells = <1>; compatible = "riscv,cpu-intc"; @@ -162,6 +166,13 @@ clocks = <&prci PRCI_CLK_TLCLK>; status = "disabled"; }; + dma: dma@3000000 { + compatible = "sifive,fu540-c000-pdma"; + reg = <0x0 0x3000000 0x0 0x8000>; + interrupt-parent = <&plic0>; + interrupts = <23 24 25 26 27 28 29 30>; + #dma-cells = <1>; + }; uart1: serial@10011000 { compatible = "sifive,fu540-c000-uart", "sifive,uart0"; reg = <0x0 0x10011000 0x0 0x1000>; @@ -246,6 +257,30 @@ #pwm-cells = <3>; status = "disabled"; }; - + l2cache: cache-controller@2010000 { + compatible = "sifive,fu540-c000-ccache", "cache"; + cache-block-size = <64>; + cache-level = <2>; + cache-sets = <1024>; + cache-size = <2097152>; + cache-unified; + interrupt-parent = <&plic0>; + interrupts = <1 2 3>; + reg = <0x0 0x2010000 0x0 0x1000>; + }; + gpio: gpio@10060000 { + compatible = "sifive,fu540-c000-gpio", "sifive,gpio0"; + interrupt-parent = <&plic0>; + interrupts = <7>, <8>, <9>, <10>, <11>, <12>, <13>, + <14>, <15>, <16>, <17>, <18>, <19>, <20>, + <21>, <22>; + reg = <0x0 0x10060000 0x0 0x1000>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&prci PRCI_CLK_TLCLK>; + status = "disabled"; + }; }; }; diff --git a/arch/riscv/dts/hifive-unleashed-a00.dts b/arch/riscv/dts/hifive-unleashed-a00.dts index 88cfcb96bf..4a2729f5ca 100644 --- a/arch/riscv/dts/hifive-unleashed-a00.dts +++ b/arch/riscv/dts/hifive-unleashed-a00.dts @@ -2,6 +2,7 @@ /* Copyright (c) 2018-2019 SiFive, Inc */
#include "fu540-c000.dtsi" +#include <dt-bindings/gpio/gpio.h>
/* Clock frequency (in Hz) of the PCB crystal for rtcclk */ #define RTCCLK_FREQ 1000000 @@ -41,6 +42,10 @@ clock-frequency = <RTCCLK_FREQ>; clock-output-names = "rtcclk"; }; + gpio-restart { + compatible = "gpio-restart"; + gpios = <&gpio 10 GPIO_ACTIVE_LOW>; + }; };
&uart0 { @@ -94,3 +99,7 @@ &pwm1 { status = "okay"; }; + +&gpio { + status = "okay"; +};
Add SiFive fu540 cpu to support RISC-V arch
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com --- arch/riscv/Kconfig | 1 + arch/riscv/cpu/fu540/Kconfig | 15 ++++++++++ arch/riscv/cpu/fu540/Makefile | 7 +++++ arch/riscv/cpu/fu540/cpu.c | 22 ++++++++++++++ arch/riscv/cpu/fu540/dram.c | 38 ++++++++++++++++++++++++ arch/riscv/include/asm/arch-fu540/clk.h | 14 +++++++++ arch/riscv/include/asm/arch-fu540/gpio.h | 38 ++++++++++++++++++++++++ board/sifive/fu540/Kconfig | 2 +- 8 files changed, 136 insertions(+), 1 deletion(-) create mode 100644 arch/riscv/cpu/fu540/Kconfig create mode 100644 arch/riscv/cpu/fu540/Makefile create mode 100644 arch/riscv/cpu/fu540/cpu.c create mode 100644 arch/riscv/cpu/fu540/dram.c create mode 100644 arch/riscv/include/asm/arch-fu540/clk.h create mode 100644 arch/riscv/include/asm/arch-fu540/gpio.h
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index fb5fe5afff..3044609971 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -57,6 +57,7 @@ source "board/sifive/fu540/Kconfig" # platform-specific options below source "arch/riscv/cpu/ax25/Kconfig" source "arch/riscv/cpu/generic/Kconfig" +source "arch/riscv/cpu/fu540/Kconfig"
# architecture-specific options below
diff --git a/arch/riscv/cpu/fu540/Kconfig b/arch/riscv/cpu/fu540/Kconfig new file mode 100644 index 0000000000..e9302e87c0 --- /dev/null +++ b/arch/riscv/cpu/fu540/Kconfig @@ -0,0 +1,15 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + +config SIFIVE_FU540 + bool + select ARCH_EARLY_INIT_R + imply CPU + imply CPU_RISCV + imply RISCV_TIMER + imply SIFIVE_CLINT if (RISCV_MMODE || SPL_RISCV_MMODE) + imply CMD_CPU + imply SPL_CPU_SUPPORT + imply SPL_OPENSBI + imply SPL_LOAD_FIT diff --git a/arch/riscv/cpu/fu540/Makefile b/arch/riscv/cpu/fu540/Makefile new file mode 100644 index 0000000000..44700d998c --- /dev/null +++ b/arch/riscv/cpu/fu540/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020 SiFive, Inc +# Pragnesh Patel pragnesh.patel@sifive.com + +obj-y += dram.o +obj-y += cpu.o diff --git a/arch/riscv/cpu/fu540/cpu.c b/arch/riscv/cpu/fu540/cpu.c new file mode 100644 index 0000000000..13a69ef0cc --- /dev/null +++ b/arch/riscv/cpu/fu540/cpu.c @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + */ + +#include <common.h> +#include <irq_func.h> + +/* + * cleanup_before_linux() is called just before we call linux + * it prepares the processor for linux + * + * we disable interrupt and caches. + */ +int cleanup_before_linux(void) +{ + disable_interrupts(); + + cache_flush(); + + return 0; +} diff --git a/arch/riscv/cpu/fu540/dram.c b/arch/riscv/cpu/fu540/dram.c new file mode 100644 index 0000000000..1dc77efeca --- /dev/null +++ b/arch/riscv/cpu/fu540/dram.c @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com + */ + +#include <common.h> +#include <fdtdec.h> +#include <init.h> +#include <linux/sizes.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + return fdtdec_setup_mem_size_base(); +} + +int dram_init_banksize(void) +{ + return fdtdec_setup_memory_banksize(); +} + +ulong board_get_usable_ram_top(ulong total_size) +{ +#ifdef CONFIG_64BIT + /* + * Ensure that we run from first 4GB so that all + * addresses used by U-Boot are 32bit addresses. + * + * This in-turn ensures that 32bit DMA capable + * devices work fine because DMA mapping APIs will + * provide 32bit DMA addresses only. + */ + if (gd->ram_top > SZ_4G) + return SZ_4G; +#endif + return gd->ram_top; +} diff --git a/arch/riscv/include/asm/arch-fu540/clk.h b/arch/riscv/include/asm/arch-fu540/clk.h new file mode 100644 index 0000000000..d71ed4357c --- /dev/null +++ b/arch/riscv/include/asm/arch-fu540/clk.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2020 SiFive Inc + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifive.com + */ + +#ifndef __CLK_SIFIVE_H +#define __CLK_SIFIVE_H + +/* Note: This is a placeholder header for driver compilation. */ + +#endif diff --git a/arch/riscv/include/asm/arch-fu540/gpio.h b/arch/riscv/include/asm/arch-fu540/gpio.h new file mode 100644 index 0000000000..0d16c59ca6 --- /dev/null +++ b/arch/riscv/include/asm/arch-fu540/gpio.h @@ -0,0 +1,38 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 SiFive, Inc. + */ + +#ifndef _GPIO_SIFIVE_H +#define _GPIO_SIFIVE_H + +#define GPIO_INPUT_VAL 0x00 +#define GPIO_INPUT_EN 0x04 +#define GPIO_OUTPUT_EN 0x08 +#define GPIO_OUTPUT_VAL 0x0C +#define GPIO_RISE_IE 0x18 +#define GPIO_RISE_IP 0x1C +#define GPIO_FALL_IE 0x20 +#define GPIO_FALL_IP 0x24 +#define GPIO_HIGH_IE 0x28 +#define GPIO_HIGH_IP 0x2C +#define GPIO_LOW_IE 0x30 +#define GPIO_LOW_IP 0x34 +#define GPIO_OUTPUT_XOR 0x40 + +#define NR_GPIOS 16 + +enum gpio_state { + LOW, + HIGH +}; + +/* Details about a GPIO bank */ +struct sifive_gpio_platdata { + void *base; /* address of registers in physical memory */ +}; + +#define SIFIVE_GENERIC_GPIO_NR(port, index) \ + (((port) * NR_GPIOS) + ((index) & (NR_GPIOS - 1))) + +#endif /* _GPIO_SIFIVE_H */ diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index d41c305227..eb5ba3123d 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -7,7 +7,7 @@ config SYS_VENDOR default "sifive"
config SYS_CPU - default "generic" + default "fu540"
config SYS_CONFIG_NAME default "sifive-fu540"
nits: please insert this line after the ax25 one by following the alphabetical order
Other than that, Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com
Hi Bin,
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 17 May 2020 18:30 To: Pragnesh Patel pragnesh.patel@sifive.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Atish Patra atish.patra@wdc.com; Palmer Dabbelt palmerdabbelt@google.com; Paul Walmsley paul.walmsley@sifive.com; Jagan Teki jagan@amarulasolutions.com; Anup Patel anup.patel@wdc.com; Sagar Kadam sagar.kadam@sifive.com; Rick Chen rick@andestech.com; Palmer Dabbelt palmer@dabbelt.com; Lukas Auer lukas.auer@aisec.fraunhofer.de; Simon Glass sjg@chromium.org Subject: Re: [PATCH v10 13/18] riscv: cpu: fu540: Add support for cpu fu540
[External Email] Do not click links or attachments unless you recognize the sender and know the content is safe
Will update in v11.
