[U-Boot] [PATCH v2 RESEND] OMAP: mmc: add support for second and third mmc channels
This patch adds support for the second and third mmc channels on OMAP3 processors
Boards wishing to use this feature should define CONFIG_SYS_MMC_SET_DEV in the board config
Tested on Overo
Signed-off-by: Steve Sakoman steve@sakoman.com Tested-by: Philip Balister philip@opensdr.com
--- arch/arm/include/asm/arch-omap3/mmc_host_def.h | 15 +++++++-- drivers/mmc/omap3_mmc.c | 39 ++++++++++++++++++++++- 2 files changed, 49 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/arch-omap3/mmc_host_def.h b/arch/arm/include/asm/arch-omap3/mmc_host_def.h index aa751c9..43dd705 100644 --- a/arch/arm/include/asm/arch-omap3/mmc_host_def.h +++ b/arch/arm/include/asm/arch-omap3/mmc_host_def.h @@ -29,13 +29,20 @@ #define T2_BASE 0x48002000
typedef struct t2 { - unsigned char res1[0x274]; + unsigned char res1[0x274]; /* 0x000 */ unsigned int devconf0; /* 0x274 */ - unsigned char res2[0x2A8]; + unsigned char res2[0x060]; /* 0x278 */ + unsigned int devconf1; /* 0x2D8 */ + unsigned char res3[0x244]; /* 0x2DC */ unsigned int pbias_lite; /* 0x520 */ } t2_t;
#define MMCSDIO1ADPCLKISEL (1 << 24) +#define MMCSDIO2ADPCLKISEL (1 << 6) + +#define EN_MMC1 (1 << 24) +#define EN_MMC2 (1 << 25) +#define EN_MMC3 (1 << 30)
#define PBIASLITEPWRDNZ0 (1 << 1) #define PBIASSPEEDCTRL0 (1 << 2) @@ -44,7 +51,9 @@ typedef struct t2 { /* * OMAP HSMMC register definitions */ -#define OMAP_HSMMC_BASE 0x4809C000 +#define OMAP_HSMMC1_BASE 0x4809C000 +#define OMAP_HSMMC2_BASE 0x480B4000 +#define OMAP_HSMMC3_BASE 0x480AD000
typedef struct hsmmc { unsigned char res1[0x10]; diff --git a/drivers/mmc/omap3_mmc.c b/drivers/mmc/omap3_mmc.c index 96c0e65..bf650ba 100644 --- a/drivers/mmc/omap3_mmc.c +++ b/drivers/mmc/omap3_mmc.c @@ -52,7 +52,27 @@ const unsigned short mmc_transspeed_val[15][4] = {
mmc_card_data cur_card_data; static block_dev_desc_t mmc_blk_dev; -static hsmmc_t *mmc_base = (hsmmc_t *)OMAP_HSMMC_BASE; +static hsmmc_t *mmc_base = (hsmmc_t *)OMAP_HSMMC1_BASE; + +unsigned char mmc_set_dev(int dev) +{ + switch (dev) { + case 1: + mmc_base = (hsmmc_t *)OMAP_HSMMC1_BASE; + break; + case 2: + mmc_base = (hsmmc_t *)OMAP_HSMMC2_BASE; + break; + case 3: + mmc_base = (hsmmc_t *)OMAP_HSMMC3_BASE; + break; + default: + mmc_base = (hsmmc_t *)OMAP_HSMMC1_BASE; + return 1; + } + + return 0; +}
block_dev_desc_t *mmc_get_dev(int dev) { @@ -62,6 +82,7 @@ block_dev_desc_t *mmc_get_dev(int dev) unsigned char mmc_board_init(void) { t2_t *t2_base = (t2_t *)T2_BASE; + struct prcm *prcm_base = (struct prcm *)PRCM_BASE;
#if defined(CONFIG_TWL4030_POWER) twl4030_power_mmc_init(); @@ -74,6 +95,17 @@ unsigned char mmc_board_init(void) writel(readl(&t2_base->devconf0) | MMCSDIO1ADPCLKISEL, &t2_base->devconf0);
+ writel(readl(&t2_base->devconf1) | MMCSDIO2ADPCLKISEL, + &t2_base->devconf1); + + writel(readl(&prcm_base->fclken1_core) | + EN_MMC1 | EN_MMC2 | EN_MMC3, + &prcm_base->fclken1_core); + + writel(readl(&prcm_base->iclken1_core) | + EN_MMC1 | EN_MMC2 | EN_MMC3, + &prcm_base->iclken1_core); + return 1; }
@@ -512,8 +544,11 @@ unsigned long mmc_bread(int dev_num, unsigned long blknr, lbaint_t blkcnt, return 1; }
-int mmc_legacy_init(int verbose) +int mmc_legacy_init(int dev) { + if (mmc_set_dev(dev) != 0) + return 1; + if (configure_mmc(&cur_card_data) != 1) return 1;
Tested on Overo
Thanks
There were checkpatch erros. I took care of it.
Applying to u-boot-ti
Paulraj, Sandeep
Steve Sakoman