Thanks for the review and testing.
Add a support for SPL which will boot from L2 LIM (0x0800_0000) and then SPL will boot U-Boot FIT image (OpenSBI FW_DYNAMIC + u-boot.bin) from MMC boot devices.
SPL related code is leveraged from FSBL (https://github.com/sifive/freedom-u540-c000-bootloader.git)
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com --- arch/riscv/cpu/fu540/Makefile | 4 ++ arch/riscv/cpu/fu540/spl.c | 23 ++++++ .../dts/hifive-unleashed-a00-u-boot.dtsi | 5 ++ arch/riscv/include/asm/arch-fu540/spl.h | 14 ++++ board/sifive/fu540/Kconfig | 10 ++- board/sifive/fu540/Makefile | 4 ++ board/sifive/fu540/fu540.c | 21 ++++++ board/sifive/fu540/spl.c | 72 +++++++++++++++++++ include/configs/sifive-fu540.h | 18 +++++ 9 files changed, 170 insertions(+), 1 deletion(-) create mode 100644 arch/riscv/cpu/fu540/spl.c create mode 100644 arch/riscv/include/asm/arch-fu540/spl.h create mode 100644 board/sifive/fu540/spl.c
diff --git a/arch/riscv/cpu/fu540/Makefile b/arch/riscv/cpu/fu540/Makefile index 44700d998c..043fb961a5 100644 --- a/arch/riscv/cpu/fu540/Makefile +++ b/arch/riscv/cpu/fu540/Makefile @@ -3,5 +3,9 @@ # Copyright (C) 2020 SiFive, Inc # Pragnesh Patel pragnesh.patel@sifive.com
+ifeq ($(CONFIG_SPL_BUILD),y) +obj-y += spl.o +else obj-y += dram.o obj-y += cpu.o +endif diff --git a/arch/riscv/cpu/fu540/spl.c b/arch/riscv/cpu/fu540/spl.c new file mode 100644 index 0000000000..2e05d8a6e2 --- /dev/null +++ b/arch/riscv/cpu/fu540/spl.c @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 SiFive, Inc + * Pragnesh Patel pragnesh.patel@sifive.com + */ + +#include <common.h> +#include <dm.h> + +int soc_spl_init(void) +{ + int ret; + struct udevice *dev; + + /* DDR init */ + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + debug("DRAM init failed: %d\n", ret); + return ret; + } + + return 0; +} diff --git a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi index 9787332bf1..303806454b 100644 --- a/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi +++ b/arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi @@ -4,6 +4,7 @@ */
#include "fu540-c000-u-boot.dtsi" +#include "fu540-hifive-unleashed-a00-ddr.dtsi"
/ { aliases { @@ -26,3 +27,7 @@ u-boot,dm-spl; }; }; + +&gpio { + u-boot,dm-spl; +}; diff --git a/arch/riscv/include/asm/arch-fu540/spl.h b/arch/riscv/include/asm/arch-fu540/spl.h new file mode 100644 index 0000000000..0c188be747 --- /dev/null +++ b/arch/riscv/include/asm/arch-fu540/spl.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 SiFive, Inc. + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifve.com + */ + +#ifndef _SPL_SIFIVE_H +#define _SPL_SIFIVE_H + +int soc_spl_init(void); + +#endif /* _SPL_SIFIVE_H */ diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index eb5ba3123d..4a77a2a37b 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -13,12 +13,20 @@ config SYS_CONFIG_NAME default "sifive-fu540"
config SYS_TEXT_BASE + default 0x80200000 if SPL default 0x80000000 if !RISCV_SMODE default 0x80200000 if RISCV_SMODE
+config SPL_TEXT_BASE + default 0x08000000 + +config SPL_OPENSBI_LOAD_ADDR + default 0x80000000 + config BOARD_SPECIFIC_OPTIONS # dummy def_bool y - select GENERIC_RISCV + select SIFIVE_FU540 + select SUPPORT_SPL select RAM select SPL_RAM if SPL imply CMD_DHCP diff --git a/board/sifive/fu540/Makefile b/board/sifive/fu540/Makefile index 6e1862c475..b05e2f5807 100644 --- a/board/sifive/fu540/Makefile +++ b/board/sifive/fu540/Makefile @@ -3,3 +3,7 @@ # Copyright (c) 2019 Western Digital Corporation or its affiliates.
obj-y += fu540.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +endif diff --git a/board/sifive/fu540/fu540.c b/board/sifive/fu540/fu540.c index 540638c919..535ab60aed 100644 --- a/board/sifive/fu540/fu540.c +++ b/board/sifive/fu540/fu540.c @@ -11,6 +11,7 @@ #include <linux/delay.h> #include <linux/io.h> #include <misc.h> +#include <spl.h>
/* * This define is a value used for error/unknown serial. @@ -114,3 +115,23 @@ int board_init(void)
return 0; } + +#ifdef CONFIG_SPL +u32 spl_boot_device(void) +{ +#ifdef CONFIG_SPL_MMC_SUPPORT + return BOOT_DEVICE_MMC1; +#else + puts("Unknown boot device\n"); + hang(); +#endif +} +#endif + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* boot using first FIT config */ + return 0; +} +#endif diff --git a/board/sifive/fu540/spl.c b/board/sifive/fu540/spl.c new file mode 100644 index 0000000000..b3ff6850e3 --- /dev/null +++ b/board/sifive/fu540/spl.c @@ -0,0 +1,72 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2019 SiFive, Inc + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifive.com + */ + +#include <common.h> +#include <spl.h> +#include <misc.h> +#include <asm/gpio.h> +#include <asm/arch/gpio.h> +#include <asm/arch/spl.h> + +#define GEM_PHY_RESET SIFIVE_GENERIC_GPIO_NR(0, 12) + +int init_clk_and_ddr(void) +{ + int ret; + + ret = soc_spl_init(); + if (ret) { + debug("FU540 SPL init failed: %d\n", ret); + return ret; + } + + /* + * GEMGXL init VSC8541 PHY reset sequence; + * leave pull-down active for 2ms + */ + udelay(2000); + ret = gpio_request(GEM_PHY_RESET, "gem_phy_reset"); + if (ret) { + debug("gem_phy_reset gpio request failed: %d\n", ret); + return ret; + } + + /* Set GPIO 12 (PHY NRESET) */ + ret = gpio_direction_output(GEM_PHY_RESET, 1); + if (ret) { + debug("gem_phy_reset gpio direction set failed: %d\n", ret); + return ret; + } + + udelay(1); + + /* Reset PHY again to enter unmanaged mode */ + gpio_set_value(GEM_PHY_RESET, 0); + udelay(1); + gpio_set_value(GEM_PHY_RESET, 1); + mdelay(15); + + return 0; +} + +void board_init_f(ulong dummy) +{ + int ret; + + ret = spl_early_init(); + if (ret) + panic("spl_early_init() failed: %d\n", ret); + + arch_cpu_init_dm(); + + preloader_console_init(); + + ret = init_clk_and_ddr(); + if (ret) + panic("init_clk_and_ddr() failed: %d\n", ret); +} diff --git a/include/configs/sifive-fu540.h b/include/configs/sifive-fu540.h index 2756ed5a77..ef3ae9b650 100644 --- a/include/configs/sifive-fu540.h +++ b/include/configs/sifive-fu540.h @@ -11,6 +11,22 @@
+#ifdef CONFIG_SPL + +#define CONFIG_SPL_MAX_SIZE 0x00100000 +#define CONFIG_SPL_BSS_START_ADDR 0x85000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 +#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ + CONFIG_SPL_BSS_MAX_SIZE) +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00100000 + +#define CONFIG_SPL_LOAD_FIT_ADDRESS 0x84000000 + +#define CONFIG_SPL_STACK (0x08000000 + 0x001D0000 - \ + GENERATED_GBL_DATA_SIZE) + +#endif + #define CONFIG_SYS_SDRAM_BASE 0x80000000 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_2M)
@@ -24,6 +40,7 @@
/* Environment options */
+#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ func(DHCP, dhcp, na) @@ -43,5 +60,6 @@ #define CONFIG_PREBOOT \ "setenv fdt_addr ${fdtcontroladdr};" \ "fdt addr ${fdtcontroladdr};" +#endif
#endif /* __CONFIG_H */
This is a sample GPT partition layout for SD card, right now three important partitions are added to make the system bootable.
partition layout:
Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000022 0x00000821 "loader1" attrs: 0x0000000000000000 type: 5b193300-fc78-40cd-8002-e86c45580b47 guid: cbcbef44-e627-42bc-b134-93b6f3784b8c 2 0x00000822 0x00002821 "loader2" attrs: 0x0000000000000000 type: 2e54b353-1271-4842-806f-e436d6af6985 guid: f54eba28-d8de-4852-978d-1a673777e2ae 3 0x00002822 0x00020821 "rootfs" attrs: 0x0000000000000004 type: 0fc63daf-8483-4772-8e79-3d69d8477de4 type: linux guid: 9561df46-8d55-4799-a83b-cfee9ef6ff93
Note: - loader1 would be fsbl or spl - loader2 would be U-Boot or U-Boot proper
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Pragnesh Patel pragnesh.patel@sifive.com --- board/sifive/fu540/Kconfig | 2 ++ include/configs/sifive-fu540.h | 13 +++++++++++++ 2 files changed, 15 insertions(+)
diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index 4a77a2a37b..86193d7668 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -34,6 +34,8 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply CMD_EXT4 imply CMD_FAT imply CMD_FS_GENERIC + imply CMD_GPT + imply PARTITION_TYPE_GUID imply CMD_NET imply CMD_PING imply CMD_SF diff --git a/include/configs/sifive-fu540.h b/include/configs/sifive-fu540.h index ef3ae9b650..72c841eb9b 100644 --- a/include/configs/sifive-fu540.h +++ b/include/configs/sifive-fu540.h @@ -47,6 +47,15 @@
#include <config_distro_bootcmd.h>
+#define TYPE_GUID_LOADER1 "5B193300-FC78-40CD-8002-E86C45580B47" +#define TYPE_GUID_LOADER2 "2E54B353-1271-4842-806F-E436D6AF6985" +#define TYPE_GUID_SYSTEM "0FC63DAF-8483-4772-8E79-3D69D8477DE4" + +#define PARTS_DEFAULT \ + "name=loader1,start=17K,size=1M,type=${type_guid_gpt_loader1};" \ + "name=loader2,size=4MB,type=${type_guid_gpt_loader2};" \ + "name=system,size=-,bootable,type=${type_guid_gpt_system};" + #define CONFIG_EXTRA_ENV_SETTINGS \ "fdt_high=0xffffffffffffffff\0" \ "initrd_high=0xffffffffffffffff\0" \ @@ -55,6 +64,10 @@ "scriptaddr=0x88100000\0" \ "pxefile_addr_r=0x88200000\0" \ "ramdisk_addr_r=0x88300000\0" \ + "type_guid_gpt_loader1=" TYPE_GUID_LOADER1 "\0" \ + "type_guid_gpt_loader2=" TYPE_GUID_LOADER2 "\0" \ + "type_guid_gpt_system=" TYPE_GUID_SYSTEM "\0" \ + "partitions=" PARTS_DEFAULT "\0" \ BOOTENV
Add U-Boot proper sector start offset for SiFive FU540. This value is based on the partition layout supported by SiFive FU540.
u-boot.itb need to write on this specific offset so-that the SPL will retrieve it from here and load.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Pragnesh Patel pragnesh.patel@sifive.com --- common/spl/Kconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 6f37f75650..24c746b2df 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -308,7 +308,7 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR ARCH_MX6 || ARCH_MX7 || \ ARCH_ROCKCHIP || ARCH_MVEBU || ARCH_SOCFPGA || \ ARCH_AT91 || ARCH_ZYNQ || ARCH_KEYSTONE || OMAP34XX || \ - OMAP44XX || OMAP54XX || AM33XX || AM43XX + OMAP44XX || OMAP54XX || AM33XX || AM43XX || TARGET_SIFIVE_FU540 help Use sector number for specifying U-Boot location on MMC/SD in raw mode. @@ -325,6 +325,7 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR default 0x300 if ARCH_ZYNQ || ARCH_KEYSTONE || OMAP34XX || OMAP44XX || \ OMAP54XX || AM33XX || AM43XX || ARCH_K3 default 0x4000 if ARCH_ROCKCHIP + default 0x822 if TARGET_SIFIVE_FU540 help Address on the MMC to load U-Boot from, when the MMC is being used in raw mode. Units: MMC sectors (1 sector = 512 bytes).
With sifive_fu540_defconfig:
User can use FSBL or u-boot-spl.bin anyone at a time.
For FSBL, fsbl->fw_payload.bin (opensbi + U-Boot)
For u-boot-spl.bin, u-boot-spl.bin->FIT image (opensbi + U-Boot proper + dtb)
U-Boot SPL will be loaded by ZSBL from SD card (replace fsbl.bin with u-boot-spl.bin) and runs in L2 LIM in machine mode and then load FIT image u-boot.itb from SD card into RAM.
U-Boot SPL expects u-boot.itb FIT image at the starting of SD card sector number (0x822) of GUID type "2E54B353-1271-4842-806F-E436D6AF6985"
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com --- configs/sifive_fu540_defconfig | 8 ++ doc/board/sifive/fu540.rst | 134 +++++++++++++++++++++++++++++++++ 2 files changed, 142 insertions(+)
diff --git a/configs/sifive_fu540_defconfig b/configs/sifive_fu540_defconfig index f805aacc7a..8d412f8d6a 100644 --- a/configs/sifive_fu540_defconfig +++ b/configs/sifive_fu540_defconfig @@ -1,6 +1,11 @@ CONFIG_RISCV=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_ENV_SIZE=0x20000 +CONFIG_SPL_MMC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_SPL_SPI_SUPPORT=y CONFIG_TARGET_SIFIVE_FU540=y CONFIG_ARCH_RV64I=y CONFIG_RISCV_SMODE=y @@ -9,7 +14,10 @@ CONFIG_FIT=y CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_OF_BOARD_FIXUP=y CONFIG_DEFAULT_DEVICE_TREE="hifive-unleashed-a00" CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_CLK=y CONFIG_DM_MTD=y diff --git a/doc/board/sifive/fu540.rst b/doc/board/sifive/fu540.rst index 610ba87074..89e8d66c56 100644 --- a/doc/board/sifive/fu540.rst +++ b/doc/board/sifive/fu540.rst @@ -31,6 +31,9 @@ TODO: stdout-path = "/soc/serial@10010000:115200"; };
+Booting from MMC using FSBL +--------------------------- + Building --------
@@ -421,3 +424,134 @@ as well.
Please press Enter to activate this console. / # + +Booting from MMC using U-Boot SPL +--------------------------------- + +Building +-------- + +Before building U-Boot SPL, OpenSBI must be built first. OpenSBI can be +cloned and built for FU540 as below: + +.. code-block:: console + + git clone https://github.com/riscv/opensbi.git + cd opensbi + make PLATFORM=generic FW_DYNAMIC=y + +Copy OpenSBI FW_DYNAMIC image +(build/platform/generic/firmware/fw_dynamic.bin) into U-Boot +root directory + +.. code-block:: console + + cp build/platform/generic/firmware/fw_dynamic.bin <u-boot-dir> + +Now build the U-Boot SPL and U-Boot proper + +.. code-block:: console + + cd <U-Boot-dir> + make sifive_fu540_defconfig + make + +This will generate spl/u-boot-spl.bin and FIT image (u-boot.itb) + + +Flashing +-------- + +ZSBL loads the U-Boot SPL (u-boot-spl.bin) from a partition with GUID type +5B193300-FC78-40CD-8002-E86C45580B47 + +U-Boot SPL expects a U-Boot FIT image (u-boot.itb) from a partition with GUID +type 2E54B353-1271-4842-806F-E436D6AF6985 + +FIT image (u-boot.itb) is a combination of fw_dynamic.bin, u-boot-nodtb.bin and +device tree blob (hifive-unleashed-a00.dtb) + +Format the SD card (make sure the disk has GPT, otherwise use gdisk to switch) + +.. code-block:: none + + # sudo sgdisk --clear \ + > --set-alignment=2 \ + > --new=1:34:2081 --change-name=1:loader1 --typecode=1:5B193300-FC78-40CD-8002-E86C45580B47 \ + > --new=2:2082:10273 --change-name=2:loader2 --typecode=2:2E54B353-1271-4842-806F-E436D6AF6985 \ + > --new=3:10274: --change-name=3:rootfs --typecode=3:0FC63DAF-8483-4772-8E79-3D69D8477DE4 \ + > /dev/sda + +Program the SD card + +.. code-block:: none + + sudo dd if=spl/u-boot-spl.bin of=/dev/sda seek=34 + sudo dd if=u-boot.itb of=/dev/sda seek=2082 + +Booting +------- +Once you plugin the sdcard and power up, you should see the U-Boot prompt. + +Sample boot log from HiFive Unleashed board +------------------------------------------- + +.. code-block:: none + + U-Boot SPL 2020.04-rc2-00109-g63efc7e07e-dirty (Apr 30 2020 - 13:52:36 +0530) + Trying to boot from MMC1 + + + U-Boot 2020.04-rc2-00109-g63efc7e07e-dirty (Apr 30 2020 - 13:52:36 +0530) + + CPU: rv64imafdc + Model: SiFive HiFive Unleashed A00 + DRAM: 8 GiB + MMC: spi@10050000:mmc@0: 0 + In: serial@10010000 + Out: serial@10010000 + Err: serial@10010000 + Board serial number should not be 0 !! + Net: + Warning: ethernet@10090000 (eth0) using random MAC address - 96:06:92:18:eb:04 + eth0: ethernet@10090000 + Hit any key to stop autoboot: 0 + => version + U-Boot 2020.04-rc2-00109-g63efc7e07e-dirty (Apr 30 2020 - 13:52:36 +0530) + + riscv64-unknown-linux-gnu-gcc (crosstool-NG 1.24.0.37-3f461da) 9.2.0 + GNU ld (crosstool-NG 1.24.0.37-3f461da) 2.32 + => mmc info + Device: spi@10050000:mmc@0 + Manufacturer ID: 3 + OEM: 5344 + Name: SC16G + Bus Speed: 20000000 + Mode: SD Legacy + Rd Block Len: 512 + SD version 2.0 + High Capacity: Yes + Capacity: 14.8 GiB + Bus Width: 1-bit + Erase Group Size: 512 Bytes + => mmc part + + Partition Map for MMC device 0 -- Partition Type: EFI + + Part Start LBA End LBA Name + Attributes + Type GUID + Partition GUID + 1 0x00000022 0x00000821 "loader1" + attrs: 0x0000000000000000 + type: 5b193300-fc78-40cd-8002-e86c45580b47 + guid: 66e2b5d2-74db-4df8-ad6f-694b3617f87f + 2 0x00000822 0x00002821 "loader2" + attrs: 0x0000000000000000 + type: 2e54b353-1271-4842-806f-e436d6af6985 + guid: 8befaeaf-bca0-435d-b002-e201f37c0a2f + 3 0x00002822 0x01dacbde "rootfs" + attrs: 0x0000000000000000 + type: 0fc63daf-8483-4772-8e79-3d69d8477de4 + type: linux + guid: 9faa81b6-39b1-4418-af5e-89c48f29c20d
On Thu, May 14, 2020 at 5:24 PM Pragnesh Patel pragnesh.patel@sifive.com wrote:
Building
+Building +--------
cd opensbi
cd <U-Boot-dir>
make
+Flashing +--------
> --set-alignment=2 \
> /dev/sda
CPU: rv64imafdc
DRAM: 8 GiB
In: serial@10010000
Net:
Look like v10 seems to be a change, I can see memory region print?
U-Boot SPL 2020.07-rc1-00540-gd06cdf6989 (May 15 2020 - 23:00:17 +0530) Trying to boot from MMC1
U-Boot 2020.07-rc1-00540-gd06cdf6989 (May 15 2020 - 23:00:17 +0530)
CPU: rv64imafdc Model: SiFive HiFive Unleashed A00 DRAM: 8 GiB No reserved memory region found in source FDT MMC: spi@10050000:mmc@0: 0 In: serial@10010000 Out: serial@10010000 Err: serial@10010000 Net: eth0: ethernet@10090000 Hit any key to stop autoboot: 0
Jagan.
Hi Jagan,
-----Original Message----- From: Jagan Teki jagan@amarulasolutions.com Sent: 15 May 2020 23:05 To: Pragnesh Patel pragnesh.patel@sifive.com Cc: U-Boot-Denx u-boot@lists.denx.de; Atish Patra atish.patra@wdc.com; Palmer Dabbelt palmerdabbelt@google.com; Bin Meng bmeng.cn@gmail.com; Paul Walmsley paul.walmsley@sifive.com; Anup Patel anup.patel@wdc.com; Sagar Kadam sagar.kadam@sifive.com; Rick Chen rick@andestech.com; Palmer Dabbelt palmer@dabbelt.com Subject: Re: [PATCH v10 17/18] configs: fu540: Add config options for U-Boot SPL
E436D6AF6985"
Building
+Building +--------
+Before building U-Boot SPL, OpenSBI must be built first. OpenSBI can +be cloned and built for FU540 as below:
cd opensbi
+Copy OpenSBI FW_DYNAMIC image +(build/platform/generic/firmware/fw_dynamic.bin) into U-Boot root +directory
cd <U-Boot-dir>
make
+Flashing +--------
+ZSBL loads the U-Boot SPL (u-boot-spl.bin) from a partition with GUID +type +5B193300-FC78-40CD-8002-E86C45580B47
+U-Boot SPL expects a U-Boot FIT image (u-boot.itb) from a partition +with GUID type 2E54B353-1271-4842-806F-E436D6AF6985
+FIT image (u-boot.itb) is a combination of fw_dynamic.bin, +u-boot-nodtb.bin and device tree blob (hifive-unleashed-a00.dtb)
+Format the SD card (make sure the disk has GPT, otherwise use gdisk +to switch)
> --set-alignment=2 \
> /dev/sda
prompt.
13:52:36 +0530)
- 13:52:36 +0530)
CPU: rv64imafdc
DRAM: 8 GiB
In: serial@10010000
Net:
96:06:92:18:eb:04
I haven't got this "memory region" print, can you please update your U-Boot and OpenSBI Repo and recheck.
U-Boot SPL 2020.07-rc2-00681-gcbf8ba388d (May 16 2020 - 11:36:52 +0530) Trying to boot from MMC1
U-Boot 2020.07-rc2-00681-gcbf8ba388d (May 16 2020 - 11:36:52 +0530)
CPU: rv64imafdc Model: SiFive HiFive Unleashed A00 DRAM: 8 GiB MMC: spi@10050000:mmc@0: 0 In: serial@10010000 Out: serial@10010000 Err: serial@10010000 Board serial number should not be 0 !! Net: Warning: ethernet@10090000 (eth0) using random MAC address - 22:48:01:00:fc:6c eth0: ethernet@10090000 Hit any key to stop autoboot: 0 =>
Jagan.
On Sat, May 16, 2020 at 11:42 AM Pragnesh Patel pragnesh.patel@sifive.com wrote:
Hi Jagan,
E436D6AF6985"
Building
+Building +--------
cd opensbi
cd <U-Boot-dir>
make
+Flashing +--------
> --set-alignment=2 \
> /dev/sda
prompt.
13:52:36 +0530)
- 13:52:36 +0530)
CPU: rv64imafdc
DRAM: 8 GiB
In: serial@10010000
Net:
96:06:92:18:eb:04
I have checked with latest opensbi, still got it.
U-Boot SPL 2020.07-rc2-00154-gb37b258d49-dirty (May 19 2020 - 21:33:36 +0530) Trying to boot from MMC1
OpenSBI v0.6 ____ _____ ____ _____ / __ \ / ____| _ _ _| | | | |_ __ ___ _ __ | (___ | |_) || | | | | | '_ \ / _ \ '_ \ ___ | _ < | | | |__| | |_) | __/ | | |____) | |_) || |_ ____/| .__/ ___|_| |_|_____/|____/_____| | | |_|
Platform Name : SiFive Freedom U540 Platform HART Features : RV64ACDFIMSU Platform Max HARTs : 5 Current Hart : 3 Firmware Base : 0x80000000 Firmware Size : 100 KB Runtime SBI Version : 0.2
MIDELEG : 0x0000000000000222 MEDELEG : 0x000000000000b109 PMP0 : 0x0000000080000000-0x000000008001ffff (A) PMP1 : 0x0000000000000000-0x0000007fffffffff (A,R,W,X)
U-Boot 2020.07-rc2-00154-gb37b258d49-dirty (May 19 2020 - 21:33:36 +0530)
opensbi sha1: 89ba63493c4ce98861144180e408d6db391fd1c3
gcc version: gcc version 8.4.0 (Buildroot 2020.05-git-00692-gd645010af2)
Jagan.
Hi Jagan,
On Wed, May 20, 2020 at 12:11 AM Jagan Teki jagan@amarulasolutions.com wrote:
Hi Jagan,
E436D6AF6985"
Building
+Building +--------
cd opensbi
cd <U-Boot-dir>
make
+Flashing +--------
> --set-alignment=2 \
> /dev/sda
prompt.
13:52:36 +0530)
- 13:52:36 +0530)
CPU: rv64imafdc
DRAM: 8 GiB
In: serial@10010000
Net:
96:06:92:18:eb:04
Do you mean this message?
If yes, you need use OpenSBI v0.7.
Regards, Bin
Hi Jagan,
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 20 May 2020 10:07 To: Jagan Teki jagan@amarulasolutions.com Cc: Pragnesh Patel pragnesh.patel@sifive.com; U-Boot-Denx <u- boot@lists.denx.de>; Atish Patra atish.patra@wdc.com; Palmer Dabbelt palmerdabbelt@google.com; Paul Walmsley paul.walmsley@sifive.com; Anup Patel anup.patel@wdc.com; Sagar Kadam sagar.kadam@sifive.com; Rick Chen rick@andestech.com; Palmer Dabbelt palmer@dabbelt.com Subject: Re: [PATCH v10 17/18] configs: fu540: Add config options for U-Boot SPL
Hi Jagan,
Hi Jagan,
E436D6AF6985"
Building
+Building +--------
+Before building U-Boot SPL, OpenSBI must be built first. OpenSBI +can be cloned and built for FU540 as below:
cd opensbi
<u-boot-dir>
cd <U-Boot-dir>
make
+Flashing +--------
+ZSBL loads the U-Boot SPL (u-boot-spl.bin) from a partition with +GUID type +5B193300-FC78-40CD-8002-E86C45580B47
+U-Boot SPL expects a U-Boot FIT image (u-boot.itb) from a +partition with GUID type 2E54B353-1271-4842-806F-E436D6AF6985
+Format the SD card (make sure the disk has GPT, otherwise use +gdisk to switch)
> --set-alignment=2 \
- --typecode=1:5B193300-
- --typecode=3:0FC63DAF-
> /dev/sda
+Booting +------- +Once you plugin the sdcard and power up, you should see the +U-Boot
prompt.
- 2020 -
13:52:36 +0530)
- 13:52:36 +0530)
CPU: rv64imafdc
DRAM: 8 GiB
In: serial@10010000
Net:
- address -
96:06:92:18:eb:04
I have updated my U-Boot and OpenSBI repo and recheck., still not getting this "reserved memory" print.
Below is my observation from your boot prints: - It looks like your OpenSBI repo is not updated one. Latest OpenSBI version is v0.7 . - you are using "make PLATFORM=sifive/fu540" instead of " make PLATFORM=generic"
Can you please rebuild OpenSBI with above suggestion and reconfirm.
U-Boot sha1: c2279d784e35fa25ee3a9fa28a74a1ba545f8c1e (Merge branch '2020-05-18-reduce-size-of-common.h')
OpenSBI sha1: 89ba63493c4ce98861144180e408d6db391fd1c3 (include: sbi: Add firmware extension constants)
Boot prints:
U-Boot SPL 2020.07-rc2-00711-g179f936b5c-dirty (May 20 2020 - 12:42:00 +0530) Trying to boot from MMC1
OpenSBI v0.7-59-g89ba634 ____ _____ ____ _____ / __ \ / ____| _ _ _| | | | |_ __ ___ _ __ | (___ | |_) || | | | | | '_ \ / _ \ '_ \ ___ | _ < | | | |__| | |_) | __/ | | |____) | |_) || |_ ____/| .__/ ___|_| |_|_____/|____/_____| | | |_|
Platform Name : SiFive HiFive Unleashed A00 Platform Features : timer,mfdeleg Platform HART Count : 5 Boot HART ID : 1 Boot HART ISA : rv64imafdcsu BOOT HART Features : pmp,scounteren,mcounteren BOOT HART PMP Count : 16 Firmware Base : 0x80000000 Firmware Size : 116 KB Runtime SBI Version : 0.2
U-Boot 2020.07-rc2-00711-g179f936b5c-dirty (May 20 2020 - 12:42:00 +0530)
CPU: rv64imafdc Model: SiFive HiFive Unleashed A00 DRAM: 8 GiB MMC: spi@10050000:mmc@0: 0 In: serial@10010000 Out: serial@10010000 Err: serial@10010000 Board serial number should not be 0 !! Net: Warning: ethernet@10090000 (eth0) using random MAC address - 7a:3f:bf:c1:f9:29 eth0: ethernet@10090000 Hit any key to stop autoboot: 0 =>
Regards, Bin
Hi Jagan,
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Pragnesh Patel Sent: 20 May 2020 12:55 To: Bin Meng bmeng.cn@gmail.com; Jagan Teki jagan@amarulasolutions.com Cc: U-Boot-Denx u-boot@lists.denx.de; Atish Patra atish.patra@wdc.com; Palmer Dabbelt palmerdabbelt@google.com; Paul Walmsley paul.walmsley@sifive.com; Anup Patel anup.patel@wdc.com; Sagar Kadam sagar.kadam@sifive.com; Rick Chen rick@andestech.com; Palmer Dabbelt palmer@dabbelt.com Subject: RE: [PATCH v10 17/18] configs: fu540: Add config options for U-Boot SPL
Hi Jagan,
Hi Jagan,
Hi Jagan,
Sagar
E436D6AF6985"
Building
+Building +--------
+Before building U-Boot SPL, OpenSBI must be built first. +OpenSBI can be cloned and built for FU540 as below:
cd opensbi
<u-boot-dir>
cd <U-Boot-dir>
make
+This will generate spl/u-boot-spl.bin and FIT image +(u-boot.itb)
+Flashing +--------
+ZSBL loads the U-Boot SPL (u-boot-spl.bin) from a partition +with GUID type +5B193300-FC78-40CD-8002-E86C45580B47
+FIT image (u-boot.itb) is a combination of fw_dynamic.bin, +u-boot-nodtb.bin and device tree blob +(hifive-unleashed-a00.dtb)
> --set-alignment=2 \
> /dev/sda
prompt.
- 2020 -
13:52:36 +0530)
- 13:52:36 +0530)
CPU: rv64imafdc
DRAM: 8 GiB
In: serial@10010000
Net:
- address -
96:06:92:18:eb:04
v0.7 .
PLATFORM=generic"
Boot prints:
Any comments ? I am planning to send v12.
Regards, Bin
Hi Pragnesh,
On Wed, May 20, 2020 at 9:33 PM Pragnesh Patel pragnesh.patel@sifive.com wrote:
Hi Jagan,
Hi Jagan,
Hi Jagan,
Hi Jagan,
Sagar
On Thu, May 14, 2020 at 5:24 PM Pragnesh Patel pragnesh.patel@sifive.com wrote: > > With sifive_fu540_defconfig: > > User can use FSBL or u-boot-spl.bin anyone at a time. > > For FSBL, > fsbl->fw_payload.bin (opensbi + U-Boot) > > For u-boot-spl.bin, > u-boot-spl.bin->FIT image (opensbi + U-Boot proper + dtb) > > U-Boot SPL will be loaded by ZSBL from SD card (replace fsbl.bin > with > u-boot-spl.bin) and runs in L2 LIM in machine mode and then load > FIT image u-boot.itb from SD card into RAM. > > U-Boot SPL expects u-boot.itb FIT image at the starting of SD > card sector number (0x822) of GUID type > "2E54B353-1271-4842-806F- E436D6AF6985" > > Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com > Signed-off-by: Jagan Teki jagan@amarulasolutions.com > Reviewed-by: Jagan Teki jagan@amarulasolutions.com > --- > configs/sifive_fu540_defconfig | 8 ++ > doc/board/sifive/fu540.rst | 134
> 2 files changed, 142 insertions(+) > > diff --git a/configs/sifive_fu540_defconfig > b/configs/sifive_fu540_defconfig index f805aacc7a..8d412f8d6a > 100644 > --- a/configs/sifive_fu540_defconfig > +++ b/configs/sifive_fu540_defconfig > @@ -1,6 +1,11 @@ > CONFIG_RISCV=y > +CONFIG_SPL_GPIO_SUPPORT=y > +CONFIG_SYS_MALLOC_F_LEN=0x3000 > CONFIG_ENV_SIZE=0x20000 > +CONFIG_SPL_MMC_SUPPORT=y > CONFIG_NR_DRAM_BANKS=1 > +CONFIG_SPL=y > +CONFIG_SPL_SPI_SUPPORT=y > CONFIG_TARGET_SIFIVE_FU540=y > CONFIG_ARCH_RV64I=y > CONFIG_RISCV_SMODE=y > @@ -9,7 +14,10 @@ CONFIG_FIT=y > CONFIG_MISC_INIT_R=y > CONFIG_DISPLAY_CPUINFO=y > CONFIG_DISPLAY_BOARDINFO=y > +CONFIG_SPL_SEPARATE_BSS=y > +CONFIG_SPL_YMODEM_SUPPORT=y > CONFIG_OF_BOARD_FIXUP=y > CONFIG_DEFAULT_DEVICE_TREE="hifive-unleashed-a00" > CONFIG_SYS_RELOC_GD_ENV_ADDR=y > +CONFIG_SPL_CLK=y > CONFIG_DM_MTD=y > diff --git a/doc/board/sifive/fu540.rst > b/doc/board/sifive/fu540.rst index 610ba87074..89e8d66c56 100644 > --- a/doc/board/sifive/fu540.rst > +++ b/doc/board/sifive/fu540.rst > @@ -31,6 +31,9 @@ TODO: > stdout-path = "/soc/serial@10010000:115200"; > }; > > +Booting from MMC using FSBL > +--------------------------- > + > Building > -------- > > @@ -421,3 +424,134 @@ as well. > > Please press Enter to activate this console. > / # > + > +Booting from MMC using U-Boot SPL > +--------------------------------- > + > +Building > +-------- > + > +Before building U-Boot SPL, OpenSBI must be built first. > +OpenSBI can be cloned and built for FU540 as below: > + > +.. code-block:: console > + > + git clone https://github.com/riscv/opensbi.git > + cd opensbi > + make PLATFORM=generic FW_DYNAMIC=y > + > +Copy OpenSBI FW_DYNAMIC image > +(build/platform/generic/firmware/fw_dynamic.bin) into U-Boot > +root directory > + > +.. code-block:: console > + > + cp build/platform/generic/firmware/fw_dynamic.bin > + <u-boot-dir> > + > +Now build the U-Boot SPL and U-Boot proper > + > +.. code-block:: console > + > + cd <U-Boot-dir> > + make sifive_fu540_defconfig > + make > + > +This will generate spl/u-boot-spl.bin and FIT image > +(u-boot.itb) > + > + > +Flashing > +-------- > + > +ZSBL loads the U-Boot SPL (u-boot-spl.bin) from a partition > +with GUID type > +5B193300-FC78-40CD-8002-E86C45580B47 > + > +U-Boot SPL expects a U-Boot FIT image (u-boot.itb) from a > +partition with GUID type 2E54B353-1271-4842-806F-E436D6AF6985 > + > +FIT image (u-boot.itb) is a combination of fw_dynamic.bin, > +u-boot-nodtb.bin and device tree blob > +(hifive-unleashed-a00.dtb) > + > +Format the SD card (make sure the disk has GPT, otherwise use > +gdisk to switch) > + > +.. code-block:: none > + > + # sudo sgdisk --clear \ > + > --set-alignment=2 \ > + > --new=1:34:2081 --change-name=1:loader1 > + --typecode=1:5B193300- FC78-40CD-8002-E86C45580B47 \ > + > --new=2:2082:10273 --change-name=2:loader2 -- typecode=2:2E54B353-1271-4842-806F-E436D6AF6985 \ > + > --new=3:10274: --change-name=3:rootfs > + --typecode=3:0FC63DAF- 8483-4772-8E79-3D69D8477DE4 \ > + > /dev/sda > + > +Program the SD card > + > +.. code-block:: none > + > + sudo dd if=spl/u-boot-spl.bin of=/dev/sda seek=34 > + sudo dd if=u-boot.itb of=/dev/sda seek=2082 > + > +Booting > +------- > +Once you plugin the sdcard and power up, you should see the > +U-Boot prompt. > + > +Sample boot log from HiFive Unleashed board > +------------------------------------------- > + > +.. code-block:: none > + > + U-Boot SPL 2020.04-rc2-00109-g63efc7e07e-dirty (Apr 30 > + 2020 - 13:52:36 +0530) > + Trying to boot from MMC1 > + > + > + U-Boot 2020.04-rc2-00109-g63efc7e07e-dirty (Apr 30 2020 > + - > + 13:52:36 +0530) > + > + CPU: rv64imafdc > + Model: SiFive HiFive Unleashed A00 > + DRAM: 8 GiB > + MMC: spi@10050000:mmc@0: 0 > + In: serial@10010000 > + Out: serial@10010000 > + Err: serial@10010000 > + Board serial number should not be 0 !! > + Net: > + Warning: ethernet@10090000 (eth0) using random MAC > + address - 96:06:92:18:eb:04 > + eth0: ethernet@10090000 > + Hit any key to stop autoboot: 0
v0.7 .
PLATFORM=generic"
Boot prints:
I did not see that. But I see your log has
and I did not see that. This means that OTP driver does not work on your board?
Regards, Bin
Hi Bin,
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 20 May 2020 19:14 To: Pragnesh Patel pragnesh.patel@sifive.com Cc: Jagan Teki jagan@amarulasolutions.com; U-Boot-Denx <u- boot@lists.denx.de>; Atish Patra atish.patra@wdc.com; Palmer Dabbelt palmerdabbelt@google.com; Paul Walmsley paul.walmsley@sifive.com; Anup Patel anup.patel@wdc.com; Sagar Kadam sagar.kadam@sifive.com; Rick Chen rick@andestech.com; Palmer Dabbelt palmer@dabbelt.com Subject: Re: [PATCH v10 17/18] configs: fu540: Add config options for U-Boot SPL
Hi Pragnesh,
Hi Jagan,
Chen
Hi Jagan,
Hi Jagan,
Hi Jagan,
>-----Original Message----- >From: Jagan Teki jagan@amarulasolutions.com >Sent: 15 May 2020 23:05 >To: Pragnesh Patel pragnesh.patel@sifive.com >Cc: U-Boot-Denx u-boot@lists.denx.de; Atish Patra >atish.patra@wdc.com; Palmer Dabbelt
>Bin Meng bmeng.cn@gmail.com; Paul Walmsley >paul.walmsley@sifive.com; Anup Patel anup.patel@wdc.com;
Sagar
>Palmer Dabbelt palmer@dabbelt.com >Subject: Re: [PATCH v10 17/18] configs: fu540: Add config >options for U-Boot SPL > >[External Email] Do not click links or attachments unless you >recognize the sender and know the content is safe > >On Thu, May 14, 2020 at 5:24 PM Pragnesh Patel >pragnesh.patel@sifive.com wrote: >> >> With sifive_fu540_defconfig: >> >> User can use FSBL or u-boot-spl.bin anyone at a time. >> >> For FSBL, >> fsbl->fw_payload.bin (opensbi + U-Boot) >> >> For u-boot-spl.bin, >> u-boot-spl.bin->FIT image (opensbi + U-Boot proper + dtb) >> >> U-Boot SPL will be loaded by ZSBL from SD card (replace >> fsbl.bin with >> u-boot-spl.bin) and runs in L2 LIM in machine mode and then >> load FIT image u-boot.itb from SD card into RAM. >> >> U-Boot SPL expects u-boot.itb FIT image at the starting of SD >> card sector number (0x822) of GUID type >> "2E54B353-1271-4842-806F- >E436D6AF6985" >> >> Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com >> Signed-off-by: Jagan Teki jagan@amarulasolutions.com >> Reviewed-by: Jagan Teki jagan@amarulasolutions.com >> --- >> configs/sifive_fu540_defconfig | 8 ++ >> doc/board/sifive/fu540.rst | 134
>> 2 files changed, 142 insertions(+) >> >> diff --git a/configs/sifive_fu540_defconfig >> b/configs/sifive_fu540_defconfig index f805aacc7a..8d412f8d6a >> 100644 >> --- a/configs/sifive_fu540_defconfig >> +++ b/configs/sifive_fu540_defconfig >> @@ -1,6 +1,11 @@ >> CONFIG_RISCV=y >> +CONFIG_SPL_GPIO_SUPPORT=y >> +CONFIG_SYS_MALLOC_F_LEN=0x3000 >> CONFIG_ENV_SIZE=0x20000 >> +CONFIG_SPL_MMC_SUPPORT=y >> CONFIG_NR_DRAM_BANKS=1 >> +CONFIG_SPL=y >> +CONFIG_SPL_SPI_SUPPORT=y >> CONFIG_TARGET_SIFIVE_FU540=y CONFIG_ARCH_RV64I=y >> CONFIG_RISCV_SMODE=y @@ -9,7 +14,10 @@ CONFIG_FIT=y >> CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_CPUINFO=y >> CONFIG_DISPLAY_BOARDINFO=y >> +CONFIG_SPL_SEPARATE_BSS=y >> +CONFIG_SPL_YMODEM_SUPPORT=y >> CONFIG_OF_BOARD_FIXUP=y >> CONFIG_DEFAULT_DEVICE_TREE="hifive-unleashed-a00" >> CONFIG_SYS_RELOC_GD_ENV_ADDR=y >> +CONFIG_SPL_CLK=y >> CONFIG_DM_MTD=y >> diff --git a/doc/board/sifive/fu540.rst >> b/doc/board/sifive/fu540.rst index 610ba87074..89e8d66c56 >> 100644 >> --- a/doc/board/sifive/fu540.rst >> +++ b/doc/board/sifive/fu540.rst >> @@ -31,6 +31,9 @@ TODO: >> stdout-path = "/soc/serial@10010000:115200"; >> }; >> >> +Booting from MMC using FSBL >> +--------------------------- >> + >> Building >> -------- >> >> @@ -421,3 +424,134 @@ as well. >> >> Please press Enter to activate this console. >> / # >> + >> +Booting from MMC using U-Boot SPL >> +--------------------------------- >> + >> +Building >> +-------- >> + >> +Before building U-Boot SPL, OpenSBI must be built first. >> +OpenSBI can be cloned and built for FU540 as below: >> + >> +.. code-block:: console >> + >> + git clone https://github.com/riscv/opensbi.git >> + cd opensbi >> + make PLATFORM=generic FW_DYNAMIC=y >> + >> +Copy OpenSBI FW_DYNAMIC image >> +(build/platform/generic/firmware/fw_dynamic.bin) into U-Boot >> +root directory >> + >> +.. code-block:: console >> + >> + cp build/platform/generic/firmware/fw_dynamic.bin >> + <u-boot-dir> >> + >> +Now build the U-Boot SPL and U-Boot proper >> + >> +.. code-block:: console >> + >> + cd <U-Boot-dir> >> + make sifive_fu540_defconfig >> + make >> + >> +This will generate spl/u-boot-spl.bin and FIT image >> +(u-boot.itb) >> + >> + >> +Flashing >> +-------- >> + >> +ZSBL loads the U-Boot SPL (u-boot-spl.bin) from a partition >> +with GUID type >> +5B193300-FC78-40CD-8002-E86C45580B47 >> + >> +U-Boot SPL expects a U-Boot FIT image (u-boot.itb) from a >> +partition with GUID type >> +2E54B353-1271-4842-806F-E436D6AF6985 >> + >> +FIT image (u-boot.itb) is a combination of fw_dynamic.bin, >> +u-boot-nodtb.bin and device tree blob >> +(hifive-unleashed-a00.dtb) >> + >> +Format the SD card (make sure the disk has GPT, otherwise >> +use gdisk to switch) >> + >> +.. code-block:: none >> + >> + # sudo sgdisk --clear \ >> + > --set-alignment=2 \ >> + > --new=1:34:2081 --change-name=1:loader1 >> + --typecode=1:5B193300- >FC78-40CD-8002-E86C45580B47 \ >> + > --new=2:2082:10273 --change-name=2:loader2 -- >typecode=2:2E54B353-1271-4842-806F-E436D6AF6985 \ >> + > --new=3:10274: --change-name=3:rootfs >> + --typecode=3:0FC63DAF- >8483-4772-8E79-3D69D8477DE4 \ >> + > /dev/sda >> + >> +Program the SD card >> + >> +.. code-block:: none >> + >> + sudo dd if=spl/u-boot-spl.bin of=/dev/sda seek=34 >> + sudo dd if=u-boot.itb of=/dev/sda seek=2082 >> + >> +Booting >> +------- >> +Once you plugin the sdcard and power up, you should see the >> +U-Boot >prompt. >> + >> +Sample boot log from HiFive Unleashed board >> +------------------------------------------- >> + >> +.. code-block:: none >> + >> + U-Boot SPL 2020.04-rc2-00109-g63efc7e07e-dirty (Apr >> + 30 >> + 2020 - >13:52:36 +0530) >> + Trying to boot from MMC1 >> + >> + >> + U-Boot 2020.04-rc2-00109-g63efc7e07e-dirty (Apr 30 >> + 2020 >> + - >> + 13:52:36 +0530) >> + >> + CPU: rv64imafdc >> + Model: SiFive HiFive Unleashed A00 >> + DRAM: 8 GiB >> + MMC: spi@10050000:mmc@0: 0 >> + In: serial@10010000 >> + Out: serial@10010000 >> + Err: serial@10010000 >> + Board serial number should not be 0 !! >> + Net: >> + Warning: ethernet@10090000 (eth0) using random MAC >> + address - >96:06:92:18:eb:04 >> + eth0: ethernet@10090000 >> + Hit any key to stop autoboot: 0 > >Look like v10 seems to be a change, I can see memory region print? > >U-Boot SPL 2020.07-rc1-00540-gd06cdf6989 (May 15 2020 - >23:00:17 >+0530) >Trying to boot from MMC1 > > >U-Boot 2020.07-rc1-00540-gd06cdf6989 (May 15 2020 - 23:00:17 >+0530) > >CPU: rv64imafdc >Model: SiFive HiFive Unleashed A00 >DRAM: 8 GiB >No reserved memory region found in source FDT >MMC: spi@10050000:mmc@0: 0 >In: serial@10010000 >Out: serial@10010000 >Err: serial@10010000 >Net: eth0: ethernet@10090000 >Hit any key to stop autoboot: 0
version is v0.7 .
PLATFORM=generic"
Boot prints:
OpenSBI v0.7-59-g89ba634 ____ _____ ____ _____ / __ \ / ____| _ _ _| | | | |_ __ ___ _ __ | (___ | |_) || | | | | | '_ \ / _ \ '_ \ ___ | _ < | | | |__| | |_) | __/ | | | | |____) | |_) || |_ ____/| .__/ ___|_| |_|_____/|____/_____| | | |_|
Count :
No OTP driver works perfectly fine, I have tested both read and write.
By mistake, I overwrite my board serial number that's why it shows " Board serial number should not be 0 !!" and ethernet mac address depends on serial number so got that warning " Warning: ethernet@10090000 (eth0) using random MAC address -"
This works perfectly fine on other boards.
Regards, Bin
Hi Pragnesh,
On Thu, May 14, 2020 at 7:54 PM Pragnesh Patel pragnesh.patel@sifive.com wrote:
Building
+Building +--------
cd opensbi
cd <U-Boot-dir>
make
+Flashing +--------
> --set-alignment=2 \
The LBAs in this command do not match what is proposed in this patch:
http://patchwork.ozlabs.org/project/uboot/patch/20200514115258.21042-16-prag...
> /dev/sda
ditto
Regards, Bin
Hi Bin,
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 17 May 2020 18:28 To: Pragnesh Patel pragnesh.patel@sifive.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Atish Patra atish.patra@wdc.com; Palmer Dabbelt palmerdabbelt@google.com; Paul Walmsley paul.walmsley@sifive.com; Jagan Teki jagan@amarulasolutions.com; Anup Patel anup.patel@wdc.com; Sagar Kadam sagar.kadam@sifive.com; Rick Chen rick@andestech.com; Palmer Dabbelt palmer@dabbelt.com Subject: Re: [PATCH v10 17/18] configs: fu540: Add config options for U-Boot SPL
Hi Pragnesh,
E436D6AF6985"
Building
+Building +--------
cd opensbi
cd <U-Boot-dir>
make
+Flashing +--------
> --set-alignment=2 \
- --typecode=3:0FC63DAF-8483-4772-8E79-3D69D8477DE4 \
http://patchwork.ozlabs.org/project/uboot/patch/20200514115258.21042- 16-pragnesh.patel@sifive.com/
I think the LBAs are in decimal here in this patch and hex in the proposed patch.
> /dev/sda
ditto
Same as above.
Regards, Bin
Hi Pragnesh,
On Sun, May 17, 2020 at 10:37 PM Pragnesh Patel pragnesh.patel@sifive.com wrote:
Hi Bin,
Hi Pragnesh,
E436D6AF6985"
Building
+Building +--------
cd opensbi
cd <U-Boot-dir>
make
+Flashing +--------
> --set-alignment=2 \
Ah, yes! Needs to get some sleep :)
Regards, Bin
OpenSBI generic platform support provides platform specific functionality based on the FDT passed by previous booting stage.
Depends on OpenSBI commit: platform: Add generic FDT based platform support (sha1: f1aa9e54e00006ae70aeac638d5b75093520f65d)
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com --- doc/board/sifive/fu540.rst | 13 +------------ 1 file changed, 1 insertion(+), 12 deletions(-)
diff --git a/doc/board/sifive/fu540.rst b/doc/board/sifive/fu540.rst index 89e8d66c56..a51d086a6d 100644 --- a/doc/board/sifive/fu540.rst +++ b/doc/board/sifive/fu540.rst @@ -20,17 +20,6 @@ The support for following drivers are already enabled: 4. SiFive SPI Driver. 5. MMC SPI Driver for MMC/SD support.
-TODO: - -1. U-Boot expects the serial console device entry to be present under /chosen - DT node. Without a serial console U-Boot will panic. Example: - -.. code-block:: none - - chosen { - stdout-path = "/soc/serial@10010000:115200"; - }; - Booting from MMC using FSBL ---------------------------
@@ -61,7 +50,7 @@ firmware. We need to compile OpenSBI with below command:
-make PLATFORM=sifive/fu540 FW_PAYLOAD_PATH=<path to u-boot-dtb.bin> + make PLATFORM=generic FW_PAYLOAD_PATH=<path to u-boot-dtb.bin>
More detailed description of steps required to build FW_PAYLOAD firmware is beyond the scope of this document. Please refer OpenSBI documenation.
On Thu, May 14, 2020 at 7:55 PM Pragnesh Patel pragnesh.patel@sifive.com wrote:
Bin Meng
Jagan Teki
Pragnesh Patel
